[petsc-users] [EXT]Re: Dynamic SNESVI bounds
Alexander B Prescott
alexprescott at email.arizona.edu
Fri Sep 11 19:08:33 CDT 2020
Hi Barry, thanks for the help, I've done as you suggested. Now, I get an
error that I'm unfamiliar with that goes away if I comment out
SNESSetUpdate(). This error pops up after several successful iterations, so
I'm not sure what's goin on here. The full message is copied below.
mpirun -n 1 a -snes_type vinewtonrsls -snes_monitor -snes_mf
-snes_converged_reason
0 SNES Function norm 1.319957381248e+02
1 SNES Function norm 3.164228677282e+01
2 SNES Function norm 5.157408019535e+00
3 SNES Function norm 2.290604723696e-01
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Corrupt argument:
https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: Object already free: Parameter # 2
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.13.2, unknown
[0]PETSC ERROR: a on a arch-linux2-c-debug named
alexprescott-ThinkPad-T420s by alexprescott Fri Sep 11 16:49:38 2020
[0]PETSC ERROR: Configure options
[0]PETSC ERROR: #1 SNESComputeJacobian() line 2676 in
/home/alexprescott/Documents/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: #2 SNESSolve_VINEWTONRSLS() line 386 in
/home/alexprescott/Documents/petsc/src/snes/impls/vi/rs/virs.c
[0]PETSC ERROR: #3 SNESSolve() line 4519 in
[0]PETSC ERROR: #4 PetscWrapperFcn() line 222 in petscshell_leq9nodes.c
[0]PETSC ERROR: #5 main() line 285 in petscshell_leq9nodes.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -snes_converged_reason
[0]PETSC ERROR: -snes_mf
[0]PETSC ERROR: -snes_monitor
[0]PETSC ERROR: -snes_type vinewtonrsls
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
Best,
Alexander
On Thu, Sep 10, 2020 at 4:27 PM Barry Smith <bsmith at petsc.dev> wrote:
> *External Email*
> Yes, it should be simple to write the code to do this.
> Provide a function that calls SNESVISetVariableBounds() using your
> criteria then call SNESSetUpdate() to have that function called on each
> iteration of SNES to reset the bounds.
> If this will converge to what you desire I have no clue. But each step
> will find a result that satisfies the current bounds you set.
> Barry
> On Sep 10, 2020, at 5:15 PM, Alexander B Prescott <
> alexprescott at email.arizona.edu> wrote:
> Hi there,
> I have a quick question (hopefully) that I didn't find addressed in the
> documentation or user list archives. Is it possible to change the SNES
> Variational Inequality bounds from one solver iteration to the next?
> My goal is to update the bounds such that a specific entry in the solution
> vector remains the supremum throughout the entire execution.
> Best,
> Alexander
> Alexander Prescott
> PhD Candidate, The University of Arizona
> Department of Geosciences
> 1040 E. 4th Street
> Tucson, AZ, 85721
Alexander Prescott
1040 E. 4th Street
Tucson, AZ, 85721
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200911/eb5d6613/attachment.html>
