[petsc-users] Undefined reference in PETSc 3.13+ with old MPI version
Danyang Su
danyang.su at gmail.com
Sat Apr 10 22:06:06 CDT 2021
Hi Junchao,
I cannot configure your branch with same options due to the error in sowing. I had similar error before on other clusters with very old openmpi version. Problem was solved when openmpi was updated to a newer one.
At this moment, I configured a PETSc version with Openmpi 2.1.6 version and it seems working properly.
Thanks and have a good rest of the weekend,
Danyang
Date: Saturday, April 10, 2021 at 4:08 PM
To: Junchao Zhang <junchao.zhang at gmail.com>
Cc: Barry Smith <bsmith at petsc.dev>, "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Undefined reference in PETSc 3.13+ with old MPI version
Hi Junchao,
The configuration is successful. The error comes from the last step when I run
make PETSC_DIR=/home/danyangs/soft/petsc/petsc-3.13.6 PETSC_ARCH=linux-intel-openmpi check
*******************Error detected during compile or link!*******************
See http://www.mcs.anl.gov/petsc/documentation/faq.html
/home/danyangs/soft/petsc/petsc-3.13.6/src/snes/tutorials ex5f
mpif90 -fPIC -O3 -march=native -mtune=nativels -I/home/danyangs/soft/petsc/petsc-3.13.6/include -I/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/include ex5f.F90 -Wl,-rpath,/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/lib -L/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/lib -Wl,-rpath,/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/lib -L/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/lib -Wl,-rpath,/global/software/intel/composer_xe_2013_sp1.2.144/mkl/lib/intel64 -L/global/software/intel/composer_xe_2013_sp1.2.144/mkl/lib/intel64 -Wl,-rpath,/global/software/intel/composer_xe_2013_sp1.2.144/compiler/lib/intel64 -L/global/software/intel/composer_xe_2013_sp1.2.144/compiler/lib/intel64 -Wl,-rpath,/global/software/openmpi-1.6.5/intel/lib64 -L/global/software/openmpi-1.6.5/intel/lib64 -Wl,-rpath,/global/software/intel/composerxe/mkl/lib/intel64 -L/global/software/intel/composerxe/mkl/lib/intel64 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -Wl,-rpath,/global/software/intel/composerxe/lib/intel64 -lpetsc -lHYPRE -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu -lflapack -lfblas -lX11 -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lparmetis -lmetis -lstdc++ -ldl -lmpi_f90 -lmpi_f77 -lmpi -lm -lnuma -lrt -lnsl -lutil -limf -lifport -lifcore -lsvml -lipgo -lintlc -lpthread -lgcc_s -lirc_s -lstdc++ -ldl -o ex5f
ifort: command line warning #10159: invalid argument for option '-m'
/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/lib/libpetsc.so: undefined reference to `MPI_Win_allocate'
/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/lib/libpetsc.so: undefined reference to `MPI_Win_attach'
/home/danyangs/soft/petsc/petsc-3.13.6/linux-intel-openmpi/lib/libpetsc.so: undefined reference to `MPI_Win_create_dynamic'
gmake[4]: *** [ex5f] Error 1
Danyang
Date: Saturday, April 10, 2021 at 3:57 PM
To: Danyang Su <danyang.su at gmail.com>
You sent a wrong one. This configure.log was from a successful configuration. Note FOPTFLAGS="-O3 -march=native -mtune=nativels" looks suspicious.
--Junchao Zhang
On Sat, Apr 10, 2021 at 5:32 PM Danyang Su <danyang.su at gmail.com> wrote:
Hi Junchao,
Thanks for looking into this problem. The configuration log is attached.
All the best,
Danyang
Date: Saturday, April 10, 2021 at 2:36 PM
Hi, Danyang,
Send the configure.log. Also, PETSc does not need MPI_Win_allocate etc to work. I will have a look.
--Junchao Zhang
On Sat, Apr 10, 2021 at 2:47 PM Danyang Su <danyang.su at gmail.com> wrote:
Hi Barry,
I tried this option before but get ‘Error running configure on OpenMPI’
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
Error running configure on OPENMPI
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/configure.py", line 456, in petsc_configure
framework.configure(out = sys.stdout)
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/framework.py", line 1253, in configure
self.processChildren()
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/framework.py", line 1242, in processChildren
self.serialEvaluation(self.childGraph)
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/framework.py", line 1217, in serialEvaluation
child.configure()
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/package.py", line 1144, in configure
self.executeTest(self.configureLibrary)
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/base.py", line 140, in executeTest
ret = test(*args,**kargs)
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/package.py", line 902, in configureLibrary
for location, directory, lib, incl in self.generateGuesses():
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/package.py", line 476, in generateGuesses
d = self.checkDownload()
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/packages/OpenMPI.py", line 56, in checkDownload
return self.getInstallDir()
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/package.py", line 365, in getInstallDir
installDir = self.Install()
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/packages/OpenMPI.py", line 63, in Install
installDir = config.package.GNUPackage.Install(self)
File "/global/home/danyangs/soft/petsc/petsc-3.14.6/config/BuildSystem/config/package.py", line 1667, in Install
raise RuntimeError('Error running configure on ' + self.PACKAGE)
Finishing configure run at Sat, 10 Apr 2021 11:57:20 -0700
Danyang
Date: Saturday, April 10, 2021 at 10:31 AM
Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
Depending on the network you can remove the ./configure options --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 and use instead --with-cc=icc --with-cxx=icpc and--with-fc=ifort --download-openmpi
Barry
On Apr 10, 2021, at 12:18 PM, Danyang Su <danyang.su at gmail.com> wrote:
Dear PETSc developers and users,
I am trying to install the latest PETSc version on an ancient cluster. The OpenMPI version is 1.6.5 and Compiler is Intel 14.0, which are the newest on that cluster. I have no problem to install PETSc up to version 3.12.5. However, if I try to use PETSc 3.13+, there are three undefined reference errors in MPI_Win_allocate, MPI_Win_attach and MPI_Win_create_dynamic. I know these three functions are available from OpenMPI 2.0+. Because the cluster is not in technical support anymore, there is no way I can install new OpenMPI version or do some update. Is it possible to disable these three functions in PETSc 3.13+ version?
The errors occur in ‘make check’ step:
/home/dsu/soft/petsc/petsc-3.13.0/linux-intel-openmpi/lib/libpetsc.so: undefined reference to `MPI_Win_allocate'
/home/dsu/soft/petsc/petsc-3.13.0/linux-intel-openmpi/lib/libpetsc.so: undefined reference to `MPI_Win_attach'
/home/dsu/soft/petsc/petsc-3.13.0/linux-intel-openmpi/lib/libpetsc.so: undefined reference to `MPI_Win_create_dynamic'
The configuration used is shown below:
./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-mumps --download-scalapack --download-parmetis --download-metis --download-fblaslapack --download-hypre --download-superlu --download-hdf5=yes --with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3 -march=native -mtune=nativels"
Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210410/5b997a20/attachment-0001.html>
