[petsc-users] [EXT]Re: Dynamic SNESVI bounds
Fri Sep 11 19:46:48 CDT 2020
On Fri, Sep 11, 2020 at 8:09 PM Alexander B Prescott <
alexprescott at email.arizona.edu> wrote:
> Hi Barry, thanks for the help, I've done as you suggested. Now, I get an
> error that I'm unfamiliar with that goes away if I comment out
> SNESSetUpdate(). This error pops up after several successful iterations, so
> I'm not sure what's goin on here. The full message is copied below.
It thinks snes>vec_sol has been freed. It seems like something illegal was
done in Update(). Can you run under valgrind?
    Matt
> mpirun -n 1 a -snes_type vinewtonrsls -snes_monitor -snes_mf
> -snes_converged_reason
>   0 SNES Function norm 1.319957381248e+02
>   1 SNES Function norm 3.164228677282e+01
>   2 SNES Function norm 5.157408019535e+00
>   3 SNES Function norm 2.290604723696e-01
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Corrupt argument:
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: Object already free: Parameter # 2
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.13.2, unknown
> [0]PETSC ERROR: a on a arch-linux2-c-debug named
> alexprescott-ThinkPad-T420s by alexprescott Fri Sep 11 16:49:38 2020
> [0]PETSC ERROR: Configure options
> [0]PETSC ERROR: #1 SNESComputeJacobian() line 2676 in
> /home/alexprescott/Documents/petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: #2 SNESSolve_VINEWTONRSLS() line 386 in
> /home/alexprescott/Documents/petsc/src/snes/impls/vi/rs/virs.c
> [0]PETSC ERROR: #3 SNESSolve() line 4519 in
> [0]PETSC ERROR: #4 PetscWrapperFcn() line 222 in petscshell_leq9nodes.c
> [0]PETSC ERROR: #5 main() line 285 in petscshell_leq9nodes.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -snes_converged_reason
> [0]PETSC ERROR: -snes_mf
> [0]PETSC ERROR: -snes_monitor
> [0]PETSC ERROR: -snes_type vinewtonrsls
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> Best,
> Alexander
> On Thu, Sep 10, 2020 at 4:27 PM Barry Smith <bsmith at petsc.dev> wrote:
>> *External Email*
>>   Yes, it should be simple to write the code to do this.
>>   Provide a function that calls SNESVISetVariableBounds() using your
>> criteria then call SNESSetUpdate() to have that function called on each
>> iteration of SNES to reset the bounds.
>>   If this will converge to what you desire I have no clue. But each step
>> will find a result that satisfies the current bounds you set.
>>   Barry
>> On Sep 10, 2020, at 5:15 PM, Alexander B Prescott <
>> Hi there,
>> I have a quick question (hopefully) that I didn't find addressed in the
>> documentation or user list archives. Is it possible to change the SNES
>> Variational Inequality bounds from one solver iteration to the next?
>> My goal is to update the bounds such that a specific entry in the
>> solution vector remains the supremum throughout the entire execution.
>> Best,
>> Alexander
>> Alexander Prescott
>> PhD Candidate, The University of Arizona
>> Department of Geosciences
>> 1040 E. 4th Street
>> Tucson, AZ, 85721
> Alexander Prescott
> 1040 E. 4th Street
> Tucson, AZ, 85721
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200911/58f3c16c/attachment-0001.html>
