[petsc-users] Convergence Error Debugging with KSP solvers in SNES
Matthew Knepley
knepley at gmail.com
Thu Oct 8 05:25:19 CDT 2020
On Thu, Oct 8, 2020 at 3:43 AM Yang Juntao <Y.Juntao at hotmail.com> wrote:
> Hello,
> I’m working on a nonlinear solver with SNES with handcoded jacobian and
> function. Each linear solver is solved with KSP solver.
> But sometimes I got issues with ksp solver convergence. I tried with
> finite difference approximated jacobian, but get the same error.
> From the iterations, the convergence seems ok at the beginning but
> suddenly diverged in the last iteration.
> Hope anyone with experience on ksp solvers could direct me to a direction
> I can debug the problem.
KSP Object: 1 MPI processes
type: gmres
restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
The GMRES restarted at iteration 30. You can increase the subspace size
using
-ksp_gmres_restart 100
Matt
> iter = 0, SNES Function norm 2.94934e-06
> iteration 0 KSP Residual norm 1.094600281831e-06
> iteration 1 KSP Residual norm 1.264284474186e-08
> iteration 2 KSP Residual norm 6.593269221816e-09
> iteration 3 KSP Residual norm 1.689570779457e-09
> iteration 4 KSP Residual norm 1.040661505932e-09
> iteration 5 KSP Residual norm 5.422761817348e-10
> iteration 6 KSP Residual norm 2.492867371369e-10
> iteration 7 KSP Residual norm 8.261522376775e-11
> iteration 8 KSP Residual norm 4.246401544245e-11
> iteration 9 KSP Residual norm 2.514366787388e-11
> iteration 10 KSP Residual norm 1.982940267051e-11
> iteration 11 KSP Residual norm 1.586470414676e-11
> iteration 12 KSP Residual norm 9.866392216207e-12
> iteration 13 KSP Residual norm 4.951342176999e-12
> iteration 14 KSP Residual norm 2.418292660318e-12
> iteration 15 KSP Residual norm 1.747418526086e-12
> iteration 16 KSP Residual norm 1.094150535809e-12
> iteration 17 KSP Residual norm 4.464287492066e-13
> iteration 18 KSP Residual norm 3.530090494462e-13
> iteration 19 KSP Residual norm 2.825698091454e-13
> iteration 20 KSP Residual norm 1.950568425807e-13
> iteration 21 KSP Residual norm 1.227898091813e-13
> iteration 22 KSP Residual norm 5.411106347374e-14
> iteration 23 KSP Residual norm 4.511115848564e-14
> iteration 24 KSP Residual norm 4.063546606691e-14
> iteration 25 KSP Residual norm 3.677694771949e-14
> iteration 26 KSP Residual norm 3.459244943466e-14
> iteration 27 KSP Residual norm 3.263954971093e-14
> iteration 28 KSP Residual norm 3.087344619079e-14
> iteration 29 KSP Residual norm 2.809426925625e-14
> iteration 30 KSP Residual norm 4.366149884754e-01
> Linear solve did not converge due to DIVERGED_DTOL iterations 30
> SNES Object: 1 MPI processes
> type: newtonls
> SNES has not been set up so information may be incomplete
> maximum iterations=50, maximum function evaluations=10000
> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
> total number of linear solver iterations=0
> total number of function evaluations=0
> norm schedule ALWAYS
> SNESLineSearch Object: 1 MPI processes
> type: bt
> interpolation: cubic
> alpha=1.000000e-04
> maxstep=1.000000e+08, minlambda=1.000000e-12
> tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
> maximum iterations=40
> type: gmres
> happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-08, absolute=1e-50, divergence=10000.
> left preconditioning
> using DEFAULT norm type for convergence test
> PC Object: 1 MPI processes
> type: fieldsplit
> PC has not been set up so information may be incomplete
> FieldSplit with Schur preconditioner, factorization FULL
> Preconditioner for the Schur complement formed from S itself
> Split info:
> KSP solver for A00 block
> not yet available
> KSP solver for S = A11 - A10 inv(A00) A01
> not yet available
> linear system matrix = precond matrix:
> Mat Object: 1 MPI processes
> type: seqaij
> rows=659, cols=659
> total: nonzeros=659, allocated nonzeros=7908
> total number of mallocs used during MatSetValues calls=0
> not using I-node routines
> Regards
> Juntao
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201008/d773df38/attachment.html>
