[petsc-users] FPE when trying to find the condition number
Barry Smith
bsmith at petsc.dev
Thu Oct 22 15:13:54 CDT 2020
The reference implementation of LAPACK tries a divide by zero in its setup to see if it can divide by zero and that is happening for you.
Hence the PETSc code has
ierr = PetscFPTrapPush(PETSC_FP_TRAP_OFF);CHKERRQ(ierr);
#if !defined(PETSC_USE_COMPLEX)
PetscStackCallBLAS("LAPACKgesvd",LAPACKgesvd_("N","N",&bn,&bn,R,&bN,realpart,&sdummy,&idummy,&sdummy,&idummy,work,&lwork,&lierr));
#else
PetscStackCallBLAS("LAPACKgesvd",LAPACKgesvd_("N","N",&bn,&bn,R,&bN,realpart,&sdummy,&idummy,&sdummy,&idummy,work,&lwork,realpart+N,&lierr));
#endif
if (lierr) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"Error in SVD Lapack routine %d",(int)lierr);
ierr = PetscFPTrapPop();CHKERRQ(ierr);
which is suppose to turn off the trapping. The code that turns off the trapping is OS dependent, perhaps it does not work for you.
There is a bit better code in the current release than 3.11 I recommend you first upgrade.
What system are you running on?
Barry
> On Oct 22, 2020, at 2:12 PM, baikadi pranay <pranayreddy865 at gmail.com> wrote:
> Hello,
> I am trying to find the condition number of the A matrix for a linear system I am solving. I have used the following commands.
> ./a.out -ksp_monitor_singular_value -ksp_type gmres -ksp_gmres_restart 1000 -pc_type none
> However, the execution comes to a halt after a few iterations with the following error.
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind <http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind>
> [0]PETSC ERROR: or try http://valgrind.org <http://valgrind.org/> on GNU/linux and Apple Mac OS X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR: INSTEAD the line number of the start of the function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: [0] LAPACKgesvd line 40 /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/impls/gmres/gmreig.c
> [0]PETSC ERROR: [0] KSPComputeExtremeSingularValues_GMRES line 22 /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/impls/gmres/gmreig.c
> [0]PETSC ERROR: [0] KSPComputeExtremeSingularValues line 59 /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] KSPMonitorSingularValue line 130 /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/interface/iterativ.c
> [0]PETSC ERROR: [0] KSPMonitor line 1765 /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] KSPGMRESCycle line 122 /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: [0] KSPSolve_GMRES line 225 /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: [0] KSPSolve line 678 /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html <http://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
> [0]PETSC ERROR: ./a.out on a linux-gnu-c-debug named cg17-9.agave.rc.asu.edu <http://cg17-9.agave.rc.asu.edu/> by pbaikadi Thu Oct 22 12:07:11 2020
> [0]PETSC ERROR: Configure options
> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> Is the error because the A matrix is singular (causing the max/min to be undefined)? Please let me know.
> Thank you,
> Sincerely,
> Pranay.
> ᐧ
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201022/cc9a83b8/attachment-0001.html>
