[petsc-users] Errors with KSP solver
Hien HN-
hoangnhanhien at gmail.com
Tue Nov 3 02:33:12 CST 2020
Luckily, I fixed my issue. I don't know exactly why I got this error.
I changed the setting of the Fortran project, do not use the option "Use
Intel Math Kernel Library", and it is fine.
There are possibly some conflicts between the options that were used to
build the PETSc library with the Intel MKL library,
and they cause this problem for vector scattering using PETSc's functions.
So, I don't need to send you my code.
Thank you very much for your consideration.
Hoang
On Tue, 3 Nov 2020 at 12:17, Barry Smith <bsmith at petsc.dev> wrote:
> Hoang,
> Could you please send the entire code as a .F90 file as an attachment so
> we can reproduce the problem?
> Thanks
> Barry
> On Nov 2, 2020, at 8:38 PM, Hien HN- <hoangnhanhien at gmail.com> wrote:
> Hi Matt,
> 1) As I understood, the VecScatterCreateToAll function will create the
> vector sol_to_all, and it does not need to create this vector with, for
> example, VecCreate or VecCreateMPI function. Is this correct?
> call VecScatterCreateToAll(petsc_
> solution,ctx,sol_to_all,petsc_err)
> I have used the VecView to print the vector sol_to_all to a file. It seems
> no problem with sol_to_all.
> I installed PETSc with Intel MKL and MS-MPI libraries. So should I enable
> the option of Intel MKL that performs vector operations in my Fortran
> project?
> 2) This system is not the Laplacian.
> Thank you very much,
> Hoang
> On Mon, 2 Nov 2020 at 20:15, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Nov 2, 2020 at 12:31 AM Hien HN- <hoangnhanhien at gmail.com> wrote:
>>> Dear PETSc developers,
>>> *I have used KSP solver to solve a linear equation system in parallel
>>> with 5 processors.*
>>> *The linear system consists of a pressure matrix (pressure_coeff_mat)
>>> and its RHS (p_coeff_mat) whose values are set every time step using
>>> MatSetValue and VecSetValues functions and then assembled using:*
>>> call MatAssemblyBegin(pressure_coeff_mat,mat_final_assembly,petsc_err)
>>> call MatAssemblyEnd(pressure_coeff_mat,mat_final_assembly,petsc_err)
>>> call VecAssemblyBegin(p_coeff_rhs,petsc_err)
>>> call VecAssemblyEnd(p_coeff_rhs,petsc_err)
>>> *One processor solves this linear system using KSBCGS Krylov solver with
>>> ILU preconditioner, and the result is scattered to all processors*
>>> call KSPGetPC(petsc_ksp,petsc_pc,petsc_err)
>>> if (preconditioner==0) then
>>> call PCSetType(petsc_pc,PCJACOBI,petsc_err
>>> call
>>> PetscOptionsSetValue(PETSC_NULL_OPTIONS,"sub_ksp_type","preonly",petsc_err)
>>> call
>>> PetscOptionsSetValue(PETSC_NULL_OPTIONS,"sub_pc_type","ilu",petsc_err)
>>> call PCSetFromOptions(petsc_pc,petsc_err)
>>> else
>>> call PCSetType(petsc_pc,PCBJACOBI,petsc_err)
>>> end if
>>> call KSPSetFromOptions(petsc_ksp,petsc_err)
>>> call KSPSetUp(petsc_ksp,petsc_err)
>>> call KSPSolve(petsc_ksp,p_coeff_rhs,petsc_solution,petsc_err)
>>> call VecScatterCreateToAll(petsc_solution,ctx,sol_to_all,petsc_err)
>>> call
>>> VecScatterBegin(ctx,petsc_solution,sol_to_all,INSERT_VALUES,SCATTER_FORWARD,petsc_err)
>>> call VecScatterEnd(ctx,petsc_solution,sol_to_all,
>>> call VecGetValues(sol_to_all,ncells, loc_id_to_global-1,sol,
>>> petsc_err)
>>> call VecScatterDestroy(ctx,petsc_err)
>>> call VecDestroy(sol_to_all,petsc_err)
>>> *However, I got the following errors with vector scattering, i.e.,
>>> VecScatterBegin, VecScatterEnd, and also VecGetValues. I have checked the
>>> pressure matrix, its RHS, and the solution for the first call of KSPSolve.
>>> Their values seem to be okay (see attached file). So, could you please tell
>>> me what does this error mean and how can I fix it.*
>> 1) The error message says that 'sol_to_all' has not been created
>> 2) Is this system the Laplacian? If so, ILU is a bad preconditioner. You
>> should try gamg.
>> Thanks,
>> Matt
>>> *Thank you,*
>>> *Error message:*
>>> Configure options --with-cc="win32fe cl" --with-fc="win32fe ifort"
>>> --with-cxx="win32fe cl"
>>> --with-blaslapack-lib="[/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_intel_c_dll.lib,/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_sequential_dll.lib,/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_core_dll.lib]"
>>> --with-mpi-lib="[/cygdrive/c/PROGRA~2/MICROS~1/MPI/Lib/x86/msmpifec.lib,/cygdrive/c/PROGRA~2/MICROS~1/MPI/Lib/x86/msmpi.lib]"
>>> --with-mpi-include="[/cygdrive/c/PROGRA~2/MICROS~1/MPI/Include,/cygdrive/c/PROGRA~2/MICROS~1/MPI/Include/x86]"
>>> --with-mpiexec=/cygdrive/c/PROGRA~1/MI564C~1/bin/mpiexec.exe
>>> --with-debugging=1 --with-shared-libraries=0 --CFLAGS=-Od --FFLAGS=-Od
>>> CXXFLAGS=-Od --with-clean=1
>>> #4930 VecScatterBegin() line 83 in
>>> C:\petsc\PE4D24~1.13-\src\vec\vscat\INTERF~1\vscatfce.c
>>> [1]PETSC ERROR:
>>> [2]PETSC ERROR:
>>> [3]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> [4]PETSC ERROR:
>>> --------------------- Error Message
>>> [1]PETSC ERROR:
>>> [2]PETSC ERROR:
>>> [3]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> [4]PETSC ERROR:
>>> Null argument, when expecting valid pointer
>>> [1]PETSC ERROR:
>>> [2]PETSC ERROR:
>>> [3]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> [4]PETSC ERROR:
>>> Null Object: Parameter # 3
>>> [1]PETSC ERROR:
>>> [2]PETSC ERROR:
>>> [3]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> [4]PETSC ERROR:
>>> Hoang Nhan Hien, Ph.D.
>>> 1) Nuclear Safety Department, Institute for Nuclear Science and
>>> Technology, Vietnam Atomic Energy Insitute
>>> 2) Nuclear Safety Analysis Method Development, Enviroment & Energy
>>> Technology, Inc.
>>> Email: hoangnhanhien at gmail.com; h <hnhien at kaeri.re.kr>ien at en2t.com
>>> Phone: +81-10-2635-2411
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> Technology, Inc.
1) Nuclear Safety Department, Institute for Nuclear Science and Technology,
Technology, Inc.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201103/f4fc21e4/attachment.html>
