[petsc-users] VTK format?
Jed Brown jed at jedbrown.org
Sun Sep 6 19:41:34 CDT 2020
This MR deprecates it for 3.14.  We can delete it for a future release.
https://gitlab.com/petsc/petsc/-/merge_requests/3142
Matthew Knepley <knepley at gmail.com> writes:
> I do not use it anymore. It can be thrown away.
>    Matt
> On Thu, Sep 3, 2020 at 12:20 PM Barry Smith <bsmith at petsc.dev> wrote:
>> On Sep 3, 2020, at 10:47 AM, Jed Brown <jed at jedbrown.org> wrote:
>> I'd have deleted the legacy vtk many years ago, but Matt says he uses it.
>>   So he is plotting garbage or he never uses the broken stuff so it can be
>> errorred out?
>> On Thu, Sep 3, 2020, at 9:45 AM, Barry Smith wrote:
>>   Shouldn't this, "just work". PETSc should not be dumping unreadable
>> garbage into any files, does the broken PETSc code need to be removed, or
>> error out until it can be fixed?
>>   Barry
>> On Sep 3, 2020, at 9:53 AM, Jed Brown <jed at jedbrown.org> wrote:
>> Use the xml format (not the legacy format) by naming your file.vtu instead
>> of file.vtk
>> On Thu, Sep 3, 2020, at 8:17 AM, Berend van Wachem wrote:
>> Dear PETSc,
>> What is the best way to write data from a DMPLEX vector to file, so it
>> can be viewed with paraview?
>> I've found that the standard VTK format works for a serial job, but if
>> there is more than 1 processor, the geometry data gets messed up.
>> I've attached a small working example for a cylinder and the visualised
>> geometry with paraview for 1 processors and 4 processors.
>> Any pointers or "best practice" very much appreciated.
>> Best regards,
>> Berend.
>> *Attachments:*
>>    - visualizemesh.c
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
