[petsc-users] Using Petsc-Matlab engine on a cluster
Amneet Bhalla
mail2amneet at gmail.com
Tue Nov 10 20:10:34 CST 2020
Thank you Barry! We will definitely try this out and let you know.
We also found an inconvenient work around. We registered the ip of a head
compute node on Mathworks.com, which generated a license file. Then we
activated Matlab on this compute node offline by pointing it to the license
file. This allowed us to run Matlab engine on the head compute node (we run
Matlab on only rank 0 which is mapped to the head compute node).
Kaustubh, can you write the exact instructions for registering an ip on
Mathworks.com here, so as to benefit other PETSc users.
On Tue, Nov 10, 2020 at 5:22 PM Barry Smith <bsmith at petsc.dev> wrote:
> In the git branch *barry/2020-11-10/add-matlab-engine-host * I have
> added the option -matlab_engine_host hostname
> Note this does require you have ssh access to hostname from where your
> PETSc program is running which may require setting up some ssh files
> Good luck
> Barry
> On Nov 9, 2020, at 5:35 PM, Kaustubh Khedkar <kkhedkar9879 at sdsu.edu>
> wrote:
> Hello,
> I am using PETSc with Matlab engine. I have built an application that uses
> Matlab engine through PETSc interface. I am trying to run this application
> on a cluster which has Matlab installed on a network drive (nas drive). I
> have made sure that I am able to access Matlab using my university details
> on the cluster (by activating Matlab license through Mathworks.com
> <http://mathworks.com/> account). I am also able to run this application
> using mpirun on the head node (master) which starts the Matlab engine but
> if I try to run this application using slurm on compute node then the
> Matlab engine does not start. I have also confirmed that if I login into
> one of the compute nodes and do a mpirun the Matlab engine does not start
> there. If I try to launch Matlab on a compute node it asks for Matlab
> license which the compute node is unable to activate possibly because it is
> not connected to the internet directly.
> Is there a way start matlab engine on the head node through Petsc
> interface even though the application is running on compute nodes or is
> there any other work around this issue?
> Thanks,
> Kaustubh Khedkar
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201110/776cbe18/attachment.html>
