[petsc-users] osx error
Satish Balay
balay at mcs.anl.gov
Fri Sep 18 10:10:17 CDT 2020
Yes - please try this part:
> >> > Mark, can you remove the line that you added to /etc/hosts - i.e:
> >> > 127.0.0.1 MarksMac-302.local
> >> > And now rerun MPI tests. Do they work or fail?
> >> > [this is to check if this test is a false positive on your machine]
> >> > Satish
Satish
On Fri, 18 Sep 2020, Mark Adams wrote:
> Let me know if you want anything else.
> Thanks,
> Mark
> On Fri, Sep 18, 2020 at 11:05 AM Mark Adams <mfadams at lbl.gov> wrote:
> > On Fri, Sep 18, 2020 at 11:04 AM Satish Balay <balay at mcs.anl.gov> wrote:
> >> On Fri, 18 Sep 2020, Satish Balay via petsc-users wrote:
> >> > > >> 07:41 master *= ~/Codes/petsc$ ping -c 2 MarksMac-302.local
> >> > > >> PING marksmac-302.local (127.0.0.1): 56 data bytes
> >> > So it is resolving MarksMac-302.local as 127.0.0.1 - but ping is not
> >> responding?
> >> > I know some machines don't respond to external ping [and firewalls can
> >> block it] but don't really know if they always respond to internal ping or
> >> not.
> >> > If some machines don't respond to internal ping - then we can't use
> >> ping test in configure [it will create false negatives - as in this case]
> >> BTW: To confirm, please try:
> >> ping 127.0.0.1
> > 11:02 master *= ~/Codes/petsc$ sudo vi /etc/hosts
> > 11:02 master *= ~/Codes/petsc$ ping 127.0.0.1
> > PING 127.0.0.1 (127.0.0.1): 56 data bytes
> > Request timeout for icmp_seq 0
> > Request timeout for icmp_seq 1
> > Request timeout for icmp_seq 2
> > Request timeout for icmp_seq 3
> > Request timeout for icmp_seq 4
> > Request timeout for icmp_seq 5
> > Request timeout for icmp_seq 6
> > Request timeout for icmp_seq 7
> > Request timeout for icmp_seq 8
> > Request timeout for icmp_seq 9
> > Request timeout for icmp_seq 10
> > Request timeout for icmp_seq 11
> > Request timeout for icmp_seq 12
> > Request timeout for icmp_seq 13
> > Request timeout for icmp_seq 14
> > Request timeout for icmp_seq 15
> > Request timeout for icmp_seq 16
> > Request timeout for icmp_seq 17
> > Request timeout for icmp_seq 18
> > Request timeout for icmp_seq 19
> > Request timeout for icmp_seq 20
> > Request timeout for icmp_seq 21
> > still going ......
> >> Satish
> >> > Satish
> >> > > On Fri, Sep 18, 2020 at 7:51 AM Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >> > > > On Fri, Sep 18, 2020 at 7:46 AM Mark Adams <mfadams at lbl.gov> wrote:
> >> > > >> Oh you did not change my hostname:
> >> > > >> 07:37 master *= ~/Codes/petsc$ hostname
> >> > > >> MarksMac-302.local
> >> > > >> --- marksmac-302.local ping statistics ---
> >> > > >> 2 packets transmitted, 0 packets received, 100.0% packet loss
> >> > > >> 07:42 2 master *= ~/Codes/petsc$
> >> > > > This does not make sense to me. You have
> >> > > > in /etc/hosts,
> >> > > 09:07 ~/.ssh$ cat /etc/hosts
> >> > > # Host Database
> >> > > # localhost is used to configure the loopback interface
> >> > > # when the system is booting. Do not change this entry.
> >> > > 127.0.0.1 localhost
> >> > > 255.255.255.255 broadcasthost
> >> > > 127.0.0.1 MarksMac-5.local
> >> > > 127.0.0.1 243.124.240.10.in-addr.arpa.private.cam.ac.uk
> >> > > 09:07 ~/.ssh$
> >> > > > but you cannot resolve that name?
> >> > > > Matt
> >> > > >> BTW, I used to get messages about some network issue and 'changing
> >> host
> >> > > >> name to MarksMac-[x+1].local'. That is, the original hostname
> >> > > >> was MarksMac.local, then I got a message about changing
> >> > > >> to MarksMac-1.local, etc. I have not seen these messages for
> >> months but
> >> > > >> apparently this process has continued unabated.
> >> > > >> On Thu, Sep 17, 2020 at 11:10 PM Satish Balay via petsc-users <
> >> > > >> petsc-users at mcs.anl.gov> wrote:
> >> > > >>> On Thu, 17 Sep 2020, Matthew Knepley wrote:
> >> > > >>> > On Thu, Sep 17, 2020 at 8:33 PM Barry Smith <bsmith at petsc.dev>
> >> wrote:
> >> > > >>> > > > On Sep 17, 2020, at 4:59 PM, Satish Balay via petsc-users <
> >> > > >>> > > > Here is a fix:
> >> > > >>> > > > echo 127.0.0.1 `hostname` | sudo tee -a /etc/hosts
> >> > > >>> > > Satish,
> >> > > >>> > > I don't think you want to be doing this on a Mac (on
> >> anything?)
> >> > > >>> On a
> >> > > >>> > > Mac based on the network configuration etc as it boots up and
> >> as
> >> > > >>> networks
> >> > > >>> > > are accessible or not (wi-fi) it determines what hostname
> >> should be,
> >> > > >>> one
> >> > > >>> > > should never being hardwiring it to some value.
> >> > > >>> > Satish is just naming the loopback interface. I did this on all
> >> my
> >> > > >>> former
> >> > > >>> > Macs.
> >> > > >>> Yes - this doesn't change the hostname. Its just adding an entry
> >> for
> >> > > >>> gethostbyname - for current hostname.
> >> > > >>> Sure - its best to not do this when one has a proper IP name [like
> >> > > >>> foo.mcs.anl.gov] - but its useful when one has a hostname like
> >> > > >>> "MarksMac-302.local" -that is not DNS resolvable
> >> > > >>> Even if the machine is moved to a different network with a
> >> different
> >> > > >>> name - the current entry won't cause problems [but will need
> >> another entry
> >> > > >>> for the new host name - if this new name is also not DNS
> >> resolvable]
> >> > > >>> Its likely this file is a generated file on macos - so might
> >> get reset
> >> > > >>> on reboot - or some network change? [if this is the case - the
> >> change won't
> >> > > >>> be permanent]
> >> > > >>> Satish
> >> > > > What most experimenters take for granted before they begin their
> >> > > > experiments is infinitely more interesting than any results to
> >> which their
> >> > > > experiments lead.
> >> > > > -- Norbert Wiener
> >> > > > https://www.cse.buffalo.edu/~knepley/
> >> > > > <http://www.cse.buffalo.edu/~knepley/>
