[petsc-users] Python version needed for internal scripts
Nicolas Barral nicolas.barral at math.u-bordeaux.fr
Wed Oct 14 16:14:19 CDT 2020
Thanks Matt, Pierre, Lisandro and Jed for your help.
Does the python version chosen to call the configure script impact other
petsc scripts ?
For now keeping python as an alias for python2 seems safer (until proven
otherwise) due to other codes.
@Pierre: I meant the search button in https://lists.mcs.anl.gov/...
wouldn't return anything, even on as obvious as queries as "petsc". It
does work now, so not sure what happened.
Nicolas
On 14/10/2020 12:20, Matthew Knepley wrote:
> On Wed, Oct 14, 2020 at 6:01 AM Nicolas Barral
> <nicolas.barral at math.u-bordeaux.fr
> <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
>     Hi all,
>     Apologies if the question has already been asked, but the ML archive
>     search seems to be broken (or has it never worked ?).
>     Many petsc scripts require a 'python' executable, which python should
>     that be ? For now, python3 seems to have worked with the configure
>     scripts and petsc_gen_xdmf scripts, but can I safely assume it will
>     always be the case ?
>     'python' is usually an alias for python2, so making it point at python3
>     seems a bit dangerous. Yet, python2 was removed from recent Ubuntus and
>     maybe others, and if I have no python2 installed, and no 'python'
>     alias,
>     I have to manually edit all the scripts.
> Right now, PETSc works with both Python2 and Python3. I am not sure how
> long we can support Python2,
> but the aim is to support it until End of Life, probably on Red Hat
> since they change the slowest I think.
>    Thanks,
>      Matt
>     Thanks
>     Nicolas
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
