[petsc-users] Can't compile code after upgrading to VS2017 and Intel One API + PETSc 3.15
TAY wee-beng zonexo at gmail.com
Wed Apr 14 19:26:41 CDT 2021
Hi all,
I have attached the req file
Thank you very much.
Yours sincerely,
TAY Wee-Beng 郑伟明 (Zheng Weiming)
Personal research webpage: _http://tayweebeng.wixsite.com/website_
Youtube research showcase: _https://goo.gl/PtvdwQ_
linkedin: _https://www.linkedin.com/in/tay-weebeng_
On 14/4/2021 11:55 pm, Satish Balay wrote:
> Please send the file /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables
> Satish
> On Wed, 14 Apr 2021, TAY wee-beng wrote:
>> Hi,
>> I redo the installation:
>> /*Now to install the libraries do:*//*
>> *//*make PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 install*//*
>> *//*DELL-T7610+wtay at DELL-T7610
>> /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*//*
>> *//*$ make PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>> *//**** Using PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0
>> PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017 ****//*
>> *//**** Installing PETSc at prefix location:
>> /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017  ****//*
>> *//*Install complete.*//*
>> *//*Now to check if the libraries are working do (in current directory):*//*
>> *//*make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>> PETSC_ARCH="" check*//*
>> *//*/usr/bin/make  --no-print-directory -f makefile
>> PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0 mpi4py-install
>> petsc4py-install libmesh-install mfem-insta*//*
>> *//*ll slepc-install hpddm-install amrex-install bamg-install*//*
>> *//*make[2]: Nothing to be done for 'mpi4py-install'.*//*
>> *//*make[2]: Nothing to be done for 'petsc4py-install'.*//*
>> *//*make[2]: Nothing to be done for 'libmesh-install'.*//*
>> *//*make[2]: Nothing to be done for 'mfem-install'.*//*
>> *//*make[2]: Nothing to be done for 'slepc-install'.*//*
>> *//*make[2]: Nothing to be done for 'hpddm-install'.*//*
>> *//*make[2]: Nothing to be done for 'amrex-install'.*//*
>> *//*make[2]: Nothing to be done for 'bamg-install'.*//*
>> I ran the check:
>> /*$ make PETSC_DIR=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
>> *//*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017//lib/petsc/conf/petscvariables:5:
>> *** missing separator.  Stop.*/
>> Why is this happening?
>> Yours sincerely,
>> On 14/4/2021 6:01 pm, Mark Adams wrote:
>>> You have PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017
>>> I think you use PETSC_ARCH="" for installed libs.
>>> When you do the install it will tell you exactly what to run to run "check".
>>> You might double check that .
>>> Mark
>>> On Wed, Apr 14, 2021 at 4:10 AM TAY wee-beng <zonexo at gmail.com
>>> <mailto:zonexo at gmail.com>> wrote:
>>>      Hi Barry,
>>>      Ops, which dir should I run /*export PETSC_DIR=`pwd`*//*
>>>      Maybe I ran it wrongly initially at where the lib is stored:
>>>      /*/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/*//*
>>>      My source is at
>>>      /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0*/
>>>      Now I ran:
>>>      *//*cd src/ksp/ksp/tutorials/*//*
>>>      *//*make ex2f*/
>>>      /*/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe
>>>      ifort -MD -Z7 -fpp  -MD -Z7 -fpp
>>>      -I/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/include
>>>      -I/cygdrive/d/wtay/Downloads/S*//*
>>>      *//*ource_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/include
>>>      -I/cygdrive/c/Program\ Files\
>>>      \(x86\)/Intel/oneAPI/mpi/latest/include     ex2f.F90
>>>      -R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.*//*
>>>      *//*15.0_win64_impi_vs2017/lib
>>>      -L/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib
>>>      -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib
>>>      -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi*//*
>>>      *//*_vs2017/lib -lpetsc -lflapack -lfblas /cygdrive/c/Program\
>>>      Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib
>>>      \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib /cygdrive/c/*//*
>>>      *//*Program\ Files\
>>>      \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib Gdi32.lib
>>>      User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex2f*//*
>>>      *//*ifort: command line warning #10006: ignoring unknown option
>>>      '/R/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/petsc-3.15.0_win64_impi_vs2017/lib'*//*
>>>      '/R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib'*//*
>>>      *//*ex2f.F90(80): error #6405: The same named entity from
>>>      different modules and/or program units cannot be referenced.
>>>      [PETSC_COMM_WORLD]*//*
>>>      *//*      call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)*//*
>>>      *//*ex2f.F90(80): error #7112: This actual argument must not be
>>>      the name of a procedure. [PETSC_COMM_WORLD]*//*
>>>      *//*ex2f.F90(81): error #6405: The same named entity from
>>>      *//*      call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)*//*
>>>      *//*ex2f.F90(81): error #7112: This actual argument must not be
>>>      *//*ex2f.F90(93): error #6405: The same named entity from
>>>      *//*      call MatCreate(PETSC_COMM_WORLD,A,ierr)*//*
>>>      *//*ex2f.F90(93): error #7112: This actual argument must not be
>>>      *//*ex2f.F90(159): error #6405: The same named entity from
>>>      *//*      call
>>>      VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)*//*
>>>      *//*ex2f.F90(159): error #7112: This actual argument must not be
>>>      *//*      call
>>>      *//*ex2f.F90(171): error #6405: The same named entity from
>>>      *//*         call PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)*//*
>>>      *//*ex2f.F90(171): error #7112: This actual argument must not be
>>>      *//*ex2f.F90(193): error #6405: The same named entity from
>>>      *//*      call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)*//*
>>>      *//*ex2f.F90(193): error #7112: This actual argument must not be
>>>      *//*ex2f.F90(319): error #6405: The same named entity from
>>>      *//*ex2f.F90(319): error #7112: This actual argument must not be
>>>      *//*compilation aborted for ex2f.F90 (code 1)*//*
>>>      *//*make: ***
>>>      [/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/conf/test:23:
>>>      ex2f] Error 1*/
>>>      I have also attached the "/*make check*/" output. Seems like
>>>      there's problem with fortran compile.
>>>      Yours sincerely,
>>>      <http://tayweebeng.wixsite.com/website>_
>>>      <https://goo.gl/PtvdwQ>_
>>>      <https://www.linkedin.com/in/tay-weebeng>_
>>>      On 14/4/2021 3:47 pm, Barry Smith wrote:
>>>>       Please send configure.log and make.log and the results of "make
>>>>      check" so we have the details on the build process.
>>>>>      /*No rule to make target
>>>>>      '/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutori*//*als/lib/petsc/conf/test'.
>>>>>      Stop.*/
>>>>       Looks funny; it does not seem to separate the PETSc directory
>>>>      from its configuration directory appropriately.
>>>>        Are you sure
>>>>>      *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*/
>>>>      are run in the appropriate directory so that PETSC_DIR is correct.
>>>>      Barry
>>>>>      On Apr 14, 2021, at 2:20 AM, TAY wee-beng <zonexo at gmail.com
>>>>>      Hi Mark,
>>>>>      I'm not sure what's wrong.
>>>>>      In VS2017 + Intel oneAPI,
>>>>>      even after adding the full path:
>>>>>      #include
>>>>>      <D:/Lib/petsc-3.15.0_win64_impi_vs2017/include/petsc/finclude/petscksp.h>
>>>>>      I got a new error:
>>>>>      /*Compiling with Intel® Fortran Compiler Classic 2021.2.0
>>>>>      [Intel(R) 64]...*//*
>>>>>      *//*ex2f.F90*//*
>>>>>      *//*petscksp.h(8): #error: can't find include file:
>>>>>      petsc/finclude/petscpc.h*//*
>>>>>      *//*ex2f : error PRJ0019: A tool returned an error code*/
>>>>>      Note that I have also specified the include dir in the properties:
>>>>>      /*Debug/;$(PETSC_DIR);$(PETSC_DIR)/include;$(I_MPI_ONEAPI_ROOT)/include*/
>>>>>      I also tried in cygwin:
>>>>>      *//*export PETSC_ARCH=petsc-3.15.0_win64_impi_vs2017*//*
>>>>>      *//*make ex2f*/
>>>>>      I got the error:
>>>>>      /*$ make ex2f*//*
>>>>>      *//*makefile:41:
>>>>>      /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/share/petsc/examples/src/ksp/ksp/tutorials/lib/petsc/conf/te*//*st:
>>>>>      No such file or directory*//*
>>>>>      *//*make: *** No rule to make target
>>>>>      Stop.*/
>>>>>      Somehow it just doesn't work. Building the library has no
>>>>>      problem though.
>>>>>      I wonder what's wrong.
>>>>>      Yours sincerely,
>>>>>      On 14/4/2021 9:31 am, Mark Adams wrote:
>>>>>>      PETSc has changed Fortran syntax since v3.9. You should
>>>>>>      upgrade. Look at examples for how to use modules etc.
>>>>>>          *//*global.F90*//*
>>>>>>          *//*global.F90(3): #error: can't find include file:
>>>>>>          petsc/finclude/petsc.h*//*
>>>>>>          *//*global.F90(937): #error: can't find include file:
>>>>>>      It looks like you might not have your PETSC_ARCH variable set.
>>>>>>      You should get a full path to /finclude/petsc.h. Look at the
>>>>>>      compile line.
>>>>>>      There are PETSc examples that you you can make to see an
>>>>>>      example of a correct make. For example,
>>>>>>      > cd petsc/src/ksp/ksp/tutorials
>>>>>>       >  > make ex2f
>>>>>>      should make an executable and you can look at the compile and
>>>>>>      link lines, and compare to what you are using.
>>>>>>      Mark
>>>>>>          Yours sincerely,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210415/b8f53884/attachment-0001.html>
FAST_AR_FLAGS = Scq
AR_FLAGS = cr
AR_ARGFILE = yes
C_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
\nMicrosoft (R) C/C++ Optimizing Compiler Version 19.16.27045 for x64
MPICC_SHOW = Unavailable
Cxx_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
MPICXX_SHOW = Unavailable
FC_VERSION = Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
\nIntel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
MPIFC_SHOW = Unavailable
FC_DEFINE_FLAG = -D
wPETSC_DIR = D:/Lib/petsc-3.15.0_win64_impi_vs2017
CC_FLAGS =  -MD -wd4996 -Z7
CXXPP_FLAGS =
CXX_FLAGS =  -MD -GR -EHsc -Z7 -Zm200   -TP
CXX_LINKER = /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe cl
CXX_LINKER_FLAGS =  -Qwd10161  -MD -GR -EHsc -Z7 -Zm200
CPP_FLAGS =
PCC = /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe cl
PCC_FLAGS =  -MD -wd4996 -Z7
PCPP_FLAGS =
PFLAGS = ${CFLAGS}
PPPFLAGS = ${CPPFLAGS}
PY_CFLAGS =
PY_CPPFLAGS =
CC_SUFFIX = o
PCC_LINKER = /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe cl
PCC_LINKER_FLAGS =  -Qwd10161  -MD -wd4996 -Z7
CC_LINKER_SUFFIX =
FPP_FLAGS =
FC_FLAGS =  -MD -Z7 -fpp
FC_SUFFIX = o
FC_LINKER = /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe ifort
FC_LINKER_FLAGS =    -MD -Z7 -fpp
FC_MODULE_FLAG = -I
FC_MODULE_OUTPUT_FLAG = -module:
SL_LINKER = /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe cl
SL_LINKER_FLAGS = ${PCC_LINKER_FLAGS}
SL_LINKER_SUFFIX = dll
SL_LINKER_LIBS = ${PETSC_EXTERNAL_LIB_BASIC}
PETSC_LANGUAGE = CONLY
PETSC_SCALAR = real
PETSC_PRECISION = double
BLASLAPACK_LIB = -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib -lflapack -lfblas
BLASLAPACK_INCLUDE =
FBLASLAPACK_LIB =
FBLASLAPACK_INCLUDE =
MATHLIB_LIB =
MATHLIB_INCLUDE =
MPI_LIB = /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib
MPI_INCLUDE = -I/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/include
PETSC_EXTERNAL_LIB_BASIC = -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib -lflapack -lfblas /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib
PETSC_CC_INCLUDES = -I/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/include -I/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/include
PETSC_FC_INCLUDES = -I/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/include -I/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/include
LIBNAME = ${INSTALL_LIB_DIR}/libpetsc.${AR_LIB_SUFFIX}
SHLIBS = libpetsc
PETSC_LIB_BASIC = -lpetsc
PETSC_KSP_LIB_BASIC = -lpetsc
PETSC_TS_LIB_BASIC = -lpetsc
PETSC_TAO_LIB_BASIC = -lpetsc
PETSC_WITH_EXTERNAL_LIB = -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib -R/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib -L/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017/lib -lpetsc -lflapack -lfblas /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib
PETSC_SYS_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_VEC_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_MAT_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_DM_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_KSP_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_SNES_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_TS_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_TAO_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_CHARACTERISTIC_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_CONTRIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
CONFIGURE_OPTIONS = --with-cc=\"win32fe cl\" --with-fc=\"win32fe ifort\" --with-cxx=\"win32fe cl\" --with-mpi-include=\"/cygdrive/c/Program Files (x86)/Intel/oneAPI/mpi/latest/include\" --with-mpi-lib=\"[/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impi.lib,/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/debug/impicxx.lib,/cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/lib/libmpi_ilp64.lib]\" --download-fblaslapack=1 --prefix=/cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017 --with-debugging=1 --with-fortran-interfaces=1
MKDIR = /usr/bin/mkdir -p
SHELL = /usr/bin/bash
SED = /usr/bin/sed
SEDINPLACE = /usr/bin/sed -i
MV = /usr/bin/mv
CP = /usr/bin/cp
GREP = /usr/bin/grep
RM = /usr/bin/rm -f
DIFF = /usr/bin/diff -w
PYTHON = /usr/bin/python3
CPP = /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe cl -E
CXX = /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe cl
CXXPP = /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe cl -E
FC = /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe ifort
AR = /usr/bin/ar
RANLIB = /usr/bin/ranlib
AR_LIB_SUFFIX = lib
LD_SHARED = /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.15.0/lib/petsc/bin/win32fe/win32fe cl
CC_LINKER_SLFLAG = -R
FC_LINKER_SLFLAG = -Wl,-rpath,
CLANGUAGE = C
PREFIXDIR = /cygdrive/d/Lib/petsc-3.15.0_win64_impi_vs2017
PETSC_SCALAR_SIZE = 64
PETSC_INDEX_SIZE = 32
MAKE = /usr/bin/make
MAKE_USER = make
OMAKE_PRINTDIR  = /usr/bin/make  --print-directory
OMAKE = /usr/bin/make  --no-print-directory
MAKE_PAR_OUT_FLG = --output-sync=recurse
MAKE_NP = 32
MAKE_TEST_NP = 21
MAKE_LOAD = 72.0
NPMAX = 48
SONAME_FUNCTION = $(1).dll
SL_LINKER_FUNCTION = -LD
PETSC_DLL_EXPORTS = 1
BUILDSHAREDLIB = yes
DSYMUTIL = true
MPIEXECEXECUTABLE = /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/bin/mpiexec
MPIEXEC = /cygdrive/c/Program\ Files\ \(x86\)/Intel/oneAPI/mpi/latest/bin/mpiexec
HOSTNAME = hostname
PING = ping
CMAKE = /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/cmake
CTEST = /cygdrive/c/Program Files (x86)/Microsoft Visual Studio/2017/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/ctest
