[petsc-users] Ainsworth formula to solve saddle point problems / preconditioner for shell matrices
Jed Brown jed at jedbrown.org
Thu Oct 8 15:07:12 CDT 2020
Olivier Jamond <olivier.jamond at cea.fr> writes:
>>     Given the structure of C it seems you should just explicitly construct Sp and use GAMG (or other preconditioners, even a direct solver) directly on Sp. Trying to avoid explicitly forming Sp will give you a much slower performing solving for what benefit? If C was just some generic monster than forming Sp might be unrealistic but in your case CCt is is block diagonal with tiny blocks which means (C*Ct)^(-1) is block diagonal with tiny blocks (the blocks are the inverses of the blocks of (C*Ct)).
>>      Sp = Ct*C  + Qt * S * Q = Ct*C  +  [I - Ct * (C*Ct)^(-1)*C] S [I - Ct * (C*Ct)^(-1)*C]
>> [Ct * (C*Ct)^(-1)*C] will again be block diagonal with slightly larger blocks.
>> You can do D = (C*Ct) with MatMatMult() then write custom code that zips through the diagonal blocks of D inverting all of them to get iD then use MatPtAP applied to C and iD to get Ct * (C*Ct)^(-1)*C then MatShift() to include the I then MatPtAP or MatRAR to get [I - Ct * (C*Ct)^(-1)*C] S [I - Ct * (C*Ct)^(-1)*C]  then finally MatAXPY() to get Sp. The complexity of each of the Mat operations is very low because of the absurdly simple structure of C and its descendants.   You might even be able to just use MUMPS to give you the explicit inv(C*Ct) without writing custom code to get iD.
> At this time, I didn't manage to compute iD=inv(C*Ct) without using
> dense matrices, what may be a shame because all matrices are sparse . Is
> it possible?
> And I get no idea of how to write code to manually zip through the
> diagonal blocks of D to invert them...
You could use MatInvertVariableBlockDiagonal(), which should perhaps return a Mat instead of a raw array.
If you have constant block sizes, MatInvertBlockDiagonalMat will return a Mat.
