[petsc-users] Very slow SVD with SLEPC
Jose E. Roman jroman at dsic.upv.es
Sun Nov 15 13:59:17 CST 2020
Rakesh,
The solvers you mention are not intended for computing the full SVD, only part of the singular triplets. In the latest version (3.14) there are now solvers that wrap external packages for parallel dense computations: ScaLAPACK and Elemental.
Jose
> El 15 nov 2020, a las 20:48, Matthew Knepley <knepley at gmail.com> escribió:
> On Sun, Nov 15, 2020 at 2:18 PM Rakesh Halder <rhalder at umich.edu> wrote:
> Hi all,
> A program I'm writing involves calculating the SVD of a large, dense N by n matrix (N ~= 150,000, n ~=10,000). I've used the different SVD solvers available through SLEPc, including the cross product, lanczos, and method available through the LAPACK library. The cross product and lanczos methods take a very long time to compute the SVD (around 7-8 hours on one processor) while the solver using the LAPACK library runs out of memory. If I write this matrix to a file and solve the SVD using MATLAB or python (numPy) it takes around 10 minutes. I'm wondering if there's a much cheaper way to solve the SVD.
> This seems suspicious, since I know numpy just calls LAPACK, and I am fairly sure that Matlab does as well. Do the machines that you
> are running on have different amounts of RAM?
>   Thanks,
>      Matt
> Thanks,
> Rakesh
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
