[petsc-users] Using MatGetColumnVector() on multiprocess
Matthew Knepley
knepley at gmail.com
Mon Nov 9 08:53:47 CST 2020
On Mon, Nov 9, 2020 at 9:44 AM Antoine Côté <Antoine.Cote3 at usherbrooke.ca>
wrote:
> Hi,
> I would like to retrieve the values of a column in a sparse Mat created
> with DMCreateMatrix(). I currently use MatGetColumnVector() to store values
> in a Vec "A". A computation is later made on each value in "A", and the
> results are stored in another Vec "B" (that was initialized at "0.0" using
> VecSet()).
> Code works fine on a single process. When I try multiple processes, some
> values are ignored i.e. Vec "B" contains the right results for some
> positions, while others stay at "0.0". I suspect it is
> because MatGetColumnVector() is "Not Collective".
I do not think that is it. It looks like GetColumnVector() works in
parallel, but it is just not optimal:
https://www.mcs.anl.gov/petsc/petsc-current/src/mat/utils/getcolv.c.html#MatGetColumnVector
I would
1) Check that the column vector you get back is the one you expect
2) Check that your computation on A is parallelized
Matt
> What would be the best workaround?
> Thank you very much,
> Antoine Côté
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201109/6d768d76/attachment.html>
