[petsc-users] [EXT]Re: petscvec.h90
Anthony Paul Haas aph at email.arizona.edu
Wed Sep 9 17:55:34 CDT 2020
Hi Barry,
I made the changes according to the information you sent me (see below
snippet module LinearSolverClass please). But I am getting the following
errors:
error #7013
error #6457
Do you know what is going on?
Anthony
.......rc/../dependencies/eigen
-I/home/u7/aph/bitcart/src/driver2/material_response -c
navier_stokes/LinearSolverClass.F90
navier_stokes/LinearSolverClass.F90(45): error #7013: This module file was
not generated by any release of this compiler.   [PETSCVEC]
  use petscvec
navier_stokes/LinearSolverClass.F90(110): error #6457: This derived type
name has not been declared.   [TVEC]
     type(tVec)            :: solution_ps,FirstSingularVec
navier_stokes/LinearSolverClass.F90(111): error #6457: This derived type
     type(tVec)            :: rhs_ps!,b_ps
navier_stokes/LinearSolverClass.F90(115): error #6457: This derived type
name has not been declared.   [TKSP]
     type(tKSP)            :: ksp
#include <petsc/finclude/petscvec.h>
#include <petsc/finclude/petscksp.h>
  use petscvec
  use petscksp
  !  use LHS, only: matLHS,rhs,sol
  use paramesh_dimensions
  use physicaldata
  use tree
  use workspace
  use utilities_data, only: mkdir
  use typedef, only: dist_fcn,solverType,mypeno
  use fill_guardcells, only: fill_guardcell_res
  !use navierstokes_data, only: fill_guardcell_phi
  use amr_1blk_bcset_mod, only: updateType
  !  use Turb_Models, only: nvars_turb
  implicit none
  !     Class type definition
  TYPE, public :: LinearSolver_C
     Integer,private        :: numVars
     Integer,private        :: numVarsp
On Wed, Sep 9, 2020 at 3:06 PM Barry Smith <bsmith at petsc.dev> wrote:
> *External Email*
> Anthony,
>   See
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html
> https://www.mcs.anl.gov/petsc/documentation/changes/38.html
>   Barry
> On Sep 9, 2020, at 4:23 PM, Anthony Paul Haas <aph at email.arizona.edu>
> wrote:
> Hello,
> Has the header file petscvec.h90 been removed from include/petsc/finclude/
> in recent Petsc releases?
> Should it then be replaced by petscvec.h?
> Thanks,
> Anthony
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200909/f2961532/attachment-0001.html>
