[petsc-users] [EXT]Re: petscvec.h90
Barry Smith
bsmith at petsc.dev
Wed Sep 9 18:32:24 CDT 2020
.......rc/../dependencies/eigen -I/home/u7/aph/bitcart/src/driver2/material_response -c navier_stokes/LinearSolverClass.F90
navier_stokes/LinearSolverClass.F90(45): error #7013: This module file was not generated by any release of this compiler. [PETSCVEC]
It is not reading the module it finds so cannot find the definitions in the module.
In the PETSc directory start all over again
rm -rf $PETSC_ARCH
./configure your options here
make all
make check
> On Sep 9, 2020, at 5:55 PM, Anthony Paul Haas <aph at email.arizona.edu> wrote:
> Hi Barry,
> I made the changes according to the information you sent me (see below snippet module LinearSolverClass please). But I am getting the following errors:
> error #7013
> error #6457
> Do you know what is going on?
> Thanks,
> Anthony
> use petscvec
> navier_stokes/LinearSolverClass.F90(110): error #6457: This derived type name has not been declared. [TVEC]
> type(tVec) :: solution_ps,FirstSingularVec
> navier_stokes/LinearSolverClass.F90(111): error #6457: This derived type name has not been declared. [TVEC]
> type(tVec) :: rhs_ps!,b_ps
> navier_stokes/LinearSolverClass.F90(115): error #6457: This derived type name has not been declared. [TKSP]
> type(tKSP) :: ksp
> #include <petsc/finclude/petscvec.h>
> #include <petsc/finclude/petscksp.h>
> use petscvec
> use petscksp
> ! use LHS, only: matLHS,rhs,sol
> use paramesh_dimensions
> use physicaldata
> use tree
> use workspace
> use utilities_data, only: mkdir
> use typedef, only: dist_fcn,solverType,mypeno
> use fill_guardcells, only: fill_guardcell_res
> !use navierstokes_data, only: fill_guardcell_phi
> use amr_1blk_bcset_mod, only: updateType
> ! use Turb_Models, only: nvars_turb
> implicit none
> ! Class type definition
> TYPE, public :: LinearSolver_C
> Integer,private :: numVars
> Integer,private :: numVarsp
> On Wed, Sep 9, 2020 at 3:06 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
> External Email
> Anthony,
> See
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html>
> https://www.mcs.anl.gov/petsc/documentation/changes/38.html <https://www.mcs.anl.gov/petsc/documentation/changes/38.html>
> Barry
>> On Sep 9, 2020, at 4:23 PM, Anthony Paul Haas <aph at email.arizona.edu <mailto:aph at email.arizona.edu>> wrote:
>> Hello,
>> Has the header file petscvec.h90 been removed from include/petsc/finclude/ in recent Petsc releases?
>> Should it then be replaced by petscvec.h?
>> Thanks,
>> Anthony
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200909/bbb613af/attachment-0001.html>
