[petsc-users] Finding which cell an arbitrary point belongs to in DMPlex
Hapla Vaclav
vaclav.hapla at erdw.ethz.ch
Wed Sep 16 09:29:24 CDT 2020
There is also DMPlexFindVertices() which finds the nearest vertex to the given coords in the given radius.
You can then get support or its transitive closure for that vertex.
I wrote it some time ago mainly for debug purposes. It uses just brute force. I'm not sure it deserves to exist :-) Maybe we should somehow merge these functionalities.
Vaclav
On 16 Sep 2020, at 01:44, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Tue, Sep 15, 2020 at 6:18 PM Jeremy Theler <jeremy at seamplex.com<mailto:jeremy at seamplex.com>> wrote:
On Mon, 2020-09-14 at 20:28 -0400, Matthew Knepley wrote:
> On Mon, Sep 14, 2020 at 6:15 PM Jeremy Theler <jeremy at seamplex.com<mailto:jeremy at seamplex.com>>
> wrote:
> > Hello all
> > Say I have a fully-interpolated 3D DMPlex and a point with
> > arbitrary
> > coordinates x,y,z. What's the most efficient way to know which cell
> > this point belongs to in parallel? Cells can be either tets or
> > hexes.
> I should make a tutorial on this, but have not had time so far.
Thank you very much for this mini-tutorial.
> The intention is that you use
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMLocatePoints.html
> This will just brute force search unless you also give
> -dm_plex_hash_location
Well, for a 3D DMplex PETSc (and git blame) tells me that you "have
only coded this for 2D." :-)
Crap. I need to do 3D. It's not hard, just work.
> which builds a grid hash to accelerate it. I should probably expose
> DMPlexLocatePoint_Internal()
> which handles the single cell queries. If you just had one point,
> that might make it simpler,
> although you would still write your own loop.
I see that DMLocatePoints() loops over all the cells until it finds the
right one. I was thinking about finding first the nearest vertex to the
point and then sweeping over all the cells that share this vertex
testing for DMPlexLocatePoint_Internal(). The nearest node ought to be
found using an octree or similar. Any direction regarding this idea?
So you can imagine both a topological search and a geometric search. Generally, people want geometric.
The geometric hash we use is just to bin elements on a regular grid.
> If your intention is to interpolate a field at these
> locations, I created
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/DMInterpolationCreate.html
> which no one but me uses so far, but I think it is convenient.
Any other example apart from src/snes/tutorials/ex63.c?
That is the only one in PETSc. The PyLith code uses this to interpolate to seismic stations.
Matt
Thank you.
> Thanks,
> Matt
> > Regards
> > jeremy theler
> > www.seamplex.com<http://www.seamplex.com/>
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200916/d0df9ee8/attachment.html>
