[petsc-users] config error on Cori/KNL
Mark Adams mfadams at lbl.gov
Wed Nov 18 07:34:57 CST 2020
So a build from the login node --with-batch=1 ran fine. I recall the batch
stuff might have gotten fixed ... and it looks good to me.
I can not get a compute node to check right now.
Dan, give it a try and if you have a PETSc (branch "release" preferably)
you could check it:
petsc$ make
PETSC_DIR=/global/common/software/m1041/petsc_install/petsc_knl_intel
PETSC_ARCH="" check
On Wed, Nov 18, 2020 at 8:27 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 18, 2020 at 8:07 AM Mark Adams <mfadams at lbl.gov> wrote:
>> I get this error (sudo not found on KNL at NERSC). I run this on a
>> computer node. I will start doing this on a login node but if there is an
>> easy fix let me know.
> Okay, this happens a few levels down. Here is the error:
> TEST setInstallDir from
> PETSc.options.installDir(/global/u2/m/madams/petsc_install/petsc/config/PETSc/options/installDir.py:39)
> TESTING: setInstallDir from
> PETSc.options.installDir(config/PETSc/options/installDir.py:39)
>    setup installDir to either prefix or if that is not set to
> PETSC_DIR/PETSC_ARCH
>           Error trying to to test write permissions on directory [Errno
> 30] Read-only file system:
> '/global/common/software/m1041/petsc_install/petsc_knl_intel/PETScTestDirectory'
>             Defined make macro "PREFIXDIR" to
> "/global/common/software/m1041/petsc_install/petsc_knl_intel"
> It makes you use sudo because it cannot write to the prefix directory.
>   Thanks,
>      Matt
> Mark
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201118/bc456ded/attachment.html>
