[petsc-users] Failed to build Petsc statically linked to MKL for Windows
Thuc Bui bui at calcreek.com
Tue Sep 29 19:29:36 CDT 2020
Hi Barry & Satish,
I also did a configuration to have a full path for each library as follows
./configure --with-cc='win32fe cl' --with-cxx='win32fe cl' --with-fc=0
--with-openmp --with-debugging=0 --with-mpi=0
--with-blas-lapack-lib="/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/m
kl/lib/mkl_intel_lp64.lib
/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib
/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread.
lib
/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/libiomp5md.lib"
and also got the same error message. Attached is the configure.log.
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
You set a value for --with-blaslapack-lib=<lib>, but
['/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_lp64.
lib',
'/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib',
'/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread
.lib',
'/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/libiomp5md.lib']
cannot be used
Thuc
-----Original Message-----
Sent: Tuesday, September 29, 2020 5:17 PM
To: petsc-users
Cc: Barry Smith
Subject: RE: [petsc-users] Failed to build Petsc statically linked to MKL
for Windows
Hi Barry & Satish,
I really appreciate you are getting back to me. Because libiomp5md.lib is
not in the mkl/lib directory, I just copy it to the same directory and per
your suggestion use the followings
--with-blas-lapack-lib="-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows
/mkl/lib mkl_intel_lp64.lib mkl_core.lib mkl_intel_thread.lib
libiomp5md.lib"
Unfortunately, I got the same error message as below. I am attaching
configure log, and hopefully you can see what I am doing icorrectly.
Many thanks,
Thuc
['-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib',
'mkl_intel_lp64.lib', 'mkl_core.lib', 'mkl_intel_thread.lib',
'libiomp5md.lib'] cannot be used
Sent: Tuesday, September 29, 2020 4:12 PM
To: Thuc Bui
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Failed to build Petsc statically linked to MKL
for Windows
https://software.intel.com/content/www/us/en/develop/articles/intel-mkl-link
-line-advisor.html
Checking for MS compilers - [MKL2018+] it gives:
mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
i.e no -Wl,--start-group [MS compiler most likely does not use this option]
So you can try:
--with-blaslapack-lib="-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/
mkl/lib/ mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib
libiomp5md.lib"
Satish
On Tue, 29 Sep 2020, Thuc Bui wrote:
> Dear Petsc Users,
> I have successfully built Petsc v3.13.5 for Windows 10 VS2015 without
> Fortran compiler and without MPI. These successful  builds are either
> linked statically with Blas-Lapack or dynamically with Intel MKL.
> However, when linking dynamically to MKL, I would have to include 4
> more Intel DLLs for building applications. I would like to have Petsc
> linking statically to MKL to avoid having these extra DLLs, but have
> not been successful. Here is how I run configure for static link
> --with-blas-lapack-lib="-Wl,--start-group
> p64.li b
> b
> lib -Wl,--end-group"
> I got this configuration error,
> === TESTING: checkLib from
> config.packages.BlasLapack(config/BuildSystem/config/pack*************
> details):
> ['-Wl,--start-group',
> lp64.l
> ib',
> ib',
> thread .lib', '-Wl,--end-group'] cannot be used
> Can someone point me to a proper syntax to link to MKL statically?
> Attached is the configure.log if you need it.
> I have also tried unsuccessfuly,
> dows/m
> b
> lib"
> or
> indows /mkl/lib -lmkl_intel_lp64.lib -lmkl_core.lib
> -lmkl_intel_thread.lib",
> or
> indows /mkl/lib mkl_intel_lp64.lib mkl_core.lib mkl_intel_thread.lib"
> and all gave the similar error message.
> Many thanks in advance for your help,
> Thuc Bui
> Senior R&D Engineer
> Calabazas Creek Research, Inc.
> (650) 948-5361 (Office)
> (650) 948-7562 (Fax)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200929/c6ca6fb9/attachment-0001.obj>
