[petsc-users] Failed to build Petsc statically linked to MKL for Windows
Barry Smith bsmith at petsc.dev
Tue Sep 29 16:33:21 CDT 2020
> On Sep 29, 2020, at 3:50 PM, Thuc Bui <bui at calcreek.com> wrote:
> Dear Petsc Users,
> I have successfully built Petsc v3.13.5 for Windows 10 VS2015 without Fortran compiler and without MPI. These successful  builds are either linked statically with Blas-Lapack or dynamically with Intel MKL. However, when linking dynamically to MKL, I would have to include 4 more Intel DLLs for building applications. I would like to have Petsc linking statically to MKL to avoid having these extra DLLs, but have not been successful. Here is how I run configure for static link
> ./configure --with-cc='win32fe cl' --with-cxx='win32fe cl' --with-fc=0 --with-openmp --with-debugging=0 --with-mpi=0 --with-blas-lapack-lib="-Wl,--start-group /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_lp64.lib /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread.lib -Wl,--end-group"
> I got this configuration error,
> =============================================================================== TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/pack*******************************************************************************
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> You set a value for --with-blaslapack-lib=<lib>, but ['-Wl,--start-group', '/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_lp64.lib', '/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib', '/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread.lib', '-Wl,--end-group'] cannot be used
> Can someone point me to a proper syntax to link to MKL statically? Attached is the configure.log if you need it.
> I have also tried unsuccessfuly,
> --with-blas-lapack-lib="/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_lp64.lib /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_core.lib /cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib/mkl_intel_thread.lib"
  Please send configure.log for the above attempt.
  Barry
> or
> --with-blas-lapack-lib="-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib -lmkl_intel_lp64.lib -lmkl_core.lib -lmkl_intel_thread.lib",
> or
> --with-blas-lapack-lib="-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1.279/windows/mkl/lib mkl_intel_lp64.lib mkl_core.lib mkl_intel_thread.lib"
> and all gave the similar error message.
> Many thanks in advance for your help,
> Thuc Bui
> Senior R&D Engineer
> Calabazas Creek Research, Inc.
> (650) 948-5361 (Office)
> (650) 948-7562 (Fax)
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200929/ad8499db/attachment.html>
