[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
TAY wee-beng zonexo at gmail.com
Wed Apr 14 20:43:10 CDT 2021
Hi Satish,
I tried a few things, not sure if it's correct. But it doesn't seem to work
I edit petscvariables in
D:\Lib\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
and
D:\wtay\Downloads\Source_codes\petsc-3.15.0\petsc-3.15.0_win64_impi_vs2017\lib\petsc\conf
C_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
2017 11:10:38 AM
\nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
MPICC_SHOW = Unavailable
Cxx_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
2017 11:10:38 AM
MPICXX_SHOW = Unavailable
FC_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27,
2017 11:10:38 AM
\nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications running on
Intel(R) 64, Version 2021.2.0 Build 20210228_000000
to
2017 11:10:38 AM\nMicrosoft (R) C/C++ Optimizing Compiler Version
19.16.27045 for x64
19.16.27045 for x64
2017 11:10:38 AM\nIntel(R) Fortran Intel(R) 64 Compiler Classic for
applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
Then in cygwin,
cd /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc
export PETSC_DIR=`pwd`
export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
make check
make: *** No rule to make target 'check'.  Stop.
Also:
/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
$ export PETSC_DIR=`pwd`
make check
petsc-3.15.0_win64_impi_vs2017/lib/petsc/conf/petscvariables:5: ***
target pattern contains no '%'.  Stop.
Thank you very much.
Yours sincerely,
TAY Wee-Beng 郑伟明 (Zheng Weiming)
Personal research webpage: _http://tayweebeng.wixsite.com/website_
Youtube research showcase: _https://goo.gl/PtvdwQ_
linkedin: _https://www.linkedin.com/in/tay-weebeng_
On 15/4/2021 9:22 am, Satish Balay wrote:
> On Thu, 15 Apr 2021, TAY wee-beng wrote:
>> Hi Satish,
>> Sorry, what do you mean by "manually fix up this file"?
>> Should I edit the petscvariables file?
> yes
>> Do I need to rebuild the lib?
> no
> After editing the file - run 'make check'
> Satish
>> I guess this problem is related to the new Intel oneAPI if I'm not wrong. No
>> such problem previously.
>> Yours sincerely,
>>> 2017 11:10:38 AM
>>> 2017 11:10:38 AM
>>> 2017 11:10:38 AM
>>> I'm not sure what happened here. You might want to just manually fix up this
>>> file
>>> 19.16.27045 for x64
>>> 19.16.27045 for x64
>>> Satish
>>>> Hi all,
>>>> I have attached the req file
>>>> Yours sincerely,
>>>> On 14/4/2021 11:55 pm, Satish Balay wrote:
>>>>> Please send the file
>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables
>>>>> Satish
>>>>> On Wed, 14 Apr 2021, TAY wee-beng wrote:
>>>>>> Hi,
>>>>>> I redo the installation:
>>>>>> /*Now to install the libraries do:*//*
>>>>>> *//*make PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 install*//*
>>>>>> *//*DELL-T7610+wtay at DELL-T7610
>>>>>> /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*//*
>>>>>> *//*$ make PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>>>>>> *//**** Using
>>>>>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 ****//*
>>>>>> *//**** Installing PETSc at prefix location:
>>>>>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017  ****//*
>>>>>> *//*Install complete.*//*
>>>>>> *//*Now to check if the libraries are working do (in current
>>>>>> directory):*//*
>>>>>> *//*make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>>>>> PETSC_ARCH="" check*//*
>>>>>> *//*/usr/bin/make  --no-print-directory -f makefile
>>>>>> mpi4py-install
>>>>>> petsc4py-install libmesh-install mfem-insta*//*
>>>>>> *//*ll slepc-install hpddm-install amrex-install bamg-install*//*
>>>>>> *//*make[2]: Nothing to be done for 'mpi4py-install'.*//*
>>>>>> *//*make[2]: Nothing to be done for 'petsc4py-install'.*//*
>>>>>> *//*make[2]: Nothing to be done for 'libmesh-install'.*//*
>>>>>> *//*make[2]: Nothing to be done for 'mfem-install'.*//*
>>>>>> *//*make[2]: Nothing to be done for 'slepc-install'.*//*
>>>>>> *//*make[2]: Nothing to be done for 'hpddm-install'.*//*
>>>>>> *//*make[2]: Nothing to be done for 'amrex-install'.*//*
>>>>>> *//*make[2]: Nothing to be done for 'bamg-install'.*//*
>>>>>> I ran the check:
>>>>>> /*$ make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>>>>>> *//*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables:5:
>>>>>> *** missing separator.  Stop.*/
>>>>>> Why is this happening?
>>>>>> Yours sincerely,
>>>>>> On 14/4/2021 6:01 pm, Mark Adams wrote:
>>>>>>> You have PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
>>>>>>> I think you use PETSC_ARCH="" for installed libs.
>>>>>>> When you do the install it will tell you exactly what to run to run
>>>>>>> "check".
>>>>>>> You might double check that .
>>>>>>> Mark
>>>>>>> On Wed, Apr 14, 2021 at 4:10 AM TAY wee-beng <zonexo at gmail.com
>>>>>>> <mailto:zonexo at gmail.com>> wrote:
>>>>>>>        Hi Barry,
>>>>>>>        Ops, which dir should I run /*export PETSC_DIR=`pwd`*//*
>>>>>>>        Maybe I ran it wrongly initially at where the lib is stored:
>>>>>>>        /*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/*//*
>>>>>>>        My source is at
>>>>>>>        /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*/
>>>>>>>        Now I ran:
>>>>>>>        *//*cd src/ksp/ksp/tutorials/*//*
>>>>>>>        *//*make ex2f*/
>>>>>>>        /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe
>>>>>>>        ifort -MD -Z7 -fpp  -MD -Z7 -fpp
>>>>>>>        -I/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/include
>>>>>>>        -I/cygdrive/d/wtay/Downloads/S*//*
>>>>>>>        *//*ource_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/include
>>>>>>>        -I/cygdrive/c/Program\ Files\
>>>>>>>        \(x86\)/Intel/oneAPI/mpi/latest/include     ex2f.F90
>>>>>>>        -R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.*//*
>>>>>>>        *//*15.0_win64_impi_vs2017/lib
>>>>>>>        -L/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib
>>>>>>>        -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib
>>>>>>>        -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi*//*
>>>>>>>        *//*_vs2017/lib -lpetsc -lflapack -lfblas /cygdrive/c/Program\
>>>>>>>        Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib
>>>>>>>        \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib
>>>>>>>        /cygdrive/c/*//*
>>>>>>>        *//*Program\ Files\
>>>>>>>        \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib Gdi32.lib
>>>>>>>        User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex2f*//*
>>>>>>>        *//*ifort: command line warning #10006: ignoring unknown option
>>>>>>>        '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib'*//*
>>>>>>>        '/R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib'*//*
>>>>>>>        *//*ex2f.F90(80): error #6405: The same named entity from
>>>>>>>        different modules and/or program units cannot be referenced.
>>>>>>>        [PETSC_COMM_WORLD]*//*
>>>>>>>        *//*      call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)*//*
>>>>>>>        *//*ex2f.F90(80): error #7112: This actual argument must not be
>>>>>>>        the name of a procedure. [PETSC_COMM_WORLD]*//*
>>>>>>>        *//*ex2f.F90(81): error #6405: The same named entity from
>>>>>>>        *//*      call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)*//*
>>>>>>>        *//*ex2f.F90(81): error #7112: This actual argument must not be
>>>>>>>        *//*ex2f.F90(93): error #6405: The same named entity from
>>>>>>>        *//*      call MatCreate(PETSC_COMM_WORLD,A,ierr)*//*
>>>>>>>        *//*ex2f.F90(93): error #7112: This actual argument must not be
>>>>>>>        *//*ex2f.F90(159): error #6405: The same named entity from
>>>>>>>        *//*      call
>>>>>>>        VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)*//*
>>>>>>>        *//*ex2f.F90(159): error #7112: This actual argument must not be
>>>>>>>        *//*      call
>>>>>>>        *//*ex2f.F90(171): error #6405: The same named entity from
>>>>>>>        *//*         call
>>>>>>>        PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)*//*
>>>>>>>        *//*ex2f.F90(171): error #7112: This actual argument must not be
>>>>>>>        *//*         call
>>>>>>>        *//*ex2f.F90(193): error #6405: The same named entity from
>>>>>>>        *//*      call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)*//*
>>>>>>>        *//*ex2f.F90(193): error #7112: This actual argument must not be
>>>>>>>        *//*ex2f.F90(319): error #6405: The same named entity from
>>>>>>>        *//*ex2f.F90(319): error #7112: This actual argument must not be
>>>>>>>        *//*compilation aborted for ex2f.F90 (code 1)*//*
>>>>>>>        *//*make: ***
>>>>>>>        [/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/conf/test:23:
>>>>>>>        ex2f] Error 1*/
>>>>>>>        I have also attached the "/*make check*/" output. Seems like
>>>>>>>        there's problem with fortran compile.
>>>>>>>        Yours sincerely,
>>>>>>>        <http://tayweebeng.wixsite.com/website>_
>>>>>>>        <https://goo.gl/PtvdwQ>_
>>>>>>>        <https://www.linkedin.com/in/tay-weebeng>_
>>>>>>>        On 14/4/2021 3:47 pm, Barry Smith wrote:
>>>>>>>>         Please send configure.log and make.log and the results of "make
>>>>>>>>        check" so we have the details on the build process.
>>>>>>>>>        /*No rule to make target
>>>>>>>>>        '/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
>>>>>>>>>        Stop.*/
>>>>>>>>         Looks funny; it does not seem to separate the PETSc directory
>>>>>>>>        from its configuration directory appropriately.
>>>>>>>>          Are you sure
>>>>>>>>>        *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*/
>>>>>>>>        are run in the appropriate directory so that PETSC_DIR is
>>>>>>>>        correct.
>>>>>>>>        Barry
>>>>>>>>>        On Apr 14, 2021, at 2:20 AM, TAY wee-beng <zonexo at gmail.com
>>>>>>>>>        Hi Mark,
>>>>>>>>>        I'm not sure what's wrong.
>>>>>>>>>        In VS2017 + Intel oneAPI,
>>>>>>>>>        even after adding the full path:
>>>>>>>>>        #include
>>>>>>>>>        <D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
>>>>>>>>>        I got a new error:
>>>>>>>>>        /*Compiling with Intel® Fortran Compiler Classic 2021.2.0
>>>>>>>>>        [Intel(R) 64]...*//*
>>>>>>>>>        *//*ex2f.F90*//*
>>>>>>>>>        *//*petscksp.h(8): #error: can't find include file:
>>>>>>>>>        petsc/finclude/petscpc.h*//*
>>>>>>>>>        *//*ex2f : error PRJ0019: A tool returned an error code*/
>>>>>>>>>        Note that I have also specified the include dir in the
>>>>>>>>>        properties:
>>>>>>>>>        /*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
>>>>>>>>>        I also tried in cygwin:
>>>>>>>>>        *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
>>>>>>>>>        *//*make ex2f*/
>>>>>>>>>        I got the error:
>>>>>>>>>        /*$ make ex2f*//*
>>>>>>>>>        *//*makefile:41:
>>>>>>>>>        /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
>>>>>>>>>        No such file or directory*//*
>>>>>>>>>        *//*make: *** No rule to make target
>>>>>>>>>        Stop.*/
>>>>>>>>>        Somehow it just doesn't work. Building the library has no
>>>>>>>>>        problem though.
>>>>>>>>>        I wonder what's wrong.
>>>>>>>>>        Yours sincerely,
>>>>>>>>>        On 14/4/2021 9:31 am, Mark Adams wrote:
>>>>>>>>>>        PETSc has changed Fortran syntax since v3.9. You should
>>>>>>>>>>        upgrade. Look at examples for how to use modules etc.
>>>>>>>>>>            *//*global.F90*//*
>>>>>>>>>>            *//*global.F90(3): #error: can't find include file:
>>>>>>>>>>            petsc/finclude/petsc.h*//*
>>>>>>>>>>            *//*global.F90(937): #error: can't find include file:
>>>>>>>>>>        It looks like you might not have your PETSC_ARCH variable set.
>>>>>>>>>>        You should get a full path to /finclude/petsc.h. Look at the
>>>>>>>>>>        compile line.
>>>>>>>>>>        There are PETSc examples that you you can make to see an
>>>>>>>>>>        example of a correct make. For example,
>>>>>>>>>>        > cd petsc/src/ksp/ksp/tutorials
>>>>>>>>>>         >  >  >  >  >  >  >  > make ex2f
>>>>>>>>>>        should make an executable and you can look at the compile and
>>>>>>>>>>        link lines, and compare to what you are using.
>>>>>>>>>>        Mark
>>>>>>>>>>            Yours sincerely,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210415/b5da49d7/attachment-0001.html>
