[petsc-users] config error on Cori/KNL
Matthew Knepley
knepley at gmail.com
Wed Nov 18 07:27:36 CST 2020
On Wed, Nov 18, 2020 at 8:07 AM Mark Adams <mfadams at lbl.gov> wrote:
> I get this error (sudo not found on KNL at NERSC). I run this on a
> computer node. I will start doing this on a login node but if there is an
> easy fix let me know.
Okay, this happens a few levels down. Here is the error:
TEST setInstallDir from
PETSc.options.installDir(/global/u2/m/madams/petsc_install/petsc/config/PETSc/options/installDir.py:39)
TESTING: setInstallDir from
PETSc.options.installDir(config/PETSc/options/installDir.py:39)
setup installDir to either prefix or if that is not set to
PETSC_DIR/PETSC_ARCH
Error trying to to test write permissions on directory [Errno 30]
Read-only file system:
'/global/common/software/m1041/petsc_install/petsc_knl_intel/PETScTestDirectory'
Defined make macro "PREFIXDIR" to
"/global/common/software/m1041/petsc_install/petsc_knl_intel"
It makes you use sudo because it cannot write to the prefix directory.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201118/643580e6/attachment.html>
