[petsc-users] Failed to build Petsc statically linked to MKL for Windows
Thuc Bui bui at calcreek.com
Tue Sep 29 17:39:16 CDT 2020
Dear Barry,
Thank you very much for looking into this. I really appreciate it. Attached
is the configure log generated by the first configuration listed below.
Best regards,
Thuc
Sent: Tuesday, September 29, 2020 2:33 PM
To: Thuc Bui
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Failed to build Petsc statically linked to MKL
for Windows
On Sep 29, 2020, at 3:50 PM, Thuc Bui <bui at calcreek.com> wrote:
Dear Petsc Users,
I have successfully built Petsc v3.13.5 for Windows 10 VS2015 without
Fortran compiler and without MPI. These successful  builds are either linked
statically with Blas-Lapack or dynamically with Intel MKL. However, when
linking dynamically to MKL, I would have to include 4 more Intel DLLs for
building applications. I would like to have Petsc linking statically to MKL
to avoid having these extra DLLs, but have not been successful. Here is how
I run configure for static link
./configure --with-cc='win32fe cl' --with-cxx='win32fe cl' --with-fc=0
--with-openmp --with-debugging=0 --with-mpi=0
--with-blas-lapack-lib="-Wl,--start-group
/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_lp64.li
b /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib
/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread.
lib -Wl,--end-group"
I got this configuration error,
=== TESTING: checkLib from
config.packages.BlasLapack(config/BuildSystem/config/pack*******************
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
You set a value for --with-blaslapack-lib=<lib>, but ['-Wl,--start-group',
'/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_lp64.l
ib',
'/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib',
'/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread
.lib', '-Wl,--end-group'] cannot be used
Can someone point me to a proper syntax to link to MKL statically? Attached
is the configure.log if you need it.
I have also tried unsuccessfuly,
--with-blas-lapack-lib="/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/m
kl/lib/mkl_intel_lp64.lib
lib"
  Please send configure.log for the above attempt.
  Barry
or
--with-blas-lapack-lib="-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows
/mkl/lib -lmkl_intel_lp64.lib -lmkl_core.lib -lmkl_intel_thread.lib",
or
/mkl/lib mkl_intel_lp64.lib mkl_core.lib mkl_intel_thread.lib"
and all gave the similar error message.
Many thanks in advance for your help,
Thuc Bui
Senior R&D Engineer
Calabazas Creek Research, Inc.
(650) 948-5361 (Office)
(650) 948-7562 (Fax)
<configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200929/81c52005/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200929/81c52005/attachment-0001.obj>
