[petsc-users] Errors with KSP solver
Barry Smith
bsmith at petsc.dev
Mon Nov 2 21:17:01 CST 2020
Hoang,
Could you please send the entire code as a .F90 file as an attachment so we can reproduce the problem?
Thanks
Barry
> On Nov 2, 2020, at 8:38 PM, Hien HN- <hoangnhanhien at gmail.com> wrote:
> Hi Matt,
> 1) As I understood, the VecScatterCreateToAll function will create the vector sol_to_all, and it does not need to create this vector with, for example, VecCreate or VecCreateMPI function. Is this correct?
> call VecScatterCreateToAll(petsc_solution,ctx,sol_to_all,petsc_err)
> I have used the VecView to print the vector sol_to_all to a file. It seems no problem with sol_to_all.
> I installed PETSc with Intel MKL and MS-MPI libraries. So should I enable the option of Intel MKL that performs vector operations in my Fortran project?
> 2) This system is not the Laplacian.
> Thank you very much,
> Hoang
> On Mon, 2 Nov 2020 at 20:15, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Mon, Nov 2, 2020 at 12:31 AM Hien HN- <hoangnhanhien at gmail.com <mailto:hoangnhanhien at gmail.com>> wrote:
> Dear PETSc developers,
> I have used KSP solver to solve a linear equation system in parallel with 5 processors.
> The linear system consists of a pressure matrix (pressure_coeff_mat) and its RHS (p_coeff_mat) whose values are set every time step using MatSetValue and VecSetValues functions and then assembled using:
> call MatAssemblyBegin(pressure_coeff_mat,mat_final_assembly,petsc_err)
> call MatAssemblyEnd(pressure_coeff_mat,mat_final_assembly,petsc_err)
> call VecAssemblyBegin(p_coeff_rhs,petsc_err)
> call VecAssemblyEnd(p_coeff_rhs,petsc_err)
> One processor solves this linear system using KSBCGS Krylov solver with ILU preconditioner, and the result is scattered to all processors
> call KSPGetPC(petsc_ksp,petsc_pc,petsc_err)
> if (preconditioner==0) then
> call PCSetType(petsc_pc,PCJACOBI,petsc_err
> call PetscOptionsSetValue(PETSC_NULL_OPTIONS,"sub_ksp_type","preonly",petsc_err)
> call PetscOptionsSetValue(PETSC_NULL_OPTIONS,"sub_pc_type","ilu",petsc_err)
> call PCSetFromOptions(petsc_pc,petsc_err)
> else
> call PCSetType(petsc_pc,PCBJACOBI,petsc_err)
> end if
> call KSPSetFromOptions(petsc_ksp,petsc_err)
> call KSPSetUp(petsc_ksp,petsc_err)
> call KSPSolve(petsc_ksp,p_coeff_rhs,petsc_solution,petsc_err)
> call VecScatterBegin(ctx,petsc_solution,sol_to_all,INSERT_VALUES,SCATTER_FORWARD,petsc_err)
> call VecScatterEnd(ctx,petsc_solution,sol_to_all, INSERT_VALUES,SCATTER_FORWARD,petsc_err)
> call VecGetValues(sol_to_all,ncells, loc_id_to_global-1,sol, petsc_err)
> call VecScatterDestroy(ctx,petsc_err)
> call VecDestroy(sol_to_all,petsc_err)
> However, I got the following errors with vector scattering, i.e., VecScatterBegin, VecScatterEnd, and also VecGetValues. I have checked the pressure matrix, its RHS, and the solution for the first call of KSPSolve. Their values seem to be okay (see attached file). So, could you please tell me what does this error mean and how can I fix it.
> 1) The error message says that 'sol_to_all' has not been created
> 2) Is this system the Laplacian? If so, ILU is a bad preconditioner. You should try gamg.
> Thanks,
> Matt
> Thank you,
> Error message:
> Configure options --with-cc="win32fe cl" --with-fc="win32fe ifort" --with-cxx="win32fe cl" --with-blaslapack-lib="[/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_intel_c_dll.lib,/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_sequential_dll.lib,/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_core_dll.lib]" --with-mpi-lib="[/cygdrive/c/PROGRA~2/MICROS~1/MPI/Lib/x86/msmpifec.lib,/cygdrive/c/PROGRA~2/MICROS~1/MPI/Lib/x86/msmpi.lib]" --with-mpi-include="[/cygdrive/c/PROGRA~2/MICROS~1/MPI/Include,/cygdrive/c/PROGRA~2/MICROS~1/MPI/Include/x86]" --with-mpiexec=/cygdrive/c/PROGRA~1/MI564C~1/bin/mpiexec.exe --with-debugging=1 --with-shared-libraries=0 --CFLAGS=-Od --FFLAGS=-Od CXXFLAGS=-Od --with-clean=1
> #4930 VecScatterBegin() line 83 in C:\petsc\PE4D24~1.13-\src\vec\vscat\INTERF~1\vscatfce.c
> [1]PETSC ERROR:
> [2]PETSC ERROR:
> [3]PETSC ERROR:
> [0]PETSC ERROR:
> [4]PETSC ERROR:
> --------------------- Error Message --------------------------------------------------------------
> [1]PETSC ERROR:
> [2]PETSC ERROR:
> [3]PETSC ERROR:
> [0]PETSC ERROR:
> [4]PETSC ERROR:
> Null argument, when expecting valid pointer
> [1]PETSC ERROR:
> [2]PETSC ERROR:
> [3]PETSC ERROR:
> [0]PETSC ERROR:
> [4]PETSC ERROR:
> Null Object: Parameter # 3
> [1]PETSC ERROR:
> [2]PETSC ERROR:
> [3]PETSC ERROR:
> [0]PETSC ERROR:
> [4]PETSC ERROR:
> Hoang Nhan Hien, Ph.D.
> 1) Nuclear Safety Department, Institute for Nuclear Science and Technology, Vietnam Atomic Energy Insitute
> 2) Nuclear Safety Analysis Method Development, Enviroment & Energy Technology, Inc.
> Email: hoangnhanhien at gmail.com <mailto:hoangnhanhien at gmail.com>; h <mailto:hnhien at kaeri.re.kr>ien at en2t.com <mailto:ien at en2t.com>
> Phone: +81-10-2635-2411
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201102/c0fa925d/attachment-0001.html>
