[petsc-users] Failed to build Petsc statically linked to MKL for Windows
    Satish Balay
    balay at mcs.anl.gov
    Tue Sep 29 19:27:11 CDT 2020
Likely the libraries are in /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/intel64 and not /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib
Please verify:
ls /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/intel64
Then you would need:
--with-blas-lapack-lib="-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/intel64 mkl_intel_lp64.lib mkl_core.lib mkl_intel_thread.lib libiomp5md.lib"
Satish
On Tue, 29 Sep 2020, Thuc Bui wrote:
> Hi Barry & Satish,
> I really appreciate you are getting back to me. Because libiomp5md.lib is
> not in the mkl/lib directory, I just copy it to the same directory and per
> your suggestion use the followings
> ./configure --with-cc='win32fe cl' --with-cxx='win32fe cl' --with-fc=0
> --with-openmp --with-debugging=0 --with-mpi=0
> /mkl/lib mkl_intel_lp64.lib mkl_core.lib mkl_intel_thread.lib
> libiomp5md.lib"
> Unfortunately, I got the same error message as below. I am attaching
> configure log, and hopefully you can see what I am doing icorrectly.
> Many thanks,
> Thuc
> You set a value for --with-blaslapack-lib=<lib>, but
> ['-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib',
> 'mkl_intel_lp64.lib', 'mkl_core.lib', 'mkl_intel_thread.lib',
> 'libiomp5md.lib'] cannot be used
> -----Original Message-----
> From: Satish Balay [mailto:balay at mcs.anl.gov]
> Sent: Tuesday, September 29, 2020 4:12 PM
> To: Thuc Bui
> Cc: petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] Failed to build Petsc statically linked to MKL
> for Windows
> https://software.intel.com/content/www/us/en/develop/articles/intel-mkl-link
> -line-advisor.html
> Checking for MS compilers - [MKL2018+] it gives:
> mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
> i.e no -Wl,--start-group [MS compiler most likely does not use this option]
> So you can try:
> --with-blaslapack-lib="-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/
> mkl/lib/ mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib
> libiomp5md.lib"
> Satish
> > Dear Petsc Users,
> > I have successfully built Petsc v3.13.5 for Windows 10 VS2015 without
> > Fortran compiler and without MPI. These successful  builds are either
> linked
> > statically with Blas-Lapack or dynamically with Intel MKL. However, when
> > linking dynamically to MKL, I would have to include 4 more Intel DLLs for
> > building applications. I would like to have Petsc linking statically to
> MKL
> > to avoid having these extra DLLs, but have not been successful. Here is
> how
> > I run configure for static link
> > --with-blas-lapack-lib="-Wl,--start-group
> /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_lp64.li
> > b /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib
> /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread.
> > lib -Wl,--end-group"
> > I got this configuration error,
> > === TESTING: checkLib from
> config.packages.BlasLapack(config/BuildSystem/config/pack*******************
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> > details):
> > You set a value for --with-blaslapack-lib=<lib>, but ['-Wl,--start-group',
> '/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_lp64.l
> > ib',
> > '/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib',
> '/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread
> > .lib', '-Wl,--end-group'] cannot be used
> > Can someone point me to a proper syntax to link to MKL statically?
> Attached
> > is the configure.log if you need it.
> > I have also tried unsuccessfuly,
> --with-blas-lapack-lib="/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/m
> > kl/lib/mkl_intel_lp64.lib
> > lib"
> > or
> > /mkl/lib -lmkl_intel_lp64.lib -lmkl_core.lib -lmkl_intel_thread.lib",
> > or
> > /mkl/lib mkl_intel_lp64.lib mkl_core.lib mkl_intel_thread.lib"
> > and all gave the similar error message.
> > Many thanks in advance for your help,
> > Thuc Bui
> > Senior R&D Engineer
> > Calabazas Creek Research, Inc.
> > (650) 948-5361 (Office)
> > (650) 948-7562 (Fax)
