[petsc-users] Convergence Error Debugging with KSP solvers in SNES
Yang Juntao
Y.Juntao at hotmail.com
Thu Oct 8 02:43:07 CDT 2020
Hello,
I’m working on a nonlinear solver with SNES with handcoded jacobian and function. Each linear solver is solved with KSP solver.
But sometimes I got issues with ksp solver convergence. I tried with finite difference approximated jacobian, but get the same error.
From the iterations, the convergence seems ok at the beginning but suddenly diverged in the last iteration.
Hope anyone with experience on ksp solvers could direct me to a direction I can debug the problem.
iter = 0, SNES Function norm 2.94934e-06
iteration 0 KSP Residual norm 1.094600281831e-06
iteration 1 KSP Residual norm 1.264284474186e-08
iteration 2 KSP Residual norm 6.593269221816e-09
iteration 3 KSP Residual norm 1.689570779457e-09
iteration 4 KSP Residual norm 1.040661505932e-09
iteration 5 KSP Residual norm 5.422761817348e-10
iteration 6 KSP Residual norm 2.492867371369e-10
iteration 7 KSP Residual norm 8.261522376775e-11
iteration 8 KSP Residual norm 4.246401544245e-11
iteration 9 KSP Residual norm 2.514366787388e-11
iteration 10 KSP Residual norm 1.982940267051e-11
iteration 11 KSP Residual norm 1.586470414676e-11
iteration 12 KSP Residual norm 9.866392216207e-12
iteration 13 KSP Residual norm 4.951342176999e-12
iteration 14 KSP Residual norm 2.418292660318e-12
iteration 15 KSP Residual norm 1.747418526086e-12
iteration 16 KSP Residual norm 1.094150535809e-12
iteration 17 KSP Residual norm 4.464287492066e-13
iteration 18 KSP Residual norm 3.530090494462e-13
iteration 19 KSP Residual norm 2.825698091454e-13
iteration 20 KSP Residual norm 1.950568425807e-13
iteration 21 KSP Residual norm 1.227898091813e-13
iteration 22 KSP Residual norm 5.411106347374e-14
iteration 23 KSP Residual norm 4.511115848564e-14
iteration 24 KSP Residual norm 4.063546606691e-14
iteration 25 KSP Residual norm 3.677694771949e-14
iteration 26 KSP Residual norm 3.459244943466e-14
iteration 27 KSP Residual norm 3.263954971093e-14
iteration 28 KSP Residual norm 3.087344619079e-14
iteration 29 KSP Residual norm 2.809426925625e-14
iteration 30 KSP Residual norm 4.366149884754e-01
Linear solve did not converge due to DIVERGED_DTOL iterations 30
SNES Object: 1 MPI processes
type: newtonls
SNES has not been set up so information may be incomplete
maximum iterations=50, maximum function evaluations=10000
tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
total number of linear solver iterations=0
total number of function evaluations=0
norm schedule ALWAYS
SNESLineSearch Object: 1 MPI processes
type: bt
interpolation: cubic
alpha=1.000000e-04
maxstep=1.000000e+08, minlambda=1.000000e-12
tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
maximum iterations=40
KSP Object: 1 MPI processes
type: gmres
restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-08, absolute=1e-50, divergence=10000.
left preconditioning
using DEFAULT norm type for convergence test
PC Object: 1 MPI processes
type: fieldsplit
PC has not been set up so information may be incomplete
FieldSplit with Schur preconditioner, factorization FULL
Preconditioner for the Schur complement formed from S itself
Split info:
KSP solver for A00 block
not yet available
KSP solver for S = A11 - A10 inv(A00) A01
not yet available
linear system matrix = precond matrix:
Mat Object: 1 MPI processes
type: seqaij
rows=659, cols=659
total: nonzeros=659, allocated nonzeros=7908
total number of mallocs used during MatSetValues calls=0
not using I-node routines
Regards
Juntao
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201008/5c9cfcac/attachment-0001.html>
