[petsc-users] Errors with KSP solver
Matthew Knepley
knepley at gmail.com
Mon Nov 2 05:15:13 CST 2020
On Mon, Nov 2, 2020 at 12:31 AM Hien HN- <hoangnhanhien at gmail.com> wrote:
> Dear PETSc developers,
> *I have used KSP solver to solve a linear equation system in parallel with
> 5 processors.*
> *The linear system consists of a pressure matrix (pressure_coeff_mat) and
> its RHS (p_coeff_mat) whose values are set every time step using
> MatSetValue and VecSetValues functions and then assembled using:*
> call MatAssemblyBegin(pressure_coeff_mat,mat_final_assembly,petsc_err)
> call MatAssemblyEnd(pressure_coeff_mat,mat_final_assembly,petsc_err)
> call VecAssemblyBegin(p_coeff_rhs,petsc_err)
> call VecAssemblyEnd(p_coeff_rhs,petsc_err)
> *One processor solves this linear system using KSBCGS Krylov solver with
> ILU preconditioner, and the result is scattered to all processors*
> call KSPGetPC(petsc_ksp,petsc_pc,petsc_err)
> if (preconditioner==0) then
> call PCSetType(petsc_pc,PCJACOBI,petsc_err
> call
> PetscOptionsSetValue(PETSC_NULL_OPTIONS,"sub_ksp_type","preonly",petsc_err)
> call
> PetscOptionsSetValue(PETSC_NULL_OPTIONS,"sub_pc_type","ilu",petsc_err)
> call PCSetFromOptions(petsc_pc,petsc_err)
> else
> call PCSetType(petsc_pc,PCBJACOBI,petsc_err)
> end if
> call KSPSetFromOptions(petsc_ksp,petsc_err)
> call KSPSetUp(petsc_ksp,petsc_err)
> call KSPSolve(petsc_ksp,p_coeff_rhs,petsc_solution,petsc_err)
> call VecScatterCreateToAll(petsc_solution,ctx,sol_to_all,petsc_err)
> call
> VecScatterBegin(ctx,petsc_solution,sol_to_all,INSERT_VALUES,SCATTER_FORWARD,petsc_err)
> call VecScatterEnd(ctx,petsc_solution,sol_to_all,
> call VecGetValues(sol_to_all,ncells, loc_id_to_global-1,sol, petsc_err)
> call VecScatterDestroy(ctx,petsc_err)
> call VecDestroy(sol_to_all,petsc_err)
> *However, I got the following errors with vector scattering, i.e.,
> VecScatterBegin, VecScatterEnd, and also VecGetValues. I have checked the
> pressure matrix, its RHS, and the solution for the first call of KSPSolve.
> Their values seem to be okay (see attached file). So, could you please tell
> me what does this error mean and how can I fix it.*
1) The error message says that 'sol_to_all' has not been created
2) Is this system the Laplacian? If so, ILU is a bad preconditioner. You
should try gamg.
Matt
> *Thank you,*
> *Error message:*
> Configure options --with-cc="win32fe cl" --with-fc="win32fe ifort"
> --with-cxx="win32fe cl"
> --with-blaslapack-lib="[/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_intel_c_dll.lib,/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_sequential_dll.lib,/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_core_dll.lib]"
> --with-mpi-lib="[/cygdrive/c/PROGRA~2/MICROS~1/MPI/Lib/x86/msmpifec.lib,/cygdrive/c/PROGRA~2/MICROS~1/MPI/Lib/x86/msmpi.lib]"
> --with-mpi-include="[/cygdrive/c/PROGRA~2/MICROS~1/MPI/Include,/cygdrive/c/PROGRA~2/MICROS~1/MPI/Include/x86]"
> --with-mpiexec=/cygdrive/c/PROGRA~1/MI564C~1/bin/mpiexec.exe
> --with-debugging=1 --with-shared-libraries=0 --CFLAGS=-Od --FFLAGS=-Od
> CXXFLAGS=-Od --with-clean=1
> #4930 VecScatterBegin() line 83 in
> C:\petsc\PE4D24~1.13-\src\vec\vscat\INTERF~1\vscatfce.c
> [1]PETSC ERROR:
> [2]PETSC ERROR:
> [3]PETSC ERROR:
> [0]PETSC ERROR:
> [4]PETSC ERROR:
> --------------------- Error Message
> [1]PETSC ERROR:
> [2]PETSC ERROR:
> [3]PETSC ERROR:
> [0]PETSC ERROR:
> [4]PETSC ERROR:
> Null argument, when expecting valid pointer
> [1]PETSC ERROR:
> [2]PETSC ERROR:
> [3]PETSC ERROR:
> [0]PETSC ERROR:
> [4]PETSC ERROR:
> Null Object: Parameter # 3
> [1]PETSC ERROR:
> [2]PETSC ERROR:
> [3]PETSC ERROR:
> [0]PETSC ERROR:
> [4]PETSC ERROR:
> Hoang Nhan Hien, Ph.D.
> 1) Nuclear Safety Department, Institute for Nuclear Science and
> Technology, Vietnam Atomic Energy Insitute
> 2) Nuclear Safety Analysis Method Development, Enviroment & Energy
> Technology, Inc.
> Email: hoangnhanhien at gmail.com; h <hnhien at kaeri.re.kr>ien at en2t.com
> Phone: +81-10-2635-2411
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201102/e1e9b8de/attachment.html>
