[petsc-users] Undefined reference in PETSc 3.13+ with old MPI version
Junchao Zhang
junchao.zhang at gmail.com
Sun Apr 11 09:54:05 CDT 2021
Thanks, Glad to know you have a workaround.
--Junchao Zhang
On Sat, Apr 10, 2021 at 10:06 PM Danyang Su <danyang.su at gmail.com> wrote:
> Hi Junchao,
> I cannot configure your branch with same options due to the error in
> sowing. I had similar error before on other clusters with very old openmpi
> version. Problem was solved when openmpi was updated to a newer one.
> At this moment, I configured a PETSc version with Openmpi 2.1.6 version
> and it seems working properly.
> Thanks and have a good rest of the weekend,
> Danyang
> *From: *Danyang Su <danyang.su at gmail.com>
> *Date: *Saturday, April 10, 2021 at 4:08 PM
> *To: *Junchao Zhang <junchao.zhang at gmail.com>
> *Cc: *Barry Smith <bsmith at petsc.dev>, "petsc-users at mcs.anl.gov" <
> petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Undefined reference in PETSc 3.13+ with old
> MPI version
> Hi Junchao,
> The configuration is successful. The error comes from the last step when I
> run
> make PETSC_DIR=/home/danyangs/soft/petsc/petsc-3.13.6
> PETSC_ARCH=linux-intel-openmpi check
> ********************Error detected during compile or
> link!********************
> *See http://www.mcs.anl.gov/petsc/documentation/faq.html
> <http://www.mcs.anl.gov/petsc/documentation/faq.html>*
> */home/danyangs/soft/petsc/petsc-3.13.6/src/snes/tutorials ex5f*
> mpif90 -fPIC -O3 -march=native -mtune=nativels
> -I/home/danyangs/soft/petsc/petsc-3.13.6/include
> -I/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/include
> ex5f.F90
> -Wl,-rpath,/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/lib
> -L/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/lib
> -Wl,-rpath,/global/software/intel/composer_xe_2013_sp1.2.144/mkl/lib/intel64
> -L/global/software/intel/composer_xe_2013_sp1.2.144/mkl/lib/intel64
> -Wl,-rpath,/global/software/intel/composer_xe_2013_sp1.2.144/compiler/lib/intel64
> -L/global/software/intel/composer_xe_2013_sp1.2.144/compiler/lib/intel64
> -Wl,-rpath,/global/software/openmpi-1.6.5/intel/lib64
> -L/global/software/openmpi-1.6.5/intel/lib64
> -Wl,-rpath,/global/software/intel/composerxe/mkl/lib/intel64
> -L/global/software/intel/composerxe/mkl/lib/intel64
> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.7
> -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7
> -Wl,-rpath,/global/software/intel/composerxe/lib/intel64 -lpetsc -lHYPRE
> -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack
> -lsuperlu -lflapack -lfblas -lX11 -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl
> -lhdf5 -lparmetis -lmetis -lstdc++ -ldl -lmpi_f90 -lmpi_f77 -lmpi -lm
> -lnuma -lrt -lnsl -lutil -limf -lifport -lifcore -lsvml -lipgo -lintlc
> -lpthread -lgcc_s -lirc_s -lstdc++ -ldl -o ex5f
> ifort: command line warning #10159: invalid argument for option '-m'
> /home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/lib/libpetsc.so:
> undefined reference to `MPI_Win_allocate'
> undefined reference to `MPI_Win_attach'
> undefined reference to `MPI_Win_create_dynamic'
> gmake[4]: *** [ex5f] Error 1
> Thanks,
> Danyang
> *From: *Junchao Zhang <junchao.zhang at gmail.com>
> *Date: *Saturday, April 10, 2021 at 3:57 PM
> *To: *Danyang Su <danyang.su at gmail.com>
> MPI version
> You sent a wrong one. This configure.log was from a successful
> configuration. Note FOPTFLAGS="-O3 -march=native -mtune=nativels" looks
> suspicious.
> --Junchao Zhang
> On Sat, Apr 10, 2021 at 5:32 PM Danyang Su <danyang.su at gmail.com> wrote:
> Hi Junchao,
> Thanks for looking into this problem. The configuration log is attached.
> All the best,
> Danyang
> *Date: *Saturday, April 10, 2021 at 2:36 PM
> MPI version
> Hi, Danyang,
> Send the configure.log. Also, PETSc does not need MPI_Win_allocate etc to
> work. I will have a look.
> --Junchao Zhang
> On Sat, Apr 10, 2021 at 2:47 PM Danyang Su <danyang.su at gmail.com> wrote:
> Hi Barry,
> I tried this option before but get ‘Error running configure on OpenMPI’
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> Error running configure on OPENMPI
> File
> "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/configure.py", line
> 456, in petsc_configure
> framework.configure(out = sys.stdout)
> File
> "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/framework.py",
> line 1253, in configure
> self.processChildren()
> File
> line 1242, in processChildren
> self.serialEvaluation(self.childGraph)
> File
> line 1217, in serialEvaluation
> child.configure()
> File
> "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/package.py",
> line 1144, in configure
> self.executeTest(self.configureLibrary)
> File
> "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/base.py",
> line 140, in executeTest
> ret = test(*args,**kargs)
> File
> line 902, in configureLibrary
> for location, directory, lib, incl in self.generateGuesses():
> File
> line 476, in generateGuesses
> d = self.checkDownload()
> File
> "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/packages/OpenMPI.py",
> line 56, in checkDownload
> return self.getInstallDir()
> File
> line 365, in getInstallDir
> installDir = self.Install()
> File
> line 63, in Install
> installDir = config.package.GNUPackage.Install(self)
> File
> line 1667, in Install
> raise RuntimeError('Error running configure on ' + self.PACKAGE)
> Finishing configure run at Sat, 10 Apr 2021 11:57:20 -0700
> Thanks,
> Danyang
> *From: *Barry Smith <bsmith at petsc.dev>
> *Date: *Saturday, April 10, 2021 at 10:31 AM
> *Cc: *"petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> MPI version
> Depending on the network you can remove the ./configure
> options --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 and use instead
> --with-cc=icc --with-cxx=icpc and--with-fc=ifort --download-openmpi
> Barry
> On Apr 10, 2021, at 12:18 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Dear PETSc developers and users,
> I am trying to install the latest PETSc version on an ancient cluster. The
> OpenMPI version is 1.6.5 and Compiler is Intel 14.0, which are the newest
> on that cluster. I have no problem to install PETSc up to version 3.12.5.
> However, if I try to use PETSc 3.13+, there are three undefined reference
> errors in MPI_Win_allocate, MPI_Win_attach and MPI_Win_create_dynamic. I
> know these three functions are available from OpenMPI 2.0+. Because the
> cluster is not in technical support anymore, there is no way I can install
> new OpenMPI version or do some update. Is it possible to disable these
> three functions in PETSc 3.13+ version?
> The errors occur in ‘make check’ step:
> /home/dsu/soft/petsc/petsc-3.13.0/linux-intel-openmpi/lib/libpetsc.so:
> The configuration used is shown below:
> ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> --download-mumps --download-scalapack --download-parmetis --download-metis
> --download-fblaslapack --download-hypre --download-superlu
> --download-hdf5=yes --with-debugging=0 COPTFLAGS="-O3 -march=native
> -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
> Thanks,
> Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210411/f70e37fc/attachment-0001.html>
