[petsc-users] Compute C*Ct using MatCreateTranspose for Ct
Zhang, Hong hzhang at mcs.anl.gov
Sun Sep 27 20:16:09 CDT 2020
Sent: Friday, September 25, 2020 2:31 AM
To: Zhang, Hong <hzhang at mcs.anl.gov>; Matthew Knepley <knepley at gmail.com>; Mark Adams <mfadams at lbl.gov>
Cc: PETSc <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Compute C*Ct using MatCreateTranspose for Ct
@Mark: Sorry, I totally misunderstood your answer, so my answer to your answer about petsc versions is non-sense...
@Hong: MatTransposeMatMult gives (Ct*C), no? And I feel that MatCreateTranspose actually works for mpiaij.
Yes,  MatTransposeMatMult gives (Ct*C).
MatCreateTranspose(C,&N) creates a new matrix N which shares the data structure of C. When user calls y = N*x, PETSc actually does MatMultTranspose with C. I do not think you can uses N to do N*C, which is not supported.
-- Hong
On 24/09/2020 16:16, Zhang, Hong via petsc-users wrote:
Olivier and Matt,
MatPtAP with A=I gives Pt*P, not P*Pt. We have sequential MatRARt and MatMatTransposeMult(), but no support for mpiaij matrices. The problem is that we do not have a way to implement C*Ct without explicitly transpose C in parallel.
We support MatTransposeMatMult (A*Bt) for mpiaij. Can you use this instead?
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov><mailto:petsc-users-bounces at mcs.anl.gov> on behalf of Zhang, Hong via petsc-users <petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov>
Sent: Thursday, September 24, 2020 8:56 AM
To: Matthew Knepley <knepley at gmail.com><mailto:knepley at gmail.com>; Mark Adams <mfadams at lbl.gov><mailto:mfadams at lbl.gov>
Cc: PETSc <petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov>
Indeed, we do not have MatCreateTranspose for mpaij matrix.
I can adding such support. How soon do you need it?
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov><mailto:petsc-users-bounces at mcs.anl.gov> on behalf of Matthew Knepley <knepley at gmail.com><mailto:knepley at gmail.com>
Sent: Thursday, September 24, 2020 6:12 AM
To: Mark Adams <mfadams at lbl.gov><mailto:mfadams at lbl.gov>
On Thu, Sep 24, 2020 at 6:48 AM Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
Is there a way to avoid the explicit transposition of the matrix?
It does not look like we have A*B^T for mpiaij as the error message says. I am not finding it in the code.
Note, MatMatMult with a transpose shell matrix, I suspect that it does an explicit transpose internally, or it could notice that you have C^T*C and we might have that implemented in-place (I doubt it, but it would be legal and fine to do).
We definitely have
  https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatPtAP.html
For now, you can put the identity in for A. It would be nice it we assumed that when A = NULL.
Patrick, the implementation strategy is broken for the MatProduct mechanism that was just introduced, so
we cannot see which things are implemented in the documentation. How would I go about fixing it?
     Matt
Many thanks,
Olivier Jamond
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200928/a7342de9/attachment.html>
