[petsc-users] Very slow SVD with SLEPC
Rakesh Halder rhalder at umich.edu
Tue Nov 17 01:30:20 CST 2020
The following is from the large matrix log:
<?xml version="1.0" encoding="UTF-8"?>
<?xml-stylesheet type="text/xsl" href="performance_xml2html.xsl"?>
<root>
<!-- PETSc Performance Summary: -->
  <petscroot>
    <runspecification desc="Run Specification">
      <executable desc="Executable">simpleROMFoam</executable>
      <architecture desc="Architecture">real-opt</architecture>
      <hostname desc="Host">pmultigrid</hostname>
      <nprocesses desc="Number of processes">1</nprocesses>
      <user desc="Run by user">rhalder</user>
      <date desc="Started at">Mon Nov 16 20:25:52 2020</date>
      <petscrelease desc="Petsc Release">Petsc Release Version 3.14.1, Nov
03, 2020 </petscrelease>
    </runspecification>
    <globalperformance desc="Global performance">
      <time desc="Time (sec)">
        <max>1.299397e+03</max>
        <maxrank desc="rank at which max was found">0</maxrank>
        <ratio>1.000000</ratio>
        <average>1.299397e+03</average>
      </time>
      <objects desc="Objects">
        <max>9.100000e+01</max>
        <average>9.100000e+01</average>
      </objects>
      <mflop desc="MFlop">
        <max>0.000000e+00</max>
        <ratio>0.000000</ratio>
        <average>0.000000e+00</average>
        <total>0.000000e+00</total>
      </mflop>
      <mflops desc="MFlop/sec">
      </mflops>
      <messagetransfers desc="MPI Message Transfers">
      </messagetransfers>
      <messagevolume desc="MPI Message Volume (MiB)">
      </messagevolume>
      <reductions desc="MPI Reductions">
      </reductions>
    </globalperformance>
    <timertree desc="Timings tree">
      <totaltime>1299.397478</totaltime>
      <timethreshold>0.010000</timethreshold>
      <event>
        <name>SVDSolve</name>
        <time>
          <value>75.5819</value>
        </time>
        <events>
          <event>
            <name>self</name>
            <time>
              <value>75.3134</value>
            </time>
          </event>
          <event>
            <name>MatConvert</name>
            <time>
              <value>0.165386</value>
            </time>
            <ncalls>
              <value>3.</value>
            </ncalls>
            <events>
              <event>
                <name>self</name>
                <time>
                </time>
              </event>
            </events>
          </event>
          <event>
            <name>SVDSetUp</name>
            <time>
              <value>0.102518</value>
            </time>
            <events>
              <event>
                <name>self</name>
                <time>
                  <value>0.0601394</value>
                </time>
              </event>
              <event>
                <name>VecSet</name>
                <time>
                  <value>0.0423783</value>
                </time>
                <ncalls>
                  <value>4.</value>
                </ncalls>
              </event>
            </events>
          </event>
        </events>
      </event>
      <event>
        <time>
          <value>0.575872</value>
        </time>
        <events>
          <event>
            <name>self</name>
            <time>
              <value>0.575869</value>
            </time>
          </event>
        </events>
      </event>
      <event>
        <name>MatView</name>
        <time>
          <value>0.424561</value>
        </time>
      </event>
      <event>
        <name>BVCopy</name>
        <time>
          <value>0.0288127</value>
        </time>
        <ncalls>
          <value>2000.</value>
        </ncalls>
        <events>
          <event>
            <name>VecCopy</name>
            <time>
              <value>0.0284472</value>
            </time>
          </event>
        </events>
      </event>
      <event>
        <name>MatAssemblyEnd</name>
        <time>
          <value>0.0128941</value>
        </time>
      </event>
    </timertree>
    <selftimertable desc="Self-timings">
      <event>
        <time>
        </time>
      </event>
      <event>
        <time>
          <value>0.741256</value>
        </time>
      </event>
      <event>
        <time>
        </time>
      </event>
      <event>
        <time>
        </time>
      </event>
      <event>
        <name>VecSet</name>
        <time>
          <value>0.0424012</value>
        </time>
      </event>
      <event>
        <time>
        </time>
      </event>
      <event>
        <time>
          <value>0.0128944</value>
        </time>
      </event>
    </selftimertable>
  </petscroot>
</root>
On Tue, Nov 17, 2020 at 2:28 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> I cannot visualize the XML files. Please send the information in plain
> text.
> Jose
> > El 17 nov 2020, a las 5:33, Rakesh Halder <rhalder at umich.edu> escribió:
> > Hi Jose,
> > I attached two XML logs of two different SVD calculations where N ~=
> 140,000; first a small N x 5 matrix, and then a large N x 1000 matrix. The
> global timing starts before the SVD calculations. The small matrix
> calculation happens very quick in total (less than a second), while the
> larger one takes around 1,000 seconds. The "largeMat.xml" file shows that
> SVDSolve takes around 75 seconds, but when I time it myself by outputting
> the time difference to the console, it shows that it takes around 1,000
> seconds, and I'm not sure where this mismatch is coming from.
> > This is using the scaLAPACK SVD solver on a single processor, and I call
> MatConvert to convert my matrix to the MATSCALAPACK format.
> > Thanks,
> > Rakesh
> > On Mon, Nov 16, 2020 at 2:45 AM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > For Cross and TRLanczos, make sure that the matrix is stored in DENSE
> format, not in the default AIJ format. On the other hand, these solvers
> build the transpose matrix explicitly, which is bad for dense matrices in
> parallel. Try using SVDSetImplicitTranspose(), this will also save memory.
> > For SCALAPACK, it is better if the matrix is passed in the MATSCALAPACK
> format already, otherwise the solver must convert it internally. Still, the
> matrix of singular vectors must be converted after computation.
> > In any case, performance questions should include information from
> -log_view so that we have a better idea of what is going on.
> > Jose
> > > El 16 nov 2020, a las 6:04, Rakesh Halder <rhalder at umich.edu>
> escribió:
> > > Hi Jose,
> > > I'm only interested in part of the singular triplets, so those
> algorithms work for me. I tried using ScaLAPACK and it gives similar
> performance to Lanczos and Cross, so it's still very slow.... I'm still
> having memory issues with LAPACK and Elemental is giving me an error
> message indicating that the operation isn't supported for rectangular
> matrices.
> > > With regards to scaLAPACK or any other solver, I'm wondering if
> there's some settings to use with the SVD object to ensure optimal
> performance.
> > > Thanks,
> > > Rakesh
> > > On Sun, Nov 15, 2020 at 2:59 PM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > > Rakesh,
> > > The solvers you mention are not intended for computing the full SVD,
> only part of the singular triplets. In the latest version (3.14) there are
> now solvers that wrap external packages for parallel dense computations:
> ScaLAPACK and Elemental.
> > > Jose
> > > > El 15 nov 2020, a las 20:48, Matthew Knepley <knepley at gmail.com>
> escribió:
> > > > On Sun, Nov 15, 2020 at 2:18 PM Rakesh Halder <rhalder at umich.edu>
> wrote:
> > > > Hi all,
> > > > A program I'm writing involves calculating the SVD of a large, dense
> N by n matrix (N ~= 150,000, n ~=10,000). I've used the different SVD
> solvers available through SLEPc, including the cross product, lanczos, and
> method available through the LAPACK library. The cross product and lanczos
> methods take a very long time to compute the SVD (around 7-8 hours on one
> processor) while the solver using the LAPACK library runs out of memory. If
> I write this matrix to a file and solve the SVD using MATLAB or python
> (numPy) it takes around 10 minutes. I'm wondering if there's a much cheaper
> way to solve the SVD.
> > > > This seems suspicious, since I know numpy just calls LAPACK, and I
> am fairly sure that Matlab does as well. Do the machines that you
> > > > are running on have different amounts of RAM?
> > > >   Thanks,
> > > >      Matt
> > > > Thanks,
> > > > Rakesh
> > > > What most experimenters take for granted before they begin their
> experiments lead.
> > > > -- Norbert Wiener
> > > > https://www.cse.buffalo.edu/~knepley/
> > <largeMat.xml><smallMat.xml>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201117/38af358f/attachment-0001.html>
