[petsc-users] VTK format?
Thu Sep 3 19:46:49 CDT 2020
I do not use it anymore. It can be thrown away.
   Matt
On Thu, Sep 3, 2020 at 12:20 PM Barry Smith <bsmith at petsc.dev> wrote:
> On Sep 3, 2020, at 10:47 AM, Jed Brown <jed at jedbrown.org> wrote:
> I'd have deleted the legacy vtk many years ago, but Matt says he uses it.
>   So he is plotting garbage or he never uses the broken stuff so it can be
> errorred out?
> On Thu, Sep 3, 2020, at 9:45 AM, Barry Smith wrote:
>   Shouldn't this, "just work". PETSc should not be dumping unreadable
> garbage into any files, does the broken PETSc code need to be removed, or
> error out until it can be fixed?
>   Barry
> On Sep 3, 2020, at 9:53 AM, Jed Brown <jed at jedbrown.org> wrote:
> Use the xml format (not the legacy format) by naming your file.vtu instead
> of file.vtk
> On Thu, Sep 3, 2020, at 8:17 AM, Berend van Wachem wrote:
> Dear PETSc,
> What is the best way to write data from a DMPLEX vector to file, so it
> can be viewed with paraview?
> I've found that the standard VTK format works for a serial job, but if
> there is more than 1 processor, the geometry data gets messed up.
> I've attached a small working example for a cylinder and the visualised
> geometry with paraview for 1 processors and 4 processors.
> Any pointers or "best practice" very much appreciated.
> Best regards,
> Berend.
> *Attachments:*
>    - visualizemesh.c
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200903/2d3c8637/attachment.html>
