[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
Satish Balay
balay at mcs.anl.gov
Wed Apr 14 20:54:44 CDT 2021
1. You can avoid this complexity if you can use in-place install of PETSc [i.e do not use --prefix option to build PETSc]
2. For a prefix install - the following patch should fix the issue [i.e requires rerunning 'configure; make; make install']
diff --git a/config/BuildSystem/config/compilerOptions.py b/config/BuildSystem/config/compilerOptions.py
index bdfd209203..b2e02783d9 100644
--- a/config/BuildSystem/config/compilerOptions.py
+++ b/config/BuildSystem/config/compilerOptions.py
@@ -310,6 +310,7 @@ class CompilerOptions(config.base.Configure):
if not status:
if compiler.find('win32fe') > -1:
version = '\\n'.join(output.split('\n')[0:2])
+ version = version.replace('\r','')
else:
#PGI/Windows writes an empty '\r\n' on the first line of output
if output.count('\n') > 1 and output.split('\n')[0] == '\r':
3. For testing a prefix install - you would do:
cd /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
make check PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017 PETSC_ARCH=""
[these instructions are printed to the screen when you run 'make install'
Satish
On Thu, 15 Apr 2021, TAY wee-beng wrote:
> Hi Satish,
> I tried a few things, not sure if it's correct. But it doesn't seem to work
> I edit petscvariables in
> D:\Lib\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
> and
> D:\wtay\Downloads\Source_codes\petsc-3.15.0\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
> from:
> C_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
> 2017 11:10:38 AM
> \nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
> MPICC_SHOW = Unavailable
> Cxx_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
> 2017 11:10:38 AM
> MPICXX_SHOW = Unavailable
> FC_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
> 2017 11:10:38 AM
> \nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications running on
> Intel(R) 64, Version 2021.2.0 Build 20210228_000000
> to
> 2017 11:10:38 AM\nMicrosoft (R) C/C++ Optimizing Compiler Version
> 19.16.27045 for x64
> 19.16.27045 for x64
> 2017 11:10:38 AM\nIntel(R) Fortran Intel(R) 64 Compiler Classic for
> applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
> Then in cygwin,
> cd /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc
> export PETSC_DIR=`pwd`
> export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
> make check
> make: *** No rule to make target 'check'. Stop.
> Also:
> $ export PETSC_DIR=`pwd`
> make check
> petsc-3.15.0_win64_impi_vs2017/lib/petsc/conf/petscvariables:5: *** target
> pattern contains no '%'. Stop.
> Thank you very much.
> Yours sincerely,
> TAY Wee-Beng 郑伟明 (Zheng Weiming)
> Personal research webpage: _http://tayweebeng.wixsite.com/website_
> Youtube research showcase: _https://goo.gl/PtvdwQ_
> linkedin: _https://www.linkedin.com/in/tay-weebeng_
> >> Hi Satish,
> >> Sorry, what do you mean by "manually fix up this file"?
> >> Should I edit the petscvariables file?
> > yes
> >> Do I need to rebuild the lib?
> > no
> > After editing the file - run 'make check'
> > Satish
> >> I guess this problem is related to the new Intel oneAPI if I'm not wrong.
> >> No
> >> such problem previously.
> >> Yours sincerely,
> >>> 2017 11:10:38 AM
> >>> 27,
> >>> 2017 11:10:38 AM
> >>> 2017 11:10:38 AM
> >>> on
> >>> I'm not sure what happened here. You might want to just manually fix up
> >>> this
> >>> file
> >>> 19.16.27045 for x64
> >>> 27,
> >>> 19.16.27045 for x64
> >>> 20210228_000000
> >>> Satish
> >>>> Hi all,
> >>>> I have attached the req file
> >>>> Yours sincerely,
> >>>> On 14/4/2021 11:55 pm, Satish Balay wrote:
> >>>>> Please send the file
> >>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables
> >>>>> Satish
> >>>>> On Wed, 14 Apr 2021, TAY wee-beng wrote:
> >>>>>> Hi,
> >>>>>> I redo the installation:
> >>>>>> /*Now to install the libraries do:*//*
> >>>>>> *//*make PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
> >>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 install*//*
> >>>>>> *//*DELL-T7610+wtay at DELL-T7610
> >>>>>> /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*//*
> >>>>>> *//*$ make
> >>>>>> *//**** Using
> >>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 ****//*
> >>>>>> *//**** Installing PETSc at prefix location:
> >>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017 ****//*
> >>>>>> *//*Install complete.*//*
> >>>>>> *//*Now to check if the libraries are working do (in current
> >>>>>> directory):*//*
> >>>>>> *//*make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>>>>> PETSC_ARCH="" check*//*
> >>>>>> *//*/usr/bin/make --no-print-directory -f makefile
> >>>>>> mpi4py-install
> >>>>>> petsc4py-install libmesh-install mfem-insta*//*
> >>>>>> *//*ll slepc-install hpddm-install amrex-install bamg-install*//*
> >>>>>> *//*make[2]: Nothing to be done for 'mpi4py-install'.*//*
> >>>>>> *//*make[2]: Nothing to be done for 'petsc4py-install'.*//*
> >>>>>> *//*make[2]: Nothing to be done for 'libmesh-install'.*//*
> >>>>>> *//*make[2]: Nothing to be done for 'mfem-install'.*//*
> >>>>>> *//*make[2]: Nothing to be done for 'slepc-install'.*//*
> >>>>>> *//*make[2]: Nothing to be done for 'hpddm-install'.*//*
> >>>>>> *//*make[2]: Nothing to be done for 'amrex-install'.*//*
> >>>>>> *//*make[2]: Nothing to be done for 'bamg-install'.*//*
> >>>>>> I ran the check:
> >>>>>> /*$ make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
> >>>>>> *//*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables:5:
> >>>>>> *** missing separator. Stop.*/
> >>>>>> Why is this happening?
> >>>>>> Yours sincerely,
> >>>>>> On 14/4/2021 6:01 pm, Mark Adams wrote:
> >>>>>>> You have PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
> >>>>>>> I think you use PETSC_ARCH="" for installed libs.
> >>>>>>> When you do the install it will tell you exactly what to run to run
> >>>>>>> "check".
> >>>>>>> You might double check that .
> >>>>>>> Mark
> >>>>>>> On Wed, Apr 14, 2021 at 4:10 AM TAY wee-beng <zonexo at gmail.com
> >>>>>>> <mailto:zonexo at gmail.com>> wrote:
> >>>>>>> Hi Barry,
> >>>>>>> Ops, which dir should I run /*export PETSC_DIR=`pwd`*//*
> >>>>>>> Maybe I ran it wrongly initially at where the lib is stored:
> >>>>>>> /*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/*//*
> >>>>>>> My source is at
> >>>>>>> /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*/
> >>>>>>> Now I ran:
> >>>>>>> *//*cd src/ksp/ksp/tutorials/*//*
> >>>>>>> *//*make ex2f*/
> >>>>>>> /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe
> >>>>>>> ifort -MD -Z7 -fpp -MD -Z7 -fpp
> >>>>>>> -I/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/include
> >>>>>>> -I/cygdrive/d/wtay/Downloads/S*//*
> >>>>>>> *//*ource_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/include
> >>>>>>> -I/cygdrive/c/Program\ Files\
> >>>>>>> \(x86\)/Intel/oneAPI/mpi/latest/include ex2f.F90
> >>>>>>> -R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.*//*
> >>>>>>> *//*15.0_win64_impi_vs2017/lib
> >>>>>>> -L/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib
> >>>>>>> -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib
> >>>>>>> -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi*//*
> >>>>>>> *//*_vs2017/lib -lpetsc -lflapack -lfblas /cygdrive/c/Program\
> >>>>>>> Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib
> >>>>>>> \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib
> >>>>>>> /cygdrive/c/*//*
> >>>>>>> *//*Program\ Files\
> >>>>>>> \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib Gdi32.lib
> >>>>>>> User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex2f*//*
> >>>>>>> *//*ifort: command line warning #10006: ignoring unknown option
> >>>>>>> '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib'*//*
> >>>>>>> '/R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib'*//*
> >>>>>>> *//*ex2f.F90(80): error #6405: The same named entity from
> >>>>>>> different modules and/or program units cannot be referenced.
> >>>>>>> [PETSC_COMM_WORLD]*//*
> >>>>>>> *//* call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)*//*
> >>>>>>> *//*ex2f.F90(80): error #7112: This actual argument must not be
> >>>>>>> the name of a procedure. [PETSC_COMM_WORLD]*//*
> >>>>>>> *//*ex2f.F90(81): error #6405: The same named entity from
> >>>>>>> *//* call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)*//*
> >>>>>>> *//*ex2f.F90(81): error #7112: This actual argument must not be
> >>>>>>> *//*ex2f.F90(93): error #6405: The same named entity from
> >>>>>>> *//* call MatCreate(PETSC_COMM_WORLD,A,ierr)*//*
> >>>>>>> *//*ex2f.F90(93): error #7112: This actual argument must not be
> >>>>>>> *//*ex2f.F90(159): error #6405: The same named entity from
> >>>>>>> *//* call
> >>>>>>> VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)*//*
> >>>>>>> *//*ex2f.F90(159): error #7112: This actual argument must not
> >>>>>>> be
> >>>>>>> *//* call
> >>>>>>> *//*ex2f.F90(171): error #6405: The same named entity from
> >>>>>>> *//* call
> >>>>>>> PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)*//*
> >>>>>>> *//*ex2f.F90(171): error #7112: This actual argument must not
> >>>>>>> be
> >>>>>>> *//* call
> >>>>>>> *//*ex2f.F90(193): error #6405: The same named entity from
> >>>>>>> *//* call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)*//*
> >>>>>>> *//*ex2f.F90(193): error #7112: This actual argument must not
> >>>>>>> be
> >>>>>>> *//*ex2f.F90(319): error #6405: The same named entity from
> >>>>>>> *//*ex2f.F90(319): error #7112: This actual argument must not
> >>>>>>> be
> >>>>>>> *//*compilation aborted for ex2f.F90 (code 1)*//*
> >>>>>>> *//*make: ***
> >>>>>>> [/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/conf/test:23:
> >>>>>>> ex2f] Error 1*/
> >>>>>>> I have also attached the "/*make check*/" output. Seems like
> >>>>>>> there's problem with fortran compile.
> >>>>>>> Yours sincerely,
> >>>>>>> <http://tayweebeng.wixsite.com/website>_
> >>>>>>> <https://goo.gl/PtvdwQ>_
> >>>>>>> <https://www.linkedin.com/in/tay-weebeng>_
> >>>>>>> On 14/4/2021 3:47 pm, Barry Smith wrote:
> >>>>>>>> Please send configure.log and make.log and the results of
> >>>>>>>> "make
> >>>>>>>> check" so we have the details on the build process.
> >>>>>>>>> /*No rule to make target
> >>>>>>>>> '/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
> >>>>>>>>> Stop.*/
> >>>>>>>> Looks funny; it does not seem to separate the PETSc directory
> >>>>>>>> from its configuration directory appropriately.
> >>>>>>>> Are you sure
> >>>>>>>>> *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*/
> >>>>>>>> are run in the appropriate directory so that PETSC_DIR is
> >>>>>>>> correct.
> >>>>>>>> Barry
> >>>>>>>>> On Apr 14, 2021, at 2:20 AM, TAY wee-beng <zonexo at gmail.com
> >>>>>>>>> Hi Mark,
> >>>>>>>>> I'm not sure what's wrong.
> >>>>>>>>> In VS2017 + Intel oneAPI,
> >>>>>>>>> even after adding the full path:
> >>>>>>>>> #include
> >>>>>>>>> <D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
> >>>>>>>>> I got a new error:
> >>>>>>>>> /*Compiling with Intel® Fortran Compiler Classic 2021.2.0
> >>>>>>>>> [Intel(R) 64]...*//*
> >>>>>>>>> *//*ex2f.F90*//*
> >>>>>>>>> *//*petscksp.h(8): #error: can't find include file:
> >>>>>>>>> petsc/finclude/petscpc.h*//*
> >>>>>>>>> *//*ex2f : error PRJ0019: A tool returned an error code*/
> >>>>>>>>> Note that I have also specified the include dir in the
> >>>>>>>>> properties:
> >>>>>>>>> /*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
> >>>>>>>>> I also tried in cygwin:
> >>>>>>>>> *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
> >>>>>>>>> *//*make ex2f*/
> >>>>>>>>> I got the error:
> >>>>>>>>> /*$ make ex2f*//*
> >>>>>>>>> *//*makefile:41:
> >>>>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
> >>>>>>>>> No such file or directory*//*
> >>>>>>>>> *//*make: *** No rule to make target
> >>>>>>>>> Stop.*/
> >>>>>>>>> Somehow it just doesn't work. Building the library has no
> >>>>>>>>> problem though.
> >>>>>>>>> I wonder what's wrong.
> >>>>>>>>> Yours sincerely,
> >>>>>>>>> On 14/4/2021 9:31 am, Mark Adams wrote:
> >>>>>>>>>> PETSc has changed Fortran syntax since v3.9. You should
> >>>>>>>>>> upgrade. Look at examples for how to use modules etc.
> >>>>>>>>>> 2021.2.0
> >>>>>>>>>> *//*global.F90*//*
> >>>>>>>>>> *//*global.F90(3): #error: can't find include file:
> >>>>>>>>>> petsc/finclude/petsc.h*//*
> >>>>>>>>>> *//*global.F90(937): #error: can't find include file:
> >>>>>>>>>> It looks like you might not have your PETSC_ARCH
> >>>>>>>>>> variable set.
> >>>>>>>>>> You should get a full path to /finclude/petsc.h. Look at the
> >>>>>>>>>> compile line.
> >>>>>>>>>> There are PETSc examples that you you can make to see an
> >>>>>>>>>> example of a correct make. For example,
> >>>>>>>>>> > cd petsc/src/ksp/ksp/tutorials
> >>>>>>>>>> > > > > > > > > > > > > > > > > make
> >>>>>>>>>> > > > > > > > > ex2f
> >>>>>>>>>> should make an executable and you can look at the compile
> >>>>>>>>>> and
> >>>>>>>>>> link lines, and compare to what you are using.
> >>>>>>>>>> Mark
> >>>>>>>>>> Yours sincerely,
