[petsc-users] Errors with KSP solver
Hien HN-
hoangnhanhien at gmail.com
Sun Nov 1 23:26:45 CST 2020
Dear PETSc developers,
*I have used KSP solver to solve a linear equation system in parallel with
5 processors.*
*The linear system consists of a pressure matrix (pressure_coeff_mat) and
its RHS (p_coeff_mat) whose values are set every time step using
MatSetValue and VecSetValues functions and then assembled using:*
call MatAssemblyBegin(pressure_coeff_mat,mat_final_assembly,petsc_err)
call MatAssemblyEnd(pressure_coeff_mat,mat_final_assembly,petsc_err)
call VecAssemblyBegin(p_coeff_rhs,petsc_err)
call VecAssemblyEnd(p_coeff_rhs,petsc_err)
*One processor solves this linear system using KSBCGS Krylov solver with
ILU preconditioner, and the result is scattered to all processors*
call KSPGetPC(petsc_ksp,petsc_pc,petsc_err)
if (preconditioner==0) then
call PCSetType(petsc_pc,PCJACOBI,petsc_err
call
PetscOptionsSetValue(PETSC_NULL_OPTIONS,"sub_ksp_type","preonly",petsc_err)
call
PetscOptionsSetValue(PETSC_NULL_OPTIONS,"sub_pc_type","ilu",petsc_err)
call PCSetFromOptions(petsc_pc,petsc_err)
else
call PCSetType(petsc_pc,PCBJACOBI,petsc_err)
end if
call KSPSetFromOptions(petsc_ksp,petsc_err)
call KSPSetUp(petsc_ksp,petsc_err)
call KSPSolve(petsc_ksp,p_coeff_rhs,petsc_solution,petsc_err)
call VecScatterCreateToAll(petsc_solution,ctx,sol_to_all,petsc_err)
call
VecScatterBegin(ctx,petsc_solution,sol_to_all,INSERT_VALUES,SCATTER_FORWARD,petsc_err)
call VecScatterEnd(ctx,petsc_solution,sol_to_all,
call VecGetValues(sol_to_all,ncells, loc_id_to_global-1,sol, petsc_err)
call VecScatterDestroy(ctx,petsc_err)
call VecDestroy(sol_to_all,petsc_err)
*However, I got the following errors with vector scattering, i.e.,
VecScatterBegin, VecScatterEnd, and also VecGetValues. I have checked the
pressure matrix, its RHS, and the solution for the first call of KSPSolve.
Their values seem to be okay (see attached file). So, could you please tell
me what does this error mean and how can I fix it.*
*Thank you,*
*Error message:*
Configure options --with-cc="win32fe cl" --with-fc="win32fe ifort"
--with-cxx="win32fe cl"
--with-blaslapack-lib="[/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_intel_c_dll.lib,/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_sequential_dll.lib,/cygdrive/c/PROGRA~2/Intel/COMPOS~1/mkl/lib/ia32/mkl_core_dll.lib]"
--with-mpi-lib="[/cygdrive/c/PROGRA~2/MICROS~1/MPI/Lib/x86/msmpifec.lib,/cygdrive/c/PROGRA~2/MICROS~1/MPI/Lib/x86/msmpi.lib]"
--with-mpi-include="[/cygdrive/c/PROGRA~2/MICROS~1/MPI/Include,/cygdrive/c/PROGRA~2/MICROS~1/MPI/Include/x86]"
--with-mpiexec=/cygdrive/c/PROGRA~1/MI564C~1/bin/mpiexec.exe
--with-debugging=1 --with-shared-libraries=0 --CFLAGS=-Od --FFLAGS=-Od
CXXFLAGS=-Od --with-clean=1
#4930 VecScatterBegin() line 83 in
C:\petsc\PE4D24~1.13-\src\vec\vscat\INTERF~1\vscatfce.c
[1]PETSC ERROR:
[2]PETSC ERROR:
[3]PETSC ERROR:
[0]PETSC ERROR:
[4]PETSC ERROR:
--------------------- Error Message
[1]PETSC ERROR:
[2]PETSC ERROR:
[3]PETSC ERROR:
[0]PETSC ERROR:
[4]PETSC ERROR:
Null argument, when expecting valid pointer
[1]PETSC ERROR:
[2]PETSC ERROR:
[3]PETSC ERROR:
[0]PETSC ERROR:
[4]PETSC ERROR:
Null Object: Parameter # 3
[1]PETSC ERROR:
[2]PETSC ERROR:
[3]PETSC ERROR:
[0]PETSC ERROR:
[4]PETSC ERROR:
Hoang Nhan Hien, Ph.D.
1) Nuclear Safety Department, Institute for Nuclear Science and Technology,
Vietnam Atomic Energy Insitute
2) Nuclear Safety Analysis Method Development, Enviroment & Energy
Technology, Inc.
Email: hoangnhanhien at gmail.com; h <hnhien at kaeri.re.kr>ien at en2t.com
Phone: +81-10-2635-2411
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201102/afe824a0/attachment-0001.html>
Vec Object: 1 MPI processes
type: seq
0.0081705
0.0171705
0.0171705
0.0081705
0.0171705
0.0177597
0.0177597
0.0171705
0.0171751
0.01776
0.01776
0.0171751
0.00815977
0.017173
0.017173
0.00815977
0.0700058
0.0787089
0.0787089
0.0700058
0.078709
0.0781956
0.0781956
0.078709
0.0787135
0.0781955
0.0781955
0.0787135
0.0699948
0.0787119
0.0787119
0.0699948
0.0703009
0.0790041
0.0790041
0.0703009
0.0790042
0.0784907
0.0784907
0.0790042
0.0790087
0.0784906
0.0784906
0.0790087
0.0702899
0.0790072
0.0790072
0.0702899
0.0703167
0.0790201
0.0790201
0.0703167
0.0790202
0.0785066
0.0785066
0.0790202
0.0790247
0.0785066
0.0785066
0.0790247
0.0703057
0.0790231
0.0790231
0.0703057
0.0703324
0.079036
0.079036
0.0703324
0.0790361
0.0785226
0.0785226
0.0790361
0.0790406
0.0785225
0.0785225
0.0790406
0.0703214
0.0790391
0.0790391
0.0703214
0.0703483
0.0790521
0.0790521
0.0703483
0.0790522
0.0785386
0.0785386
0.0790522
0.0790567
0.0785386
0.0785386
0.0790567
0.0703373
0.0790552
0.0790552
0.0703373
0.0703653
0.0790693
0.0790693
0.0703653
0.0790694
0.0785558
0.0785558
0.0790694
0.0790739
0.0785558
0.0785558
0.0790739
0.0703543
0.0790724
0.0790724
0.0703543
0.0863353
0.0950395
0.0950395
0.0863353
0.0950396
0.0945259
0.0945259
0.0950396
0.0950442
0.0945259
0.0945259
0.0950442
0.0863243
0.0950426
0.0950426
0.0863243
0.0366038
0.0453081
0.0453081
0.0366038
0.0453082
0.0447948
0.0447948
0.0453082
0.0453127
0.0447947
0.0447947
0.0453127
0.0365928
0.0453111
0.0453111
0.0365928
0.0701306
0.0788351
0.0788351
0.0701306
0.0788352
0.0783216
0.0783216
0.0788352
0.0788397
0.0783215
0.0783215
0.0788397
0.0701196
0.0788382
0.0788382
0.0701196
0.0704182
0.0791229
0.0791229
0.0704182
0.079123
0.0786094
0.0786094
0.079123
0.0791275
0.0786093
0.0786093
0.0791275
0.0704072
0.0791259
0.0791259
0.0704072
0.0704337
0.0791386
0.0791386
0.0704337
0.0791387
0.0786251
0.0786251
0.0791387
0.0791432
0.078625
0.078625
0.0791432
0.0704227
0.0791417
0.0791417
0.0704227
0.0704492
0.0791543
0.0791543
0.0704492
0.0791544
0.0786408
0.0786408
0.0791544
0.0791589
0.0786407
0.0786407
0.0791589
0.0704382
0.0791574
0.0791574
0.0704382
0.0704661
0.0791714
0.0791714
0.0704661
0.0791715
0.0786579
0.0786579
0.0791715
0.079176
0.0786578
0.0786578
0.079176
0.0704552
0.0791745
0.0791745
0.0704552
0.0869215
0.095627
0.095627
0.0869215
0.0956271
0.0951134
0.0951134
0.0956271
0.0956317
0.0951133
0.0951133
0.0956317
0.0869106
0.0956301
0.0956301
0.0869106
0.0362613
0.0449669
0.0449669
0.0362613
0.044967
0.0444535
0.0444535
0.044967
0.0449715
0.0444534
0.0444534
0.0449715
0.0362503
0.0449699
0.0449699
0.0362503
0.070231
0.0789367
0.0789367
0.070231
0.0789368
0.0784231
0.0784231
0.0789368
0.0789413
0.0784231
0.0784231
0.0789413
0.07022
0.0789398
0.0789398
0.07022
0.0705186
0.0792246
0.0792246
0.0705186
0.0792246
0.0787109
0.0787109
0.0792246
0.0792292
0.0787109
0.0787109
0.0792292
0.0705076
0.0792276
0.0792276
0.0705076
0.0705341
0.0792403
0.0792403
0.0705341
0.0792404
0.0787267
0.0787267
0.0792404
0.0792449
0.0787266
0.0787266
0.0792449
0.0705232
0.0792434
0.0792434
0.0705232
0.0705497
0.079256
0.079256
0.0705497
0.0792561
0.0787424
0.0787424
0.0792561
0.0792606
0.0787423
0.0787423
0.0792606
0.0705387
0.0792591
0.0792591
0.0705387
0.0705666
0.0792732
0.0792732
0.0705666
0.0792732
0.0787595
0.0787595
0.0792732
0.0792778
0.0787595
0.0787595
0.0792778
0.0705556
0.0792762
0.0792762
0.0705556
0.0870236
0.0957304
0.0957304
0.0870236
0.0957304
0.0952166
0.0952166
0.0957304
0.095735
0.0952166
0.0952166
0.095735
0.0870126
0.0957335
0.0957335
0.0870126
0.0363585
0.0450654
0.0450654
0.0363585
0.0450654
0.0445519
0.0445519
0.0450654
0.0450699
0.0445518
0.0445518
0.0450699
0.0363475
0.0450684
0.0450684
0.0363475
0.0703315
0.0790385
0.0790385
0.0703315
0.0790386
0.0785248
0.0785248
0.0790386
0.0790431
0.0785248
0.0785248
0.0790431
0.0703205
0.0790416
0.0790416
0.0703205
0.0706191
0.0793264
0.0793264
0.0706191
0.0793264
0.0788127
0.0788127
0.0793264
0.079331
0.0788126
0.0788126
0.079331
0.0706081
0.0793294
0.0793294
0.0706081
0.0706347
0.0793421
0.0793421
0.0706347
0.0793422
0.0788284
0.0788284
0.0793422
0.0793467
0.0788284
0.0788284
0.0793467
0.0706237
0.0793452
0.0793452
0.0706237
0.0706503
0.0793579
0.0793579
0.0706503
0.0793579
0.0788442
0.0788442
0.0793579
0.0793625
0.0788441
0.0788441
0.0793625
0.0706393
0.0793609
0.0793609
0.0706393
0.0706672
0.079375
0.079375
0.0706672
0.0793751
0.0788613
0.0788613
0.0793751
0.0793796
0.0788612
0.0788612
0.0793796
0.0706562
0.0793781
0.0793781
0.0706562
0.0871258
0.0958338
0.0958338
0.0871258
0.0958339
0.09532
0.09532
0.0958339
0.0958385
0.0953199
0.0953199
0.0958385
0.0871148
0.0958369
0.0958369
0.0871148
0.0364558
0.045164
0.045164
0.0364558
0.045164
0.0446504
0.0446504
0.045164
0.0451685
0.0446503
0.0446503
0.0451685
0.0364448
0.045167
0.045167
0.0364448
0.0704321
0.0791404
0.0791404
0.0704321
0.0791405
0.0786267
0.0786267
0.0791405
0.079145
0.0786266
0.0786266
0.079145
0.0704211
0.0791435
0.0791435
0.0704211
0.0707198
0.0794283
0.0794283
0.0707198
0.0794284
0.0789145
0.0789145
0.0794284
0.0794329
0.0789145
0.0789145
0.0794329
0.0707088
0.0794313
0.0794313
0.0707088
0.0707354
0.0794441
0.0794441
0.0707354
0.0794442
0.0789303
0.0789303
0.0794442
0.0794487
0.0789302
0.0789302
0.0794487
0.0707244
0.0794471
0.0794471
0.0707244
0.070751
0.0794599
0.0794599
0.070751
0.0794599
0.0789461
0.0789461
0.0794599
0.0794645
0.078946
0.078946
0.0794645
0.07074
0.0794629
0.0794629
0.07074
0.070768
0.079477
0.079477
0.070768
0.0794771
0.0789632
0.0789632
0.0794771
0.0794816
0.0789632
0.0789632
0.0794816
0.070757
0.0794801
0.0794801
0.070757
0.0872281
0.0959374
0.0959374
0.0872281
0.0959375
0.0954235
0.0954235
0.0959375
0.095942
0.0954235
0.0954235
0.095942
0.0872171
0.0959405
0.0959405
0.0872171
0.0365533
0.0452627
0.0452627
0.0365533
0.0452627
0.0447491
0.0447491
0.0452627
0.0452672
0.044749
0.044749
0.0452672
0.0365423
0.0452657
0.0452657
0.0365423
0.0705329
0.0792425
0.0792425
0.0705329
0.0792425
0.0787286
0.0787286
0.0792425
0.0792471
0.0787286
0.0787286
0.0792471
0.0705219
0.0792455
0.0792455
0.0705219
0.0708206
0.0795304
0.0795304
0.0708206
0.0795304
0.0790165
0.0790165
0.0795304
0.079535
0.0790164
0.0790164
0.079535
0.0708096
0.0795334
0.0795334
0.0708096
0.0708362
0.0795462
0.0795462
0.0708362
0.0795462
0.0790323
0.0790323
0.0795462
0.0795508
0.0790323
0.0790323
0.0795508
0.0708252
0.0795492
0.0795492
0.0708252
0.0708518
0.079562
0.079562
0.0708518
0.079562
0.0790481
0.0790481
0.079562
0.0795666
0.079048
0.079048
0.0795666
0.0708408
0.079565
0.079565
0.0708408
0.0708688
0.0795792
0.0795792
0.0708688
0.0795792
0.0790653
0.0790653
0.0795792
0.0795838
0.0790652
0.0790652
0.0795838
0.0708578
0.0795822
0.0795822
0.0708578
0.0873306
0.0960411
0.0960411
0.0873306
0.0960412
0.0955271
0.0955271
0.0960412
0.0960458
0.0955271
0.0955271
0.0960458
0.0873196
0.0960442
0.0960442
0.0873196
0.0366573
0.045368
0.045368
0.0366573
0.0453681
0.0448543
0.0448543
0.0453681
0.0453726
0.0448542
0.0448542
0.0453726
0.0366464
0.045371
0.045371
0.0366464
0.0706379
0.0793488
0.0793488
0.0706379
0.0793488
0.0788348
0.0788348
0.0793488
0.0793534
0.0788348
0.0788348
0.0793534
0.0706269
0.0793518
0.0793518
0.0706269
0.0709211
0.0796321
0.0796321
0.0709211
0.0796322
0.0791182
0.0791182
0.0796322
0.0796367
0.0791181
0.0791181
0.0796367
0.0709101
0.0796352
0.0796352
0.0709101
0.0709365
0.0796477
0.0796477
0.0709365
0.0796478
0.0791338
0.0791338
0.0796478
0.0796523
0.0791337
0.0791337
0.0796523
0.0709255
0.0796507
0.0796507
0.0709255
0.0709519
0.0796633
0.0796633
0.0709519
0.0796634
0.0791493
0.0791493
0.0796634
0.0796679
0.0791493
0.0791493
0.0796679
0.0709409
0.0796663
0.0796663
0.0709409
0.0718272
0.080538
0.080538
0.0718272
0.0805381
0.0800241
0.0800241
0.0805381
0.0805426
0.080024
0.080024
0.0805426
0.0718162
0.0805411
0.0805411
0.0718162
0.0081705
0.0171705
0.0171751
0.0171705
0.0177597
0.01776
0.017173
0.0171705
0.0177597
0.01776
0.017173
0.0081705
0.0171705
0.0171751
0.00815977
0.0700058
0.078709
0.0787135
0.0787089
0.0781956
0.0781955
0.0787119
0.0787089
0.0781956
0.0781955
0.0787119
0.0700058
0.078709
0.0787135
0.0699948
0.0703009
0.0790042
0.0790087
0.0790041
0.0784907
0.0784906
0.0790072
0.0790041
0.0784907
0.0784906
0.0790072
0.0703009
0.0790042
0.0790087
0.0702899
0.0703167
0.0790202
0.0790247
0.0790201
0.0785066
0.0785066
0.0790231
0.0790201
0.0785066
0.0785066
0.0790231
0.0703167
0.0790202
0.0790247
0.0703057
0.0703324
0.0790361
0.0790406
0.079036
0.0785226
0.0785225
0.0790391
0.079036
0.0785226
0.0785225
0.0790391
0.0703324
0.0790361
0.0790406
0.0703214
0.0703483
0.0790522
0.0790567
0.0790521
0.0785386
0.0785386
0.0790552
0.0790521
0.0785386
0.0785386
0.0790552
0.0703483
0.0790522
0.0790567
0.0703373
0.0703653
0.0790694
0.0790739
0.0790693
0.0785558
0.0785558
0.0790724
0.0790693
0.0785558
0.0785558
0.0790724
0.0703653
0.0790694
0.0790739
0.0703543
0.0863353
0.0950396
0.0950442
0.0950395
0.0945259
0.0945259
0.0950426
0.0950395
0.0945259
0.0945259
0.0950426
0.0863353
0.0950396
0.0950442
0.0863243
0.0366038
0.0453082
0.0453127
0.0453081
0.0447948
0.0447947
0.0453111
0.0453081
0.0447948
0.0447947
0.0453111
0.0366038
0.0453082
0.0453127
0.0365928
0.0701306
0.0788352
0.0788397
0.0788351
0.0783216
0.0783215
0.0788382
0.0788351
0.0783216
0.0783215
0.0788382
0.0701306
0.0788352
0.0788397
0.0701196
0.0704182
0.079123
0.0791275
0.0791229
0.0786094
0.0786093
0.0791259
0.0791229
0.0786094
0.0786093
0.0791259
0.0704182
0.079123
0.0791275
0.0704072
0.0704337
0.0791387
0.0791432
0.0791386
0.0786251
0.078625
0.0791417
0.0791386
0.0786251
0.078625
0.0791417
0.0704337
0.0791387
0.0791432
0.0704227
0.0704492
0.0791544
0.0791589
0.0791543
0.0786408
0.0786407
0.0791574
0.0791543
0.0786408
0.0786407
0.0791574
0.0704492
0.0791544
0.0791589
0.0704382
0.0704661
0.0791715
0.079176
0.0791714
0.0786579
0.0786578
0.0791745
0.0791714
0.0786579
0.0786578
0.0791745
0.0704661
0.0791715
0.079176
0.0704552
0.0869215
0.0956271
0.0956317
0.095627
0.0951134
0.0951133
0.0956301
0.095627
0.0951134
0.0951133
0.0956301
0.0869215
0.0956271
0.0956317
0.0869106
0.0362613
0.044967
0.0449715
0.0449669
0.0444535
0.0444534
0.0449699
0.0449669
0.0444535
0.0444534
0.0449699
0.0362613
0.044967
0.0449715
0.0362503
0.070231
0.0789368
0.0789413
0.0789367
0.0784231
0.0784231
0.0789398
0.0789367
0.0784231
0.0784231
0.0789398
0.070231
0.0789368
0.0789413
0.07022
0.0705186
0.0792246
0.0792292
0.0792246
0.0787109
0.0787109
0.0792276
0.0792246
0.0787109
0.0787109
0.0792276
0.0705186
0.0792246
0.0792292
0.0705076
0.0705341
0.0792404
0.0792449
0.0792403
0.0787267
0.0787266
0.0792434
0.0792403
0.0787267
0.0787266
0.0792434
0.0705341
0.0792404
0.0792449
0.0705232
0.0705497
0.0792561
0.0792606
0.079256
0.0787424
0.0787423
0.0792591
0.079256
0.0787424
0.0787423
0.0792591
0.0705497
0.0792561
0.0792606
0.0705387
0.0705666
0.0792732
0.0792778
0.0792732
0.0787595
0.0787595
0.0792762
0.0792732
0.0787595
0.0787595
0.0792762
0.0705666
0.0792732
0.0792778
0.0705556
0.0870236
0.0957304
0.095735
0.0957304
0.0952166
0.0952166
0.0957335
0.0957304
0.0952166
0.0952166
0.0957335
0.0870236
0.0957304
0.095735
0.0870126
0.0363585
0.0450654
0.0450699
0.0450654
0.0445519
0.0445518
0.0450684
0.0450654
0.0445519
0.0445518
0.0450684
0.0363585
0.0450654
0.0450699
0.0363475
0.0703315
0.0790386
0.0790431
0.0790385
0.0785248
0.0785248
0.0790416
0.0790385
0.0785248
0.0785248
0.0790416
0.0703315
0.0790386
0.0790431
0.0703205
0.0706191
0.0793264
0.079331
0.0793264
0.0788127
0.0788126
0.0793294
0.0793264
0.0788127
0.0788126
0.0793294
0.0706191
0.0793264
0.079331
0.0706081
0.0706347
0.0793422
0.0793467
0.0793421
0.0788284
0.0788284
0.0793452
0.0793421
0.0788284
0.0788284
0.0793452
0.0706347
0.0793422
0.0793467
0.0706237
0.0706503
0.0793579
0.0793625
0.0793579
0.0788442
0.0788441
0.0793609
0.0793579
0.0788442
0.0788441
0.0793609
0.0706503
0.0793579
0.0793625
0.0706393
0.0706672
0.0793751
0.0793796
0.079375
0.0788613
0.0788612
0.0793781
0.079375
0.0788613
0.0788612
0.0793781
0.0706672
0.0793751
0.0793796
0.0706562
0.0871258
0.0958339
0.0958385
0.0958338
0.09532
0.0953199
0.0958369
0.0958338
0.09532
0.0953199
0.0958369
0.0871258
0.0958339
0.0958385
0.0871148
0.0364558
0.045164
0.0451685
0.045164
0.0446504
0.0446503
0.045167
0.045164
0.0446504
0.0446503
0.045167
0.0364558
0.045164
0.0451685
0.0364448
0.0704321
0.0791405
0.079145
0.0791404
0.0786267
0.0786266
0.0791435
0.0791404
0.0786267
0.0786266
0.0791435
0.0704321
0.0791405
0.079145
0.0704211
0.0707198
0.0794284
0.0794329
0.0794283
0.0789145
0.0789145
0.0794313
0.0794283
0.0789145
0.0789145
0.0794313
0.0707198
0.0794284
0.0794329
0.0707088
0.0707354
0.0794442
0.0794487
0.0794441
0.0789303
0.0789302
0.0794471
0.0794441
0.0789303
0.0789302
0.0794471
0.0707354
0.0794442
0.0794487
0.0707244
0.070751
0.0794599
0.0794645
0.0794599
0.0789461
0.078946
0.0794629
0.0794599
0.0789461
0.078946
0.0794629
0.070751
0.0794599
0.0794645
0.07074
0.070768
0.0794771
0.0794816
0.079477
0.0789632
0.0789632
0.0794801
0.079477
0.0789632
0.0789632
0.0794801
0.070768
0.0794771
0.0794816
0.070757
0.0872281
0.0959375
0.095942
0.0959374
0.0954235
0.0954235
0.0959405
0.0959374
0.0954235
0.0954235
0.0959405
0.0872281
0.0959375
0.095942
0.0872171
0.0365533
0.0452627
0.0452672
0.0452627
0.0447491
0.044749
0.0452657
0.0452627
0.0447491
0.044749
0.0452657
0.0365533
0.0452627
0.0452672
0.0365423
0.0705329
0.0792425
0.0792471
0.0792425
0.0787286
0.0787286
0.0792455
0.0792425
0.0787286
0.0787286
0.0792455
0.0705329
0.0792425
0.0792471
0.0705219
0.0708206
0.0795304
0.079535
0.0795304
0.0790165
0.0790164
0.0795334
0.0795304
0.0790165
0.0790164
0.0795334
0.0708206
0.0795304
0.079535
0.0708096
0.0708362
0.0795462
0.0795508
0.0795462
0.0790323
0.0790323
0.0795492
0.0795462
0.0790323
0.0790323
0.0795492
0.0708362
0.0795462
0.0795508
0.0708252
0.0708518
0.079562
0.0795666
0.079562
0.0790481
0.079048
0.079565
0.079562
0.0790481
0.079048
0.079565
0.0708518
0.079562
0.0795666
0.0708408
0.0708688
0.0795792
0.0795838
0.0795792
0.0790653
0.0790652
0.0795822
0.0795792
0.0790653
0.0790652
0.0795822
0.0708688
0.0795792
0.0795838
0.0708578
0.0873306
0.0960412
0.0960458
0.0960411
0.0955271
0.0955271
0.0960442
0.0960411
0.0955271
0.0955271
0.0960442
0.0873306
0.0960412
0.0960458
0.0873196
0.0366573
0.0453681
0.0453726
0.045368
0.0448543
0.0448542
0.045371
0.045368
0.0448543
0.0448542
0.045371
0.0366573
0.0453681
0.0453726
0.0366464
0.0706379
0.0793488
0.0793534
0.0793488
0.0788348
0.0788348
0.0793518
0.0793488
0.0788348
0.0788348
0.0793518
0.0706379
0.0793488
0.0793534
0.0706269
0.0709211
0.0796322
0.0796367
0.0796321
0.0791182
0.0791181
0.0796352
0.0796321
0.0791182
0.0791181
0.0796352
0.0709211
0.0796322
0.0796367
0.0709101
0.0709365
0.0796478
0.0796523
0.0796477
0.0791338
0.0791337
0.0796507
0.0796477
0.0791338
0.0791337
0.0796507
0.0709365
0.0796478
0.0796523
0.0709255
0.0709519
0.0796634
0.0796679
0.0796633
0.0791493
0.0791493
0.0796663
0.0796633
0.0791493
0.0791493
0.0796663
0.0709519
0.0796634
0.0796679
0.0709409
0.0718272
0.0805381
0.0805426
0.080538
0.0800241
0.080024
0.0805411
0.080538
0.0800241
0.080024
0.0805411
0.0718272
0.0805381
0.0805426
0.0718162
0.0177602
0.0177602
0.017173
0.0177602
0.0177602
0.017173
0.017173
0.017173
0.00815977
0.0781954
0.0781954
0.0787119
0.0781954
0.0781954
0.0787119
0.0787119
0.0787119
0.0699948
0.0784905
0.0784905
0.0790072
0.0784905
0.0784905
0.0790072
0.0790072
0.0790072
0.0702899
0.0785064
0.0785064
0.0790231
0.0785064
0.0785064
0.0790231
0.0790231
0.0790231
0.0703057
0.0785223
0.0785223
0.0790391
0.0785223
0.0785223
0.0790391
0.0790391
0.0790391
0.0703214
0.0785384
0.0785384
0.0790552
0.0785384
0.0785384
0.0790552
0.0790552
0.0790552
0.0703373
0.0785556
0.0785556
0.0790724
0.0785556
0.0785556
0.0790724
0.0790724
0.0790724
0.0703543
0.0945258
0.0945258
0.0950426
0.0945258
0.0945258
0.0950426
0.0950426
0.0950426
0.0863243
0.0447946
0.0447946
0.0453111
0.0447946
0.0447946
0.0453111
0.0453111
0.0453111
0.0365928
0.0783214
0.0783214
0.0788382
0.0783214
0.0783214
0.0788382
0.0788382
0.0788382
0.0701196
0.0786091
0.0786091
0.0791259
0.0786091
0.0786091
0.0791259
0.0791259
0.0791259
0.0704072
0.0786249
0.0786249
0.0791417
0.0786249
0.0786249
0.0791417
0.0791417
0.0791417
0.0704227
0.0786406
0.0786406
0.0791574
0.0786406
0.0786406
0.0791574
0.0791574
0.0791574
0.0704382
0.0786577
0.0786577
0.0791745
0.0786577
0.0786577
0.0791745
0.0791745
0.0791745
0.0704552
0.0951132
0.0951132
0.0956301
0.0951132
0.0951132
0.0956301
0.0956301
0.0956301
0.0869106
0.0444533
0.0444533
0.0449699
0.0444533
0.0444533
0.0449699
0.0449699
0.0449699
0.0362503
0.0784229
0.0784229
0.0789398
0.0784229
0.0784229
0.0789398
0.0789398
0.0789398
0.07022
0.0787107
0.0787107
0.0792276
0.0787107
0.0787107
0.0792276
0.0792276
0.0792276
0.0705076
0.0787265
0.0787265
0.0792434
0.0787265
0.0787265
0.0792434
0.0792434
0.0792434
0.0705232
0.0787422
0.0787422
0.0792591
0.0787422
0.0787422
0.0792591
0.0792591
0.0792591
0.0705387
0.0787593
0.0787593
0.0792762
0.0787593
0.0787593
0.0792762
0.0792762
0.0792762
0.0705556
0.0952164
0.0952164
0.0957335
0.0952164
0.0952164
0.0957335
0.0957335
0.0957335
0.0870126
0.0445517
0.0445517
0.0450684
0.0445517
0.0445517
0.0450684
0.0450684
0.0450684
0.0363475
0.0785246
0.0785246
0.0790416
0.0785246
0.0785246
0.0790416
0.0790416
0.0790416
0.0703205
0.0788125
0.0788125
0.0793294
0.0788125
0.0788125
0.0793294
0.0793294
0.0793294
0.0706081
0.0788282
0.0788282
0.0793452
0.0788282
0.0788282
0.0793452
0.0793452
0.0793452
0.0706237
0.0788439
0.0788439
0.0793609
0.0788439
0.0788439
0.0793609
0.0793609
0.0793609
0.0706393
0.0788611
0.0788611
0.0793781
0.0788611
0.0788611
0.0793781
0.0793781
0.0793781
0.0706562
0.0953198
0.0953198
0.0958369
0.0953198
0.0953198
0.0958369
0.0958369
0.0958369
0.0871148
0.0446502
0.0446502
0.045167
0.0446502
0.0446502
0.045167
0.045167
0.045167
0.0364448
0.0786265
0.0786265
0.0791435
0.0786265
0.0786265
0.0791435
0.0791435
0.0791435
0.0704211
0.0789143
0.0789143
0.0794313
0.0789143
0.0789143
0.0794313
0.0794313
0.0794313
0.0707088
0.0789301
0.0789301
0.0794471
0.0789301
0.0789301
0.0794471
0.0794471
0.0794471
0.0707244
0.0789458
0.0789458
0.0794629
0.0789458
0.0789458
0.0794629
0.0794629
0.0794629
0.07074
0.078963
0.078963
0.0794801
0.078963
0.078963
0.0794801
0.0794801
0.0794801
0.070757
0.0954233
0.0954233
0.0959405
0.0954233
0.0954233
0.0959405
0.0959405
0.0959405
0.0872171
0.0447488
0.0447488
0.0452657
0.0447488
0.0447488
0.0452657
0.0452657
0.0452657
0.0365423
0.0787284
0.0787284
0.0792455
0.0787284
0.0787284
0.0792455
0.0792455
0.0792455
0.0705219
0.0790163
0.0790163
0.0795334
0.0790163
0.0790163
0.0795334
0.0795334
0.0795334
0.0708096
0.0790321
0.0790321
0.0795492
0.0790321
0.0790321
0.0795492
0.0795492
0.0795492
0.0708252
0.0790479
0.0790479
0.079565
0.0790479
0.0790479
0.079565
0.079565
0.079565
0.0708408
0.0790651
0.0790651
0.0795822
0.0790651
0.0790651
0.0795822
0.0795822
0.0795822
0.0708578
0.095527
0.095527
0.0960442
0.095527
0.095527
0.0960442
0.0960442
0.0960442
0.0873196
0.0448541
0.0448541
0.045371
0.0448541
0.0448541
0.045371
0.045371
0.045371
0.0366464
0.0788346
0.0788346
0.0793518
0.0788346
0.0788346
0.0793518
0.0793518
0.0793518
0.0706269
0.079118
0.079118
0.0796352
0.079118
0.079118
0.0796352
0.0796352
0.0796352
0.0709101
0.0791335
0.0791335
0.0796507
0.0791335
0.0791335
0.0796507
0.0796507
0.0796507
0.0709255
0.0791491
0.0791491
0.0796663
0.0791491
0.0791491
0.0796663
0.0796663
0.0796663
0.0709409
0.0800239
0.0800239
0.0805411
0.0800239
0.0800239
0.0805411
0.0805411
0.0805411
0.0718162
0.0171751
0.0171705
0.0081705
0.01776
0.0177597
0.0171705
0.01776
0.0177597
0.0171705
0.0171751
0.0171705
0.0081705
0.0787135
0.078709
0.0700058
0.0781955
0.0781956
0.0787089
0.0781955
0.0781956
0.0787089
0.0787135
0.078709
0.0700058
0.0790087
0.0790042
0.0703009
0.0784906
0.0784907
0.0790041
0.0784906
0.0784907
0.0790041
0.0790087
0.0790042
0.0703009
0.0790247
0.0790202
0.0703167
0.0785066
0.0785066
0.0790201
0.0785066
0.0785066
0.0790201
0.0790247
0.0790202
0.0703167
0.0790406
0.0790361
0.0703324
0.0785225
0.0785226
0.079036
0.0785225
0.0785226
0.079036
0.0790406
0.0790361
0.0703324
0.0790567
0.0790522
0.0703483
0.0785386
0.0785386
0.0790521
0.0785386
0.0785386
0.0790521
0.0790567
0.0790522
0.0703483
0.0790739
0.0790694
0.0703653
0.0785558
0.0785558
0.0790693
0.0785558
0.0785558
0.0790693
0.0790739
0.0790694
0.0703653
0.0950442
0.0950396
0.0863353
0.0945259
0.0945259
0.0950395
0.0945259
0.0945259
0.0950395
0.0950442
0.0950396
0.0863353
0.0453127
0.0453082
0.0366038
0.0447947
0.0447948
0.0453081
0.0447947
0.0447948
0.0453081
0.0453127
0.0453082
0.0366038
0.0788397
0.0788352
0.0701306
0.0783215
0.0783216
0.0788351
0.0783215
0.0783216
0.0788351
0.0788397
0.0788352
0.0701306
0.0791275
0.079123
0.0704182
0.0786093
0.0786094
0.0791229
0.0786093
0.0786094
0.0791229
0.0791275
0.079123
0.0704182
0.0791432
0.0791387
0.0704337
0.078625
0.0786251
0.0791386
0.078625
0.0786251
0.0791386
0.0791432
0.0791387
0.0704337
0.0791589
0.0791544
0.0704492
0.0786407
0.0786408
0.0791543
0.0786407
0.0786408
0.0791543
0.0791589
0.0791544
0.0704492
0.079176
0.0791715
0.0704661
0.0786578
0.0786579
0.0791714
0.0786578
0.0786579
0.0791714
0.079176
0.0791715
0.0704661
0.0956317
0.0956271
0.0869215
0.0951133
0.0951134
0.095627
0.0951133
0.0951134
0.095627
0.0956317
0.0956271
0.0869215
0.0449715
0.044967
0.0362613
0.0444534
0.0444535
0.0449669
0.0444534
0.0444535
0.0449669
0.0449715
0.044967
0.0362613
0.0789413
0.0789368
0.070231
0.0784231
0.0784231
0.0789367
0.0784231
0.0784231
0.0789367
0.0789413
0.0789368
0.070231
0.0792292
0.0792246
0.0705186
0.0787109
0.0787109
0.0792246
0.0787109
0.0787109
0.0792246
0.0792292
0.0792246
0.0705186
0.0792449
0.0792404
0.0705341
0.0787266
0.0787267
0.0792403
0.0787266
0.0787267
0.0792403
0.0792449
0.0792404
0.0705341
0.0792606
0.0792561
0.0705497
0.0787423
0.0787424
0.079256
0.0787423
0.0787424
0.079256
0.0792606
0.0792561
0.0705497
0.0792778
0.0792732
0.0705666
0.0787595
0.0787595
0.0792732
0.0787595
0.0787595
0.0792732
0.0792778
0.0792732
0.0705666
0.095735
0.0957304
0.0870236
0.0952166
0.0952166
0.0957304
0.0952166
0.0952166
0.0957304
0.095735
0.0957304
0.0870236
0.0450699
0.0450654
0.0363585
0.0445518
0.0445519
0.0450654
0.0445518
0.0445519
0.0450654
0.0450699
0.0450654
0.0363585
0.0790431
0.0790386
0.0703315
0.0785248
0.0785248
0.0790385
0.0785248
0.0785248
0.0790385
0.0790431
0.0790386
0.0703315
0.079331
0.0793264
0.0706191
0.0788126
0.0788127
0.0793264
0.0788126
0.0788127
0.0793264
0.079331
0.0793264
0.0706191
0.0793467
0.0793422
0.0706347
0.0788284
0.0788284
0.0793421
0.0788284
0.0788284
0.0793421
0.0793467
0.0793422
0.0706347
0.0793625
0.0793579
0.0706503
0.0788441
0.0788442
0.0793579
0.0788441
0.0788442
0.0793579
0.0793625
0.0793579
0.0706503
0.0793796
0.0793751
0.0706672
0.0788612
0.0788613
0.079375
0.0788612
0.0788613
0.079375
0.0793796
0.0793751
0.0706672
0.0958385
0.0958339
0.0871258
0.0953199
0.09532
0.0958338
0.0953199
0.09532
0.0958338
0.0958385
0.0958339
0.0871258
0.0451685
0.045164
0.0364558
0.0446503
0.0446504
0.045164
0.0446503
0.0446504
0.045164
0.0451685
0.045164
0.0364558
0.079145
0.0791405
0.0704321
0.0786266
0.0786267
0.0791404
0.0786266
0.0786267
0.0791404
0.079145
0.0791405
0.0704321
0.0794329
0.0794284
0.0707198
0.0789145
0.0789145
0.0794283
0.0789145
0.0789145
0.0794283
0.0794329
0.0794284
0.0707198
0.0794487
0.0794442
0.0707354
0.0789302
0.0789303
0.0794441
0.0789302
0.0789303
0.0794441
0.0794487
0.0794442
0.0707354
0.0794645
0.0794599
0.070751
0.078946
0.0789461
0.0794599
0.078946
0.0789461
0.0794599
0.0794645
0.0794599
0.070751
0.0794816
0.0794771
0.070768
0.0789632
0.0789632
0.079477
0.0789632
0.0789632
0.079477
0.0794816
0.0794771
0.070768
0.095942
0.0959375
0.0872281
0.0954235
0.0954235
0.0959374
0.0954235
0.0954235
0.0959374
0.095942
0.0959375
0.0872281
0.0452672
0.0452627
0.0365533
0.044749
0.0447491
0.0452627
0.044749
0.0447491
0.0452627
0.0452672
0.0452627
0.0365533
0.0792471
0.0792425
0.0705329
0.0787286
0.0787286
0.0792425
0.0787286
0.0787286
0.0792425
0.0792471
0.0792425
0.0705329
0.079535
0.0795304
0.0708206
0.0790164
0.0790165
0.0795304
0.0790164
0.0790165
0.0795304
0.079535
0.0795304
0.0708206
0.0795508
0.0795462
0.0708362
0.0790323
0.0790323
0.0795462
0.0790323
0.0790323
0.0795462
0.0795508
0.0795462
0.0708362
0.0795666
0.079562
0.0708518
0.079048
0.0790481
0.079562
0.079048
0.0790481
0.079562
0.0795666
0.079562
0.0708518
0.0795838
0.0795792
0.0708688
0.0790652
0.0790653
0.0795792
0.0790652
0.0790653
0.0795792
0.0795838
0.0795792
0.0708688
0.0960458
0.0960412
0.0873306
0.0955271
0.0955271
0.0960411
0.0955271
0.0955271
0.0960411
0.0960458
0.0960412
0.0873306
0.0453726
0.0453681
0.0366573
0.0448542
0.0448543
0.045368
0.0448542
0.0448543
0.045368
0.0453726
0.0453681
0.0366573
0.0793534
0.0793488
0.0706379
0.0788348
0.0788348
0.0793488
0.0788348
0.0788348
0.0793488
0.0793534
0.0793488
0.0706379
0.0796367
0.0796322
0.0709211
0.0791181
0.0791182
0.0796321
0.0791181
0.0791182
0.0796321
0.0796367
0.0796322
0.0709211
0.0796523
0.0796478
0.0709365
0.0791337
0.0791338
0.0796477
0.0791337
0.0791338
0.0796477
0.0796523
0.0796478
0.0709365
0.0796679
0.0796634
0.0709519
0.0791493
0.0791493
0.0796633
0.0791493
0.0791493
0.0796633
0.0796679
0.0796634
0.0709519
0.0805426
0.0805381
0.0718272
0.080024
0.0800241
0.080538
0.080024
0.0800241
0.080538
0.0805426
0.0805381
0.0718272
0.0171751
0.01776
0.01776
0.0171751
0.0171705
0.0177597
0.0177597
0.0171705
0.0081705
0.0171705
0.0171705
0.0081705
0.0787135
0.0781955
0.0781955
0.0787135
0.078709
0.0781956
0.0781956
0.078709
0.0700058
0.0787089
0.0787089
0.0700058
0.0790087
0.0784906
0.0784906
0.0790087
0.0790042
0.0784907
0.0784907
0.0790042
0.0703009
0.0790041
0.0790041
0.0703009
0.0790247
0.0785066
0.0785066
0.0790247
0.0790202
0.0785066
0.0785066
0.0790202
0.0703167
0.0790201
0.0790201
0.0703167
0.0790406
0.0785225
0.0785225
0.0790406
0.0790361
0.0785226
0.0785226
0.0790361
0.0703324
0.079036
0.079036
0.0703324
0.0790567
0.0785386
0.0785386
0.0790567
0.0790522
0.0785386
0.0785386
0.0790522
0.0703483
0.0790521
0.0790521
0.0703483
0.0790739
0.0785558
0.0785558
0.0790739
0.0790694
0.0785558
0.0785558
0.0790694
0.0703653
0.0790693
0.0790693
0.0703653
0.0950442
0.0945259
0.0945259
0.0950442
0.0950396
0.0945259
0.0945259
0.0950396
0.0863353
0.0950395
0.0950395
0.0863353
0.0453127
0.0447947
0.0447947
0.0453127
0.0453082
0.0447948
0.0447948
0.0453082
0.0366038
0.0453081
0.0453081
0.0366038
0.0788397
0.0783215
0.0783215
0.0788397
0.0788352
0.0783216
0.0783216
0.0788352
0.0701306
0.0788351
0.0788351
0.0701306
0.0791275
0.0786093
0.0786093
0.0791275
0.079123
0.0786094
0.0786094
0.079123
0.0704182
0.0791229
0.0791229
0.0704182
0.0791432
0.078625
0.078625
0.0791432
0.0791387
0.0786251
0.0786251
0.0791387
0.0704337
0.0791386
0.0791386
0.0704337
0.0791589
0.0786407
0.0786407
0.0791589
0.0791544
0.0786408
0.0786408
0.0791544
0.0704492
0.0791543
0.0791543
0.0704492
0.079176
0.0786578
0.0786578
0.079176
0.0791715
0.0786579
0.0786579
0.0791715
0.0704661
0.0791714
0.0791714
0.0704661
0.0956317
0.0951133
0.0951133
0.0956317
0.0956271
0.0951134
0.0951134
0.0956271
0.0869215
0.095627
0.095627
0.0869215
0.0449715
0.0444534
0.0444534
0.0449715
0.044967
0.0444535
0.0444535
0.044967
0.0362613
0.0449669
0.0449669
0.0362613
0.0789413
0.0784231
0.0784231
0.0789413
0.0789368
0.0784231
0.0784231
0.0789368
0.070231
0.0789367
0.0789367
0.070231
0.0792292
0.0787109
0.0787109
0.0792292
0.0792246
0.0787109
0.0787109
0.0792246
0.0705186
0.0792246
0.0792246
0.0705186
0.0792449
0.0787266
0.0787266
0.0792449
0.0792404
0.0787267
0.0787267
0.0792404
0.0705341
0.0792403
0.0792403
0.0705341
0.0792606
0.0787423
0.0787423
0.0792606
0.0792561
0.0787424
0.0787424
0.0792561
0.0705497
0.079256
0.079256
0.0705497
0.0792778
0.0787595
0.0787595
0.0792778
0.0792732
0.0787595
0.0787595
0.0792732
0.0705666
0.0792732
0.0792732
0.0705666
0.095735
0.0952166
0.0952166
0.095735
0.0957304
0.0952166
0.0952166
0.0957304
0.0870236
0.0957304
0.0957304
0.0870236
0.0450699
0.0445518
0.0445518
0.0450699
0.0450654
0.0445519
0.0445519
0.0450654
0.0363585
0.0450654
0.0450654
0.0363585
0.0790431
0.0785248
0.0785248
0.0790431
0.0790386
0.0785248
0.0785248
0.0790386
0.0703315
0.0790385
0.0790385
0.0703315
0.079331
0.0788126
0.0788126
0.079331
0.0793264
0.0788127
0.0788127
0.0793264
0.0706191
0.0793264
0.0793264
0.0706191
0.0793467
0.0788284
0.0788284
0.0793467
0.0793422
0.0788284
0.0788284
0.0793422
0.0706347
0.0793421
0.0793421
0.0706347
0.0793625
0.0788441
0.0788441
0.0793625
0.0793579
0.0788442
0.0788442
0.0793579
0.0706503
0.0793579
0.0793579
0.0706503
0.0793796
0.0788612
0.0788612
0.0793796
0.0793751
0.0788613
0.0788613
0.0793751
0.0706672
0.079375
0.079375
0.0706672
0.0958385
0.0953199
0.0953199
0.0958385
0.0958339
0.09532
0.09532
0.0958339
0.0871258
0.0958338
0.0958338
0.0871258
0.0451685
0.0446503
0.0446503
0.0451685
0.045164
0.0446504
0.0446504
0.045164
0.0364558
0.045164
0.045164
0.0364558
0.079145
0.0786266
0.0786266
0.079145
0.0791405
0.0786267
0.0786267
0.0791405
0.0704321
0.0791404
0.0791404
0.0704321
0.0794329
0.0789145
0.0789145
0.0794329
0.0794284
0.0789145
0.0789145
0.0794284
0.0707198
0.0794283
0.0794283
0.0707198
0.0794487
0.0789302
0.0789302
0.0794487
0.0794442
0.0789303
0.0789303
0.0794442
0.0707354
0.0794441
0.0794441
0.0707354
0.0794645
0.078946
0.078946
0.0794645
0.0794599
0.0789461
0.0789461
0.0794599
0.070751
0.0794599
0.0794599
0.070751
0.0794816
0.0789632
0.0789632
0.0794816
0.0794771
0.0789632
0.0789632
0.0794771
0.070768
0.079477
0.079477
0.070768
0.095942
0.0954235
0.0954235
0.095942
0.0959375
0.0954235
0.0954235
0.0959375
0.0872281
0.0959374
0.0959374
0.0872281
0.0452672
0.044749
0.044749
0.0452672
0.0452627
0.0447491
0.0447491
0.0452627
0.0365533
0.0452627
0.0452627
0.0365533
0.0792471
0.0787286
0.0787286
0.0792471
0.0792425
0.0787286
0.0787286
0.0792425
0.0705329
0.0792425
0.0792425
0.0705329
0.079535
0.0790164
0.0790164
0.079535
0.0795304
0.0790165
0.0790165
0.0795304
0.0708206
0.0795304
0.0795304
0.0708206
0.0795508
0.0790323
0.0790323
0.0795508
0.0795462
0.0790323
0.0790323
0.0795462
0.0708362
0.0795462
0.0795462
0.0708362
0.0795666
0.079048
0.079048
0.0795666
0.079562
0.0790481
0.0790481
0.079562
0.0708518
0.079562
0.079562
0.0708518
0.0795838
0.0790652
0.0790652
0.0795838
0.0795792
0.0790653
0.0790653
0.0795792
0.0708688
0.0795792
0.0795792
0.0708688
0.0960458
0.0955271
0.0955271
0.0960458
0.0960412
0.0955271
0.0955271
0.0960412
0.0873306
0.0960411
0.0960411
0.0873306
0.0453726
0.0448542
0.0448542
0.0453726
0.0453681
0.0448543
0.0448543
0.0453681
0.0366573
0.045368
0.045368
0.0366573
0.0793534
0.0788348
0.0788348
0.0793534
0.0793488
0.0788348
0.0788348
0.0793488
0.0706379
0.0793488
0.0793488
0.0706379
0.0796367
0.0791181
0.0791181
0.0796367
0.0796322
0.0791182
0.0791182
0.0796322
0.0709211
0.0796321
0.0796321
0.0709211
0.0796523
0.0791337
0.0791337
0.0796523
0.0796478
0.0791338
0.0791338
0.0796478
0.0709365
0.0796477
0.0796477
0.0709365
0.0796679
0.0791493
0.0791493
0.0796679
0.0796634
0.0791493
0.0791493
0.0796634
0.0709519
0.0796633
0.0796633
0.0709519
0.0805426
0.080024
0.080024
0.0805426
0.0805381
0.0800241
0.0800241
0.0805381
0.0718272
0.080538
0.080538
0.0718272
Mat Object: 5 MPI processes
type: mpiaij
row 0: (0, -4.66151e-06) (1, 1.764e-08) (4, 1.764e-08) (16, 1.10757e-09)
row 1: (0, 9.78524e-09) (1, -4.6602e-06) (2, 8.16997e-09) (5, 1.60166e-08) (17, 1.10757e-09)
row 2: (1, 8.16997e-09) (2, -4.6602e-06) (3, 9.78524e-09) (6, 1.60166e-08) (18, 1.10757e-09)
row 3: (2, 1.764e-08) (3, -4.66151e-06) (7, 1.764e-08) (19, 1.10757e-09)
row 4: (0, 9.78524e-09) (4, -4.6602e-06) (5, 1.60166e-08) (8, 8.16997e-09) (20, 1.10757e-09)
row 5: (1, 1.01701e-08) (4, 1.01701e-08) (5, -4.65573e-06) (6, 4.57936e-09) (9, 4.57936e-09) (21, 1.10757e-09)
row 6: (2, 1.01701e-08) (5, 4.57936e-09) (6, -4.65573e-06) (7, 1.01701e-08) (10, 4.57936e-09) (22, 1.10757e-09)
row 7: (3, 9.78524e-09) (6, 1.60166e-08) (7, -4.6602e-06) (11, 8.16997e-09) (23, 1.10757e-09)
row 8: (4, 8.16997e-09) (8, -4.65786e-06) (9, 1.60166e-08) (12, 7.44519e-09) (24, 1.10757e-09)
row 9: (5, 4.57936e-09) (8, 1.01701e-08) (9, -4.65381e-06) (10, 4.57936e-09) (13, 8.24565e-09) (25, 1.10757e-09)
row 10: (6, 4.57936e-09) (9, 4.57936e-09) (10, -4.65381e-06) (11, 1.01701e-08) (14, 8.24565e-09) (26, 1.10757e-09)
row 11: (7, 8.16997e-09) (10, 1.60166e-08) (11, -4.65786e-06) (15, 7.44519e-09) (27, 1.10757e-09)
row 12: (8, 4.47386e-09) (12, -4.65551e-06) (13, 1.01629e-08) (28, 1.10757e-09) (786, 4.47386e-09) (790, 1.01629e-08)
row 13: (9, 6.4929e-09) (12, 8.45628e-09) (13, -4.65584e-06) (14, 8.16997e-09) (29, 1.10757e-09) (1519, 6.4929e-09)
row 14: (10, 6.4929e-09) (13, 8.16997e-09) (14, -4.65584e-06) (15, 8.45628e-09) (30, 1.10757e-09) (1520, 6.4929e-09)
row 15: (11, 4.47386e-09) (14, 1.01629e-08) (15, -4.65551e-06) (31, 1.10757e-09) (1521, 1.01629e-08) (1960, 4.47386e-09)
row 16: (0, 5.21484e-10) (16, -4.66127e-06) (17, 1.76401e-08) (20, 1.76401e-08) (32, 3.83508e-10)
row 17: (1, 5.21484e-10) (16, 9.78529e-09) (17, -4.65997e-06) (18, 8.17002e-09) (21, 1.60167e-08) (33, 3.83508e-10)
row 18: (2, 5.21484e-10) (17, 8.17002e-09) (18, -4.65997e-06) (19, 9.78529e-09) (22, 1.60167e-08) (34, 3.83508e-10)
row 19: (3, 5.21484e-10) (18, 1.76401e-08) (19, -4.66127e-06) (23, 1.76401e-08) (35, 3.83508e-10)
row 20: (4, 5.21484e-10) (16, 9.78529e-09) (20, -4.65997e-06) (21, 1.60167e-08) (24, 8.17002e-09) (36, 3.83508e-10)
row 21: (5, 5.21483e-10) (17, 1.01702e-08) (20, 1.01702e-08) (21, -4.65549e-06) (22, 4.57939e-09) (25, 4.57939e-09) (37, 3.83507e-10)
row 22: (6, 5.21483e-10) (18, 1.01702e-08) (21, 4.57939e-09) (22, -4.65549e-06) (23, 1.01702e-08) (26, 4.57939e-09) (38, 3.83507e-10)
row 23: (7, 5.21484e-10) (19, 9.78529e-09) (22, 1.60167e-08) (23, -4.65997e-06) (27, 8.17002e-09) (39, 3.83508e-10)
row 24: (8, 5.21484e-10) (20, 8.17002e-09) (24, -4.65763e-06) (25, 1.60167e-08) (28, 7.44523e-09) (40, 3.83508e-10)
row 25: (9, 5.21483e-10) (21, 4.57939e-09) (24, 1.01702e-08) (25, -4.65357e-06) (26, 4.57939e-09) (29, 8.2457e-09) (41, 3.83507e-10)
row 26: (10, 5.21483e-10) (22, 4.57939e-09) (25, 4.57939e-09) (26, -4.65357e-06) (27, 1.01702e-08) (30, 8.2457e-09) (42, 3.83507e-10)
row 27: (11, 5.21484e-10) (23, 8.17002e-09) (26, 1.60167e-08) (27, -4.65763e-06) (31, 7.44523e-09) (43, 3.83508e-10)
row 28: (12, 5.21484e-10) (24, 4.47389e-09) (28, -4.65527e-06) (29, 1.01629e-08) (44, 3.83508e-10) (801, 4.47389e-09) (805, 1.01629e-08)
row 29: (13, 5.21484e-10) (25, 6.49293e-09) (28, 8.45633e-09) (29, -4.65561e-06) (30, 8.17002e-09) (45, 3.83508e-10) (1528, 6.49293e-09)
row 30: (14, 5.21484e-10) (26, 6.49293e-09) (29, 8.17002e-09) (30, -4.65561e-06) (31, 8.45633e-09) (46, 3.83508e-10) (1529, 6.49293e-09)
row 31: (15, 5.21484e-10) (27, 4.47389e-09) (30, 1.01629e-08) (31, -4.65527e-06) (47, 3.83508e-10) (1530, 1.01629e-08) (1972, 4.47389e-09)
row 32: (16, 3.83511e-10) (32, -4.66109e-06) (33, 1.76402e-08) (36, 1.76402e-08) (48, 3.83511e-10)
row 33: (17, 3.8351e-10) (32, 9.78536e-09) (33, -4.65978e-06) (34, 8.17008e-09) (37, 1.60168e-08) (49, 3.8351e-10)
row 34: (18, 3.8351e-10) (33, 8.17008e-09) (34, -4.65978e-06) (35, 9.78536e-09) (38, 1.60168e-08) (50, 3.8351e-10)
row 35: (19, 3.83511e-10) (34, 1.76402e-08) (35, -4.66109e-06) (39, 1.76402e-08) (51, 3.83511e-10)
row 36: (20, 3.8351e-10) (32, 9.78536e-09) (36, -4.65978e-06) (37, 1.60168e-08) (40, 8.17008e-09) (52, 3.8351e-10)
row 37: (21, 3.8351e-10) (33, 1.01702e-08) (36, 1.01702e-08) (37, -4.65531e-06) (38, 4.57942e-09) (41, 4.57942e-09) (53, 3.8351e-10)
row 38: (22, 3.8351e-10) (34, 1.01702e-08) (37, 4.57942e-09) (38, -4.65531e-06) (39, 1.01702e-08) (42, 4.57942e-09) (54, 3.8351e-10)
row 39: (23, 3.8351e-10) (35, 9.78536e-09) (38, 1.60168e-08) (39, -4.65978e-06) (43, 8.17008e-09) (55, 3.8351e-10)
row 40: (24, 3.8351e-10) (36, 8.17008e-09) (40, -4.65744e-06) (41, 1.60168e-08) (44, 7.44529e-09) (56, 3.8351e-10)
row 41: (25, 3.8351e-10) (37, 4.57942e-09) (40, 1.01702e-08) (41, -4.65338e-06) (42, 4.57942e-09) (45, 8.24576e-09) (57, 3.8351e-10)
row 42: (26, 3.8351e-10) (38, 4.57942e-09) (41, 4.57942e-09) (42, -4.65338e-06) (43, 1.01702e-08) (46, 8.24576e-09) (58, 3.8351e-10)
row 43: (27, 3.8351e-10) (39, 8.17008e-09) (42, 1.60168e-08) (43, -4.65744e-06) (47, 7.44529e-09) (59, 3.8351e-10)
row 44: (28, 3.83511e-10) (40, 4.47392e-09) (44, -4.65508e-06) (45, 1.0163e-08) (60, 3.83511e-10) (816, 4.47392e-09) (820, 1.0163e-08)
row 45: (29, 3.8351e-10) (41, 6.49298e-09) (44, 8.45639e-09) (45, -4.65542e-06) (46, 8.17008e-09) (61, 3.8351e-10) (1537, 6.49298e-09)
row 46: (30, 3.8351e-10) (42, 6.49298e-09) (45, 8.17008e-09) (46, -4.65542e-06) (47, 8.45639e-09) (62, 3.8351e-10) (1538, 6.49298e-09)
row 47: (31, 3.83511e-10) (43, 4.47392e-09) (46, 1.0163e-08) (47, -4.65508e-06) (63, 3.83511e-10) (1539, 1.0163e-08) (1984, 4.47392e-09)
row 48: (32, 3.83514e-10) (48, -4.66104e-06) (49, 1.76404e-08) (52, 1.76404e-08) (64, 3.8349e-10)
row 49: (33, 3.83513e-10) (48, 9.78543e-09) (49, -4.65973e-06) (50, 8.17014e-09) (53, 1.60169e-08) (65, 3.8349e-10)
row 50: (34, 3.83513e-10) (49, 8.17014e-09) (50, -4.65973e-06) (51, 9.78543e-09) (54, 1.60169e-08) (66, 3.8349e-10)
row 51: (35, 3.83514e-10) (50, 1.76404e-08) (51, -4.66104e-06) (55, 1.76404e-08) (67, 3.8349e-10)
row 52: (36, 3.83513e-10) (48, 9.78543e-09) (52, -4.65973e-06) (53, 1.60169e-08) (56, 8.17014e-09) (68, 3.8349e-10)
row 53: (37, 3.83512e-10) (49, 1.01703e-08) (52, 1.01703e-08) (53, -4.65526e-06) (54, 4.57946e-09) (57, 4.57946e-09) (69, 3.83489e-10)
row 54: (38, 3.83512e-10) (50, 1.01703e-08) (53, 4.57946e-09) (54, -4.65526e-06) (55, 1.01703e-08) (58, 4.57946e-09) (70, 3.83489e-10)
row 55: (39, 3.83513e-10) (51, 9.78543e-09) (54, 1.60169e-08) (55, -4.65973e-06) (59, 8.17014e-09) (71, 3.8349e-10)
row 56: (40, 3.83513e-10) (52, 8.17014e-09) (56, -4.65739e-06) (57, 1.60169e-08) (60, 7.44534e-09) (72, 3.8349e-10)
row 57: (41, 3.83512e-10) (53, 4.57946e-09) (56, 1.01703e-08) (57, -4.65333e-06) (58, 4.57946e-09) (61, 8.24582e-09) (73, 3.83489e-10)
row 58: (42, 3.83512e-10) (54, 4.57946e-09) (57, 4.57946e-09) (58, -4.65333e-06) (59, 1.01703e-08) (62, 8.24582e-09) (74, 3.83489e-10)
row 59: (43, 3.83513e-10) (55, 8.17014e-09) (58, 1.60169e-08) (59, -4.65739e-06) (63, 7.44534e-09) (75, 3.8349e-10)
row 60: (44, 3.83514e-10) (56, 4.47395e-09) (60, -4.65503e-06) (61, 1.01631e-08) (76, 3.8349e-10) (831, 4.47395e-09) (835, 1.01631e-08)
row 61: (45, 3.83513e-10) (57, 6.49303e-09) (60, 8.45645e-09) (61, -4.65537e-06) (62, 8.17014e-09) (77, 3.8349e-10) (1546, 6.49303e-09)
row 62: (46, 3.83513e-10) (58, 6.49303e-09) (61, 8.17014e-09) (62, -4.65537e-06) (63, 8.45645e-09) (78, 3.8349e-10) (1547, 6.49303e-09)
row 63: (47, 3.83514e-10) (59, 4.47395e-09) (62, 1.01631e-08) (63, -4.65503e-06) (79, 3.8349e-10) (1548, 1.01631e-08) (1996, 4.47395e-09)
row 64: (48, 3.83446e-10) (64, -4.66099e-06) (65, 1.76405e-08) (68, 1.76405e-08) (80, 3.83446e-10)
row 65: (49, 3.83446e-10) (64, 9.78551e-09) (65, -4.65968e-06) (66, 8.1702e-09) (69, 1.6017e-08) (81, 3.83446e-10)
row 66: (50, 3.83446e-10) (65, 8.1702e-09) (66, -4.65968e-06) (67, 9.78551e-09) (70, 1.6017e-08) (82, 3.83446e-10)
row 67: (51, 3.83446e-10) (66, 1.76405e-08) (67, -4.66099e-06) (71, 1.76405e-08) (83, 3.83446e-10)
row 68: (52, 3.83446e-10) (64, 9.78551e-09) (68, -4.65968e-06) (69, 1.6017e-08) (72, 8.1702e-09) (84, 3.83446e-10)
row 69: (53, 3.83445e-10) (65, 1.01704e-08) (68, 1.01704e-08) (69, -4.65521e-06) (70, 4.57949e-09) (73, 4.57949e-09) (85, 3.83445e-10)
row 70: (54, 3.83445e-10) (66, 1.01704e-08) (69, 4.57949e-09) (70, -4.65521e-06) (71, 1.01704e-08) (74, 4.57949e-09) (86, 3.83445e-10)
row 71: (55, 3.83446e-10) (67, 9.78551e-09) (70, 1.6017e-08) (71, -4.65968e-06) (75, 8.1702e-09) (87, 3.83446e-10)
row 72: (56, 3.83446e-10) (68, 8.1702e-09) (72, -4.65734e-06) (73, 1.6017e-08) (76, 7.4454e-09) (88, 3.83446e-10)
row 73: (57, 3.83445e-10) (69, 4.57949e-09) (72, 1.01704e-08) (73, -4.65328e-06) (74, 4.57949e-09) (77, 8.24588e-09) (89, 3.83445e-10)
row 74: (58, 3.83445e-10) (70, 4.57949e-09) (73, 4.57949e-09) (74, -4.65328e-06) (75, 1.01704e-08) (78, 8.24588e-09) (90, 3.83445e-10)
row 75: (59, 3.83446e-10) (71, 8.1702e-09) (74, 1.6017e-08) (75, -4.65734e-06) (79, 7.4454e-09) (91, 3.83446e-10)
row 76: (60, 3.83446e-10) (72, 4.47398e-09) (76, -4.65498e-06) (77, 1.01631e-08) (92, 3.83446e-10) (846, 4.47398e-09) (850, 1.01631e-08)
row 77: (61, 3.83446e-10) (73, 6.49308e-09) (76, 8.45651e-09) (77, -4.65532e-06) (78, 8.1702e-09) (93, 3.83446e-10) (1555, 6.49308e-09)
row 78: (62, 3.83446e-10) (74, 6.49308e-09) (77, 8.1702e-09) (78, -4.65532e-06) (79, 8.45651e-09) (94, 3.83446e-10) (1556, 6.49308e-09)
row 79: (63, 3.83446e-10) (75, 4.47398e-09) (78, 1.01631e-08) (79, -4.65498e-06) (95, 3.83446e-10) (1557, 1.01631e-08) (2008, 4.47398e-09)
row 80: (64, 3.83496e-10) (80, -4.66094e-06) (81, 1.76406e-08) (84, 1.76406e-08) (96, 3.83519e-10)
row 81: (65, 3.83496e-10) (80, 9.78558e-09) (81, -4.65963e-06) (82, 8.17026e-09) (85, 1.60171e-08) (97, 3.83519e-10)
row 82: (66, 3.83496e-10) (81, 8.17026e-09) (82, -4.65963e-06) (83, 9.78558e-09) (86, 1.60171e-08) (98, 3.83519e-10)
row 83: (67, 3.83496e-10) (82, 1.76406e-08) (83, -4.66094e-06) (87, 1.76406e-08) (99, 3.83519e-10)
row 84: (68, 3.83496e-10) (80, 9.78558e-09) (84, -4.65963e-06) (85, 1.60171e-08) (88, 8.17026e-09) (100, 3.83519e-10)
row 85: (69, 3.83495e-10) (81, 1.01705e-08) (84, 1.01705e-08) (85, -4.65516e-06) (86, 4.57952e-09) (89, 4.57952e-09) (101, 3.83518e-10)
row 86: (70, 3.83495e-10) (82, 1.01705e-08) (85, 4.57952e-09) (86, -4.65516e-06) (87, 1.01705e-08) (90, 4.57952e-09) (102, 3.83518e-10)
row 87: (71, 3.83496e-10) (83, 9.78558e-09) (86, 1.60171e-08) (87, -4.65963e-06) (91, 8.17026e-09) (103, 3.83519e-10)
row 88: (72, 3.83496e-10) (84, 8.17026e-09) (88, -4.65729e-06) (89, 1.60171e-08) (92, 7.44545e-09) (104, 3.83519e-10)
row 89: (73, 3.83495e-10) (85, 4.57952e-09) (88, 1.01705e-08) (89, -4.65324e-06) (90, 4.57952e-09) (93, 8.24594e-09) (105, 3.83518e-10)
row 90: (74, 3.83495e-10) (86, 4.57952e-09) (89, 4.57952e-09) (90, -4.65324e-06) (91, 1.01705e-08) (94, 8.24594e-09) (106, 3.83518e-10)
row 91: (75, 3.83496e-10) (87, 8.17026e-09) (90, 1.60171e-08) (91, -4.65729e-06) (95, 7.44545e-09) (107, 3.83519e-10)
row 92: (76, 3.83496e-10) (88, 4.47402e-09) (92, -4.65493e-06) (93, 1.01632e-08) (108, 3.83519e-10) (861, 4.47402e-09) (865, 1.01632e-08)
row 93: (77, 3.83496e-10) (89, 6.49312e-09) (92, 8.45658e-09) (93, -4.65527e-06) (94, 8.17026e-09) (109, 3.83519e-10) (1564, 6.49312e-09)
row 94: (78, 3.83496e-10) (90, 6.49312e-09) (93, 8.17026e-09) (94, -4.65527e-06) (95, 8.45658e-09) (110, 3.83519e-10) (1565, 6.49312e-09)
row 95: (79, 3.83496e-10) (91, 4.47402e-09) (94, 1.01632e-08) (95, -4.65493e-06) (111, 3.83519e-10) (1566, 1.01632e-08) (2020, 4.47402e-09)
row 96: (80, 3.83522e-10) (96, -4.66089e-06) (97, 1.76408e-08) (100, 1.76408e-08) (112, 3.83522e-10)
row 97: (81, 3.83522e-10) (96, 9.78565e-09) (97, -4.65958e-06) (98, 8.17032e-09) (101, 1.60172e-08) (113, 3.83522e-10)
row 98: (82, 3.83522e-10) (97, 8.17032e-09) (98, -4.65958e-06) (99, 9.78565e-09) (102, 1.60172e-08) (114, 3.83522e-10)
row 99: (83, 3.83522e-10) (98, 1.76408e-08) (99, -4.66089e-06) (103, 1.76408e-08) (115, 3.83522e-10)
row 100: (84, 3.83522e-10) (96, 9.78565e-09) (100, -4.65958e-06) (101, 1.60172e-08) (104, 8.17032e-09) (116, 3.83522e-10)
row 101: (85, 3.83521e-10) (97, 1.01705e-08) (100, 1.01705e-08) (101, -4.65511e-06) (102, 4.57956e-09) (105, 4.57956e-09) (117, 3.83521e-10)
row 102: (86, 3.83521e-10) (98, 1.01705e-08) (101, 4.57956e-09) (102, -4.65511e-06) (103, 1.01705e-08) (106, 4.57956e-09) (118, 3.83521e-10)
row 103: (87, 3.83522e-10) (99, 9.78565e-09) (102, 1.60172e-08) (103, -4.65958e-06) (107, 8.17032e-09) (119, 3.83522e-10)
row 104: (88, 3.83522e-10) (100, 8.17032e-09) (104, -4.65724e-06) (105, 1.60172e-08) (108, 7.44551e-09) (120, 3.83522e-10)
row 105: (89, 3.83521e-10) (101, 4.57956e-09) (104, 1.01705e-08) (105, -4.65319e-06) (106, 4.57956e-09) (109, 8.246e-09) (121, 3.83521e-10)
row 106: (90, 3.83521e-10) (102, 4.57956e-09) (105, 4.57956e-09) (106, -4.65319e-06) (107, 1.01705e-08) (110, 8.246e-09) (122, 3.83521e-10)
row 107: (91, 3.83522e-10) (103, 8.17032e-09) (106, 1.60172e-08) (107, -4.65724e-06) (111, 7.44551e-09) (123, 3.83522e-10)
row 108: (92, 3.83522e-10) (104, 4.47405e-09) (108, -4.65489e-06) (109, 1.01633e-08) (124, 3.83522e-10) (876, 4.47405e-09) (880, 1.01633e-08)
row 109: (93, 3.83522e-10) (105, 6.49317e-09) (108, 8.45664e-09) (109, -4.65522e-06) (110, 8.17032e-09) (125, 3.83522e-10) (1573, 6.49317e-09)
row 110: (94, 3.83522e-10) (106, 6.49317e-09) (109, 8.17032e-09) (110, -4.65522e-06) (111, 8.45664e-09) (126, 3.83522e-10) (1574, 6.49317e-09)
row 111: (95, 3.83522e-10) (107, 4.47405e-09) (110, 1.01633e-08) (111, -4.65489e-06) (127, 3.83522e-10) (1575, 1.01633e-08) (2032, 4.47405e-09)
row 112: (96, 3.83525e-10) (112, -4.66098e-06) (113, 1.76409e-08) (116, 1.76409e-08) (128, 5.23901e-10)
row 113: (97, 3.83525e-10) (112, 9.78572e-09) (113, -4.65968e-06) (114, 8.17038e-09) (117, 1.60174e-08) (129, 5.23901e-10)
row 114: (98, 3.83525e-10) (113, 8.17038e-09) (114, -4.65968e-06) (115, 9.78572e-09) (118, 1.60174e-08) (130, 5.23901e-10)
row 115: (99, 3.83525e-10) (114, 1.76409e-08) (115, -4.66098e-06) (119, 1.76409e-08) (131, 5.23901e-10)
row 116: (100, 3.83525e-10) (112, 9.78572e-09) (116, -4.65968e-06) (117, 1.60174e-08) (120, 8.17038e-09) (132, 5.23901e-10)
row 117: (101, 3.83524e-10) (113, 1.01706e-08) (116, 1.01706e-08) (117, -4.6552e-06) (118, 4.57959e-09) (121, 4.57959e-09) (133, 5.239e-10)
row 118: (102, 3.83524e-10) (114, 1.01706e-08) (117, 4.57959e-09) (118, -4.6552e-06) (119, 1.01706e-08) (122, 4.57959e-09) (134, 5.239e-10)
row 119: (103, 3.83525e-10) (115, 9.78572e-09) (118, 1.60174e-08) (119, -4.65968e-06) (123, 8.17038e-09) (135, 5.23901e-10)
row 120: (104, 3.83525e-10) (116, 8.17038e-09) (120, -4.65734e-06) (121, 1.60174e-08) (124, 7.44556e-09) (136, 5.23901e-10)
row 121: (105, 3.83524e-10) (117, 4.57959e-09) (120, 1.01706e-08) (121, -4.65328e-06) (122, 4.57959e-09) (125, 8.24606e-09) (137, 5.239e-10)
row 122: (106, 3.83524e-10) (118, 4.57959e-09) (121, 4.57959e-09) (122, -4.65328e-06) (123, 1.01706e-08) (126, 8.24606e-09) (138, 5.239e-10)
row 123: (107, 3.83525e-10) (119, 8.17038e-09) (122, 1.60174e-08) (123, -4.65734e-06) (127, 7.44556e-09) (139, 5.23901e-10)
row 124: (108, 3.83525e-10) (120, 4.47408e-09) (124, -4.65498e-06) (125, 1.01634e-08) (140, 5.23901e-10) (891, 4.47408e-09) (895, 1.01634e-08)
row 125: (109, 3.83525e-10) (121, 6.49322e-09) (124, 8.4567e-09) (125, -4.65532e-06) (126, 8.17038e-09) (141, 5.23901e-10) (1582, 6.49322e-09)
row 126: (110, 3.83525e-10) (122, 6.49322e-09) (125, 8.17038e-09) (126, -4.65532e-06) (127, 8.4567e-09) (142, 5.23901e-10) (1583, 6.49322e-09)
row 127: (111, 3.83525e-10) (123, 4.47408e-09) (126, 1.01634e-08) (127, -4.65498e-06) (143, 5.23901e-10) (1584, 1.01634e-08) (2044, 4.47408e-09)
row 128: (112, 1.12908e-09) (128, -4.66231e-06) (129, 1.7641e-08) (132, 1.7641e-08) (144, 1.14303e-09)
row 129: (113, 1.12907e-09) (128, 9.78578e-09) (129, -4.66101e-06) (130, 8.17042e-09) (133, 1.60174e-08) (145, 1.14303e-09)
row 130: (114, 1.12907e-09) (129, 8.17042e-09) (130, -4.66101e-06) (131, 9.78578e-09) (134, 1.60174e-08) (146, 1.14303e-09)
row 131: (115, 1.12908e-09) (130, 1.7641e-08) (131, -4.66231e-06) (135, 1.7641e-08) (147, 1.14303e-09)
row 132: (116, 1.12907e-09) (128, 9.78578e-09) (132, -4.66101e-06) (133, 1.60174e-08) (136, 8.17042e-09) (148, 1.14303e-09)
row 133: (117, 1.12907e-09) (129, 1.01707e-08) (132, 1.01707e-08) (133, -4.65653e-06) (134, 4.57962e-09) (137, 4.57962e-09) (149, 1.14303e-09)
row 134: (118, 1.12907e-09) (130, 1.01707e-08) (133, 4.57962e-09) (134, -4.65653e-06) (135, 1.01707e-08) (138, 4.57962e-09) (150, 1.14303e-09)
row 135: (119, 1.12907e-09) (131, 9.78578e-09) (134, 1.60174e-08) (135, -4.66101e-06) (139, 8.17042e-09) (151, 1.14303e-09)
row 136: (120, 1.12907e-09) (132, 8.17042e-09) (136, -4.65867e-06) (137, 1.60174e-08) (140, 7.4456e-09) (152, 1.14303e-09)
row 137: (121, 1.12907e-09) (133, 4.57962e-09) (136, 1.01707e-08) (137, -4.65461e-06) (138, 4.57962e-09) (141, 8.2461e-09) (153, 1.14303e-09)
row 138: (122, 1.12907e-09) (134, 4.57962e-09) (137, 4.57962e-09) (138, -4.65461e-06) (139, 1.01707e-08) (142, 8.2461e-09) (154, 1.14303e-09)
row 139: (123, 1.12907e-09) (135, 8.17042e-09) (138, 1.60174e-08) (139, -4.65867e-06) (143, 7.4456e-09) (155, 1.14303e-09)
row 140: (124, 1.12908e-09) (136, 4.47411e-09) (140, -4.65631e-06) (141, 1.01634e-08) (156, 1.14303e-09) (906, 4.47411e-09) (910, 1.01634e-08)
row 141: (125, 1.12907e-09) (137, 6.49325e-09) (140, 8.45675e-09) (141, -4.65665e-06) (142, 8.17042e-09) (157, 1.14303e-09) (1591, 6.49325e-09)
row 142: (126, 1.12907e-09) (138, 6.49325e-09) (141, 8.17042e-09) (142, -4.65665e-06) (143, 8.45675e-09) (158, 1.14303e-09) (1592, 6.49325e-09)
row 143: (127, 1.12908e-09) (139, 4.47411e-09) (142, 1.01634e-08) (143, -4.65631e-06) (159, 1.14303e-09) (1593, 1.01634e-08) (2056, 4.47411e-09)
row 144: (128, 5.39986e-10) (144, -4.66094e-06) (145, 1.76411e-08) (148, 1.76411e-08) (160, 3.97541e-10)
row 145: (129, 5.39985e-10) (144, 9.78583e-09) (145, -4.65964e-06) (146, 8.17047e-09) (149, 1.60175e-08) (161, 3.9754e-10)
row 146: (130, 5.39985e-10) (145, 8.17047e-09) (146, -4.65964e-06) (147, 9.78583e-09) (150, 1.60175e-08) (162, 3.9754e-10)
row 147: (131, 5.39986e-10) (146, 1.76411e-08) (147, -4.66094e-06) (151, 1.76411e-08) (163, 3.97541e-10)
row 148: (132, 5.39985e-10) (144, 9.78583e-09) (148, -4.65964e-06) (149, 1.60175e-08) (152, 8.17047e-09) (164, 3.9754e-10)
row 149: (133, 5.39984e-10) (145, 1.01707e-08) (148, 1.01707e-08) (149, -4.65516e-06) (150, 4.57964e-09) (153, 4.57964e-09) (165, 3.9754e-10)
row 150: (134, 5.39984e-10) (146, 1.01707e-08) (149, 4.57964e-09) (150, -4.65516e-06) (151, 1.01707e-08) (154, 4.57964e-09) (166, 3.9754e-10)
row 151: (135, 5.39985e-10) (147, 9.78583e-09) (150, 1.60175e-08) (151, -4.65964e-06) (155, 8.17047e-09) (167, 3.9754e-10)
row 152: (136, 5.39985e-10) (148, 8.17047e-09) (152, -4.6573e-06) (153, 1.60175e-08) (156, 7.44564e-09) (168, 3.9754e-10)
row 153: (137, 5.39984e-10) (149, 4.57964e-09) (152, 1.01707e-08) (153, -4.65324e-06) (154, 4.57964e-09) (157, 8.24615e-09) (169, 3.9754e-10)
row 154: (138, 5.39984e-10) (150, 4.57964e-09) (153, 4.57964e-09) (154, -4.65324e-06) (155, 1.01707e-08) (158, 8.24615e-09) (170, 3.9754e-10)
row 155: (139, 5.39985e-10) (151, 8.17047e-09) (154, 1.60175e-08) (155, -4.6573e-06) (159, 7.44564e-09) (171, 3.9754e-10)
row 156: (140, 5.39986e-10) (152, 4.47413e-09) (156, -4.65494e-06) (157, 1.01635e-08) (172, 3.97541e-10) (921, 4.47413e-09) (925, 1.01635e-08)
row 157: (141, 5.39985e-10) (153, 6.49329e-09) (156, 8.45679e-09) (157, -4.65528e-06) (158, 8.17047e-09) (173, 3.9754e-10) (1600, 6.49329e-09)
row 158: (142, 5.39985e-10) (154, 6.49329e-09) (157, 8.17047e-09) (158, -4.65528e-06) (159, 8.45679e-09) (174, 3.9754e-10) (1601, 6.49329e-09)
row 159: (143, 5.39986e-10) (155, 4.47413e-09) (158, 1.01635e-08) (159, -4.65494e-06) (175, 3.97541e-10) (1602, 1.01635e-08) (2068, 4.47413e-09)
row 160: (144, 3.97544e-10) (160, -4.66075e-06) (161, 1.76412e-08) (164, 1.76412e-08) (176, 3.97544e-10)
row 161: (145, 3.97543e-10) (160, 9.7859e-09) (161, -4.65945e-06) (162, 8.17053e-09) (165, 1.60177e-08) (177, 3.97543e-10)
row 162: (146, 3.97543e-10) (161, 8.17053e-09) (162, -4.65945e-06) (163, 9.7859e-09) (166, 1.60177e-08) (178, 3.97543e-10)
row 163: (147, 3.97544e-10) (162, 1.76412e-08) (163, -4.66075e-06) (167, 1.76412e-08) (179, 3.97544e-10)
row 164: (148, 3.97543e-10) (160, 9.7859e-09) (164, -4.65945e-06) (165, 1.60177e-08) (168, 8.17053e-09) (180, 3.97543e-10)
row 165: (149, 3.97542e-10) (161, 1.01708e-08) (164, 1.01708e-08) (165, -4.65497e-06) (166, 4.57967e-09) (169, 4.57967e-09) (181, 3.97542e-10)
row 166: (150, 3.97542e-10) (162, 1.01708e-08) (165, 4.57967e-09) (166, -4.65497e-06) (167, 1.01708e-08) (170, 4.57967e-09) (182, 3.97542e-10)
row 167: (151, 3.97543e-10) (163, 9.7859e-09) (166, 1.60177e-08) (167, -4.65945e-06) (171, 8.17053e-09) (183, 3.97543e-10)
row 168: (152, 3.97543e-10) (164, 8.17053e-09) (168, -4.65711e-06) (169, 1.60177e-08) (172, 7.44569e-09) (184, 3.97543e-10)
row 169: (153, 3.97542e-10) (165, 4.57967e-09) (168, 1.01708e-08) (169, -4.65305e-06) (170, 4.57967e-09) (173, 8.24621e-09) (185, 3.97542e-10)
row 170: (154, 3.97542e-10) (166, 4.57967e-09) (169, 4.57967e-09) (170, -4.65305e-06) (171, 1.01708e-08) (174, 8.24621e-09) (186, 3.97542e-10)
row 171: (155, 3.97543e-10) (167, 8.17053e-09) (170, 1.60177e-08) (171, -4.65711e-06) (175, 7.44569e-09) (187, 3.97543e-10)
row 172: (156, 3.97544e-10) (168, 4.47416e-09) (172, -4.65475e-06) (173, 1.01635e-08) (188, 3.97544e-10) (936, 4.47416e-09) (940, 1.01635e-08)
row 173: (157, 3.97543e-10) (169, 6.49334e-09) (172, 8.45685e-09) (173, -4.65509e-06) (174, 8.17053e-09) (189, 3.97543e-10) (1609, 6.49334e-09)
row 174: (158, 3.97543e-10) (170, 6.49334e-09) (173, 8.17053e-09) (174, -4.65509e-06) (175, 8.45685e-09) (190, 3.97543e-10) (1610, 6.49334e-09)
row 175: (159, 3.97544e-10) (171, 4.47416e-09) (174, 1.01635e-08) (175, -4.65475e-06) (191, 3.97544e-10) (1611, 1.01635e-08) (2080, 4.47416e-09)
row 176: (160, 3.97546e-10) (176, -4.66071e-06) (177, 1.76413e-08) (180, 1.76413e-08) (192, 3.97546e-10)
row 177: (161, 3.97546e-10) (176, 9.78597e-09) (177, -4.6594e-06) (178, 8.17059e-09) (181, 1.60178e-08) (193, 3.97546e-10)
row 178: (162, 3.97546e-10) (177, 8.17059e-09) (178, -4.6594e-06) (179, 9.78597e-09) (182, 1.60178e-08) (194, 3.97546e-10)
row 179: (163, 3.97546e-10) (178, 1.76413e-08) (179, -4.66071e-06) (183, 1.76413e-08) (195, 3.97546e-10)
row 180: (164, 3.97546e-10) (176, 9.78597e-09) (180, -4.6594e-06) (181, 1.60178e-08) (184, 8.17059e-09) (196, 3.97546e-10)
row 181: (165, 3.97545e-10) (177, 1.01709e-08) (180, 1.01709e-08) (181, -4.65492e-06) (182, 4.57971e-09) (185, 4.57971e-09) (197, 3.97545e-10)
row 182: (166, 3.97545e-10) (178, 1.01709e-08) (181, 4.57971e-09) (182, -4.65492e-06) (183, 1.01709e-08) (186, 4.57971e-09) (198, 3.97545e-10)
row 183: (167, 3.97546e-10) (179, 9.78597e-09) (182, 1.60178e-08) (183, -4.6594e-06) (187, 8.17059e-09) (199, 3.97546e-10)
row 184: (168, 3.97546e-10) (180, 8.17059e-09) (184, -4.65706e-06) (185, 1.60178e-08) (188, 7.44575e-09) (200, 3.97546e-10)
row 185: (169, 3.97545e-10) (181, 4.57971e-09) (184, 1.01709e-08) (185, -4.653e-06) (186, 4.57971e-09) (189, 8.24627e-09) (201, 3.97545e-10)
row 186: (170, 3.97545e-10) (182, 4.57971e-09) (185, 4.57971e-09) (186, -4.653e-06) (187, 1.01709e-08) (190, 8.24627e-09) (202, 3.97545e-10)
row 187: (171, 3.97546e-10) (183, 8.17059e-09) (186, 1.60178e-08) (187, -4.65706e-06) (191, 7.44575e-09) (203, 3.97546e-10)
row 188: (172, 3.97546e-10) (184, 4.4742e-09) (188, -4.6547e-06) (189, 1.01636e-08) (204, 3.97546e-10) (951, 4.4742e-09) (955, 1.01636e-08)
row 189: (173, 3.97546e-10) (185, 6.49338e-09) (188, 8.45691e-09) (189, -4.65504e-06) (190, 8.17059e-09) (205, 3.97546e-10) (1618, 6.49338e-09)
row 190: (174, 3.97546e-10) (186, 6.49338e-09) (189, 8.17059e-09) (190, -4.65504e-06) (191, 8.45691e-09) (206, 3.97546e-10) (1619, 6.49338e-09)
row 191: (175, 3.97546e-10) (187, 4.4742e-09) (190, 1.01636e-08) (191, -4.6547e-06) (207, 3.97546e-10) (1620, 1.01636e-08) (2092, 4.4742e-09)
row 192: (176, 3.97549e-10) (192, -4.66066e-06) (193, 1.76415e-08) (196, 1.76415e-08) (208, 3.97549e-10)
row 193: (177, 3.97549e-10) (192, 9.78604e-09) (193, -4.65935e-06) (194, 8.17065e-09) (197, 1.60179e-08) (209, 3.97549e-10)
row 194: (178, 3.97549e-10) (193, 8.17065e-09) (194, -4.65935e-06) (195, 9.78604e-09) (198, 1.60179e-08) (210, 3.97549e-10)
row 195: (179, 3.97549e-10) (194, 1.76415e-08) (195, -4.66066e-06) (199, 1.76415e-08) (211, 3.97549e-10)
row 196: (180, 3.97549e-10) (192, 9.78604e-09) (196, -4.65935e-06) (197, 1.60179e-08) (200, 8.17065e-09) (212, 3.97549e-10)
row 197: (181, 3.97548e-10) (193, 1.0171e-08) (196, 1.0171e-08) (197, -4.65488e-06) (198, 4.57974e-09) (201, 4.57974e-09) (213, 3.97548e-10)
row 198: (182, 3.97548e-10) (194, 1.0171e-08) (197, 4.57974e-09) (198, -4.65488e-06) (199, 1.0171e-08) (202, 4.57974e-09) (214, 3.97548e-10)
row 199: (183, 3.97549e-10) (195, 9.78604e-09) (198, 1.60179e-08) (199, -4.65935e-06) (203, 8.17065e-09) (215, 3.97549e-10)
row 200: (184, 3.97549e-10) (196, 8.17065e-09) (200, -4.65701e-06) (201, 1.60179e-08) (204, 7.4458e-09) (216, 3.97549e-10)
row 201: (185, 3.97548e-10) (197, 4.57974e-09) (200, 1.0171e-08) (201, -4.65295e-06) (202, 4.57974e-09) (205, 8.24633e-09) (217, 3.97548e-10)
row 202: (186, 3.97548e-10) (198, 4.57974e-09) (201, 4.57974e-09) (202, -4.65295e-06) (203, 1.0171e-08) (206, 8.24633e-09) (218, 3.97548e-10)
row 203: (187, 3.97549e-10) (199, 8.17065e-09) (202, 1.60179e-08) (203, -4.65701e-06) (207, 7.4458e-09) (219, 3.97549e-10)
row 204: (188, 3.97549e-10) (200, 4.47423e-09) (204, -4.65465e-06) (205, 1.01637e-08) (220, 3.97549e-10) (966, 4.47423e-09) (970, 1.01637e-08)
row 205: (189, 3.97549e-10) (201, 6.49343e-09) (204, 8.45697e-09) (205, -4.65499e-06) (206, 8.17065e-09) (221, 3.97549e-10) (1627, 6.49343e-09)
row 206: (190, 3.97549e-10) (202, 6.49343e-09) (205, 8.17065e-09) (206, -4.65499e-06) (207, 8.45697e-09) (222, 3.97549e-10) (1628, 6.49343e-09)
row 207: (191, 3.97549e-10) (203, 4.47423e-09) (206, 1.01637e-08) (207, -4.65465e-06) (223, 3.97549e-10) (1629, 1.01637e-08) (2104, 4.47423e-09)
row 208: (192, 3.97552e-10) (208, -4.66061e-06) (209, 1.76416e-08) (212, 1.76416e-08) (224, 3.97552e-10)
row 209: (193, 3.97552e-10) (208, 9.78611e-09) (209, -4.6593e-06) (210, 8.17071e-09) (213, 1.6018e-08) (225, 3.97552e-10)
row 210: (194, 3.97552e-10) (209, 8.17071e-09) (210, -4.6593e-06) (211, 9.78611e-09) (214, 1.6018e-08) (226, 3.97552e-10)
row 211: (195, 3.97552e-10) (210, 1.76416e-08) (211, -4.66061e-06) (215, 1.76416e-08) (227, 3.97552e-10)
row 212: (196, 3.97552e-10) (208, 9.78611e-09) (212, -4.6593e-06) (213, 1.6018e-08) (216, 8.17071e-09) (228, 3.97552e-10)
row 213: (197, 3.97551e-10) (209, 1.0171e-08) (212, 1.0171e-08) (213, -4.65483e-06) (214, 4.57977e-09) (217, 4.57977e-09) (229, 3.97551e-10)
row 214: (198, 3.97551e-10) (210, 1.0171e-08) (213, 4.57977e-09) (214, -4.65483e-06) (215, 1.0171e-08) (218, 4.57977e-09) (230, 3.97551e-10)
row 215: (199, 3.97552e-10) (211, 9.78611e-09) (214, 1.6018e-08) (215, -4.6593e-06) (219, 8.17071e-09) (231, 3.97552e-10)
row 216: (200, 3.97552e-10) (212, 8.17071e-09) (216, -4.65696e-06) (217, 1.6018e-08) (220, 7.44586e-09) (232, 3.97552e-10)
row 217: (201, 3.97551e-10) (213, 4.57977e-09) (216, 1.0171e-08) (217, -4.6529e-06) (218, 4.57977e-09) (221, 8.24639e-09) (233, 3.97551e-10)
row 218: (202, 3.97551e-10) (214, 4.57977e-09) (217, 4.57977e-09) (218, -4.6529e-06) (219, 1.0171e-08) (222, 8.24639e-09) (234, 3.97551e-10)
row 219: (203, 3.97552e-10) (215, 8.17071e-09) (218, 1.6018e-08) (219, -4.65696e-06) (223, 7.44586e-09) (235, 3.97552e-10)
row 220: (204, 3.97552e-10) (216, 4.47426e-09) (220, -4.6546e-06) (221, 1.01638e-08) (236, 3.97552e-10) (981, 4.47426e-09) (985, 1.01638e-08)
row 221: (205, 3.97552e-10) (217, 6.49348e-09) (220, 8.45704e-09) (221, -4.65494e-06) (222, 8.17071e-09) (237, 3.97552e-10) (1636, 6.49348e-09)
row 222: (206, 3.97552e-10) (218, 6.49348e-09) (221, 8.17071e-09) (222, -4.65494e-06) (223, 8.45704e-09) (238, 3.97552e-10) (1637, 6.49348e-09)
row 223: (207, 3.97552e-10) (219, 4.47426e-09) (222, 1.01638e-08) (223, -4.6546e-06) (239, 3.97552e-10) (1638, 1.01638e-08) (2116, 4.47426e-09)
row 224: (208, 3.97555e-10) (224, -4.66071e-06) (225, 1.76417e-08) (228, 1.76417e-08) (240, 5.39968e-10)
row 225: (209, 3.97555e-10) (224, 9.78618e-09) (225, -4.6594e-06) (226, 8.17076e-09) (229, 1.60181e-08) (241, 5.39968e-10)
row 226: (210, 3.97555e-10) (225, 8.17076e-09) (226, -4.6594e-06) (227, 9.78618e-09) (230, 1.60181e-08) (242, 5.39968e-10)
row 227: (211, 3.97555e-10) (226, 1.76417e-08) (227, -4.66071e-06) (231, 1.76417e-08) (243, 5.39968e-10)
row 228: (212, 3.97555e-10) (224, 9.78618e-09) (228, -4.6594e-06) (229, 1.60181e-08) (232, 8.17076e-09) (244, 5.39968e-10)
row 229: (213, 3.97554e-10) (225, 1.01711e-08) (228, 1.01711e-08) (229, -4.65492e-06) (230, 4.57981e-09) (233, 4.57981e-09) (245, 5.39967e-10)
row 230: (214, 3.97554e-10) (226, 1.01711e-08) (229, 4.57981e-09) (230, -4.65492e-06) (231, 1.01711e-08) (234, 4.57981e-09) (246, 5.39967e-10)
row 231: (215, 3.97555e-10) (227, 9.78618e-09) (230, 1.60181e-08) (231, -4.6594e-06) (235, 8.17076e-09) (247, 5.39968e-10)
row 232: (216, 3.97555e-10) (228, 8.17076e-09) (232, -4.65706e-06) (233, 1.60181e-08) (236, 7.44591e-09) (248, 5.39968e-10)
row 233: (217, 3.97554e-10) (229, 4.57981e-09) (232, 1.01711e-08) (233, -4.653e-06) (234, 4.57981e-09) (237, 8.24645e-09) (249, 5.39967e-10)
row 234: (218, 3.97554e-10) (230, 4.57981e-09) (233, 4.57981e-09) (234, -4.653e-06) (235, 1.01711e-08) (238, 8.24645e-09) (250, 5.39967e-10)
row 235: (219, 3.97555e-10) (231, 8.17076e-09) (234, 1.60181e-08) (235, -4.65706e-06) (239, 7.44591e-09) (251, 5.39968e-10)
row 236: (220, 3.97555e-10) (232, 4.47429e-09) (236, -4.6547e-06) (237, 1.01638e-08) (252, 5.39968e-10) (996, 4.47429e-09) (1000, 1.01638e-08)
row 237: (221, 3.97555e-10) (233, 6.49352e-09) (236, 8.4571e-09) (237, -4.65504e-06) (238, 8.17076e-09) (253, 5.39968e-10) (1645, 6.49352e-09)
row 238: (222, 3.97555e-10) (234, 6.49352e-09) (237, 8.17076e-09) (238, -4.65504e-06) (239, 8.4571e-09) (254, 5.39968e-10) (1646, 6.49352e-09)
row 239: (223, 3.97555e-10) (235, 4.47429e-09) (238, 1.01638e-08) (239, -4.6547e-06) (255, 5.39968e-10) (1647, 1.01638e-08) (2128, 4.47429e-09)
row 240: (224, 1.14301e-09) (240, -4.66202e-06) (241, 1.76418e-08) (244, 1.76418e-08) (256, 1.14309e-09)
row 241: (225, 1.14301e-09) (240, 9.78624e-09) (241, -4.66071e-06) (242, 8.17081e-09) (245, 1.60182e-08) (257, 1.14309e-09)
row 242: (226, 1.14301e-09) (241, 8.17081e-09) (242, -4.66071e-06) (243, 9.78624e-09) (246, 1.60182e-08) (258, 1.14309e-09)
row 243: (227, 1.14301e-09) (242, 1.76418e-08) (243, -4.66202e-06) (247, 1.76418e-08) (259, 1.14309e-09)
row 244: (228, 1.14301e-09) (240, 9.78624e-09) (244, -4.66071e-06) (245, 1.60182e-08) (248, 8.17081e-09) (260, 1.14309e-09)
row 245: (229, 1.14301e-09) (241, 1.01712e-08) (244, 1.01712e-08) (245, -4.65624e-06) (246, 4.57983e-09) (249, 4.57983e-09) (261, 1.14308e-09)
row 246: (230, 1.14301e-09) (242, 1.01712e-08) (245, 4.57983e-09) (246, -4.65624e-06) (247, 1.01712e-08) (250, 4.57983e-09) (262, 1.14308e-09)
row 247: (231, 1.14301e-09) (243, 9.78624e-09) (246, 1.60182e-08) (247, -4.66071e-06) (251, 8.17081e-09) (263, 1.14309e-09)
row 248: (232, 1.14301e-09) (244, 8.17081e-09) (248, -4.65837e-06) (249, 1.60182e-08) (252, 7.44595e-09) (264, 1.14309e-09)
row 249: (233, 1.14301e-09) (245, 4.57983e-09) (248, 1.01712e-08) (249, -4.65431e-06) (250, 4.57983e-09) (253, 8.24649e-09) (265, 1.14308e-09)
row 250: (234, 1.14301e-09) (246, 4.57983e-09) (249, 4.57983e-09) (250, -4.65431e-06) (251, 1.01712e-08) (254, 8.24649e-09) (266, 1.14308e-09)
row 251: (235, 1.14301e-09) (247, 8.17081e-09) (250, 1.60182e-08) (251, -4.65837e-06) (255, 7.44595e-09) (267, 1.14309e-09)
row 252: (236, 1.14301e-09) (248, 4.47432e-09) (252, -4.65601e-06) (253, 1.01639e-08) (268, 1.14309e-09) (1011, 4.47432e-09) (1015, 1.01639e-08)
row 253: (237, 1.14301e-09) (249, 6.49356e-09) (252, 8.45714e-09) (253, -4.65635e-06) (254, 8.17081e-09) (269, 1.14309e-09) (1654, 6.49356e-09)
row 254: (238, 1.14301e-09) (250, 6.49356e-09) (253, 8.17081e-09) (254, -4.65635e-06) (255, 8.45714e-09) (270, 1.14309e-09) (1655, 6.49356e-09)
row 255: (239, 1.14301e-09) (251, 4.47432e-09) (254, 1.01639e-08) (255, -4.65601e-06) (271, 1.14309e-09) (1656, 1.01639e-08) (2140, 4.47432e-09)
row 256: (240, 5.40011e-10) (256, -4.66064e-06) (257, 1.76419e-08) (260, 1.76419e-08) (272, 3.97559e-10)
row 257: (241, 5.40011e-10) (256, 9.78629e-09) (257, -4.65933e-06) (258, 8.17085e-09) (261, 1.60183e-08) (273, 3.97559e-10)
row 258: (242, 5.40011e-10) (257, 8.17085e-09) (258, -4.65933e-06) (259, 9.78629e-09) (262, 1.60183e-08) (274, 3.97559e-10)
row 259: (243, 5.40011e-10) (258, 1.76419e-08) (259, -4.66064e-06) (263, 1.76419e-08) (275, 3.97559e-10)
row 260: (244, 5.40011e-10) (256, 9.78629e-09) (260, -4.65933e-06) (261, 1.60183e-08) (264, 8.17085e-09) (276, 3.97559e-10)
row 261: (245, 5.40009e-10) (257, 1.01712e-08) (260, 1.01712e-08) (261, -4.65485e-06) (262, 4.57986e-09) (265, 4.57986e-09) (277, 3.97558e-10)
row 262: (246, 5.40009e-10) (258, 1.01712e-08) (261, 4.57986e-09) (262, -4.65485e-06) (263, 1.01712e-08) (266, 4.57986e-09) (278, 3.97558e-10)
row 263: (247, 5.40011e-10) (259, 9.78629e-09) (262, 1.60183e-08) (263, -4.65933e-06) (267, 8.17085e-09) (279, 3.97559e-10)
row 264: (248, 5.40011e-10) (260, 8.17085e-09) (264, -4.65699e-06) (265, 1.60183e-08) (268, 7.44599e-09) (280, 3.97559e-10)
row 265: (249, 5.40009e-10) (261, 4.57986e-09) (264, 1.01712e-08) (265, -4.65293e-06) (266, 4.57986e-09) (269, 8.24654e-09) (281, 3.97558e-10)
row 266: (250, 5.40009e-10) (262, 4.57986e-09) (265, 4.57986e-09) (266, -4.65293e-06) (267, 1.01712e-08) (270, 8.24654e-09) (282, 3.97558e-10)
row 267: (251, 5.40011e-10) (263, 8.17085e-09) (266, 1.60183e-08) (267, -4.65699e-06) (271, 7.44599e-09) (283, 3.97559e-10)
row 268: (252, 5.40011e-10) (264, 4.47434e-09) (268, -4.65463e-06) (269, 1.0164e-08) (284, 3.97559e-10) (1026, 4.47434e-09) (1030, 1.0164e-08)
row 269: (253, 5.40011e-10) (265, 6.49359e-09) (268, 8.45719e-09) (269, -4.65497e-06) (270, 8.17085e-09) (285, 3.97559e-10) (1663, 6.49359e-09)
row 270: (254, 5.40011e-10) (266, 6.49359e-09) (269, 8.17085e-09) (270, -4.65497e-06) (271, 8.45719e-09) (286, 3.97559e-10) (1664, 6.49359e-09)
row 271: (255, 5.40011e-10) (267, 4.47434e-09) (270, 1.0164e-08) (271, -4.65463e-06) (287, 3.97559e-10) (1665, 1.0164e-08) (2152, 4.47434e-09)
row 272: (256, 3.97562e-10) (272, -4.66044e-06) (273, 1.7642e-08) (276, 1.7642e-08) (288, 3.97562e-10)
row 273: (257, 3.97562e-10) (272, 9.78636e-09) (273, -4.65914e-06) (274, 8.17091e-09) (277, 1.60184e-08) (289, 3.97562e-10)
row 274: (258, 3.97562e-10) (273, 8.17091e-09) (274, -4.65914e-06) (275, 9.78636e-09) (278, 1.60184e-08) (290, 3.97562e-10)
row 275: (259, 3.97562e-10) (274, 1.7642e-08) (275, -4.66044e-06) (279, 1.7642e-08) (291, 3.97562e-10)
row 276: (260, 3.97562e-10) (272, 9.78636e-09) (276, -4.65914e-06) (277, 1.60184e-08) (280, 8.17091e-09) (292, 3.97562e-10)
row 277: (261, 3.97561e-10) (273, 1.01713e-08) (276, 1.01713e-08) (277, -4.65466e-06) (278, 4.57989e-09) (281, 4.57989e-09) (293, 3.97561e-10)
row 278: (262, 3.97561e-10) (274, 1.01713e-08) (277, 4.57989e-09) (278, -4.65466e-06) (279, 1.01713e-08) (282, 4.57989e-09) (294, 3.97561e-10)
row 279: (263, 3.97562e-10) (275, 9.78636e-09) (278, 1.60184e-08) (279, -4.65914e-06) (283, 8.17091e-09) (295, 3.97562e-10)
row 280: (264, 3.97562e-10) (276, 8.17091e-09) (280, -4.6568e-06) (281, 1.60184e-08) (284, 7.44604e-09) (296, 3.97562e-10)
row 281: (265, 3.97561e-10) (277, 4.57989e-09) (280, 1.01713e-08) (281, -4.65274e-06) (282, 4.57989e-09) (285, 8.2466e-09) (297, 3.97561e-10)
row 282: (266, 3.97561e-10) (278, 4.57989e-09) (281, 4.57989e-09) (282, -4.65274e-06) (283, 1.01713e-08) (286, 8.2466e-09) (298, 3.97561e-10)
row 283: (267, 3.97562e-10) (279, 8.17091e-09) (282, 1.60184e-08) (283, -4.6568e-06) (287, 7.44604e-09) (299, 3.97562e-10)
row 284: (268, 3.97562e-10) (280, 4.47437e-09) (284, -4.65444e-06) (285, 1.0164e-08) (300, 3.97562e-10) (1041, 4.47437e-09) (1045, 1.0164e-08)
row 285: (269, 3.97562e-10) (281, 6.49364e-09) (284, 8.45725e-09) (285, -4.65478e-06) (286, 8.17091e-09) (301, 3.97562e-10) (1672, 6.49364e-09)
row 286: (270, 3.97562e-10) (282, 6.49364e-09) (285, 8.17091e-09) (286, -4.65478e-06) (287, 8.45725e-09) (302, 3.97562e-10) (1673, 6.49364e-09)
row 287: (271, 3.97562e-10) (283, 4.47437e-09) (286, 1.0164e-08) (287, -4.65444e-06) (303, 3.97562e-10) (1674, 1.0164e-08) (2164, 4.47437e-09)
row 288: (272, 3.97565e-10) (288, -4.6604e-06) (289, 1.76422e-08) (292, 1.76422e-08) (304, 3.97565e-10)
row 289: (273, 3.97565e-10) (288, 9.78643e-09) (289, -4.65909e-06) (290, 8.17097e-09) (293, 1.60185e-08) (305, 3.97565e-10)
row 290: (274, 3.97565e-10) (289, 8.17097e-09) (290, -4.65909e-06) (291, 9.78643e-09) (294, 1.60185e-08) (306, 3.97565e-10)
row 291: (275, 3.97565e-10) (290, 1.76422e-08) (291, -4.6604e-06) (295, 1.76422e-08) (307, 3.97565e-10)
row 292: (276, 3.97565e-10) (288, 9.78643e-09) (292, -4.65909e-06) (293, 1.60185e-08) (296, 8.17097e-09) (308, 3.97565e-10)
row 293: (277, 3.97564e-10) (289, 1.01714e-08) (292, 1.01714e-08) (293, -4.65462e-06) (294, 4.57992e-09) (297, 4.57992e-09) (309, 3.97564e-10)
row 294: (278, 3.97564e-10) (290, 1.01714e-08) (293, 4.57992e-09) (294, -4.65462e-06) (295, 1.01714e-08) (298, 4.57992e-09) (310, 3.97564e-10)
row 295: (279, 3.97565e-10) (291, 9.78643e-09) (294, 1.60185e-08) (295, -4.65909e-06) (299, 8.17097e-09) (311, 3.97565e-10)
row 296: (280, 3.97565e-10) (292, 8.17097e-09) (296, -4.65675e-06) (297, 1.60185e-08) (300, 7.4461e-09) (312, 3.97565e-10)
row 297: (281, 3.97564e-10) (293, 4.57992e-09) (296, 1.01714e-08) (297, -4.65269e-06) (298, 4.57992e-09) (301, 8.24666e-09) (313, 3.97564e-10)
row 298: (282, 3.97564e-10) (294, 4.57992e-09) (297, 4.57992e-09) (298, -4.65269e-06) (299, 1.01714e-08) (302, 8.24666e-09) (314, 3.97564e-10)
row 299: (283, 3.97565e-10) (295, 8.17097e-09) (298, 1.60185e-08) (299, -4.65675e-06) (303, 7.4461e-09) (315, 3.97565e-10)
row 300: (284, 3.97565e-10) (296, 4.47441e-09) (300, -4.65439e-06) (301, 1.01641e-08) (316, 3.97565e-10) (1056, 4.47441e-09) (1060, 1.01641e-08)
row 301: (285, 3.97565e-10) (297, 6.49369e-09) (300, 8.45731e-09) (301, -4.65473e-06) (302, 8.17097e-09) (317, 3.97565e-10) (1681, 6.49369e-09)
row 302: (286, 3.97565e-10) (298, 6.49369e-09) (301, 8.17097e-09) (302, -4.65473e-06) (303, 8.45731e-09) (318, 3.97565e-10) (1682, 6.49369e-09)
row 303: (287, 3.97565e-10) (299, 4.47441e-09) (302, 1.01641e-08) (303, -4.65439e-06) (319, 3.97565e-10) (1683, 1.01641e-08) (2176, 4.47441e-09)
row 304: (288, 3.97568e-10) (304, -4.66035e-06) (305, 1.76423e-08) (308, 1.76423e-08) (320, 3.97568e-10)
row 305: (289, 3.97568e-10) (304, 9.7865e-09) (305, -4.65904e-06) (306, 8.17103e-09) (309, 1.60186e-08) (321, 3.97568e-10)
row 306: (290, 3.97568e-10) (305, 8.17103e-09) (306, -4.65904e-06) (307, 9.7865e-09) (310, 1.60186e-08) (322, 3.97568e-10)
row 307: (291, 3.97568e-10) (306, 1.76423e-08) (307, -4.66035e-06) (311, 1.76423e-08) (323, 3.97568e-10)
row 308: (292, 3.97568e-10) (304, 9.7865e-09) (308, -4.65904e-06) (309, 1.60186e-08) (312, 8.17103e-09) (324, 3.97568e-10)
row 309: (293, 3.97567e-10) (305, 1.01714e-08) (308, 1.01714e-08) (309, -4.65457e-06) (310, 4.57996e-09) (313, 4.57996e-09) (325, 3.97567e-10)
row 310: (294, 3.97567e-10) (306, 1.01714e-08) (309, 4.57996e-09) (310, -4.65457e-06) (311, 1.01714e-08) (314, 4.57996e-09) (326, 3.97567e-10)
row 311: (295, 3.97568e-10) (307, 9.7865e-09) (310, 1.60186e-08) (311, -4.65904e-06) (315, 8.17103e-09) (327, 3.97568e-10)
row 312: (296, 3.97568e-10) (308, 8.17103e-09) (312, -4.6567e-06) (313, 1.60186e-08) (316, 7.44615e-09) (328, 3.97568e-10)
row 313: (297, 3.97567e-10) (309, 4.57996e-09) (312, 1.01714e-08) (313, -4.65264e-06) (314, 4.57996e-09) (317, 8.24672e-09) (329, 3.97567e-10)
row 314: (298, 3.97567e-10) (310, 4.57996e-09) (313, 4.57996e-09) (314, -4.65264e-06) (315, 1.01714e-08) (318, 8.24672e-09) (330, 3.97567e-10)
row 315: (299, 3.97568e-10) (311, 8.17103e-09) (314, 1.60186e-08) (315, -4.6567e-06) (319, 7.44615e-09) (331, 3.97568e-10)
row 316: (300, 3.97568e-10) (312, 4.47444e-09) (316, -4.65434e-06) (317, 1.01642e-08) (332, 3.97568e-10) (1071, 4.47444e-09) (1075, 1.01642e-08)
row 317: (301, 3.97568e-10) (313, 6.49374e-09) (316, 8.45737e-09) (317, -4.65468e-06) (318, 8.17103e-09) (333, 3.97568e-10) (1690, 6.49374e-09)
row 318: (302, 3.97568e-10) (314, 6.49374e-09) (317, 8.17103e-09) (318, -4.65468e-06) (319, 8.45737e-09) (334, 3.97568e-10) (1691, 6.49374e-09)
row 319: (303, 3.97568e-10) (315, 4.47444e-09) (318, 1.01642e-08) (319, -4.65434e-06) (335, 3.97568e-10) (1692, 1.01642e-08) (2188, 4.47444e-09)
row 320: (304, 3.97571e-10) (320, -4.6603e-06) (321, 1.76424e-08) (324, 1.76424e-08) (336, 3.97571e-10)
row 321: (305, 3.97571e-10) (320, 9.78657e-09) (321, -4.65899e-06) (322, 8.17109e-09) (325, 1.60188e-08) (337, 3.97571e-10)
row 322: (306, 3.97571e-10) (321, 8.17109e-09) (322, -4.65899e-06) (323, 9.78657e-09) (326, 1.60188e-08) (338, 3.97571e-10)
row 323: (307, 3.97571e-10) (322, 1.76424e-08) (323, -4.6603e-06) (327, 1.76424e-08) (339, 3.97571e-10)
row 324: (308, 3.97571e-10) (320, 9.78657e-09) (324, -4.65899e-06) (325, 1.60188e-08) (328, 8.17109e-09) (340, 3.97571e-10)
row 325: (309, 3.9757e-10) (321, 1.01715e-08) (324, 1.01715e-08) (325, -4.65452e-06) (326, 4.57999e-09) (329, 4.57999e-09) (341, 3.9757e-10)
row 326: (310, 3.9757e-10) (322, 1.01715e-08) (325, 4.57999e-09) (326, -4.65452e-06) (327, 1.01715e-08) (330, 4.57999e-09) (342, 3.9757e-10)
row 327: (311, 3.97571e-10) (323, 9.78657e-09) (326, 1.60188e-08) (327, -4.65899e-06) (331, 8.17109e-09) (343, 3.97571e-10)
row 328: (312, 3.97571e-10) (324, 8.17109e-09) (328, -4.65665e-06) (329, 1.60188e-08) (332, 7.44621e-09) (344, 3.97571e-10)
row 329: (313, 3.9757e-10) (325, 4.57999e-09) (328, 1.01715e-08) (329, -4.6526e-06) (330, 4.57999e-09) (333, 8.24678e-09) (345, 3.9757e-10)
row 330: (314, 3.9757e-10) (326, 4.57999e-09) (329, 4.57999e-09) (330, -4.6526e-06) (331, 1.01715e-08) (334, 8.24678e-09) (346, 3.9757e-10)
row 331: (315, 3.97571e-10) (327, 8.17109e-09) (330, 1.60188e-08) (331, -4.65665e-06) (335, 7.44621e-09) (347, 3.97571e-10)
row 332: (316, 3.97571e-10) (328, 4.47447e-09) (332, -4.65429e-06) (333, 1.01642e-08) (348, 3.97571e-10) (1086, 4.47447e-09) (1090, 1.01642e-08)
row 333: (317, 3.97571e-10) (329, 6.49378e-09) (332, 8.45743e-09) (333, -4.65463e-06) (334, 8.17109e-09) (349, 3.97571e-10) (1699, 6.49378e-09)
row 334: (318, 3.97571e-10) (330, 6.49378e-09) (333, 8.17109e-09) (334, -4.65463e-06) (335, 8.45743e-09) (350, 3.97571e-10) (1700, 6.49378e-09)
row 335: (319, 3.97571e-10) (331, 4.47447e-09) (334, 1.01642e-08) (335, -4.65429e-06) (351, 3.97571e-10) (1701, 1.01642e-08) (2200, 4.47447e-09)
row 336: (320, 3.97574e-10) (336, -4.6604e-06) (337, 1.76425e-08) (340, 1.76425e-08) (352, 5.39994e-10)
row 337: (321, 3.97574e-10) (336, 9.78664e-09) (337, -4.65909e-06) (338, 8.17115e-09) (341, 1.60189e-08) (353, 5.39993e-10)
row 338: (322, 3.97574e-10) (337, 8.17115e-09) (338, -4.65909e-06) (339, 9.78664e-09) (342, 1.60189e-08) (354, 5.39993e-10)
row 339: (323, 3.97574e-10) (338, 1.76425e-08) (339, -4.6604e-06) (343, 1.76425e-08) (355, 5.39994e-10)
row 340: (324, 3.97574e-10) (336, 9.78664e-09) (340, -4.65909e-06) (341, 1.60189e-08) (344, 8.17115e-09) (356, 5.39993e-10)
row 341: (325, 3.97573e-10) (337, 1.01716e-08) (340, 1.01716e-08) (341, -4.65461e-06) (342, 4.58002e-09) (345, 4.58002e-09) (357, 5.39992e-10)
row 342: (326, 3.97573e-10) (338, 1.01716e-08) (341, 4.58002e-09) (342, -4.65461e-06) (343, 1.01716e-08) (346, 4.58002e-09) (358, 5.39992e-10)
row 343: (327, 3.97574e-10) (339, 9.78664e-09) (342, 1.60189e-08) (343, -4.65909e-06) (347, 8.17115e-09) (359, 5.39993e-10)
row 344: (328, 3.97574e-10) (340, 8.17115e-09) (344, -4.65675e-06) (345, 1.60189e-08) (348, 7.44626e-09) (360, 5.39993e-10)
row 345: (329, 3.97573e-10) (341, 4.58002e-09) (344, 1.01716e-08) (345, -4.65269e-06) (346, 4.58002e-09) (349, 8.24684e-09) (361, 5.39992e-10)
row 346: (330, 3.97573e-10) (342, 4.58002e-09) (345, 4.58002e-09) (346, -4.65269e-06) (347, 1.01716e-08) (350, 8.24684e-09) (362, 5.39992e-10)
row 347: (331, 3.97574e-10) (343, 8.17115e-09) (346, 1.60189e-08) (347, -4.65675e-06) (351, 7.44626e-09) (363, 5.39993e-10)
row 348: (332, 3.97574e-10) (344, 4.4745e-09) (348, -4.65439e-06) (349, 1.01643e-08) (364, 5.39994e-10) (1101, 4.4745e-09) (1105, 1.01643e-08)
row 349: (333, 3.97574e-10) (345, 6.49383e-09) (348, 8.4575e-09) (349, -4.65473e-06) (350, 8.17115e-09) (365, 5.39993e-10) (1708, 6.49383e-09)
row 350: (334, 3.97574e-10) (346, 6.49383e-09) (349, 8.17115e-09) (350, -4.65473e-06) (351, 8.4575e-09) (366, 5.39993e-10) (1709, 6.49383e-09)
row 351: (335, 3.97574e-10) (347, 4.4745e-09) (350, 1.01643e-08) (351, -4.65439e-06) (367, 5.39994e-10) (1710, 1.01643e-08) (2212, 4.4745e-09)
row 352: (336, 1.14306e-09) (352, -4.66171e-06) (353, 1.76426e-08) (356, 1.76426e-08) (368, 1.14314e-09)
row 353: (337, 1.14306e-09) (352, 9.7867e-09) (353, -4.6604e-06) (354, 8.17119e-09) (357, 1.6019e-08) (369, 1.14314e-09)
row 354: (338, 1.14306e-09) (353, 8.17119e-09) (354, -4.6604e-06) (355, 9.7867e-09) (358, 1.6019e-08) (370, 1.14314e-09)
row 355: (339, 1.14306e-09) (354, 1.76426e-08) (355, -4.66171e-06) (359, 1.76426e-08) (371, 1.14314e-09)
row 356: (340, 1.14306e-09) (352, 9.7867e-09) (356, -4.6604e-06) (357, 1.6019e-08) (360, 8.17119e-09) (372, 1.14314e-09)
row 357: (341, 1.14306e-09) (353, 1.01716e-08) (356, 1.01716e-08) (357, -4.65593e-06) (358, 4.58005e-09) (361, 4.58005e-09) (373, 1.14314e-09)
row 358: (342, 1.14306e-09) (354, 1.01716e-08) (357, 4.58005e-09) (358, -4.65593e-06) (359, 1.01716e-08) (362, 4.58005e-09) (374, 1.14314e-09)
row 359: (343, 1.14306e-09) (355, 9.7867e-09) (358, 1.6019e-08) (359, -4.6604e-06) (363, 8.17119e-09) (375, 1.14314e-09)
row 360: (344, 1.14306e-09) (356, 8.17119e-09) (360, -4.65806e-06) (361, 1.6019e-08) (364, 7.4463e-09) (376, 1.14314e-09)
row 361: (345, 1.14306e-09) (357, 4.58005e-09) (360, 1.01716e-08) (361, -4.654e-06) (362, 4.58005e-09) (365, 8.24688e-09) (377, 1.14314e-09)
row 362: (346, 1.14306e-09) (358, 4.58005e-09) (361, 4.58005e-09) (362, -4.654e-06) (363, 1.01716e-08) (366, 8.24688e-09) (378, 1.14314e-09)
row 363: (347, 1.14306e-09) (359, 8.17119e-09) (362, 1.6019e-08) (363, -4.65806e-06) (367, 7.4463e-09) (379, 1.14314e-09)
row 364: (348, 1.14306e-09) (360, 4.47453e-09) (364, -4.6557e-06) (365, 1.01644e-08) (380, 1.14314e-09) (1116, 4.47453e-09) (1120, 1.01644e-08)
row 365: (349, 1.14306e-09) (361, 6.49386e-09) (364, 8.45754e-09) (365, -4.65604e-06) (366, 8.17119e-09) (381, 1.14314e-09) (1717, 6.49386e-09)
row 366: (350, 1.14306e-09) (362, 6.49386e-09) (365, 8.17119e-09) (366, -4.65604e-06) (367, 8.45754e-09) (382, 1.14314e-09) (1718, 6.49386e-09)
row 367: (351, 1.14306e-09) (363, 4.47453e-09) (366, 1.01644e-08) (367, -4.6557e-06) (383, 1.14314e-09) (1719, 1.01644e-08) (2224, 4.47453e-09)
row 368: (352, 5.40036e-10) (368, -4.66033e-06) (369, 1.76427e-08) (372, 1.76427e-08) (384, 3.97578e-10)
row 369: (353, 5.40036e-10) (368, 9.78675e-09) (369, -4.65902e-06) (370, 8.17124e-09) (373, 1.6019e-08) (385, 3.97578e-10)
row 370: (354, 5.40036e-10) (369, 8.17124e-09) (370, -4.65902e-06) (371, 9.78675e-09) (374, 1.6019e-08) (386, 3.97578e-10)
row 371: (355, 5.40036e-10) (370, 1.76427e-08) (371, -4.66033e-06) (375, 1.76427e-08) (387, 3.97578e-10)
row 372: (356, 5.40036e-10) (368, 9.78675e-09) (372, -4.65902e-06) (373, 1.6019e-08) (376, 8.17124e-09) (388, 3.97578e-10)
row 373: (357, 5.40035e-10) (369, 1.01717e-08) (372, 1.01717e-08) (373, -4.65454e-06) (374, 4.58007e-09) (377, 4.58007e-09) (389, 3.97577e-10)
row 374: (358, 5.40035e-10) (370, 1.01717e-08) (373, 4.58007e-09) (374, -4.65454e-06) (375, 1.01717e-08) (378, 4.58007e-09) (390, 3.97577e-10)
row 375: (359, 5.40036e-10) (371, 9.78675e-09) (374, 1.6019e-08) (375, -4.65902e-06) (379, 8.17124e-09) (391, 3.97578e-10)
row 376: (360, 5.40036e-10) (372, 8.17124e-09) (376, -4.65668e-06) (377, 1.6019e-08) (380, 7.44634e-09) (392, 3.97578e-10)
row 377: (361, 5.40035e-10) (373, 4.58007e-09) (376, 1.01717e-08) (377, -4.65262e-06) (378, 4.58007e-09) (381, 8.24692e-09) (393, 3.97577e-10)
row 378: (362, 5.40035e-10) (374, 4.58007e-09) (377, 4.58007e-09) (378, -4.65262e-06) (379, 1.01717e-08) (382, 8.24692e-09) (394, 3.97577e-10)
row 379: (363, 5.40036e-10) (375, 8.17124e-09) (378, 1.6019e-08) (379, -4.65668e-06) (383, 7.44634e-09) (395, 3.97578e-10)
row 380: (364, 5.40036e-10) (376, 4.47455e-09) (380, -4.65432e-06) (381, 1.01644e-08) (396, 3.97578e-10) (1131, 4.47455e-09) (1135, 1.01644e-08)
row 381: (365, 5.40036e-10) (377, 6.4939e-09) (380, 8.45759e-09) (381, -4.65466e-06) (382, 8.17124e-09) (397, 3.97578e-10) (1726, 6.4939e-09)
row 382: (366, 5.40036e-10) (378, 6.4939e-09) (381, 8.17124e-09) (382, -4.65466e-06) (383, 8.45759e-09) (398, 3.97578e-10) (1727, 6.4939e-09)
row 383: (367, 5.40036e-10) (379, 4.47455e-09) (382, 1.01644e-08) (383, -4.65432e-06) (399, 3.97578e-10) (1728, 1.01644e-08) (2236, 4.47455e-09)
row 384: (368, 3.97581e-10) (384, -4.66014e-06) (385, 1.76429e-08) (388, 1.76429e-08) (400, 3.97581e-10)
row 385: (369, 3.97581e-10) (384, 9.78682e-09) (385, -4.65883e-06) (386, 8.1713e-09) (389, 1.60192e-08) (401, 3.97581e-10)
row 386: (370, 3.97581e-10) (385, 8.1713e-09) (386, -4.65883e-06) (387, 9.78682e-09) (390, 1.60192e-08) (402, 3.97581e-10)
row 387: (371, 3.97581e-10) (386, 1.76429e-08) (387, -4.66014e-06) (391, 1.76429e-08) (403, 3.97581e-10)
row 388: (372, 3.97581e-10) (384, 9.78682e-09) (388, -4.65883e-06) (389, 1.60192e-08) (392, 8.1713e-09) (404, 3.97581e-10)
row 389: (373, 3.9758e-10) (385, 1.01718e-08) (388, 1.01718e-08) (389, -4.65435e-06) (390, 4.5801e-09) (393, 4.5801e-09) (405, 3.9758e-10)
row 390: (374, 3.9758e-10) (386, 1.01718e-08) (389, 4.5801e-09) (390, -4.65435e-06) (391, 1.01718e-08) (394, 4.5801e-09) (406, 3.9758e-10)
row 391: (375, 3.97581e-10) (387, 9.78682e-09) (390, 1.60192e-08) (391, -4.65883e-06) (395, 8.1713e-09) (407, 3.97581e-10)
row 392: (376, 3.97581e-10) (388, 8.1713e-09) (392, -4.65649e-06) (393, 1.60192e-08) (396, 7.44639e-09) (408, 3.97581e-10)
row 393: (377, 3.9758e-10) (389, 4.5801e-09) (392, 1.01718e-08) (393, -4.65243e-06) (394, 4.5801e-09) (397, 8.24698e-09) (409, 3.9758e-10)
row 394: (378, 3.9758e-10) (390, 4.5801e-09) (393, 4.5801e-09) (394, -4.65243e-06) (395, 1.01718e-08) (398, 8.24698e-09) (410, 3.9758e-10)
row 395: (379, 3.97581e-10) (391, 8.1713e-09) (394, 1.60192e-08) (395, -4.65649e-06) (399, 7.44639e-09) (411, 3.97581e-10)
row 396: (380, 3.97581e-10) (392, 4.47458e-09) (396, -4.65413e-06) (397, 1.01645e-08) (412, 3.97581e-10) (1146, 4.47458e-09) (1150, 1.01645e-08)
row 397: (381, 3.97581e-10) (393, 6.49395e-09) (396, 8.45765e-09) (397, -4.65447e-06) (398, 8.1713e-09) (413, 3.97581e-10) (1735, 6.49395e-09)
row 398: (382, 3.97581e-10) (394, 6.49395e-09) (397, 8.1713e-09) (398, -4.65447e-06) (399, 8.45765e-09) (414, 3.97581e-10) (1736, 6.49395e-09)
row 399: (383, 3.97581e-10) (395, 4.47458e-09) (398, 1.01645e-08) (399, -4.65413e-06) (415, 3.97581e-10) (1737, 1.01645e-08) (2248, 4.47458e-09)
row 400: (384, 3.97584e-10) (400, -4.66009e-06) (401, 1.7643e-08) (404, 1.7643e-08) (416, 3.97584e-10)
row 401: (385, 3.97584e-10) (400, 9.78689e-09) (401, -4.65878e-06) (402, 8.17135e-09) (405, 1.60193e-08) (417, 3.97584e-10)
row 402: (386, 3.97584e-10) (401, 8.17135e-09) (402, -4.65878e-06) (403, 9.78689e-09) (406, 1.60193e-08) (418, 3.97584e-10)
row 403: (387, 3.97584e-10) (402, 1.7643e-08) (403, -4.66009e-06) (407, 1.7643e-08) (419, 3.97584e-10)
row 404: (388, 3.97584e-10) (400, 9.78689e-09) (404, -4.65878e-06) (405, 1.60193e-08) (408, 8.17135e-09) (420, 3.97584e-10)
row 405: (389, 3.97583e-10) (401, 1.01718e-08) (404, 1.01718e-08) (405, -4.65431e-06) (406, 4.58014e-09) (409, 4.58014e-09) (421, 3.97583e-10)
row 406: (390, 3.97583e-10) (402, 1.01718e-08) (405, 4.58014e-09) (406, -4.65431e-06) (407, 1.01718e-08) (410, 4.58014e-09) (422, 3.97583e-10)
row 407: (391, 3.97584e-10) (403, 9.78689e-09) (406, 1.60193e-08) (407, -4.65878e-06) (411, 8.17135e-09) (423, 3.97584e-10)
row 408: (392, 3.97584e-10) (404, 8.17135e-09) (408, -4.65644e-06) (409, 1.60193e-08) (412, 7.44645e-09) (424, 3.97584e-10)
row 409: (393, 3.97583e-10) (405, 4.58014e-09) (408, 1.01718e-08) (409, -4.65238e-06) (410, 4.58014e-09) (413, 8.24704e-09) (425, 3.97583e-10)
row 410: (394, 3.97583e-10) (406, 4.58014e-09) (409, 4.58014e-09) (410, -4.65238e-06) (411, 1.01718e-08) (414, 8.24704e-09) (426, 3.97583e-10)
row 411: (395, 3.97584e-10) (407, 8.17135e-09) (410, 1.60193e-08) (411, -4.65644e-06) (415, 7.44645e-09) (427, 3.97584e-10)
row 412: (396, 3.97584e-10) (408, 4.47462e-09) (412, -4.65408e-06) (413, 1.01646e-08) (428, 3.97584e-10) (1161, 4.47462e-09) (1165, 1.01646e-08)
row 413: (397, 3.97584e-10) (409, 6.49399e-09) (412, 8.45771e-09) (413, -4.65442e-06) (414, 8.17135e-09) (429, 3.97584e-10) (1744, 6.49399e-09)
row 414: (398, 3.97584e-10) (410, 6.49399e-09) (413, 8.17135e-09) (414, -4.65442e-06) (415, 8.45771e-09) (430, 3.97584e-10) (1745, 6.49399e-09)
row 415: (399, 3.97584e-10) (411, 4.47462e-09) (414, 1.01646e-08) (415, -4.65408e-06) (431, 3.97584e-10) (1746, 1.01646e-08) (2260, 4.47462e-09)
row 416: (400, 3.97587e-10) (416, -4.66004e-06) (417, 1.76431e-08) (420, 1.76431e-08) (432, 3.97587e-10)
row 417: (401, 3.97586e-10) (416, 9.78696e-09) (417, -4.65873e-06) (418, 8.17141e-09) (421, 1.60194e-08) (433, 3.97586e-10)
row 418: (402, 3.97586e-10) (417, 8.17141e-09) (418, -4.65873e-06) (419, 9.78696e-09) (422, 1.60194e-08) (434, 3.97586e-10)
row 419: (403, 3.97587e-10) (418, 1.76431e-08) (419, -4.66004e-06) (423, 1.76431e-08) (435, 3.97587e-10)
row 420: (404, 3.97586e-10) (416, 9.78696e-09) (420, -4.65873e-06) (421, 1.60194e-08) (424, 8.17141e-09) (436, 3.97586e-10)
row 421: (405, 3.97586e-10) (417, 1.01719e-08) (420, 1.01719e-08) (421, -4.65426e-06) (422, 4.58017e-09) (425, 4.58017e-09) (437, 3.97586e-10)
row 422: (406, 3.97586e-10) (418, 1.01719e-08) (421, 4.58017e-09) (422, -4.65426e-06) (423, 1.01719e-08) (426, 4.58017e-09) (438, 3.97586e-10)
row 423: (407, 3.97586e-10) (419, 9.78696e-09) (422, 1.60194e-08) (423, -4.65873e-06) (427, 8.17141e-09) (439, 3.97586e-10)
row 424: (408, 3.97586e-10) (420, 8.17141e-09) (424, -4.65639e-06) (425, 1.60194e-08) (428, 7.4465e-09) (440, 3.97586e-10)
row 425: (409, 3.97586e-10) (421, 4.58017e-09) (424, 1.01719e-08) (425, -4.65233e-06) (426, 4.58017e-09) (429, 8.2471e-09) (441, 3.97586e-10)
row 426: (410, 3.97586e-10) (422, 4.58017e-09) (425, 4.58017e-09) (426, -4.65233e-06) (427, 1.01719e-08) (430, 8.2471e-09) (442, 3.97586e-10)
row 427: (411, 3.97586e-10) (423, 8.17141e-09) (426, 1.60194e-08) (427, -4.65639e-06) (431, 7.4465e-09) (443, 3.97586e-10)
row 428: (412, 3.97587e-10) (424, 4.47465e-09) (428, -4.65403e-06) (429, 1.01647e-08) (444, 3.97587e-10) (1176, 4.47465e-09) (1180, 1.01647e-08)
row 429: (413, 3.97586e-10) (425, 6.49404e-09) (428, 8.45777e-09) (429, -4.65437e-06) (430, 8.17141e-09) (445, 3.97586e-10) (1753, 6.49404e-09)
row 430: (414, 3.97586e-10) (426, 6.49404e-09) (429, 8.17141e-09) (430, -4.65437e-06) (431, 8.45777e-09) (446, 3.97586e-10) (1754, 6.49404e-09)
row 431: (415, 3.97587e-10) (427, 4.47465e-09) (430, 1.01647e-08) (431, -4.65403e-06) (447, 3.97587e-10) (1755, 1.01647e-08) (2272, 4.47465e-09)
row 432: (416, 3.9759e-10) (432, -4.65999e-06) (433, 1.76432e-08) (436, 1.76432e-08) (448, 3.9759e-10)
row 433: (417, 3.97589e-10) (432, 9.78703e-09) (433, -4.65868e-06) (434, 8.17147e-09) (437, 1.60195e-08) (449, 3.97589e-10)
row 434: (418, 3.97589e-10) (433, 8.17147e-09) (434, -4.65868e-06) (435, 9.78703e-09) (438, 1.60195e-08) (450, 3.97589e-10)
row 435: (419, 3.9759e-10) (434, 1.76432e-08) (435, -4.65999e-06) (439, 1.76432e-08) (451, 3.9759e-10)
row 436: (420, 3.97589e-10) (432, 9.78703e-09) (436, -4.65868e-06) (437, 1.60195e-08) (440, 8.17147e-09) (452, 3.97589e-10)
row 437: (421, 3.97588e-10) (433, 1.0172e-08) (436, 1.0172e-08) (437, -4.65421e-06) (438, 4.5802e-09) (441, 4.5802e-09) (453, 3.97588e-10)
row 438: (422, 3.97588e-10) (434, 1.0172e-08) (437, 4.5802e-09) (438, -4.65421e-06) (439, 1.0172e-08) (442, 4.5802e-09) (454, 3.97588e-10)
row 439: (423, 3.97589e-10) (435, 9.78703e-09) (438, 1.60195e-08) (439, -4.65868e-06) (443, 8.17147e-09) (455, 3.97589e-10)
row 440: (424, 3.97589e-10) (436, 8.17147e-09) (440, -4.65634e-06) (441, 1.60195e-08) (444, 7.44656e-09) (456, 3.97589e-10)
row 441: (425, 3.97588e-10) (437, 4.5802e-09) (440, 1.0172e-08) (441, -4.65229e-06) (442, 4.5802e-09) (445, 8.24716e-09) (457, 3.97588e-10)
row 442: (426, 3.97588e-10) (438, 4.5802e-09) (441, 4.5802e-09) (442, -4.65229e-06) (443, 1.0172e-08) (446, 8.24716e-09) (458, 3.97588e-10)
row 443: (427, 3.97589e-10) (439, 8.17147e-09) (442, 1.60195e-08) (443, -4.65634e-06) (447, 7.44656e-09) (459, 3.97589e-10)
row 444: (428, 3.9759e-10) (440, 4.47468e-09) (444, -4.65399e-06) (445, 1.01647e-08) (460, 3.9759e-10) (1191, 4.47468e-09) (1195, 1.01647e-08)
row 445: (429, 3.97589e-10) (441, 6.49409e-09) (444, 8.45783e-09) (445, -4.65432e-06) (446, 8.17147e-09) (461, 3.97589e-10) (1762, 6.49409e-09)
row 446: (430, 3.97589e-10) (442, 6.49409e-09) (445, 8.17147e-09) (446, -4.65432e-06) (447, 8.45783e-09) (462, 3.97589e-10) (1763, 6.49409e-09)
row 447: (431, 3.9759e-10) (443, 4.47468e-09) (446, 1.01647e-08) (447, -4.65399e-06) (463, 3.9759e-10) (1764, 1.01647e-08) (2284, 4.47468e-09)
row 448: (432, 3.97592e-10) (448, -4.66009e-06) (449, 1.76434e-08) (452, 1.76434e-08) (464, 5.40019e-10)
row 449: (433, 3.97592e-10) (448, 9.7871e-09) (449, -4.65878e-06) (450, 8.17153e-09) (453, 1.60196e-08) (465, 5.40019e-10)
row 450: (434, 3.97592e-10) (449, 8.17153e-09) (450, -4.65878e-06) (451, 9.7871e-09) (454, 1.60196e-08) (466, 5.40019e-10)
row 451: (435, 3.97592e-10) (450, 1.76434e-08) (451, -4.66009e-06) (455, 1.76434e-08) (467, 5.40019e-10)
row 452: (436, 3.97592e-10) (448, 9.7871e-09) (452, -4.65878e-06) (453, 1.60196e-08) (456, 8.17153e-09) (468, 5.40019e-10)
row 453: (437, 3.97591e-10) (449, 1.01721e-08) (452, 1.01721e-08) (453, -4.65431e-06) (454, 4.58024e-09) (457, 4.58024e-09) (469, 5.40018e-10)
row 454: (438, 3.97591e-10) (450, 1.01721e-08) (453, 4.58024e-09) (454, -4.65431e-06) (455, 1.01721e-08) (458, 4.58024e-09) (470, 5.40018e-10)
row 455: (439, 3.97592e-10) (451, 9.7871e-09) (454, 1.60196e-08) (455, -4.65878e-06) (459, 8.17153e-09) (471, 5.40019e-10)
row 456: (440, 3.97592e-10) (452, 8.17153e-09) (456, -4.65644e-06) (457, 1.60196e-08) (460, 7.44661e-09) (472, 5.40019e-10)
row 457: (441, 3.97591e-10) (453, 4.58024e-09) (456, 1.01721e-08) (457, -4.65238e-06) (458, 4.58024e-09) (461, 8.24722e-09) (473, 5.40018e-10)
row 458: (442, 3.97591e-10) (454, 4.58024e-09) (457, 4.58024e-09) (458, -4.65238e-06) (459, 1.01721e-08) (462, 8.24722e-09) (474, 5.40018e-10)
row 459: (443, 3.97592e-10) (455, 8.17153e-09) (458, 1.60196e-08) (459, -4.65644e-06) (463, 7.44661e-09) (475, 5.40019e-10)
row 460: (444, 3.97592e-10) (456, 4.47471e-09) (460, -4.65408e-06) (461, 1.01648e-08) (476, 5.40019e-10) (1206, 4.47471e-09) (1210, 1.01648e-08)
row 461: (445, 3.97592e-10) (457, 6.49414e-09) (460, 8.45789e-09) (461, -4.65442e-06) (462, 8.17153e-09) (477, 5.40019e-10) (1771, 6.49414e-09)
row 462: (446, 3.97592e-10) (458, 6.49414e-09) (461, 8.17153e-09) (462, -4.65442e-06) (463, 8.45789e-09) (478, 5.40019e-10) (1772, 6.49414e-09)
row 463: (447, 3.97592e-10) (459, 4.47471e-09) (462, 1.01648e-08) (463, -4.65408e-06) (479, 5.40019e-10) (1773, 1.01648e-08) (2296, 4.47471e-09)
row 464: (448, 1.14312e-09) (464, -4.6614e-06) (465, 1.76435e-08) (468, 1.76435e-08) (480, 1.1432e-09)
row 465: (449, 1.14312e-09) (464, 9.78716e-09) (465, -4.66009e-06) (466, 8.17158e-09) (469, 1.60197e-08) (481, 1.14319e-09)
row 466: (450, 1.14312e-09) (465, 8.17158e-09) (466, -4.66009e-06) (467, 9.78716e-09) (470, 1.60197e-08) (482, 1.14319e-09)
row 467: (451, 1.14312e-09) (466, 1.76435e-08) (467, -4.6614e-06) (471, 1.76435e-08) (483, 1.1432e-09)
row 468: (452, 1.14312e-09) (464, 9.78716e-09) (468, -4.66009e-06) (469, 1.60197e-08) (472, 8.17158e-09) (484, 1.14319e-09)
row 469: (453, 1.14311e-09) (465, 1.01721e-08) (468, 1.01721e-08) (469, -4.65562e-06) (470, 4.58026e-09) (473, 4.58026e-09) (485, 1.14319e-09)
row 470: (454, 1.14311e-09) (466, 1.01721e-08) (469, 4.58026e-09) (470, -4.65562e-06) (471, 1.01721e-08) (474, 4.58026e-09) (486, 1.14319e-09)
row 471: (455, 1.14312e-09) (467, 9.78716e-09) (470, 1.60197e-08) (471, -4.66009e-06) (475, 8.17158e-09) (487, 1.14319e-09)
row 472: (456, 1.14312e-09) (468, 8.17158e-09) (472, -4.65775e-06) (473, 1.60197e-08) (476, 7.44665e-09) (488, 1.14319e-09)
row 473: (457, 1.14311e-09) (469, 4.58026e-09) (472, 1.01721e-08) (473, -4.65369e-06) (474, 4.58026e-09) (477, 8.24727e-09) (489, 1.14319e-09)
row 474: (458, 1.14311e-09) (470, 4.58026e-09) (473, 4.58026e-09) (474, -4.65369e-06) (475, 1.01721e-08) (478, 8.24727e-09) (490, 1.14319e-09)
row 475: (459, 1.14312e-09) (471, 8.17158e-09) (474, 1.60197e-08) (475, -4.65775e-06) (479, 7.44665e-09) (491, 1.14319e-09)
row 476: (460, 1.14312e-09) (472, 4.47474e-09) (476, -4.65539e-06) (477, 1.01649e-08) (492, 1.1432e-09) (1221, 4.47474e-09) (1225, 1.01649e-08)
row 477: (461, 1.14312e-09) (473, 6.49417e-09) (476, 8.45794e-09) (477, -4.65573e-06) (478, 8.17158e-09) (493, 1.14319e-09) (1780, 6.49417e-09)
row 478: (462, 1.14312e-09) (474, 6.49417e-09) (477, 8.17158e-09) (478, -4.65573e-06) (479, 8.45794e-09) (494, 1.14319e-09) (1781, 6.49417e-09)
row 479: (463, 1.14312e-09) (475, 4.47474e-09) (478, 1.01649e-08) (479, -4.65539e-06) (495, 1.1432e-09) (1782, 1.01649e-08) (2308, 4.47474e-09)
row 480: (464, 5.40062e-10) (480, -4.66002e-06) (481, 1.76436e-08) (484, 1.76436e-08) (496, 3.97597e-10)
row 481: (465, 5.40061e-10) (480, 9.78721e-09) (481, -4.65871e-06) (482, 8.17162e-09) (485, 1.60198e-08) (497, 3.97596e-10)
row 482: (466, 5.40061e-10) (481, 8.17162e-09) (482, -4.65871e-06) (483, 9.78721e-09) (486, 1.60198e-08) (498, 3.97596e-10)
row 483: (467, 5.40062e-10) (482, 1.76436e-08) (483, -4.66002e-06) (487, 1.76436e-08) (499, 3.97597e-10)
row 484: (468, 5.40061e-10) (480, 9.78721e-09) (484, -4.65871e-06) (485, 1.60198e-08) (488, 8.17162e-09) (500, 3.97596e-10)
row 485: (469, 5.4006e-10) (481, 1.01722e-08) (484, 1.01722e-08) (485, -4.65424e-06) (486, 4.58029e-09) (489, 4.58029e-09) (501, 3.97596e-10)
row 486: (470, 5.4006e-10) (482, 1.01722e-08) (485, 4.58029e-09) (486, -4.65424e-06) (487, 1.01722e-08) (490, 4.58029e-09) (502, 3.97596e-10)
row 487: (471, 5.40061e-10) (483, 9.78721e-09) (486, 1.60198e-08) (487, -4.65871e-06) (491, 8.17162e-09) (503, 3.97596e-10)
row 488: (472, 5.40061e-10) (484, 8.17162e-09) (488, -4.65637e-06) (489, 1.60198e-08) (492, 7.44669e-09) (504, 3.97596e-10)
row 489: (473, 5.4006e-10) (485, 4.58029e-09) (488, 1.01722e-08) (489, -4.65231e-06) (490, 4.58029e-09) (493, 8.24731e-09) (505, 3.97596e-10)
row 490: (474, 5.4006e-10) (486, 4.58029e-09) (489, 4.58029e-09) (490, -4.65231e-06) (491, 1.01722e-08) (494, 8.24731e-09) (506, 3.97596e-10)
row 491: (475, 5.40061e-10) (487, 8.17162e-09) (490, 1.60198e-08) (491, -4.65637e-06) (495, 7.44669e-09) (507, 3.97596e-10)
row 492: (476, 5.40062e-10) (488, 4.47476e-09) (492, -4.65401e-06) (493, 1.01649e-08) (508, 3.97597e-10) (1236, 4.47476e-09) (1240, 1.01649e-08)
row 493: (477, 5.40061e-10) (489, 6.49421e-09) (492, 8.45798e-09) (493, -4.65435e-06) (494, 8.17162e-09) (509, 3.97596e-10) (1789, 6.49421e-09)
row 494: (478, 5.40061e-10) (490, 6.49421e-09) (493, 8.17162e-09) (494, -4.65435e-06) (495, 8.45798e-09) (510, 3.97596e-10) (1790, 6.49421e-09)
row 495: (479, 5.40062e-10) (491, 4.47476e-09) (494, 1.01649e-08) (495, -4.65401e-06) (511, 3.97597e-10) (1791, 1.01649e-08) (2320, 4.47476e-09)
row 496: (480, 3.976e-10) (496, -4.65983e-06) (497, 1.76437e-08) (500, 1.76437e-08) (512, 3.976e-10)
row 497: (481, 3.97599e-10) (496, 9.78728e-09) (497, -4.65852e-06) (498, 8.17168e-09) (501, 1.60199e-08) (513, 3.97599e-10)
row 498: (482, 3.97599e-10) (497, 8.17168e-09) (498, -4.65852e-06) (499, 9.78728e-09) (502, 1.60199e-08) (514, 3.97599e-10)
row 499: (483, 3.976e-10) (498, 1.76437e-08) (499, -4.65983e-06) (503, 1.76437e-08) (515, 3.976e-10)
row 500: (484, 3.97599e-10) (496, 9.78728e-09) (500, -4.65852e-06) (501, 1.60199e-08) (504, 8.17168e-09) (516, 3.97599e-10)
row 501: (485, 3.97598e-10) (497, 1.01722e-08) (500, 1.01722e-08) (501, -4.65405e-06) (502, 4.58032e-09) (505, 4.58032e-09) (517, 3.97598e-10)
row 502: (486, 3.97598e-10) (498, 1.01722e-08) (501, 4.58032e-09) (502, -4.65405e-06) (503, 1.01722e-08) (506, 4.58032e-09) (518, 3.97598e-10)
row 503: (487, 3.97599e-10) (499, 9.78728e-09) (502, 1.60199e-08) (503, -4.65852e-06) (507, 8.17168e-09) (519, 3.97599e-10)
row 504: (488, 3.97599e-10) (500, 8.17168e-09) (504, -4.65618e-06) (505, 1.60199e-08) (508, 7.44675e-09) (520, 3.97599e-10)
row 505: (489, 3.97598e-10) (501, 4.58032e-09) (504, 1.01722e-08) (505, -4.65212e-06) (506, 4.58032e-09) (509, 8.24737e-09) (521, 3.97598e-10)
row 506: (490, 3.97598e-10) (502, 4.58032e-09) (505, 4.58032e-09) (506, -4.65212e-06) (507, 1.01722e-08) (510, 8.24737e-09) (522, 3.97598e-10)
row 507: (491, 3.97599e-10) (503, 8.17168e-09) (506, 1.60199e-08) (507, -4.65618e-06) (511, 7.44675e-09) (523, 3.97599e-10)
row 508: (492, 3.976e-10) (504, 4.4748e-09) (508, -4.65382e-06) (509, 1.0165e-08) (524, 3.976e-10) (1251, 4.4748e-09) (1255, 1.0165e-08)
row 509: (493, 3.97599e-10) (505, 6.49425e-09) (508, 8.45805e-09) (509, -4.65416e-06) (510, 8.17168e-09) (525, 3.97599e-10) (1798, 6.49425e-09)
row 510: (494, 3.97599e-10) (506, 6.49425e-09) (509, 8.17168e-09) (510, -4.65416e-06) (511, 8.45805e-09) (526, 3.97599e-10) (1799, 6.49425e-09)
row 511: (495, 3.976e-10) (507, 4.4748e-09) (510, 1.0165e-08) (511, -4.65382e-06) (527, 3.976e-10) (1800, 1.0165e-08) (2332, 4.4748e-09)
row 512: (496, 3.97603e-10) (512, -4.65978e-06) (513, 1.76438e-08) (516, 1.76438e-08) (528, 3.97603e-10)
row 513: (497, 3.97602e-10) (512, 9.78735e-09) (513, -4.65847e-06) (514, 8.17174e-09) (517, 1.602e-08) (529, 3.97602e-10)
row 514: (498, 3.97602e-10) (513, 8.17174e-09) (514, -4.65847e-06) (515, 9.78735e-09) (518, 1.602e-08) (530, 3.97602e-10)
row 515: (499, 3.97603e-10) (514, 1.76438e-08) (515, -4.65978e-06) (519, 1.76438e-08) (531, 3.97603e-10)
row 516: (500, 3.97602e-10) (512, 9.78735e-09) (516, -4.65847e-06) (517, 1.602e-08) (520, 8.17174e-09) (532, 3.97602e-10)
row 517: (501, 3.97601e-10) (513, 1.01723e-08) (516, 1.01723e-08) (517, -4.654e-06) (518, 4.58035e-09) (521, 4.58035e-09) (533, 3.97601e-10)
row 518: (502, 3.97601e-10) (514, 1.01723e-08) (517, 4.58035e-09) (518, -4.654e-06) (519, 1.01723e-08) (522, 4.58035e-09) (534, 3.97601e-10)
row 519: (503, 3.97602e-10) (515, 9.78735e-09) (518, 1.602e-08) (519, -4.65847e-06) (523, 8.17174e-09) (535, 3.97602e-10)
row 520: (504, 3.97602e-10) (516, 8.17174e-09) (520, -4.65613e-06) (521, 1.602e-08) (524, 7.4468e-09) (536, 3.97602e-10)
row 521: (505, 3.97601e-10) (517, 4.58035e-09) (520, 1.01723e-08) (521, -4.65207e-06) (522, 4.58035e-09) (525, 8.24743e-09) (537, 3.97601e-10)
row 522: (506, 3.97601e-10) (518, 4.58035e-09) (521, 4.58035e-09) (522, -4.65207e-06) (523, 1.01723e-08) (526, 8.24743e-09) (538, 3.97601e-10)
row 523: (507, 3.97602e-10) (519, 8.17174e-09) (522, 1.602e-08) (523, -4.65613e-06) (527, 7.4468e-09) (539, 3.97602e-10)
row 524: (508, 3.97603e-10) (520, 4.47483e-09) (524, -4.65377e-06) (525, 1.01651e-08) (540, 3.97603e-10) (1266, 4.47483e-09) (1270, 1.01651e-08)
row 525: (509, 3.97602e-10) (521, 6.4943e-09) (524, 8.45811e-09) (525, -4.65411e-06) (526, 8.17174e-09) (541, 3.97602e-10) (1807, 6.4943e-09)
row 526: (510, 3.97602e-10) (522, 6.4943e-09) (525, 8.17174e-09) (526, -4.65411e-06) (527, 8.45811e-09) (542, 3.97602e-10) (1808, 6.4943e-09)
row 527: (511, 3.97603e-10) (523, 4.47483e-09) (526, 1.01651e-08) (527, -4.65377e-06) (543, 3.97603e-10) (1809, 1.01651e-08) (2344, 4.47483e-09)
row 528: (512, 3.97605e-10) (528, -4.65973e-06) (529, 1.76439e-08) (532, 1.76439e-08) (544, 3.97605e-10)
row 529: (513, 3.97605e-10) (528, 9.78742e-09) (529, -4.65842e-06) (530, 8.1718e-09) (533, 1.60201e-08) (545, 3.97605e-10)
row 530: (514, 3.97605e-10) (529, 8.1718e-09) (530, -4.65842e-06) (531, 9.78742e-09) (534, 1.60201e-08) (546, 3.97605e-10)
row 531: (515, 3.97605e-10) (530, 1.76439e-08) (531, -4.65973e-06) (535, 1.76439e-08) (547, 3.97605e-10)
row 532: (516, 3.97605e-10) (528, 9.78742e-09) (532, -4.65842e-06) (533, 1.60201e-08) (536, 8.1718e-09) (548, 3.97605e-10)
row 533: (517, 3.97604e-10) (529, 1.01724e-08) (532, 1.01724e-08) (533, -4.65395e-06) (534, 4.58039e-09) (537, 4.58039e-09) (549, 3.97604e-10)
row 534: (518, 3.97604e-10) (530, 1.01724e-08) (533, 4.58039e-09) (534, -4.65395e-06) (535, 1.01724e-08) (538, 4.58039e-09) (550, 3.97604e-10)
row 535: (519, 3.97605e-10) (531, 9.78742e-09) (534, 1.60201e-08) (535, -4.65842e-06) (539, 8.1718e-09) (551, 3.97605e-10)
row 536: (520, 3.97605e-10) (532, 8.1718e-09) (536, -4.65608e-06) (537, 1.60201e-08) (540, 7.44685e-09) (552, 3.97605e-10)
row 537: (521, 3.97604e-10) (533, 4.58039e-09) (536, 1.01724e-08) (537, -4.65203e-06) (538, 4.58039e-09) (541, 8.24749e-09) (553, 3.97604e-10)
row 538: (522, 3.97604e-10) (534, 4.58039e-09) (537, 4.58039e-09) (538, -4.65203e-06) (539, 1.01724e-08) (542, 8.24749e-09) (554, 3.97604e-10)
row 539: (523, 3.97605e-10) (535, 8.1718e-09) (538, 1.60201e-08) (539, -4.65608e-06) (543, 7.44685e-09) (555, 3.97605e-10)
row 540: (524, 3.97605e-10) (536, 4.47486e-09) (540, -4.65372e-06) (541, 1.01651e-08) (556, 3.97605e-10) (1281, 4.47486e-09) (1285, 1.01651e-08)
row 541: (525, 3.97605e-10) (537, 6.49435e-09) (540, 8.45817e-09) (541, -4.65406e-06) (542, 8.1718e-09) (557, 3.97605e-10) (1816, 6.49435e-09)
row 542: (526, 3.97605e-10) (538, 6.49435e-09) (541, 8.1718e-09) (542, -4.65406e-06) (543, 8.45817e-09) (558, 3.97605e-10) (1817, 6.49435e-09)
row 543: (527, 3.97605e-10) (539, 4.47486e-09) (542, 1.01651e-08) (543, -4.65372e-06) (559, 3.97605e-10) (1818, 1.01651e-08) (2356, 4.47486e-09)
row 544: (528, 3.97608e-10) (544, -4.65969e-06) (545, 1.76441e-08) (548, 1.76441e-08) (560, 3.97608e-10)
row 545: (529, 3.97608e-10) (544, 9.78749e-09) (545, -4.65838e-06) (546, 8.17186e-09) (549, 1.60203e-08) (561, 3.97608e-10)
row 546: (530, 3.97608e-10) (545, 8.17186e-09) (546, -4.65838e-06) (547, 9.78749e-09) (550, 1.60203e-08) (562, 3.97608e-10)
row 547: (531, 3.97608e-10) (546, 1.76441e-08) (547, -4.65969e-06) (551, 1.76441e-08) (563, 3.97608e-10)
row 548: (532, 3.97608e-10) (544, 9.78749e-09) (548, -4.65838e-06) (549, 1.60203e-08) (552, 8.17186e-09) (564, 3.97608e-10)
row 549: (533, 3.97607e-10) (545, 1.01725e-08) (548, 1.01725e-08) (549, -4.6539e-06) (550, 4.58042e-09) (553, 4.58042e-09) (565, 3.97607e-10)
row 550: (534, 3.97607e-10) (546, 1.01725e-08) (549, 4.58042e-09) (550, -4.6539e-06) (551, 1.01725e-08) (554, 4.58042e-09) (566, 3.97607e-10)
row 551: (535, 3.97608e-10) (547, 9.78749e-09) (550, 1.60203e-08) (551, -4.65838e-06) (555, 8.17186e-09) (567, 3.97608e-10)
row 552: (536, 3.97608e-10) (548, 8.17186e-09) (552, -4.65604e-06) (553, 1.60203e-08) (556, 7.44691e-09) (568, 3.97608e-10)
row 553: (537, 3.97607e-10) (549, 4.58042e-09) (552, 1.01725e-08) (553, -4.65198e-06) (554, 4.58042e-09) (557, 8.24755e-09) (569, 3.97607e-10)
row 554: (538, 3.97607e-10) (550, 4.58042e-09) (553, 4.58042e-09) (554, -4.65198e-06) (555, 1.01725e-08) (558, 8.24755e-09) (570, 3.97607e-10)
row 555: (539, 3.97608e-10) (551, 8.17186e-09) (554, 1.60203e-08) (555, -4.65604e-06) (559, 7.44691e-09) (571, 3.97608e-10)
row 556: (540, 3.97608e-10) (552, 4.47489e-09) (556, -4.65368e-06) (557, 1.01652e-08) (572, 3.97608e-10) (1296, 4.47489e-09) (1300, 1.01652e-08)
row 557: (541, 3.97608e-10) (553, 6.49439e-09) (556, 8.45823e-09) (557, -4.65402e-06) (558, 8.17186e-09) (573, 3.97608e-10) (1825, 6.49439e-09)
row 558: (542, 3.97608e-10) (554, 6.49439e-09) (557, 8.17186e-09) (558, -4.65402e-06) (559, 8.45823e-09) (574, 3.97608e-10) (1826, 6.49439e-09)
row 559: (543, 3.97608e-10) (555, 4.47489e-09) (558, 1.01652e-08) (559, -4.65368e-06) (575, 3.97608e-10) (1827, 1.01652e-08) (2368, 4.47489e-09)
row 560: (544, 3.97611e-10) (560, -4.65978e-06) (561, 1.76442e-08) (564, 1.76442e-08) (576, 5.40045e-10)
row 561: (545, 3.97611e-10) (560, 9.78757e-09) (561, -4.65847e-06) (562, 8.17192e-09) (565, 1.60204e-08) (577, 5.40044e-10)
row 562: (546, 3.97611e-10) (561, 8.17192e-09) (562, -4.65847e-06) (563, 9.78757e-09) (566, 1.60204e-08) (578, 5.40044e-10)
row 563: (547, 3.97611e-10) (562, 1.76442e-08) (563, -4.65978e-06) (567, 1.76442e-08) (579, 5.40045e-10)
row 564: (548, 3.97611e-10) (560, 9.78757e-09) (564, -4.65847e-06) (565, 1.60204e-08) (568, 8.17192e-09) (580, 5.40044e-10)
row 565: (549, 3.9761e-10) (561, 1.01725e-08) (564, 1.01725e-08) (565, -4.654e-06) (566, 4.58045e-09) (569, 4.58045e-09) (581, 5.40043e-10)
row 566: (550, 3.9761e-10) (562, 1.01725e-08) (565, 4.58045e-09) (566, -4.654e-06) (567, 1.01725e-08) (570, 4.58045e-09) (582, 5.40043e-10)
row 567: (551, 3.97611e-10) (563, 9.78757e-09) (566, 1.60204e-08) (567, -4.65847e-06) (571, 8.17192e-09) (583, 5.40044e-10)
row 568: (552, 3.97611e-10) (564, 8.17192e-09) (568, -4.65613e-06) (569, 1.60204e-08) (572, 7.44696e-09) (584, 5.40044e-10)
row 569: (553, 3.9761e-10) (565, 4.58045e-09) (568, 1.01725e-08) (569, -4.65207e-06) (570, 4.58045e-09) (573, 8.24761e-09) (585, 5.40043e-10)
row 570: (554, 3.9761e-10) (566, 4.58045e-09) (569, 4.58045e-09) (570, -4.65207e-06) (571, 1.01725e-08) (574, 8.24761e-09) (586, 5.40043e-10)
row 571: (555, 3.97611e-10) (567, 8.17192e-09) (570, 1.60204e-08) (571, -4.65613e-06) (575, 7.44696e-09) (587, 5.40044e-10)
row 572: (556, 3.97611e-10) (568, 4.47493e-09) (572, -4.65377e-06) (573, 1.01653e-08) (588, 5.40045e-10) (1311, 4.47493e-09) (1315, 1.01653e-08)
row 573: (557, 3.97611e-10) (569, 6.49444e-09) (572, 8.45829e-09) (573, -4.65411e-06) (574, 8.17192e-09) (589, 5.40044e-10) (1834, 6.49444e-09)
row 574: (558, 3.97611e-10) (570, 6.49444e-09) (573, 8.17192e-09) (574, -4.65411e-06) (575, 8.45829e-09) (590, 5.40044e-10) (1835, 6.49444e-09)
row 575: (559, 3.97611e-10) (571, 4.47493e-09) (574, 1.01653e-08) (575, -4.65377e-06) (591, 5.40045e-10) (1836, 1.01653e-08) (2380, 4.47493e-09)
row 576: (560, 1.14317e-09) (576, -4.66109e-06) (577, 1.76443e-08) (580, 1.76443e-08) (592, 1.14325e-09)
row 577: (561, 1.14317e-09) (576, 9.78762e-09) (577, -4.65978e-06) (578, 8.17196e-09) (581, 1.60205e-08) (593, 1.14325e-09)
row 578: (562, 1.14317e-09) (577, 8.17196e-09) (578, -4.65978e-06) (579, 9.78762e-09) (582, 1.60205e-08) (594, 1.14325e-09)
row 579: (563, 1.14317e-09) (578, 1.76443e-08) (579, -4.66109e-06) (583, 1.76443e-08) (595, 1.14325e-09)
row 580: (564, 1.14317e-09) (576, 9.78762e-09) (580, -4.65978e-06) (581, 1.60205e-08) (584, 8.17196e-09) (596, 1.14325e-09)
row 581: (565, 1.14317e-09) (577, 1.01726e-08) (580, 1.01726e-08) (581, -4.65531e-06) (582, 4.58048e-09) (585, 4.58048e-09) (597, 1.14325e-09)
row 582: (566, 1.14317e-09) (578, 1.01726e-08) (581, 4.58048e-09) (582, -4.65531e-06) (583, 1.01726e-08) (586, 4.58048e-09) (598, 1.14325e-09)
row 583: (567, 1.14317e-09) (579, 9.78762e-09) (582, 1.60205e-08) (583, -4.65978e-06) (587, 8.17196e-09) (599, 1.14325e-09)
row 584: (568, 1.14317e-09) (580, 8.17196e-09) (584, -4.65744e-06) (585, 1.60205e-08) (588, 7.447e-09) (600, 1.14325e-09)
row 585: (569, 1.14317e-09) (581, 4.58048e-09) (584, 1.01726e-08) (585, -4.65339e-06) (586, 4.58048e-09) (589, 8.24766e-09) (601, 1.14325e-09)
row 586: (570, 1.14317e-09) (582, 4.58048e-09) (585, 4.58048e-09) (586, -4.65339e-06) (587, 1.01726e-08) (590, 8.24766e-09) (602, 1.14325e-09)
row 587: (571, 1.14317e-09) (583, 8.17196e-09) (586, 1.60205e-08) (587, -4.65744e-06) (591, 7.447e-09) (603, 1.14325e-09)
row 588: (572, 1.14317e-09) (584, 4.47495e-09) (588, -4.65509e-06) (589, 1.01653e-08) (604, 1.14325e-09) (1326, 4.47495e-09) (1330, 1.01653e-08)
row 589: (573, 1.14317e-09) (585, 6.49448e-09) (588, 8.45834e-09) (589, -4.65542e-06) (590, 8.17196e-09) (605, 1.14325e-09) (1843, 6.49448e-09)
row 590: (574, 1.14317e-09) (586, 6.49448e-09) (589, 8.17196e-09) (590, -4.65542e-06) (591, 8.45834e-09) (606, 1.14325e-09) (1844, 6.49448e-09)
row 591: (575, 1.14317e-09) (587, 4.47495e-09) (590, 1.01653e-08) (591, -4.65509e-06) (607, 1.14325e-09) (1845, 1.01653e-08) (2392, 4.47495e-09)
row 592: (576, 5.40087e-10) (592, -4.65971e-06) (593, 1.76444e-08) (596, 1.76444e-08) (608, 3.97615e-10)
row 593: (577, 5.40087e-10) (592, 9.78767e-09) (593, -4.6584e-06) (594, 8.17201e-09) (597, 1.60205e-08) (609, 3.97615e-10)
row 594: (578, 5.40087e-10) (593, 8.17201e-09) (594, -4.6584e-06) (595, 9.78767e-09) (598, 1.60205e-08) (610, 3.97615e-10)
row 595: (579, 5.40087e-10) (594, 1.76444e-08) (595, -4.65971e-06) (599, 1.76444e-08) (611, 3.97615e-10)
row 596: (580, 5.40087e-10) (592, 9.78767e-09) (596, -4.6584e-06) (597, 1.60205e-08) (600, 8.17201e-09) (612, 3.97615e-10)
row 597: (581, 5.40086e-10) (593, 1.01726e-08) (596, 1.01726e-08) (597, -4.65393e-06) (598, 4.5805e-09) (601, 4.5805e-09) (613, 3.97614e-10)
row 598: (582, 5.40086e-10) (594, 1.01726e-08) (597, 4.5805e-09) (598, -4.65393e-06) (599, 1.01726e-08) (602, 4.5805e-09) (614, 3.97614e-10)
row 599: (583, 5.40087e-10) (595, 9.78767e-09) (598, 1.60205e-08) (599, -4.6584e-06) (603, 8.17201e-09) (615, 3.97615e-10)
row 600: (584, 5.40087e-10) (596, 8.17201e-09) (600, -4.65606e-06) (601, 1.60205e-08) (604, 7.44704e-09) (616, 3.97615e-10)
row 601: (585, 5.40086e-10) (597, 4.5805e-09) (600, 1.01726e-08) (601, -4.652e-06) (602, 4.5805e-09) (605, 8.2477e-09) (617, 3.97614e-10)
row 602: (586, 5.40086e-10) (598, 4.5805e-09) (601, 4.5805e-09) (602, -4.652e-06) (603, 1.01726e-08) (606, 8.2477e-09) (618, 3.97614e-10)
row 603: (587, 5.40087e-10) (599, 8.17201e-09) (602, 1.60205e-08) (603, -4.65606e-06) (607, 7.44704e-09) (619, 3.97615e-10)
row 604: (588, 5.40087e-10) (600, 4.47497e-09) (604, -4.6537e-06) (605, 1.01654e-08) (620, 3.97615e-10) (1341, 4.47497e-09) (1345, 1.01654e-08)
row 605: (589, 5.40087e-10) (601, 6.49451e-09) (604, 8.45838e-09) (605, -4.65404e-06) (606, 8.17201e-09) (621, 3.97615e-10) (1852, 6.49451e-09)
row 606: (590, 5.40087e-10) (602, 6.49451e-09) (605, 8.17201e-09) (606, -4.65404e-06) (607, 8.45838e-09) (622, 3.97615e-10) (1853, 6.49451e-09)
row 607: (591, 5.40087e-10) (603, 4.47497e-09) (606, 1.01654e-08) (607, -4.6537e-06) (623, 3.97615e-10) (1854, 1.01654e-08) (2404, 4.47497e-09)
row 608: (592, 3.97618e-10) (608, -4.65952e-06) (609, 1.76445e-08) (612, 1.76445e-08) (624, 3.97618e-10)
row 609: (593, 3.97618e-10) (608, 9.78774e-09) (609, -4.65821e-06) (610, 8.17207e-09) (613, 1.60207e-08) (625, 3.97618e-10)
row 610: (594, 3.97618e-10) (609, 8.17207e-09) (610, -4.65821e-06) (611, 9.78774e-09) (614, 1.60207e-08) (626, 3.97618e-10)
row 611: (595, 3.97618e-10) (610, 1.76445e-08) (611, -4.65952e-06) (615, 1.76445e-08) (627, 3.97618e-10)
row 612: (596, 3.97618e-10) (608, 9.78774e-09) (612, -4.65821e-06) (613, 1.60207e-08) (616, 8.17207e-09) (628, 3.97618e-10)
row 613: (597, 3.97617e-10) (609, 1.01727e-08) (612, 1.01727e-08) (613, -4.65374e-06) (614, 4.58054e-09) (617, 4.58054e-09) (629, 3.97617e-10)
row 614: (598, 3.97617e-10) (610, 1.01727e-08) (613, 4.58054e-09) (614, -4.65374e-06) (615, 1.01727e-08) (618, 4.58054e-09) (630, 3.97617e-10)
row 615: (599, 3.97618e-10) (611, 9.78774e-09) (614, 1.60207e-08) (615, -4.65821e-06) (619, 8.17207e-09) (631, 3.97618e-10)
row 616: (600, 3.97618e-10) (612, 8.17207e-09) (616, -4.65587e-06) (617, 1.60207e-08) (620, 7.4471e-09) (632, 3.97618e-10)
row 617: (601, 3.97617e-10) (613, 4.58054e-09) (616, 1.01727e-08) (617, -4.65181e-06) (618, 4.58054e-09) (621, 8.24776e-09) (633, 3.97617e-10)
row 618: (602, 3.97617e-10) (614, 4.58054e-09) (617, 4.58054e-09) (618, -4.65181e-06) (619, 1.01727e-08) (622, 8.24776e-09) (634, 3.97617e-10)
row 619: (603, 3.97618e-10) (615, 8.17207e-09) (618, 1.60207e-08) (619, -4.65587e-06) (623, 7.4471e-09) (635, 3.97618e-10)
row 620: (604, 3.97618e-10) (616, 4.47501e-09) (620, -4.65351e-06) (621, 1.01655e-08) (636, 3.97618e-10) (1356, 4.47501e-09) (1360, 1.01655e-08)
row 621: (605, 3.97618e-10) (617, 6.49456e-09) (620, 8.45844e-09) (621, -4.65385e-06) (622, 8.17207e-09) (637, 3.97618e-10) (1861, 6.49456e-09)
row 622: (606, 3.97618e-10) (618, 6.49456e-09) (621, 8.17207e-09) (622, -4.65385e-06) (623, 8.45844e-09) (638, 3.97618e-10) (1862, 6.49456e-09)
row 623: (607, 3.97618e-10) (619, 4.47501e-09) (622, 1.01655e-08) (623, -4.65351e-06) (639, 3.97618e-10) (1863, 1.01655e-08) (2416, 4.47501e-09)
row 624: (608, 3.97621e-10) (624, -4.65947e-06) (625, 1.76447e-08) (628, 1.76447e-08) (640, 3.97621e-10)
row 625: (609, 3.97621e-10) (624, 9.78781e-09) (625, -4.65816e-06) (626, 8.17212e-09) (629, 1.60208e-08) (641, 3.97621e-10)
row 626: (610, 3.97621e-10) (625, 8.17212e-09) (626, -4.65816e-06) (627, 9.78781e-09) (630, 1.60208e-08) (642, 3.97621e-10)
row 627: (611, 3.97621e-10) (626, 1.76447e-08) (627, -4.65947e-06) (631, 1.76447e-08) (643, 3.97621e-10)
row 628: (612, 3.97621e-10) (624, 9.78781e-09) (628, -4.65816e-06) (629, 1.60208e-08) (632, 8.17212e-09) (644, 3.97621e-10)
row 629: (613, 3.9762e-10) (625, 1.01728e-08) (628, 1.01728e-08) (629, -4.65369e-06) (630, 4.58057e-09) (633, 4.58057e-09) (645, 3.9762e-10)
row 630: (614, 3.9762e-10) (626, 1.01728e-08) (629, 4.58057e-09) (630, -4.65369e-06) (631, 1.01728e-08) (634, 4.58057e-09) (646, 3.9762e-10)
row 631: (615, 3.97621e-10) (627, 9.78781e-09) (630, 1.60208e-08) (631, -4.65816e-06) (635, 8.17212e-09) (647, 3.97621e-10)
row 632: (616, 3.97621e-10) (628, 8.17212e-09) (632, -4.65582e-06) (633, 1.60208e-08) (636, 7.44715e-09) (648, 3.97621e-10)
row 633: (617, 3.9762e-10) (629, 4.58057e-09) (632, 1.01728e-08) (633, -4.65176e-06) (634, 4.58057e-09) (637, 8.24782e-09) (649, 3.9762e-10)
row 634: (618, 3.9762e-10) (630, 4.58057e-09) (633, 4.58057e-09) (634, -4.65176e-06) (635, 1.01728e-08) (638, 8.24782e-09) (650, 3.9762e-10)
row 635: (619, 3.97621e-10) (631, 8.17212e-09) (634, 1.60208e-08) (635, -4.65582e-06) (639, 7.44715e-09) (651, 3.97621e-10)
row 636: (620, 3.97621e-10) (632, 4.47504e-09) (636, -4.65346e-06) (637, 1.01655e-08) (652, 3.97621e-10) (1371, 4.47504e-09) (1375, 1.01655e-08)
row 637: (621, 3.97621e-10) (633, 6.49461e-09) (636, 8.45851e-09) (637, -4.6538e-06) (638, 8.17212e-09) (653, 3.97621e-10) (1870, 6.49461e-09)
row 638: (622, 3.97621e-10) (634, 6.49461e-09) (637, 8.17212e-09) (638, -4.6538e-06) (639, 8.45851e-09) (654, 3.97621e-10) (1871, 6.49461e-09)
row 639: (623, 3.97621e-10) (635, 4.47504e-09) (638, 1.01655e-08) (639, -4.65346e-06) (655, 3.97621e-10) (1872, 1.01655e-08) (2428, 4.47504e-09)
row 640: (624, 3.97624e-10) (640, -4.65942e-06) (641, 1.76448e-08) (644, 1.76448e-08) (656, 3.97624e-10)
row 641: (625, 3.97624e-10) (640, 9.78788e-09) (641, -4.65812e-06) (642, 8.17218e-09) (645, 1.60209e-08) (657, 3.97624e-10)
row 642: (626, 3.97624e-10) (641, 8.17218e-09) (642, -4.65812e-06) (643, 9.78788e-09) (646, 1.60209e-08) (658, 3.97624e-10)
row 643: (627, 3.97624e-10) (642, 1.76448e-08) (643, -4.65942e-06) (647, 1.76448e-08) (659, 3.97624e-10)
row 644: (628, 3.97624e-10) (640, 9.78788e-09) (644, -4.65812e-06) (645, 1.60209e-08) (648, 8.17218e-09) (660, 3.97624e-10)
row 645: (629, 3.97623e-10) (641, 1.01729e-08) (644, 1.01729e-08) (645, -4.65364e-06) (646, 4.5806e-09) (649, 4.5806e-09) (661, 3.97623e-10)
row 646: (630, 3.97623e-10) (642, 1.01729e-08) (645, 4.5806e-09) (646, -4.65364e-06) (647, 1.01729e-08) (650, 4.5806e-09) (662, 3.97623e-10)
row 647: (631, 3.97624e-10) (643, 9.78788e-09) (646, 1.60209e-08) (647, -4.65812e-06) (651, 8.17218e-09) (663, 3.97624e-10)
row 648: (632, 3.97624e-10) (644, 8.17218e-09) (648, -4.65578e-06) (649, 1.60209e-08) (652, 7.44721e-09) (664, 3.97624e-10)
row 649: (633, 3.97623e-10) (645, 4.5806e-09) (648, 1.01729e-08) (649, -4.65172e-06) (650, 4.5806e-09) (653, 8.24788e-09) (665, 3.97623e-10)
row 650: (634, 3.97623e-10) (646, 4.5806e-09) (649, 4.5806e-09) (650, -4.65172e-06) (651, 1.01729e-08) (654, 8.24788e-09) (666, 3.97623e-10)
row 651: (635, 3.97624e-10) (647, 8.17218e-09) (650, 1.60209e-08) (651, -4.65578e-06) (655, 7.44721e-09) (667, 3.97624e-10)
row 652: (636, 3.97624e-10) (648, 4.47507e-09) (652, -4.65342e-06) (653, 1.01656e-08) (668, 3.97624e-10) (1386, 4.47507e-09) (1390, 1.01656e-08)
row 653: (637, 3.97624e-10) (649, 6.49465e-09) (652, 8.45857e-09) (653, -4.65376e-06) (654, 8.17218e-09) (669, 3.97624e-10) (1879, 6.49465e-09)
row 654: (638, 3.97624e-10) (650, 6.49465e-09) (653, 8.17218e-09) (654, -4.65376e-06) (655, 8.45857e-09) (670, 3.97624e-10) (1880, 6.49465e-09)
row 655: (639, 3.97624e-10) (651, 4.47507e-09) (654, 1.01656e-08) (655, -4.65342e-06) (671, 3.97624e-10) (1881, 1.01656e-08) (2440, 4.47507e-09)
row 656: (640, 3.97627e-10) (656, -4.65938e-06) (657, 1.76449e-08) (660, 1.76449e-08) (672, 3.97627e-10)
row 657: (641, 3.97627e-10) (656, 9.78796e-09) (657, -4.65807e-06) (658, 8.17224e-09) (661, 1.6021e-08) (673, 3.97627e-10)
row 658: (642, 3.97627e-10) (657, 8.17224e-09) (658, -4.65807e-06) (659, 9.78796e-09) (662, 1.6021e-08) (674, 3.97627e-10)
row 659: (643, 3.97627e-10) (658, 1.76449e-08) (659, -4.65938e-06) (663, 1.76449e-08) (675, 3.97627e-10)
row 660: (644, 3.97627e-10) (656, 9.78796e-09) (660, -4.65807e-06) (661, 1.6021e-08) (664, 8.17224e-09) (676, 3.97627e-10)
row 661: (645, 3.97626e-10) (657, 1.01729e-08) (660, 1.01729e-08) (661, -4.65359e-06) (662, 4.58064e-09) (665, 4.58064e-09) (677, 3.97626e-10)
row 662: (646, 3.97626e-10) (658, 1.01729e-08) (661, 4.58064e-09) (662, -4.65359e-06) (663, 1.01729e-08) (666, 4.58064e-09) (678, 3.97626e-10)
row 663: (647, 3.97627e-10) (659, 9.78796e-09) (662, 1.6021e-08) (663, -4.65807e-06) (667, 8.17224e-09) (679, 3.97627e-10)
row 664: (648, 3.97627e-10) (660, 8.17224e-09) (664, -4.65573e-06) (665, 1.6021e-08) (668, 7.44726e-09) (680, 3.97627e-10)
row 665: (649, 3.97626e-10) (661, 4.58064e-09) (664, 1.01729e-08) (665, -4.65167e-06) (666, 4.58064e-09) (669, 8.24794e-09) (681, 3.97626e-10)
row 666: (650, 3.97626e-10) (662, 4.58064e-09) (665, 4.58064e-09) (666, -4.65167e-06) (667, 1.01729e-08) (670, 8.24794e-09) (682, 3.97626e-10)
row 667: (651, 3.97627e-10) (663, 8.17224e-09) (666, 1.6021e-08) (667, -4.65573e-06) (671, 7.44726e-09) (683, 3.97627e-10)
row 668: (652, 3.97627e-10) (664, 4.4751e-09) (668, -4.65337e-06) (669, 1.01657e-08) (684, 3.97627e-10) (1401, 4.4751e-09) (1405, 1.01657e-08)
row 669: (653, 3.97627e-10) (665, 6.4947e-09) (668, 8.45863e-09) (669, -4.65371e-06) (670, 8.17224e-09) (685, 3.97627e-10) (1888, 6.4947e-09)
row 670: (654, 3.97627e-10) (666, 6.4947e-09) (669, 8.17224e-09) (670, -4.65371e-06) (671, 8.45863e-09) (686, 3.97627e-10) (1889, 6.4947e-09)
row 671: (655, 3.97627e-10) (667, 4.4751e-09) (670, 1.01657e-08) (671, -4.65337e-06) (687, 3.97627e-10) (1890, 1.01657e-08) (2452, 4.4751e-09)
row 672: (656, 3.9763e-10) (672, -4.65947e-06) (673, 1.7645e-08) (676, 1.7645e-08) (688, 5.4007e-10)
row 673: (657, 3.9763e-10) (672, 9.78803e-09) (673, -4.65816e-06) (674, 8.1723e-09) (677, 1.60211e-08) (689, 5.4007e-10)
row 674: (658, 3.9763e-10) (673, 8.1723e-09) (674, -4.65816e-06) (675, 9.78803e-09) (678, 1.60211e-08) (690, 5.4007e-10)
row 675: (659, 3.9763e-10) (674, 1.7645e-08) (675, -4.65947e-06) (679, 1.7645e-08) (691, 5.4007e-10)
row 676: (660, 3.9763e-10) (672, 9.78803e-09) (676, -4.65816e-06) (677, 1.60211e-08) (680, 8.1723e-09) (692, 5.4007e-10)
row 677: (661, 3.97629e-10) (673, 1.0173e-08) (676, 1.0173e-08) (677, -4.65369e-06) (678, 4.58067e-09) (681, 4.58067e-09) (693, 5.40069e-10)
row 678: (662, 3.97629e-10) (674, 1.0173e-08) (677, 4.58067e-09) (678, -4.65369e-06) (679, 1.0173e-08) (682, 4.58067e-09) (694, 5.40069e-10)
row 679: (663, 3.9763e-10) (675, 9.78803e-09) (678, 1.60211e-08) (679, -4.65816e-06) (683, 8.1723e-09) (695, 5.4007e-10)
row 680: (664, 3.9763e-10) (676, 8.1723e-09) (680, -4.65582e-06) (681, 1.60211e-08) (684, 7.44731e-09) (696, 5.4007e-10)
row 681: (665, 3.97629e-10) (677, 4.58067e-09) (680, 1.0173e-08) (681, -4.65176e-06) (682, 4.58067e-09) (685, 8.248e-09) (697, 5.40069e-10)
row 682: (666, 3.97629e-10) (678, 4.58067e-09) (681, 4.58067e-09) (682, -4.65176e-06) (683, 1.0173e-08) (686, 8.248e-09) (698, 5.40069e-10)
row 683: (667, 3.9763e-10) (679, 8.1723e-09) (682, 1.60211e-08) (683, -4.65582e-06) (687, 7.44731e-09) (699, 5.4007e-10)
row 684: (668, 3.9763e-10) (680, 4.47514e-09) (684, -4.65346e-06) (685, 1.01658e-08) (700, 5.4007e-10) (1416, 4.47514e-09) (1420, 1.01658e-08)
row 685: (669, 3.9763e-10) (681, 6.49475e-09) (684, 8.45869e-09) (685, -4.6538e-06) (686, 8.1723e-09) (701, 5.4007e-10) (1897, 6.49475e-09)
row 686: (670, 3.9763e-10) (682, 6.49475e-09) (685, 8.1723e-09) (686, -4.6538e-06) (687, 8.45869e-09) (702, 5.4007e-10) (1898, 6.49475e-09)
row 687: (671, 3.9763e-10) (683, 4.47514e-09) (686, 1.01658e-08) (687, -4.65346e-06) (703, 5.4007e-10) (1899, 1.01658e-08) (2464, 4.47514e-09)
row 688: (672, 1.14323e-09) (688, -4.6608e-06) (689, 1.76451e-08) (692, 1.76451e-08) (704, 1.15732e-09)
row 689: (673, 1.14322e-09) (688, 9.78808e-09) (689, -4.65949e-06) (690, 8.17235e-09) (693, 1.60212e-08) (705, 1.15732e-09)
row 690: (674, 1.14322e-09) (689, 8.17235e-09) (690, -4.65949e-06) (691, 9.78808e-09) (694, 1.60212e-08) (706, 1.15732e-09)
row 691: (675, 1.14323e-09) (690, 1.76451e-08) (691, -4.6608e-06) (695, 1.76451e-08) (707, 1.15732e-09)
row 692: (676, 1.14322e-09) (688, 9.78808e-09) (692, -4.65949e-06) (693, 1.60212e-08) (696, 8.17235e-09) (708, 1.15732e-09)
row 693: (677, 1.14322e-09) (689, 1.01731e-08) (692, 1.01731e-08) (693, -4.65502e-06) (694, 4.58069e-09) (697, 4.58069e-09) (709, 1.15731e-09)
row 694: (678, 1.14322e-09) (690, 1.01731e-08) (693, 4.58069e-09) (694, -4.65502e-06) (695, 1.01731e-08) (698, 4.58069e-09) (710, 1.15731e-09)
row 695: (679, 1.14322e-09) (691, 9.78808e-09) (694, 1.60212e-08) (695, -4.65949e-06) (699, 8.17235e-09) (711, 1.15732e-09)
row 696: (680, 1.14322e-09) (692, 8.17235e-09) (696, -4.65715e-06) (697, 1.60212e-08) (700, 7.44735e-09) (712, 1.15732e-09)
row 697: (681, 1.14322e-09) (693, 4.58069e-09) (696, 1.01731e-08) (697, -4.65309e-06) (698, 4.58069e-09) (701, 8.24805e-09) (713, 1.15731e-09)
row 698: (682, 1.14322e-09) (694, 4.58069e-09) (697, 4.58069e-09) (698, -4.65309e-06) (699, 1.01731e-08) (702, 8.24805e-09) (714, 1.15731e-09)
row 699: (683, 1.14322e-09) (695, 8.17235e-09) (698, 1.60212e-08) (699, -4.65715e-06) (703, 7.44735e-09) (715, 1.15732e-09)
row 700: (684, 1.14323e-09) (696, 4.47516e-09) (700, -4.65479e-06) (701, 1.01658e-08) (716, 1.15732e-09) (1431, 4.47516e-09) (1435, 1.01658e-08)
row 701: (685, 1.14322e-09) (697, 6.49478e-09) (700, 8.45874e-09) (701, -4.65513e-06) (702, 8.17235e-09) (717, 1.15732e-09) (1906, 6.49478e-09)
row 702: (686, 1.14322e-09) (698, 6.49478e-09) (701, 8.17235e-09) (702, -4.65513e-06) (703, 8.45874e-09) (718, 1.15732e-09) (1907, 6.49478e-09)
row 703: (687, 1.14323e-09) (699, 4.47516e-09) (702, 1.01658e-08) (703, -4.65479e-06) (719, 1.15732e-09) (1908, 1.01658e-08) (2476, 4.47516e-09)
row 704: (688, 5.56659e-10) (704, -4.65943e-06) (705, 1.76452e-08) (708, 1.76452e-08) (720, 4.12202e-10)
row 705: (689, 5.56658e-10) (704, 9.78813e-09) (705, -4.65812e-06) (706, 8.17239e-09) (709, 1.60213e-08) (721, 4.12202e-10)
row 706: (690, 5.56658e-10) (705, 8.17239e-09) (706, -4.65812e-06) (707, 9.78813e-09) (710, 1.60213e-08) (722, 4.12202e-10)
row 707: (691, 5.56659e-10) (706, 1.76452e-08) (707, -4.65943e-06) (711, 1.76452e-08) (723, 4.12202e-10)
row 708: (692, 5.56658e-10) (704, 9.78813e-09) (708, -4.65812e-06) (709, 1.60213e-08) (712, 8.17239e-09) (724, 4.12202e-10)
row 709: (693, 5.56657e-10) (705, 1.01731e-08) (708, 1.01731e-08) (709, -4.65365e-06) (710, 4.58072e-09) (713, 4.58072e-09) (725, 4.12201e-10)
row 710: (694, 5.56657e-10) (706, 1.01731e-08) (709, 4.58072e-09) (710, -4.65365e-06) (711, 1.01731e-08) (714, 4.58072e-09) (726, 4.12201e-10)
row 711: (695, 5.56658e-10) (707, 9.78813e-09) (710, 1.60213e-08) (711, -4.65812e-06) (715, 8.17239e-09) (727, 4.12202e-10)
row 712: (696, 5.56658e-10) (708, 8.17239e-09) (712, -4.65578e-06) (713, 1.60213e-08) (716, 7.44739e-09) (728, 4.12202e-10)
row 713: (697, 5.56657e-10) (709, 4.58072e-09) (712, 1.01731e-08) (713, -4.65173e-06) (714, 4.58072e-09) (717, 8.24809e-09) (729, 4.12201e-10)
row 714: (698, 5.56657e-10) (710, 4.58072e-09) (713, 4.58072e-09) (714, -4.65173e-06) (715, 1.01731e-08) (718, 8.24809e-09) (730, 4.12201e-10)
row 715: (699, 5.56658e-10) (711, 8.17239e-09) (714, 1.60213e-08) (715, -4.65578e-06) (719, 7.44739e-09) (731, 4.12202e-10)
row 716: (700, 5.56659e-10) (712, 4.47518e-09) (716, -4.65342e-06) (717, 1.01659e-08) (732, 4.12202e-10) (1446, 4.47518e-09) (1450, 1.01659e-08)
row 717: (701, 5.56658e-10) (713, 6.49482e-09) (716, 8.45878e-09) (717, -4.65376e-06) (718, 8.17239e-09) (733, 4.12202e-10) (1915, 6.49482e-09)
row 718: (702, 5.56658e-10) (714, 6.49482e-09) (717, 8.17239e-09) (718, -4.65376e-06) (719, 8.45878e-09) (734, 4.12202e-10) (1916, 6.49482e-09)
row 719: (703, 5.56659e-10) (715, 4.47518e-09) (718, 1.01659e-08) (719, -4.65342e-06) (735, 4.12202e-10) (1917, 1.01659e-08) (2488, 4.47518e-09)
row 720: (704, 4.12205e-10) (720, -4.65924e-06) (721, 1.76454e-08) (724, 1.76454e-08) (736, 4.12205e-10)
row 721: (705, 4.12205e-10) (720, 9.7882e-09) (721, -4.65793e-06) (722, 8.17245e-09) (725, 1.60214e-08) (737, 4.12205e-10)
row 722: (706, 4.12205e-10) (721, 8.17245e-09) (722, -4.65793e-06) (723, 9.7882e-09) (726, 1.60214e-08) (738, 4.12205e-10)
row 723: (707, 4.12205e-10) (722, 1.76454e-08) (723, -4.65924e-06) (727, 1.76454e-08) (739, 4.12205e-10)
row 724: (708, 4.12205e-10) (720, 9.7882e-09) (724, -4.65793e-06) (725, 1.60214e-08) (728, 8.17245e-09) (740, 4.12205e-10)
row 725: (709, 4.12204e-10) (721, 1.01732e-08) (724, 1.01732e-08) (725, -4.65346e-06) (726, 4.58075e-09) (729, 4.58075e-09) (741, 4.12204e-10)
row 726: (710, 4.12204e-10) (722, 1.01732e-08) (725, 4.58075e-09) (726, -4.65346e-06) (727, 1.01732e-08) (730, 4.58075e-09) (742, 4.12204e-10)
row 727: (711, 4.12205e-10) (723, 9.7882e-09) (726, 1.60214e-08) (727, -4.65793e-06) (731, 8.17245e-09) (743, 4.12205e-10)
row 728: (712, 4.12205e-10) (724, 8.17245e-09) (728, -4.65559e-06) (729, 1.60214e-08) (732, 7.44745e-09) (744, 4.12205e-10)
row 729: (713, 4.12204e-10) (725, 4.58075e-09) (728, 1.01732e-08) (729, -4.65153e-06) (730, 4.58075e-09) (733, 8.24815e-09) (745, 4.12204e-10)
row 730: (714, 4.12204e-10) (726, 4.58075e-09) (729, 4.58075e-09) (730, -4.65153e-06) (731, 1.01732e-08) (734, 8.24815e-09) (746, 4.12204e-10)
row 731: (715, 4.12205e-10) (727, 8.17245e-09) (730, 1.60214e-08) (731, -4.65559e-06) (735, 7.44745e-09) (747, 4.12205e-10)
row 732: (716, 4.12205e-10) (728, 4.47522e-09) (732, -4.65323e-06) (733, 1.01659e-08) (748, 4.12205e-10) (1461, 4.47522e-09) (1465, 1.01659e-08)
row 733: (717, 4.12205e-10) (729, 6.49486e-09) (732, 8.45884e-09) (733, -4.65357e-06) (734, 8.17245e-09) (749, 4.12205e-10) (1924, 6.49486e-09)
row 734: (718, 4.12205e-10) (730, 6.49486e-09) (733, 8.17245e-09) (734, -4.65357e-06) (735, 8.45884e-09) (750, 4.12205e-10) (1925, 6.49486e-09)
row 735: (719, 4.12205e-10) (731, 4.47522e-09) (734, 1.01659e-08) (735, -4.65323e-06) (751, 4.12205e-10) (1926, 1.01659e-08) (2500, 4.47522e-09)
row 736: (720, 4.12208e-10) (736, -4.6592e-06) (737, 1.76455e-08) (740, 1.76455e-08) (752, 4.12208e-10)
row 737: (721, 4.12208e-10) (736, 9.78827e-09) (737, -4.65789e-06) (738, 8.17251e-09) (741, 1.60215e-08) (753, 4.12208e-10)
row 738: (722, 4.12208e-10) (737, 8.17251e-09) (738, -4.65789e-06) (739, 9.78827e-09) (742, 1.60215e-08) (754, 4.12208e-10)
row 739: (723, 4.12208e-10) (738, 1.76455e-08) (739, -4.6592e-06) (743, 1.76455e-08) (755, 4.12208e-10)
row 740: (724, 4.12208e-10) (736, 9.78827e-09) (740, -4.65789e-06) (741, 1.60215e-08) (744, 8.17251e-09) (756, 4.12208e-10)
row 741: (725, 4.12207e-10) (737, 1.01733e-08) (740, 1.01733e-08) (741, -4.65341e-06) (742, 4.58078e-09) (745, 4.58078e-09) (757, 4.12207e-10)
row 742: (726, 4.12207e-10) (738, 1.01733e-08) (741, 4.58078e-09) (742, -4.65341e-06) (743, 1.01733e-08) (746, 4.58078e-09) (758, 4.12207e-10)
row 743: (727, 4.12208e-10) (739, 9.78827e-09) (742, 1.60215e-08) (743, -4.65789e-06) (747, 8.17251e-09) (759, 4.12208e-10)
row 744: (728, 4.12208e-10) (740, 8.17251e-09) (744, -4.65555e-06) (745, 1.60215e-08) (748, 7.4475e-09) (760, 4.12208e-10)
row 745: (729, 4.12207e-10) (741, 4.58078e-09) (744, 1.01733e-08) (745, -4.65149e-06) (746, 4.58078e-09) (749, 8.24821e-09) (761, 4.12207e-10)
row 746: (730, 4.12207e-10) (742, 4.58078e-09) (745, 4.58078e-09) (746, -4.65149e-06) (747, 1.01733e-08) (750, 8.24821e-09) (762, 4.12207e-10)
row 747: (731, 4.12208e-10) (743, 8.17251e-09) (746, 1.60215e-08) (747, -4.65555e-06) (751, 7.4475e-09) (763, 4.12208e-10)
row 748: (732, 4.12208e-10) (744, 4.47525e-09) (748, -4.65319e-06) (749, 1.0166e-08) (764, 4.12208e-10) (1476, 4.47525e-09) (1480, 1.0166e-08)
row 749: (733, 4.12208e-10) (745, 6.49491e-09) (748, 8.4589e-09) (749, -4.65353e-06) (750, 8.17251e-09) (765, 4.12208e-10) (1933, 6.49491e-09)
row 750: (734, 4.12208e-10) (746, 6.49491e-09) (749, 8.17251e-09) (750, -4.65353e-06) (751, 8.4589e-09) (766, 4.12208e-10) (1934, 6.49491e-09)
row 751: (735, 4.12208e-10) (747, 4.47525e-09) (750, 1.0166e-08) (751, -4.65319e-06) (767, 4.12208e-10) (1935, 1.0166e-08) (2512, 4.47525e-09)
row 752: (736, 4.12211e-10) (752, -4.65915e-06) (753, 1.76456e-08) (756, 1.76456e-08) (768, 4.12211e-10)
row 753: (737, 4.12211e-10) (752, 9.78834e-09) (753, -4.65784e-06) (754, 8.17257e-09) (757, 1.60216e-08) (769, 4.12211e-10)
row 754: (738, 4.12211e-10) (753, 8.17257e-09) (754, -4.65784e-06) (755, 9.78834e-09) (758, 1.60216e-08) (770, 4.12211e-10)
row 755: (739, 4.12211e-10) (754, 1.76456e-08) (755, -4.65915e-06) (759, 1.76456e-08) (771, 4.12211e-10)
row 756: (740, 4.12211e-10) (752, 9.78834e-09) (756, -4.65784e-06) (757, 1.60216e-08) (760, 8.17257e-09) (772, 4.12211e-10)
row 757: (741, 4.1221e-10) (753, 1.01733e-08) (756, 1.01733e-08) (757, -4.65337e-06) (758, 4.58082e-09) (761, 4.58082e-09) (773, 4.1221e-10)
row 758: (742, 4.1221e-10) (754, 1.01733e-08) (757, 4.58082e-09) (758, -4.65337e-06) (759, 1.01733e-08) (762, 4.58082e-09) (774, 4.1221e-10)
row 759: (743, 4.12211e-10) (755, 9.78834e-09) (758, 1.60216e-08) (759, -4.65784e-06) (763, 8.17257e-09) (775, 4.12211e-10)
row 760: (744, 4.12211e-10) (756, 8.17257e-09) (760, -4.6555e-06) (761, 1.60216e-08) (764, 7.44755e-09) (776, 4.12211e-10)
row 761: (745, 4.1221e-10) (757, 4.58082e-09) (760, 1.01733e-08) (761, -4.65144e-06) (762, 4.58082e-09) (765, 8.24827e-09) (777, 4.1221e-10)
row 762: (746, 4.1221e-10) (758, 4.58082e-09) (761, 4.58082e-09) (762, -4.65144e-06) (763, 1.01733e-08) (766, 8.24827e-09) (778, 4.1221e-10)
row 763: (747, 4.12211e-10) (759, 8.17257e-09) (762, 1.60216e-08) (763, -4.6555e-06) (767, 7.44755e-09) (779, 4.12211e-10)
row 764: (748, 4.12211e-10) (760, 4.47528e-09) (764, -4.65314e-06) (765, 1.01661e-08) (780, 4.12211e-10) (1491, 4.47528e-09) (1495, 1.01661e-08)
row 765: (749, 4.12211e-10) (761, 6.49496e-09) (764, 8.45896e-09) (765, -4.65348e-06) (766, 8.17257e-09) (781, 4.12211e-10) (1942, 6.49496e-09)
row 766: (750, 4.12211e-10) (762, 6.49496e-09) (765, 8.17257e-09) (766, -4.65348e-06) (767, 8.45896e-09) (782, 4.12211e-10) (1943, 6.49496e-09)
row 767: (751, 4.12211e-10) (763, 4.47528e-09) (766, 1.01661e-08) (767, -4.65314e-06) (783, 4.12211e-10) (1944, 1.01661e-08) (2524, 4.47528e-09)
row 768: (752, 4.12214e-10) (768, -4.6591e-06) (769, 1.76457e-08) (772, 1.76457e-08)
row 769: (753, 4.12214e-10) (768, 9.78841e-09) (769, -4.65779e-06) (770, 8.17263e-09) (773, 1.60218e-08)
row 770: (754, 4.12214e-10) (769, 8.17263e-09) (770, -4.65779e-06) (771, 9.78841e-09) (774, 1.60218e-08)
row 771: (755, 4.12214e-10) (770, 1.76457e-08) (771, -4.6591e-06) (775, 1.76457e-08)
row 772: (756, 4.12214e-10) (768, 9.78841e-09) (772, -4.65779e-06) (773, 1.60218e-08) (776, 8.17263e-09)
row 773: (757, 4.12213e-10) (769, 1.01734e-08) (772, 1.01734e-08) (773, -4.65332e-06) (774, 4.58085e-09) (777, 4.58085e-09)
row 774: (758, 4.12213e-10) (770, 1.01734e-08) (773, 4.58085e-09) (774, -4.65332e-06) (775, 1.01734e-08) (778, 4.58085e-09)
row 775: (759, 4.12214e-10) (771, 9.78841e-09) (774, 1.60218e-08) (775, -4.65779e-06) (779, 8.17263e-09)
row 776: (760, 4.12214e-10) (772, 8.17263e-09) (776, -4.65545e-06) (777, 1.60218e-08) (780, 7.44761e-09)
row 777: (761, 4.12213e-10) (773, 4.58085e-09) (776, 1.01734e-08) (777, -4.65139e-06) (778, 4.58085e-09) (781, 8.24833e-09)
row 778: (762, 4.12213e-10) (774, 4.58085e-09) (777, 4.58085e-09) (778, -4.65139e-06) (779, 1.01734e-08) (782, 8.24833e-09)
row 779: (763, 4.12214e-10) (775, 8.17263e-09) (778, 1.60218e-08) (779, -4.65545e-06) (783, 7.44761e-09)
row 780: (764, 4.12214e-10) (776, 4.47531e-09) (780, -4.65309e-06) (781, 1.01662e-08) (1506, 4.47531e-09) (1510, 1.01662e-08)
row 781: (765, 4.12214e-10) (777, 6.495e-09) (780, 8.45902e-09) (781, -4.65343e-06) (782, 8.17263e-09) (1951, 6.495e-09)
row 782: (766, 4.12214e-10) (778, 6.495e-09) (781, 8.17263e-09) (782, -4.65343e-06) (783, 8.45902e-09) (1952, 6.495e-09)
row 783: (767, 4.12214e-10) (779, 4.47531e-09) (782, 1.01662e-08) (783, -4.65309e-06) (1953, 1.01662e-08) (2536, 4.47531e-09)
row 784: (784, -4.66151e-06) (785, 1.764e-08) (787, 1.764e-08) (799, 1.10757e-09)
row 785: (784, 9.78524e-09) (785, -4.6602e-06) (786, 8.16997e-09) (788, 1.60166e-08) (800, 1.10757e-09)
row 786: (12, 7.44519e-09) (785, 8.16997e-09) (786, -4.65786e-06) (789, 1.60166e-08) (801, 1.10757e-09)
row 787: (784, 9.78524e-09) (787, -4.6602e-06) (788, 1.60166e-08) (791, 8.16997e-09) (802, 1.10757e-09)
row 788: (785, 1.01701e-08) (787, 1.01701e-08) (788, -4.65573e-06) (789, 4.57936e-09) (792, 4.57936e-09) (803, 1.10757e-09)
row 789: (786, 1.01701e-08) (788, 4.57936e-09) (789, -4.65381e-06) (790, 8.24565e-09) (793, 4.57936e-09) (804, 1.10757e-09)
row 790: (12, 8.45628e-09) (789, 6.4929e-09) (790, -4.65584e-06) (794, 8.16997e-09) (805, 1.10757e-09) (1519, 6.4929e-09)
row 791: (787, 8.16997e-09) (791, -4.6602e-06) (792, 1.60166e-08) (795, 9.78524e-09) (806, 1.10757e-09)
row 792: (788, 4.57936e-09) (791, 1.01701e-08) (792, -4.65573e-06) (793, 4.57936e-09) (796, 1.01701e-08) (807, 1.10757e-09)
row 793: (789, 4.57936e-09) (792, 4.57936e-09) (793, -4.65381e-06) (794, 8.24565e-09) (797, 1.01701e-08) (808, 1.10757e-09)
row 794: (790, 8.16997e-09) (793, 6.4929e-09) (794, -4.65584e-06) (798, 8.45628e-09) (809, 1.10757e-09) (1522, 6.4929e-09)
row 795: (791, 1.764e-08) (795, -4.66151e-06) (796, 1.764e-08) (810, 1.10757e-09)
row 796: (792, 1.60166e-08) (795, 9.78524e-09) (796, -4.6602e-06) (797, 8.16997e-09) (811, 1.10757e-09)
row 797: (793, 1.60166e-08) (796, 8.16997e-09) (797, -4.65786e-06) (798, 7.44519e-09) (812, 1.10757e-09)
row 798: (794, 1.01629e-08) (797, 4.47386e-09) (798, -4.65551e-06) (813, 1.10757e-09) (1525, 1.01629e-08) (2548, 4.47386e-09)
row 799: (784, 5.21484e-10) (799, -4.66127e-06) (800, 1.76401e-08) (802, 1.76401e-08) (814, 3.83508e-10)
row 800: (785, 5.21484e-10) (799, 9.78529e-09) (800, -4.65997e-06) (801, 8.17002e-09) (803, 1.60167e-08) (815, 3.83508e-10)
row 801: (28, 7.44523e-09) (786, 5.21484e-10) (800, 8.17002e-09) (801, -4.65763e-06) (804, 1.60167e-08) (816, 3.83508e-10)
row 802: (787, 5.21484e-10) (799, 9.78529e-09) (802, -4.65997e-06) (803, 1.60167e-08) (806, 8.17002e-09) (817, 3.83508e-10)
row 803: (788, 5.21483e-10) (800, 1.01702e-08) (802, 1.01702e-08) (803, -4.65549e-06) (804, 4.57939e-09) (807, 4.57939e-09) (818, 3.83507e-10)
row 804: (789, 5.21483e-10) (801, 1.01702e-08) (803, 4.57939e-09) (804, -4.65357e-06) (805, 8.2457e-09) (808, 4.57939e-09) (819, 3.83507e-10)
row 805: (28, 8.45633e-09) (790, 5.21484e-10) (804, 6.49293e-09) (805, -4.65561e-06) (809, 8.17002e-09) (820, 3.83508e-10) (1528, 6.49293e-09)
row 806: (791, 5.21484e-10) (802, 8.17002e-09) (806, -4.65997e-06) (807, 1.60167e-08) (810, 9.78529e-09) (821, 3.83508e-10)
row 807: (792, 5.21483e-10) (803, 4.57939e-09) (806, 1.01702e-08) (807, -4.65549e-06) (808, 4.57939e-09) (811, 1.01702e-08) (822, 3.83507e-10)
row 808: (793, 5.21483e-10) (804, 4.57939e-09) (807, 4.57939e-09) (808, -4.65357e-06) (809, 8.2457e-09) (812, 1.01702e-08) (823, 3.83507e-10)
row 809: (794, 5.21484e-10) (805, 8.17002e-09) (808, 6.49293e-09) (809, -4.65561e-06) (813, 8.45633e-09) (824, 3.83508e-10) (1531, 6.49293e-09)
row 810: (795, 5.21484e-10) (806, 1.76401e-08) (810, -4.66127e-06) (811, 1.76401e-08) (825, 3.83508e-10)
row 811: (796, 5.21484e-10) (807, 1.60167e-08) (810, 9.78529e-09) (811, -4.65997e-06) (812, 8.17002e-09) (826, 3.83508e-10)
row 812: (797, 5.21484e-10) (808, 1.60167e-08) (811, 8.17002e-09) (812, -4.65763e-06) (813, 7.44523e-09) (827, 3.83508e-10)
row 813: (798, 5.21484e-10) (809, 1.01629e-08) (812, 4.47389e-09) (813, -4.65527e-06) (828, 3.83508e-10) (1534, 1.01629e-08) (2560, 4.47389e-09)
row 814: (799, 3.83511e-10) (814, -4.66109e-06) (815, 1.76402e-08) (817, 1.76402e-08) (829, 3.83511e-10)
row 815: (800, 3.8351e-10) (814, 9.78536e-09) (815, -4.65978e-06) (816, 8.17008e-09) (818, 1.60168e-08) (830, 3.8351e-10)
row 816: (44, 7.44529e-09) (801, 3.8351e-10) (815, 8.17008e-09) (816, -4.65744e-06) (819, 1.60168e-08) (831, 3.8351e-10)
row 817: (802, 3.8351e-10) (814, 9.78536e-09) (817, -4.65978e-06) (818, 1.60168e-08) (821, 8.17008e-09) (832, 3.8351e-10)
row 818: (803, 3.8351e-10) (815, 1.01702e-08) (817, 1.01702e-08) (818, -4.65531e-06) (819, 4.57942e-09) (822, 4.57942e-09) (833, 3.8351e-10)
row 819: (804, 3.8351e-10) (816, 1.01702e-08) (818, 4.57942e-09) (819, -4.65338e-06) (820, 8.24576e-09) (823, 4.57942e-09) (834, 3.8351e-10)
row 820: (44, 8.45639e-09) (805, 3.8351e-10) (819, 6.49298e-09) (820, -4.65542e-06) (824, 8.17008e-09) (835, 3.8351e-10) (1537, 6.49298e-09)
row 821: (806, 3.8351e-10) (817, 8.17008e-09) (821, -4.65978e-06) (822, 1.60168e-08) (825, 9.78536e-09) (836, 3.8351e-10)
row 822: (807, 3.8351e-10) (818, 4.57942e-09) (821, 1.01702e-08) (822, -4.65531e-06) (823, 4.57942e-09) (826, 1.01702e-08) (837, 3.8351e-10)
row 823: (808, 3.8351e-10) (819, 4.57942e-09) (822, 4.57942e-09) (823, -4.65338e-06) (824, 8.24576e-09) (827, 1.01702e-08) (838, 3.8351e-10)
row 824: (809, 3.8351e-10) (820, 8.17008e-09) (823, 6.49298e-09) (824, -4.65542e-06) (828, 8.45639e-09) (839, 3.8351e-10) (1540, 6.49298e-09)
row 825: (810, 3.83511e-10) (821, 1.76402e-08) (825, -4.66109e-06) (826, 1.76402e-08) (840, 3.83511e-10)
row 826: (811, 3.8351e-10) (822, 1.60168e-08) (825, 9.78536e-09) (826, -4.65978e-06) (827, 8.17008e-09) (841, 3.8351e-10)
row 827: (812, 3.8351e-10) (823, 1.60168e-08) (826, 8.17008e-09) (827, -4.65744e-06) (828, 7.44529e-09) (842, 3.8351e-10)
row 828: (813, 3.83511e-10) (824, 1.0163e-08) (827, 4.47392e-09) (828, -4.65508e-06) (843, 3.83511e-10) (1543, 1.0163e-08) (2572, 4.47392e-09)
row 829: (814, 3.83514e-10) (829, -4.66104e-06) (830, 1.76404e-08) (832, 1.76404e-08) (844, 3.8349e-10)
row 830: (815, 3.83513e-10) (829, 9.78543e-09) (830, -4.65973e-06) (831, 8.17014e-09) (833, 1.60169e-08) (845, 3.8349e-10)
row 831: (60, 7.44534e-09) (816, 3.83513e-10) (830, 8.17014e-09) (831, -4.65739e-06) (834, 1.60169e-08) (846, 3.8349e-10)
row 832: (817, 3.83513e-10) (829, 9.78543e-09) (832, -4.65973e-06) (833, 1.60169e-08) (836, 8.17014e-09) (847, 3.8349e-10)
row 833: (818, 3.83512e-10) (830, 1.01703e-08) (832, 1.01703e-08) (833, -4.65526e-06) (834, 4.57946e-09) (837, 4.57946e-09) (848, 3.83489e-10)
row 834: (819, 3.83512e-10) (831, 1.01703e-08) (833, 4.57946e-09) (834, -4.65333e-06) (835, 8.24582e-09) (838, 4.57946e-09) (849, 3.83489e-10)
row 835: (60, 8.45645e-09) (820, 3.83513e-10) (834, 6.49303e-09) (835, -4.65537e-06) (839, 8.17014e-09) (850, 3.8349e-10) (1546, 6.49303e-09)
row 836: (821, 3.83513e-10) (832, 8.17014e-09) (836, -4.65973e-06) (837, 1.60169e-08) (840, 9.78543e-09) (851, 3.8349e-10)
row 837: (822, 3.83512e-10) (833, 4.57946e-09) (836, 1.01703e-08) (837, -4.65526e-06) (838, 4.57946e-09) (841, 1.01703e-08) (852, 3.83489e-10)
row 838: (823, 3.83512e-10) (834, 4.57946e-09) (837, 4.57946e-09) (838, -4.65333e-06) (839, 8.24582e-09) (842, 1.01703e-08) (853, 3.83489e-10)
row 839: (824, 3.83513e-10) (835, 8.17014e-09) (838, 6.49303e-09) (839, -4.65537e-06) (843, 8.45645e-09) (854, 3.8349e-10) (1549, 6.49303e-09)
row 840: (825, 3.83514e-10) (836, 1.76404e-08) (840, -4.66104e-06) (841, 1.76404e-08) (855, 3.8349e-10)
row 841: (826, 3.83513e-10) (837, 1.60169e-08) (840, 9.78543e-09) (841, -4.65973e-06) (842, 8.17014e-09) (856, 3.8349e-10)
row 842: (827, 3.83513e-10) (838, 1.60169e-08) (841, 8.17014e-09) (842, -4.65739e-06) (843, 7.44534e-09) (857, 3.8349e-10)
row 843: (828, 3.83514e-10) (839, 1.01631e-08) (842, 4.47395e-09) (843, -4.65503e-06) (858, 3.8349e-10) (1552, 1.01631e-08) (2584, 4.47395e-09)
row 844: (829, 3.83446e-10) (844, -4.66099e-06) (845, 1.76405e-08) (847, 1.76405e-08) (859, 3.83446e-10)
row 845: (830, 3.83446e-10) (844, 9.78551e-09) (845, -4.65968e-06) (846, 8.1702e-09) (848, 1.6017e-08) (860, 3.83446e-10)
row 846: (76, 7.4454e-09) (831, 3.83446e-10) (845, 8.1702e-09) (846, -4.65734e-06) (849, 1.6017e-08) (861, 3.83446e-10)
row 847: (832, 3.83446e-10) (844, 9.78551e-09) (847, -4.65968e-06) (848, 1.6017e-08) (851, 8.1702e-09) (862, 3.83446e-10)
row 848: (833, 3.83445e-10) (845, 1.01704e-08) (847, 1.01704e-08) (848, -4.65521e-06) (849, 4.57949e-09) (852, 4.57949e-09) (863, 3.83445e-10)
row 849: (834, 3.83445e-10) (846, 1.01704e-08) (848, 4.57949e-09) (849, -4.65328e-06) (850, 8.24588e-09) (853, 4.57949e-09) (864, 3.83445e-10)
row 850: (76, 8.45651e-09) (835, 3.83446e-10) (849, 6.49308e-09) (850, -4.65532e-06) (854, 8.1702e-09) (865, 3.83446e-10) (1555, 6.49308e-09)
row 851: (836, 3.83446e-10) (847, 8.1702e-09) (851, -4.65968e-06) (852, 1.6017e-08) (855, 9.78551e-09) (866, 3.83446e-10)
row 852: (837, 3.83445e-10) (848, 4.57949e-09) (851, 1.01704e-08) (852, -4.65521e-06) (853, 4.57949e-09) (856, 1.01704e-08) (867, 3.83445e-10)
row 853: (838, 3.83445e-10) (849, 4.57949e-09) (852, 4.57949e-09) (853, -4.65328e-06) (854, 8.24588e-09) (857, 1.01704e-08) (868, 3.83445e-10)
row 854: (839, 3.83446e-10) (850, 8.1702e-09) (853, 6.49308e-09) (854, -4.65532e-06) (858, 8.45651e-09) (869, 3.83446e-10) (1558, 6.49308e-09)
row 855: (840, 3.83446e-10) (851, 1.76405e-08) (855, -4.66099e-06) (856, 1.76405e-08) (870, 3.83446e-10)
row 856: (841, 3.83446e-10) (852, 1.6017e-08) (855, 9.78551e-09) (856, -4.65968e-06) (857, 8.1702e-09) (871, 3.83446e-10)
row 857: (842, 3.83446e-10) (853, 1.6017e-08) (856, 8.1702e-09) (857, -4.65734e-06) (858, 7.4454e-09) (872, 3.83446e-10)
row 858: (843, 3.83446e-10) (854, 1.01631e-08) (857, 4.47398e-09) (858, -4.65498e-06) (873, 3.83446e-10) (1561, 1.01631e-08) (2596, 4.47398e-09)
row 859: (844, 3.83496e-10) (859, -4.66094e-06) (860, 1.76406e-08) (862, 1.76406e-08) (874, 3.83519e-10)
row 860: (845, 3.83496e-10) (859, 9.78558e-09) (860, -4.65963e-06) (861, 8.17026e-09) (863, 1.60171e-08) (875, 3.83519e-10)
row 861: (92, 7.44545e-09) (846, 3.83496e-10) (860, 8.17026e-09) (861, -4.65729e-06) (864, 1.60171e-08) (876, 3.83519e-10)
row 862: (847, 3.83496e-10) (859, 9.78558e-09) (862, -4.65963e-06) (863, 1.60171e-08) (866, 8.17026e-09) (877, 3.83519e-10)
row 863: (848, 3.83495e-10) (860, 1.01705e-08) (862, 1.01705e-08) (863, -4.65516e-06) (864, 4.57952e-09) (867, 4.57952e-09) (878, 3.83518e-10)
row 864: (849, 3.83495e-10) (861, 1.01705e-08) (863, 4.57952e-09) (864, -4.65324e-06) (865, 8.24594e-09) (868, 4.57952e-09) (879, 3.83518e-10)
row 865: (92, 8.45658e-09) (850, 3.83496e-10) (864, 6.49312e-09) (865, -4.65527e-06) (869, 8.17026e-09) (880, 3.83519e-10) (1564, 6.49312e-09)
row 866: (851, 3.83496e-10) (862, 8.17026e-09) (866, -4.65963e-06) (867, 1.60171e-08) (870, 9.78558e-09) (881, 3.83519e-10)
row 867: (852, 3.83495e-10) (863, 4.57952e-09) (866, 1.01705e-08) (867, -4.65516e-06) (868, 4.57952e-09) (871, 1.01705e-08) (882, 3.83518e-10)
row 868: (853, 3.83495e-10) (864, 4.57952e-09) (867, 4.57952e-09) (868, -4.65324e-06) (869, 8.24594e-09) (872, 1.01705e-08) (883, 3.83518e-10)
row 869: (854, 3.83496e-10) (865, 8.17026e-09) (868, 6.49312e-09) (869, -4.65527e-06) (873, 8.45658e-09) (884, 3.83519e-10) (1567, 6.49312e-09)
row 870: (855, 3.83496e-10) (866, 1.76406e-08) (870, -4.66094e-06) (871, 1.76406e-08) (885, 3.83519e-10)
row 871: (856, 3.83496e-10) (867, 1.60171e-08) (870, 9.78558e-09) (871, -4.65963e-06) (872, 8.17026e-09) (886, 3.83519e-10)
row 872: (857, 3.83496e-10) (868, 1.60171e-08) (871, 8.17026e-09) (872, -4.65729e-06) (873, 7.44545e-09) (887, 3.83519e-10)
row 873: (858, 3.83496e-10) (869, 1.01632e-08) (872, 4.47402e-09) (873, -4.65493e-06) (888, 3.83519e-10) (1570, 1.01632e-08) (2608, 4.47402e-09)
row 874: (859, 3.83522e-10) (874, -4.66089e-06) (875, 1.76408e-08) (877, 1.76408e-08) (889, 3.83522e-10)
row 875: (860, 3.83522e-10) (874, 9.78565e-09) (875, -4.65958e-06) (876, 8.17032e-09) (878, 1.60172e-08) (890, 3.83522e-10)
row 876: (108, 7.44551e-09) (861, 3.83522e-10) (875, 8.17032e-09) (876, -4.65724e-06) (879, 1.60172e-08) (891, 3.83522e-10)
row 877: (862, 3.83522e-10) (874, 9.78565e-09) (877, -4.65958e-06) (878, 1.60172e-08) (881, 8.17032e-09) (892, 3.83522e-10)
row 878: (863, 3.83521e-10) (875, 1.01705e-08) (877, 1.01705e-08) (878, -4.65511e-06) (879, 4.57956e-09) (882, 4.57956e-09) (893, 3.83521e-10)
row 879: (864, 3.83521e-10) (876, 1.01705e-08) (878, 4.57956e-09) (879, -4.65319e-06) (880, 8.246e-09) (883, 4.57956e-09) (894, 3.83521e-10)
row 880: (108, 8.45664e-09) (865, 3.83522e-10) (879, 6.49317e-09) (880, -4.65522e-06) (884, 8.17032e-09) (895, 3.83522e-10) (1573, 6.49317e-09)
row 881: (866, 3.83522e-10) (877, 8.17032e-09) (881, -4.65958e-06) (882, 1.60172e-08) (885, 9.78565e-09) (896, 3.83522e-10)
row 882: (867, 3.83521e-10) (878, 4.57956e-09) (881, 1.01705e-08) (882, -4.65511e-06) (883, 4.57956e-09) (886, 1.01705e-08) (897, 3.83521e-10)
row 883: (868, 3.83521e-10) (879, 4.57956e-09) (882, 4.57956e-09) (883, -4.65319e-06) (884, 8.246e-09) (887, 1.01705e-08) (898, 3.83521e-10)
row 884: (869, 3.83522e-10) (880, 8.17032e-09) (883, 6.49317e-09) (884, -4.65522e-06) (888, 8.45664e-09) (899, 3.83522e-10) (1576, 6.49317e-09)
row 885: (870, 3.83522e-10) (881, 1.76408e-08) (885, -4.66089e-06) (886, 1.76408e-08) (900, 3.83522e-10)
row 886: (871, 3.83522e-10) (882, 1.60172e-08) (885, 9.78565e-09) (886, -4.65958e-06) (887, 8.17032e-09) (901, 3.83522e-10)
row 887: (872, 3.83522e-10) (883, 1.60172e-08) (886, 8.17032e-09) (887, -4.65724e-06) (888, 7.44551e-09) (902, 3.83522e-10)
row 888: (873, 3.83522e-10) (884, 1.01633e-08) (887, 4.47405e-09) (888, -4.65489e-06) (903, 3.83522e-10) (1579, 1.01633e-08) (2620, 4.47405e-09)
row 889: (874, 3.83525e-10) (889, -4.66098e-06) (890, 1.76409e-08) (892, 1.76409e-08) (904, 5.23901e-10)
row 890: (875, 3.83525e-10) (889, 9.78572e-09) (890, -4.65968e-06) (891, 8.17038e-09) (893, 1.60174e-08) (905, 5.23901e-10)
row 891: (124, 7.44556e-09) (876, 3.83525e-10) (890, 8.17038e-09) (891, -4.65734e-06) (894, 1.60174e-08) (906, 5.23901e-10)
row 892: (877, 3.83525e-10) (889, 9.78572e-09) (892, -4.65968e-06) (893, 1.60174e-08) (896, 8.17038e-09) (907, 5.23901e-10)
row 893: (878, 3.83524e-10) (890, 1.01706e-08) (892, 1.01706e-08) (893, -4.6552e-06) (894, 4.57959e-09) (897, 4.57959e-09) (908, 5.239e-10)
row 894: (879, 3.83524e-10) (891, 1.01706e-08) (893, 4.57959e-09) (894, -4.65328e-06) (895, 8.24606e-09) (898, 4.57959e-09) (909, 5.239e-10)
row 895: (124, 8.4567e-09) (880, 3.83525e-10) (894, 6.49322e-09) (895, -4.65532e-06) (899, 8.17038e-09) (910, 5.23901e-10) (1582, 6.49322e-09)
row 896: (881, 3.83525e-10) (892, 8.17038e-09) (896, -4.65968e-06) (897, 1.60174e-08) (900, 9.78572e-09) (911, 5.23901e-10)
row 897: (882, 3.83524e-10) (893, 4.57959e-09) (896, 1.01706e-08) (897, -4.6552e-06) (898, 4.57959e-09) (901, 1.01706e-08) (912, 5.239e-10)
row 898: (883, 3.83524e-10) (894, 4.57959e-09) (897, 4.57959e-09) (898, -4.65328e-06) (899, 8.24606e-09) (902, 1.01706e-08) (913, 5.239e-10)
row 899: (884, 3.83525e-10) (895, 8.17038e-09) (898, 6.49322e-09) (899, -4.65532e-06) (903, 8.4567e-09) (914, 5.23901e-10) (1585, 6.49322e-09)
row 900: (885, 3.83525e-10) (896, 1.76409e-08) (900, -4.66098e-06) (901, 1.76409e-08) (915, 5.23901e-10)
row 901: (886, 3.83525e-10) (897, 1.60174e-08) (900, 9.78572e-09) (901, -4.65968e-06) (902, 8.17038e-09) (916, 5.23901e-10)
row 902: (887, 3.83525e-10) (898, 1.60174e-08) (901, 8.17038e-09) (902, -4.65734e-06) (903, 7.44556e-09) (917, 5.23901e-10)
row 903: (888, 3.83525e-10) (899, 1.01634e-08) (902, 4.47408e-09) (903, -4.65498e-06) (918, 5.23901e-10) (1588, 1.01634e-08) (2632, 4.47408e-09)
row 904: (889, 1.12908e-09) (904, -4.66231e-06) (905, 1.7641e-08) (907, 1.7641e-08) (919, 1.14303e-09)
row 905: (890, 1.12907e-09) (904, 9.78578e-09) (905, -4.66101e-06) (906, 8.17042e-09) (908, 1.60174e-08) (920, 1.14303e-09)
row 906: (140, 7.4456e-09) (891, 1.12907e-09) (905, 8.17042e-09) (906, -4.65867e-06) (909, 1.60174e-08) (921, 1.14303e-09)
row 907: (892, 1.12907e-09) (904, 9.78578e-09) (907, -4.66101e-06) (908, 1.60174e-08) (911, 8.17042e-09) (922, 1.14303e-09)
row 908: (893, 1.12907e-09) (905, 1.01707e-08) (907, 1.01707e-08) (908, -4.65653e-06) (909, 4.57962e-09) (912, 4.57962e-09) (923, 1.14303e-09)
row 909: (894, 1.12907e-09) (906, 1.01707e-08) (908, 4.57962e-09) (909, -4.65461e-06) (910, 8.2461e-09) (913, 4.57962e-09) (924, 1.14303e-09)
row 910: (140, 8.45675e-09) (895, 1.12907e-09) (909, 6.49325e-09) (910, -4.65665e-06) (914, 8.17042e-09) (925, 1.14303e-09) (1591, 6.49325e-09)
row 911: (896, 1.12907e-09) (907, 8.17042e-09) (911, -4.66101e-06) (912, 1.60174e-08) (915, 9.78578e-09) (926, 1.14303e-09)
row 912: (897, 1.12907e-09) (908, 4.57962e-09) (911, 1.01707e-08) (912, -4.65653e-06) (913, 4.57962e-09) (916, 1.01707e-08) (927, 1.14303e-09)
row 913: (898, 1.12907e-09) (909, 4.57962e-09) (912, 4.57962e-09) (913, -4.65461e-06) (914, 8.2461e-09) (917, 1.01707e-08) (928, 1.14303e-09)
row 914: (899, 1.12907e-09) (910, 8.17042e-09) (913, 6.49325e-09) (914, -4.65665e-06) (918, 8.45675e-09) (929, 1.14303e-09) (1594, 6.49325e-09)
row 915: (900, 1.12908e-09) (911, 1.7641e-08) (915, -4.66231e-06) (916, 1.7641e-08) (930, 1.14303e-09)
row 916: (901, 1.12907e-09) (912, 1.60174e-08) (915, 9.78578e-09) (916, -4.66101e-06) (917, 8.17042e-09) (931, 1.14303e-09)
row 917: (902, 1.12907e-09) (913, 1.60174e-08) (916, 8.17042e-09) (917, -4.65867e-06) (918, 7.4456e-09) (932, 1.14303e-09)
row 918: (903, 1.12908e-09) (914, 1.01634e-08) (917, 4.47411e-09) (918, -4.65631e-06) (933, 1.14303e-09) (1597, 1.01634e-08) (2644, 4.47411e-09)
row 919: (904, 5.39986e-10) (919, -4.66094e-06) (920, 1.76411e-08) (922, 1.76411e-08) (934, 3.97541e-10)
row 920: (905, 5.39985e-10) (919, 9.78583e-09) (920, -4.65964e-06) (921, 8.17047e-09) (923, 1.60175e-08) (935, 3.9754e-10)
row 921: (156, 7.44564e-09) (906, 5.39985e-10) (920, 8.17047e-09) (921, -4.6573e-06) (924, 1.60175e-08) (936, 3.9754e-10)
row 922: (907, 5.39985e-10) (919, 9.78583e-09) (922, -4.65964e-06) (923, 1.60175e-08) (926, 8.17047e-09) (937, 3.9754e-10)
row 923: (908, 5.39984e-10) (920, 1.01707e-08) (922, 1.01707e-08) (923, -4.65516e-06) (924, 4.57964e-09) (927, 4.57964e-09) (938, 3.9754e-10)
row 924: (909, 5.39984e-10) (921, 1.01707e-08) (923, 4.57964e-09) (924, -4.65324e-06) (925, 8.24615e-09) (928, 4.57964e-09) (939, 3.9754e-10)
row 925: (156, 8.45679e-09) (910, 5.39985e-10) (924, 6.49329e-09) (925, -4.65528e-06) (929, 8.17047e-09) (940, 3.9754e-10) (1600, 6.49329e-09)
row 926: (911, 5.39985e-10) (922, 8.17047e-09) (926, -4.65964e-06) (927, 1.60175e-08) (930, 9.78583e-09) (941, 3.9754e-10)
row 927: (912, 5.39984e-10) (923, 4.57964e-09) (926, 1.01707e-08) (927, -4.65516e-06) (928, 4.57964e-09) (931, 1.01707e-08) (942, 3.9754e-10)
row 928: (913, 5.39984e-10) (924, 4.57964e-09) (927, 4.57964e-09) (928, -4.65324e-06) (929, 8.24615e-09) (932, 1.01707e-08) (943, 3.9754e-10)
row 929: (914, 5.39985e-10) (925, 8.17047e-09) (928, 6.49329e-09) (929, -4.65528e-06) (933, 8.45679e-09) (944, 3.9754e-10) (1603, 6.49329e-09)
row 930: (915, 5.39986e-10) (926, 1.76411e-08) (930, -4.66094e-06) (931, 1.76411e-08) (945, 3.97541e-10)
row 931: (916, 5.39985e-10) (927, 1.60175e-08) (930, 9.78583e-09) (931, -4.65964e-06) (932, 8.17047e-09) (946, 3.9754e-10)
row 932: (917, 5.39985e-10) (928, 1.60175e-08) (931, 8.17047e-09) (932, -4.6573e-06) (933, 7.44564e-09) (947, 3.9754e-10)
row 933: (918, 5.39986e-10) (929, 1.01635e-08) (932, 4.47413e-09) (933, -4.65494e-06) (948, 3.97541e-10) (1606, 1.01635e-08) (2656, 4.47413e-09)
row 934: (919, 3.97544e-10) (934, -4.66075e-06) (935, 1.76412e-08) (937, 1.76412e-08) (949, 3.97544e-10)
row 935: (920, 3.97543e-10) (934, 9.7859e-09) (935, -4.65945e-06) (936, 8.17053e-09) (938, 1.60177e-08) (950, 3.97543e-10)
row 936: (172, 7.44569e-09) (921, 3.97543e-10) (935, 8.17053e-09) (936, -4.65711e-06) (939, 1.60177e-08) (951, 3.97543e-10)
row 937: (922, 3.97543e-10) (934, 9.7859e-09) (937, -4.65945e-06) (938, 1.60177e-08) (941, 8.17053e-09) (952, 3.97543e-10)
row 938: (923, 3.97542e-10) (935, 1.01708e-08) (937, 1.01708e-08) (938, -4.65497e-06) (939, 4.57967e-09) (942, 4.57967e-09) (953, 3.97542e-10)
row 939: (924, 3.97542e-10) (936, 1.01708e-08) (938, 4.57967e-09) (939, -4.65305e-06) (940, 8.24621e-09) (943, 4.57967e-09) (954, 3.97542e-10)
row 940: (172, 8.45685e-09) (925, 3.97543e-10) (939, 6.49334e-09) (940, -4.65509e-06) (944, 8.17053e-09) (955, 3.97543e-10) (1609, 6.49334e-09)
row 941: (926, 3.97543e-10) (937, 8.17053e-09) (941, -4.65945e-06) (942, 1.60177e-08) (945, 9.7859e-09) (956, 3.97543e-10)
row 942: (927, 3.97542e-10) (938, 4.57967e-09) (941, 1.01708e-08) (942, -4.65497e-06) (943, 4.57967e-09) (946, 1.01708e-08) (957, 3.97542e-10)
row 943: (928, 3.97542e-10) (939, 4.57967e-09) (942, 4.57967e-09) (943, -4.65305e-06) (944, 8.24621e-09) (947, 1.01708e-08) (958, 3.97542e-10)
row 944: (929, 3.97543e-10) (940, 8.17053e-09) (943, 6.49334e-09) (944, -4.65509e-06) (948, 8.45685e-09) (959, 3.97543e-10) (1612, 6.49334e-09)
row 945: (930, 3.97544e-10) (941, 1.76412e-08) (945, -4.66075e-06) (946, 1.76412e-08) (960, 3.97544e-10)
row 946: (931, 3.97543e-10) (942, 1.60177e-08) (945, 9.7859e-09) (946, -4.65945e-06) (947, 8.17053e-09) (961, 3.97543e-10)
row 947: (932, 3.97543e-10) (943, 1.60177e-08) (946, 8.17053e-09) (947, -4.65711e-06) (948, 7.44569e-09) (962, 3.97543e-10)
row 948: (933, 3.97544e-10) (944, 1.01635e-08) (947, 4.47416e-09) (948, -4.65475e-06) (963, 3.97544e-10) (1615, 1.01635e-08) (2668, 4.47416e-09)
row 949: (934, 3.97546e-10) (949, -4.66071e-06) (950, 1.76413e-08) (952, 1.76413e-08) (964, 3.97546e-10)
row 950: (935, 3.97546e-10) (949, 9.78597e-09) (950, -4.6594e-06) (951, 8.17059e-09) (953, 1.60178e-08) (965, 3.97546e-10)
row 951: (188, 7.44575e-09) (936, 3.97546e-10) (950, 8.17059e-09) (951, -4.65706e-06) (954, 1.60178e-08) (966, 3.97546e-10)
row 952: (937, 3.97546e-10) (949, 9.78597e-09) (952, -4.6594e-06) (953, 1.60178e-08) (956, 8.17059e-09) (967, 3.97546e-10)
row 953: (938, 3.97545e-10) (950, 1.01709e-08) (952, 1.01709e-08) (953, -4.65492e-06) (954, 4.57971e-09) (957, 4.57971e-09) (968, 3.97545e-10)
row 954: (939, 3.97545e-10) (951, 1.01709e-08) (953, 4.57971e-09) (954, -4.653e-06) (955, 8.24627e-09) (958, 4.57971e-09) (969, 3.97545e-10)
row 955: (188, 8.45691e-09) (940, 3.97546e-10) (954, 6.49338e-09) (955, -4.65504e-06) (959, 8.17059e-09) (970, 3.97546e-10) (1618, 6.49338e-09)
row 956: (941, 3.97546e-10) (952, 8.17059e-09) (956, -4.6594e-06) (957, 1.60178e-08) (960, 9.78597e-09) (971, 3.97546e-10)
row 957: (942, 3.97545e-10) (953, 4.57971e-09) (956, 1.01709e-08) (957, -4.65492e-06) (958, 4.57971e-09) (961, 1.01709e-08) (972, 3.97545e-10)
row 958: (943, 3.97545e-10) (954, 4.57971e-09) (957, 4.57971e-09) (958, -4.653e-06) (959, 8.24627e-09) (962, 1.01709e-08) (973, 3.97545e-10)
row 959: (944, 3.97546e-10) (955, 8.17059e-09) (958, 6.49338e-09) (959, -4.65504e-06) (963, 8.45691e-09) (974, 3.97546e-10) (1621, 6.49338e-09)
row 960: (945, 3.97546e-10) (956, 1.76413e-08) (960, -4.66071e-06) (961, 1.76413e-08) (975, 3.97546e-10)
row 961: (946, 3.97546e-10) (957, 1.60178e-08) (960, 9.78597e-09) (961, -4.6594e-06) (962, 8.17059e-09) (976, 3.97546e-10)
row 962: (947, 3.97546e-10) (958, 1.60178e-08) (961, 8.17059e-09) (962, -4.65706e-06) (963, 7.44575e-09) (977, 3.97546e-10)
row 963: (948, 3.97546e-10) (959, 1.01636e-08) (962, 4.4742e-09) (963, -4.6547e-06) (978, 3.97546e-10) (1624, 1.01636e-08) (2680, 4.4742e-09)
row 964: (949, 3.97549e-10) (964, -4.66066e-06) (965, 1.76415e-08) (967, 1.76415e-08) (979, 3.97549e-10)
row 965: (950, 3.97549e-10) (964, 9.78604e-09) (965, -4.65935e-06) (966, 8.17065e-09) (968, 1.60179e-08) (980, 3.97549e-10)
row 966: (204, 7.4458e-09) (951, 3.97549e-10) (965, 8.17065e-09) (966, -4.65701e-06) (969, 1.60179e-08) (981, 3.97549e-10)
row 967: (952, 3.97549e-10) (964, 9.78604e-09) (967, -4.65935e-06) (968, 1.60179e-08) (971, 8.17065e-09) (982, 3.97549e-10)
row 968: (953, 3.97548e-10) (965, 1.0171e-08) (967, 1.0171e-08) (968, -4.65488e-06) (969, 4.57974e-09) (972, 4.57974e-09) (983, 3.97548e-10)
row 969: (954, 3.97548e-10) (966, 1.0171e-08) (968, 4.57974e-09) (969, -4.65295e-06) (970, 8.24633e-09) (973, 4.57974e-09) (984, 3.97548e-10)
row 970: (204, 8.45697e-09) (955, 3.97549e-10) (969, 6.49343e-09) (970, -4.65499e-06) (974, 8.17065e-09) (985, 3.97549e-10) (1627, 6.49343e-09)
row 971: (956, 3.97549e-10) (967, 8.17065e-09) (971, -4.65935e-06) (972, 1.60179e-08) (975, 9.78604e-09) (986, 3.97549e-10)
row 972: (957, 3.97548e-10) (968, 4.57974e-09) (971, 1.0171e-08) (972, -4.65488e-06) (973, 4.57974e-09) (976, 1.0171e-08) (987, 3.97548e-10)
row 973: (958, 3.97548e-10) (969, 4.57974e-09) (972, 4.57974e-09) (973, -4.65295e-06) (974, 8.24633e-09) (977, 1.0171e-08) (988, 3.97548e-10)
row 974: (959, 3.97549e-10) (970, 8.17065e-09) (973, 6.49343e-09) (974, -4.65499e-06) (978, 8.45697e-09) (989, 3.97549e-10) (1630, 6.49343e-09)
row 975: (960, 3.97549e-10) (971, 1.76415e-08) (975, -4.66066e-06) (976, 1.76415e-08) (990, 3.97549e-10)
row 976: (961, 3.97549e-10) (972, 1.60179e-08) (975, 9.78604e-09) (976, -4.65935e-06) (977, 8.17065e-09) (991, 3.97549e-10)
row 977: (962, 3.97549e-10) (973, 1.60179e-08) (976, 8.17065e-09) (977, -4.65701e-06) (978, 7.4458e-09) (992, 3.97549e-10)
row 978: (963, 3.97549e-10) (974, 1.01637e-08) (977, 4.47423e-09) (978, -4.65465e-06) (993, 3.97549e-10) (1633, 1.01637e-08) (2692, 4.47423e-09)
row 979: (964, 3.97552e-10) (979, -4.66061e-06) (980, 1.76416e-08) (982, 1.76416e-08) (994, 3.97552e-10)
row 980: (965, 3.97552e-10) (979, 9.78611e-09) (980, -4.6593e-06) (981, 8.17071e-09) (983, 1.6018e-08) (995, 3.97552e-10)
row 981: (220, 7.44586e-09) (966, 3.97552e-10) (980, 8.17071e-09) (981, -4.65696e-06) (984, 1.6018e-08) (996, 3.97552e-10)
row 982: (967, 3.97552e-10) (979, 9.78611e-09) (982, -4.6593e-06) (983, 1.6018e-08) (986, 8.17071e-09) (997, 3.97552e-10)
row 983: (968, 3.97551e-10) (980, 1.0171e-08) (982, 1.0171e-08) (983, -4.65483e-06) (984, 4.57977e-09) (987, 4.57977e-09) (998, 3.97551e-10)
row 984: (969, 3.97551e-10) (981, 1.0171e-08) (983, 4.57977e-09) (984, -4.6529e-06) (985, 8.24639e-09) (988, 4.57977e-09) (999, 3.97551e-10)
row 985: (220, 8.45704e-09) (970, 3.97552e-10) (984, 6.49348e-09) (985, -4.65494e-06) (989, 8.17071e-09) (1000, 3.97552e-10) (1636, 6.49348e-09)
row 986: (971, 3.97552e-10) (982, 8.17071e-09) (986, -4.6593e-06) (987, 1.6018e-08) (990, 9.78611e-09) (1001, 3.97552e-10)
row 987: (972, 3.97551e-10) (983, 4.57977e-09) (986, 1.0171e-08) (987, -4.65483e-06) (988, 4.57977e-09) (991, 1.0171e-08) (1002, 3.97551e-10)
row 988: (973, 3.97551e-10) (984, 4.57977e-09) (987, 4.57977e-09) (988, -4.6529e-06) (989, 8.24639e-09) (992, 1.0171e-08) (1003, 3.97551e-10)
row 989: (974, 3.97552e-10) (985, 8.17071e-09) (988, 6.49348e-09) (989, -4.65494e-06) (993, 8.45704e-09) (1004, 3.97552e-10) (1639, 6.49348e-09)
row 990: (975, 3.97552e-10) (986, 1.76416e-08) (990, -4.66061e-06) (991, 1.76416e-08) (1005, 3.97552e-10)
row 991: (976, 3.97552e-10) (987, 1.6018e-08) (990, 9.78611e-09) (991, -4.6593e-06) (992, 8.17071e-09) (1006, 3.97552e-10)
row 992: (977, 3.97552e-10) (988, 1.6018e-08) (991, 8.17071e-09) (992, -4.65696e-06) (993, 7.44586e-09) (1007, 3.97552e-10)
row 993: (978, 3.97552e-10) (989, 1.01638e-08) (992, 4.47426e-09) (993, -4.6546e-06) (1008, 3.97552e-10) (1642, 1.01638e-08) (2704, 4.47426e-09)
row 994: (979, 3.97555e-10) (994, -4.66071e-06) (995, 1.76417e-08) (997, 1.76417e-08) (1009, 5.39968e-10)
row 995: (980, 3.97555e-10) (994, 9.78618e-09) (995, -4.6594e-06) (996, 8.17076e-09) (998, 1.60181e-08) (1010, 5.39968e-10)
row 996: (236, 7.44591e-09) (981, 3.97555e-10) (995, 8.17076e-09) (996, -4.65706e-06) (999, 1.60181e-08) (1011, 5.39968e-10)
row 997: (982, 3.97555e-10) (994, 9.78618e-09) (997, -4.6594e-06) (998, 1.60181e-08) (1001, 8.17076e-09) (1012, 5.39968e-10)
row 998: (983, 3.97554e-10) (995, 1.01711e-08) (997, 1.01711e-08) (998, -4.65492e-06) (999, 4.57981e-09) (1002, 4.57981e-09) (1013, 5.39967e-10)
row 999: (984, 3.97554e-10) (996, 1.01711e-08) (998, 4.57981e-09) (999, -4.653e-06) (1000, 8.24645e-09) (1003, 4.57981e-09) (1014, 5.39967e-10)
row 1000: (236, 8.4571e-09) (985, 3.97555e-10) (999, 6.49352e-09) (1000, -4.65504e-06) (1004, 8.17076e-09) (1015, 5.39968e-10) (1645, 6.49352e-09)
row 1001: (986, 3.97555e-10) (997, 8.17076e-09) (1001, -4.6594e-06) (1002, 1.60181e-08) (1005, 9.78618e-09) (1016, 5.39968e-10)
row 1002: (987, 3.97554e-10) (998, 4.57981e-09) (1001, 1.01711e-08) (1002, -4.65492e-06) (1003, 4.57981e-09) (1006, 1.01711e-08) (1017, 5.39967e-10)
row 1003: (988, 3.97554e-10) (999, 4.57981e-09) (1002, 4.57981e-09) (1003, -4.653e-06) (1004, 8.24645e-09) (1007, 1.01711e-08) (1018, 5.39967e-10)
row 1004: (989, 3.97555e-10) (1000, 8.17076e-09) (1003, 6.49352e-09) (1004, -4.65504e-06) (1008, 8.4571e-09) (1019, 5.39968e-10) (1648, 6.49352e-09)
row 1005: (990, 3.97555e-10) (1001, 1.76417e-08) (1005, -4.66071e-06) (1006, 1.76417e-08) (1020, 5.39968e-10)
row 1006: (991, 3.97555e-10) (1002, 1.60181e-08) (1005, 9.78618e-09) (1006, -4.6594e-06) (1007, 8.17076e-09) (1021, 5.39968e-10)
row 1007: (992, 3.97555e-10) (1003, 1.60181e-08) (1006, 8.17076e-09) (1007, -4.65706e-06) (1008, 7.44591e-09) (1022, 5.39968e-10)
row 1008: (993, 3.97555e-10) (1004, 1.01638e-08) (1007, 4.47429e-09) (1008, -4.6547e-06) (1023, 5.39968e-10) (1651, 1.01638e-08) (2716, 4.47429e-09)
row 1009: (994, 1.14301e-09) (1009, -4.66202e-06) (1010, 1.76418e-08) (1012, 1.76418e-08) (1024, 1.14309e-09)
row 1010: (995, 1.14301e-09) (1009, 9.78624e-09) (1010, -4.66071e-06) (1011, 8.17081e-09) (1013, 1.60182e-08) (1025, 1.14309e-09)
row 1011: (252, 7.44595e-09) (996, 1.14301e-09) (1010, 8.17081e-09) (1011, -4.65837e-06) (1014, 1.60182e-08) (1026, 1.14309e-09)
row 1012: (997, 1.14301e-09) (1009, 9.78624e-09) (1012, -4.66071e-06) (1013, 1.60182e-08) (1016, 8.17081e-09) (1027, 1.14309e-09)
row 1013: (998, 1.14301e-09) (1010, 1.01712e-08) (1012, 1.01712e-08) (1013, -4.65624e-06) (1014, 4.57983e-09) (1017, 4.57983e-09) (1028, 1.14308e-09)
row 1014: (999, 1.14301e-09) (1011, 1.01712e-08) (1013, 4.57983e-09) (1014, -4.65431e-06) (1015, 8.24649e-09) (1018, 4.57983e-09) (1029, 1.14308e-09)
row 1015: (252, 8.45714e-09) (1000, 1.14301e-09) (1014, 6.49356e-09) (1015, -4.65635e-06) (1019, 8.17081e-09) (1030, 1.14309e-09) (1654, 6.49356e-09)
row 1016: (1001, 1.14301e-09) (1012, 8.17081e-09) (1016, -4.66071e-06) (1017, 1.60182e-08) (1020, 9.78624e-09) (1031, 1.14309e-09)
row 1017: (1002, 1.14301e-09) (1013, 4.57983e-09) (1016, 1.01712e-08) (1017, -4.65624e-06) (1018, 4.57983e-09) (1021, 1.01712e-08) (1032, 1.14308e-09)
row 1018: (1003, 1.14301e-09) (1014, 4.57983e-09) (1017, 4.57983e-09) (1018, -4.65431e-06) (1019, 8.24649e-09) (1022, 1.01712e-08) (1033, 1.14308e-09)
row 1019: (1004, 1.14301e-09) (1015, 8.17081e-09) (1018, 6.49356e-09) (1019, -4.65635e-06) (1023, 8.45714e-09) (1034, 1.14309e-09) (1657, 6.49356e-09)
row 1020: (1005, 1.14301e-09) (1016, 1.76418e-08) (1020, -4.66202e-06) (1021, 1.76418e-08) (1035, 1.14309e-09)
row 1021: (1006, 1.14301e-09) (1017, 1.60182e-08) (1020, 9.78624e-09) (1021, -4.66071e-06) (1022, 8.17081e-09) (1036, 1.14309e-09)
row 1022: (1007, 1.14301e-09) (1018, 1.60182e-08) (1021, 8.17081e-09) (1022, -4.65837e-06) (1023, 7.44595e-09) (1037, 1.14309e-09)
row 1023: (1008, 1.14301e-09) (1019, 1.01639e-08) (1022, 4.47432e-09) (1023, -4.65601e-06) (1038, 1.14309e-09) (1660, 1.01639e-08) (2728, 4.47432e-09)
row 1024: (1009, 5.40011e-10) (1024, -4.66064e-06) (1025, 1.76419e-08) (1027, 1.76419e-08) (1039, 3.97559e-10)
row 1025: (1010, 5.40011e-10) (1024, 9.78629e-09) (1025, -4.65933e-06) (1026, 8.17085e-09) (1028, 1.60183e-08) (1040, 3.97559e-10)
row 1026: (268, 7.44599e-09) (1011, 5.40011e-10) (1025, 8.17085e-09) (1026, -4.65699e-06) (1029, 1.60183e-08) (1041, 3.97559e-10)
row 1027: (1012, 5.40011e-10) (1024, 9.78629e-09) (1027, -4.65933e-06) (1028, 1.60183e-08) (1031, 8.17085e-09) (1042, 3.97559e-10)
row 1028: (1013, 5.40009e-10) (1025, 1.01712e-08) (1027, 1.01712e-08) (1028, -4.65485e-06) (1029, 4.57986e-09) (1032, 4.57986e-09) (1043, 3.97558e-10)
row 1029: (1014, 5.40009e-10) (1026, 1.01712e-08) (1028, 4.57986e-09) (1029, -4.65293e-06) (1030, 8.24654e-09) (1033, 4.57986e-09) (1044, 3.97558e-10)
row 1030: (268, 8.45719e-09) (1015, 5.40011e-10) (1029, 6.49359e-09) (1030, -4.65497e-06) (1034, 8.17085e-09) (1045, 3.97559e-10) (1663, 6.49359e-09)
row 1031: (1016, 5.40011e-10) (1027, 8.17085e-09) (1031, -4.65933e-06) (1032, 1.60183e-08) (1035, 9.78629e-09) (1046, 3.97559e-10)
row 1032: (1017, 5.40009e-10) (1028, 4.57986e-09) (1031, 1.01712e-08) (1032, -4.65485e-06) (1033, 4.57986e-09) (1036, 1.01712e-08) (1047, 3.97558e-10)
row 1033: (1018, 5.40009e-10) (1029, 4.57986e-09) (1032, 4.57986e-09) (1033, -4.65293e-06) (1034, 8.24654e-09) (1037, 1.01712e-08) (1048, 3.97558e-10)
row 1034: (1019, 5.40011e-10) (1030, 8.17085e-09) (1033, 6.49359e-09) (1034, -4.65497e-06) (1038, 8.45719e-09) (1049, 3.97559e-10) (1666, 6.49359e-09)
row 1035: (1020, 5.40011e-10) (1031, 1.76419e-08) (1035, -4.66064e-06) (1036, 1.76419e-08) (1050, 3.97559e-10)
row 1036: (1021, 5.40011e-10) (1032, 1.60183e-08) (1035, 9.78629e-09) (1036, -4.65933e-06) (1037, 8.17085e-09) (1051, 3.97559e-10)
row 1037: (1022, 5.40011e-10) (1033, 1.60183e-08) (1036, 8.17085e-09) (1037, -4.65699e-06) (1038, 7.44599e-09) (1052, 3.97559e-10)
row 1038: (1023, 5.40011e-10) (1034, 1.0164e-08) (1037, 4.47434e-09) (1038, -4.65463e-06) (1053, 3.97559e-10) (1669, 1.0164e-08) (2740, 4.47434e-09)
row 1039: (1024, 3.97562e-10) (1039, -4.66044e-06) (1040, 1.7642e-08) (1042, 1.7642e-08) (1054, 3.97562e-10)
row 1040: (1025, 3.97562e-10) (1039, 9.78636e-09) (1040, -4.65914e-06) (1041, 8.17091e-09) (1043, 1.60184e-08) (1055, 3.97562e-10)
row 1041: (284, 7.44604e-09) (1026, 3.97562e-10) (1040, 8.17091e-09) (1041, -4.6568e-06) (1044, 1.60184e-08) (1056, 3.97562e-10)
row 1042: (1027, 3.97562e-10) (1039, 9.78636e-09) (1042, -4.65914e-06) (1043, 1.60184e-08) (1046, 8.17091e-09) (1057, 3.97562e-10)
row 1043: (1028, 3.97561e-10) (1040, 1.01713e-08) (1042, 1.01713e-08) (1043, -4.65466e-06) (1044, 4.57989e-09) (1047, 4.57989e-09) (1058, 3.97561e-10)
row 1044: (1029, 3.97561e-10) (1041, 1.01713e-08) (1043, 4.57989e-09) (1044, -4.65274e-06) (1045, 8.2466e-09) (1048, 4.57989e-09) (1059, 3.97561e-10)
row 1045: (284, 8.45725e-09) (1030, 3.97562e-10) (1044, 6.49364e-09) (1045, -4.65478e-06) (1049, 8.17091e-09) (1060, 3.97562e-10) (1672, 6.49364e-09)
row 1046: (1031, 3.97562e-10) (1042, 8.17091e-09) (1046, -4.65914e-06) (1047, 1.60184e-08) (1050, 9.78636e-09) (1061, 3.97562e-10)
row 1047: (1032, 3.97561e-10) (1043, 4.57989e-09) (1046, 1.01713e-08) (1047, -4.65466e-06) (1048, 4.57989e-09) (1051, 1.01713e-08) (1062, 3.97561e-10)
row 1048: (1033, 3.97561e-10) (1044, 4.57989e-09) (1047, 4.57989e-09) (1048, -4.65274e-06) (1049, 8.2466e-09) (1052, 1.01713e-08) (1063, 3.97561e-10)
row 1049: (1034, 3.97562e-10) (1045, 8.17091e-09) (1048, 6.49364e-09) (1049, -4.65478e-06) (1053, 8.45725e-09) (1064, 3.97562e-10) (1675, 6.49364e-09)
row 1050: (1035, 3.97562e-10) (1046, 1.7642e-08) (1050, -4.66044e-06) (1051, 1.7642e-08) (1065, 3.97562e-10)
row 1051: (1036, 3.97562e-10) (1047, 1.60184e-08) (1050, 9.78636e-09) (1051, -4.65914e-06) (1052, 8.17091e-09) (1066, 3.97562e-10)
row 1052: (1037, 3.97562e-10) (1048, 1.60184e-08) (1051, 8.17091e-09) (1052, -4.6568e-06) (1053, 7.44604e-09) (1067, 3.97562e-10)
row 1053: (1038, 3.97562e-10) (1049, 1.0164e-08) (1052, 4.47437e-09) (1053, -4.65444e-06) (1068, 3.97562e-10) (1678, 1.0164e-08) (2752, 4.47437e-09)
row 1054: (1039, 3.97565e-10) (1054, -4.6604e-06) (1055, 1.76422e-08) (1057, 1.76422e-08) (1069, 3.97565e-10)
row 1055: (1040, 3.97565e-10) (1054, 9.78643e-09) (1055, -4.65909e-06) (1056, 8.17097e-09) (1058, 1.60185e-08) (1070, 3.97565e-10)
row 1056: (300, 7.4461e-09) (1041, 3.97565e-10) (1055, 8.17097e-09) (1056, -4.65675e-06) (1059, 1.60185e-08) (1071, 3.97565e-10)
row 1057: (1042, 3.97565e-10) (1054, 9.78643e-09) (1057, -4.65909e-06) (1058, 1.60185e-08) (1061, 8.17097e-09) (1072, 3.97565e-10)
row 1058: (1043, 3.97564e-10) (1055, 1.01714e-08) (1057, 1.01714e-08) (1058, -4.65462e-06) (1059, 4.57992e-09) (1062, 4.57992e-09) (1073, 3.97564e-10)
row 1059: (1044, 3.97564e-10) (1056, 1.01714e-08) (1058, 4.57992e-09) (1059, -4.65269e-06) (1060, 8.24666e-09) (1063, 4.57992e-09) (1074, 3.97564e-10)
row 1060: (300, 8.45731e-09) (1045, 3.97565e-10) (1059, 6.49369e-09) (1060, -4.65473e-06) (1064, 8.17097e-09) (1075, 3.97565e-10) (1681, 6.49369e-09)
row 1061: (1046, 3.97565e-10) (1057, 8.17097e-09) (1061, -4.65909e-06) (1062, 1.60185e-08) (1065, 9.78643e-09) (1076, 3.97565e-10)
row 1062: (1047, 3.97564e-10) (1058, 4.57992e-09) (1061, 1.01714e-08) (1062, -4.65462e-06) (1063, 4.57992e-09) (1066, 1.01714e-08) (1077, 3.97564e-10)
row 1063: (1048, 3.97564e-10) (1059, 4.57992e-09) (1062, 4.57992e-09) (1063, -4.65269e-06) (1064, 8.24666e-09) (1067, 1.01714e-08) (1078, 3.97564e-10)
row 1064: (1049, 3.97565e-10) (1060, 8.17097e-09) (1063, 6.49369e-09) (1064, -4.65473e-06) (1068, 8.45731e-09) (1079, 3.97565e-10) (1684, 6.49369e-09)
row 1065: (1050, 3.97565e-10) (1061, 1.76422e-08) (1065, -4.6604e-06) (1066, 1.76422e-08) (1080, 3.97565e-10)
row 1066: (1051, 3.97565e-10) (1062, 1.60185e-08) (1065, 9.78643e-09) (1066, -4.65909e-06) (1067, 8.17097e-09) (1081, 3.97565e-10)
row 1067: (1052, 3.97565e-10) (1063, 1.60185e-08) (1066, 8.17097e-09) (1067, -4.65675e-06) (1068, 7.4461e-09) (1082, 3.97565e-10)
row 1068: (1053, 3.97565e-10) (1064, 1.01641e-08) (1067, 4.47441e-09) (1068, -4.65439e-06) (1083, 3.97565e-10) (1687, 1.01641e-08) (2764, 4.47441e-09)
row 1069: (1054, 3.97568e-10) (1069, -4.66035e-06) (1070, 1.76423e-08) (1072, 1.76423e-08) (1084, 3.97568e-10)
row 1070: (1055, 3.97568e-10) (1069, 9.7865e-09) (1070, -4.65904e-06) (1071, 8.17103e-09) (1073, 1.60186e-08) (1085, 3.97568e-10)
row 1071: (316, 7.44615e-09) (1056, 3.97568e-10) (1070, 8.17103e-09) (1071, -4.6567e-06) (1074, 1.60186e-08) (1086, 3.97568e-10)
row 1072: (1057, 3.97568e-10) (1069, 9.7865e-09) (1072, -4.65904e-06) (1073, 1.60186e-08) (1076, 8.17103e-09) (1087, 3.97568e-10)
row 1073: (1058, 3.97567e-10) (1070, 1.01714e-08) (1072, 1.01714e-08) (1073, -4.65457e-06) (1074, 4.57996e-09) (1077, 4.57996e-09) (1088, 3.97567e-10)
row 1074: (1059, 3.97567e-10) (1071, 1.01714e-08) (1073, 4.57996e-09) (1074, -4.65264e-06) (1075, 8.24672e-09) (1078, 4.57996e-09) (1089, 3.97567e-10)
row 1075: (316, 8.45737e-09) (1060, 3.97568e-10) (1074, 6.49374e-09) (1075, -4.65468e-06) (1079, 8.17103e-09) (1090, 3.97568e-10) (1690, 6.49374e-09)
row 1076: (1061, 3.97568e-10) (1072, 8.17103e-09) (1076, -4.65904e-06) (1077, 1.60186e-08) (1080, 9.7865e-09) (1091, 3.97568e-10)
row 1077: (1062, 3.97567e-10) (1073, 4.57996e-09) (1076, 1.01714e-08) (1077, -4.65457e-06) (1078, 4.57996e-09) (1081, 1.01714e-08) (1092, 3.97567e-10)
row 1078: (1063, 3.97567e-10) (1074, 4.57996e-09) (1077, 4.57996e-09) (1078, -4.65264e-06) (1079, 8.24672e-09) (1082, 1.01714e-08) (1093, 3.97567e-10)
row 1079: (1064, 3.97568e-10) (1075, 8.17103e-09) (1078, 6.49374e-09) (1079, -4.65468e-06) (1083, 8.45737e-09) (1094, 3.97568e-10) (1693, 6.49374e-09)
row 1080: (1065, 3.97568e-10) (1076, 1.76423e-08) (1080, -4.66035e-06) (1081, 1.76423e-08) (1095, 3.97568e-10)
row 1081: (1066, 3.97568e-10) (1077, 1.60186e-08) (1080, 9.7865e-09) (1081, -4.65904e-06) (1082, 8.17103e-09) (1096, 3.97568e-10)
row 1082: (1067, 3.97568e-10) (1078, 1.60186e-08) (1081, 8.17103e-09) (1082, -4.6567e-06) (1083, 7.44615e-09) (1097, 3.97568e-10)
row 1083: (1068, 3.97568e-10) (1079, 1.01642e-08) (1082, 4.47444e-09) (1083, -4.65434e-06) (1098, 3.97568e-10) (1696, 1.01642e-08) (2776, 4.47444e-09)
row 1084: (1069, 3.97571e-10) (1084, -4.6603e-06) (1085, 1.76424e-08) (1087, 1.76424e-08) (1099, 3.97571e-10)
row 1085: (1070, 3.97571e-10) (1084, 9.78657e-09) (1085, -4.65899e-06) (1086, 8.17109e-09) (1088, 1.60188e-08) (1100, 3.97571e-10)
row 1086: (332, 7.44621e-09) (1071, 3.97571e-10) (1085, 8.17109e-09) (1086, -4.65665e-06) (1089, 1.60188e-08) (1101, 3.97571e-10)
row 1087: (1072, 3.97571e-10) (1084, 9.78657e-09) (1087, -4.65899e-06) (1088, 1.60188e-08) (1091, 8.17109e-09) (1102, 3.97571e-10)
row 1088: (1073, 3.9757e-10) (1085, 1.01715e-08) (1087, 1.01715e-08) (1088, -4.65452e-06) (1089, 4.57999e-09) (1092, 4.57999e-09) (1103, 3.9757e-10)
row 1089: (1074, 3.9757e-10) (1086, 1.01715e-08) (1088, 4.57999e-09) (1089, -4.6526e-06) (1090, 8.24678e-09) (1093, 4.57999e-09) (1104, 3.9757e-10)
row 1090: (332, 8.45743e-09) (1075, 3.97571e-10) (1089, 6.49378e-09) (1090, -4.65463e-06) (1094, 8.17109e-09) (1105, 3.97571e-10) (1699, 6.49378e-09)
row 1091: (1076, 3.97571e-10) (1087, 8.17109e-09) (1091, -4.65899e-06) (1092, 1.60188e-08) (1095, 9.78657e-09) (1106, 3.97571e-10)
row 1092: (1077, 3.9757e-10) (1088, 4.57999e-09) (1091, 1.01715e-08) (1092, -4.65452e-06) (1093, 4.57999e-09) (1096, 1.01715e-08) (1107, 3.9757e-10)
row 1093: (1078, 3.9757e-10) (1089, 4.57999e-09) (1092, 4.57999e-09) (1093, -4.6526e-06) (1094, 8.24678e-09) (1097, 1.01715e-08) (1108, 3.9757e-10)
row 1094: (1079, 3.97571e-10) (1090, 8.17109e-09) (1093, 6.49378e-09) (1094, -4.65463e-06) (1098, 8.45743e-09) (1109, 3.97571e-10) (1702, 6.49378e-09)
row 1095: (1080, 3.97571e-10) (1091, 1.76424e-08) (1095, -4.6603e-06) (1096, 1.76424e-08) (1110, 3.97571e-10)
row 1096: (1081, 3.97571e-10) (1092, 1.60188e-08) (1095, 9.78657e-09) (1096, -4.65899e-06) (1097, 8.17109e-09) (1111, 3.97571e-10)
row 1097: (1082, 3.97571e-10) (1093, 1.60188e-08) (1096, 8.17109e-09) (1097, -4.65665e-06) (1098, 7.44621e-09) (1112, 3.97571e-10)
row 1098: (1083, 3.97571e-10) (1094, 1.01642e-08) (1097, 4.47447e-09) (1098, -4.65429e-06) (1113, 3.97571e-10) (1705, 1.01642e-08) (2788, 4.47447e-09)
row 1099: (1084, 3.97574e-10) (1099, -4.6604e-06) (1100, 1.76425e-08) (1102, 1.76425e-08) (1114, 5.39994e-10)
row 1100: (1085, 3.97574e-10) (1099, 9.78664e-09) (1100, -4.65909e-06) (1101, 8.17115e-09) (1103, 1.60189e-08) (1115, 5.39993e-10)
row 1101: (348, 7.44626e-09) (1086, 3.97574e-10) (1100, 8.17115e-09) (1101, -4.65675e-06) (1104, 1.60189e-08) (1116, 5.39993e-10)
row 1102: (1087, 3.97574e-10) (1099, 9.78664e-09) (1102, -4.65909e-06) (1103, 1.60189e-08) (1106, 8.17115e-09) (1117, 5.39993e-10)
row 1103: (1088, 3.97573e-10) (1100, 1.01716e-08) (1102, 1.01716e-08) (1103, -4.65461e-06) (1104, 4.58002e-09) (1107, 4.58002e-09) (1118, 5.39992e-10)
row 1104: (1089, 3.97573e-10) (1101, 1.01716e-08) (1103, 4.58002e-09) (1104, -4.65269e-06) (1105, 8.24684e-09) (1108, 4.58002e-09) (1119, 5.39992e-10)
row 1105: (348, 8.4575e-09) (1090, 3.97574e-10) (1104, 6.49383e-09) (1105, -4.65473e-06) (1109, 8.17115e-09) (1120, 5.39993e-10) (1708, 6.49383e-09)
row 1106: (1091, 3.97574e-10) (1102, 8.17115e-09) (1106, -4.65909e-06) (1107, 1.60189e-08) (1110, 9.78664e-09) (1121, 5.39993e-10)
row 1107: (1092, 3.97573e-10) (1103, 4.58002e-09) (1106, 1.01716e-08) (1107, -4.65461e-06) (1108, 4.58002e-09) (1111, 1.01716e-08) (1122, 5.39992e-10)
row 1108: (1093, 3.97573e-10) (1104, 4.58002e-09) (1107, 4.58002e-09) (1108, -4.65269e-06) (1109, 8.24684e-09) (1112, 1.01716e-08) (1123, 5.39992e-10)
row 1109: (1094, 3.97574e-10) (1105, 8.17115e-09) (1108, 6.49383e-09) (1109, -4.65473e-06) (1113, 8.4575e-09) (1124, 5.39993e-10) (1711, 6.49383e-09)
row 1110: (1095, 3.97574e-10) (1106, 1.76425e-08) (1110, -4.6604e-06) (1111, 1.76425e-08) (1125, 5.39994e-10)
row 1111: (1096, 3.97574e-10) (1107, 1.60189e-08) (1110, 9.78664e-09) (1111, -4.65909e-06) (1112, 8.17115e-09) (1126, 5.39993e-10)
row 1112: (1097, 3.97574e-10) (1108, 1.60189e-08) (1111, 8.17115e-09) (1112, -4.65675e-06) (1113, 7.44626e-09) (1127, 5.39993e-10)
row 1113: (1098, 3.97574e-10) (1109, 1.01643e-08) (1112, 4.4745e-09) (1113, -4.65439e-06) (1128, 5.39994e-10) (1714, 1.01643e-08) (2800, 4.4745e-09)
row 1114: (1099, 1.14306e-09) (1114, -4.66171e-06) (1115, 1.76426e-08) (1117, 1.76426e-08) (1129, 1.14314e-09)
row 1115: (1100, 1.14306e-09) (1114, 9.7867e-09) (1115, -4.6604e-06) (1116, 8.17119e-09) (1118, 1.6019e-08) (1130, 1.14314e-09)
row 1116: (364, 7.4463e-09) (1101, 1.14306e-09) (1115, 8.17119e-09) (1116, -4.65806e-06) (1119, 1.6019e-08) (1131, 1.14314e-09)
row 1117: (1102, 1.14306e-09) (1114, 9.7867e-09) (1117, -4.6604e-06) (1118, 1.6019e-08) (1121, 8.17119e-09) (1132, 1.14314e-09)
row 1118: (1103, 1.14306e-09) (1115, 1.01716e-08) (1117, 1.01716e-08) (1118, -4.65593e-06) (1119, 4.58005e-09) (1122, 4.58005e-09) (1133, 1.14314e-09)
row 1119: (1104, 1.14306e-09) (1116, 1.01716e-08) (1118, 4.58005e-09) (1119, -4.654e-06) (1120, 8.24688e-09) (1123, 4.58005e-09) (1134, 1.14314e-09)
row 1120: (364, 8.45754e-09) (1105, 1.14306e-09) (1119, 6.49386e-09) (1120, -4.65604e-06) (1124, 8.17119e-09) (1135, 1.14314e-09) (1717, 6.49386e-09)
row 1121: (1106, 1.14306e-09) (1117, 8.17119e-09) (1121, -4.6604e-06) (1122, 1.6019e-08) (1125, 9.7867e-09) (1136, 1.14314e-09)
row 1122: (1107, 1.14306e-09) (1118, 4.58005e-09) (1121, 1.01716e-08) (1122, -4.65593e-06) (1123, 4.58005e-09) (1126, 1.01716e-08) (1137, 1.14314e-09)
row 1123: (1108, 1.14306e-09) (1119, 4.58005e-09) (1122, 4.58005e-09) (1123, -4.654e-06) (1124, 8.24688e-09) (1127, 1.01716e-08) (1138, 1.14314e-09)
row 1124: (1109, 1.14306e-09) (1120, 8.17119e-09) (1123, 6.49386e-09) (1124, -4.65604e-06) (1128, 8.45754e-09) (1139, 1.14314e-09) (1720, 6.49386e-09)
row 1125: (1110, 1.14306e-09) (1121, 1.76426e-08) (1125, -4.66171e-06) (1126, 1.76426e-08) (1140, 1.14314e-09)
row 1126: (1111, 1.14306e-09) (1122, 1.6019e-08) (1125, 9.7867e-09) (1126, -4.6604e-06) (1127, 8.17119e-09) (1141, 1.14314e-09)
row 1127: (1112, 1.14306e-09) (1123, 1.6019e-08) (1126, 8.17119e-09) (1127, -4.65806e-06) (1128, 7.4463e-09) (1142, 1.14314e-09)
row 1128: (1113, 1.14306e-09) (1124, 1.01644e-08) (1127, 4.47453e-09) (1128, -4.6557e-06) (1143, 1.14314e-09) (1723, 1.01644e-08) (2812, 4.47453e-09)
row 1129: (1114, 5.40036e-10) (1129, -4.66033e-06) (1130, 1.76427e-08) (1132, 1.76427e-08) (1144, 3.97578e-10)
row 1130: (1115, 5.40036e-10) (1129, 9.78675e-09) (1130, -4.65902e-06) (1131, 8.17124e-09) (1133, 1.6019e-08) (1145, 3.97578e-10)
row 1131: (380, 7.44634e-09) (1116, 5.40036e-10) (1130, 8.17124e-09) (1131, -4.65668e-06) (1134, 1.6019e-08) (1146, 3.97578e-10)
row 1132: (1117, 5.40036e-10) (1129, 9.78675e-09) (1132, -4.65902e-06) (1133, 1.6019e-08) (1136, 8.17124e-09) (1147, 3.97578e-10)
row 1133: (1118, 5.40035e-10) (1130, 1.01717e-08) (1132, 1.01717e-08) (1133, -4.65454e-06) (1134, 4.58007e-09) (1137, 4.58007e-09) (1148, 3.97577e-10)
row 1134: (1119, 5.40035e-10) (1131, 1.01717e-08) (1133, 4.58007e-09) (1134, -4.65262e-06) (1135, 8.24692e-09) (1138, 4.58007e-09) (1149, 3.97577e-10)
row 1135: (380, 8.45759e-09) (1120, 5.40036e-10) (1134, 6.4939e-09) (1135, -4.65466e-06) (1139, 8.17124e-09) (1150, 3.97578e-10) (1726, 6.4939e-09)
row 1136: (1121, 5.40036e-10) (1132, 8.17124e-09) (1136, -4.65902e-06) (1137, 1.6019e-08) (1140, 9.78675e-09) (1151, 3.97578e-10)
row 1137: (1122, 5.40035e-10) (1133, 4.58007e-09) (1136, 1.01717e-08) (1137, -4.65454e-06) (1138, 4.58007e-09) (1141, 1.01717e-08) (1152, 3.97577e-10)
row 1138: (1123, 5.40035e-10) (1134, 4.58007e-09) (1137, 4.58007e-09) (1138, -4.65262e-06) (1139, 8.24692e-09) (1142, 1.01717e-08) (1153, 3.97577e-10)
row 1139: (1124, 5.40036e-10) (1135, 8.17124e-09) (1138, 6.4939e-09) (1139, -4.65466e-06) (1143, 8.45759e-09) (1154, 3.97578e-10) (1729, 6.4939e-09)
row 1140: (1125, 5.40036e-10) (1136, 1.76427e-08) (1140, -4.66033e-06) (1141, 1.76427e-08) (1155, 3.97578e-10)
row 1141: (1126, 5.40036e-10) (1137, 1.6019e-08) (1140, 9.78675e-09) (1141, -4.65902e-06) (1142, 8.17124e-09) (1156, 3.97578e-10)
row 1142: (1127, 5.40036e-10) (1138, 1.6019e-08) (1141, 8.17124e-09) (1142, -4.65668e-06) (1143, 7.44634e-09) (1157, 3.97578e-10)
row 1143: (1128, 5.40036e-10) (1139, 1.01644e-08) (1142, 4.47455e-09) (1143, -4.65432e-06) (1158, 3.97578e-10) (1732, 1.01644e-08) (2824, 4.47455e-09)
row 1144: (1129, 3.97581e-10) (1144, -4.66014e-06) (1145, 1.76429e-08) (1147, 1.76429e-08) (1159, 3.97581e-10)
row 1145: (1130, 3.97581e-10) (1144, 9.78682e-09) (1145, -4.65883e-06) (1146, 8.1713e-09) (1148, 1.60192e-08) (1160, 3.97581e-10)
row 1146: (396, 7.44639e-09) (1131, 3.97581e-10) (1145, 8.1713e-09) (1146, -4.65649e-06) (1149, 1.60192e-08) (1161, 3.97581e-10)
row 1147: (1132, 3.97581e-10) (1144, 9.78682e-09) (1147, -4.65883e-06) (1148, 1.60192e-08) (1151, 8.1713e-09) (1162, 3.97581e-10)
row 1148: (1133, 3.9758e-10) (1145, 1.01718e-08) (1147, 1.01718e-08) (1148, -4.65435e-06) (1149, 4.5801e-09) (1152, 4.5801e-09) (1163, 3.9758e-10)
row 1149: (1134, 3.9758e-10) (1146, 1.01718e-08) (1148, 4.5801e-09) (1149, -4.65243e-06) (1150, 8.24698e-09) (1153, 4.5801e-09) (1164, 3.9758e-10)
row 1150: (396, 8.45765e-09) (1135, 3.97581e-10) (1149, 6.49395e-09) (1150, -4.65447e-06) (1154, 8.1713e-09) (1165, 3.97581e-10) (1735, 6.49395e-09)
row 1151: (1136, 3.97581e-10) (1147, 8.1713e-09) (1151, -4.65883e-06) (1152, 1.60192e-08) (1155, 9.78682e-09) (1166, 3.97581e-10)
row 1152: (1137, 3.9758e-10) (1148, 4.5801e-09) (1151, 1.01718e-08) (1152, -4.65435e-06) (1153, 4.5801e-09) (1156, 1.01718e-08) (1167, 3.9758e-10)
row 1153: (1138, 3.9758e-10) (1149, 4.5801e-09) (1152, 4.5801e-09) (1153, -4.65243e-06) (1154, 8.24698e-09) (1157, 1.01718e-08) (1168, 3.9758e-10)
row 1154: (1139, 3.97581e-10) (1150, 8.1713e-09) (1153, 6.49395e-09) (1154, -4.65447e-06) (1158, 8.45765e-09) (1169, 3.97581e-10) (1738, 6.49395e-09)
row 1155: (1140, 3.97581e-10) (1151, 1.76429e-08) (1155, -4.66014e-06) (1156, 1.76429e-08) (1170, 3.97581e-10)
row 1156: (1141, 3.97581e-10) (1152, 1.60192e-08) (1155, 9.78682e-09) (1156, -4.65883e-06) (1157, 8.1713e-09) (1171, 3.97581e-10)
row 1157: (1142, 3.97581e-10) (1153, 1.60192e-08) (1156, 8.1713e-09) (1157, -4.65649e-06) (1158, 7.44639e-09) (1172, 3.97581e-10)
row 1158: (1143, 3.97581e-10) (1154, 1.01645e-08) (1157, 4.47458e-09) (1158, -4.65413e-06) (1173, 3.97581e-10) (1741, 1.01645e-08) (2836, 4.47458e-09)
row 1159: (1144, 3.97584e-10) (1159, -4.66009e-06) (1160, 1.7643e-08) (1162, 1.7643e-08) (1174, 3.97584e-10)
row 1160: (1145, 3.97584e-10) (1159, 9.78689e-09) (1160, -4.65878e-06) (1161, 8.17135e-09) (1163, 1.60193e-08) (1175, 3.97584e-10)
row 1161: (412, 7.44645e-09) (1146, 3.97584e-10) (1160, 8.17135e-09) (1161, -4.65644e-06) (1164, 1.60193e-08) (1176, 3.97584e-10)
row 1162: (1147, 3.97584e-10) (1159, 9.78689e-09) (1162, -4.65878e-06) (1163, 1.60193e-08) (1166, 8.17135e-09) (1177, 3.97584e-10)
row 1163: (1148, 3.97583e-10) (1160, 1.01718e-08) (1162, 1.01718e-08) (1163, -4.65431e-06) (1164, 4.58014e-09) (1167, 4.58014e-09) (1178, 3.97583e-10)
row 1164: (1149, 3.97583e-10) (1161, 1.01718e-08) (1163, 4.58014e-09) (1164, -4.65238e-06) (1165, 8.24704e-09) (1168, 4.58014e-09) (1179, 3.97583e-10)
row 1165: (412, 8.45771e-09) (1150, 3.97584e-10) (1164, 6.49399e-09) (1165, -4.65442e-06) (1169, 8.17135e-09) (1180, 3.97584e-10) (1744, 6.49399e-09)
row 1166: (1151, 3.97584e-10) (1162, 8.17135e-09) (1166, -4.65878e-06) (1167, 1.60193e-08) (1170, 9.78689e-09) (1181, 3.97584e-10)
row 1167: (1152, 3.97583e-10) (1163, 4.58014e-09) (1166, 1.01718e-08) (1167, -4.65431e-06) (1168, 4.58014e-09) (1171, 1.01718e-08) (1182, 3.97583e-10)
row 1168: (1153, 3.97583e-10) (1164, 4.58014e-09) (1167, 4.58014e-09) (1168, -4.65238e-06) (1169, 8.24704e-09) (1172, 1.01718e-08) (1183, 3.97583e-10)
row 1169: (1154, 3.97584e-10) (1165, 8.17135e-09) (1168, 6.49399e-09) (1169, -4.65442e-06) (1173, 8.45771e-09) (1184, 3.97584e-10) (1747, 6.49399e-09)
row 1170: (1155, 3.97584e-10) (1166, 1.7643e-08) (1170, -4.66009e-06) (1171, 1.7643e-08) (1185, 3.97584e-10)
row 1171: (1156, 3.97584e-10) (1167, 1.60193e-08) (1170, 9.78689e-09) (1171, -4.65878e-06) (1172, 8.17135e-09) (1186, 3.97584e-10)
row 1172: (1157, 3.97584e-10) (1168, 1.60193e-08) (1171, 8.17135e-09) (1172, -4.65644e-06) (1173, 7.44645e-09) (1187, 3.97584e-10)
row 1173: (1158, 3.97584e-10) (1169, 1.01646e-08) (1172, 4.47462e-09) (1173, -4.65408e-06) (1188, 3.97584e-10) (1750, 1.01646e-08) (2848, 4.47462e-09)
row 1174: (1159, 3.97587e-10) (1174, -4.66004e-06) (1175, 1.76431e-08) (1177, 1.76431e-08) (1189, 3.97587e-10)
row 1175: (1160, 3.97586e-10) (1174, 9.78696e-09) (1175, -4.65873e-06) (1176, 8.17141e-09) (1178, 1.60194e-08) (1190, 3.97586e-10)
row 1176: (428, 7.4465e-09) (1161, 3.97586e-10) (1175, 8.17141e-09) (1176, -4.65639e-06) (1179, 1.60194e-08) (1191, 3.97586e-10)
row 1177: (1162, 3.97586e-10) (1174, 9.78696e-09) (1177, -4.65873e-06) (1178, 1.60194e-08) (1181, 8.17141e-09) (1192, 3.97586e-10)
row 1178: (1163, 3.97586e-10) (1175, 1.01719e-08) (1177, 1.01719e-08) (1178, -4.65426e-06) (1179, 4.58017e-09) (1182, 4.58017e-09) (1193, 3.97586e-10)
row 1179: (1164, 3.97586e-10) (1176, 1.01719e-08) (1178, 4.58017e-09) (1179, -4.65233e-06) (1180, 8.2471e-09) (1183, 4.58017e-09) (1194, 3.97586e-10)
row 1180: (428, 8.45777e-09) (1165, 3.97586e-10) (1179, 6.49404e-09) (1180, -4.65437e-06) (1184, 8.17141e-09) (1195, 3.97586e-10) (1753, 6.49404e-09)
row 1181: (1166, 3.97586e-10) (1177, 8.17141e-09) (1181, -4.65873e-06) (1182, 1.60194e-08) (1185, 9.78696e-09) (1196, 3.97586e-10)
row 1182: (1167, 3.97586e-10) (1178, 4.58017e-09) (1181, 1.01719e-08) (1182, -4.65426e-06) (1183, 4.58017e-09) (1186, 1.01719e-08) (1197, 3.97586e-10)
row 1183: (1168, 3.97586e-10) (1179, 4.58017e-09) (1182, 4.58017e-09) (1183, -4.65233e-06) (1184, 8.2471e-09) (1187, 1.01719e-08) (1198, 3.97586e-10)
row 1184: (1169, 3.97586e-10) (1180, 8.17141e-09) (1183, 6.49404e-09) (1184, -4.65437e-06) (1188, 8.45777e-09) (1199, 3.97586e-10) (1756, 6.49404e-09)
row 1185: (1170, 3.97587e-10) (1181, 1.76431e-08) (1185, -4.66004e-06) (1186, 1.76431e-08) (1200, 3.97587e-10)
row 1186: (1171, 3.97586e-10) (1182, 1.60194e-08) (1185, 9.78696e-09) (1186, -4.65873e-06) (1187, 8.17141e-09) (1201, 3.97586e-10)
row 1187: (1172, 3.97586e-10) (1183, 1.60194e-08) (1186, 8.17141e-09) (1187, -4.65639e-06) (1188, 7.4465e-09) (1202, 3.97586e-10)
row 1188: (1173, 3.97587e-10) (1184, 1.01647e-08) (1187, 4.47465e-09) (1188, -4.65403e-06) (1203, 3.97587e-10) (1759, 1.01647e-08) (2860, 4.47465e-09)
row 1189: (1174, 3.9759e-10) (1189, -4.65999e-06) (1190, 1.76432e-08) (1192, 1.76432e-08) (1204, 3.9759e-10)
row 1190: (1175, 3.97589e-10) (1189, 9.78703e-09) (1190, -4.65868e-06) (1191, 8.17147e-09) (1193, 1.60195e-08) (1205, 3.97589e-10)
row 1191: (444, 7.44656e-09) (1176, 3.97589e-10) (1190, 8.17147e-09) (1191, -4.65634e-06) (1194, 1.60195e-08) (1206, 3.97589e-10)
row 1192: (1177, 3.97589e-10) (1189, 9.78703e-09) (1192, -4.65868e-06) (1193, 1.60195e-08) (1196, 8.17147e-09) (1207, 3.97589e-10)
row 1193: (1178, 3.97588e-10) (1190, 1.0172e-08) (1192, 1.0172e-08) (1193, -4.65421e-06) (1194, 4.5802e-09) (1197, 4.5802e-09) (1208, 3.97588e-10)
row 1194: (1179, 3.97588e-10) (1191, 1.0172e-08) (1193, 4.5802e-09) (1194, -4.65229e-06) (1195, 8.24716e-09) (1198, 4.5802e-09) (1209, 3.97588e-10)
row 1195: (444, 8.45783e-09) (1180, 3.97589e-10) (1194, 6.49409e-09) (1195, -4.65432e-06) (1199, 8.17147e-09) (1210, 3.97589e-10) (1762, 6.49409e-09)
row 1196: (1181, 3.97589e-10) (1192, 8.17147e-09) (1196, -4.65868e-06) (1197, 1.60195e-08) (1200, 9.78703e-09) (1211, 3.97589e-10)
row 1197: (1182, 3.97588e-10) (1193, 4.5802e-09) (1196, 1.0172e-08) (1197, -4.65421e-06) (1198, 4.5802e-09) (1201, 1.0172e-08) (1212, 3.97588e-10)
row 1198: (1183, 3.97588e-10) (1194, 4.5802e-09) (1197, 4.5802e-09) (1198, -4.65229e-06) (1199, 8.24716e-09) (1202, 1.0172e-08) (1213, 3.97588e-10)
row 1199: (1184, 3.97589e-10) (1195, 8.17147e-09) (1198, 6.49409e-09) (1199, -4.65432e-06) (1203, 8.45783e-09) (1214, 3.97589e-10) (1765, 6.49409e-09)
row 1200: (1185, 3.9759e-10) (1196, 1.76432e-08) (1200, -4.65999e-06) (1201, 1.76432e-08) (1215, 3.9759e-10)
row 1201: (1186, 3.97589e-10) (1197, 1.60195e-08) (1200, 9.78703e-09) (1201, -4.65868e-06) (1202, 8.17147e-09) (1216, 3.97589e-10)
row 1202: (1187, 3.97589e-10) (1198, 1.60195e-08) (1201, 8.17147e-09) (1202, -4.65634e-06) (1203, 7.44656e-09) (1217, 3.97589e-10)
row 1203: (1188, 3.9759e-10) (1199, 1.01647e-08) (1202, 4.47468e-09) (1203, -4.65399e-06) (1218, 3.9759e-10) (1768, 1.01647e-08) (2872, 4.47468e-09)
row 1204: (1189, 3.97592e-10) (1204, -4.66009e-06) (1205, 1.76434e-08) (1207, 1.76434e-08) (1219, 5.40019e-10)
row 1205: (1190, 3.97592e-10) (1204, 9.7871e-09) (1205, -4.65878e-06) (1206, 8.17153e-09) (1208, 1.60196e-08) (1220, 5.40019e-10)
row 1206: (460, 7.44661e-09) (1191, 3.97592e-10) (1205, 8.17153e-09) (1206, -4.65644e-06) (1209, 1.60196e-08) (1221, 5.40019e-10)
row 1207: (1192, 3.97592e-10) (1204, 9.7871e-09) (1207, -4.65878e-06) (1208, 1.60196e-08) (1211, 8.17153e-09) (1222, 5.40019e-10)
row 1208: (1193, 3.97591e-10) (1205, 1.01721e-08) (1207, 1.01721e-08) (1208, -4.65431e-06) (1209, 4.58024e-09) (1212, 4.58024e-09) (1223, 5.40018e-10)
row 1209: (1194, 3.97591e-10) (1206, 1.01721e-08) (1208, 4.58024e-09) (1209, -4.65238e-06) (1210, 8.24722e-09) (1213, 4.58024e-09) (1224, 5.40018e-10)
row 1210: (460, 8.45789e-09) (1195, 3.97592e-10) (1209, 6.49414e-09) (1210, -4.65442e-06) (1214, 8.17153e-09) (1225, 5.40019e-10) (1771, 6.49414e-09)
row 1211: (1196, 3.97592e-10) (1207, 8.17153e-09) (1211, -4.65878e-06) (1212, 1.60196e-08) (1215, 9.7871e-09) (1226, 5.40019e-10)
row 1212: (1197, 3.97591e-10) (1208, 4.58024e-09) (1211, 1.01721e-08) (1212, -4.65431e-06) (1213, 4.58024e-09) (1216, 1.01721e-08) (1227, 5.40018e-10)
row 1213: (1198, 3.97591e-10) (1209, 4.58024e-09) (1212, 4.58024e-09) (1213, -4.65238e-06) (1214, 8.24722e-09) (1217, 1.01721e-08) (1228, 5.40018e-10)
row 1214: (1199, 3.97592e-10) (1210, 8.17153e-09) (1213, 6.49414e-09) (1214, -4.65442e-06) (1218, 8.45789e-09) (1229, 5.40019e-10) (1774, 6.49414e-09)
row 1215: (1200, 3.97592e-10) (1211, 1.76434e-08) (1215, -4.66009e-06) (1216, 1.76434e-08) (1230, 5.40019e-10)
row 1216: (1201, 3.97592e-10) (1212, 1.60196e-08) (1215, 9.7871e-09) (1216, -4.65878e-06) (1217, 8.17153e-09) (1231, 5.40019e-10)
row 1217: (1202, 3.97592e-10) (1213, 1.60196e-08) (1216, 8.17153e-09) (1217, -4.65644e-06) (1218, 7.44661e-09) (1232, 5.40019e-10)
row 1218: (1203, 3.97592e-10) (1214, 1.01648e-08) (1217, 4.47471e-09) (1218, -4.65408e-06) (1233, 5.40019e-10) (1777, 1.01648e-08) (2884, 4.47471e-09)
row 1219: (1204, 1.14312e-09) (1219, -4.6614e-06) (1220, 1.76435e-08) (1222, 1.76435e-08) (1234, 1.1432e-09)
row 1220: (1205, 1.14312e-09) (1219, 9.78716e-09) (1220, -4.66009e-06) (1221, 8.17158e-09) (1223, 1.60197e-08) (1235, 1.14319e-09)
row 1221: (476, 7.44665e-09) (1206, 1.14312e-09) (1220, 8.17158e-09) (1221, -4.65775e-06) (1224, 1.60197e-08) (1236, 1.14319e-09)
row 1222: (1207, 1.14312e-09) (1219, 9.78716e-09) (1222, -4.66009e-06) (1223, 1.60197e-08) (1226, 8.17158e-09) (1237, 1.14319e-09)
row 1223: (1208, 1.14311e-09) (1220, 1.01721e-08) (1222, 1.01721e-08) (1223, -4.65562e-06) (1224, 4.58026e-09) (1227, 4.58026e-09) (1238, 1.14319e-09)
row 1224: (1209, 1.14311e-09) (1221, 1.01721e-08) (1223, 4.58026e-09) (1224, -4.65369e-06) (1225, 8.24727e-09) (1228, 4.58026e-09) (1239, 1.14319e-09)
row 1225: (476, 8.45794e-09) (1210, 1.14312e-09) (1224, 6.49417e-09) (1225, -4.65573e-06) (1229, 8.17158e-09) (1240, 1.14319e-09) (1780, 6.49417e-09)
row 1226: (1211, 1.14312e-09) (1222, 8.17158e-09) (1226, -4.66009e-06) (1227, 1.60197e-08) (1230, 9.78716e-09) (1241, 1.14319e-09)
row 1227: (1212, 1.14311e-09) (1223, 4.58026e-09) (1226, 1.01721e-08) (1227, -4.65562e-06) (1228, 4.58026e-09) (1231, 1.01721e-08) (1242, 1.14319e-09)
row 1228: (1213, 1.14311e-09) (1224, 4.58026e-09) (1227, 4.58026e-09) (1228, -4.65369e-06) (1229, 8.24727e-09) (1232, 1.01721e-08) (1243, 1.14319e-09)
row 1229: (1214, 1.14312e-09) (1225, 8.17158e-09) (1228, 6.49417e-09) (1229, -4.65573e-06) (1233, 8.45794e-09) (1244, 1.14319e-09) (1783, 6.49417e-09)
row 1230: (1215, 1.14312e-09) (1226, 1.76435e-08) (1230, -4.6614e-06) (1231, 1.76435e-08) (1245, 1.1432e-09)
row 1231: (1216, 1.14312e-09) (1227, 1.60197e-08) (1230, 9.78716e-09) (1231, -4.66009e-06) (1232, 8.17158e-09) (1246, 1.14319e-09)
row 1232: (1217, 1.14312e-09) (1228, 1.60197e-08) (1231, 8.17158e-09) (1232, -4.65775e-06) (1233, 7.44665e-09) (1247, 1.14319e-09)
row 1233: (1218, 1.14312e-09) (1229, 1.01649e-08) (1232, 4.47474e-09) (1233, -4.65539e-06) (1248, 1.1432e-09) (1786, 1.01649e-08) (2896, 4.47474e-09)
row 1234: (1219, 5.40062e-10) (1234, -4.66002e-06) (1235, 1.76436e-08) (1237, 1.76436e-08) (1249, 3.97597e-10)
row 1235: (1220, 5.40061e-10) (1234, 9.78721e-09) (1235, -4.65871e-06) (1236, 8.17162e-09) (1238, 1.60198e-08) (1250, 3.97596e-10)
row 1236: (492, 7.44669e-09) (1221, 5.40061e-10) (1235, 8.17162e-09) (1236, -4.65637e-06) (1239, 1.60198e-08) (1251, 3.97596e-10)
row 1237: (1222, 5.40061e-10) (1234, 9.78721e-09) (1237, -4.65871e-06) (1238, 1.60198e-08) (1241, 8.17162e-09) (1252, 3.97596e-10)
row 1238: (1223, 5.4006e-10) (1235, 1.01722e-08) (1237, 1.01722e-08) (1238, -4.65424e-06) (1239, 4.58029e-09) (1242, 4.58029e-09) (1253, 3.97596e-10)
row 1239: (1224, 5.4006e-10) (1236, 1.01722e-08) (1238, 4.58029e-09) (1239, -4.65231e-06) (1240, 8.24731e-09) (1243, 4.58029e-09) (1254, 3.97596e-10)
row 1240: (492, 8.45798e-09) (1225, 5.40061e-10) (1239, 6.49421e-09) (1240, -4.65435e-06) (1244, 8.17162e-09) (1255, 3.97596e-10) (1789, 6.49421e-09)
row 1241: (1226, 5.40061e-10) (1237, 8.17162e-09) (1241, -4.65871e-06) (1242, 1.60198e-08) (1245, 9.78721e-09) (1256, 3.97596e-10)
row 1242: (1227, 5.4006e-10) (1238, 4.58029e-09) (1241, 1.01722e-08) (1242, -4.65424e-06) (1243, 4.58029e-09) (1246, 1.01722e-08) (1257, 3.97596e-10)
row 1243: (1228, 5.4006e-10) (1239, 4.58029e-09) (1242, 4.58029e-09) (1243, -4.65231e-06) (1244, 8.24731e-09) (1247, 1.01722e-08) (1258, 3.97596e-10)
row 1244: (1229, 5.40061e-10) (1240, 8.17162e-09) (1243, 6.49421e-09) (1244, -4.65435e-06) (1248, 8.45798e-09) (1259, 3.97596e-10) (1792, 6.49421e-09)
row 1245: (1230, 5.40062e-10) (1241, 1.76436e-08) (1245, -4.66002e-06) (1246, 1.76436e-08) (1260, 3.97597e-10)
row 1246: (1231, 5.40061e-10) (1242, 1.60198e-08) (1245, 9.78721e-09) (1246, -4.65871e-06) (1247, 8.17162e-09) (1261, 3.97596e-10)
row 1247: (1232, 5.40061e-10) (1243, 1.60198e-08) (1246, 8.17162e-09) (1247, -4.65637e-06) (1248, 7.44669e-09) (1262, 3.97596e-10)
row 1248: (1233, 5.40062e-10) (1244, 1.01649e-08) (1247, 4.47476e-09) (1248, -4.65401e-06) (1263, 3.97597e-10) (1795, 1.01649e-08) (2908, 4.47476e-09)
row 1249: (1234, 3.976e-10) (1249, -4.65983e-06) (1250, 1.76437e-08) (1252, 1.76437e-08) (1264, 3.976e-10)
row 1250: (1235, 3.97599e-10) (1249, 9.78728e-09) (1250, -4.65852e-06) (1251, 8.17168e-09) (1253, 1.60199e-08) (1265, 3.97599e-10)
row 1251: (508, 7.44675e-09) (1236, 3.97599e-10) (1250, 8.17168e-09) (1251, -4.65618e-06) (1254, 1.60199e-08) (1266, 3.97599e-10)
row 1252: (1237, 3.97599e-10) (1249, 9.78728e-09) (1252, -4.65852e-06) (1253, 1.60199e-08) (1256, 8.17168e-09) (1267, 3.97599e-10)
row 1253: (1238, 3.97598e-10) (1250, 1.01722e-08) (1252, 1.01722e-08) (1253, -4.65405e-06) (1254, 4.58032e-09) (1257, 4.58032e-09) (1268, 3.97598e-10)
row 1254: (1239, 3.97598e-10) (1251, 1.01722e-08) (1253, 4.58032e-09) (1254, -4.65212e-06) (1255, 8.24737e-09) (1258, 4.58032e-09) (1269, 3.97598e-10)
row 1255: (508, 8.45805e-09) (1240, 3.97599e-10) (1254, 6.49425e-09) (1255, -4.65416e-06) (1259, 8.17168e-09) (1270, 3.97599e-10) (1798, 6.49425e-09)
row 1256: (1241, 3.97599e-10) (1252, 8.17168e-09) (1256, -4.65852e-06) (1257, 1.60199e-08) (1260, 9.78728e-09) (1271, 3.97599e-10)
row 1257: (1242, 3.97598e-10) (1253, 4.58032e-09) (1256, 1.01722e-08) (1257, -4.65405e-06) (1258, 4.58032e-09) (1261, 1.01722e-08) (1272, 3.97598e-10)
row 1258: (1243, 3.97598e-10) (1254, 4.58032e-09) (1257, 4.58032e-09) (1258, -4.65212e-06) (1259, 8.24737e-09) (1262, 1.01722e-08) (1273, 3.97598e-10)
row 1259: (1244, 3.97599e-10) (1255, 8.17168e-09) (1258, 6.49425e-09) (1259, -4.65416e-06) (1263, 8.45805e-09) (1274, 3.97599e-10) (1801, 6.49425e-09)
row 1260: (1245, 3.976e-10) (1256, 1.76437e-08) (1260, -4.65983e-06) (1261, 1.76437e-08) (1275, 3.976e-10)
row 1261: (1246, 3.97599e-10) (1257, 1.60199e-08) (1260, 9.78728e-09) (1261, -4.65852e-06) (1262, 8.17168e-09) (1276, 3.97599e-10)
row 1262: (1247, 3.97599e-10) (1258, 1.60199e-08) (1261, 8.17168e-09) (1262, -4.65618e-06) (1263, 7.44675e-09) (1277, 3.97599e-10)
row 1263: (1248, 3.976e-10) (1259, 1.0165e-08) (1262, 4.4748e-09) (1263, -4.65382e-06) (1278, 3.976e-10) (1804, 1.0165e-08) (2920, 4.4748e-09)
row 1264: (1249, 3.97603e-10) (1264, -4.65978e-06) (1265, 1.76438e-08) (1267, 1.76438e-08) (1279, 3.97603e-10)
row 1265: (1250, 3.97602e-10) (1264, 9.78735e-09) (1265, -4.65847e-06) (1266, 8.17174e-09) (1268, 1.602e-08) (1280, 3.97602e-10)
row 1266: (524, 7.4468e-09) (1251, 3.97602e-10) (1265, 8.17174e-09) (1266, -4.65613e-06) (1269, 1.602e-08) (1281, 3.97602e-10)
row 1267: (1252, 3.97602e-10) (1264, 9.78735e-09) (1267, -4.65847e-06) (1268, 1.602e-08) (1271, 8.17174e-09) (1282, 3.97602e-10)
row 1268: (1253, 3.97601e-10) (1265, 1.01723e-08) (1267, 1.01723e-08) (1268, -4.654e-06) (1269, 4.58035e-09) (1272, 4.58035e-09) (1283, 3.97601e-10)
row 1269: (1254, 3.97601e-10) (1266, 1.01723e-08) (1268, 4.58035e-09) (1269, -4.65207e-06) (1270, 8.24743e-09) (1273, 4.58035e-09) (1284, 3.97601e-10)
row 1270: (524, 8.45811e-09) (1255, 3.97602e-10) (1269, 6.4943e-09) (1270, -4.65411e-06) (1274, 8.17174e-09) (1285, 3.97602e-10) (1807, 6.4943e-09)
row 1271: (1256, 3.97602e-10) (1267, 8.17174e-09) (1271, -4.65847e-06) (1272, 1.602e-08) (1275, 9.78735e-09) (1286, 3.97602e-10)
row 1272: (1257, 3.97601e-10) (1268, 4.58035e-09) (1271, 1.01723e-08) (1272, -4.654e-06) (1273, 4.58035e-09) (1276, 1.01723e-08) (1287, 3.97601e-10)
row 1273: (1258, 3.97601e-10) (1269, 4.58035e-09) (1272, 4.58035e-09) (1273, -4.65207e-06) (1274, 8.24743e-09) (1277, 1.01723e-08) (1288, 3.97601e-10)
row 1274: (1259, 3.97602e-10) (1270, 8.17174e-09) (1273, 6.4943e-09) (1274, -4.65411e-06) (1278, 8.45811e-09) (1289, 3.97602e-10) (1810, 6.4943e-09)
row 1275: (1260, 3.97603e-10) (1271, 1.76438e-08) (1275, -4.65978e-06) (1276, 1.76438e-08) (1290, 3.97603e-10)
row 1276: (1261, 3.97602e-10) (1272, 1.602e-08) (1275, 9.78735e-09) (1276, -4.65847e-06) (1277, 8.17174e-09) (1291, 3.97602e-10)
row 1277: (1262, 3.97602e-10) (1273, 1.602e-08) (1276, 8.17174e-09) (1277, -4.65613e-06) (1278, 7.4468e-09) (1292, 3.97602e-10)
row 1278: (1263, 3.97603e-10) (1274, 1.01651e-08) (1277, 4.47483e-09) (1278, -4.65377e-06) (1293, 3.97603e-10) (1813, 1.01651e-08) (2932, 4.47483e-09)
row 1279: (1264, 3.97605e-10) (1279, -4.65973e-06) (1280, 1.76439e-08) (1282, 1.76439e-08) (1294, 3.97605e-10)
row 1280: (1265, 3.97605e-10) (1279, 9.78742e-09) (1280, -4.65842e-06) (1281, 8.1718e-09) (1283, 1.60201e-08) (1295, 3.97605e-10)
row 1281: (540, 7.44685e-09) (1266, 3.97605e-10) (1280, 8.1718e-09) (1281, -4.65608e-06) (1284, 1.60201e-08) (1296, 3.97605e-10)
row 1282: (1267, 3.97605e-10) (1279, 9.78742e-09) (1282, -4.65842e-06) (1283, 1.60201e-08) (1286, 8.1718e-09) (1297, 3.97605e-10)
row 1283: (1268, 3.97604e-10) (1280, 1.01724e-08) (1282, 1.01724e-08) (1283, -4.65395e-06) (1284, 4.58039e-09) (1287, 4.58039e-09) (1298, 3.97604e-10)
row 1284: (1269, 3.97604e-10) (1281, 1.01724e-08) (1283, 4.58039e-09) (1284, -4.65203e-06) (1285, 8.24749e-09) (1288, 4.58039e-09) (1299, 3.97604e-10)
row 1285: (540, 8.45817e-09) (1270, 3.97605e-10) (1284, 6.49435e-09) (1285, -4.65406e-06) (1289, 8.1718e-09) (1300, 3.97605e-10) (1816, 6.49435e-09)
row 1286: (1271, 3.97605e-10) (1282, 8.1718e-09) (1286, -4.65842e-06) (1287, 1.60201e-08) (1290, 9.78742e-09) (1301, 3.97605e-10)
row 1287: (1272, 3.97604e-10) (1283, 4.58039e-09) (1286, 1.01724e-08) (1287, -4.65395e-06) (1288, 4.58039e-09) (1291, 1.01724e-08) (1302, 3.97604e-10)
row 1288: (1273, 3.97604e-10) (1284, 4.58039e-09) (1287, 4.58039e-09) (1288, -4.65203e-06) (1289, 8.24749e-09) (1292, 1.01724e-08) (1303, 3.97604e-10)
row 1289: (1274, 3.97605e-10) (1285, 8.1718e-09) (1288, 6.49435e-09) (1289, -4.65406e-06) (1293, 8.45817e-09) (1304, 3.97605e-10) (1819, 6.49435e-09)
row 1290: (1275, 3.97605e-10) (1286, 1.76439e-08) (1290, -4.65973e-06) (1291, 1.76439e-08) (1305, 3.97605e-10)
row 1291: (1276, 3.97605e-10) (1287, 1.60201e-08) (1290, 9.78742e-09) (1291, -4.65842e-06) (1292, 8.1718e-09) (1306, 3.97605e-10)
row 1292: (1277, 3.97605e-10) (1288, 1.60201e-08) (1291, 8.1718e-09) (1292, -4.65608e-06) (1293, 7.44685e-09) (1307, 3.97605e-10)
row 1293: (1278, 3.97605e-10) (1289, 1.01651e-08) (1292, 4.47486e-09) (1293, -4.65372e-06) (1308, 3.97605e-10) (1822, 1.01651e-08) (2944, 4.47486e-09)
row 1294: (1279, 3.97608e-10) (1294, -4.65969e-06) (1295, 1.76441e-08) (1297, 1.76441e-08) (1309, 3.97608e-10)
row 1295: (1280, 3.97608e-10) (1294, 9.78749e-09) (1295, -4.65838e-06) (1296, 8.17186e-09) (1298, 1.60203e-08) (1310, 3.97608e-10)
row 1296: (556, 7.44691e-09) (1281, 3.97608e-10) (1295, 8.17186e-09) (1296, -4.65604e-06) (1299, 1.60203e-08) (1311, 3.97608e-10)
row 1297: (1282, 3.97608e-10) (1294, 9.78749e-09) (1297, -4.65838e-06) (1298, 1.60203e-08) (1301, 8.17186e-09) (1312, 3.97608e-10)
row 1298: (1283, 3.97607e-10) (1295, 1.01725e-08) (1297, 1.01725e-08) (1298, -4.6539e-06) (1299, 4.58042e-09) (1302, 4.58042e-09) (1313, 3.97607e-10)
row 1299: (1284, 3.97607e-10) (1296, 1.01725e-08) (1298, 4.58042e-09) (1299, -4.65198e-06) (1300, 8.24755e-09) (1303, 4.58042e-09) (1314, 3.97607e-10)
row 1300: (556, 8.45823e-09) (1285, 3.97608e-10) (1299, 6.49439e-09) (1300, -4.65402e-06) (1304, 8.17186e-09) (1315, 3.97608e-10) (1825, 6.49439e-09)
row 1301: (1286, 3.97608e-10) (1297, 8.17186e-09) (1301, -4.65838e-06) (1302, 1.60203e-08) (1305, 9.78749e-09) (1316, 3.97608e-10)
row 1302: (1287, 3.97607e-10) (1298, 4.58042e-09) (1301, 1.01725e-08) (1302, -4.6539e-06) (1303, 4.58042e-09) (1306, 1.01725e-08) (1317, 3.97607e-10)
row 1303: (1288, 3.97607e-10) (1299, 4.58042e-09) (1302, 4.58042e-09) (1303, -4.65198e-06) (1304, 8.24755e-09) (1307, 1.01725e-08) (1318, 3.97607e-10)
row 1304: (1289, 3.97608e-10) (1300, 8.17186e-09) (1303, 6.49439e-09) (1304, -4.65402e-06) (1308, 8.45823e-09) (1319, 3.97608e-10) (1828, 6.49439e-09)
row 1305: (1290, 3.97608e-10) (1301, 1.76441e-08) (1305, -4.65969e-06) (1306, 1.76441e-08) (1320, 3.97608e-10)
row 1306: (1291, 3.97608e-10) (1302, 1.60203e-08) (1305, 9.78749e-09) (1306, -4.65838e-06) (1307, 8.17186e-09) (1321, 3.97608e-10)
row 1307: (1292, 3.97608e-10) (1303, 1.60203e-08) (1306, 8.17186e-09) (1307, -4.65604e-06) (1308, 7.44691e-09) (1322, 3.97608e-10)
row 1308: (1293, 3.97608e-10) (1304, 1.01652e-08) (1307, 4.47489e-09) (1308, -4.65368e-06) (1323, 3.97608e-10) (1831, 1.01652e-08) (2956, 4.47489e-09)
row 1309: (1294, 3.97611e-10) (1309, -4.65978e-06) (1310, 1.76442e-08) (1312, 1.76442e-08) (1324, 5.40045e-10)
row 1310: (1295, 3.97611e-10) (1309, 9.78757e-09) (1310, -4.65847e-06) (1311, 8.17192e-09) (1313, 1.60204e-08) (1325, 5.40044e-10)
row 1311: (572, 7.44696e-09) (1296, 3.97611e-10) (1310, 8.17192e-09) (1311, -4.65613e-06) (1314, 1.60204e-08) (1326, 5.40044e-10)
row 1312: (1297, 3.97611e-10) (1309, 9.78757e-09) (1312, -4.65847e-06) (1313, 1.60204e-08) (1316, 8.17192e-09) (1327, 5.40044e-10)
row 1313: (1298, 3.9761e-10) (1310, 1.01725e-08) (1312, 1.01725e-08) (1313, -4.654e-06) (1314, 4.58045e-09) (1317, 4.58045e-09) (1328, 5.40043e-10)
row 1314: (1299, 3.9761e-10) (1311, 1.01725e-08) (1313, 4.58045e-09) (1314, -4.65207e-06) (1315, 8.24761e-09) (1318, 4.58045e-09) (1329, 5.40043e-10)
row 1315: (572, 8.45829e-09) (1300, 3.97611e-10) (1314, 6.49444e-09) (1315, -4.65411e-06) (1319, 8.17192e-09) (1330, 5.40044e-10) (1834, 6.49444e-09)
row 1316: (1301, 3.97611e-10) (1312, 8.17192e-09) (1316, -4.65847e-06) (1317, 1.60204e-08) (1320, 9.78757e-09) (1331, 5.40044e-10)
row 1317: (1302, 3.9761e-10) (1313, 4.58045e-09) (1316, 1.01725e-08) (1317, -4.654e-06) (1318, 4.58045e-09) (1321, 1.01725e-08) (1332, 5.40043e-10)
row 1318: (1303, 3.9761e-10) (1314, 4.58045e-09) (1317, 4.58045e-09) (1318, -4.65207e-06) (1319, 8.24761e-09) (1322, 1.01725e-08) (1333, 5.40043e-10)
row 1319: (1304, 3.97611e-10) (1315, 8.17192e-09) (1318, 6.49444e-09) (1319, -4.65411e-06) (1323, 8.45829e-09) (1334, 5.40044e-10) (1837, 6.49444e-09)
row 1320: (1305, 3.97611e-10) (1316, 1.76442e-08) (1320, -4.65978e-06) (1321, 1.76442e-08) (1335, 5.40045e-10)
row 1321: (1306, 3.97611e-10) (1317, 1.60204e-08) (1320, 9.78757e-09) (1321, -4.65847e-06) (1322, 8.17192e-09) (1336, 5.40044e-10)
row 1322: (1307, 3.97611e-10) (1318, 1.60204e-08) (1321, 8.17192e-09) (1322, -4.65613e-06) (1323, 7.44696e-09) (1337, 5.40044e-10)
row 1323: (1308, 3.97611e-10) (1319, 1.01653e-08) (1322, 4.47493e-09) (1323, -4.65377e-06) (1338, 5.40045e-10) (1840, 1.01653e-08) (2968, 4.47493e-09)
row 1324: (1309, 1.14317e-09) (1324, -4.66109e-06) (1325, 1.76443e-08) (1327, 1.76443e-08) (1339, 1.14325e-09)
row 1325: (1310, 1.14317e-09) (1324, 9.78762e-09) (1325, -4.65978e-06) (1326, 8.17196e-09) (1328, 1.60205e-08) (1340, 1.14325e-09)
row 1326: (588, 7.447e-09) (1311, 1.14317e-09) (1325, 8.17196e-09) (1326, -4.65744e-06) (1329, 1.60205e-08) (1341, 1.14325e-09)
row 1327: (1312, 1.14317e-09) (1324, 9.78762e-09) (1327, -4.65978e-06) (1328, 1.60205e-08) (1331, 8.17196e-09) (1342, 1.14325e-09)
row 1328: (1313, 1.14317e-09) (1325, 1.01726e-08) (1327, 1.01726e-08) (1328, -4.65531e-06) (1329, 4.58048e-09) (1332, 4.58048e-09) (1343, 1.14325e-09)
row 1329: (1314, 1.14317e-09) (1326, 1.01726e-08) (1328, 4.58048e-09) (1329, -4.65339e-06) (1330, 8.24766e-09) (1333, 4.58048e-09) (1344, 1.14325e-09)
row 1330: (588, 8.45834e-09) (1315, 1.14317e-09) (1329, 6.49448e-09) (1330, -4.65542e-06) (1334, 8.17196e-09) (1345, 1.14325e-09) (1843, 6.49448e-09)
row 1331: (1316, 1.14317e-09) (1327, 8.17196e-09) (1331, -4.65978e-06) (1332, 1.60205e-08) (1335, 9.78762e-09) (1346, 1.14325e-09)
row 1332: (1317, 1.14317e-09) (1328, 4.58048e-09) (1331, 1.01726e-08) (1332, -4.65531e-06) (1333, 4.58048e-09) (1336, 1.01726e-08) (1347, 1.14325e-09)
row 1333: (1318, 1.14317e-09) (1329, 4.58048e-09) (1332, 4.58048e-09) (1333, -4.65339e-06) (1334, 8.24766e-09) (1337, 1.01726e-08) (1348, 1.14325e-09)
row 1334: (1319, 1.14317e-09) (1330, 8.17196e-09) (1333, 6.49448e-09) (1334, -4.65542e-06) (1338, 8.45834e-09) (1349, 1.14325e-09) (1846, 6.49448e-09)
row 1335: (1320, 1.14317e-09) (1331, 1.76443e-08) (1335, -4.66109e-06) (1336, 1.76443e-08) (1350, 1.14325e-09)
row 1336: (1321, 1.14317e-09) (1332, 1.60205e-08) (1335, 9.78762e-09) (1336, -4.65978e-06) (1337, 8.17196e-09) (1351, 1.14325e-09)
row 1337: (1322, 1.14317e-09) (1333, 1.60205e-08) (1336, 8.17196e-09) (1337, -4.65744e-06) (1338, 7.447e-09) (1352, 1.14325e-09)
row 1338: (1323, 1.14317e-09) (1334, 1.01653e-08) (1337, 4.47495e-09) (1338, -4.65509e-06) (1353, 1.14325e-09) (1849, 1.01653e-08) (2980, 4.47495e-09)
row 1339: (1324, 5.40087e-10) (1339, -4.65971e-06) (1340, 1.76444e-08) (1342, 1.76444e-08) (1354, 3.97615e-10)
row 1340: (1325, 5.40087e-10) (1339, 9.78767e-09) (1340, -4.6584e-06) (1341, 8.17201e-09) (1343, 1.60205e-08) (1355, 3.97615e-10)
row 1341: (604, 7.44704e-09) (1326, 5.40087e-10) (1340, 8.17201e-09) (1341, -4.65606e-06) (1344, 1.60205e-08) (1356, 3.97615e-10)
row 1342: (1327, 5.40087e-10) (1339, 9.78767e-09) (1342, -4.6584e-06) (1343, 1.60205e-08) (1346, 8.17201e-09) (1357, 3.97615e-10)
row 1343: (1328, 5.40086e-10) (1340, 1.01726e-08) (1342, 1.01726e-08) (1343, -4.65393e-06) (1344, 4.5805e-09) (1347, 4.5805e-09) (1358, 3.97614e-10)
row 1344: (1329, 5.40086e-10) (1341, 1.01726e-08) (1343, 4.5805e-09) (1344, -4.652e-06) (1345, 8.2477e-09) (1348, 4.5805e-09) (1359, 3.97614e-10)
row 1345: (604, 8.45838e-09) (1330, 5.40087e-10) (1344, 6.49451e-09) (1345, -4.65404e-06) (1349, 8.17201e-09) (1360, 3.97615e-10) (1852, 6.49451e-09)
row 1346: (1331, 5.40087e-10) (1342, 8.17201e-09) (1346, -4.6584e-06) (1347, 1.60205e-08) (1350, 9.78767e-09) (1361, 3.97615e-10)
row 1347: (1332, 5.40086e-10) (1343, 4.5805e-09) (1346, 1.01726e-08) (1347, -4.65393e-06) (1348, 4.5805e-09) (1351, 1.01726e-08) (1362, 3.97614e-10)
row 1348: (1333, 5.40086e-10) (1344, 4.5805e-09) (1347, 4.5805e-09) (1348, -4.652e-06) (1349, 8.2477e-09) (1352, 1.01726e-08) (1363, 3.97614e-10)
row 1349: (1334, 5.40087e-10) (1345, 8.17201e-09) (1348, 6.49451e-09) (1349, -4.65404e-06) (1353, 8.45838e-09) (1364, 3.97615e-10) (1855, 6.49451e-09)
row 1350: (1335, 5.40087e-10) (1346, 1.76444e-08) (1350, -4.65971e-06) (1351, 1.76444e-08) (1365, 3.97615e-10)
row 1351: (1336, 5.40087e-10) (1347, 1.60205e-08) (1350, 9.78767e-09) (1351, -4.6584e-06) (1352, 8.17201e-09) (1366, 3.97615e-10)
row 1352: (1337, 5.40087e-10) (1348, 1.60205e-08) (1351, 8.17201e-09) (1352, -4.65606e-06) (1353, 7.44704e-09) (1367, 3.97615e-10)
row 1353: (1338, 5.40087e-10) (1349, 1.01654e-08) (1352, 4.47497e-09) (1353, -4.6537e-06) (1368, 3.97615e-10) (1858, 1.01654e-08) (2992, 4.47497e-09)
row 1354: (1339, 3.97618e-10) (1354, -4.65952e-06) (1355, 1.76445e-08) (1357, 1.76445e-08) (1369, 3.97618e-10)
row 1355: (1340, 3.97618e-10) (1354, 9.78774e-09) (1355, -4.65821e-06) (1356, 8.17207e-09) (1358, 1.60207e-08) (1370, 3.97618e-10)
row 1356: (620, 7.4471e-09) (1341, 3.97618e-10) (1355, 8.17207e-09) (1356, -4.65587e-06) (1359, 1.60207e-08) (1371, 3.97618e-10)
row 1357: (1342, 3.97618e-10) (1354, 9.78774e-09) (1357, -4.65821e-06) (1358, 1.60207e-08) (1361, 8.17207e-09) (1372, 3.97618e-10)
row 1358: (1343, 3.97617e-10) (1355, 1.01727e-08) (1357, 1.01727e-08) (1358, -4.65374e-06) (1359, 4.58054e-09) (1362, 4.58054e-09) (1373, 3.97617e-10)
row 1359: (1344, 3.97617e-10) (1356, 1.01727e-08) (1358, 4.58054e-09) (1359, -4.65181e-06) (1360, 8.24776e-09) (1363, 4.58054e-09) (1374, 3.97617e-10)
row 1360: (620, 8.45844e-09) (1345, 3.97618e-10) (1359, 6.49456e-09) (1360, -4.65385e-06) (1364, 8.17207e-09) (1375, 3.97618e-10) (1861, 6.49456e-09)
row 1361: (1346, 3.97618e-10) (1357, 8.17207e-09) (1361, -4.65821e-06) (1362, 1.60207e-08) (1365, 9.78774e-09) (1376, 3.97618e-10)
row 1362: (1347, 3.97617e-10) (1358, 4.58054e-09) (1361, 1.01727e-08) (1362, -4.65374e-06) (1363, 4.58054e-09) (1366, 1.01727e-08) (1377, 3.97617e-10)
row 1363: (1348, 3.97617e-10) (1359, 4.58054e-09) (1362, 4.58054e-09) (1363, -4.65181e-06) (1364, 8.24776e-09) (1367, 1.01727e-08) (1378, 3.97617e-10)
row 1364: (1349, 3.97618e-10) (1360, 8.17207e-09) (1363, 6.49456e-09) (1364, -4.65385e-06) (1368, 8.45844e-09) (1379, 3.97618e-10) (1864, 6.49456e-09)
row 1365: (1350, 3.97618e-10) (1361, 1.76445e-08) (1365, -4.65952e-06) (1366, 1.76445e-08) (1380, 3.97618e-10)
row 1366: (1351, 3.97618e-10) (1362, 1.60207e-08) (1365, 9.78774e-09) (1366, -4.65821e-06) (1367, 8.17207e-09) (1381, 3.97618e-10)
row 1367: (1352, 3.97618e-10) (1363, 1.60207e-08) (1366, 8.17207e-09) (1367, -4.65587e-06) (1368, 7.4471e-09) (1382, 3.97618e-10)
row 1368: (1353, 3.97618e-10) (1364, 1.01655e-08) (1367, 4.47501e-09) (1368, -4.65351e-06) (1383, 3.97618e-10) (1867, 1.01655e-08) (3004, 4.47501e-09)
row 1369: (1354, 3.97621e-10) (1369, -4.65947e-06) (1370, 1.76447e-08) (1372, 1.76447e-08) (1384, 3.97621e-10)
row 1370: (1355, 3.97621e-10) (1369, 9.78781e-09) (1370, -4.65816e-06) (1371, 8.17212e-09) (1373, 1.60208e-08) (1385, 3.97621e-10)
row 1371: (636, 7.44715e-09) (1356, 3.97621e-10) (1370, 8.17212e-09) (1371, -4.65582e-06) (1374, 1.60208e-08) (1386, 3.97621e-10)
row 1372: (1357, 3.97621e-10) (1369, 9.78781e-09) (1372, -4.65816e-06) (1373, 1.60208e-08) (1376, 8.17212e-09) (1387, 3.97621e-10)
row 1373: (1358, 3.9762e-10) (1370, 1.01728e-08) (1372, 1.01728e-08) (1373, -4.65369e-06) (1374, 4.58057e-09) (1377, 4.58057e-09) (1388, 3.9762e-10)
row 1374: (1359, 3.9762e-10) (1371, 1.01728e-08) (1373, 4.58057e-09) (1374, -4.65176e-06) (1375, 8.24782e-09) (1378, 4.58057e-09) (1389, 3.9762e-10)
row 1375: (636, 8.45851e-09) (1360, 3.97621e-10) (1374, 6.49461e-09) (1375, -4.6538e-06) (1379, 8.17212e-09) (1390, 3.97621e-10) (1870, 6.49461e-09)
row 1376: (1361, 3.97621e-10) (1372, 8.17212e-09) (1376, -4.65816e-06) (1377, 1.60208e-08) (1380, 9.78781e-09) (1391, 3.97621e-10)
row 1377: (1362, 3.9762e-10) (1373, 4.58057e-09) (1376, 1.01728e-08) (1377, -4.65369e-06) (1378, 4.58057e-09) (1381, 1.01728e-08) (1392, 3.9762e-10)
row 1378: (1363, 3.9762e-10) (1374, 4.58057e-09) (1377, 4.58057e-09) (1378, -4.65176e-06) (1379, 8.24782e-09) (1382, 1.01728e-08) (1393, 3.9762e-10)
row 1379: (1364, 3.97621e-10) (1375, 8.17212e-09) (1378, 6.49461e-09) (1379, -4.6538e-06) (1383, 8.45851e-09) (1394, 3.97621e-10) (1873, 6.49461e-09)
row 1380: (1365, 3.97621e-10) (1376, 1.76447e-08) (1380, -4.65947e-06) (1381, 1.76447e-08) (1395, 3.97621e-10)
row 1381: (1366, 3.97621e-10) (1377, 1.60208e-08) (1380, 9.78781e-09) (1381, -4.65816e-06) (1382, 8.17212e-09) (1396, 3.97621e-10)
row 1382: (1367, 3.97621e-10) (1378, 1.60208e-08) (1381, 8.17212e-09) (1382, -4.65582e-06) (1383, 7.44715e-09) (1397, 3.97621e-10)
row 1383: (1368, 3.97621e-10) (1379, 1.01655e-08) (1382, 4.47504e-09) (1383, -4.65346e-06) (1398, 3.97621e-10) (1876, 1.01655e-08) (3016, 4.47504e-09)
row 1384: (1369, 3.97624e-10) (1384, -4.65942e-06) (1385, 1.76448e-08) (1387, 1.76448e-08) (1399, 3.97624e-10)
row 1385: (1370, 3.97624e-10) (1384, 9.78788e-09) (1385, -4.65812e-06) (1386, 8.17218e-09) (1388, 1.60209e-08) (1400, 3.97624e-10)
row 1386: (652, 7.44721e-09) (1371, 3.97624e-10) (1385, 8.17218e-09) (1386, -4.65578e-06) (1389, 1.60209e-08) (1401, 3.97624e-10)
row 1387: (1372, 3.97624e-10) (1384, 9.78788e-09) (1387, -4.65812e-06) (1388, 1.60209e-08) (1391, 8.17218e-09) (1402, 3.97624e-10)
row 1388: (1373, 3.97623e-10) (1385, 1.01729e-08) (1387, 1.01729e-08) (1388, -4.65364e-06) (1389, 4.5806e-09) (1392, 4.5806e-09) (1403, 3.97623e-10)
row 1389: (1374, 3.97623e-10) (1386, 1.01729e-08) (1388, 4.5806e-09) (1389, -4.65172e-06) (1390, 8.24788e-09) (1393, 4.5806e-09) (1404, 3.97623e-10)
row 1390: (652, 8.45857e-09) (1375, 3.97624e-10) (1389, 6.49465e-09) (1390, -4.65376e-06) (1394, 8.17218e-09) (1405, 3.97624e-10) (1879, 6.49465e-09)
row 1391: (1376, 3.97624e-10) (1387, 8.17218e-09) (1391, -4.65812e-06) (1392, 1.60209e-08) (1395, 9.78788e-09) (1406, 3.97624e-10)
row 1392: (1377, 3.97623e-10) (1388, 4.5806e-09) (1391, 1.01729e-08) (1392, -4.65364e-06) (1393, 4.5806e-09) (1396, 1.01729e-08) (1407, 3.97623e-10)
row 1393: (1378, 3.97623e-10) (1389, 4.5806e-09) (1392, 4.5806e-09) (1393, -4.65172e-06) (1394, 8.24788e-09) (1397, 1.01729e-08) (1408, 3.97623e-10)
row 1394: (1379, 3.97624e-10) (1390, 8.17218e-09) (1393, 6.49465e-09) (1394, -4.65376e-06) (1398, 8.45857e-09) (1409, 3.97624e-10) (1882, 6.49465e-09)
row 1395: (1380, 3.97624e-10) (1391, 1.76448e-08) (1395, -4.65942e-06) (1396, 1.76448e-08) (1410, 3.97624e-10)
row 1396: (1381, 3.97624e-10) (1392, 1.60209e-08) (1395, 9.78788e-09) (1396, -4.65812e-06) (1397, 8.17218e-09) (1411, 3.97624e-10)
row 1397: (1382, 3.97624e-10) (1393, 1.60209e-08) (1396, 8.17218e-09) (1397, -4.65578e-06) (1398, 7.44721e-09) (1412, 3.97624e-10)
row 1398: (1383, 3.97624e-10) (1394, 1.01656e-08) (1397, 4.47507e-09) (1398, -4.65342e-06) (1413, 3.97624e-10) (1885, 1.01656e-08) (3028, 4.47507e-09)
row 1399: (1384, 3.97627e-10) (1399, -4.65938e-06) (1400, 1.76449e-08) (1402, 1.76449e-08) (1414, 3.97627e-10)
row 1400: (1385, 3.97627e-10) (1399, 9.78796e-09) (1400, -4.65807e-06) (1401, 8.17224e-09) (1403, 1.6021e-08) (1415, 3.97627e-10)
row 1401: (668, 7.44726e-09) (1386, 3.97627e-10) (1400, 8.17224e-09) (1401, -4.65573e-06) (1404, 1.6021e-08) (1416, 3.97627e-10)
row 1402: (1387, 3.97627e-10) (1399, 9.78796e-09) (1402, -4.65807e-06) (1403, 1.6021e-08) (1406, 8.17224e-09) (1417, 3.97627e-10)
row 1403: (1388, 3.97626e-10) (1400, 1.01729e-08) (1402, 1.01729e-08) (1403, -4.65359e-06) (1404, 4.58064e-09) (1407, 4.58064e-09) (1418, 3.97626e-10)
row 1404: (1389, 3.97626e-10) (1401, 1.01729e-08) (1403, 4.58064e-09) (1404, -4.65167e-06) (1405, 8.24794e-09) (1408, 4.58064e-09) (1419, 3.97626e-10)
row 1405: (668, 8.45863e-09) (1390, 3.97627e-10) (1404, 6.4947e-09) (1405, -4.65371e-06) (1409, 8.17224e-09) (1420, 3.97627e-10) (1888, 6.4947e-09)
row 1406: (1391, 3.97627e-10) (1402, 8.17224e-09) (1406, -4.65807e-06) (1407, 1.6021e-08) (1410, 9.78796e-09) (1421, 3.97627e-10)
row 1407: (1392, 3.97626e-10) (1403, 4.58064e-09) (1406, 1.01729e-08) (1407, -4.65359e-06) (1408, 4.58064e-09) (1411, 1.01729e-08) (1422, 3.97626e-10)
row 1408: (1393, 3.97626e-10) (1404, 4.58064e-09) (1407, 4.58064e-09) (1408, -4.65167e-06) (1409, 8.24794e-09) (1412, 1.01729e-08) (1423, 3.97626e-10)
row 1409: (1394, 3.97627e-10) (1405, 8.17224e-09) (1408, 6.4947e-09) (1409, -4.65371e-06) (1413, 8.45863e-09) (1424, 3.97627e-10) (1891, 6.4947e-09)
row 1410: (1395, 3.97627e-10) (1406, 1.76449e-08) (1410, -4.65938e-06) (1411, 1.76449e-08) (1425, 3.97627e-10)
row 1411: (1396, 3.97627e-10) (1407, 1.6021e-08) (1410, 9.78796e-09) (1411, -4.65807e-06) (1412, 8.17224e-09) (1426, 3.97627e-10)
row 1412: (1397, 3.97627e-10) (1408, 1.6021e-08) (1411, 8.17224e-09) (1412, -4.65573e-06) (1413, 7.44726e-09) (1427, 3.97627e-10)
row 1413: (1398, 3.97627e-10) (1409, 1.01657e-08) (1412, 4.4751e-09) (1413, -4.65337e-06) (1428, 3.97627e-10) (1894, 1.01657e-08) (3040, 4.4751e-09)
row 1414: (1399, 3.9763e-10) (1414, -4.65947e-06) (1415, 1.7645e-08) (1417, 1.7645e-08) (1429, 5.4007e-10)
row 1415: (1400, 3.9763e-10) (1414, 9.78803e-09) (1415, -4.65816e-06) (1416, 8.1723e-09) (1418, 1.60211e-08) (1430, 5.4007e-10)
row 1416: (684, 7.44731e-09) (1401, 3.9763e-10) (1415, 8.1723e-09) (1416, -4.65582e-06) (1419, 1.60211e-08) (1431, 5.4007e-10)
row 1417: (1402, 3.9763e-10) (1414, 9.78803e-09) (1417, -4.65816e-06) (1418, 1.60211e-08) (1421, 8.1723e-09) (1432, 5.4007e-10)
row 1418: (1403, 3.97629e-10) (1415, 1.0173e-08) (1417, 1.0173e-08) (1418, -4.65369e-06) (1419, 4.58067e-09) (1422, 4.58067e-09) (1433, 5.40069e-10)
row 1419: (1404, 3.97629e-10) (1416, 1.0173e-08) (1418, 4.58067e-09) (1419, -4.65176e-06) (1420, 8.248e-09) (1423, 4.58067e-09) (1434, 5.40069e-10)
row 1420: (684, 8.45869e-09) (1405, 3.9763e-10) (1419, 6.49475e-09) (1420, -4.6538e-06) (1424, 8.1723e-09) (1435, 5.4007e-10) (1897, 6.49475e-09)
row 1421: (1406, 3.9763e-10) (1417, 8.1723e-09) (1421, -4.65816e-06) (1422, 1.60211e-08) (1425, 9.78803e-09) (1436, 5.4007e-10)
row 1422: (1407, 3.97629e-10) (1418, 4.58067e-09) (1421, 1.0173e-08) (1422, -4.65369e-06) (1423, 4.58067e-09) (1426, 1.0173e-08) (1437, 5.40069e-10)
row 1423: (1408, 3.97629e-10) (1419, 4.58067e-09) (1422, 4.58067e-09) (1423, -4.65176e-06) (1424, 8.248e-09) (1427, 1.0173e-08) (1438, 5.40069e-10)
row 1424: (1409, 3.9763e-10) (1420, 8.1723e-09) (1423, 6.49475e-09) (1424, -4.6538e-06) (1428, 8.45869e-09) (1439, 5.4007e-10) (1900, 6.49475e-09)
row 1425: (1410, 3.9763e-10) (1421, 1.7645e-08) (1425, -4.65947e-06) (1426, 1.7645e-08) (1440, 5.4007e-10)
row 1426: (1411, 3.9763e-10) (1422, 1.60211e-08) (1425, 9.78803e-09) (1426, -4.65816e-06) (1427, 8.1723e-09) (1441, 5.4007e-10)
row 1427: (1412, 3.9763e-10) (1423, 1.60211e-08) (1426, 8.1723e-09) (1427, -4.65582e-06) (1428, 7.44731e-09) (1442, 5.4007e-10)
row 1428: (1413, 3.9763e-10) (1424, 1.01658e-08) (1427, 4.47514e-09) (1428, -4.65346e-06) (1443, 5.4007e-10) (1903, 1.01658e-08) (3052, 4.47514e-09)
row 1429: (1414, 1.14323e-09) (1429, -4.6608e-06) (1430, 1.76451e-08) (1432, 1.76451e-08) (1444, 1.15732e-09)
row 1430: (1415, 1.14322e-09) (1429, 9.78808e-09) (1430, -4.65949e-06) (1431, 8.17235e-09) (1433, 1.60212e-08) (1445, 1.15732e-09)
row 1431: (700, 7.44735e-09) (1416, 1.14322e-09) (1430, 8.17235e-09) (1431, -4.65715e-06) (1434, 1.60212e-08) (1446, 1.15732e-09)
row 1432: (1417, 1.14322e-09) (1429, 9.78808e-09) (1432, -4.65949e-06) (1433, 1.60212e-08) (1436, 8.17235e-09) (1447, 1.15732e-09)
row 1433: (1418, 1.14322e-09) (1430, 1.01731e-08) (1432, 1.01731e-08) (1433, -4.65502e-06) (1434, 4.58069e-09) (1437, 4.58069e-09) (1448, 1.15731e-09)
row 1434: (1419, 1.14322e-09) (1431, 1.01731e-08) (1433, 4.58069e-09) (1434, -4.65309e-06) (1435, 8.24805e-09) (1438, 4.58069e-09) (1449, 1.15731e-09)
row 1435: (700, 8.45874e-09) (1420, 1.14322e-09) (1434, 6.49478e-09) (1435, -4.65513e-06) (1439, 8.17235e-09) (1450, 1.15732e-09) (1906, 6.49478e-09)
row 1436: (1421, 1.14322e-09) (1432, 8.17235e-09) (1436, -4.65949e-06) (1437, 1.60212e-08) (1440, 9.78808e-09) (1451, 1.15732e-09)
row 1437: (1422, 1.14322e-09) (1433, 4.58069e-09) (1436, 1.01731e-08) (1437, -4.65502e-06) (1438, 4.58069e-09) (1441, 1.01731e-08) (1452, 1.15731e-09)
row 1438: (1423, 1.14322e-09) (1434, 4.58069e-09) (1437, 4.58069e-09) (1438, -4.65309e-06) (1439, 8.24805e-09) (1442, 1.01731e-08) (1453, 1.15731e-09)
row 1439: (1424, 1.14322e-09) (1435, 8.17235e-09) (1438, 6.49478e-09) (1439, -4.65513e-06) (1443, 8.45874e-09) (1454, 1.15732e-09) (1909, 6.49478e-09)
row 1440: (1425, 1.14323e-09) (1436, 1.76451e-08) (1440, -4.6608e-06) (1441, 1.76451e-08) (1455, 1.15732e-09)
row 1441: (1426, 1.14322e-09) (1437, 1.60212e-08) (1440, 9.78808e-09) (1441, -4.65949e-06) (1442, 8.17235e-09) (1456, 1.15732e-09)
row 1442: (1427, 1.14322e-09) (1438, 1.60212e-08) (1441, 8.17235e-09) (1442, -4.65715e-06) (1443, 7.44735e-09) (1457, 1.15732e-09)
row 1443: (1428, 1.14323e-09) (1439, 1.01658e-08) (1442, 4.47516e-09) (1443, -4.65479e-06) (1458, 1.15732e-09) (1912, 1.01658e-08) (3064, 4.47516e-09)
row 1444: (1429, 5.56659e-10) (1444, -4.65943e-06) (1445, 1.76452e-08) (1447, 1.76452e-08) (1459, 4.12202e-10)
row 1445: (1430, 5.56658e-10) (1444, 9.78813e-09) (1445, -4.65812e-06) (1446, 8.17239e-09) (1448, 1.60213e-08) (1460, 4.12202e-10)
row 1446: (716, 7.44739e-09) (1431, 5.56658e-10) (1445, 8.17239e-09) (1446, -4.65578e-06) (1449, 1.60213e-08) (1461, 4.12202e-10)
row 1447: (1432, 5.56658e-10) (1444, 9.78813e-09) (1447, -4.65812e-06) (1448, 1.60213e-08) (1451, 8.17239e-09) (1462, 4.12202e-10)
row 1448: (1433, 5.56657e-10) (1445, 1.01731e-08) (1447, 1.01731e-08) (1448, -4.65365e-06) (1449, 4.58072e-09) (1452, 4.58072e-09) (1463, 4.12201e-10)
row 1449: (1434, 5.56657e-10) (1446, 1.01731e-08) (1448, 4.58072e-09) (1449, -4.65173e-06) (1450, 8.24809e-09) (1453, 4.58072e-09) (1464, 4.12201e-10)
row 1450: (716, 8.45878e-09) (1435, 5.56658e-10) (1449, 6.49482e-09) (1450, -4.65376e-06) (1454, 8.17239e-09) (1465, 4.12202e-10) (1915, 6.49482e-09)
row 1451: (1436, 5.56658e-10) (1447, 8.17239e-09) (1451, -4.65812e-06) (1452, 1.60213e-08) (1455, 9.78813e-09) (1466, 4.12202e-10)
row 1452: (1437, 5.56657e-10) (1448, 4.58072e-09) (1451, 1.01731e-08) (1452, -4.65365e-06) (1453, 4.58072e-09) (1456, 1.01731e-08) (1467, 4.12201e-10)
row 1453: (1438, 5.56657e-10) (1449, 4.58072e-09) (1452, 4.58072e-09) (1453, -4.65173e-06) (1454, 8.24809e-09) (1457, 1.01731e-08) (1468, 4.12201e-10)
row 1454: (1439, 5.56658e-10) (1450, 8.17239e-09) (1453, 6.49482e-09) (1454, -4.65376e-06) (1458, 8.45878e-09) (1469, 4.12202e-10) (1918, 6.49482e-09)
row 1455: (1440, 5.56659e-10) (1451, 1.76452e-08) (1455, -4.65943e-06) (1456, 1.76452e-08) (1470, 4.12202e-10)
row 1456: (1441, 5.56658e-10) (1452, 1.60213e-08) (1455, 9.78813e-09) (1456, -4.65812e-06) (1457, 8.17239e-09) (1471, 4.12202e-10)
row 1457: (1442, 5.56658e-10) (1453, 1.60213e-08) (1456, 8.17239e-09) (1457, -4.65578e-06) (1458, 7.44739e-09) (1472, 4.12202e-10)
row 1458: (1443, 5.56659e-10) (1454, 1.01659e-08) (1457, 4.47518e-09) (1458, -4.65342e-06) (1473, 4.12202e-10) (1921, 1.01659e-08) (3076, 4.47518e-09)
row 1459: (1444, 4.12205e-10) (1459, -4.65924e-06) (1460, 1.76454e-08) (1462, 1.76454e-08) (1474, 4.12205e-10)
row 1460: (1445, 4.12205e-10) (1459, 9.7882e-09) (1460, -4.65793e-06) (1461, 8.17245e-09) (1463, 1.60214e-08) (1475, 4.12205e-10)
row 1461: (732, 7.44745e-09) (1446, 4.12205e-10) (1460, 8.17245e-09) (1461, -4.65559e-06) (1464, 1.60214e-08) (1476, 4.12205e-10)
row 1462: (1447, 4.12205e-10) (1459, 9.7882e-09) (1462, -4.65793e-06) (1463, 1.60214e-08) (1466, 8.17245e-09) (1477, 4.12205e-10)
row 1463: (1448, 4.12204e-10) (1460, 1.01732e-08) (1462, 1.01732e-08) (1463, -4.65346e-06) (1464, 4.58075e-09) (1467, 4.58075e-09) (1478, 4.12204e-10)
row 1464: (1449, 4.12204e-10) (1461, 1.01732e-08) (1463, 4.58075e-09) (1464, -4.65153e-06) (1465, 8.24815e-09) (1468, 4.58075e-09) (1479, 4.12204e-10)
row 1465: (732, 8.45884e-09) (1450, 4.12205e-10) (1464, 6.49486e-09) (1465, -4.65357e-06) (1469, 8.17245e-09) (1480, 4.12205e-10) (1924, 6.49486e-09)
row 1466: (1451, 4.12205e-10) (1462, 8.17245e-09) (1466, -4.65793e-06) (1467, 1.60214e-08) (1470, 9.7882e-09) (1481, 4.12205e-10)
row 1467: (1452, 4.12204e-10) (1463, 4.58075e-09) (1466, 1.01732e-08) (1467, -4.65346e-06) (1468, 4.58075e-09) (1471, 1.01732e-08) (1482, 4.12204e-10)
row 1468: (1453, 4.12204e-10) (1464, 4.58075e-09) (1467, 4.58075e-09) (1468, -4.65153e-06) (1469, 8.24815e-09) (1472, 1.01732e-08) (1483, 4.12204e-10)
row 1469: (1454, 4.12205e-10) (1465, 8.17245e-09) (1468, 6.49486e-09) (1469, -4.65357e-06) (1473, 8.45884e-09) (1484, 4.12205e-10) (1927, 6.49486e-09)
row 1470: (1455, 4.12205e-10) (1466, 1.76454e-08) (1470, -4.65924e-06) (1471, 1.76454e-08) (1485, 4.12205e-10)
row 1471: (1456, 4.12205e-10) (1467, 1.60214e-08) (1470, 9.7882e-09) (1471, -4.65793e-06) (1472, 8.17245e-09) (1486, 4.12205e-10)
row 1472: (1457, 4.12205e-10) (1468, 1.60214e-08) (1471, 8.17245e-09) (1472, -4.65559e-06) (1473, 7.44745e-09) (1487, 4.12205e-10)
row 1473: (1458, 4.12205e-10) (1469, 1.01659e-08) (1472, 4.47522e-09) (1473, -4.65323e-06) (1488, 4.12205e-10) (1930, 1.01659e-08) (3088, 4.47522e-09)
row 1474: (1459, 4.12208e-10) (1474, -4.6592e-06) (1475, 1.76455e-08) (1477, 1.76455e-08) (1489, 4.12208e-10)
row 1475: (1460, 4.12208e-10) (1474, 9.78827e-09) (1475, -4.65789e-06) (1476, 8.17251e-09) (1478, 1.60215e-08) (1490, 4.12208e-10)
row 1476: (748, 7.4475e-09) (1461, 4.12208e-10) (1475, 8.17251e-09) (1476, -4.65555e-06) (1479, 1.60215e-08) (1491, 4.12208e-10)
row 1477: (1462, 4.12208e-10) (1474, 9.78827e-09) (1477, -4.65789e-06) (1478, 1.60215e-08) (1481, 8.17251e-09) (1492, 4.12208e-10)
row 1478: (1463, 4.12207e-10) (1475, 1.01733e-08) (1477, 1.01733e-08) (1478, -4.65341e-06) (1479, 4.58078e-09) (1482, 4.58078e-09) (1493, 4.12207e-10)
row 1479: (1464, 4.12207e-10) (1476, 1.01733e-08) (1478, 4.58078e-09) (1479, -4.65149e-06) (1480, 8.24821e-09) (1483, 4.58078e-09) (1494, 4.12207e-10)
row 1480: (748, 8.4589e-09) (1465, 4.12208e-10) (1479, 6.49491e-09) (1480, -4.65353e-06) (1484, 8.17251e-09) (1495, 4.12208e-10) (1933, 6.49491e-09)
row 1481: (1466, 4.12208e-10) (1477, 8.17251e-09) (1481, -4.65789e-06) (1482, 1.60215e-08) (1485, 9.78827e-09) (1496, 4.12208e-10)
row 1482: (1467, 4.12207e-10) (1478, 4.58078e-09) (1481, 1.01733e-08) (1482, -4.65341e-06) (1483, 4.58078e-09) (1486, 1.01733e-08) (1497, 4.12207e-10)
row 1483: (1468, 4.12207e-10) (1479, 4.58078e-09) (1482, 4.58078e-09) (1483, -4.65149e-06) (1484, 8.24821e-09) (1487, 1.01733e-08) (1498, 4.12207e-10)
row 1484: (1469, 4.12208e-10) (1480, 8.17251e-09) (1483, 6.49491e-09) (1484, -4.65353e-06) (1488, 8.4589e-09) (1499, 4.12208e-10) (1936, 6.49491e-09)
row 1485: (1470, 4.12208e-10) (1481, 1.76455e-08) (1485, -4.6592e-06) (1486, 1.76455e-08) (1500, 4.12208e-10)
row 1486: (1471, 4.12208e-10) (1482, 1.60215e-08) (1485, 9.78827e-09) (1486, -4.65789e-06) (1487, 8.17251e-09) (1501, 4.12208e-10)
row 1487: (1472, 4.12208e-10) (1483, 1.60215e-08) (1486, 8.17251e-09) (1487, -4.65555e-06) (1488, 7.4475e-09) (1502, 4.12208e-10)
row 1488: (1473, 4.12208e-10) (1484, 1.0166e-08) (1487, 4.47525e-09) (1488, -4.65319e-06) (1503, 4.12208e-10) (1939, 1.0166e-08) (3100, 4.47525e-09)
row 1489: (1474, 4.12211e-10) (1489, -4.65915e-06) (1490, 1.76456e-08) (1492, 1.76456e-08) (1504, 4.12211e-10)
row 1490: (1475, 4.12211e-10) (1489, 9.78834e-09) (1490, -4.65784e-06) (1491, 8.17257e-09) (1493, 1.60216e-08) (1505, 4.12211e-10)
row 1491: (764, 7.44755e-09) (1476, 4.12211e-10) (1490, 8.17257e-09) (1491, -4.6555e-06) (1494, 1.60216e-08) (1506, 4.12211e-10)
row 1492: (1477, 4.12211e-10) (1489, 9.78834e-09) (1492, -4.65784e-06) (1493, 1.60216e-08) (1496, 8.17257e-09) (1507, 4.12211e-10)
row 1493: (1478, 4.1221e-10) (1490, 1.01733e-08) (1492, 1.01733e-08) (1493, -4.65337e-06) (1494, 4.58082e-09) (1497, 4.58082e-09) (1508, 4.1221e-10)
row 1494: (1479, 4.1221e-10) (1491, 1.01733e-08) (1493, 4.58082e-09) (1494, -4.65144e-06) (1495, 8.24827e-09) (1498, 4.58082e-09) (1509, 4.1221e-10)
row 1495: (764, 8.45896e-09) (1480, 4.12211e-10) (1494, 6.49496e-09) (1495, -4.65348e-06) (1499, 8.17257e-09) (1510, 4.12211e-10) (1942, 6.49496e-09)
row 1496: (1481, 4.12211e-10) (1492, 8.17257e-09) (1496, -4.65784e-06) (1497, 1.60216e-08) (1500, 9.78834e-09) (1511, 4.12211e-10)
row 1497: (1482, 4.1221e-10) (1493, 4.58082e-09) (1496, 1.01733e-08) (1497, -4.65337e-06) (1498, 4.58082e-09) (1501, 1.01733e-08) (1512, 4.1221e-10)
row 1498: (1483, 4.1221e-10) (1494, 4.58082e-09) (1497, 4.58082e-09) (1498, -4.65144e-06) (1499, 8.24827e-09) (1502, 1.01733e-08) (1513, 4.1221e-10)
row 1499: (1484, 4.12211e-10) (1495, 8.17257e-09) (1498, 6.49496e-09) (1499, -4.65348e-06) (1503, 8.45896e-09) (1514, 4.12211e-10) (1945, 6.49496e-09)
row 1500: (1485, 4.12211e-10) (1496, 1.76456e-08) (1500, -4.65915e-06) (1501, 1.76456e-08) (1515, 4.12211e-10)
row 1501: (1486, 4.12211e-10) (1497, 1.60216e-08) (1500, 9.78834e-09) (1501, -4.65784e-06) (1502, 8.17257e-09) (1516, 4.12211e-10)
row 1502: (1487, 4.12211e-10) (1498, 1.60216e-08) (1501, 8.17257e-09) (1502, -4.6555e-06) (1503, 7.44755e-09) (1517, 4.12211e-10)
row 1503: (1488, 4.12211e-10) (1499, 1.01661e-08) (1502, 4.47528e-09) (1503, -4.65314e-06) (1518, 4.12211e-10) (1948, 1.01661e-08) (3112, 4.47528e-09)
row 1504: (1489, 4.12214e-10) (1504, -4.6591e-06) (1505, 1.76457e-08) (1507, 1.76457e-08)
row 1505: (1490, 4.12214e-10) (1504, 9.78841e-09) (1505, -4.65779e-06) (1506, 8.17263e-09) (1508, 1.60218e-08)
row 1506: (780, 7.44761e-09) (1491, 4.12214e-10) (1505, 8.17263e-09) (1506, -4.65545e-06) (1509, 1.60218e-08)
row 1507: (1492, 4.12214e-10) (1504, 9.78841e-09) (1507, -4.65779e-06) (1508, 1.60218e-08) (1511, 8.17263e-09)
row 1508: (1493, 4.12213e-10) (1505, 1.01734e-08) (1507, 1.01734e-08) (1508, -4.65332e-06) (1509, 4.58085e-09) (1512, 4.58085e-09)
row 1509: (1494, 4.12213e-10) (1506, 1.01734e-08) (1508, 4.58085e-09) (1509, -4.65139e-06) (1510, 8.24833e-09) (1513, 4.58085e-09)
row 1510: (780, 8.45902e-09) (1495, 4.12214e-10) (1509, 6.495e-09) (1510, -4.65343e-06) (1514, 8.17263e-09) (1951, 6.495e-09)
row 1511: (1496, 4.12214e-10) (1507, 8.17263e-09) (1511, -4.65779e-06) (1512, 1.60218e-08) (1515, 9.78841e-09)
row 1512: (1497, 4.12213e-10) (1508, 4.58085e-09) (1511, 1.01734e-08) (1512, -4.65332e-06) (1513, 4.58085e-09) (1516, 1.01734e-08)
row 1513: (1498, 4.12213e-10) (1509, 4.58085e-09) (1512, 4.58085e-09) (1513, -4.65139e-06) (1514, 8.24833e-09) (1517, 1.01734e-08)
row 1514: (1499, 4.12214e-10) (1510, 8.17263e-09) (1513, 6.495e-09) (1514, -4.65343e-06) (1518, 8.45902e-09) (1954, 6.495e-09)
row 1515: (1500, 4.12214e-10) (1511, 1.76457e-08) (1515, -4.6591e-06) (1516, 1.76457e-08)
row 1516: (1501, 4.12214e-10) (1512, 1.60218e-08) (1515, 9.78841e-09) (1516, -4.65779e-06) (1517, 8.17263e-09)
row 1517: (1502, 4.12214e-10) (1513, 1.60218e-08) (1516, 8.17263e-09) (1517, -4.65545e-06) (1518, 7.44761e-09)
row 1518: (1503, 4.12214e-10) (1514, 1.01662e-08) (1517, 4.47531e-09) (1518, -4.65309e-06) (1957, 1.01662e-08) (3124, 4.47531e-09)
row 1519: (13, 8.24565e-09) (790, 8.24565e-09) (1519, -4.65188e-06) (1520, 4.57936e-09) (1522, 4.57936e-09) (1528, 1.10757e-09)
row 1520: (14, 8.24565e-09) (1519, 4.57936e-09) (1520, -4.65188e-06) (1521, 8.24565e-09) (1523, 4.57936e-09) (1529, 1.10757e-09)
row 1521: (15, 8.45628e-09) (1520, 6.4929e-09) (1521, -4.65584e-06) (1524, 8.16997e-09) (1530, 1.10757e-09) (1963, 6.4929e-09)
row 1522: (794, 8.24565e-09) (1519, 4.57936e-09) (1522, -4.65188e-06) (1523, 4.57936e-09) (1525, 8.24565e-09) (1531, 1.10757e-09)
row 1523: (1520, 4.57936e-09) (1522, 4.57936e-09) (1523, -4.65188e-06) (1524, 8.24565e-09) (1526, 8.24565e-09) (1532, 1.10757e-09)
row 1524: (1521, 8.16997e-09) (1523, 6.4929e-09) (1524, -4.65584e-06) (1527, 8.45628e-09) (1533, 1.10757e-09) (1966, 6.4929e-09)
row 1525: (798, 8.45628e-09) (1522, 6.4929e-09) (1525, -4.65584e-06) (1526, 8.16997e-09) (1534, 1.10757e-09) (2549, 6.4929e-09)
row 1526: (1523, 6.4929e-09) (1525, 8.16997e-09) (1526, -4.65584e-06) (1527, 8.45628e-09) (1535, 1.10757e-09) (2550, 6.4929e-09)
row 1527: (1524, 1.01629e-08) (1526, 1.01629e-08) (1527, -4.65551e-06) (1536, 1.10757e-09) (1969, 4.47386e-09) (2551, 4.47386e-09)
row 1528: (29, 8.2457e-09) (805, 8.2457e-09) (1519, 5.21483e-10) (1528, -4.65164e-06) (1529, 4.57939e-09) (1531, 4.57939e-09) (1537, 3.83507e-10)
row 1529: (30, 8.2457e-09) (1520, 5.21483e-10) (1528, 4.57939e-09) (1529, -4.65164e-06) (1530, 8.2457e-09) (1532, 4.57939e-09) (1538, 3.83507e-10)
row 1530: (31, 8.45633e-09) (1521, 5.21484e-10) (1529, 6.49293e-09) (1530, -4.65561e-06) (1533, 8.17002e-09) (1539, 3.83508e-10) (1975, 6.49293e-09)
row 1531: (809, 8.2457e-09) (1522, 5.21483e-10) (1528, 4.57939e-09) (1531, -4.65164e-06) (1532, 4.57939e-09) (1534, 8.2457e-09) (1540, 3.83507e-10)
row 1532: (1523, 5.21483e-10) (1529, 4.57939e-09) (1531, 4.57939e-09) (1532, -4.65164e-06) (1533, 8.2457e-09) (1535, 8.2457e-09) (1541, 3.83507e-10)
row 1533: (1524, 5.21484e-10) (1530, 8.17002e-09) (1532, 6.49293e-09) (1533, -4.65561e-06) (1536, 8.45633e-09) (1542, 3.83508e-10) (1978, 6.49293e-09)
row 1534: (813, 8.45633e-09) (1525, 5.21484e-10) (1531, 6.49293e-09) (1534, -4.65561e-06) (1535, 8.17002e-09) (1543, 3.83508e-10) (2561, 6.49293e-09)
row 1535: (1526, 5.21484e-10) (1532, 6.49293e-09) (1534, 8.17002e-09) (1535, -4.65561e-06) (1536, 8.45633e-09) (1544, 3.83508e-10) (2562, 6.49293e-09)
row 1536: (1527, 5.21484e-10) (1533, 1.01629e-08) (1535, 1.01629e-08) (1536, -4.65527e-06) (1545, 3.83508e-10) (1981, 4.47389e-09) (2563, 4.47389e-09)
row 1537: (45, 8.24576e-09) (820, 8.24576e-09) (1528, 3.8351e-10) (1537, -4.65146e-06) (1538, 4.57942e-09) (1540, 4.57942e-09) (1546, 3.8351e-10)
row 1538: (46, 8.24576e-09) (1529, 3.8351e-10) (1537, 4.57942e-09) (1538, -4.65146e-06) (1539, 8.24576e-09) (1541, 4.57942e-09) (1547, 3.8351e-10)
row 1539: (47, 8.45639e-09) (1530, 3.8351e-10) (1538, 6.49298e-09) (1539, -4.65542e-06) (1542, 8.17008e-09) (1548, 3.8351e-10) (1987, 6.49298e-09)
row 1540: (824, 8.24576e-09) (1531, 3.8351e-10) (1537, 4.57942e-09) (1540, -4.65146e-06) (1541, 4.57942e-09) (1543, 8.24576e-09) (1549, 3.8351e-10)
row 1541: (1532, 3.8351e-10) (1538, 4.57942e-09) (1540, 4.57942e-09) (1541, -4.65146e-06) (1542, 8.24576e-09) (1544, 8.24576e-09) (1550, 3.8351e-10)
row 1542: (1533, 3.8351e-10) (1539, 8.17008e-09) (1541, 6.49298e-09) (1542, -4.65542e-06) (1545, 8.45639e-09) (1551, 3.8351e-10) (1990, 6.49298e-09)
row 1543: (828, 8.45639e-09) (1534, 3.8351e-10) (1540, 6.49298e-09) (1543, -4.65542e-06) (1544, 8.17008e-09) (1552, 3.8351e-10) (2573, 6.49298e-09)
row 1544: (1535, 3.8351e-10) (1541, 6.49298e-09) (1543, 8.17008e-09) (1544, -4.65542e-06) (1545, 8.45639e-09) (1553, 3.8351e-10) (2574, 6.49298e-09)
row 1545: (1536, 3.83511e-10) (1542, 1.0163e-08) (1544, 1.0163e-08) (1545, -4.65508e-06) (1554, 3.83511e-10) (1993, 4.47392e-09) (2575, 4.47392e-09)
row 1546: (61, 8.24582e-09) (835, 8.24582e-09) (1537, 3.83512e-10) (1546, -4.65141e-06) (1547, 4.57946e-09) (1549, 4.57946e-09) (1555, 3.83489e-10)
row 1547: (62, 8.24582e-09) (1538, 3.83512e-10) (1546, 4.57946e-09) (1547, -4.65141e-06) (1548, 8.24582e-09) (1550, 4.57946e-09) (1556, 3.83489e-10)
row 1548: (63, 8.45645e-09) (1539, 3.83513e-10) (1547, 6.49303e-09) (1548, -4.65537e-06) (1551, 8.17014e-09) (1557, 3.8349e-10) (1999, 6.49303e-09)
row 1549: (839, 8.24582e-09) (1540, 3.83512e-10) (1546, 4.57946e-09) (1549, -4.65141e-06) (1550, 4.57946e-09) (1552, 8.24582e-09) (1558, 3.83489e-10)
row 1550: (1541, 3.83512e-10) (1547, 4.57946e-09) (1549, 4.57946e-09) (1550, -4.65141e-06) (1551, 8.24582e-09) (1553, 8.24582e-09) (1559, 3.83489e-10)
row 1551: (1542, 3.83513e-10) (1548, 8.17014e-09) (1550, 6.49303e-09) (1551, -4.65537e-06) (1554, 8.45645e-09) (1560, 3.8349e-10) (2002, 6.49303e-09)
row 1552: (843, 8.45645e-09) (1543, 3.83513e-10) (1549, 6.49303e-09) (1552, -4.65537e-06) (1553, 8.17014e-09) (1561, 3.8349e-10) (2585, 6.49303e-09)
row 1553: (1544, 3.83513e-10) (1550, 6.49303e-09) (1552, 8.17014e-09) (1553, -4.65537e-06) (1554, 8.45645e-09) (1562, 3.8349e-10) (2586, 6.49303e-09)
row 1554: (1545, 3.83514e-10) (1551, 1.01631e-08) (1553, 1.01631e-08) (1554, -4.65503e-06) (1563, 3.8349e-10) (2005, 4.47395e-09) (2587, 4.47395e-09)
row 1555: (77, 8.24588e-09) (850, 8.24588e-09) (1546, 3.83445e-10) (1555, -4.65136e-06) (1556, 4.57949e-09) (1558, 4.57949e-09) (1564, 3.83445e-10)
row 1556: (78, 8.24588e-09) (1547, 3.83445e-10) (1555, 4.57949e-09) (1556, -4.65136e-06) (1557, 8.24588e-09) (1559, 4.57949e-09) (1565, 3.83445e-10)
row 1557: (79, 8.45651e-09) (1548, 3.83446e-10) (1556, 6.49308e-09) (1557, -4.65532e-06) (1560, 8.1702e-09) (1566, 3.83446e-10) (2011, 6.49308e-09)
row 1558: (854, 8.24588e-09) (1549, 3.83445e-10) (1555, 4.57949e-09) (1558, -4.65136e-06) (1559, 4.57949e-09) (1561, 8.24588e-09) (1567, 3.83445e-10)
row 1559: (1550, 3.83445e-10) (1556, 4.57949e-09) (1558, 4.57949e-09) (1559, -4.65136e-06) (1560, 8.24588e-09) (1562, 8.24588e-09) (1568, 3.83445e-10)
row 1560: (1551, 3.83446e-10) (1557, 8.1702e-09) (1559, 6.49308e-09) (1560, -4.65532e-06) (1563, 8.45651e-09) (1569, 3.83446e-10) (2014, 6.49308e-09)
row 1561: (858, 8.45651e-09) (1552, 3.83446e-10) (1558, 6.49308e-09) (1561, -4.65532e-06) (1562, 8.1702e-09) (1570, 3.83446e-10) (2597, 6.49308e-09)
row 1562: (1553, 3.83446e-10) (1559, 6.49308e-09) (1561, 8.1702e-09) (1562, -4.65532e-06) (1563, 8.45651e-09) (1571, 3.83446e-10) (2598, 6.49308e-09)
row 1563: (1554, 3.83446e-10) (1560, 1.01631e-08) (1562, 1.01631e-08) (1563, -4.65498e-06) (1572, 3.83446e-10) (2017, 4.47398e-09) (2599, 4.47398e-09)
row 1564: (93, 8.24594e-09) (865, 8.24594e-09) (1555, 3.83495e-10) (1564, -4.65131e-06) (1565, 4.57952e-09) (1567, 4.57952e-09) (1573, 3.83518e-10)
row 1565: (94, 8.24594e-09) (1556, 3.83495e-10) (1564, 4.57952e-09) (1565, -4.65131e-06) (1566, 8.24594e-09) (1568, 4.57952e-09) (1574, 3.83518e-10)
row 1566: (95, 8.45658e-09) (1557, 3.83496e-10) (1565, 6.49312e-09) (1566, -4.65527e-06) (1569, 8.17026e-09) (1575, 3.83519e-10) (2023, 6.49312e-09)
row 1567: (869, 8.24594e-09) (1558, 3.83495e-10) (1564, 4.57952e-09) (1567, -4.65131e-06) (1568, 4.57952e-09) (1570, 8.24594e-09) (1576, 3.83518e-10)
row 1568: (1559, 3.83495e-10) (1565, 4.57952e-09) (1567, 4.57952e-09) (1568, -4.65131e-06) (1569, 8.24594e-09) (1571, 8.24594e-09) (1577, 3.83518e-10)
row 1569: (1560, 3.83496e-10) (1566, 8.17026e-09) (1568, 6.49312e-09) (1569, -4.65527e-06) (1572, 8.45658e-09) (1578, 3.83519e-10) (2026, 6.49312e-09)
row 1570: (873, 8.45658e-09) (1561, 3.83496e-10) (1567, 6.49312e-09) (1570, -4.65527e-06) (1571, 8.17026e-09) (1579, 3.83519e-10) (2609, 6.49312e-09)
row 1571: (1562, 3.83496e-10) (1568, 6.49312e-09) (1570, 8.17026e-09) (1571, -4.65527e-06) (1572, 8.45658e-09) (1580, 3.83519e-10) (2610, 6.49312e-09)
row 1572: (1563, 3.83496e-10) (1569, 1.01632e-08) (1571, 1.01632e-08) (1572, -4.65493e-06) (1581, 3.83519e-10) (2029, 4.47402e-09) (2611, 4.47402e-09)
row 1573: (109, 8.246e-09) (880, 8.246e-09) (1564, 3.83521e-10) (1573, -4.65126e-06) (1574, 4.57956e-09) (1576, 4.57956e-09) (1582, 3.83521e-10)
row 1574: (110, 8.246e-09) (1565, 3.83521e-10) (1573, 4.57956e-09) (1574, -4.65126e-06) (1575, 8.246e-09) (1577, 4.57956e-09) (1583, 3.83521e-10)
row 1575: (111, 8.45664e-09) (1566, 3.83522e-10) (1574, 6.49317e-09) (1575, -4.65522e-06) (1578, 8.17032e-09) (1584, 3.83522e-10) (2035, 6.49317e-09)
row 1576: (884, 8.246e-09) (1567, 3.83521e-10) (1573, 4.57956e-09) (1576, -4.65126e-06) (1577, 4.57956e-09) (1579, 8.246e-09) (1585, 3.83521e-10)
row 1577: (1568, 3.83521e-10) (1574, 4.57956e-09) (1576, 4.57956e-09) (1577, -4.65126e-06) (1578, 8.246e-09) (1580, 8.246e-09) (1586, 3.83521e-10)
row 1578: (1569, 3.83522e-10) (1575, 8.17032e-09) (1577, 6.49317e-09) (1578, -4.65522e-06) (1581, 8.45664e-09) (1587, 3.83522e-10) (2038, 6.49317e-09)
row 1579: (888, 8.45664e-09) (1570, 3.83522e-10) (1576, 6.49317e-09) (1579, -4.65522e-06) (1580, 8.17032e-09) (1588, 3.83522e-10) (2621, 6.49317e-09)
row 1580: (1571, 3.83522e-10) (1577, 6.49317e-09) (1579, 8.17032e-09) (1580, -4.65522e-06) (1581, 8.45664e-09) (1589, 3.83522e-10) (2622, 6.49317e-09)
row 1581: (1572, 3.83522e-10) (1578, 1.01633e-08) (1580, 1.01633e-08) (1581, -4.65489e-06) (1590, 3.83522e-10) (2041, 4.47405e-09) (2623, 4.47405e-09)
row 1582: (125, 8.24606e-09) (895, 8.24606e-09) (1573, 3.83524e-10) (1582, -4.65135e-06) (1583, 4.57959e-09) (1585, 4.57959e-09) (1591, 5.239e-10)
row 1583: (126, 8.24606e-09) (1574, 3.83524e-10) (1582, 4.57959e-09) (1583, -4.65135e-06) (1584, 8.24606e-09) (1586, 4.57959e-09) (1592, 5.239e-10)
row 1584: (127, 8.4567e-09) (1575, 3.83525e-10) (1583, 6.49322e-09) (1584, -4.65532e-06) (1587, 8.17038e-09) (1593, 5.23901e-10) (2047, 6.49322e-09)
row 1585: (899, 8.24606e-09) (1576, 3.83524e-10) (1582, 4.57959e-09) (1585, -4.65135e-06) (1586, 4.57959e-09) (1588, 8.24606e-09) (1594, 5.239e-10)
row 1586: (1577, 3.83524e-10) (1583, 4.57959e-09) (1585, 4.57959e-09) (1586, -4.65135e-06) (1587, 8.24606e-09) (1589, 8.24606e-09) (1595, 5.239e-10)
row 1587: (1578, 3.83525e-10) (1584, 8.17038e-09) (1586, 6.49322e-09) (1587, -4.65532e-06) (1590, 8.4567e-09) (1596, 5.23901e-10) (2050, 6.49322e-09)
row 1588: (903, 8.4567e-09) (1579, 3.83525e-10) (1585, 6.49322e-09) (1588, -4.65532e-06) (1589, 8.17038e-09) (1597, 5.23901e-10) (2633, 6.49322e-09)
row 1589: (1580, 3.83525e-10) (1586, 6.49322e-09) (1588, 8.17038e-09) (1589, -4.65532e-06) (1590, 8.4567e-09) (1598, 5.23901e-10) (2634, 6.49322e-09)
row 1590: (1581, 3.83525e-10) (1587, 1.01634e-08) (1589, 1.01634e-08) (1590, -4.65498e-06) (1599, 5.23901e-10) (2053, 4.47408e-09) (2635, 4.47408e-09)
row 1591: (141, 8.2461e-09) (910, 8.2461e-09) (1582, 1.12907e-09) (1591, -4.65268e-06) (1592, 4.57962e-09) (1594, 4.57962e-09) (1600, 1.14303e-09)
row 1592: (142, 8.2461e-09) (1583, 1.12907e-09) (1591, 4.57962e-09) (1592, -4.65268e-06) (1593, 8.2461e-09) (1595, 4.57962e-09) (1601, 1.14303e-09)
row 1593: (143, 8.45675e-09) (1584, 1.12907e-09) (1592, 6.49325e-09) (1593, -4.65665e-06) (1596, 8.17042e-09) (1602, 1.14303e-09) (2059, 6.49325e-09)
row 1594: (914, 8.2461e-09) (1585, 1.12907e-09) (1591, 4.57962e-09) (1594, -4.65268e-06) (1595, 4.57962e-09) (1597, 8.2461e-09) (1603, 1.14303e-09)
row 1595: (1586, 1.12907e-09) (1592, 4.57962e-09) (1594, 4.57962e-09) (1595, -4.65268e-06) (1596, 8.2461e-09) (1598, 8.2461e-09) (1604, 1.14303e-09)
row 1596: (1587, 1.12907e-09) (1593, 8.17042e-09) (1595, 6.49325e-09) (1596, -4.65665e-06) (1599, 8.45675e-09) (1605, 1.14303e-09) (2062, 6.49325e-09)
row 1597: (918, 8.45675e-09) (1588, 1.12907e-09) (1594, 6.49325e-09) (1597, -4.65665e-06) (1598, 8.17042e-09) (1606, 1.14303e-09) (2645, 6.49325e-09)
row 1598: (1589, 1.12907e-09) (1595, 6.49325e-09) (1597, 8.17042e-09) (1598, -4.65665e-06) (1599, 8.45675e-09) (1607, 1.14303e-09) (2646, 6.49325e-09)
row 1599: (1590, 1.12908e-09) (1596, 1.01634e-08) (1598, 1.01634e-08) (1599, -4.65631e-06) (1608, 1.14303e-09) (2065, 4.47411e-09) (2647, 4.47411e-09)
row 1600: (157, 8.24615e-09) (925, 8.24615e-09) (1591, 5.39984e-10) (1600, -4.65131e-06) (1601, 4.57964e-09) (1603, 4.57964e-09) (1609, 3.9754e-10)
row 1601: (158, 8.24615e-09) (1592, 5.39984e-10) (1600, 4.57964e-09) (1601, -4.65131e-06) (1602, 8.24615e-09) (1604, 4.57964e-09) (1610, 3.9754e-10)
row 1602: (159, 8.45679e-09) (1593, 5.39985e-10) (1601, 6.49329e-09) (1602, -4.65528e-06) (1605, 8.17047e-09) (1611, 3.9754e-10) (2071, 6.49329e-09)
row 1603: (929, 8.24615e-09) (1594, 5.39984e-10) (1600, 4.57964e-09) (1603, -4.65131e-06) (1604, 4.57964e-09) (1606, 8.24615e-09) (1612, 3.9754e-10)
row 1604: (1595, 5.39984e-10) (1601, 4.57964e-09) (1603, 4.57964e-09) (1604, -4.65131e-06) (1605, 8.24615e-09) (1607, 8.24615e-09) (1613, 3.9754e-10)
row 1605: (1596, 5.39985e-10) (1602, 8.17047e-09) (1604, 6.49329e-09) (1605, -4.65528e-06) (1608, 8.45679e-09) (1614, 3.9754e-10) (2074, 6.49329e-09)
row 1606: (933, 8.45679e-09) (1597, 5.39985e-10) (1603, 6.49329e-09) (1606, -4.65528e-06) (1607, 8.17047e-09) (1615, 3.9754e-10) (2657, 6.49329e-09)
row 1607: (1598, 5.39985e-10) (1604, 6.49329e-09) (1606, 8.17047e-09) (1607, -4.65528e-06) (1608, 8.45679e-09) (1616, 3.9754e-10) (2658, 6.49329e-09)
row 1608: (1599, 5.39986e-10) (1605, 1.01635e-08) (1607, 1.01635e-08) (1608, -4.65494e-06) (1617, 3.97541e-10) (2077, 4.47413e-09) (2659, 4.47413e-09)
row 1609: (173, 8.24621e-09) (940, 8.24621e-09) (1600, 3.97542e-10) (1609, -4.65112e-06) (1610, 4.57967e-09) (1612, 4.57967e-09) (1618, 3.97542e-10)
row 1610: (174, 8.24621e-09) (1601, 3.97542e-10) (1609, 4.57967e-09) (1610, -4.65112e-06) (1611, 8.24621e-09) (1613, 4.57967e-09) (1619, 3.97542e-10)
row 1611: (175, 8.45685e-09) (1602, 3.97543e-10) (1610, 6.49334e-09) (1611, -4.65509e-06) (1614, 8.17053e-09) (1620, 3.97543e-10) (2083, 6.49334e-09)
row 1612: (944, 8.24621e-09) (1603, 3.97542e-10) (1609, 4.57967e-09) (1612, -4.65112e-06) (1613, 4.57967e-09) (1615, 8.24621e-09) (1621, 3.97542e-10)
row 1613: (1604, 3.97542e-10) (1610, 4.57967e-09) (1612, 4.57967e-09) (1613, -4.65112e-06) (1614, 8.24621e-09) (1616, 8.24621e-09) (1622, 3.97542e-10)
row 1614: (1605, 3.97543e-10) (1611, 8.17053e-09) (1613, 6.49334e-09) (1614, -4.65509e-06) (1617, 8.45685e-09) (1623, 3.97543e-10) (2086, 6.49334e-09)
row 1615: (948, 8.45685e-09) (1606, 3.97543e-10) (1612, 6.49334e-09) (1615, -4.65509e-06) (1616, 8.17053e-09) (1624, 3.97543e-10) (2669, 6.49334e-09)
row 1616: (1607, 3.97543e-10) (1613, 6.49334e-09) (1615, 8.17053e-09) (1616, -4.65509e-06) (1617, 8.45685e-09) (1625, 3.97543e-10) (2670, 6.49334e-09)
row 1617: (1608, 3.97544e-10) (1614, 1.01635e-08) (1616, 1.01635e-08) (1617, -4.65475e-06) (1626, 3.97544e-10) (2089, 4.47416e-09) (2671, 4.47416e-09)
row 1618: (189, 8.24627e-09) (955, 8.24627e-09) (1609, 3.97545e-10) (1618, -4.65108e-06) (1619, 4.57971e-09) (1621, 4.57971e-09) (1627, 3.97545e-10)
row 1619: (190, 8.24627e-09) (1610, 3.97545e-10) (1618, 4.57971e-09) (1619, -4.65108e-06) (1620, 8.24627e-09) (1622, 4.57971e-09) (1628, 3.97545e-10)
row 1620: (191, 8.45691e-09) (1611, 3.97546e-10) (1619, 6.49338e-09) (1620, -4.65504e-06) (1623, 8.17059e-09) (1629, 3.97546e-10) (2095, 6.49338e-09)
row 1621: (959, 8.24627e-09) (1612, 3.97545e-10) (1618, 4.57971e-09) (1621, -4.65108e-06) (1622, 4.57971e-09) (1624, 8.24627e-09) (1630, 3.97545e-10)
row 1622: (1613, 3.97545e-10) (1619, 4.57971e-09) (1621, 4.57971e-09) (1622, -4.65108e-06) (1623, 8.24627e-09) (1625, 8.24627e-09) (1631, 3.97545e-10)
row 1623: (1614, 3.97546e-10) (1620, 8.17059e-09) (1622, 6.49338e-09) (1623, -4.65504e-06) (1626, 8.45691e-09) (1632, 3.97546e-10) (2098, 6.49338e-09)
row 1624: (963, 8.45691e-09) (1615, 3.97546e-10) (1621, 6.49338e-09) (1624, -4.65504e-06) (1625, 8.17059e-09) (1633, 3.97546e-10) (2681, 6.49338e-09)
row 1625: (1616, 3.97546e-10) (1622, 6.49338e-09) (1624, 8.17059e-09) (1625, -4.65504e-06) (1626, 8.45691e-09) (1634, 3.97546e-10) (2682, 6.49338e-09)
row 1626: (1617, 3.97546e-10) (1623, 1.01636e-08) (1625, 1.01636e-08) (1626, -4.6547e-06) (1635, 3.97546e-10) (2101, 4.4742e-09) (2683, 4.4742e-09)
row 1627: (205, 8.24633e-09) (970, 8.24633e-09) (1618, 3.97548e-10) (1627, -4.65103e-06) (1628, 4.57974e-09) (1630, 4.57974e-09) (1636, 3.97548e-10)
row 1628: (206, 8.24633e-09) (1619, 3.97548e-10) (1627, 4.57974e-09) (1628, -4.65103e-06) (1629, 8.24633e-09) (1631, 4.57974e-09) (1637, 3.97548e-10)
row 1629: (207, 8.45697e-09) (1620, 3.97549e-10) (1628, 6.49343e-09) (1629, -4.65499e-06) (1632, 8.17065e-09) (1638, 3.97549e-10) (2107, 6.49343e-09)
row 1630: (974, 8.24633e-09) (1621, 3.97548e-10) (1627, 4.57974e-09) (1630, -4.65103e-06) (1631, 4.57974e-09) (1633, 8.24633e-09) (1639, 3.97548e-10)
row 1631: (1622, 3.97548e-10) (1628, 4.57974e-09) (1630, 4.57974e-09) (1631, -4.65103e-06) (1632, 8.24633e-09) (1634, 8.24633e-09) (1640, 3.97548e-10)
row 1632: (1623, 3.97549e-10) (1629, 8.17065e-09) (1631, 6.49343e-09) (1632, -4.65499e-06) (1635, 8.45697e-09) (1641, 3.97549e-10) (2110, 6.49343e-09)
row 1633: (978, 8.45697e-09) (1624, 3.97549e-10) (1630, 6.49343e-09) (1633, -4.65499e-06) (1634, 8.17065e-09) (1642, 3.97549e-10) (2693, 6.49343e-09)
row 1634: (1625, 3.97549e-10) (1631, 6.49343e-09) (1633, 8.17065e-09) (1634, -4.65499e-06) (1635, 8.45697e-09) (1643, 3.97549e-10) (2694, 6.49343e-09)
row 1635: (1626, 3.97549e-10) (1632, 1.01637e-08) (1634, 1.01637e-08) (1635, -4.65465e-06) (1644, 3.97549e-10) (2113, 4.47423e-09) (2695, 4.47423e-09)
row 1636: (221, 8.24639e-09) (985, 8.24639e-09) (1627, 3.97551e-10) (1636, -4.65098e-06) (1637, 4.57977e-09) (1639, 4.57977e-09) (1645, 3.97551e-10)
row 1637: (222, 8.24639e-09) (1628, 3.97551e-10) (1636, 4.57977e-09) (1637, -4.65098e-06) (1638, 8.24639e-09) (1640, 4.57977e-09) (1646, 3.97551e-10)
row 1638: (223, 8.45704e-09) (1629, 3.97552e-10) (1637, 6.49348e-09) (1638, -4.65494e-06) (1641, 8.17071e-09) (1647, 3.97552e-10) (2119, 6.49348e-09)
row 1639: (989, 8.24639e-09) (1630, 3.97551e-10) (1636, 4.57977e-09) (1639, -4.65098e-06) (1640, 4.57977e-09) (1642, 8.24639e-09) (1648, 3.97551e-10)
row 1640: (1631, 3.97551e-10) (1637, 4.57977e-09) (1639, 4.57977e-09) (1640, -4.65098e-06) (1641, 8.24639e-09) (1643, 8.24639e-09) (1649, 3.97551e-10)
row 1641: (1632, 3.97552e-10) (1638, 8.17071e-09) (1640, 6.49348e-09) (1641, -4.65494e-06) (1644, 8.45704e-09) (1650, 3.97552e-10) (2122, 6.49348e-09)
row 1642: (993, 8.45704e-09) (1633, 3.97552e-10) (1639, 6.49348e-09) (1642, -4.65494e-06) (1643, 8.17071e-09) (1651, 3.97552e-10) (2705, 6.49348e-09)
row 1643: (1634, 3.97552e-10) (1640, 6.49348e-09) (1642, 8.17071e-09) (1643, -4.65494e-06) (1644, 8.45704e-09) (1652, 3.97552e-10) (2706, 6.49348e-09)
row 1644: (1635, 3.97552e-10) (1641, 1.01638e-08) (1643, 1.01638e-08) (1644, -4.6546e-06) (1653, 3.97552e-10) (2125, 4.47426e-09) (2707, 4.47426e-09)
row 1645: (237, 8.24645e-09) (1000, 8.24645e-09) (1636, 3.97554e-10) (1645, -4.65107e-06) (1646, 4.57981e-09) (1648, 4.57981e-09) (1654, 5.39967e-10)
row 1646: (238, 8.24645e-09) (1637, 3.97554e-10) (1645, 4.57981e-09) (1646, -4.65107e-06) (1647, 8.24645e-09) (1649, 4.57981e-09) (1655, 5.39967e-10)
row 1647: (239, 8.4571e-09) (1638, 3.97555e-10) (1646, 6.49352e-09) (1647, -4.65504e-06) (1650, 8.17076e-09) (1656, 5.39968e-10) (2131, 6.49352e-09)
row 1648: (1004, 8.24645e-09) (1639, 3.97554e-10) (1645, 4.57981e-09) (1648, -4.65107e-06) (1649, 4.57981e-09) (1651, 8.24645e-09) (1657, 5.39967e-10)
row 1649: (1640, 3.97554e-10) (1646, 4.57981e-09) (1648, 4.57981e-09) (1649, -4.65107e-06) (1650, 8.24645e-09) (1652, 8.24645e-09) (1658, 5.39967e-10)
row 1650: (1641, 3.97555e-10) (1647, 8.17076e-09) (1649, 6.49352e-09) (1650, -4.65504e-06) (1653, 8.4571e-09) (1659, 5.39968e-10) (2134, 6.49352e-09)
row 1651: (1008, 8.4571e-09) (1642, 3.97555e-10) (1648, 6.49352e-09) (1651, -4.65504e-06) (1652, 8.17076e-09) (1660, 5.39968e-10) (2717, 6.49352e-09)
row 1652: (1643, 3.97555e-10) (1649, 6.49352e-09) (1651, 8.17076e-09) (1652, -4.65504e-06) (1653, 8.4571e-09) (1661, 5.39968e-10) (2718, 6.49352e-09)
row 1653: (1644, 3.97555e-10) (1650, 1.01638e-08) (1652, 1.01638e-08) (1653, -4.6547e-06) (1662, 5.39968e-10) (2137, 4.47429e-09) (2719, 4.47429e-09)
row 1654: (253, 8.24649e-09) (1015, 8.24649e-09) (1645, 1.14301e-09) (1654, -4.65239e-06) (1655, 4.57983e-09) (1657, 4.57983e-09) (1663, 1.14308e-09)
row 1655: (254, 8.24649e-09) (1646, 1.14301e-09) (1654, 4.57983e-09) (1655, -4.65239e-06) (1656, 8.24649e-09) (1658, 4.57983e-09) (1664, 1.14308e-09)
row 1656: (255, 8.45714e-09) (1647, 1.14301e-09) (1655, 6.49356e-09) (1656, -4.65635e-06) (1659, 8.17081e-09) (1665, 1.14309e-09) (2143, 6.49356e-09)
row 1657: (1019, 8.24649e-09) (1648, 1.14301e-09) (1654, 4.57983e-09) (1657, -4.65239e-06) (1658, 4.57983e-09) (1660, 8.24649e-09) (1666, 1.14308e-09)
row 1658: (1649, 1.14301e-09) (1655, 4.57983e-09) (1657, 4.57983e-09) (1658, -4.65239e-06) (1659, 8.24649e-09) (1661, 8.24649e-09) (1667, 1.14308e-09)
row 1659: (1650, 1.14301e-09) (1656, 8.17081e-09) (1658, 6.49356e-09) (1659, -4.65635e-06) (1662, 8.45714e-09) (1668, 1.14309e-09) (2146, 6.49356e-09)
row 1660: (1023, 8.45714e-09) (1651, 1.14301e-09) (1657, 6.49356e-09) (1660, -4.65635e-06) (1661, 8.17081e-09) (1669, 1.14309e-09) (2729, 6.49356e-09)
row 1661: (1652, 1.14301e-09) (1658, 6.49356e-09) (1660, 8.17081e-09) (1661, -4.65635e-06) (1662, 8.45714e-09) (1670, 1.14309e-09) (2730, 6.49356e-09)
row 1662: (1653, 1.14301e-09) (1659, 1.01639e-08) (1661, 1.01639e-08) (1662, -4.65601e-06) (1671, 1.14309e-09) (2149, 4.47432e-09) (2731, 4.47432e-09)
row 1663: (269, 8.24654e-09) (1030, 8.24654e-09) (1654, 5.40009e-10) (1663, -4.651e-06) (1664, 4.57986e-09) (1666, 4.57986e-09) (1672, 3.97558e-10)
row 1664: (270, 8.24654e-09) (1655, 5.40009e-10) (1663, 4.57986e-09) (1664, -4.651e-06) (1665, 8.24654e-09) (1667, 4.57986e-09) (1673, 3.97558e-10)
row 1665: (271, 8.45719e-09) (1656, 5.40011e-10) (1664, 6.49359e-09) (1665, -4.65497e-06) (1668, 8.17085e-09) (1674, 3.97559e-10) (2155, 6.49359e-09)
row 1666: (1034, 8.24654e-09) (1657, 5.40009e-10) (1663, 4.57986e-09) (1666, -4.651e-06) (1667, 4.57986e-09) (1669, 8.24654e-09) (1675, 3.97558e-10)
row 1667: (1658, 5.40009e-10) (1664, 4.57986e-09) (1666, 4.57986e-09) (1667, -4.651e-06) (1668, 8.24654e-09) (1670, 8.24654e-09) (1676, 3.97558e-10)
row 1668: (1659, 5.40011e-10) (1665, 8.17085e-09) (1667, 6.49359e-09) (1668, -4.65497e-06) (1671, 8.45719e-09) (1677, 3.97559e-10) (2158, 6.49359e-09)
row 1669: (1038, 8.45719e-09) (1660, 5.40011e-10) (1666, 6.49359e-09) (1669, -4.65497e-06) (1670, 8.17085e-09) (1678, 3.97559e-10) (2741, 6.49359e-09)
row 1670: (1661, 5.40011e-10) (1667, 6.49359e-09) (1669, 8.17085e-09) (1670, -4.65497e-06) (1671, 8.45719e-09) (1679, 3.97559e-10) (2742, 6.49359e-09)
row 1671: (1662, 5.40011e-10) (1668, 1.0164e-08) (1670, 1.0164e-08) (1671, -4.65463e-06) (1680, 3.97559e-10) (2161, 4.47434e-09) (2743, 4.47434e-09)
row 1672: (285, 8.2466e-09) (1045, 8.2466e-09) (1663, 3.97561e-10) (1672, -4.65081e-06) (1673, 4.57989e-09) (1675, 4.57989e-09) (1681, 3.97561e-10)
row 1673: (286, 8.2466e-09) (1664, 3.97561e-10) (1672, 4.57989e-09) (1673, -4.65081e-06) (1674, 8.2466e-09) (1676, 4.57989e-09) (1682, 3.97561e-10)
row 1674: (287, 8.45725e-09) (1665, 3.97562e-10) (1673, 6.49364e-09) (1674, -4.65478e-06) (1677, 8.17091e-09) (1683, 3.97562e-10) (2167, 6.49364e-09)
row 1675: (1049, 8.2466e-09) (1666, 3.97561e-10) (1672, 4.57989e-09) (1675, -4.65081e-06) (1676, 4.57989e-09) (1678, 8.2466e-09) (1684, 3.97561e-10)
row 1676: (1667, 3.97561e-10) (1673, 4.57989e-09) (1675, 4.57989e-09) (1676, -4.65081e-06) (1677, 8.2466e-09) (1679, 8.2466e-09) (1685, 3.97561e-10)
row 1677: (1668, 3.97562e-10) (1674, 8.17091e-09) (1676, 6.49364e-09) (1677, -4.65478e-06) (1680, 8.45725e-09) (1686, 3.97562e-10) (2170, 6.49364e-09)
row 1678: (1053, 8.45725e-09) (1669, 3.97562e-10) (1675, 6.49364e-09) (1678, -4.65478e-06) (1679, 8.17091e-09) (1687, 3.97562e-10) (2753, 6.49364e-09)
row 1679: (1670, 3.97562e-10) (1676, 6.49364e-09) (1678, 8.17091e-09) (1679, -4.65478e-06) (1680, 8.45725e-09) (1688, 3.97562e-10) (2754, 6.49364e-09)
row 1680: (1671, 3.97562e-10) (1677, 1.0164e-08) (1679, 1.0164e-08) (1680, -4.65444e-06) (1689, 3.97562e-10) (2173, 4.47437e-09) (2755, 4.47437e-09)
row 1681: (301, 8.24666e-09) (1060, 8.24666e-09) (1672, 3.97564e-10) (1681, -4.65077e-06) (1682, 4.57992e-09) (1684, 4.57992e-09) (1690, 3.97564e-10)
row 1682: (302, 8.24666e-09) (1673, 3.97564e-10) (1681, 4.57992e-09) (1682, -4.65077e-06) (1683, 8.24666e-09) (1685, 4.57992e-09) (1691, 3.97564e-10)
row 1683: (303, 8.45731e-09) (1674, 3.97565e-10) (1682, 6.49369e-09) (1683, -4.65473e-06) (1686, 8.17097e-09) (1692, 3.97565e-10) (2179, 6.49369e-09)
row 1684: (1064, 8.24666e-09) (1675, 3.97564e-10) (1681, 4.57992e-09) (1684, -4.65077e-06) (1685, 4.57992e-09) (1687, 8.24666e-09) (1693, 3.97564e-10)
row 1685: (1676, 3.97564e-10) (1682, 4.57992e-09) (1684, 4.57992e-09) (1685, -4.65077e-06) (1686, 8.24666e-09) (1688, 8.24666e-09) (1694, 3.97564e-10)
row 1686: (1677, 3.97565e-10) (1683, 8.17097e-09) (1685, 6.49369e-09) (1686, -4.65473e-06) (1689, 8.45731e-09) (1695, 3.97565e-10) (2182, 6.49369e-09)
row 1687: (1068, 8.45731e-09) (1678, 3.97565e-10) (1684, 6.49369e-09) (1687, -4.65473e-06) (1688, 8.17097e-09) (1696, 3.97565e-10) (2765, 6.49369e-09)
row 1688: (1679, 3.97565e-10) (1685, 6.49369e-09) (1687, 8.17097e-09) (1688, -4.65473e-06) (1689, 8.45731e-09) (1697, 3.97565e-10) (2766, 6.49369e-09)
row 1689: (1680, 3.97565e-10) (1686, 1.01641e-08) (1688, 1.01641e-08) (1689, -4.65439e-06) (1698, 3.97565e-10) (2185, 4.47441e-09) (2767, 4.47441e-09)
row 1690: (317, 8.24672e-09) (1075, 8.24672e-09) (1681, 3.97567e-10) (1690, -4.65072e-06) (1691, 4.57996e-09) (1693, 4.57996e-09) (1699, 3.97567e-10)
row 1691: (318, 8.24672e-09) (1682, 3.97567e-10) (1690, 4.57996e-09) (1691, -4.65072e-06) (1692, 8.24672e-09) (1694, 4.57996e-09) (1700, 3.97567e-10)
row 1692: (319, 8.45737e-09) (1683, 3.97568e-10) (1691, 6.49374e-09) (1692, -4.65468e-06) (1695, 8.17103e-09) (1701, 3.97568e-10) (2191, 6.49374e-09)
row 1693: (1079, 8.24672e-09) (1684, 3.97567e-10) (1690, 4.57996e-09) (1693, -4.65072e-06) (1694, 4.57996e-09) (1696, 8.24672e-09) (1702, 3.97567e-10)
row 1694: (1685, 3.97567e-10) (1691, 4.57996e-09) (1693, 4.57996e-09) (1694, -4.65072e-06) (1695, 8.24672e-09) (1697, 8.24672e-09) (1703, 3.97567e-10)
row 1695: (1686, 3.97568e-10) (1692, 8.17103e-09) (1694, 6.49374e-09) (1695, -4.65468e-06) (1698, 8.45737e-09) (1704, 3.97568e-10) (2194, 6.49374e-09)
row 1696: (1083, 8.45737e-09) (1687, 3.97568e-10) (1693, 6.49374e-09) (1696, -4.65468e-06) (1697, 8.17103e-09) (1705, 3.97568e-10) (2777, 6.49374e-09)
row 1697: (1688, 3.97568e-10) (1694, 6.49374e-09) (1696, 8.17103e-09) (1697, -4.65468e-06) (1698, 8.45737e-09) (1706, 3.97568e-10) (2778, 6.49374e-09)
row 1698: (1689, 3.97568e-10) (1695, 1.01642e-08) (1697, 1.01642e-08) (1698, -4.65434e-06) (1707, 3.97568e-10) (2197, 4.47444e-09) (2779, 4.47444e-09)
row 1699: (333, 8.24678e-09) (1090, 8.24678e-09) (1690, 3.9757e-10) (1699, -4.65067e-06) (1700, 4.57999e-09) (1702, 4.57999e-09) (1708, 3.9757e-10)
row 1700: (334, 8.24678e-09) (1691, 3.9757e-10) (1699, 4.57999e-09) (1700, -4.65067e-06) (1701, 8.24678e-09) (1703, 4.57999e-09) (1709, 3.9757e-10)
row 1701: (335, 8.45743e-09) (1692, 3.97571e-10) (1700, 6.49378e-09) (1701, -4.65463e-06) (1704, 8.17109e-09) (1710, 3.97571e-10) (2203, 6.49378e-09)
row 1702: (1094, 8.24678e-09) (1693, 3.9757e-10) (1699, 4.57999e-09) (1702, -4.65067e-06) (1703, 4.57999e-09) (1705, 8.24678e-09) (1711, 3.9757e-10)
row 1703: (1694, 3.9757e-10) (1700, 4.57999e-09) (1702, 4.57999e-09) (1703, -4.65067e-06) (1704, 8.24678e-09) (1706, 8.24678e-09) (1712, 3.9757e-10)
row 1704: (1695, 3.97571e-10) (1701, 8.17109e-09) (1703, 6.49378e-09) (1704, -4.65463e-06) (1707, 8.45743e-09) (1713, 3.97571e-10) (2206, 6.49378e-09)
row 1705: (1098, 8.45743e-09) (1696, 3.97571e-10) (1702, 6.49378e-09) (1705, -4.65463e-06) (1706, 8.17109e-09) (1714, 3.97571e-10) (2789, 6.49378e-09)
row 1706: (1697, 3.97571e-10) (1703, 6.49378e-09) (1705, 8.17109e-09) (1706, -4.65463e-06) (1707, 8.45743e-09) (1715, 3.97571e-10) (2790, 6.49378e-09)
row 1707: (1698, 3.97571e-10) (1704, 1.01642e-08) (1706, 1.01642e-08) (1707, -4.65429e-06) (1716, 3.97571e-10) (2209, 4.47447e-09) (2791, 4.47447e-09)
row 1708: (349, 8.24684e-09) (1105, 8.24684e-09) (1699, 3.97573e-10) (1708, -4.65077e-06) (1709, 4.58002e-09) (1711, 4.58002e-09) (1717, 5.39992e-10)
row 1709: (350, 8.24684e-09) (1700, 3.97573e-10) (1708, 4.58002e-09) (1709, -4.65077e-06) (1710, 8.24684e-09) (1712, 4.58002e-09) (1718, 5.39992e-10)
row 1710: (351, 8.4575e-09) (1701, 3.97574e-10) (1709, 6.49383e-09) (1710, -4.65473e-06) (1713, 8.17115e-09) (1719, 5.39993e-10) (2215, 6.49383e-09)
row 1711: (1109, 8.24684e-09) (1702, 3.97573e-10) (1708, 4.58002e-09) (1711, -4.65077e-06) (1712, 4.58002e-09) (1714, 8.24684e-09) (1720, 5.39992e-10)
row 1712: (1703, 3.97573e-10) (1709, 4.58002e-09) (1711, 4.58002e-09) (1712, -4.65077e-06) (1713, 8.24684e-09) (1715, 8.24684e-09) (1721, 5.39992e-10)
row 1713: (1704, 3.97574e-10) (1710, 8.17115e-09) (1712, 6.49383e-09) (1713, -4.65473e-06) (1716, 8.4575e-09) (1722, 5.39993e-10) (2218, 6.49383e-09)
row 1714: (1113, 8.4575e-09) (1705, 3.97574e-10) (1711, 6.49383e-09) (1714, -4.65473e-06) (1715, 8.17115e-09) (1723, 5.39993e-10) (2801, 6.49383e-09)
row 1715: (1706, 3.97574e-10) (1712, 6.49383e-09) (1714, 8.17115e-09) (1715, -4.65473e-06) (1716, 8.4575e-09) (1724, 5.39993e-10) (2802, 6.49383e-09)
row 1716: (1707, 3.97574e-10) (1713, 1.01643e-08) (1715, 1.01643e-08) (1716, -4.65439e-06) (1725, 5.39994e-10) (2221, 4.4745e-09) (2803, 4.4745e-09)
row 1717: (365, 8.24688e-09) (1120, 8.24688e-09) (1708, 1.14306e-09) (1717, -4.65208e-06) (1718, 4.58005e-09) (1720, 4.58005e-09) (1726, 1.14314e-09)
row 1718: (366, 8.24688e-09) (1709, 1.14306e-09) (1717, 4.58005e-09) (1718, -4.65208e-06) (1719, 8.24688e-09) (1721, 4.58005e-09) (1727, 1.14314e-09)
row 1719: (367, 8.45754e-09) (1710, 1.14306e-09) (1718, 6.49386e-09) (1719, -4.65604e-06) (1722, 8.17119e-09) (1728, 1.14314e-09) (2227, 6.49386e-09)
row 1720: (1124, 8.24688e-09) (1711, 1.14306e-09) (1717, 4.58005e-09) (1720, -4.65208e-06) (1721, 4.58005e-09) (1723, 8.24688e-09) (1729, 1.14314e-09)
row 1721: (1712, 1.14306e-09) (1718, 4.58005e-09) (1720, 4.58005e-09) (1721, -4.65208e-06) (1722, 8.24688e-09) (1724, 8.24688e-09) (1730, 1.14314e-09)
row 1722: (1713, 1.14306e-09) (1719, 8.17119e-09) (1721, 6.49386e-09) (1722, -4.65604e-06) (1725, 8.45754e-09) (1731, 1.14314e-09) (2230, 6.49386e-09)
row 1723: (1128, 8.45754e-09) (1714, 1.14306e-09) (1720, 6.49386e-09) (1723, -4.65604e-06) (1724, 8.17119e-09) (1732, 1.14314e-09) (2813, 6.49386e-09)
row 1724: (1715, 1.14306e-09) (1721, 6.49386e-09) (1723, 8.17119e-09) (1724, -4.65604e-06) (1725, 8.45754e-09) (1733, 1.14314e-09) (2814, 6.49386e-09)
row 1725: (1716, 1.14306e-09) (1722, 1.01644e-08) (1724, 1.01644e-08) (1725, -4.6557e-06) (1734, 1.14314e-09) (2233, 4.47453e-09) (2815, 4.47453e-09)
row 1726: (381, 8.24692e-09) (1135, 8.24692e-09) (1717, 5.40035e-10) (1726, -4.65069e-06) (1727, 4.58007e-09) (1729, 4.58007e-09) (1735, 3.97577e-10)
row 1727: (382, 8.24692e-09) (1718, 5.40035e-10) (1726, 4.58007e-09) (1727, -4.65069e-06) (1728, 8.24692e-09) (1730, 4.58007e-09) (1736, 3.97577e-10)
row 1728: (383, 8.45759e-09) (1719, 5.40036e-10) (1727, 6.4939e-09) (1728, -4.65466e-06) (1731, 8.17124e-09) (1737, 3.97578e-10) (2239, 6.4939e-09)
row 1729: (1139, 8.24692e-09) (1720, 5.40035e-10) (1726, 4.58007e-09) (1729, -4.65069e-06) (1730, 4.58007e-09) (1732, 8.24692e-09) (1738, 3.97577e-10)
row 1730: (1721, 5.40035e-10) (1727, 4.58007e-09) (1729, 4.58007e-09) (1730, -4.65069e-06) (1731, 8.24692e-09) (1733, 8.24692e-09) (1739, 3.97577e-10)
row 1731: (1722, 5.40036e-10) (1728, 8.17124e-09) (1730, 6.4939e-09) (1731, -4.65466e-06) (1734, 8.45759e-09) (1740, 3.97578e-10) (2242, 6.4939e-09)
row 1732: (1143, 8.45759e-09) (1723, 5.40036e-10) (1729, 6.4939e-09) (1732, -4.65466e-06) (1733, 8.17124e-09) (1741, 3.97578e-10) (2825, 6.4939e-09)
row 1733: (1724, 5.40036e-10) (1730, 6.4939e-09) (1732, 8.17124e-09) (1733, -4.65466e-06) (1734, 8.45759e-09) (1742, 3.97578e-10) (2826, 6.4939e-09)
row 1734: (1725, 5.40036e-10) (1731, 1.01644e-08) (1733, 1.01644e-08) (1734, -4.65432e-06) (1743, 3.97578e-10) (2245, 4.47455e-09) (2827, 4.47455e-09)
row 1735: (397, 8.24698e-09) (1150, 8.24698e-09) (1726, 3.9758e-10) (1735, -4.6505e-06) (1736, 4.5801e-09) (1738, 4.5801e-09) (1744, 3.9758e-10)
row 1736: (398, 8.24698e-09) (1727, 3.9758e-10) (1735, 4.5801e-09) (1736, -4.6505e-06) (1737, 8.24698e-09) (1739, 4.5801e-09) (1745, 3.9758e-10)
row 1737: (399, 8.45765e-09) (1728, 3.97581e-10) (1736, 6.49395e-09) (1737, -4.65447e-06) (1740, 8.1713e-09) (1746, 3.97581e-10) (2251, 6.49395e-09)
row 1738: (1154, 8.24698e-09) (1729, 3.9758e-10) (1735, 4.5801e-09) (1738, -4.6505e-06) (1739, 4.5801e-09) (1741, 8.24698e-09) (1747, 3.9758e-10)
row 1739: (1730, 3.9758e-10) (1736, 4.5801e-09) (1738, 4.5801e-09) (1739, -4.6505e-06) (1740, 8.24698e-09) (1742, 8.24698e-09) (1748, 3.9758e-10)
row 1740: (1731, 3.97581e-10) (1737, 8.1713e-09) (1739, 6.49395e-09) (1740, -4.65447e-06) (1743, 8.45765e-09) (1749, 3.97581e-10) (2254, 6.49395e-09)
row 1741: (1158, 8.45765e-09) (1732, 3.97581e-10) (1738, 6.49395e-09) (1741, -4.65447e-06) (1742, 8.1713e-09) (1750, 3.97581e-10) (2837, 6.49395e-09)
row 1742: (1733, 3.97581e-10) (1739, 6.49395e-09) (1741, 8.1713e-09) (1742, -4.65447e-06) (1743, 8.45765e-09) (1751, 3.97581e-10) (2838, 6.49395e-09)
row 1743: (1734, 3.97581e-10) (1740, 1.01645e-08) (1742, 1.01645e-08) (1743, -4.65413e-06) (1752, 3.97581e-10) (2257, 4.47458e-09) (2839, 4.47458e-09)
row 1744: (413, 8.24704e-09) (1165, 8.24704e-09) (1735, 3.97583e-10) (1744, -4.65046e-06) (1745, 4.58014e-09) (1747, 4.58014e-09) (1753, 3.97583e-10)
row 1745: (414, 8.24704e-09) (1736, 3.97583e-10) (1744, 4.58014e-09) (1745, -4.65046e-06) (1746, 8.24704e-09) (1748, 4.58014e-09) (1754, 3.97583e-10)
row 1746: (415, 8.45771e-09) (1737, 3.97584e-10) (1745, 6.49399e-09) (1746, -4.65442e-06) (1749, 8.17135e-09) (1755, 3.97584e-10) (2263, 6.49399e-09)
row 1747: (1169, 8.24704e-09) (1738, 3.97583e-10) (1744, 4.58014e-09) (1747, -4.65046e-06) (1748, 4.58014e-09) (1750, 8.24704e-09) (1756, 3.97583e-10)
row 1748: (1739, 3.97583e-10) (1745, 4.58014e-09) (1747, 4.58014e-09) (1748, -4.65046e-06) (1749, 8.24704e-09) (1751, 8.24704e-09) (1757, 3.97583e-10)
row 1749: (1740, 3.97584e-10) (1746, 8.17135e-09) (1748, 6.49399e-09) (1749, -4.65442e-06) (1752, 8.45771e-09) (1758, 3.97584e-10) (2266, 6.49399e-09)
row 1750: (1173, 8.45771e-09) (1741, 3.97584e-10) (1747, 6.49399e-09) (1750, -4.65442e-06) (1751, 8.17135e-09) (1759, 3.97584e-10) (2849, 6.49399e-09)
row 1751: (1742, 3.97584e-10) (1748, 6.49399e-09) (1750, 8.17135e-09) (1751, -4.65442e-06) (1752, 8.45771e-09) (1760, 3.97584e-10) (2850, 6.49399e-09)
row 1752: (1743, 3.97584e-10) (1749, 1.01646e-08) (1751, 1.01646e-08) (1752, -4.65408e-06) (1761, 3.97584e-10) (2269, 4.47462e-09) (2851, 4.47462e-09)
row 1753: (429, 8.2471e-09) (1180, 8.2471e-09) (1744, 3.97586e-10) (1753, -4.65041e-06) (1754, 4.58017e-09) (1756, 4.58017e-09) (1762, 3.97586e-10)
row 1754: (430, 8.2471e-09) (1745, 3.97586e-10) (1753, 4.58017e-09) (1754, -4.65041e-06) (1755, 8.2471e-09) (1757, 4.58017e-09) (1763, 3.97586e-10)
row 1755: (431, 8.45777e-09) (1746, 3.97586e-10) (1754, 6.49404e-09) (1755, -4.65437e-06) (1758, 8.17141e-09) (1764, 3.97586e-10) (2275, 6.49404e-09)
row 1756: (1184, 8.2471e-09) (1747, 3.97586e-10) (1753, 4.58017e-09) (1756, -4.65041e-06) (1757, 4.58017e-09) (1759, 8.2471e-09) (1765, 3.97586e-10)
row 1757: (1748, 3.97586e-10) (1754, 4.58017e-09) (1756, 4.58017e-09) (1757, -4.65041e-06) (1758, 8.2471e-09) (1760, 8.2471e-09) (1766, 3.97586e-10)
row 1758: (1749, 3.97586e-10) (1755, 8.17141e-09) (1757, 6.49404e-09) (1758, -4.65437e-06) (1761, 8.45777e-09) (1767, 3.97586e-10) (2278, 6.49404e-09)
row 1759: (1188, 8.45777e-09) (1750, 3.97586e-10) (1756, 6.49404e-09) (1759, -4.65437e-06) (1760, 8.17141e-09) (1768, 3.97586e-10) (2861, 6.49404e-09)
row 1760: (1751, 3.97586e-10) (1757, 6.49404e-09) (1759, 8.17141e-09) (1760, -4.65437e-06) (1761, 8.45777e-09) (1769, 3.97586e-10) (2862, 6.49404e-09)
row 1761: (1752, 3.97587e-10) (1758, 1.01647e-08) (1760, 1.01647e-08) (1761, -4.65403e-06) (1770, 3.97587e-10) (2281, 4.47465e-09) (2863, 4.47465e-09)
row 1762: (445, 8.24716e-09) (1195, 8.24716e-09) (1753, 3.97588e-10) (1762, -4.65036e-06) (1763, 4.5802e-09) (1765, 4.5802e-09) (1771, 3.97588e-10)
row 1763: (446, 8.24716e-09) (1754, 3.97588e-10) (1762, 4.5802e-09) (1763, -4.65036e-06) (1764, 8.24716e-09) (1766, 4.5802e-09) (1772, 3.97588e-10)
row 1764: (447, 8.45783e-09) (1755, 3.97589e-10) (1763, 6.49409e-09) (1764, -4.65432e-06) (1767, 8.17147e-09) (1773, 3.97589e-10) (2287, 6.49409e-09)
row 1765: (1199, 8.24716e-09) (1756, 3.97588e-10) (1762, 4.5802e-09) (1765, -4.65036e-06) (1766, 4.5802e-09) (1768, 8.24716e-09) (1774, 3.97588e-10)
row 1766: (1757, 3.97588e-10) (1763, 4.5802e-09) (1765, 4.5802e-09) (1766, -4.65036e-06) (1767, 8.24716e-09) (1769, 8.24716e-09) (1775, 3.97588e-10)
row 1767: (1758, 3.97589e-10) (1764, 8.17147e-09) (1766, 6.49409e-09) (1767, -4.65432e-06) (1770, 8.45783e-09) (1776, 3.97589e-10) (2290, 6.49409e-09)
row 1768: (1203, 8.45783e-09) (1759, 3.97589e-10) (1765, 6.49409e-09) (1768, -4.65432e-06) (1769, 8.17147e-09) (1777, 3.97589e-10) (2873, 6.49409e-09)
row 1769: (1760, 3.97589e-10) (1766, 6.49409e-09) (1768, 8.17147e-09) (1769, -4.65432e-06) (1770, 8.45783e-09) (1778, 3.97589e-10) (2874, 6.49409e-09)
row 1770: (1761, 3.9759e-10) (1767, 1.01647e-08) (1769, 1.01647e-08) (1770, -4.65399e-06) (1779, 3.9759e-10) (2293, 4.47468e-09) (2875, 4.47468e-09)
row 1771: (461, 8.24722e-09) (1210, 8.24722e-09) (1762, 3.97591e-10) (1771, -4.65046e-06) (1772, 4.58024e-09) (1774, 4.58024e-09) (1780, 5.40018e-10)
row 1772: (462, 8.24722e-09) (1763, 3.97591e-10) (1771, 4.58024e-09) (1772, -4.65046e-06) (1773, 8.24722e-09) (1775, 4.58024e-09) (1781, 5.40018e-10)
row 1773: (463, 8.45789e-09) (1764, 3.97592e-10) (1772, 6.49414e-09) (1773, -4.65442e-06) (1776, 8.17153e-09) (1782, 5.40019e-10) (2299, 6.49414e-09)
row 1774: (1214, 8.24722e-09) (1765, 3.97591e-10) (1771, 4.58024e-09) (1774, -4.65046e-06) (1775, 4.58024e-09) (1777, 8.24722e-09) (1783, 5.40018e-10)
row 1775: (1766, 3.97591e-10) (1772, 4.58024e-09) (1774, 4.58024e-09) (1775, -4.65046e-06) (1776, 8.24722e-09) (1778, 8.24722e-09) (1784, 5.40018e-10)
row 1776: (1767, 3.97592e-10) (1773, 8.17153e-09) (1775, 6.49414e-09) (1776, -4.65442e-06) (1779, 8.45789e-09) (1785, 5.40019e-10) (2302, 6.49414e-09)
row 1777: (1218, 8.45789e-09) (1768, 3.97592e-10) (1774, 6.49414e-09) (1777, -4.65442e-06) (1778, 8.17153e-09) (1786, 5.40019e-10) (2885, 6.49414e-09)
row 1778: (1769, 3.97592e-10) (1775, 6.49414e-09) (1777, 8.17153e-09) (1778, -4.65442e-06) (1779, 8.45789e-09) (1787, 5.40019e-10) (2886, 6.49414e-09)
row 1779: (1770, 3.97592e-10) (1776, 1.01648e-08) (1778, 1.01648e-08) (1779, -4.65408e-06) (1788, 5.40019e-10) (2305, 4.47471e-09) (2887, 4.47471e-09)
row 1780: (477, 8.24727e-09) (1225, 8.24727e-09) (1771, 1.14311e-09) (1780, -4.65177e-06) (1781, 4.58026e-09) (1783, 4.58026e-09) (1789, 1.14319e-09)
row 1781: (478, 8.24727e-09) (1772, 1.14311e-09) (1780, 4.58026e-09) (1781, -4.65177e-06) (1782, 8.24727e-09) (1784, 4.58026e-09) (1790, 1.14319e-09)
row 1782: (479, 8.45794e-09) (1773, 1.14312e-09) (1781, 6.49417e-09) (1782, -4.65573e-06) (1785, 8.17158e-09) (1791, 1.14319e-09) (2311, 6.49417e-09)
row 1783: (1229, 8.24727e-09) (1774, 1.14311e-09) (1780, 4.58026e-09) (1783, -4.65177e-06) (1784, 4.58026e-09) (1786, 8.24727e-09) (1792, 1.14319e-09)
row 1784: (1775, 1.14311e-09) (1781, 4.58026e-09) (1783, 4.58026e-09) (1784, -4.65177e-06) (1785, 8.24727e-09) (1787, 8.24727e-09) (1793, 1.14319e-09)
row 1785: (1776, 1.14312e-09) (1782, 8.17158e-09) (1784, 6.49417e-09) (1785, -4.65573e-06) (1788, 8.45794e-09) (1794, 1.14319e-09) (2314, 6.49417e-09)
row 1786: (1233, 8.45794e-09) (1777, 1.14312e-09) (1783, 6.49417e-09) (1786, -4.65573e-06) (1787, 8.17158e-09) (1795, 1.14319e-09) (2897, 6.49417e-09)
row 1787: (1778, 1.14312e-09) (1784, 6.49417e-09) (1786, 8.17158e-09) (1787, -4.65573e-06) (1788, 8.45794e-09) (1796, 1.14319e-09) (2898, 6.49417e-09)
row 1788: (1779, 1.14312e-09) (1785, 1.01649e-08) (1787, 1.01649e-08) (1788, -4.65539e-06) (1797, 1.1432e-09) (2317, 4.47474e-09) (2899, 4.47474e-09)
row 1789: (493, 8.24731e-09) (1240, 8.24731e-09) (1780, 5.4006e-10) (1789, -4.65039e-06) (1790, 4.58029e-09) (1792, 4.58029e-09) (1798, 3.97596e-10)
row 1790: (494, 8.24731e-09) (1781, 5.4006e-10) (1789, 4.58029e-09) (1790, -4.65039e-06) (1791, 8.24731e-09) (1793, 4.58029e-09) (1799, 3.97596e-10)
row 1791: (495, 8.45798e-09) (1782, 5.40061e-10) (1790, 6.49421e-09) (1791, -4.65435e-06) (1794, 8.17162e-09) (1800, 3.97596e-10) (2323, 6.49421e-09)
row 1792: (1244, 8.24731e-09) (1783, 5.4006e-10) (1789, 4.58029e-09) (1792, -4.65039e-06) (1793, 4.58029e-09) (1795, 8.24731e-09) (1801, 3.97596e-10)
row 1793: (1784, 5.4006e-10) (1790, 4.58029e-09) (1792, 4.58029e-09) (1793, -4.65039e-06) (1794, 8.24731e-09) (1796, 8.24731e-09) (1802, 3.97596e-10)
row 1794: (1785, 5.40061e-10) (1791, 8.17162e-09) (1793, 6.49421e-09) (1794, -4.65435e-06) (1797, 8.45798e-09) (1803, 3.97596e-10) (2326, 6.49421e-09)
row 1795: (1248, 8.45798e-09) (1786, 5.40061e-10) (1792, 6.49421e-09) (1795, -4.65435e-06) (1796, 8.17162e-09) (1804, 3.97596e-10) (2909, 6.49421e-09)
row 1796: (1787, 5.40061e-10) (1793, 6.49421e-09) (1795, 8.17162e-09) (1796, -4.65435e-06) (1797, 8.45798e-09) (1805, 3.97596e-10) (2910, 6.49421e-09)
row 1797: (1788, 5.40062e-10) (1794, 1.01649e-08) (1796, 1.01649e-08) (1797, -4.65401e-06) (1806, 3.97597e-10) (2329, 4.47476e-09) (2911, 4.47476e-09)
row 1798: (509, 8.24737e-09) (1255, 8.24737e-09) (1789, 3.97598e-10) (1798, -4.6502e-06) (1799, 4.58032e-09) (1801, 4.58032e-09) (1807, 3.97598e-10)
row 1799: (510, 8.24737e-09) (1790, 3.97598e-10) (1798, 4.58032e-09) (1799, -4.6502e-06) (1800, 8.24737e-09) (1802, 4.58032e-09) (1808, 3.97598e-10)
row 1800: (511, 8.45805e-09) (1791, 3.97599e-10) (1799, 6.49425e-09) (1800, -4.65416e-06) (1803, 8.17168e-09) (1809, 3.97599e-10) (2335, 6.49425e-09)
row 1801: (1259, 8.24737e-09) (1792, 3.97598e-10) (1798, 4.58032e-09) (1801, -4.6502e-06) (1802, 4.58032e-09) (1804, 8.24737e-09) (1810, 3.97598e-10)
row 1802: (1793, 3.97598e-10) (1799, 4.58032e-09) (1801, 4.58032e-09) (1802, -4.6502e-06) (1803, 8.24737e-09) (1805, 8.24737e-09) (1811, 3.97598e-10)
row 1803: (1794, 3.97599e-10) (1800, 8.17168e-09) (1802, 6.49425e-09) (1803, -4.65416e-06) (1806, 8.45805e-09) (1812, 3.97599e-10) (2338, 6.49425e-09)
row 1804: (1263, 8.45805e-09) (1795, 3.97599e-10) (1801, 6.49425e-09) (1804, -4.65416e-06) (1805, 8.17168e-09) (1813, 3.97599e-10) (2921, 6.49425e-09)
row 1805: (1796, 3.97599e-10) (1802, 6.49425e-09) (1804, 8.17168e-09) (1805, -4.65416e-06) (1806, 8.45805e-09) (1814, 3.97599e-10) (2922, 6.49425e-09)
row 1806: (1797, 3.976e-10) (1803, 1.0165e-08) (1805, 1.0165e-08) (1806, -4.65382e-06) (1815, 3.976e-10) (2341, 4.4748e-09) (2923, 4.4748e-09)
row 1807: (525, 8.24743e-09) (1270, 8.24743e-09) (1798, 3.97601e-10) (1807, -4.65015e-06) (1808, 4.58035e-09) (1810, 4.58035e-09) (1816, 3.97601e-10)
row 1808: (526, 8.24743e-09) (1799, 3.97601e-10) (1807, 4.58035e-09) (1808, -4.65015e-06) (1809, 8.24743e-09) (1811, 4.58035e-09) (1817, 3.97601e-10)
row 1809: (527, 8.45811e-09) (1800, 3.97602e-10) (1808, 6.4943e-09) (1809, -4.65411e-06) (1812, 8.17174e-09) (1818, 3.97602e-10) (2347, 6.4943e-09)
row 1810: (1274, 8.24743e-09) (1801, 3.97601e-10) (1807, 4.58035e-09) (1810, -4.65015e-06) (1811, 4.58035e-09) (1813, 8.24743e-09) (1819, 3.97601e-10)
row 1811: (1802, 3.97601e-10) (1808, 4.58035e-09) (1810, 4.58035e-09) (1811, -4.65015e-06) (1812, 8.24743e-09) (1814, 8.24743e-09) (1820, 3.97601e-10)
row 1812: (1803, 3.97602e-10) (1809, 8.17174e-09) (1811, 6.4943e-09) (1812, -4.65411e-06) (1815, 8.45811e-09) (1821, 3.97602e-10) (2350, 6.4943e-09)
row 1813: (1278, 8.45811e-09) (1804, 3.97602e-10) (1810, 6.4943e-09) (1813, -4.65411e-06) (1814, 8.17174e-09) (1822, 3.97602e-10) (2933, 6.4943e-09)
row 1814: (1805, 3.97602e-10) (1811, 6.4943e-09) (1813, 8.17174e-09) (1814, -4.65411e-06) (1815, 8.45811e-09) (1823, 3.97602e-10) (2934, 6.4943e-09)
row 1815: (1806, 3.97603e-10) (1812, 1.01651e-08) (1814, 1.01651e-08) (1815, -4.65377e-06) (1824, 3.97603e-10) (2353, 4.47483e-09) (2935, 4.47483e-09)
row 1816: (541, 8.24749e-09) (1285, 8.24749e-09) (1807, 3.97604e-10) (1816, -4.6501e-06) (1817, 4.58039e-09) (1819, 4.58039e-09) (1825, 3.97604e-10)
row 1817: (542, 8.24749e-09) (1808, 3.97604e-10) (1816, 4.58039e-09) (1817, -4.6501e-06) (1818, 8.24749e-09) (1820, 4.58039e-09) (1826, 3.97604e-10)
row 1818: (543, 8.45817e-09) (1809, 3.97605e-10) (1817, 6.49435e-09) (1818, -4.65406e-06) (1821, 8.1718e-09) (1827, 3.97605e-10) (2359, 6.49435e-09)
row 1819: (1289, 8.24749e-09) (1810, 3.97604e-10) (1816, 4.58039e-09) (1819, -4.6501e-06) (1820, 4.58039e-09) (1822, 8.24749e-09) (1828, 3.97604e-10)
row 1820: (1811, 3.97604e-10) (1817, 4.58039e-09) (1819, 4.58039e-09) (1820, -4.6501e-06) (1821, 8.24749e-09) (1823, 8.24749e-09) (1829, 3.97604e-10)
row 1821: (1812, 3.97605e-10) (1818, 8.1718e-09) (1820, 6.49435e-09) (1821, -4.65406e-06) (1824, 8.45817e-09) (1830, 3.97605e-10) (2362, 6.49435e-09)
row 1822: (1293, 8.45817e-09) (1813, 3.97605e-10) (1819, 6.49435e-09) (1822, -4.65406e-06) (1823, 8.1718e-09) (1831, 3.97605e-10) (2945, 6.49435e-09)
row 1823: (1814, 3.97605e-10) (1820, 6.49435e-09) (1822, 8.1718e-09) (1823, -4.65406e-06) (1824, 8.45817e-09) (1832, 3.97605e-10) (2946, 6.49435e-09)
row 1824: (1815, 3.97605e-10) (1821, 1.01651e-08) (1823, 1.01651e-08) (1824, -4.65372e-06) (1833, 3.97605e-10) (2365, 4.47486e-09) (2947, 4.47486e-09)
row 1825: (557, 8.24755e-09) (1300, 8.24755e-09) (1816, 3.97607e-10) (1825, -4.65005e-06) (1826, 4.58042e-09) (1828, 4.58042e-09) (1834, 3.97607e-10)
row 1826: (558, 8.24755e-09) (1817, 3.97607e-10) (1825, 4.58042e-09) (1826, -4.65005e-06) (1827, 8.24755e-09) (1829, 4.58042e-09) (1835, 3.97607e-10)
row 1827: (559, 8.45823e-09) (1818, 3.97608e-10) (1826, 6.49439e-09) (1827, -4.65402e-06) (1830, 8.17186e-09) (1836, 3.97608e-10) (2371, 6.49439e-09)
row 1828: (1304, 8.24755e-09) (1819, 3.97607e-10) (1825, 4.58042e-09) (1828, -4.65005e-06) (1829, 4.58042e-09) (1831, 8.24755e-09) (1837, 3.97607e-10)
row 1829: (1820, 3.97607e-10) (1826, 4.58042e-09) (1828, 4.58042e-09) (1829, -4.65005e-06) (1830, 8.24755e-09) (1832, 8.24755e-09) (1838, 3.97607e-10)
row 1830: (1821, 3.97608e-10) (1827, 8.17186e-09) (1829, 6.49439e-09) (1830, -4.65402e-06) (1833, 8.45823e-09) (1839, 3.97608e-10) (2374, 6.49439e-09)
row 1831: (1308, 8.45823e-09) (1822, 3.97608e-10) (1828, 6.49439e-09) (1831, -4.65402e-06) (1832, 8.17186e-09) (1840, 3.97608e-10) (2957, 6.49439e-09)
row 1832: (1823, 3.97608e-10) (1829, 6.49439e-09) (1831, 8.17186e-09) (1832, -4.65402e-06) (1833, 8.45823e-09) (1841, 3.97608e-10) (2958, 6.49439e-09)
row 1833: (1824, 3.97608e-10) (1830, 1.01652e-08) (1832, 1.01652e-08) (1833, -4.65368e-06) (1842, 3.97608e-10) (2377, 4.47489e-09) (2959, 4.47489e-09)
row 1834: (573, 8.24761e-09) (1315, 8.24761e-09) (1825, 3.9761e-10) (1834, -4.65015e-06) (1835, 4.58045e-09) (1837, 4.58045e-09) (1843, 5.40043e-10)
row 1835: (574, 8.24761e-09) (1826, 3.9761e-10) (1834, 4.58045e-09) (1835, -4.65015e-06) (1836, 8.24761e-09) (1838, 4.58045e-09) (1844, 5.40043e-10)
row 1836: (575, 8.45829e-09) (1827, 3.97611e-10) (1835, 6.49444e-09) (1836, -4.65411e-06) (1839, 8.17192e-09) (1845, 5.40044e-10) (2383, 6.49444e-09)
row 1837: (1319, 8.24761e-09) (1828, 3.9761e-10) (1834, 4.58045e-09) (1837, -4.65015e-06) (1838, 4.58045e-09) (1840, 8.24761e-09) (1846, 5.40043e-10)
row 1838: (1829, 3.9761e-10) (1835, 4.58045e-09) (1837, 4.58045e-09) (1838, -4.65015e-06) (1839, 8.24761e-09) (1841, 8.24761e-09) (1847, 5.40043e-10)
row 1839: (1830, 3.97611e-10) (1836, 8.17192e-09) (1838, 6.49444e-09) (1839, -4.65411e-06) (1842, 8.45829e-09) (1848, 5.40044e-10) (2386, 6.49444e-09)
row 1840: (1323, 8.45829e-09) (1831, 3.97611e-10) (1837, 6.49444e-09) (1840, -4.65411e-06) (1841, 8.17192e-09) (1849, 5.40044e-10) (2969, 6.49444e-09)
row 1841: (1832, 3.97611e-10) (1838, 6.49444e-09) (1840, 8.17192e-09) (1841, -4.65411e-06) (1842, 8.45829e-09) (1850, 5.40044e-10) (2970, 6.49444e-09)
row 1842: (1833, 3.97611e-10) (1839, 1.01653e-08) (1841, 1.01653e-08) (1842, -4.65377e-06) (1851, 5.40045e-10) (2389, 4.47493e-09) (2971, 4.47493e-09)
row 1843: (589, 8.24766e-09) (1330, 8.24766e-09) (1834, 1.14317e-09) (1843, -4.65146e-06) (1844, 4.58048e-09) (1846, 4.58048e-09) (1852, 1.14325e-09)
row 1844: (590, 8.24766e-09) (1835, 1.14317e-09) (1843, 4.58048e-09) (1844, -4.65146e-06) (1845, 8.24766e-09) (1847, 4.58048e-09) (1853, 1.14325e-09)
row 1845: (591, 8.45834e-09) (1836, 1.14317e-09) (1844, 6.49448e-09) (1845, -4.65542e-06) (1848, 8.17196e-09) (1854, 1.14325e-09) (2395, 6.49448e-09)
row 1846: (1334, 8.24766e-09) (1837, 1.14317e-09) (1843, 4.58048e-09) (1846, -4.65146e-06) (1847, 4.58048e-09) (1849, 8.24766e-09) (1855, 1.14325e-09)
row 1847: (1838, 1.14317e-09) (1844, 4.58048e-09) (1846, 4.58048e-09) (1847, -4.65146e-06) (1848, 8.24766e-09) (1850, 8.24766e-09) (1856, 1.14325e-09)
row 1848: (1839, 1.14317e-09) (1845, 8.17196e-09) (1847, 6.49448e-09) (1848, -4.65542e-06) (1851, 8.45834e-09) (1857, 1.14325e-09) (2398, 6.49448e-09)
row 1849: (1338, 8.45834e-09) (1840, 1.14317e-09) (1846, 6.49448e-09) (1849, -4.65542e-06) (1850, 8.17196e-09) (1858, 1.14325e-09) (2981, 6.49448e-09)
row 1850: (1841, 1.14317e-09) (1847, 6.49448e-09) (1849, 8.17196e-09) (1850, -4.65542e-06) (1851, 8.45834e-09) (1859, 1.14325e-09) (2982, 6.49448e-09)
row 1851: (1842, 1.14317e-09) (1848, 1.01653e-08) (1850, 1.01653e-08) (1851, -4.65509e-06) (1860, 1.14325e-09) (2401, 4.47495e-09) (2983, 4.47495e-09)
row 1852: (605, 8.2477e-09) (1345, 8.2477e-09) (1843, 5.40086e-10) (1852, -4.65008e-06) (1853, 4.5805e-09) (1855, 4.5805e-09) (1861, 3.97614e-10)
row 1853: (606, 8.2477e-09) (1844, 5.40086e-10) (1852, 4.5805e-09) (1853, -4.65008e-06) (1854, 8.2477e-09) (1856, 4.5805e-09) (1862, 3.97614e-10)
row 1854: (607, 8.45838e-09) (1845, 5.40087e-10) (1853, 6.49451e-09) (1854, -4.65404e-06) (1857, 8.17201e-09) (1863, 3.97615e-10) (2407, 6.49451e-09)
row 1855: (1349, 8.2477e-09) (1846, 5.40086e-10) (1852, 4.5805e-09) (1855, -4.65008e-06) (1856, 4.5805e-09) (1858, 8.2477e-09) (1864, 3.97614e-10)
row 1856: (1847, 5.40086e-10) (1853, 4.5805e-09) (1855, 4.5805e-09) (1856, -4.65008e-06) (1857, 8.2477e-09) (1859, 8.2477e-09) (1865, 3.97614e-10)
row 1857: (1848, 5.40087e-10) (1854, 8.17201e-09) (1856, 6.49451e-09) (1857, -4.65404e-06) (1860, 8.45838e-09) (1866, 3.97615e-10) (2410, 6.49451e-09)
row 1858: (1353, 8.45838e-09) (1849, 5.40087e-10) (1855, 6.49451e-09) (1858, -4.65404e-06) (1859, 8.17201e-09) (1867, 3.97615e-10) (2993, 6.49451e-09)
row 1859: (1850, 5.40087e-10) (1856, 6.49451e-09) (1858, 8.17201e-09) (1859, -4.65404e-06) (1860, 8.45838e-09) (1868, 3.97615e-10) (2994, 6.49451e-09)
row 1860: (1851, 5.40087e-10) (1857, 1.01654e-08) (1859, 1.01654e-08) (1860, -4.6537e-06) (1869, 3.97615e-10) (2413, 4.47497e-09) (2995, 4.47497e-09)
row 1861: (621, 8.24776e-09) (1360, 8.24776e-09) (1852, 3.97617e-10) (1861, -4.64989e-06) (1862, 4.58054e-09) (1864, 4.58054e-09) (1870, 3.97617e-10)
row 1862: (622, 8.24776e-09) (1853, 3.97617e-10) (1861, 4.58054e-09) (1862, -4.64989e-06) (1863, 8.24776e-09) (1865, 4.58054e-09) (1871, 3.97617e-10)
row 1863: (623, 8.45844e-09) (1854, 3.97618e-10) (1862, 6.49456e-09) (1863, -4.65385e-06) (1866, 8.17207e-09) (1872, 3.97618e-10) (2419, 6.49456e-09)
row 1864: (1364, 8.24776e-09) (1855, 3.97617e-10) (1861, 4.58054e-09) (1864, -4.64989e-06) (1865, 4.58054e-09) (1867, 8.24776e-09) (1873, 3.97617e-10)
row 1865: (1856, 3.97617e-10) (1862, 4.58054e-09) (1864, 4.58054e-09) (1865, -4.64989e-06) (1866, 8.24776e-09) (1868, 8.24776e-09) (1874, 3.97617e-10)
row 1866: (1857, 3.97618e-10) (1863, 8.17207e-09) (1865, 6.49456e-09) (1866, -4.65385e-06) (1869, 8.45844e-09) (1875, 3.97618e-10) (2422, 6.49456e-09)
row 1867: (1368, 8.45844e-09) (1858, 3.97618e-10) (1864, 6.49456e-09) (1867, -4.65385e-06) (1868, 8.17207e-09) (1876, 3.97618e-10) (3005, 6.49456e-09)
row 1868: (1859, 3.97618e-10) (1865, 6.49456e-09) (1867, 8.17207e-09) (1868, -4.65385e-06) (1869, 8.45844e-09) (1877, 3.97618e-10) (3006, 6.49456e-09)
row 1869: (1860, 3.97618e-10) (1866, 1.01655e-08) (1868, 1.01655e-08) (1869, -4.65351e-06) (1878, 3.97618e-10) (2425, 4.47501e-09) (3007, 4.47501e-09)
row 1870: (637, 8.24782e-09) (1375, 8.24782e-09) (1861, 3.9762e-10) (1870, -4.64984e-06) (1871, 4.58057e-09) (1873, 4.58057e-09) (1879, 3.9762e-10)
row 1871: (638, 8.24782e-09) (1862, 3.9762e-10) (1870, 4.58057e-09) (1871, -4.64984e-06) (1872, 8.24782e-09) (1874, 4.58057e-09) (1880, 3.9762e-10)
row 1872: (639, 8.45851e-09) (1863, 3.97621e-10) (1871, 6.49461e-09) (1872, -4.6538e-06) (1875, 8.17212e-09) (1881, 3.97621e-10) (2431, 6.49461e-09)
row 1873: (1379, 8.24782e-09) (1864, 3.9762e-10) (1870, 4.58057e-09) (1873, -4.64984e-06) (1874, 4.58057e-09) (1876, 8.24782e-09) (1882, 3.9762e-10)
row 1874: (1865, 3.9762e-10) (1871, 4.58057e-09) (1873, 4.58057e-09) (1874, -4.64984e-06) (1875, 8.24782e-09) (1877, 8.24782e-09) (1883, 3.9762e-10)
row 1875: (1866, 3.97621e-10) (1872, 8.17212e-09) (1874, 6.49461e-09) (1875, -4.6538e-06) (1878, 8.45851e-09) (1884, 3.97621e-10) (2434, 6.49461e-09)
row 1876: (1383, 8.45851e-09) (1867, 3.97621e-10) (1873, 6.49461e-09) (1876, -4.6538e-06) (1877, 8.17212e-09) (1885, 3.97621e-10) (3017, 6.49461e-09)
row 1877: (1868, 3.97621e-10) (1874, 6.49461e-09) (1876, 8.17212e-09) (1877, -4.6538e-06) (1878, 8.45851e-09) (1886, 3.97621e-10) (3018, 6.49461e-09)
row 1878: (1869, 3.97621e-10) (1875, 1.01655e-08) (1877, 1.01655e-08) (1878, -4.65346e-06) (1887, 3.97621e-10) (2437, 4.47504e-09) (3019, 4.47504e-09)
row 1879: (653, 8.24788e-09) (1390, 8.24788e-09) (1870, 3.97623e-10) (1879, -4.64979e-06) (1880, 4.5806e-09) (1882, 4.5806e-09) (1888, 3.97623e-10)
row 1880: (654, 8.24788e-09) (1871, 3.97623e-10) (1879, 4.5806e-09) (1880, -4.64979e-06) (1881, 8.24788e-09) (1883, 4.5806e-09) (1889, 3.97623e-10)
row 1881: (655, 8.45857e-09) (1872, 3.97624e-10) (1880, 6.49465e-09) (1881, -4.65376e-06) (1884, 8.17218e-09) (1890, 3.97624e-10) (2443, 6.49465e-09)
row 1882: (1394, 8.24788e-09) (1873, 3.97623e-10) (1879, 4.5806e-09) (1882, -4.64979e-06) (1883, 4.5806e-09) (1885, 8.24788e-09) (1891, 3.97623e-10)
row 1883: (1874, 3.97623e-10) (1880, 4.5806e-09) (1882, 4.5806e-09) (1883, -4.64979e-06) (1884, 8.24788e-09) (1886, 8.24788e-09) (1892, 3.97623e-10)
row 1884: (1875, 3.97624e-10) (1881, 8.17218e-09) (1883, 6.49465e-09) (1884, -4.65376e-06) (1887, 8.45857e-09) (1893, 3.97624e-10) (2446, 6.49465e-09)
row 1885: (1398, 8.45857e-09) (1876, 3.97624e-10) (1882, 6.49465e-09) (1885, -4.65376e-06) (1886, 8.17218e-09) (1894, 3.97624e-10) (3029, 6.49465e-09)
row 1886: (1877, 3.97624e-10) (1883, 6.49465e-09) (1885, 8.17218e-09) (1886, -4.65376e-06) (1887, 8.45857e-09) (1895, 3.97624e-10) (3030, 6.49465e-09)
row 1887: (1878, 3.97624e-10) (1884, 1.01656e-08) (1886, 1.01656e-08) (1887, -4.65342e-06) (1896, 3.97624e-10) (2449, 4.47507e-09) (3031, 4.47507e-09)
row 1888: (669, 8.24794e-09) (1405, 8.24794e-09) (1879, 3.97626e-10) (1888, -4.64974e-06) (1889, 4.58064e-09) (1891, 4.58064e-09) (1897, 3.97626e-10)
row 1889: (670, 8.24794e-09) (1880, 3.97626e-10) (1888, 4.58064e-09) (1889, -4.64974e-06) (1890, 8.24794e-09) (1892, 4.58064e-09) (1898, 3.97626e-10)
row 1890: (671, 8.45863e-09) (1881, 3.97627e-10) (1889, 6.4947e-09) (1890, -4.65371e-06) (1893, 8.17224e-09) (1899, 3.97627e-10) (2455, 6.4947e-09)
row 1891: (1409, 8.24794e-09) (1882, 3.97626e-10) (1888, 4.58064e-09) (1891, -4.64974e-06) (1892, 4.58064e-09) (1894, 8.24794e-09) (1900, 3.97626e-10)
row 1892: (1883, 3.97626e-10) (1889, 4.58064e-09) (1891, 4.58064e-09) (1892, -4.64974e-06) (1893, 8.24794e-09) (1895, 8.24794e-09) (1901, 3.97626e-10)
row 1893: (1884, 3.97627e-10) (1890, 8.17224e-09) (1892, 6.4947e-09) (1893, -4.65371e-06) (1896, 8.45863e-09) (1902, 3.97627e-10) (2458, 6.4947e-09)
row 1894: (1413, 8.45863e-09) (1885, 3.97627e-10) (1891, 6.4947e-09) (1894, -4.65371e-06) (1895, 8.17224e-09) (1903, 3.97627e-10) (3041, 6.4947e-09)
row 1895: (1886, 3.97627e-10) (1892, 6.4947e-09) (1894, 8.17224e-09) (1895, -4.65371e-06) (1896, 8.45863e-09) (1904, 3.97627e-10) (3042, 6.4947e-09)
row 1896: (1887, 3.97627e-10) (1893, 1.01657e-08) (1895, 1.01657e-08) (1896, -4.65337e-06) (1905, 3.97627e-10) (2461, 4.4751e-09) (3043, 4.4751e-09)
row 1897: (685, 8.248e-09) (1420, 8.248e-09) (1888, 3.97629e-10) (1897, -4.64984e-06) (1898, 4.58067e-09) (1900, 4.58067e-09) (1906, 5.40069e-10)
row 1898: (686, 8.248e-09) (1889, 3.97629e-10) (1897, 4.58067e-09) (1898, -4.64984e-06) (1899, 8.248e-09) (1901, 4.58067e-09) (1907, 5.40069e-10)
row 1899: (687, 8.45869e-09) (1890, 3.9763e-10) (1898, 6.49475e-09) (1899, -4.6538e-06) (1902, 8.1723e-09) (1908, 5.4007e-10) (2467, 6.49475e-09)
row 1900: (1424, 8.248e-09) (1891, 3.97629e-10) (1897, 4.58067e-09) (1900, -4.64984e-06) (1901, 4.58067e-09) (1903, 8.248e-09) (1909, 5.40069e-10)
row 1901: (1892, 3.97629e-10) (1898, 4.58067e-09) (1900, 4.58067e-09) (1901, -4.64984e-06) (1902, 8.248e-09) (1904, 8.248e-09) (1910, 5.40069e-10)
row 1902: (1893, 3.9763e-10) (1899, 8.1723e-09) (1901, 6.49475e-09) (1902, -4.6538e-06) (1905, 8.45869e-09) (1911, 5.4007e-10) (2470, 6.49475e-09)
row 1903: (1428, 8.45869e-09) (1894, 3.9763e-10) (1900, 6.49475e-09) (1903, -4.6538e-06) (1904, 8.1723e-09) (1912, 5.4007e-10) (3053, 6.49475e-09)
row 1904: (1895, 3.9763e-10) (1901, 6.49475e-09) (1903, 8.1723e-09) (1904, -4.6538e-06) (1905, 8.45869e-09) (1913, 5.4007e-10) (3054, 6.49475e-09)
row 1905: (1896, 3.9763e-10) (1902, 1.01658e-08) (1904, 1.01658e-08) (1905, -4.65346e-06) (1914, 5.4007e-10) (2473, 4.47514e-09) (3055, 4.47514e-09)
row 1906: (701, 8.24805e-09) (1435, 8.24805e-09) (1897, 1.14322e-09) (1906, -4.65117e-06) (1907, 4.58069e-09) (1909, 4.58069e-09) (1915, 1.15731e-09)
row 1907: (702, 8.24805e-09) (1898, 1.14322e-09) (1906, 4.58069e-09) (1907, -4.65117e-06) (1908, 8.24805e-09) (1910, 4.58069e-09) (1916, 1.15731e-09)
row 1908: (703, 8.45874e-09) (1899, 1.14322e-09) (1907, 6.49478e-09) (1908, -4.65513e-06) (1911, 8.17235e-09) (1917, 1.15732e-09) (2479, 6.49478e-09)
row 1909: (1439, 8.24805e-09) (1900, 1.14322e-09) (1906, 4.58069e-09) (1909, -4.65117e-06) (1910, 4.58069e-09) (1912, 8.24805e-09) (1918, 1.15731e-09)
row 1910: (1901, 1.14322e-09) (1907, 4.58069e-09) (1909, 4.58069e-09) (1910, -4.65117e-06) (1911, 8.24805e-09) (1913, 8.24805e-09) (1919, 1.15731e-09)
row 1911: (1902, 1.14322e-09) (1908, 8.17235e-09) (1910, 6.49478e-09) (1911, -4.65513e-06) (1914, 8.45874e-09) (1920, 1.15732e-09) (2482, 6.49478e-09)
row 1912: (1443, 8.45874e-09) (1903, 1.14322e-09) (1909, 6.49478e-09) (1912, -4.65513e-06) (1913, 8.17235e-09) (1921, 1.15732e-09) (3065, 6.49478e-09)
row 1913: (1904, 1.14322e-09) (1910, 6.49478e-09) (1912, 8.17235e-09) (1913, -4.65513e-06) (1914, 8.45874e-09) (1922, 1.15732e-09) (3066, 6.49478e-09)
row 1914: (1905, 1.14323e-09) (1911, 1.01658e-08) (1913, 1.01658e-08) (1914, -4.65479e-06) (1923, 1.15732e-09) (2485, 4.47516e-09) (3067, 4.47516e-09)
row 1915: (717, 8.24809e-09) (1450, 8.24809e-09) (1906, 5.56657e-10) (1915, -4.6498e-06) (1916, 4.58072e-09) (1918, 4.58072e-09) (1924, 4.12201e-10)
row 1916: (718, 8.24809e-09) (1907, 5.56657e-10) (1915, 4.58072e-09) (1916, -4.6498e-06) (1917, 8.24809e-09) (1919, 4.58072e-09) (1925, 4.12201e-10)
row 1917: (719, 8.45878e-09) (1908, 5.56658e-10) (1916, 6.49482e-09) (1917, -4.65376e-06) (1920, 8.17239e-09) (1926, 4.12202e-10) (2491, 6.49482e-09)
row 1918: (1454, 8.24809e-09) (1909, 5.56657e-10) (1915, 4.58072e-09) (1918, -4.6498e-06) (1919, 4.58072e-09) (1921, 8.24809e-09) (1927, 4.12201e-10)
row 1919: (1910, 5.56657e-10) (1916, 4.58072e-09) (1918, 4.58072e-09) (1919, -4.6498e-06) (1920, 8.24809e-09) (1922, 8.24809e-09) (1928, 4.12201e-10)
row 1920: (1911, 5.56658e-10) (1917, 8.17239e-09) (1919, 6.49482e-09) (1920, -4.65376e-06) (1923, 8.45878e-09) (1929, 4.12202e-10) (2494, 6.49482e-09)
row 1921: (1458, 8.45878e-09) (1912, 5.56658e-10) (1918, 6.49482e-09) (1921, -4.65376e-06) (1922, 8.17239e-09) (1930, 4.12202e-10) (3077, 6.49482e-09)
row 1922: (1913, 5.56658e-10) (1919, 6.49482e-09) (1921, 8.17239e-09) (1922, -4.65376e-06) (1923, 8.45878e-09) (1931, 4.12202e-10) (3078, 6.49482e-09)
row 1923: (1914, 5.56659e-10) (1920, 1.01659e-08) (1922, 1.01659e-08) (1923, -4.65342e-06) (1932, 4.12202e-10) (2497, 4.47518e-09) (3079, 4.47518e-09)
row 1924: (733, 8.24815e-09) (1465, 8.24815e-09) (1915, 4.12204e-10) (1924, -4.64961e-06) (1925, 4.58075e-09) (1927, 4.58075e-09) (1933, 4.12204e-10)
row 1925: (734, 8.24815e-09) (1916, 4.12204e-10) (1924, 4.58075e-09) (1925, -4.64961e-06) (1926, 8.24815e-09) (1928, 4.58075e-09) (1934, 4.12204e-10)
row 1926: (735, 8.45884e-09) (1917, 4.12205e-10) (1925, 6.49486e-09) (1926, -4.65357e-06) (1929, 8.17245e-09) (1935, 4.12205e-10) (2503, 6.49486e-09)
row 1927: (1469, 8.24815e-09) (1918, 4.12204e-10) (1924, 4.58075e-09) (1927, -4.64961e-06) (1928, 4.58075e-09) (1930, 8.24815e-09) (1936, 4.12204e-10)
row 1928: (1919, 4.12204e-10) (1925, 4.58075e-09) (1927, 4.58075e-09) (1928, -4.64961e-06) (1929, 8.24815e-09) (1931, 8.24815e-09) (1937, 4.12204e-10)
row 1929: (1920, 4.12205e-10) (1926, 8.17245e-09) (1928, 6.49486e-09) (1929, -4.65357e-06) (1932, 8.45884e-09) (1938, 4.12205e-10) (2506, 6.49486e-09)
row 1930: (1473, 8.45884e-09) (1921, 4.12205e-10) (1927, 6.49486e-09) (1930, -4.65357e-06) (1931, 8.17245e-09) (1939, 4.12205e-10) (3089, 6.49486e-09)
row 1931: (1922, 4.12205e-10) (1928, 6.49486e-09) (1930, 8.17245e-09) (1931, -4.65357e-06) (1932, 8.45884e-09) (1940, 4.12205e-10) (3090, 6.49486e-09)
row 1932: (1923, 4.12205e-10) (1929, 1.01659e-08) (1931, 1.01659e-08) (1932, -4.65323e-06) (1941, 4.12205e-10) (2509, 4.47522e-09) (3091, 4.47522e-09)
row 1933: (749, 8.24821e-09) (1480, 8.24821e-09) (1924, 4.12207e-10) (1933, -4.64956e-06) (1934, 4.58078e-09) (1936, 4.58078e-09) (1942, 4.12207e-10)
row 1934: (750, 8.24821e-09) (1925, 4.12207e-10) (1933, 4.58078e-09) (1934, -4.64956e-06) (1935, 8.24821e-09) (1937, 4.58078e-09) (1943, 4.12207e-10)
row 1935: (751, 8.4589e-09) (1926, 4.12208e-10) (1934, 6.49491e-09) (1935, -4.65353e-06) (1938, 8.17251e-09) (1944, 4.12208e-10) (2515, 6.49491e-09)
row 1936: (1484, 8.24821e-09) (1927, 4.12207e-10) (1933, 4.58078e-09) (1936, -4.64956e-06) (1937, 4.58078e-09) (1939, 8.24821e-09) (1945, 4.12207e-10)
row 1937: (1928, 4.12207e-10) (1934, 4.58078e-09) (1936, 4.58078e-09) (1937, -4.64956e-06) (1938, 8.24821e-09) (1940, 8.24821e-09) (1946, 4.12207e-10)
row 1938: (1929, 4.12208e-10) (1935, 8.17251e-09) (1937, 6.49491e-09) (1938, -4.65353e-06) (1941, 8.4589e-09) (1947, 4.12208e-10) (2518, 6.49491e-09)
row 1939: (1488, 8.4589e-09) (1930, 4.12208e-10) (1936, 6.49491e-09) (1939, -4.65353e-06) (1940, 8.17251e-09) (1948, 4.12208e-10) (3101, 6.49491e-09)
row 1940: (1931, 4.12208e-10) (1937, 6.49491e-09) (1939, 8.17251e-09) (1940, -4.65353e-06) (1941, 8.4589e-09) (1949, 4.12208e-10) (3102, 6.49491e-09)
row 1941: (1932, 4.12208e-10) (1938, 1.0166e-08) (1940, 1.0166e-08) (1941, -4.65319e-06) (1950, 4.12208e-10) (2521, 4.47525e-09) (3103, 4.47525e-09)
row 1942: (765, 8.24827e-09) (1495, 8.24827e-09) (1933, 4.1221e-10) (1942, -4.64952e-06) (1943, 4.58082e-09) (1945, 4.58082e-09) (1951, 4.1221e-10)
row 1943: (766, 8.24827e-09) (1934, 4.1221e-10) (1942, 4.58082e-09) (1943, -4.64952e-06) (1944, 8.24827e-09) (1946, 4.58082e-09) (1952, 4.1221e-10)
row 1944: (767, 8.45896e-09) (1935, 4.12211e-10) (1943, 6.49496e-09) (1944, -4.65348e-06) (1947, 8.17257e-09) (1953, 4.12211e-10) (2527, 6.49496e-09)
row 1945: (1499, 8.24827e-09) (1936, 4.1221e-10) (1942, 4.58082e-09) (1945, -4.64952e-06) (1946, 4.58082e-09) (1948, 8.24827e-09) (1954, 4.1221e-10)
row 1946: (1937, 4.1221e-10) (1943, 4.58082e-09) (1945, 4.58082e-09) (1946, -4.64952e-06) (1947, 8.24827e-09) (1949, 8.24827e-09) (1955, 4.1221e-10)
row 1947: (1938, 4.12211e-10) (1944, 8.17257e-09) (1946, 6.49496e-09) (1947, -4.65348e-06) (1950, 8.45896e-09) (1956, 4.12211e-10) (2530, 6.49496e-09)
row 1948: (1503, 8.45896e-09) (1939, 4.12211e-10) (1945, 6.49496e-09) (1948, -4.65348e-06) (1949, 8.17257e-09) (1957, 4.12211e-10) (3113, 6.49496e-09)
row 1949: (1940, 4.12211e-10) (1946, 6.49496e-09) (1948, 8.17257e-09) (1949, -4.65348e-06) (1950, 8.45896e-09) (1958, 4.12211e-10) (3114, 6.49496e-09)
row 1950: (1941, 4.12211e-10) (1947, 1.01661e-08) (1949, 1.01661e-08) (1950, -4.65314e-06) (1959, 4.12211e-10) (2533, 4.47528e-09) (3115, 4.47528e-09)
row 1951: (781, 8.24833e-09) (1510, 8.24833e-09) (1942, 4.12213e-10) (1951, -4.64947e-06) (1952, 4.58085e-09) (1954, 4.58085e-09)
row 1952: (782, 8.24833e-09) (1943, 4.12213e-10) (1951, 4.58085e-09) (1952, -4.64947e-06) (1953, 8.24833e-09) (1955, 4.58085e-09)
row 1953: (783, 8.45902e-09) (1944, 4.12214e-10) (1952, 6.495e-09) (1953, -4.65343e-06) (1956, 8.17263e-09) (2539, 6.495e-09)
row 1954: (1514, 8.24833e-09) (1945, 4.12213e-10) (1951, 4.58085e-09) (1954, -4.64947e-06) (1955, 4.58085e-09) (1957, 8.24833e-09)
row 1955: (1946, 4.12213e-10) (1952, 4.58085e-09) (1954, 4.58085e-09) (1955, -4.64947e-06) (1956, 8.24833e-09) (1958, 8.24833e-09)
row 1956: (1947, 4.12214e-10) (1953, 8.17263e-09) (1955, 6.495e-09) (1956, -4.65343e-06) (1959, 8.45902e-09) (2542, 6.495e-09)
row 1957: (1518, 8.45902e-09) (1948, 4.12214e-10) (1954, 6.495e-09) (1957, -4.65343e-06) (1958, 8.17263e-09) (3125, 6.495e-09)
row 1958: (1949, 4.12214e-10) (1955, 6.495e-09) (1957, 8.17263e-09) (1958, -4.65343e-06) (1959, 8.45902e-09) (3126, 6.495e-09)
row 1959: (1950, 4.12214e-10) (1956, 1.01662e-08) (1958, 1.01662e-08) (1959, -4.65309e-06) (2545, 4.47531e-09) (3127, 4.47531e-09)
row 1960: (15, 7.44519e-09) (1960, -4.65786e-06) (1961, 8.16997e-09) (1963, 1.60166e-08) (1972, 1.10757e-09)
row 1961: (1960, 8.16997e-09) (1961, -4.6602e-06) (1962, 9.78524e-09) (1964, 1.60166e-08) (1973, 1.10757e-09)
row 1962: (1961, 1.764e-08) (1962, -4.66151e-06) (1965, 1.764e-08) (1974, 1.10757e-09)
row 1963: (1521, 8.24565e-09) (1960, 1.01701e-08) (1963, -4.65381e-06) (1964, 4.57936e-09) (1966, 4.57936e-09) (1975, 1.10757e-09)
row 1964: (1961, 1.01701e-08) (1963, 4.57936e-09) (1964, -4.65573e-06) (1965, 1.01701e-08) (1967, 4.57936e-09) (1976, 1.10757e-09)
row 1965: (1962, 9.78524e-09) (1964, 1.60166e-08) (1965, -4.6602e-06) (1968, 8.16997e-09) (1977, 1.10757e-09)
row 1966: (1524, 8.24565e-09) (1963, 4.57936e-09) (1966, -4.65381e-06) (1967, 4.57936e-09) (1969, 1.01701e-08) (1978, 1.10757e-09)
row 1967: (1964, 4.57936e-09) (1966, 4.57936e-09) (1967, -4.65573e-06) (1968, 1.01701e-08) (1970, 1.01701e-08) (1979, 1.10757e-09)
row 1968: (1965, 8.16997e-09) (1967, 1.60166e-08) (1968, -4.6602e-06) (1971, 9.78524e-09) (1980, 1.10757e-09)
row 1969: (1527, 7.44519e-09) (1966, 1.60166e-08) (1969, -4.65786e-06) (1970, 8.16997e-09) (1981, 1.10757e-09)
row 1970: (1967, 1.60166e-08) (1969, 8.16997e-09) (1970, -4.6602e-06) (1971, 9.78524e-09) (1982, 1.10757e-09)
row 1971: (1968, 1.764e-08) (1970, 1.764e-08) (1971, -4.66151e-06) (1983, 1.10757e-09)
row 1972: (31, 7.44523e-09) (1960, 5.21484e-10) (1972, -4.65763e-06) (1973, 8.17002e-09) (1975, 1.60167e-08) (1984, 3.83508e-10)
row 1973: (1961, 5.21484e-10) (1972, 8.17002e-09) (1973, -4.65997e-06) (1974, 9.78529e-09) (1976, 1.60167e-08) (1985, 3.83508e-10)
row 1974: (1962, 5.21484e-10) (1973, 1.76401e-08) (1974, -4.66127e-06) (1977, 1.76401e-08) (1986, 3.83508e-10)
row 1975: (1530, 8.2457e-09) (1963, 5.21483e-10) (1972, 1.01702e-08) (1975, -4.65357e-06) (1976, 4.57939e-09) (1978, 4.57939e-09) (1987, 3.83507e-10)
row 1976: (1964, 5.21483e-10) (1973, 1.01702e-08) (1975, 4.57939e-09) (1976, -4.65549e-06) (1977, 1.01702e-08) (1979, 4.57939e-09) (1988, 3.83507e-10)
row 1977: (1965, 5.21484e-10) (1974, 9.78529e-09) (1976, 1.60167e-08) (1977, -4.65997e-06) (1980, 8.17002e-09) (1989, 3.83508e-10)
row 1978: (1533, 8.2457e-09) (1966, 5.21483e-10) (1975, 4.57939e-09) (1978, -4.65357e-06) (1979, 4.57939e-09) (1981, 1.01702e-08) (1990, 3.83507e-10)
row 1979: (1967, 5.21483e-10) (1976, 4.57939e-09) (1978, 4.57939e-09) (1979, -4.65549e-06) (1980, 1.01702e-08) (1982, 1.01702e-08) (1991, 3.83507e-10)
row 1980: (1968, 5.21484e-10) (1977, 8.17002e-09) (1979, 1.60167e-08) (1980, -4.65997e-06) (1983, 9.78529e-09) (1992, 3.83508e-10)
row 1981: (1536, 7.44523e-09) (1969, 5.21484e-10) (1978, 1.60167e-08) (1981, -4.65763e-06) (1982, 8.17002e-09) (1993, 3.83508e-10)
row 1982: (1970, 5.21484e-10) (1979, 1.60167e-08) (1981, 8.17002e-09) (1982, -4.65997e-06) (1983, 9.78529e-09) (1994, 3.83508e-10)
row 1983: (1971, 5.21484e-10) (1980, 1.76401e-08) (1982, 1.76401e-08) (1983, -4.66127e-06) (1995, 3.83508e-10)
row 1984: (47, 7.44529e-09) (1972, 3.8351e-10) (1984, -4.65744e-06) (1985, 8.17008e-09) (1987, 1.60168e-08) (1996, 3.8351e-10)
row 1985: (1973, 3.8351e-10) (1984, 8.17008e-09) (1985, -4.65978e-06) (1986, 9.78536e-09) (1988, 1.60168e-08) (1997, 3.8351e-10)
row 1986: (1974, 3.83511e-10) (1985, 1.76402e-08) (1986, -4.66109e-06) (1989, 1.76402e-08) (1998, 3.83511e-10)
row 1987: (1539, 8.24576e-09) (1975, 3.8351e-10) (1984, 1.01702e-08) (1987, -4.65338e-06) (1988, 4.57942e-09) (1990, 4.57942e-09) (1999, 3.8351e-10)
row 1988: (1976, 3.8351e-10) (1985, 1.01702e-08) (1987, 4.57942e-09) (1988, -4.65531e-06) (1989, 1.01702e-08) (1991, 4.57942e-09) (2000, 3.8351e-10)
row 1989: (1977, 3.8351e-10) (1986, 9.78536e-09) (1988, 1.60168e-08) (1989, -4.65978e-06) (1992, 8.17008e-09) (2001, 3.8351e-10)
row 1990: (1542, 8.24576e-09) (1978, 3.8351e-10) (1987, 4.57942e-09) (1990, -4.65338e-06) (1991, 4.57942e-09) (1993, 1.01702e-08) (2002, 3.8351e-10)
row 1991: (1979, 3.8351e-10) (1988, 4.57942e-09) (1990, 4.57942e-09) (1991, -4.65531e-06) (1992, 1.01702e-08) (1994, 1.01702e-08) (2003, 3.8351e-10)
row 1992: (1980, 3.8351e-10) (1989, 8.17008e-09) (1991, 1.60168e-08) (1992, -4.65978e-06) (1995, 9.78536e-09) (2004, 3.8351e-10)
row 1993: (1545, 7.44529e-09) (1981, 3.8351e-10) (1990, 1.60168e-08) (1993, -4.65744e-06) (1994, 8.17008e-09) (2005, 3.8351e-10)
row 1994: (1982, 3.8351e-10) (1991, 1.60168e-08) (1993, 8.17008e-09) (1994, -4.65978e-06) (1995, 9.78536e-09) (2006, 3.8351e-10)
row 1995: (1983, 3.83511e-10) (1992, 1.76402e-08) (1994, 1.76402e-08) (1995, -4.66109e-06) (2007, 3.83511e-10)
row 1996: (63, 7.44534e-09) (1984, 3.83513e-10) (1996, -4.65739e-06) (1997, 8.17014e-09) (1999, 1.60169e-08) (2008, 3.8349e-10)
row 1997: (1985, 3.83513e-10) (1996, 8.17014e-09) (1997, -4.65973e-06) (1998, 9.78543e-09) (2000, 1.60169e-08) (2009, 3.8349e-10)
row 1998: (1986, 3.83514e-10) (1997, 1.76404e-08) (1998, -4.66104e-06) (2001, 1.76404e-08) (2010, 3.8349e-10)
row 1999: (1548, 8.24582e-09) (1987, 3.83512e-10) (1996, 1.01703e-08) (1999, -4.65333e-06) (2000, 4.57946e-09) (2002, 4.57946e-09) (2011, 3.83489e-10)
row 2000: (1988, 3.83512e-10) (1997, 1.01703e-08) (1999, 4.57946e-09) (2000, -4.65526e-06) (2001, 1.01703e-08) (2003, 4.57946e-09) (2012, 3.83489e-10)
row 2001: (1989, 3.83513e-10) (1998, 9.78543e-09) (2000, 1.60169e-08) (2001, -4.65973e-06) (2004, 8.17014e-09) (2013, 3.8349e-10)
row 2002: (1551, 8.24582e-09) (1990, 3.83512e-10) (1999, 4.57946e-09) (2002, -4.65333e-06) (2003, 4.57946e-09) (2005, 1.01703e-08) (2014, 3.83489e-10)
row 2003: (1991, 3.83512e-10) (2000, 4.57946e-09) (2002, 4.57946e-09) (2003, -4.65526e-06) (2004, 1.01703e-08) (2006, 1.01703e-08) (2015, 3.83489e-10)
row 2004: (1992, 3.83513e-10) (2001, 8.17014e-09) (2003, 1.60169e-08) (2004, -4.65973e-06) (2007, 9.78543e-09) (2016, 3.8349e-10)
row 2005: (1554, 7.44534e-09) (1993, 3.83513e-10) (2002, 1.60169e-08) (2005, -4.65739e-06) (2006, 8.17014e-09) (2017, 3.8349e-10)
row 2006: (1994, 3.83513e-10) (2003, 1.60169e-08) (2005, 8.17014e-09) (2006, -4.65973e-06) (2007, 9.78543e-09) (2018, 3.8349e-10)
row 2007: (1995, 3.83514e-10) (2004, 1.76404e-08) (2006, 1.76404e-08) (2007, -4.66104e-06) (2019, 3.8349e-10)
row 2008: (79, 7.4454e-09) (1996, 3.83446e-10) (2008, -4.65734e-06) (2009, 8.1702e-09) (2011, 1.6017e-08) (2020, 3.83446e-10)
row 2009: (1997, 3.83446e-10) (2008, 8.1702e-09) (2009, -4.65968e-06) (2010, 9.78551e-09) (2012, 1.6017e-08) (2021, 3.83446e-10)
row 2010: (1998, 3.83446e-10) (2009, 1.76405e-08) (2010, -4.66099e-06) (2013, 1.76405e-08) (2022, 3.83446e-10)
row 2011: (1557, 8.24588e-09) (1999, 3.83445e-10) (2008, 1.01704e-08) (2011, -4.65328e-06) (2012, 4.57949e-09) (2014, 4.57949e-09) (2023, 3.83445e-10)
row 2012: (2000, 3.83445e-10) (2009, 1.01704e-08) (2011, 4.57949e-09) (2012, -4.65521e-06) (2013, 1.01704e-08) (2015, 4.57949e-09) (2024, 3.83445e-10)
row 2013: (2001, 3.83446e-10) (2010, 9.78551e-09) (2012, 1.6017e-08) (2013, -4.65968e-06) (2016, 8.1702e-09) (2025, 3.83446e-10)
row 2014: (1560, 8.24588e-09) (2002, 3.83445e-10) (2011, 4.57949e-09) (2014, -4.65328e-06) (2015, 4.57949e-09) (2017, 1.01704e-08) (2026, 3.83445e-10)
row 2015: (2003, 3.83445e-10) (2012, 4.57949e-09) (2014, 4.57949e-09) (2015, -4.65521e-06) (2016, 1.01704e-08) (2018, 1.01704e-08) (2027, 3.83445e-10)
row 2016: (2004, 3.83446e-10) (2013, 8.1702e-09) (2015, 1.6017e-08) (2016, -4.65968e-06) (2019, 9.78551e-09) (2028, 3.83446e-10)
row 2017: (1563, 7.4454e-09) (2005, 3.83446e-10) (2014, 1.6017e-08) (2017, -4.65734e-06) (2018, 8.1702e-09) (2029, 3.83446e-10)
row 2018: (2006, 3.83446e-10) (2015, 1.6017e-08) (2017, 8.1702e-09) (2018, -4.65968e-06) (2019, 9.78551e-09) (2030, 3.83446e-10)
row 2019: (2007, 3.83446e-10) (2016, 1.76405e-08) (2018, 1.76405e-08) (2019, -4.66099e-06) (2031, 3.83446e-10)
row 2020: (95, 7.44545e-09) (2008, 3.83496e-10) (2020, -4.65729e-06) (2021, 8.17026e-09) (2023, 1.60171e-08) (2032, 3.83519e-10)
row 2021: (2009, 3.83496e-10) (2020, 8.17026e-09) (2021, -4.65963e-06) (2022, 9.78558e-09) (2024, 1.60171e-08) (2033, 3.83519e-10)
row 2022: (2010, 3.83496e-10) (2021, 1.76406e-08) (2022, -4.66094e-06) (2025, 1.76406e-08) (2034, 3.83519e-10)
row 2023: (1566, 8.24594e-09) (2011, 3.83495e-10) (2020, 1.01705e-08) (2023, -4.65324e-06) (2024, 4.57952e-09) (2026, 4.57952e-09) (2035, 3.83518e-10)
row 2024: (2012, 3.83495e-10) (2021, 1.01705e-08) (2023, 4.57952e-09) (2024, -4.65516e-06) (2025, 1.01705e-08) (2027, 4.57952e-09) (2036, 3.83518e-10)
row 2025: (2013, 3.83496e-10) (2022, 9.78558e-09) (2024, 1.60171e-08) (2025, -4.65963e-06) (2028, 8.17026e-09) (2037, 3.83519e-10)
row 2026: (1569, 8.24594e-09) (2014, 3.83495e-10) (2023, 4.57952e-09) (2026, -4.65324e-06) (2027, 4.57952e-09) (2029, 1.01705e-08) (2038, 3.83518e-10)
row 2027: (2015, 3.83495e-10) (2024, 4.57952e-09) (2026, 4.57952e-09) (2027, -4.65516e-06) (2028, 1.01705e-08) (2030, 1.01705e-08) (2039, 3.83518e-10)
row 2028: (2016, 3.83496e-10) (2025, 8.17026e-09) (2027, 1.60171e-08) (2028, -4.65963e-06) (2031, 9.78558e-09) (2040, 3.83519e-10)
row 2029: (1572, 7.44545e-09) (2017, 3.83496e-10) (2026, 1.60171e-08) (2029, -4.65729e-06) (2030, 8.17026e-09) (2041, 3.83519e-10)
row 2030: (2018, 3.83496e-10) (2027, 1.60171e-08) (2029, 8.17026e-09) (2030, -4.65963e-06) (2031, 9.78558e-09) (2042, 3.83519e-10)
row 2031: (2019, 3.83496e-10) (2028, 1.76406e-08) (2030, 1.76406e-08) (2031, -4.66094e-06) (2043, 3.83519e-10)
row 2032: (111, 7.44551e-09) (2020, 3.83522e-10) (2032, -4.65724e-06) (2033, 8.17032e-09) (2035, 1.60172e-08) (2044, 3.83522e-10)
row 2033: (2021, 3.83522e-10) (2032, 8.17032e-09) (2033, -4.65958e-06) (2034, 9.78565e-09) (2036, 1.60172e-08) (2045, 3.83522e-10)
row 2034: (2022, 3.83522e-10) (2033, 1.76408e-08) (2034, -4.66089e-06) (2037, 1.76408e-08) (2046, 3.83522e-10)
row 2035: (1575, 8.246e-09) (2023, 3.83521e-10) (2032, 1.01705e-08) (2035, -4.65319e-06) (2036, 4.57956e-09) (2038, 4.57956e-09) (2047, 3.83521e-10)
row 2036: (2024, 3.83521e-10) (2033, 1.01705e-08) (2035, 4.57956e-09) (2036, -4.65511e-06) (2037, 1.01705e-08) (2039, 4.57956e-09) (2048, 3.83521e-10)
row 2037: (2025, 3.83522e-10) (2034, 9.78565e-09) (2036, 1.60172e-08) (2037, -4.65958e-06) (2040, 8.17032e-09) (2049, 3.83522e-10)
row 2038: (1578, 8.246e-09) (2026, 3.83521e-10) (2035, 4.57956e-09) (2038, -4.65319e-06) (2039, 4.57956e-09) (2041, 1.01705e-08) (2050, 3.83521e-10)
row 2039: (2027, 3.83521e-10) (2036, 4.57956e-09) (2038, 4.57956e-09) (2039, -4.65511e-06) (2040, 1.01705e-08) (2042, 1.01705e-08) (2051, 3.83521e-10)
row 2040: (2028, 3.83522e-10) (2037, 8.17032e-09) (2039, 1.60172e-08) (2040, -4.65958e-06) (2043, 9.78565e-09) (2052, 3.83522e-10)
row 2041: (1581, 7.44551e-09) (2029, 3.83522e-10) (2038, 1.60172e-08) (2041, -4.65724e-06) (2042, 8.17032e-09) (2053, 3.83522e-10)
row 2042: (2030, 3.83522e-10) (2039, 1.60172e-08) (2041, 8.17032e-09) (2042, -4.65958e-06) (2043, 9.78565e-09) (2054, 3.83522e-10)
row 2043: (2031, 3.83522e-10) (2040, 1.76408e-08) (2042, 1.76408e-08) (2043, -4.66089e-06) (2055, 3.83522e-10)
row 2044: (127, 7.44556e-09) (2032, 3.83525e-10) (2044, -4.65734e-06) (2045, 8.17038e-09) (2047, 1.60174e-08) (2056, 5.23901e-10)
row 2045: (2033, 3.83525e-10) (2044, 8.17038e-09) (2045, -4.65968e-06) (2046, 9.78572e-09) (2048, 1.60174e-08) (2057, 5.23901e-10)
row 2046: (2034, 3.83525e-10) (2045, 1.76409e-08) (2046, -4.66098e-06) (2049, 1.76409e-08) (2058, 5.23901e-10)
row 2047: (1584, 8.24606e-09) (2035, 3.83524e-10) (2044, 1.01706e-08) (2047, -4.65328e-06) (2048, 4.57959e-09) (2050, 4.57959e-09) (2059, 5.239e-10)
row 2048: (2036, 3.83524e-10) (2045, 1.01706e-08) (2047, 4.57959e-09) (2048, -4.6552e-06) (2049, 1.01706e-08) (2051, 4.57959e-09) (2060, 5.239e-10)
row 2049: (2037, 3.83525e-10) (2046, 9.78572e-09) (2048, 1.60174e-08) (2049, -4.65968e-06) (2052, 8.17038e-09) (2061, 5.23901e-10)
row 2050: (1587, 8.24606e-09) (2038, 3.83524e-10) (2047, 4.57959e-09) (2050, -4.65328e-06) (2051, 4.57959e-09) (2053, 1.01706e-08) (2062, 5.239e-10)
row 2051: (2039, 3.83524e-10) (2048, 4.57959e-09) (2050, 4.57959e-09) (2051, -4.6552e-06) (2052, 1.01706e-08) (2054, 1.01706e-08) (2063, 5.239e-10)
row 2052: (2040, 3.83525e-10) (2049, 8.17038e-09) (2051, 1.60174e-08) (2052, -4.65968e-06) (2055, 9.78572e-09) (2064, 5.23901e-10)
row 2053: (1590, 7.44556e-09) (2041, 3.83525e-10) (2050, 1.60174e-08) (2053, -4.65734e-06) (2054, 8.17038e-09) (2065, 5.23901e-10)
row 2054: (2042, 3.83525e-10) (2051, 1.60174e-08) (2053, 8.17038e-09) (2054, -4.65968e-06) (2055, 9.78572e-09) (2066, 5.23901e-10)
row 2055: (2043, 3.83525e-10) (2052, 1.76409e-08) (2054, 1.76409e-08) (2055, -4.66098e-06) (2067, 5.23901e-10)
row 2056: (143, 7.4456e-09) (2044, 1.12907e-09) (2056, -4.65867e-06) (2057, 8.17042e-09) (2059, 1.60174e-08) (2068, 1.14303e-09)
row 2057: (2045, 1.12907e-09) (2056, 8.17042e-09) (2057, -4.66101e-06) (2058, 9.78578e-09) (2060, 1.60174e-08) (2069, 1.14303e-09)
row 2058: (2046, 1.12908e-09) (2057, 1.7641e-08) (2058, -4.66231e-06) (2061, 1.7641e-08) (2070, 1.14303e-09)
row 2059: (1593, 8.2461e-09) (2047, 1.12907e-09) (2056, 1.01707e-08) (2059, -4.65461e-06) (2060, 4.57962e-09) (2062, 4.57962e-09) (2071, 1.14303e-09)
row 2060: (2048, 1.12907e-09) (2057, 1.01707e-08) (2059, 4.57962e-09) (2060, -4.65653e-06) (2061, 1.01707e-08) (2063, 4.57962e-09) (2072, 1.14303e-09)
row 2061: (2049, 1.12907e-09) (2058, 9.78578e-09) (2060, 1.60174e-08) (2061, -4.66101e-06) (2064, 8.17042e-09) (2073, 1.14303e-09)
row 2062: (1596, 8.2461e-09) (2050, 1.12907e-09) (2059, 4.57962e-09) (2062, -4.65461e-06) (2063, 4.57962e-09) (2065, 1.01707e-08) (2074, 1.14303e-09)
row 2063: (2051, 1.12907e-09) (2060, 4.57962e-09) (2062, 4.57962e-09) (2063, -4.65653e-06) (2064, 1.01707e-08) (2066, 1.01707e-08) (2075, 1.14303e-09)
row 2064: (2052, 1.12907e-09) (2061, 8.17042e-09) (2063, 1.60174e-08) (2064, -4.66101e-06) (2067, 9.78578e-09) (2076, 1.14303e-09)
row 2065: (1599, 7.4456e-09) (2053, 1.12907e-09) (2062, 1.60174e-08) (2065, -4.65867e-06) (2066, 8.17042e-09) (2077, 1.14303e-09)
row 2066: (2054, 1.12907e-09) (2063, 1.60174e-08) (2065, 8.17042e-09) (2066, -4.66101e-06) (2067, 9.78578e-09) (2078, 1.14303e-09)
row 2067: (2055, 1.12908e-09) (2064, 1.7641e-08) (2066, 1.7641e-08) (2067, -4.66231e-06) (2079, 1.14303e-09)
row 2068: (159, 7.44564e-09) (2056, 5.39985e-10) (2068, -4.6573e-06) (2069, 8.17047e-09) (2071, 1.60175e-08) (2080, 3.9754e-10)
row 2069: (2057, 5.39985e-10) (2068, 8.17047e-09) (2069, -4.65964e-06) (2070, 9.78583e-09) (2072, 1.60175e-08) (2081, 3.9754e-10)
row 2070: (2058, 5.39986e-10) (2069, 1.76411e-08) (2070, -4.66094e-06) (2073, 1.76411e-08) (2082, 3.97541e-10)
row 2071: (1602, 8.24615e-09) (2059, 5.39984e-10) (2068, 1.01707e-08) (2071, -4.65324e-06) (2072, 4.57964e-09) (2074, 4.57964e-09) (2083, 3.9754e-10)
row 2072: (2060, 5.39984e-10) (2069, 1.01707e-08) (2071, 4.57964e-09) (2072, -4.65516e-06) (2073, 1.01707e-08) (2075, 4.57964e-09) (2084, 3.9754e-10)
row 2073: (2061, 5.39985e-10) (2070, 9.78583e-09) (2072, 1.60175e-08) (2073, -4.65964e-06) (2076, 8.17047e-09) (2085, 3.9754e-10)
row 2074: (1605, 8.24615e-09) (2062, 5.39984e-10) (2071, 4.57964e-09) (2074, -4.65324e-06) (2075, 4.57964e-09) (2077, 1.01707e-08) (2086, 3.9754e-10)
row 2075: (2063, 5.39984e-10) (2072, 4.57964e-09) (2074, 4.57964e-09) (2075, -4.65516e-06) (2076, 1.01707e-08) (2078, 1.01707e-08) (2087, 3.9754e-10)
row 2076: (2064, 5.39985e-10) (2073, 8.17047e-09) (2075, 1.60175e-08) (2076, -4.65964e-06) (2079, 9.78583e-09) (2088, 3.9754e-10)
row 2077: (1608, 7.44564e-09) (2065, 5.39985e-10) (2074, 1.60175e-08) (2077, -4.6573e-06) (2078, 8.17047e-09) (2089, 3.9754e-10)
row 2078: (2066, 5.39985e-10) (2075, 1.60175e-08) (2077, 8.17047e-09) (2078, -4.65964e-06) (2079, 9.78583e-09) (2090, 3.9754e-10)
row 2079: (2067, 5.39986e-10) (2076, 1.76411e-08) (2078, 1.76411e-08) (2079, -4.66094e-06) (2091, 3.97541e-10)
row 2080: (175, 7.44569e-09) (2068, 3.97543e-10) (2080, -4.65711e-06) (2081, 8.17053e-09) (2083, 1.60177e-08) (2092, 3.97543e-10)
row 2081: (2069, 3.97543e-10) (2080, 8.17053e-09) (2081, -4.65945e-06) (2082, 9.7859e-09) (2084, 1.60177e-08) (2093, 3.97543e-10)
row 2082: (2070, 3.97544e-10) (2081, 1.76412e-08) (2082, -4.66075e-06) (2085, 1.76412e-08) (2094, 3.97544e-10)
row 2083: (1611, 8.24621e-09) (2071, 3.97542e-10) (2080, 1.01708e-08) (2083, -4.65305e-06) (2084, 4.57967e-09) (2086, 4.57967e-09) (2095, 3.97542e-10)
row 2084: (2072, 3.97542e-10) (2081, 1.01708e-08) (2083, 4.57967e-09) (2084, -4.65497e-06) (2085, 1.01708e-08) (2087, 4.57967e-09) (2096, 3.97542e-10)
row 2085: (2073, 3.97543e-10) (2082, 9.7859e-09) (2084, 1.60177e-08) (2085, -4.65945e-06) (2088, 8.17053e-09) (2097, 3.97543e-10)
row 2086: (1614, 8.24621e-09) (2074, 3.97542e-10) (2083, 4.57967e-09) (2086, -4.65305e-06) (2087, 4.57967e-09) (2089, 1.01708e-08) (2098, 3.97542e-10)
row 2087: (2075, 3.97542e-10) (2084, 4.57967e-09) (2086, 4.57967e-09) (2087, -4.65497e-06) (2088, 1.01708e-08) (2090, 1.01708e-08) (2099, 3.97542e-10)
row 2088: (2076, 3.97543e-10) (2085, 8.17053e-09) (2087, 1.60177e-08) (2088, -4.65945e-06) (2091, 9.7859e-09) (2100, 3.97543e-10)
row 2089: (1617, 7.44569e-09) (2077, 3.97543e-10) (2086, 1.60177e-08) (2089, -4.65711e-06) (2090, 8.17053e-09) (2101, 3.97543e-10)
row 2090: (2078, 3.97543e-10) (2087, 1.60177e-08) (2089, 8.17053e-09) (2090, -4.65945e-06) (2091, 9.7859e-09) (2102, 3.97543e-10)
row 2091: (2079, 3.97544e-10) (2088, 1.76412e-08) (2090, 1.76412e-08) (2091, -4.66075e-06) (2103, 3.97544e-10)
row 2092: (191, 7.44575e-09) (2080, 3.97546e-10) (2092, -4.65706e-06) (2093, 8.17059e-09) (2095, 1.60178e-08) (2104, 3.97546e-10)
row 2093: (2081, 3.97546e-10) (2092, 8.17059e-09) (2093, -4.6594e-06) (2094, 9.78597e-09) (2096, 1.60178e-08) (2105, 3.97546e-10)
row 2094: (2082, 3.97546e-10) (2093, 1.76413e-08) (2094, -4.66071e-06) (2097, 1.76413e-08) (2106, 3.97546e-10)
row 2095: (1620, 8.24627e-09) (2083, 3.97545e-10) (2092, 1.01709e-08) (2095, -4.653e-06) (2096, 4.57971e-09) (2098, 4.57971e-09) (2107, 3.97545e-10)
row 2096: (2084, 3.97545e-10) (2093, 1.01709e-08) (2095, 4.57971e-09) (2096, -4.65492e-06) (2097, 1.01709e-08) (2099, 4.57971e-09) (2108, 3.97545e-10)
row 2097: (2085, 3.97546e-10) (2094, 9.78597e-09) (2096, 1.60178e-08) (2097, -4.6594e-06) (2100, 8.17059e-09) (2109, 3.97546e-10)
row 2098: (1623, 8.24627e-09) (2086, 3.97545e-10) (2095, 4.57971e-09) (2098, -4.653e-06) (2099, 4.57971e-09) (2101, 1.01709e-08) (2110, 3.97545e-10)
row 2099: (2087, 3.97545e-10) (2096, 4.57971e-09) (2098, 4.57971e-09) (2099, -4.65492e-06) (2100, 1.01709e-08) (2102, 1.01709e-08) (2111, 3.97545e-10)
row 2100: (2088, 3.97546e-10) (2097, 8.17059e-09) (2099, 1.60178e-08) (2100, -4.6594e-06) (2103, 9.78597e-09) (2112, 3.97546e-10)
row 2101: (1626, 7.44575e-09) (2089, 3.97546e-10) (2098, 1.60178e-08) (2101, -4.65706e-06) (2102, 8.17059e-09) (2113, 3.97546e-10)
row 2102: (2090, 3.97546e-10) (2099, 1.60178e-08) (2101, 8.17059e-09) (2102, -4.6594e-06) (2103, 9.78597e-09) (2114, 3.97546e-10)
row 2103: (2091, 3.97546e-10) (2100, 1.76413e-08) (2102, 1.76413e-08) (2103, -4.66071e-06) (2115, 3.97546e-10)
row 2104: (207, 7.4458e-09) (2092, 3.97549e-10) (2104, -4.65701e-06) (2105, 8.17065e-09) (2107, 1.60179e-08) (2116, 3.97549e-10)
row 2105: (2093, 3.97549e-10) (2104, 8.17065e-09) (2105, -4.65935e-06) (2106, 9.78604e-09) (2108, 1.60179e-08) (2117, 3.97549e-10)
row 2106: (2094, 3.97549e-10) (2105, 1.76415e-08) (2106, -4.66066e-06) (2109, 1.76415e-08) (2118, 3.97549e-10)
row 2107: (1629, 8.24633e-09) (2095, 3.97548e-10) (2104, 1.0171e-08) (2107, -4.65295e-06) (2108, 4.57974e-09) (2110, 4.57974e-09) (2119, 3.97548e-10)
row 2108: (2096, 3.97548e-10) (2105, 1.0171e-08) (2107, 4.57974e-09) (2108, -4.65488e-06) (2109, 1.0171e-08) (2111, 4.57974e-09) (2120, 3.97548e-10)
row 2109: (2097, 3.97549e-10) (2106, 9.78604e-09) (2108, 1.60179e-08) (2109, -4.65935e-06) (2112, 8.17065e-09) (2121, 3.97549e-10)
row 2110: (1632, 8.24633e-09) (2098, 3.97548e-10) (2107, 4.57974e-09) (2110, -4.65295e-06) (2111, 4.57974e-09) (2113, 1.0171e-08) (2122, 3.97548e-10)
row 2111: (2099, 3.97548e-10) (2108, 4.57974e-09) (2110, 4.57974e-09) (2111, -4.65488e-06) (2112, 1.0171e-08) (2114, 1.0171e-08) (2123, 3.97548e-10)
row 2112: (2100, 3.97549e-10) (2109, 8.17065e-09) (2111, 1.60179e-08) (2112, -4.65935e-06) (2115, 9.78604e-09) (2124, 3.97549e-10)
row 2113: (1635, 7.4458e-09) (2101, 3.97549e-10) (2110, 1.60179e-08) (2113, -4.65701e-06) (2114, 8.17065e-09) (2125, 3.97549e-10)
row 2114: (2102, 3.97549e-10) (2111, 1.60179e-08) (2113, 8.17065e-09) (2114, -4.65935e-06) (2115, 9.78604e-09) (2126, 3.97549e-10)
row 2115: (2103, 3.97549e-10) (2112, 1.76415e-08) (2114, 1.76415e-08) (2115, -4.66066e-06) (2127, 3.97549e-10)
row 2116: (223, 7.44586e-09) (2104, 3.97552e-10) (2116, -4.65696e-06) (2117, 8.17071e-09) (2119, 1.6018e-08) (2128, 3.97552e-10)
row 2117: (2105, 3.97552e-10) (2116, 8.17071e-09) (2117, -4.6593e-06) (2118, 9.78611e-09) (2120, 1.6018e-08) (2129, 3.97552e-10)
row 2118: (2106, 3.97552e-10) (2117, 1.76416e-08) (2118, -4.66061e-06) (2121, 1.76416e-08) (2130, 3.97552e-10)
row 2119: (1638, 8.24639e-09) (2107, 3.97551e-10) (2116, 1.0171e-08) (2119, -4.6529e-06) (2120, 4.57977e-09) (2122, 4.57977e-09) (2131, 3.97551e-10)
row 2120: (2108, 3.97551e-10) (2117, 1.0171e-08) (2119, 4.57977e-09) (2120, -4.65483e-06) (2121, 1.0171e-08) (2123, 4.57977e-09) (2132, 3.97551e-10)
row 2121: (2109, 3.97552e-10) (2118, 9.78611e-09) (2120, 1.6018e-08) (2121, -4.6593e-06) (2124, 8.17071e-09) (2133, 3.97552e-10)
row 2122: (1641, 8.24639e-09) (2110, 3.97551e-10) (2119, 4.57977e-09) (2122, -4.6529e-06) (2123, 4.57977e-09) (2125, 1.0171e-08) (2134, 3.97551e-10)
row 2123: (2111, 3.97551e-10) (2120, 4.57977e-09) (2122, 4.57977e-09) (2123, -4.65483e-06) (2124, 1.0171e-08) (2126, 1.0171e-08) (2135, 3.97551e-10)
row 2124: (2112, 3.97552e-10) (2121, 8.17071e-09) (2123, 1.6018e-08) (2124, -4.6593e-06) (2127, 9.78611e-09) (2136, 3.97552e-10)
row 2125: (1644, 7.44586e-09) (2113, 3.97552e-10) (2122, 1.6018e-08) (2125, -4.65696e-06) (2126, 8.17071e-09) (2137, 3.97552e-10)
row 2126: (2114, 3.97552e-10) (2123, 1.6018e-08) (2125, 8.17071e-09) (2126, -4.6593e-06) (2127, 9.78611e-09) (2138, 3.97552e-10)
row 2127: (2115, 3.97552e-10) (2124, 1.76416e-08) (2126, 1.76416e-08) (2127, -4.66061e-06) (2139, 3.97552e-10)
row 2128: (239, 7.44591e-09) (2116, 3.97555e-10) (2128, -4.65706e-06) (2129, 8.17076e-09) (2131, 1.60181e-08) (2140, 5.39968e-10)
row 2129: (2117, 3.97555e-10) (2128, 8.17076e-09) (2129, -4.6594e-06) (2130, 9.78618e-09) (2132, 1.60181e-08) (2141, 5.39968e-10)
row 2130: (2118, 3.97555e-10) (2129, 1.76417e-08) (2130, -4.66071e-06) (2133, 1.76417e-08) (2142, 5.39968e-10)
row 2131: (1647, 8.24645e-09) (2119, 3.97554e-10) (2128, 1.01711e-08) (2131, -4.653e-06) (2132, 4.57981e-09) (2134, 4.57981e-09) (2143, 5.39967e-10)
row 2132: (2120, 3.97554e-10) (2129, 1.01711e-08) (2131, 4.57981e-09) (2132, -4.65492e-06) (2133, 1.01711e-08) (2135, 4.57981e-09) (2144, 5.39967e-10)
row 2133: (2121, 3.97555e-10) (2130, 9.78618e-09) (2132, 1.60181e-08) (2133, -4.6594e-06) (2136, 8.17076e-09) (2145, 5.39968e-10)
row 2134: (1650, 8.24645e-09) (2122, 3.97554e-10) (2131, 4.57981e-09) (2134, -4.653e-06) (2135, 4.57981e-09) (2137, 1.01711e-08) (2146, 5.39967e-10)
row 2135: (2123, 3.97554e-10) (2132, 4.57981e-09) (2134, 4.57981e-09) (2135, -4.65492e-06) (2136, 1.01711e-08) (2138, 1.01711e-08) (2147, 5.39967e-10)
row 2136: (2124, 3.97555e-10) (2133, 8.17076e-09) (2135, 1.60181e-08) (2136, -4.6594e-06) (2139, 9.78618e-09) (2148, 5.39968e-10)
row 2137: (1653, 7.44591e-09) (2125, 3.97555e-10) (2134, 1.60181e-08) (2137, -4.65706e-06) (2138, 8.17076e-09) (2149, 5.39968e-10)
row 2138: (2126, 3.97555e-10) (2135, 1.60181e-08) (2137, 8.17076e-09) (2138, -4.6594e-06) (2139, 9.78618e-09) (2150, 5.39968e-10)
row 2139: (2127, 3.97555e-10) (2136, 1.76417e-08) (2138, 1.76417e-08) (2139, -4.66071e-06) (2151, 5.39968e-10)
row 2140: (255, 7.44595e-09) (2128, 1.14301e-09) (2140, -4.65837e-06) (2141, 8.17081e-09) (2143, 1.60182e-08) (2152, 1.14309e-09)
row 2141: (2129, 1.14301e-09) (2140, 8.17081e-09) (2141, -4.66071e-06) (2142, 9.78624e-09) (2144, 1.60182e-08) (2153, 1.14309e-09)
row 2142: (2130, 1.14301e-09) (2141, 1.76418e-08) (2142, -4.66202e-06) (2145, 1.76418e-08) (2154, 1.14309e-09)
row 2143: (1656, 8.24649e-09) (2131, 1.14301e-09) (2140, 1.01712e-08) (2143, -4.65431e-06) (2144, 4.57983e-09) (2146, 4.57983e-09) (2155, 1.14308e-09)
row 2144: (2132, 1.14301e-09) (2141, 1.01712e-08) (2143, 4.57983e-09) (2144, -4.65624e-06) (2145, 1.01712e-08) (2147, 4.57983e-09) (2156, 1.14308e-09)
row 2145: (2133, 1.14301e-09) (2142, 9.78624e-09) (2144, 1.60182e-08) (2145, -4.66071e-06) (2148, 8.17081e-09) (2157, 1.14309e-09)
row 2146: (1659, 8.24649e-09) (2134, 1.14301e-09) (2143, 4.57983e-09) (2146, -4.65431e-06) (2147, 4.57983e-09) (2149, 1.01712e-08) (2158, 1.14308e-09)
row 2147: (2135, 1.14301e-09) (2144, 4.57983e-09) (2146, 4.57983e-09) (2147, -4.65624e-06) (2148, 1.01712e-08) (2150, 1.01712e-08) (2159, 1.14308e-09)
row 2148: (2136, 1.14301e-09) (2145, 8.17081e-09) (2147, 1.60182e-08) (2148, -4.66071e-06) (2151, 9.78624e-09) (2160, 1.14309e-09)
row 2149: (1662, 7.44595e-09) (2137, 1.14301e-09) (2146, 1.60182e-08) (2149, -4.65837e-06) (2150, 8.17081e-09) (2161, 1.14309e-09)
row 2150: (2138, 1.14301e-09) (2147, 1.60182e-08) (2149, 8.17081e-09) (2150, -4.66071e-06) (2151, 9.78624e-09) (2162, 1.14309e-09)
row 2151: (2139, 1.14301e-09) (2148, 1.76418e-08) (2150, 1.76418e-08) (2151, -4.66202e-06) (2163, 1.14309e-09)
row 2152: (271, 7.44599e-09) (2140, 5.40011e-10) (2152, -4.65699e-06) (2153, 8.17085e-09) (2155, 1.60183e-08) (2164, 3.97559e-10)
row 2153: (2141, 5.40011e-10) (2152, 8.17085e-09) (2153, -4.65933e-06) (2154, 9.78629e-09) (2156, 1.60183e-08) (2165, 3.97559e-10)
row 2154: (2142, 5.40011e-10) (2153, 1.76419e-08) (2154, -4.66064e-06) (2157, 1.76419e-08) (2166, 3.97559e-10)
row 2155: (1665, 8.24654e-09) (2143, 5.40009e-10) (2152, 1.01712e-08) (2155, -4.65293e-06) (2156, 4.57986e-09) (2158, 4.57986e-09) (2167, 3.97558e-10)
row 2156: (2144, 5.40009e-10) (2153, 1.01712e-08) (2155, 4.57986e-09) (2156, -4.65485e-06) (2157, 1.01712e-08) (2159, 4.57986e-09) (2168, 3.97558e-10)
row 2157: (2145, 5.40011e-10) (2154, 9.78629e-09) (2156, 1.60183e-08) (2157, -4.65933e-06) (2160, 8.17085e-09) (2169, 3.97559e-10)
row 2158: (1668, 8.24654e-09) (2146, 5.40009e-10) (2155, 4.57986e-09) (2158, -4.65293e-06) (2159, 4.57986e-09) (2161, 1.01712e-08) (2170, 3.97558e-10)
row 2159: (2147, 5.40009e-10) (2156, 4.57986e-09) (2158, 4.57986e-09) (2159, -4.65485e-06) (2160, 1.01712e-08) (2162, 1.01712e-08) (2171, 3.97558e-10)
row 2160: (2148, 5.40011e-10) (2157, 8.17085e-09) (2159, 1.60183e-08) (2160, -4.65933e-06) (2163, 9.78629e-09) (2172, 3.97559e-10)
row 2161: (1671, 7.44599e-09) (2149, 5.40011e-10) (2158, 1.60183e-08) (2161, -4.65699e-06) (2162, 8.17085e-09) (2173, 3.97559e-10)
row 2162: (2150, 5.40011e-10) (2159, 1.60183e-08) (2161, 8.17085e-09) (2162, -4.65933e-06) (2163, 9.78629e-09) (2174, 3.97559e-10)
row 2163: (2151, 5.40011e-10) (2160, 1.76419e-08) (2162, 1.76419e-08) (2163, -4.66064e-06) (2175, 3.97559e-10)
row 2164: (287, 7.44604e-09) (2152, 3.97562e-10) (2164, -4.6568e-06) (2165, 8.17091e-09) (2167, 1.60184e-08) (2176, 3.97562e-10)
row 2165: (2153, 3.97562e-10) (2164, 8.17091e-09) (2165, -4.65914e-06) (2166, 9.78636e-09) (2168, 1.60184e-08) (2177, 3.97562e-10)
row 2166: (2154, 3.97562e-10) (2165, 1.7642e-08) (2166, -4.66044e-06) (2169, 1.7642e-08) (2178, 3.97562e-10)
row 2167: (1674, 8.2466e-09) (2155, 3.97561e-10) (2164, 1.01713e-08) (2167, -4.65274e-06) (2168, 4.57989e-09) (2170, 4.57989e-09) (2179, 3.97561e-10)
row 2168: (2156, 3.97561e-10) (2165, 1.01713e-08) (2167, 4.57989e-09) (2168, -4.65466e-06) (2169, 1.01713e-08) (2171, 4.57989e-09) (2180, 3.97561e-10)
row 2169: (2157, 3.97562e-10) (2166, 9.78636e-09) (2168, 1.60184e-08) (2169, -4.65914e-06) (2172, 8.17091e-09) (2181, 3.97562e-10)
row 2170: (1677, 8.2466e-09) (2158, 3.97561e-10) (2167, 4.57989e-09) (2170, -4.65274e-06) (2171, 4.57989e-09) (2173, 1.01713e-08) (2182, 3.97561e-10)
row 2171: (2159, 3.97561e-10) (2168, 4.57989e-09) (2170, 4.57989e-09) (2171, -4.65466e-06) (2172, 1.01713e-08) (2174, 1.01713e-08) (2183, 3.97561e-10)
row 2172: (2160, 3.97562e-10) (2169, 8.17091e-09) (2171, 1.60184e-08) (2172, -4.65914e-06) (2175, 9.78636e-09) (2184, 3.97562e-10)
row 2173: (1680, 7.44604e-09) (2161, 3.97562e-10) (2170, 1.60184e-08) (2173, -4.6568e-06) (2174, 8.17091e-09) (2185, 3.97562e-10)
row 2174: (2162, 3.97562e-10) (2171, 1.60184e-08) (2173, 8.17091e-09) (2174, -4.65914e-06) (2175, 9.78636e-09) (2186, 3.97562e-10)
row 2175: (2163, 3.97562e-10) (2172, 1.7642e-08) (2174, 1.7642e-08) (2175, -4.66044e-06) (2187, 3.97562e-10)
row 2176: (303, 7.4461e-09) (2164, 3.97565e-10) (2176, -4.65675e-06) (2177, 8.17097e-09) (2179, 1.60185e-08) (2188, 3.97565e-10)
row 2177: (2165, 3.97565e-10) (2176, 8.17097e-09) (2177, -4.65909e-06) (2178, 9.78643e-09) (2180, 1.60185e-08) (2189, 3.97565e-10)
row 2178: (2166, 3.97565e-10) (2177, 1.76422e-08) (2178, -4.6604e-06) (2181, 1.76422e-08) (2190, 3.97565e-10)
row 2179: (1683, 8.24666e-09) (2167, 3.97564e-10) (2176, 1.01714e-08) (2179, -4.65269e-06) (2180, 4.57992e-09) (2182, 4.57992e-09) (2191, 3.97564e-10)
row 2180: (2168, 3.97564e-10) (2177, 1.01714e-08) (2179, 4.57992e-09) (2180, -4.65462e-06) (2181, 1.01714e-08) (2183, 4.57992e-09) (2192, 3.97564e-10)
row 2181: (2169, 3.97565e-10) (2178, 9.78643e-09) (2180, 1.60185e-08) (2181, -4.65909e-06) (2184, 8.17097e-09) (2193, 3.97565e-10)
row 2182: (1686, 8.24666e-09) (2170, 3.97564e-10) (2179, 4.57992e-09) (2182, -4.65269e-06) (2183, 4.57992e-09) (2185, 1.01714e-08) (2194, 3.97564e-10)
row 2183: (2171, 3.97564e-10) (2180, 4.57992e-09) (2182, 4.57992e-09) (2183, -4.65462e-06) (2184, 1.01714e-08) (2186, 1.01714e-08) (2195, 3.97564e-10)
row 2184: (2172, 3.97565e-10) (2181, 8.17097e-09) (2183, 1.60185e-08) (2184, -4.65909e-06) (2187, 9.78643e-09) (2196, 3.97565e-10)
row 2185: (1689, 7.4461e-09) (2173, 3.97565e-10) (2182, 1.60185e-08) (2185, -4.65675e-06) (2186, 8.17097e-09) (2197, 3.97565e-10)
row 2186: (2174, 3.97565e-10) (2183, 1.60185e-08) (2185, 8.17097e-09) (2186, -4.65909e-06) (2187, 9.78643e-09) (2198, 3.97565e-10)
row 2187: (2175, 3.97565e-10) (2184, 1.76422e-08) (2186, 1.76422e-08) (2187, -4.6604e-06) (2199, 3.97565e-10)
row 2188: (319, 7.44615e-09) (2176, 3.97568e-10) (2188, -4.6567e-06) (2189, 8.17103e-09) (2191, 1.60186e-08) (2200, 3.97568e-10)
row 2189: (2177, 3.97568e-10) (2188, 8.17103e-09) (2189, -4.65904e-06) (2190, 9.7865e-09) (2192, 1.60186e-08) (2201, 3.97568e-10)
row 2190: (2178, 3.97568e-10) (2189, 1.76423e-08) (2190, -4.66035e-06) (2193, 1.76423e-08) (2202, 3.97568e-10)
row 2191: (1692, 8.24672e-09) (2179, 3.97567e-10) (2188, 1.01714e-08) (2191, -4.65264e-06) (2192, 4.57996e-09) (2194, 4.57996e-09) (2203, 3.97567e-10)
row 2192: (2180, 3.97567e-10) (2189, 1.01714e-08) (2191, 4.57996e-09) (2192, -4.65457e-06) (2193, 1.01714e-08) (2195, 4.57996e-09) (2204, 3.97567e-10)
row 2193: (2181, 3.97568e-10) (2190, 9.7865e-09) (2192, 1.60186e-08) (2193, -4.65904e-06) (2196, 8.17103e-09) (2205, 3.97568e-10)
row 2194: (1695, 8.24672e-09) (2182, 3.97567e-10) (2191, 4.57996e-09) (2194, -4.65264e-06) (2195, 4.57996e-09) (2197, 1.01714e-08) (2206, 3.97567e-10)
row 2195: (2183, 3.97567e-10) (2192, 4.57996e-09) (2194, 4.57996e-09) (2195, -4.65457e-06) (2196, 1.01714e-08) (2198, 1.01714e-08) (2207, 3.97567e-10)
row 2196: (2184, 3.97568e-10) (2193, 8.17103e-09) (2195, 1.60186e-08) (2196, -4.65904e-06) (2199, 9.7865e-09) (2208, 3.97568e-10)
row 2197: (1698, 7.44615e-09) (2185, 3.97568e-10) (2194, 1.60186e-08) (2197, -4.6567e-06) (2198, 8.17103e-09) (2209, 3.97568e-10)
row 2198: (2186, 3.97568e-10) (2195, 1.60186e-08) (2197, 8.17103e-09) (2198, -4.65904e-06) (2199, 9.7865e-09) (2210, 3.97568e-10)
row 2199: (2187, 3.97568e-10) (2196, 1.76423e-08) (2198, 1.76423e-08) (2199, -4.66035e-06) (2211, 3.97568e-10)
row 2200: (335, 7.44621e-09) (2188, 3.97571e-10) (2200, -4.65665e-06) (2201, 8.17109e-09) (2203, 1.60188e-08) (2212, 3.97571e-10)
row 2201: (2189, 3.97571e-10) (2200, 8.17109e-09) (2201, -4.65899e-06) (2202, 9.78657e-09) (2204, 1.60188e-08) (2213, 3.97571e-10)
row 2202: (2190, 3.97571e-10) (2201, 1.76424e-08) (2202, -4.6603e-06) (2205, 1.76424e-08) (2214, 3.97571e-10)
row 2203: (1701, 8.24678e-09) (2191, 3.9757e-10) (2200, 1.01715e-08) (2203, -4.6526e-06) (2204, 4.57999e-09) (2206, 4.57999e-09) (2215, 3.9757e-10)
row 2204: (2192, 3.9757e-10) (2201, 1.01715e-08) (2203, 4.57999e-09) (2204, -4.65452e-06) (2205, 1.01715e-08) (2207, 4.57999e-09) (2216, 3.9757e-10)
row 2205: (2193, 3.97571e-10) (2202, 9.78657e-09) (2204, 1.60188e-08) (2205, -4.65899e-06) (2208, 8.17109e-09) (2217, 3.97571e-10)
row 2206: (1704, 8.24678e-09) (2194, 3.9757e-10) (2203, 4.57999e-09) (2206, -4.6526e-06) (2207, 4.57999e-09) (2209, 1.01715e-08) (2218, 3.9757e-10)
row 2207: (2195, 3.9757e-10) (2204, 4.57999e-09) (2206, 4.57999e-09) (2207, -4.65452e-06) (2208, 1.01715e-08) (2210, 1.01715e-08) (2219, 3.9757e-10)
row 2208: (2196, 3.97571e-10) (2205, 8.17109e-09) (2207, 1.60188e-08) (2208, -4.65899e-06) (2211, 9.78657e-09) (2220, 3.97571e-10)
row 2209: (1707, 7.44621e-09) (2197, 3.97571e-10) (2206, 1.60188e-08) (2209, -4.65665e-06) (2210, 8.17109e-09) (2221, 3.97571e-10)
row 2210: (2198, 3.97571e-10) (2207, 1.60188e-08) (2209, 8.17109e-09) (2210, -4.65899e-06) (2211, 9.78657e-09) (2222, 3.97571e-10)
row 2211: (2199, 3.97571e-10) (2208, 1.76424e-08) (2210, 1.76424e-08) (2211, -4.6603e-06) (2223, 3.97571e-10)
row 2212: (351, 7.44626e-09) (2200, 3.97574e-10) (2212, -4.65675e-06) (2213, 8.17115e-09) (2215, 1.60189e-08) (2224, 5.39993e-10)
row 2213: (2201, 3.97574e-10) (2212, 8.17115e-09) (2213, -4.65909e-06) (2214, 9.78664e-09) (2216, 1.60189e-08) (2225, 5.39993e-10)
row 2214: (2202, 3.97574e-10) (2213, 1.76425e-08) (2214, -4.6604e-06) (2217, 1.76425e-08) (2226, 5.39994e-10)
row 2215: (1710, 8.24684e-09) (2203, 3.97573e-10) (2212, 1.01716e-08) (2215, -4.65269e-06) (2216, 4.58002e-09) (2218, 4.58002e-09) (2227, 5.39992e-10)
row 2216: (2204, 3.97573e-10) (2213, 1.01716e-08) (2215, 4.58002e-09) (2216, -4.65461e-06) (2217, 1.01716e-08) (2219, 4.58002e-09) (2228, 5.39992e-10)
row 2217: (2205, 3.97574e-10) (2214, 9.78664e-09) (2216, 1.60189e-08) (2217, -4.65909e-06) (2220, 8.17115e-09) (2229, 5.39993e-10)
row 2218: (1713, 8.24684e-09) (2206, 3.97573e-10) (2215, 4.58002e-09) (2218, -4.65269e-06) (2219, 4.58002e-09) (2221, 1.01716e-08) (2230, 5.39992e-10)
row 2219: (2207, 3.97573e-10) (2216, 4.58002e-09) (2218, 4.58002e-09) (2219, -4.65461e-06) (2220, 1.01716e-08) (2222, 1.01716e-08) (2231, 5.39992e-10)
row 2220: (2208, 3.97574e-10) (2217, 8.17115e-09) (2219, 1.60189e-08) (2220, -4.65909e-06) (2223, 9.78664e-09) (2232, 5.39993e-10)
row 2221: (1716, 7.44626e-09) (2209, 3.97574e-10) (2218, 1.60189e-08) (2221, -4.65675e-06) (2222, 8.17115e-09) (2233, 5.39993e-10)
row 2222: (2210, 3.97574e-10) (2219, 1.60189e-08) (2221, 8.17115e-09) (2222, -4.65909e-06) (2223, 9.78664e-09) (2234, 5.39993e-10)
row 2223: (2211, 3.97574e-10) (2220, 1.76425e-08) (2222, 1.76425e-08) (2223, -4.6604e-06) (2235, 5.39994e-10)
row 2224: (367, 7.4463e-09) (2212, 1.14306e-09) (2224, -4.65806e-06) (2225, 8.17119e-09) (2227, 1.6019e-08) (2236, 1.14314e-09)
row 2225: (2213, 1.14306e-09) (2224, 8.17119e-09) (2225, -4.6604e-06) (2226, 9.7867e-09) (2228, 1.6019e-08) (2237, 1.14314e-09)
row 2226: (2214, 1.14306e-09) (2225, 1.76426e-08) (2226, -4.66171e-06) (2229, 1.76426e-08) (2238, 1.14314e-09)
row 2227: (1719, 8.24688e-09) (2215, 1.14306e-09) (2224, 1.01716e-08) (2227, -4.654e-06) (2228, 4.58005e-09) (2230, 4.58005e-09) (2239, 1.14314e-09)
row 2228: (2216, 1.14306e-09) (2225, 1.01716e-08) (2227, 4.58005e-09) (2228, -4.65593e-06) (2229, 1.01716e-08) (2231, 4.58005e-09) (2240, 1.14314e-09)
row 2229: (2217, 1.14306e-09) (2226, 9.7867e-09) (2228, 1.6019e-08) (2229, -4.6604e-06) (2232, 8.17119e-09) (2241, 1.14314e-09)
row 2230: (1722, 8.24688e-09) (2218, 1.14306e-09) (2227, 4.58005e-09) (2230, -4.654e-06) (2231, 4.58005e-09) (2233, 1.01716e-08) (2242, 1.14314e-09)
row 2231: (2219, 1.14306e-09) (2228, 4.58005e-09) (2230, 4.58005e-09) (2231, -4.65593e-06) (2232, 1.01716e-08) (2234, 1.01716e-08) (2243, 1.14314e-09)
row 2232: (2220, 1.14306e-09) (2229, 8.17119e-09) (2231, 1.6019e-08) (2232, -4.6604e-06) (2235, 9.7867e-09) (2244, 1.14314e-09)
row 2233: (1725, 7.4463e-09) (2221, 1.14306e-09) (2230, 1.6019e-08) (2233, -4.65806e-06) (2234, 8.17119e-09) (2245, 1.14314e-09)
row 2234: (2222, 1.14306e-09) (2231, 1.6019e-08) (2233, 8.17119e-09) (2234, -4.6604e-06) (2235, 9.7867e-09) (2246, 1.14314e-09)
row 2235: (2223, 1.14306e-09) (2232, 1.76426e-08) (2234, 1.76426e-08) (2235, -4.66171e-06) (2247, 1.14314e-09)
row 2236: (383, 7.44634e-09) (2224, 5.40036e-10) (2236, -4.65668e-06) (2237, 8.17124e-09) (2239, 1.6019e-08) (2248, 3.97578e-10)
row 2237: (2225, 5.40036e-10) (2236, 8.17124e-09) (2237, -4.65902e-06) (2238, 9.78675e-09) (2240, 1.6019e-08) (2249, 3.97578e-10)
row 2238: (2226, 5.40036e-10) (2237, 1.76427e-08) (2238, -4.66033e-06) (2241, 1.76427e-08) (2250, 3.97578e-10)
row 2239: (1728, 8.24692e-09) (2227, 5.40035e-10) (2236, 1.01717e-08) (2239, -4.65262e-06) (2240, 4.58007e-09) (2242, 4.58007e-09) (2251, 3.97577e-10)
row 2240: (2228, 5.40035e-10) (2237, 1.01717e-08) (2239, 4.58007e-09) (2240, -4.65454e-06) (2241, 1.01717e-08) (2243, 4.58007e-09) (2252, 3.97577e-10)
row 2241: (2229, 5.40036e-10) (2238, 9.78675e-09) (2240, 1.6019e-08) (2241, -4.65902e-06) (2244, 8.17124e-09) (2253, 3.97578e-10)
row 2242: (1731, 8.24692e-09) (2230, 5.40035e-10) (2239, 4.58007e-09) (2242, -4.65262e-06) (2243, 4.58007e-09) (2245, 1.01717e-08) (2254, 3.97577e-10)
row 2243: (2231, 5.40035e-10) (2240, 4.58007e-09) (2242, 4.58007e-09) (2243, -4.65454e-06) (2244, 1.01717e-08) (2246, 1.01717e-08) (2255, 3.97577e-10)
row 2244: (2232, 5.40036e-10) (2241, 8.17124e-09) (2243, 1.6019e-08) (2244, -4.65902e-06) (2247, 9.78675e-09) (2256, 3.97578e-10)
row 2245: (1734, 7.44634e-09) (2233, 5.40036e-10) (2242, 1.6019e-08) (2245, -4.65668e-06) (2246, 8.17124e-09) (2257, 3.97578e-10)
row 2246: (2234, 5.40036e-10) (2243, 1.6019e-08) (2245, 8.17124e-09) (2246, -4.65902e-06) (2247, 9.78675e-09) (2258, 3.97578e-10)
row 2247: (2235, 5.40036e-10) (2244, 1.76427e-08) (2246, 1.76427e-08) (2247, -4.66033e-06) (2259, 3.97578e-10)
row 2248: (399, 7.44639e-09) (2236, 3.97581e-10) (2248, -4.65649e-06) (2249, 8.1713e-09) (2251, 1.60192e-08) (2260, 3.97581e-10)
row 2249: (2237, 3.97581e-10) (2248, 8.1713e-09) (2249, -4.65883e-06) (2250, 9.78682e-09) (2252, 1.60192e-08) (2261, 3.97581e-10)
row 2250: (2238, 3.97581e-10) (2249, 1.76429e-08) (2250, -4.66014e-06) (2253, 1.76429e-08) (2262, 3.97581e-10)
row 2251: (1737, 8.24698e-09) (2239, 3.9758e-10) (2248, 1.01718e-08) (2251, -4.65243e-06) (2252, 4.5801e-09) (2254, 4.5801e-09) (2263, 3.9758e-10)
row 2252: (2240, 3.9758e-10) (2249, 1.01718e-08) (2251, 4.5801e-09) (2252, -4.65435e-06) (2253, 1.01718e-08) (2255, 4.5801e-09) (2264, 3.9758e-10)
row 2253: (2241, 3.97581e-10) (2250, 9.78682e-09) (2252, 1.60192e-08) (2253, -4.65883e-06) (2256, 8.1713e-09) (2265, 3.97581e-10)
row 2254: (1740, 8.24698e-09) (2242, 3.9758e-10) (2251, 4.5801e-09) (2254, -4.65243e-06) (2255, 4.5801e-09) (2257, 1.01718e-08) (2266, 3.9758e-10)
row 2255: (2243, 3.9758e-10) (2252, 4.5801e-09) (2254, 4.5801e-09) (2255, -4.65435e-06) (2256, 1.01718e-08) (2258, 1.01718e-08) (2267, 3.9758e-10)
row 2256: (2244, 3.97581e-10) (2253, 8.1713e-09) (2255, 1.60192e-08) (2256, -4.65883e-06) (2259, 9.78682e-09) (2268, 3.97581e-10)
row 2257: (1743, 7.44639e-09) (2245, 3.97581e-10) (2254, 1.60192e-08) (2257, -4.65649e-06) (2258, 8.1713e-09) (2269, 3.97581e-10)
row 2258: (2246, 3.97581e-10) (2255, 1.60192e-08) (2257, 8.1713e-09) (2258, -4.65883e-06) (2259, 9.78682e-09) (2270, 3.97581e-10)
row 2259: (2247, 3.97581e-10) (2256, 1.76429e-08) (2258, 1.76429e-08) (2259, -4.66014e-06) (2271, 3.97581e-10)
row 2260: (415, 7.44645e-09) (2248, 3.97584e-10) (2260, -4.65644e-06) (2261, 8.17135e-09) (2263, 1.60193e-08) (2272, 3.97584e-10)
row 2261: (2249, 3.97584e-10) (2260, 8.17135e-09) (2261, -4.65878e-06) (2262, 9.78689e-09) (2264, 1.60193e-08) (2273, 3.97584e-10)
row 2262: (2250, 3.97584e-10) (2261, 1.7643e-08) (2262, -4.66009e-06) (2265, 1.7643e-08) (2274, 3.97584e-10)
row 2263: (1746, 8.24704e-09) (2251, 3.97583e-10) (2260, 1.01718e-08) (2263, -4.65238e-06) (2264, 4.58014e-09) (2266, 4.58014e-09) (2275, 3.97583e-10)
row 2264: (2252, 3.97583e-10) (2261, 1.01718e-08) (2263, 4.58014e-09) (2264, -4.65431e-06) (2265, 1.01718e-08) (2267, 4.58014e-09) (2276, 3.97583e-10)
row 2265: (2253, 3.97584e-10) (2262, 9.78689e-09) (2264, 1.60193e-08) (2265, -4.65878e-06) (2268, 8.17135e-09) (2277, 3.97584e-10)
row 2266: (1749, 8.24704e-09) (2254, 3.97583e-10) (2263, 4.58014e-09) (2266, -4.65238e-06) (2267, 4.58014e-09) (2269, 1.01718e-08) (2278, 3.97583e-10)
row 2267: (2255, 3.97583e-10) (2264, 4.58014e-09) (2266, 4.58014e-09) (2267, -4.65431e-06) (2268, 1.01718e-08) (2270, 1.01718e-08) (2279, 3.97583e-10)
row 2268: (2256, 3.97584e-10) (2265, 8.17135e-09) (2267, 1.60193e-08) (2268, -4.65878e-06) (2271, 9.78689e-09) (2280, 3.97584e-10)
row 2269: (1752, 7.44645e-09) (2257, 3.97584e-10) (2266, 1.60193e-08) (2269, -4.65644e-06) (2270, 8.17135e-09) (2281, 3.97584e-10)
row 2270: (2258, 3.97584e-10) (2267, 1.60193e-08) (2269, 8.17135e-09) (2270, -4.65878e-06) (2271, 9.78689e-09) (2282, 3.97584e-10)
row 2271: (2259, 3.97584e-10) (2268, 1.7643e-08) (2270, 1.7643e-08) (2271, -4.66009e-06) (2283, 3.97584e-10)
row 2272: (431, 7.4465e-09) (2260, 3.97586e-10) (2272, -4.65639e-06) (2273, 8.17141e-09) (2275, 1.60194e-08) (2284, 3.97586e-10)
row 2273: (2261, 3.97586e-10) (2272, 8.17141e-09) (2273, -4.65873e-06) (2274, 9.78696e-09) (2276, 1.60194e-08) (2285, 3.97586e-10)
row 2274: (2262, 3.97587e-10) (2273, 1.76431e-08) (2274, -4.66004e-06) (2277, 1.76431e-08) (2286, 3.97587e-10)
row 2275: (1755, 8.2471e-09) (2263, 3.97586e-10) (2272, 1.01719e-08) (2275, -4.65233e-06) (2276, 4.58017e-09) (2278, 4.58017e-09) (2287, 3.97586e-10)
row 2276: (2264, 3.97586e-10) (2273, 1.01719e-08) (2275, 4.58017e-09) (2276, -4.65426e-06) (2277, 1.01719e-08) (2279, 4.58017e-09) (2288, 3.97586e-10)
row 2277: (2265, 3.97586e-10) (2274, 9.78696e-09) (2276, 1.60194e-08) (2277, -4.65873e-06) (2280, 8.17141e-09) (2289, 3.97586e-10)
row 2278: (1758, 8.2471e-09) (2266, 3.97586e-10) (2275, 4.58017e-09) (2278, -4.65233e-06) (2279, 4.58017e-09) (2281, 1.01719e-08) (2290, 3.97586e-10)
row 2279: (2267, 3.97586e-10) (2276, 4.58017e-09) (2278, 4.58017e-09) (2279, -4.65426e-06) (2280, 1.01719e-08) (2282, 1.01719e-08) (2291, 3.97586e-10)
row 2280: (2268, 3.97586e-10) (2277, 8.17141e-09) (2279, 1.60194e-08) (2280, -4.65873e-06) (2283, 9.78696e-09) (2292, 3.97586e-10)
row 2281: (1761, 7.4465e-09) (2269, 3.97586e-10) (2278, 1.60194e-08) (2281, -4.65639e-06) (2282, 8.17141e-09) (2293, 3.97586e-10)
row 2282: (2270, 3.97586e-10) (2279, 1.60194e-08) (2281, 8.17141e-09) (2282, -4.65873e-06) (2283, 9.78696e-09) (2294, 3.97586e-10)
row 2283: (2271, 3.97587e-10) (2280, 1.76431e-08) (2282, 1.76431e-08) (2283, -4.66004e-06) (2295, 3.97587e-10)
row 2284: (447, 7.44656e-09) (2272, 3.97589e-10) (2284, -4.65634e-06) (2285, 8.17147e-09) (2287, 1.60195e-08) (2296, 3.97589e-10)
row 2285: (2273, 3.97589e-10) (2284, 8.17147e-09) (2285, -4.65868e-06) (2286, 9.78703e-09) (2288, 1.60195e-08) (2297, 3.97589e-10)
row 2286: (2274, 3.9759e-10) (2285, 1.76432e-08) (2286, -4.65999e-06) (2289, 1.76432e-08) (2298, 3.9759e-10)
row 2287: (1764, 8.24716e-09) (2275, 3.97588e-10) (2284, 1.0172e-08) (2287, -4.65229e-06) (2288, 4.5802e-09) (2290, 4.5802e-09) (2299, 3.97588e-10)
row 2288: (2276, 3.97588e-10) (2285, 1.0172e-08) (2287, 4.5802e-09) (2288, -4.65421e-06) (2289, 1.0172e-08) (2291, 4.5802e-09) (2300, 3.97588e-10)
row 2289: (2277, 3.97589e-10) (2286, 9.78703e-09) (2288, 1.60195e-08) (2289, -4.65868e-06) (2292, 8.17147e-09) (2301, 3.97589e-10)
row 2290: (1767, 8.24716e-09) (2278, 3.97588e-10) (2287, 4.5802e-09) (2290, -4.65229e-06) (2291, 4.5802e-09) (2293, 1.0172e-08) (2302, 3.97588e-10)
row 2291: (2279, 3.97588e-10) (2288, 4.5802e-09) (2290, 4.5802e-09) (2291, -4.65421e-06) (2292, 1.0172e-08) (2294, 1.0172e-08) (2303, 3.97588e-10)
row 2292: (2280, 3.97589e-10) (2289, 8.17147e-09) (2291, 1.60195e-08) (2292, -4.65868e-06) (2295, 9.78703e-09) (2304, 3.97589e-10)
row 2293: (1770, 7.44656e-09) (2281, 3.97589e-10) (2290, 1.60195e-08) (2293, -4.65634e-06) (2294, 8.17147e-09) (2305, 3.97589e-10)
row 2294: (2282, 3.97589e-10) (2291, 1.60195e-08) (2293, 8.17147e-09) (2294, -4.65868e-06) (2295, 9.78703e-09) (2306, 3.97589e-10)
row 2295: (2283, 3.9759e-10) (2292, 1.76432e-08) (2294, 1.76432e-08) (2295, -4.65999e-06) (2307, 3.9759e-10)
row 2296: (463, 7.44661e-09) (2284, 3.97592e-10) (2296, -4.65644e-06) (2297, 8.17153e-09) (2299, 1.60196e-08) (2308, 5.40019e-10)
row 2297: (2285, 3.97592e-10) (2296, 8.17153e-09) (2297, -4.65878e-06) (2298, 9.7871e-09) (2300, 1.60196e-08) (2309, 5.40019e-10)
row 2298: (2286, 3.97592e-10) (2297, 1.76434e-08) (2298, -4.66009e-06) (2301, 1.76434e-08) (2310, 5.40019e-10)
row 2299: (1773, 8.24722e-09) (2287, 3.97591e-10) (2296, 1.01721e-08) (2299, -4.65238e-06) (2300, 4.58024e-09) (2302, 4.58024e-09) (2311, 5.40018e-10)
row 2300: (2288, 3.97591e-10) (2297, 1.01721e-08) (2299, 4.58024e-09) (2300, -4.65431e-06) (2301, 1.01721e-08) (2303, 4.58024e-09) (2312, 5.40018e-10)
row 2301: (2289, 3.97592e-10) (2298, 9.7871e-09) (2300, 1.60196e-08) (2301, -4.65878e-06) (2304, 8.17153e-09) (2313, 5.40019e-10)
row 2302: (1776, 8.24722e-09) (2290, 3.97591e-10) (2299, 4.58024e-09) (2302, -4.65238e-06) (2303, 4.58024e-09) (2305, 1.01721e-08) (2314, 5.40018e-10)
row 2303: (2291, 3.97591e-10) (2300, 4.58024e-09) (2302, 4.58024e-09) (2303, -4.65431e-06) (2304, 1.01721e-08) (2306, 1.01721e-08) (2315, 5.40018e-10)
row 2304: (2292, 3.97592e-10) (2301, 8.17153e-09) (2303, 1.60196e-08) (2304, -4.65878e-06) (2307, 9.7871e-09) (2316, 5.40019e-10)
row 2305: (1779, 7.44661e-09) (2293, 3.97592e-10) (2302, 1.60196e-08) (2305, -4.65644e-06) (2306, 8.17153e-09) (2317, 5.40019e-10)
row 2306: (2294, 3.97592e-10) (2303, 1.60196e-08) (2305, 8.17153e-09) (2306, -4.65878e-06) (2307, 9.7871e-09) (2318, 5.40019e-10)
row 2307: (2295, 3.97592e-10) (2304, 1.76434e-08) (2306, 1.76434e-08) (2307, -4.66009e-06) (2319, 5.40019e-10)
row 2308: (479, 7.44665e-09) (2296, 1.14312e-09) (2308, -4.65775e-06) (2309, 8.17158e-09) (2311, 1.60197e-08) (2320, 1.14319e-09)
row 2309: (2297, 1.14312e-09) (2308, 8.17158e-09) (2309, -4.66009e-06) (2310, 9.78716e-09) (2312, 1.60197e-08) (2321, 1.14319e-09)
row 2310: (2298, 1.14312e-09) (2309, 1.76435e-08) (2310, -4.6614e-06) (2313, 1.76435e-08) (2322, 1.1432e-09)
row 2311: (1782, 8.24727e-09) (2299, 1.14311e-09) (2308, 1.01721e-08) (2311, -4.65369e-06) (2312, 4.58026e-09) (2314, 4.58026e-09) (2323, 1.14319e-09)
row 2312: (2300, 1.14311e-09) (2309, 1.01721e-08) (2311, 4.58026e-09) (2312, -4.65562e-06) (2313, 1.01721e-08) (2315, 4.58026e-09) (2324, 1.14319e-09)
row 2313: (2301, 1.14312e-09) (2310, 9.78716e-09) (2312, 1.60197e-08) (2313, -4.66009e-06) (2316, 8.17158e-09) (2325, 1.14319e-09)
row 2314: (1785, 8.24727e-09) (2302, 1.14311e-09) (2311, 4.58026e-09) (2314, -4.65369e-06) (2315, 4.58026e-09) (2317, 1.01721e-08) (2326, 1.14319e-09)
row 2315: (2303, 1.14311e-09) (2312, 4.58026e-09) (2314, 4.58026e-09) (2315, -4.65562e-06) (2316, 1.01721e-08) (2318, 1.01721e-08) (2327, 1.14319e-09)
row 2316: (2304, 1.14312e-09) (2313, 8.17158e-09) (2315, 1.60197e-08) (2316, -4.66009e-06) (2319, 9.78716e-09) (2328, 1.14319e-09)
row 2317: (1788, 7.44665e-09) (2305, 1.14312e-09) (2314, 1.60197e-08) (2317, -4.65775e-06) (2318, 8.17158e-09) (2329, 1.14319e-09)
row 2318: (2306, 1.14312e-09) (2315, 1.60197e-08) (2317, 8.17158e-09) (2318, -4.66009e-06) (2319, 9.78716e-09) (2330, 1.14319e-09)
row 2319: (2307, 1.14312e-09) (2316, 1.76435e-08) (2318, 1.76435e-08) (2319, -4.6614e-06) (2331, 1.1432e-09)
row 2320: (495, 7.44669e-09) (2308, 5.40061e-10) (2320, -4.65637e-06) (2321, 8.17162e-09) (2323, 1.60198e-08) (2332, 3.97596e-10)
row 2321: (2309, 5.40061e-10) (2320, 8.17162e-09) (2321, -4.65871e-06) (2322, 9.78721e-09) (2324, 1.60198e-08) (2333, 3.97596e-10)
row 2322: (2310, 5.40062e-10) (2321, 1.76436e-08) (2322, -4.66002e-06) (2325, 1.76436e-08) (2334, 3.97597e-10)
row 2323: (1791, 8.24731e-09) (2311, 5.4006e-10) (2320, 1.01722e-08) (2323, -4.65231e-06) (2324, 4.58029e-09) (2326, 4.58029e-09) (2335, 3.97596e-10)
row 2324: (2312, 5.4006e-10) (2321, 1.01722e-08) (2323, 4.58029e-09) (2324, -4.65424e-06) (2325, 1.01722e-08) (2327, 4.58029e-09) (2336, 3.97596e-10)
row 2325: (2313, 5.40061e-10) (2322, 9.78721e-09) (2324, 1.60198e-08) (2325, -4.65871e-06) (2328, 8.17162e-09) (2337, 3.97596e-10)
row 2326: (1794, 8.24731e-09) (2314, 5.4006e-10) (2323, 4.58029e-09) (2326, -4.65231e-06) (2327, 4.58029e-09) (2329, 1.01722e-08) (2338, 3.97596e-10)
row 2327: (2315, 5.4006e-10) (2324, 4.58029e-09) (2326, 4.58029e-09) (2327, -4.65424e-06) (2328, 1.01722e-08) (2330, 1.01722e-08) (2339, 3.97596e-10)
row 2328: (2316, 5.40061e-10) (2325, 8.17162e-09) (2327, 1.60198e-08) (2328, -4.65871e-06) (2331, 9.78721e-09) (2340, 3.97596e-10)
row 2329: (1797, 7.44669e-09) (2317, 5.40061e-10) (2326, 1.60198e-08) (2329, -4.65637e-06) (2330, 8.17162e-09) (2341, 3.97596e-10)
row 2330: (2318, 5.40061e-10) (2327, 1.60198e-08) (2329, 8.17162e-09) (2330, -4.65871e-06) (2331, 9.78721e-09) (2342, 3.97596e-10)
row 2331: (2319, 5.40062e-10) (2328, 1.76436e-08) (2330, 1.76436e-08) (2331, -4.66002e-06) (2343, 3.97597e-10)
row 2332: (511, 7.44675e-09) (2320, 3.97599e-10) (2332, -4.65618e-06) (2333, 8.17168e-09) (2335, 1.60199e-08) (2344, 3.97599e-10)
row 2333: (2321, 3.97599e-10) (2332, 8.17168e-09) (2333, -4.65852e-06) (2334, 9.78728e-09) (2336, 1.60199e-08) (2345, 3.97599e-10)
row 2334: (2322, 3.976e-10) (2333, 1.76437e-08) (2334, -4.65983e-06) (2337, 1.76437e-08) (2346, 3.976e-10)
row 2335: (1800, 8.24737e-09) (2323, 3.97598e-10) (2332, 1.01722e-08) (2335, -4.65212e-06) (2336, 4.58032e-09) (2338, 4.58032e-09) (2347, 3.97598e-10)
row 2336: (2324, 3.97598e-10) (2333, 1.01722e-08) (2335, 4.58032e-09) (2336, -4.65405e-06) (2337, 1.01722e-08) (2339, 4.58032e-09) (2348, 3.97598e-10)
row 2337: (2325, 3.97599e-10) (2334, 9.78728e-09) (2336, 1.60199e-08) (2337, -4.65852e-06) (2340, 8.17168e-09) (2349, 3.97599e-10)
row 2338: (1803, 8.24737e-09) (2326, 3.97598e-10) (2335, 4.58032e-09) (2338, -4.65212e-06) (2339, 4.58032e-09) (2341, 1.01722e-08) (2350, 3.97598e-10)
row 2339: (2327, 3.97598e-10) (2336, 4.58032e-09) (2338, 4.58032e-09) (2339, -4.65405e-06) (2340, 1.01722e-08) (2342, 1.01722e-08) (2351, 3.97598e-10)
row 2340: (2328, 3.97599e-10) (2337, 8.17168e-09) (2339, 1.60199e-08) (2340, -4.65852e-06) (2343, 9.78728e-09) (2352, 3.97599e-10)
row 2341: (1806, 7.44675e-09) (2329, 3.97599e-10) (2338, 1.60199e-08) (2341, -4.65618e-06) (2342, 8.17168e-09) (2353, 3.97599e-10)
row 2342: (2330, 3.97599e-10) (2339, 1.60199e-08) (2341, 8.17168e-09) (2342, -4.65852e-06) (2343, 9.78728e-09) (2354, 3.97599e-10)
row 2343: (2331, 3.976e-10) (2340, 1.76437e-08) (2342, 1.76437e-08) (2343, -4.65983e-06) (2355, 3.976e-10)
row 2344: (527, 7.4468e-09) (2332, 3.97602e-10) (2344, -4.65613e-06) (2345, 8.17174e-09) (2347, 1.602e-08) (2356, 3.97602e-10)
row 2345: (2333, 3.97602e-10) (2344, 8.17174e-09) (2345, -4.65847e-06) (2346, 9.78735e-09) (2348, 1.602e-08) (2357, 3.97602e-10)
row 2346: (2334, 3.97603e-10) (2345, 1.76438e-08) (2346, -4.65978e-06) (2349, 1.76438e-08) (2358, 3.97603e-10)
row 2347: (1809, 8.24743e-09) (2335, 3.97601e-10) (2344, 1.01723e-08) (2347, -4.65207e-06) (2348, 4.58035e-09) (2350, 4.58035e-09) (2359, 3.97601e-10)
row 2348: (2336, 3.97601e-10) (2345, 1.01723e-08) (2347, 4.58035e-09) (2348, -4.654e-06) (2349, 1.01723e-08) (2351, 4.58035e-09) (2360, 3.97601e-10)
row 2349: (2337, 3.97602e-10) (2346, 9.78735e-09) (2348, 1.602e-08) (2349, -4.65847e-06) (2352, 8.17174e-09) (2361, 3.97602e-10)
row 2350: (1812, 8.24743e-09) (2338, 3.97601e-10) (2347, 4.58035e-09) (2350, -4.65207e-06) (2351, 4.58035e-09) (2353, 1.01723e-08) (2362, 3.97601e-10)
row 2351: (2339, 3.97601e-10) (2348, 4.58035e-09) (2350, 4.58035e-09) (2351, -4.654e-06) (2352, 1.01723e-08) (2354, 1.01723e-08) (2363, 3.97601e-10)
row 2352: (2340, 3.97602e-10) (2349, 8.17174e-09) (2351, 1.602e-08) (2352, -4.65847e-06) (2355, 9.78735e-09) (2364, 3.97602e-10)
row 2353: (1815, 7.4468e-09) (2341, 3.97602e-10) (2350, 1.602e-08) (2353, -4.65613e-06) (2354, 8.17174e-09) (2365, 3.97602e-10)
row 2354: (2342, 3.97602e-10) (2351, 1.602e-08) (2353, 8.17174e-09) (2354, -4.65847e-06) (2355, 9.78735e-09) (2366, 3.97602e-10)
row 2355: (2343, 3.97603e-10) (2352, 1.76438e-08) (2354, 1.76438e-08) (2355, -4.65978e-06) (2367, 3.97603e-10)
row 2356: (543, 7.44685e-09) (2344, 3.97605e-10) (2356, -4.65608e-06) (2357, 8.1718e-09) (2359, 1.60201e-08) (2368, 3.97605e-10)
row 2357: (2345, 3.97605e-10) (2356, 8.1718e-09) (2357, -4.65842e-06) (2358, 9.78742e-09) (2360, 1.60201e-08) (2369, 3.97605e-10)
row 2358: (2346, 3.97605e-10) (2357, 1.76439e-08) (2358, -4.65973e-06) (2361, 1.76439e-08) (2370, 3.97605e-10)
row 2359: (1818, 8.24749e-09) (2347, 3.97604e-10) (2356, 1.01724e-08) (2359, -4.65203e-06) (2360, 4.58039e-09) (2362, 4.58039e-09) (2371, 3.97604e-10)
row 2360: (2348, 3.97604e-10) (2357, 1.01724e-08) (2359, 4.58039e-09) (2360, -4.65395e-06) (2361, 1.01724e-08) (2363, 4.58039e-09) (2372, 3.97604e-10)
row 2361: (2349, 3.97605e-10) (2358, 9.78742e-09) (2360, 1.60201e-08) (2361, -4.65842e-06) (2364, 8.1718e-09) (2373, 3.97605e-10)
row 2362: (1821, 8.24749e-09) (2350, 3.97604e-10) (2359, 4.58039e-09) (2362, -4.65203e-06) (2363, 4.58039e-09) (2365, 1.01724e-08) (2374, 3.97604e-10)
row 2363: (2351, 3.97604e-10) (2360, 4.58039e-09) (2362, 4.58039e-09) (2363, -4.65395e-06) (2364, 1.01724e-08) (2366, 1.01724e-08) (2375, 3.97604e-10)
row 2364: (2352, 3.97605e-10) (2361, 8.1718e-09) (2363, 1.60201e-08) (2364, -4.65842e-06) (2367, 9.78742e-09) (2376, 3.97605e-10)
row 2365: (1824, 7.44685e-09) (2353, 3.97605e-10) (2362, 1.60201e-08) (2365, -4.65608e-06) (2366, 8.1718e-09) (2377, 3.97605e-10)
row 2366: (2354, 3.97605e-10) (2363, 1.60201e-08) (2365, 8.1718e-09) (2366, -4.65842e-06) (2367, 9.78742e-09) (2378, 3.97605e-10)
row 2367: (2355, 3.97605e-10) (2364, 1.76439e-08) (2366, 1.76439e-08) (2367, -4.65973e-06) (2379, 3.97605e-10)
row 2368: (559, 7.44691e-09) (2356, 3.97608e-10) (2368, -4.65604e-06) (2369, 8.17186e-09) (2371, 1.60203e-08) (2380, 3.97608e-10)
row 2369: (2357, 3.97608e-10) (2368, 8.17186e-09) (2369, -4.65838e-06) (2370, 9.78749e-09) (2372, 1.60203e-08) (2381, 3.97608e-10)
row 2370: (2358, 3.97608e-10) (2369, 1.76441e-08) (2370, -4.65969e-06) (2373, 1.76441e-08) (2382, 3.97608e-10)
row 2371: (1827, 8.24755e-09) (2359, 3.97607e-10) (2368, 1.01725e-08) (2371, -4.65198e-06) (2372, 4.58042e-09) (2374, 4.58042e-09) (2383, 3.97607e-10)
row 2372: (2360, 3.97607e-10) (2369, 1.01725e-08) (2371, 4.58042e-09) (2372, -4.6539e-06) (2373, 1.01725e-08) (2375, 4.58042e-09) (2384, 3.97607e-10)
row 2373: (2361, 3.97608e-10) (2370, 9.78749e-09) (2372, 1.60203e-08) (2373, -4.65838e-06) (2376, 8.17186e-09) (2385, 3.97608e-10)
row 2374: (1830, 8.24755e-09) (2362, 3.97607e-10) (2371, 4.58042e-09) (2374, -4.65198e-06) (2375, 4.58042e-09) (2377, 1.01725e-08) (2386, 3.97607e-10)
row 2375: (2363, 3.97607e-10) (2372, 4.58042e-09) (2374, 4.58042e-09) (2375, -4.6539e-06) (2376, 1.01725e-08) (2378, 1.01725e-08) (2387, 3.97607e-10)
row 2376: (2364, 3.97608e-10) (2373, 8.17186e-09) (2375, 1.60203e-08) (2376, -4.65838e-06) (2379, 9.78749e-09) (2388, 3.97608e-10)
row 2377: (1833, 7.44691e-09) (2365, 3.97608e-10) (2374, 1.60203e-08) (2377, -4.65604e-06) (2378, 8.17186e-09) (2389, 3.97608e-10)
row 2378: (2366, 3.97608e-10) (2375, 1.60203e-08) (2377, 8.17186e-09) (2378, -4.65838e-06) (2379, 9.78749e-09) (2390, 3.97608e-10)
row 2379: (2367, 3.97608e-10) (2376, 1.76441e-08) (2378, 1.76441e-08) (2379, -4.65969e-06) (2391, 3.97608e-10)
row 2380: (575, 7.44696e-09) (2368, 3.97611e-10) (2380, -4.65613e-06) (2381, 8.17192e-09) (2383, 1.60204e-08) (2392, 5.40044e-10)
row 2381: (2369, 3.97611e-10) (2380, 8.17192e-09) (2381, -4.65847e-06) (2382, 9.78757e-09) (2384, 1.60204e-08) (2393, 5.40044e-10)
row 2382: (2370, 3.97611e-10) (2381, 1.76442e-08) (2382, -4.65978e-06) (2385, 1.76442e-08) (2394, 5.40045e-10)
row 2383: (1836, 8.24761e-09) (2371, 3.9761e-10) (2380, 1.01725e-08) (2383, -4.65207e-06) (2384, 4.58045e-09) (2386, 4.58045e-09) (2395, 5.40043e-10)
row 2384: (2372, 3.9761e-10) (2381, 1.01725e-08) (2383, 4.58045e-09) (2384, -4.654e-06) (2385, 1.01725e-08) (2387, 4.58045e-09) (2396, 5.40043e-10)
row 2385: (2373, 3.97611e-10) (2382, 9.78757e-09) (2384, 1.60204e-08) (2385, -4.65847e-06) (2388, 8.17192e-09) (2397, 5.40044e-10)
row 2386: (1839, 8.24761e-09) (2374, 3.9761e-10) (2383, 4.58045e-09) (2386, -4.65207e-06) (2387, 4.58045e-09) (2389, 1.01725e-08) (2398, 5.40043e-10)
row 2387: (2375, 3.9761e-10) (2384, 4.58045e-09) (2386, 4.58045e-09) (2387, -4.654e-06) (2388, 1.01725e-08) (2390, 1.01725e-08) (2399, 5.40043e-10)
row 2388: (2376, 3.97611e-10) (2385, 8.17192e-09) (2387, 1.60204e-08) (2388, -4.65847e-06) (2391, 9.78757e-09) (2400, 5.40044e-10)
row 2389: (1842, 7.44696e-09) (2377, 3.97611e-10) (2386, 1.60204e-08) (2389, -4.65613e-06) (2390, 8.17192e-09) (2401, 5.40044e-10)
row 2390: (2378, 3.97611e-10) (2387, 1.60204e-08) (2389, 8.17192e-09) (2390, -4.65847e-06) (2391, 9.78757e-09) (2402, 5.40044e-10)
row 2391: (2379, 3.97611e-10) (2388, 1.76442e-08) (2390, 1.76442e-08) (2391, -4.65978e-06) (2403, 5.40045e-10)
row 2392: (591, 7.447e-09) (2380, 1.14317e-09) (2392, -4.65744e-06) (2393, 8.17196e-09) (2395, 1.60205e-08) (2404, 1.14325e-09)
row 2393: (2381, 1.14317e-09) (2392, 8.17196e-09) (2393, -4.65978e-06) (2394, 9.78762e-09) (2396, 1.60205e-08) (2405, 1.14325e-09)
row 2394: (2382, 1.14317e-09) (2393, 1.76443e-08) (2394, -4.66109e-06) (2397, 1.76443e-08) (2406, 1.14325e-09)
row 2395: (1845, 8.24766e-09) (2383, 1.14317e-09) (2392, 1.01726e-08) (2395, -4.65339e-06) (2396, 4.58048e-09) (2398, 4.58048e-09) (2407, 1.14325e-09)
row 2396: (2384, 1.14317e-09) (2393, 1.01726e-08) (2395, 4.58048e-09) (2396, -4.65531e-06) (2397, 1.01726e-08) (2399, 4.58048e-09) (2408, 1.14325e-09)
row 2397: (2385, 1.14317e-09) (2394, 9.78762e-09) (2396, 1.60205e-08) (2397, -4.65978e-06) (2400, 8.17196e-09) (2409, 1.14325e-09)
row 2398: (1848, 8.24766e-09) (2386, 1.14317e-09) (2395, 4.58048e-09) (2398, -4.65339e-06) (2399, 4.58048e-09) (2401, 1.01726e-08) (2410, 1.14325e-09)
row 2399: (2387, 1.14317e-09) (2396, 4.58048e-09) (2398, 4.58048e-09) (2399, -4.65531e-06) (2400, 1.01726e-08) (2402, 1.01726e-08) (2411, 1.14325e-09)
row 2400: (2388, 1.14317e-09) (2397, 8.17196e-09) (2399, 1.60205e-08) (2400, -4.65978e-06) (2403, 9.78762e-09) (2412, 1.14325e-09)
row 2401: (1851, 7.447e-09) (2389, 1.14317e-09) (2398, 1.60205e-08) (2401, -4.65744e-06) (2402, 8.17196e-09) (2413, 1.14325e-09)
row 2402: (2390, 1.14317e-09) (2399, 1.60205e-08) (2401, 8.17196e-09) (2402, -4.65978e-06) (2403, 9.78762e-09) (2414, 1.14325e-09)
row 2403: (2391, 1.14317e-09) (2400, 1.76443e-08) (2402, 1.76443e-08) (2403, -4.66109e-06) (2415, 1.14325e-09)
row 2404: (607, 7.44704e-09) (2392, 5.40087e-10) (2404, -4.65606e-06) (2405, 8.17201e-09) (2407, 1.60205e-08) (2416, 3.97615e-10)
row 2405: (2393, 5.40087e-10) (2404, 8.17201e-09) (2405, -4.6584e-06) (2406, 9.78767e-09) (2408, 1.60205e-08) (2417, 3.97615e-10)
row 2406: (2394, 5.40087e-10) (2405, 1.76444e-08) (2406, -4.65971e-06) (2409, 1.76444e-08) (2418, 3.97615e-10)
row 2407: (1854, 8.2477e-09) (2395, 5.40086e-10) (2404, 1.01726e-08) (2407, -4.652e-06) (2408, 4.5805e-09) (2410, 4.5805e-09) (2419, 3.97614e-10)
row 2408: (2396, 5.40086e-10) (2405, 1.01726e-08) (2407, 4.5805e-09) (2408, -4.65393e-06) (2409, 1.01726e-08) (2411, 4.5805e-09) (2420, 3.97614e-10)
row 2409: (2397, 5.40087e-10) (2406, 9.78767e-09) (2408, 1.60205e-08) (2409, -4.6584e-06) (2412, 8.17201e-09) (2421, 3.97615e-10)
row 2410: (1857, 8.2477e-09) (2398, 5.40086e-10) (2407, 4.5805e-09) (2410, -4.652e-06) (2411, 4.5805e-09) (2413, 1.01726e-08) (2422, 3.97614e-10)
row 2411: (2399, 5.40086e-10) (2408, 4.5805e-09) (2410, 4.5805e-09) (2411, -4.65393e-06) (2412, 1.01726e-08) (2414, 1.01726e-08) (2423, 3.97614e-10)
row 2412: (2400, 5.40087e-10) (2409, 8.17201e-09) (2411, 1.60205e-08) (2412, -4.6584e-06) (2415, 9.78767e-09) (2424, 3.97615e-10)
row 2413: (1860, 7.44704e-09) (2401, 5.40087e-10) (2410, 1.60205e-08) (2413, -4.65606e-06) (2414, 8.17201e-09) (2425, 3.97615e-10)
row 2414: (2402, 5.40087e-10) (2411, 1.60205e-08) (2413, 8.17201e-09) (2414, -4.6584e-06) (2415, 9.78767e-09) (2426, 3.97615e-10)
row 2415: (2403, 5.40087e-10) (2412, 1.76444e-08) (2414, 1.76444e-08) (2415, -4.65971e-06) (2427, 3.97615e-10)
row 2416: (623, 7.4471e-09) (2404, 3.97618e-10) (2416, -4.65587e-06) (2417, 8.17207e-09) (2419, 1.60207e-08) (2428, 3.97618e-10)
row 2417: (2405, 3.97618e-10) (2416, 8.17207e-09) (2417, -4.65821e-06) (2418, 9.78774e-09) (2420, 1.60207e-08) (2429, 3.97618e-10)
row 2418: (2406, 3.97618e-10) (2417, 1.76445e-08) (2418, -4.65952e-06) (2421, 1.76445e-08) (2430, 3.97618e-10)
row 2419: (1863, 8.24776e-09) (2407, 3.97617e-10) (2416, 1.01727e-08) (2419, -4.65181e-06) (2420, 4.58054e-09) (2422, 4.58054e-09) (2431, 3.97617e-10)
row 2420: (2408, 3.97617e-10) (2417, 1.01727e-08) (2419, 4.58054e-09) (2420, -4.65374e-06) (2421, 1.01727e-08) (2423, 4.58054e-09) (2432, 3.97617e-10)
row 2421: (2409, 3.97618e-10) (2418, 9.78774e-09) (2420, 1.60207e-08) (2421, -4.65821e-06) (2424, 8.17207e-09) (2433, 3.97618e-10)
row 2422: (1866, 8.24776e-09) (2410, 3.97617e-10) (2419, 4.58054e-09) (2422, -4.65181e-06) (2423, 4.58054e-09) (2425, 1.01727e-08) (2434, 3.97617e-10)
row 2423: (2411, 3.97617e-10) (2420, 4.58054e-09) (2422, 4.58054e-09) (2423, -4.65374e-06) (2424, 1.01727e-08) (2426, 1.01727e-08) (2435, 3.97617e-10)
row 2424: (2412, 3.97618e-10) (2421, 8.17207e-09) (2423, 1.60207e-08) (2424, -4.65821e-06) (2427, 9.78774e-09) (2436, 3.97618e-10)
row 2425: (1869, 7.4471e-09) (2413, 3.97618e-10) (2422, 1.60207e-08) (2425, -4.65587e-06) (2426, 8.17207e-09) (2437, 3.97618e-10)
row 2426: (2414, 3.97618e-10) (2423, 1.60207e-08) (2425, 8.17207e-09) (2426, -4.65821e-06) (2427, 9.78774e-09) (2438, 3.97618e-10)
row 2427: (2415, 3.97618e-10) (2424, 1.76445e-08) (2426, 1.76445e-08) (2427, -4.65952e-06) (2439, 3.97618e-10)
row 2428: (639, 7.44715e-09) (2416, 3.97621e-10) (2428, -4.65582e-06) (2429, 8.17212e-09) (2431, 1.60208e-08) (2440, 3.97621e-10)
row 2429: (2417, 3.97621e-10) (2428, 8.17212e-09) (2429, -4.65816e-06) (2430, 9.78781e-09) (2432, 1.60208e-08) (2441, 3.97621e-10)
row 2430: (2418, 3.97621e-10) (2429, 1.76447e-08) (2430, -4.65947e-06) (2433, 1.76447e-08) (2442, 3.97621e-10)
row 2431: (1872, 8.24782e-09) (2419, 3.9762e-10) (2428, 1.01728e-08) (2431, -4.65176e-06) (2432, 4.58057e-09) (2434, 4.58057e-09) (2443, 3.9762e-10)
row 2432: (2420, 3.9762e-10) (2429, 1.01728e-08) (2431, 4.58057e-09) (2432, -4.65369e-06) (2433, 1.01728e-08) (2435, 4.58057e-09) (2444, 3.9762e-10)
row 2433: (2421, 3.97621e-10) (2430, 9.78781e-09) (2432, 1.60208e-08) (2433, -4.65816e-06) (2436, 8.17212e-09) (2445, 3.97621e-10)
row 2434: (1875, 8.24782e-09) (2422, 3.9762e-10) (2431, 4.58057e-09) (2434, -4.65176e-06) (2435, 4.58057e-09) (2437, 1.01728e-08) (2446, 3.9762e-10)
row 2435: (2423, 3.9762e-10) (2432, 4.58057e-09) (2434, 4.58057e-09) (2435, -4.65369e-06) (2436, 1.01728e-08) (2438, 1.01728e-08) (2447, 3.9762e-10)
row 2436: (2424, 3.97621e-10) (2433, 8.17212e-09) (2435, 1.60208e-08) (2436, -4.65816e-06) (2439, 9.78781e-09) (2448, 3.97621e-10)
row 2437: (1878, 7.44715e-09) (2425, 3.97621e-10) (2434, 1.60208e-08) (2437, -4.65582e-06) (2438, 8.17212e-09) (2449, 3.97621e-10)
row 2438: (2426, 3.97621e-10) (2435, 1.60208e-08) (2437, 8.17212e-09) (2438, -4.65816e-06) (2439, 9.78781e-09) (2450, 3.97621e-10)
row 2439: (2427, 3.97621e-10) (2436, 1.76447e-08) (2438, 1.76447e-08) (2439, -4.65947e-06) (2451, 3.97621e-10)
row 2440: (655, 7.44721e-09) (2428, 3.97624e-10) (2440, -4.65578e-06) (2441, 8.17218e-09) (2443, 1.60209e-08) (2452, 3.97624e-10)
row 2441: (2429, 3.97624e-10) (2440, 8.17218e-09) (2441, -4.65812e-06) (2442, 9.78788e-09) (2444, 1.60209e-08) (2453, 3.97624e-10)
row 2442: (2430, 3.97624e-10) (2441, 1.76448e-08) (2442, -4.65942e-06) (2445, 1.76448e-08) (2454, 3.97624e-10)
row 2443: (1881, 8.24788e-09) (2431, 3.97623e-10) (2440, 1.01729e-08) (2443, -4.65172e-06) (2444, 4.5806e-09) (2446, 4.5806e-09) (2455, 3.97623e-10)
row 2444: (2432, 3.97623e-10) (2441, 1.01729e-08) (2443, 4.5806e-09) (2444, -4.65364e-06) (2445, 1.01729e-08) (2447, 4.5806e-09) (2456, 3.97623e-10)
row 2445: (2433, 3.97624e-10) (2442, 9.78788e-09) (2444, 1.60209e-08) (2445, -4.65812e-06) (2448, 8.17218e-09) (2457, 3.97624e-10)
row 2446: (1884, 8.24788e-09) (2434, 3.97623e-10) (2443, 4.5806e-09) (2446, -4.65172e-06) (2447, 4.5806e-09) (2449, 1.01729e-08) (2458, 3.97623e-10)
row 2447: (2435, 3.97623e-10) (2444, 4.5806e-09) (2446, 4.5806e-09) (2447, -4.65364e-06) (2448, 1.01729e-08) (2450, 1.01729e-08) (2459, 3.97623e-10)
row 2448: (2436, 3.97624e-10) (2445, 8.17218e-09) (2447, 1.60209e-08) (2448, -4.65812e-06) (2451, 9.78788e-09) (2460, 3.97624e-10)
row 2449: (1887, 7.44721e-09) (2437, 3.97624e-10) (2446, 1.60209e-08) (2449, -4.65578e-06) (2450, 8.17218e-09) (2461, 3.97624e-10)
row 2450: (2438, 3.97624e-10) (2447, 1.60209e-08) (2449, 8.17218e-09) (2450, -4.65812e-06) (2451, 9.78788e-09) (2462, 3.97624e-10)
row 2451: (2439, 3.97624e-10) (2448, 1.76448e-08) (2450, 1.76448e-08) (2451, -4.65942e-06) (2463, 3.97624e-10)
row 2452: (671, 7.44726e-09) (2440, 3.97627e-10) (2452, -4.65573e-06) (2453, 8.17224e-09) (2455, 1.6021e-08) (2464, 3.97627e-10)
row 2453: (2441, 3.97627e-10) (2452, 8.17224e-09) (2453, -4.65807e-06) (2454, 9.78796e-09) (2456, 1.6021e-08) (2465, 3.97627e-10)
row 2454: (2442, 3.97627e-10) (2453, 1.76449e-08) (2454, -4.65938e-06) (2457, 1.76449e-08) (2466, 3.97627e-10)
row 2455: (1890, 8.24794e-09) (2443, 3.97626e-10) (2452, 1.01729e-08) (2455, -4.65167e-06) (2456, 4.58064e-09) (2458, 4.58064e-09) (2467, 3.97626e-10)
row 2456: (2444, 3.97626e-10) (2453, 1.01729e-08) (2455, 4.58064e-09) (2456, -4.65359e-06) (2457, 1.01729e-08) (2459, 4.58064e-09) (2468, 3.97626e-10)
row 2457: (2445, 3.97627e-10) (2454, 9.78796e-09) (2456, 1.6021e-08) (2457, -4.65807e-06) (2460, 8.17224e-09) (2469, 3.97627e-10)
row 2458: (1893, 8.24794e-09) (2446, 3.97626e-10) (2455, 4.58064e-09) (2458, -4.65167e-06) (2459, 4.58064e-09) (2461, 1.01729e-08) (2470, 3.97626e-10)
row 2459: (2447, 3.97626e-10) (2456, 4.58064e-09) (2458, 4.58064e-09) (2459, -4.65359e-06) (2460, 1.01729e-08) (2462, 1.01729e-08) (2471, 3.97626e-10)
row 2460: (2448, 3.97627e-10) (2457, 8.17224e-09) (2459, 1.6021e-08) (2460, -4.65807e-06) (2463, 9.78796e-09) (2472, 3.97627e-10)
row 2461: (1896, 7.44726e-09) (2449, 3.97627e-10) (2458, 1.6021e-08) (2461, -4.65573e-06) (2462, 8.17224e-09) (2473, 3.97627e-10)
row 2462: (2450, 3.97627e-10) (2459, 1.6021e-08) (2461, 8.17224e-09) (2462, -4.65807e-06) (2463, 9.78796e-09) (2474, 3.97627e-10)
row 2463: (2451, 3.97627e-10) (2460, 1.76449e-08) (2462, 1.76449e-08) (2463, -4.65938e-06) (2475, 3.97627e-10)
row 2464: (687, 7.44731e-09) (2452, 3.9763e-10) (2464, -4.65582e-06) (2465, 8.1723e-09) (2467, 1.60211e-08) (2476, 5.4007e-10)
row 2465: (2453, 3.9763e-10) (2464, 8.1723e-09) (2465, -4.65816e-06) (2466, 9.78803e-09) (2468, 1.60211e-08) (2477, 5.4007e-10)
row 2466: (2454, 3.9763e-10) (2465, 1.7645e-08) (2466, -4.65947e-06) (2469, 1.7645e-08) (2478, 5.4007e-10)
row 2467: (1899, 8.248e-09) (2455, 3.97629e-10) (2464, 1.0173e-08) (2467, -4.65176e-06) (2468, 4.58067e-09) (2470, 4.58067e-09) (2479, 5.40069e-10)
row 2468: (2456, 3.97629e-10) (2465, 1.0173e-08) (2467, 4.58067e-09) (2468, -4.65369e-06) (2469, 1.0173e-08) (2471, 4.58067e-09) (2480, 5.40069e-10)
row 2469: (2457, 3.9763e-10) (2466, 9.78803e-09) (2468, 1.60211e-08) (2469, -4.65816e-06) (2472, 8.1723e-09) (2481, 5.4007e-10)
row 2470: (1902, 8.248e-09) (2458, 3.97629e-10) (2467, 4.58067e-09) (2470, -4.65176e-06) (2471, 4.58067e-09) (2473, 1.0173e-08) (2482, 5.40069e-10)
row 2471: (2459, 3.97629e-10) (2468, 4.58067e-09) (2470, 4.58067e-09) (2471, -4.65369e-06) (2472, 1.0173e-08) (2474, 1.0173e-08) (2483, 5.40069e-10)
row 2472: (2460, 3.9763e-10) (2469, 8.1723e-09) (2471, 1.60211e-08) (2472, -4.65816e-06) (2475, 9.78803e-09) (2484, 5.4007e-10)
row 2473: (1905, 7.44731e-09) (2461, 3.9763e-10) (2470, 1.60211e-08) (2473, -4.65582e-06) (2474, 8.1723e-09) (2485, 5.4007e-10)
row 2474: (2462, 3.9763e-10) (2471, 1.60211e-08) (2473, 8.1723e-09) (2474, -4.65816e-06) (2475, 9.78803e-09) (2486, 5.4007e-10)
row 2475: (2463, 3.9763e-10) (2472, 1.7645e-08) (2474, 1.7645e-08) (2475, -4.65947e-06) (2487, 5.4007e-10)
row 2476: (703, 7.44735e-09) (2464, 1.14322e-09) (2476, -4.65715e-06) (2477, 8.17235e-09) (2479, 1.60212e-08) (2488, 1.15732e-09)
row 2477: (2465, 1.14322e-09) (2476, 8.17235e-09) (2477, -4.65949e-06) (2478, 9.78808e-09) (2480, 1.60212e-08) (2489, 1.15732e-09)
row 2478: (2466, 1.14323e-09) (2477, 1.76451e-08) (2478, -4.6608e-06) (2481, 1.76451e-08) (2490, 1.15732e-09)
row 2479: (1908, 8.24805e-09) (2467, 1.14322e-09) (2476, 1.01731e-08) (2479, -4.65309e-06) (2480, 4.58069e-09) (2482, 4.58069e-09) (2491, 1.15731e-09)
row 2480: (2468, 1.14322e-09) (2477, 1.01731e-08) (2479, 4.58069e-09) (2480, -4.65502e-06) (2481, 1.01731e-08) (2483, 4.58069e-09) (2492, 1.15731e-09)
row 2481: (2469, 1.14322e-09) (2478, 9.78808e-09) (2480, 1.60212e-08) (2481, -4.65949e-06) (2484, 8.17235e-09) (2493, 1.15732e-09)
row 2482: (1911, 8.24805e-09) (2470, 1.14322e-09) (2479, 4.58069e-09) (2482, -4.65309e-06) (2483, 4.58069e-09) (2485, 1.01731e-08) (2494, 1.15731e-09)
row 2483: (2471, 1.14322e-09) (2480, 4.58069e-09) (2482, 4.58069e-09) (2483, -4.65502e-06) (2484, 1.01731e-08) (2486, 1.01731e-08) (2495, 1.15731e-09)
row 2484: (2472, 1.14322e-09) (2481, 8.17235e-09) (2483, 1.60212e-08) (2484, -4.65949e-06) (2487, 9.78808e-09) (2496, 1.15732e-09)
row 2485: (1914, 7.44735e-09) (2473, 1.14322e-09) (2482, 1.60212e-08) (2485, -4.65715e-06) (2486, 8.17235e-09) (2497, 1.15732e-09)
row 2486: (2474, 1.14322e-09) (2483, 1.60212e-08) (2485, 8.17235e-09) (2486, -4.65949e-06) (2487, 9.78808e-09) (2498, 1.15732e-09)
row 2487: (2475, 1.14323e-09) (2484, 1.76451e-08) (2486, 1.76451e-08) (2487, -4.6608e-06) (2499, 1.15732e-09)
row 2488: (719, 7.44739e-09) (2476, 5.56658e-10) (2488, -4.65578e-06) (2489, 8.17239e-09) (2491, 1.60213e-08) (2500, 4.12202e-10)
row 2489: (2477, 5.56658e-10) (2488, 8.17239e-09) (2489, -4.65812e-06) (2490, 9.78813e-09) (2492, 1.60213e-08) (2501, 4.12202e-10)
row 2490: (2478, 5.56659e-10) (2489, 1.76452e-08) (2490, -4.65943e-06) (2493, 1.76452e-08) (2502, 4.12202e-10)
row 2491: (1917, 8.24809e-09) (2479, 5.56657e-10) (2488, 1.01731e-08) (2491, -4.65173e-06) (2492, 4.58072e-09) (2494, 4.58072e-09) (2503, 4.12201e-10)
row 2492: (2480, 5.56657e-10) (2489, 1.01731e-08) (2491, 4.58072e-09) (2492, -4.65365e-06) (2493, 1.01731e-08) (2495, 4.58072e-09) (2504, 4.12201e-10)
row 2493: (2481, 5.56658e-10) (2490, 9.78813e-09) (2492, 1.60213e-08) (2493, -4.65812e-06) (2496, 8.17239e-09) (2505, 4.12202e-10)
row 2494: (1920, 8.24809e-09) (2482, 5.56657e-10) (2491, 4.58072e-09) (2494, -4.65173e-06) (2495, 4.58072e-09) (2497, 1.01731e-08) (2506, 4.12201e-10)
row 2495: (2483, 5.56657e-10) (2492, 4.58072e-09) (2494, 4.58072e-09) (2495, -4.65365e-06) (2496, 1.01731e-08) (2498, 1.01731e-08) (2507, 4.12201e-10)
row 2496: (2484, 5.56658e-10) (2493, 8.17239e-09) (2495, 1.60213e-08) (2496, -4.65812e-06) (2499, 9.78813e-09) (2508, 4.12202e-10)
row 2497: (1923, 7.44739e-09) (2485, 5.56658e-10) (2494, 1.60213e-08) (2497, -4.65578e-06) (2498, 8.17239e-09) (2509, 4.12202e-10)
row 2498: (2486, 5.56658e-10) (2495, 1.60213e-08) (2497, 8.17239e-09) (2498, -4.65812e-06) (2499, 9.78813e-09) (2510, 4.12202e-10)
row 2499: (2487, 5.56659e-10) (2496, 1.76452e-08) (2498, 1.76452e-08) (2499, -4.65943e-06) (2511, 4.12202e-10)
row 2500: (735, 7.44745e-09) (2488, 4.12205e-10) (2500, -4.65559e-06) (2501, 8.17245e-09) (2503, 1.60214e-08) (2512, 4.12205e-10)
row 2501: (2489, 4.12205e-10) (2500, 8.17245e-09) (2501, -4.65793e-06) (2502, 9.7882e-09) (2504, 1.60214e-08) (2513, 4.12205e-10)
row 2502: (2490, 4.12205e-10) (2501, 1.76454e-08) (2502, -4.65924e-06) (2505, 1.76454e-08) (2514, 4.12205e-10)
row 2503: (1926, 8.24815e-09) (2491, 4.12204e-10) (2500, 1.01732e-08) (2503, -4.65153e-06) (2504, 4.58075e-09) (2506, 4.58075e-09) (2515, 4.12204e-10)
row 2504: (2492, 4.12204e-10) (2501, 1.01732e-08) (2503, 4.58075e-09) (2504, -4.65346e-06) (2505, 1.01732e-08) (2507, 4.58075e-09) (2516, 4.12204e-10)
row 2505: (2493, 4.12205e-10) (2502, 9.7882e-09) (2504, 1.60214e-08) (2505, -4.65793e-06) (2508, 8.17245e-09) (2517, 4.12205e-10)
row 2506: (1929, 8.24815e-09) (2494, 4.12204e-10) (2503, 4.58075e-09) (2506, -4.65153e-06) (2507, 4.58075e-09) (2509, 1.01732e-08) (2518, 4.12204e-10)
row 2507: (2495, 4.12204e-10) (2504, 4.58075e-09) (2506, 4.58075e-09) (2507, -4.65346e-06) (2508, 1.01732e-08) (2510, 1.01732e-08) (2519, 4.12204e-10)
row 2508: (2496, 4.12205e-10) (2505, 8.17245e-09) (2507, 1.60214e-08) (2508, -4.65793e-06) (2511, 9.7882e-09) (2520, 4.12205e-10)
row 2509: (1932, 7.44745e-09) (2497, 4.12205e-10) (2506, 1.60214e-08) (2509, -4.65559e-06) (2510, 8.17245e-09) (2521, 4.12205e-10)
row 2510: (2498, 4.12205e-10) (2507, 1.60214e-08) (2509, 8.17245e-09) (2510, -4.65793e-06) (2511, 9.7882e-09) (2522, 4.12205e-10)
row 2511: (2499, 4.12205e-10) (2508, 1.76454e-08) (2510, 1.76454e-08) (2511, -4.65924e-06) (2523, 4.12205e-10)
row 2512: (751, 7.4475e-09) (2500, 4.12208e-10) (2512, -4.65555e-06) (2513, 8.17251e-09) (2515, 1.60215e-08) (2524, 4.12208e-10)
row 2513: (2501, 4.12208e-10) (2512, 8.17251e-09) (2513, -4.65789e-06) (2514, 9.78827e-09) (2516, 1.60215e-08) (2525, 4.12208e-10)
row 2514: (2502, 4.12208e-10) (2513, 1.76455e-08) (2514, -4.6592e-06) (2517, 1.76455e-08) (2526, 4.12208e-10)
row 2515: (1935, 8.24821e-09) (2503, 4.12207e-10) (2512, 1.01733e-08) (2515, -4.65149e-06) (2516, 4.58078e-09) (2518, 4.58078e-09) (2527, 4.12207e-10)
row 2516: (2504, 4.12207e-10) (2513, 1.01733e-08) (2515, 4.58078e-09) (2516, -4.65341e-06) (2517, 1.01733e-08) (2519, 4.58078e-09) (2528, 4.12207e-10)
row 2517: (2505, 4.12208e-10) (2514, 9.78827e-09) (2516, 1.60215e-08) (2517, -4.65789e-06) (2520, 8.17251e-09) (2529, 4.12208e-10)
row 2518: (1938, 8.24821e-09) (2506, 4.12207e-10) (2515, 4.58078e-09) (2518, -4.65149e-06) (2519, 4.58078e-09) (2521, 1.01733e-08) (2530, 4.12207e-10)
row 2519: (2507, 4.12207e-10) (2516, 4.58078e-09) (2518, 4.58078e-09) (2519, -4.65341e-06) (2520, 1.01733e-08) (2522, 1.01733e-08) (2531, 4.12207e-10)
row 2520: (2508, 4.12208e-10) (2517, 8.17251e-09) (2519, 1.60215e-08) (2520, -4.65789e-06) (2523, 9.78827e-09) (2532, 4.12208e-10)
row 2521: (1941, 7.4475e-09) (2509, 4.12208e-10) (2518, 1.60215e-08) (2521, -4.65555e-06) (2522, 8.17251e-09) (2533, 4.12208e-10)
row 2522: (2510, 4.12208e-10) (2519, 1.60215e-08) (2521, 8.17251e-09) (2522, -4.65789e-06) (2523, 9.78827e-09) (2534, 4.12208e-10)
row 2523: (2511, 4.12208e-10) (2520, 1.76455e-08) (2522, 1.76455e-08) (2523, -4.6592e-06) (2535, 4.12208e-10)
row 2524: (767, 7.44755e-09) (2512, 4.12211e-10) (2524, -4.6555e-06) (2525, 8.17257e-09) (2527, 1.60216e-08) (2536, 4.12211e-10)
row 2525: (2513, 4.12211e-10) (2524, 8.17257e-09) (2525, -4.65784e-06) (2526, 9.78834e-09) (2528, 1.60216e-08) (2537, 4.12211e-10)
row 2526: (2514, 4.12211e-10) (2525, 1.76456e-08) (2526, -4.65915e-06) (2529, 1.76456e-08) (2538, 4.12211e-10)
row 2527: (1944, 8.24827e-09) (2515, 4.1221e-10) (2524, 1.01733e-08) (2527, -4.65144e-06) (2528, 4.58082e-09) (2530, 4.58082e-09) (2539, 4.1221e-10)
row 2528: (2516, 4.1221e-10) (2525, 1.01733e-08) (2527, 4.58082e-09) (2528, -4.65337e-06) (2529, 1.01733e-08) (2531, 4.58082e-09) (2540, 4.1221e-10)
row 2529: (2517, 4.12211e-10) (2526, 9.78834e-09) (2528, 1.60216e-08) (2529, -4.65784e-06) (2532, 8.17257e-09) (2541, 4.12211e-10)
row 2530: (1947, 8.24827e-09) (2518, 4.1221e-10) (2527, 4.58082e-09) (2530, -4.65144e-06) (2531, 4.58082e-09) (2533, 1.01733e-08) (2542, 4.1221e-10)
row 2531: (2519, 4.1221e-10) (2528, 4.58082e-09) (2530, 4.58082e-09) (2531, -4.65337e-06) (2532, 1.01733e-08) (2534, 1.01733e-08) (2543, 4.1221e-10)
row 2532: (2520, 4.12211e-10) (2529, 8.17257e-09) (2531, 1.60216e-08) (2532, -4.65784e-06) (2535, 9.78834e-09) (2544, 4.12211e-10)
row 2533: (1950, 7.44755e-09) (2521, 4.12211e-10) (2530, 1.60216e-08) (2533, -4.6555e-06) (2534, 8.17257e-09) (2545, 4.12211e-10)
row 2534: (2522, 4.12211e-10) (2531, 1.60216e-08) (2533, 8.17257e-09) (2534, -4.65784e-06) (2535, 9.78834e-09) (2546, 4.12211e-10)
row 2535: (2523, 4.12211e-10) (2532, 1.76456e-08) (2534, 1.76456e-08) (2535, -4.65915e-06) (2547, 4.12211e-10)
row 2536: (783, 7.44761e-09) (2524, 4.12214e-10) (2536, -4.65545e-06) (2537, 8.17263e-09) (2539, 1.60218e-08)
row 2537: (2525, 4.12214e-10) (2536, 8.17263e-09) (2537, -4.65779e-06) (2538, 9.78841e-09) (2540, 1.60218e-08)
row 2538: (2526, 4.12214e-10) (2537, 1.76457e-08) (2538, -4.6591e-06) (2541, 1.76457e-08)
row 2539: (1953, 8.24833e-09) (2527, 4.12213e-10) (2536, 1.01734e-08) (2539, -4.65139e-06) (2540, 4.58085e-09) (2542, 4.58085e-09)
row 2540: (2528, 4.12213e-10) (2537, 1.01734e-08) (2539, 4.58085e-09) (2540, -4.65332e-06) (2541, 1.01734e-08) (2543, 4.58085e-09)
row 2541: (2529, 4.12214e-10) (2538, 9.78841e-09) (2540, 1.60218e-08) (2541, -4.65779e-06) (2544, 8.17263e-09)
row 2542: (1956, 8.24833e-09) (2530, 4.12213e-10) (2539, 4.58085e-09) (2542, -4.65139e-06) (2543, 4.58085e-09) (2545, 1.01734e-08)
row 2543: (2531, 4.12213e-10) (2540, 4.58085e-09) (2542, 4.58085e-09) (2543, -4.65332e-06) (2544, 1.01734e-08) (2546, 1.01734e-08)
row 2544: (2532, 4.12214e-10) (2541, 8.17263e-09) (2543, 1.60218e-08) (2544, -4.65779e-06) (2547, 9.78841e-09)
row 2545: (1959, 7.44761e-09) (2533, 4.12214e-10) (2542, 1.60218e-08) (2545, -4.65545e-06) (2546, 8.17263e-09)
row 2546: (2534, 4.12214e-10) (2543, 1.60218e-08) (2545, 8.17263e-09) (2546, -4.65779e-06) (2547, 9.78841e-09)
row 2547: (2535, 4.12214e-10) (2544, 1.76457e-08) (2546, 1.76457e-08) (2547, -4.6591e-06)
row 2548: (798, 7.44519e-09) (2548, -4.65786e-06) (2549, 1.60166e-08) (2552, 8.16997e-09) (2560, 1.10757e-09)
row 2549: (1525, 8.24565e-09) (2548, 1.01701e-08) (2549, -4.65381e-06) (2550, 4.57936e-09) (2553, 4.57936e-09) (2561, 1.10757e-09)
row 2550: (1526, 8.24565e-09) (2549, 4.57936e-09) (2550, -4.65381e-06) (2551, 1.01701e-08) (2554, 4.57936e-09) (2562, 1.10757e-09)
row 2551: (1527, 7.44519e-09) (2550, 1.60166e-08) (2551, -4.65786e-06) (2555, 8.16997e-09) (2563, 1.10757e-09)
row 2552: (2548, 8.16997e-09) (2552, -4.6602e-06) (2553, 1.60166e-08) (2556, 9.78524e-09) (2564, 1.10757e-09)
row 2553: (2549, 4.57936e-09) (2552, 1.01701e-08) (2553, -4.65573e-06) (2554, 4.57936e-09) (2557, 1.01701e-08) (2565, 1.10757e-09)
row 2554: (2550, 4.57936e-09) (2553, 4.57936e-09) (2554, -4.65573e-06) (2555, 1.01701e-08) (2558, 1.01701e-08) (2566, 1.10757e-09)
row 2555: (2551, 8.16997e-09) (2554, 1.60166e-08) (2555, -4.6602e-06) (2559, 9.78524e-09) (2567, 1.10757e-09)
row 2556: (2552, 1.764e-08) (2556, -4.66151e-06) (2557, 1.764e-08) (2568, 1.10757e-09)
row 2557: (2553, 1.60166e-08) (2556, 9.78524e-09) (2557, -4.6602e-06) (2558, 8.16997e-09) (2569, 1.10757e-09)
row 2558: (2554, 1.60166e-08) (2557, 8.16997e-09) (2558, -4.6602e-06) (2559, 9.78524e-09) (2570, 1.10757e-09)
row 2559: (2555, 1.764e-08) (2558, 1.764e-08) (2559, -4.66151e-06) (2571, 1.10757e-09)
row 2560: (813, 7.44523e-09) (2548, 5.21484e-10) (2560, -4.65763e-06) (2561, 1.60167e-08) (2564, 8.17002e-09) (2572, 3.83508e-10)
row 2561: (1534, 8.2457e-09) (2549, 5.21483e-10) (2560, 1.01702e-08) (2561, -4.65357e-06) (2562, 4.57939e-09) (2565, 4.57939e-09) (2573, 3.83507e-10)
row 2562: (1535, 8.2457e-09) (2550, 5.21483e-10) (2561, 4.57939e-09) (2562, -4.65357e-06) (2563, 1.01702e-08) (2566, 4.57939e-09) (2574, 3.83507e-10)
row 2563: (1536, 7.44523e-09) (2551, 5.21484e-10) (2562, 1.60167e-08) (2563, -4.65763e-06) (2567, 8.17002e-09) (2575, 3.83508e-10)
row 2564: (2552, 5.21484e-10) (2560, 8.17002e-09) (2564, -4.65997e-06) (2565, 1.60167e-08) (2568, 9.78529e-09) (2576, 3.83508e-10)
row 2565: (2553, 5.21483e-10) (2561, 4.57939e-09) (2564, 1.01702e-08) (2565, -4.65549e-06) (2566, 4.57939e-09) (2569, 1.01702e-08) (2577, 3.83507e-10)
row 2566: (2554, 5.21483e-10) (2562, 4.57939e-09) (2565, 4.57939e-09) (2566, -4.65549e-06) (2567, 1.01702e-08) (2570, 1.01702e-08) (2578, 3.83507e-10)
row 2567: (2555, 5.21484e-10) (2563, 8.17002e-09) (2566, 1.60167e-08) (2567, -4.65997e-06) (2571, 9.78529e-09) (2579, 3.83508e-10)
row 2568: (2556, 5.21484e-10) (2564, 1.76401e-08) (2568, -4.66127e-06) (2569, 1.76401e-08) (2580, 3.83508e-10)
row 2569: (2557, 5.21484e-10) (2565, 1.60167e-08) (2568, 9.78529e-09) (2569, -4.65997e-06) (2570, 8.17002e-09) (2581, 3.83508e-10)
row 2570: (2558, 5.21484e-10) (2566, 1.60167e-08) (2569, 8.17002e-09) (2570, -4.65997e-06) (2571, 9.78529e-09) (2582, 3.83508e-10)
row 2571: (2559, 5.21484e-10) (2567, 1.76401e-08) (2570, 1.76401e-08) (2571, -4.66127e-06) (2583, 3.83508e-10)
row 2572: (828, 7.44529e-09) (2560, 3.8351e-10) (2572, -4.65744e-06) (2573, 1.60168e-08) (2576, 8.17008e-09) (2584, 3.8351e-10)
row 2573: (1543, 8.24576e-09) (2561, 3.8351e-10) (2572, 1.01702e-08) (2573, -4.65338e-06) (2574, 4.57942e-09) (2577, 4.57942e-09) (2585, 3.8351e-10)
row 2574: (1544, 8.24576e-09) (2562, 3.8351e-10) (2573, 4.57942e-09) (2574, -4.65338e-06) (2575, 1.01702e-08) (2578, 4.57942e-09) (2586, 3.8351e-10)
row 2575: (1545, 7.44529e-09) (2563, 3.8351e-10) (2574, 1.60168e-08) (2575, -4.65744e-06) (2579, 8.17008e-09) (2587, 3.8351e-10)
row 2576: (2564, 3.8351e-10) (2572, 8.17008e-09) (2576, -4.65978e-06) (2577, 1.60168e-08) (2580, 9.78536e-09) (2588, 3.8351e-10)
row 2577: (2565, 3.8351e-10) (2573, 4.57942e-09) (2576, 1.01702e-08) (2577, -4.65531e-06) (2578, 4.57942e-09) (2581, 1.01702e-08) (2589, 3.8351e-10)
row 2578: (2566, 3.8351e-10) (2574, 4.57942e-09) (2577, 4.57942e-09) (2578, -4.65531e-06) (2579, 1.01702e-08) (2582, 1.01702e-08) (2590, 3.8351e-10)
row 2579: (2567, 3.8351e-10) (2575, 8.17008e-09) (2578, 1.60168e-08) (2579, -4.65978e-06) (2583, 9.78536e-09) (2591, 3.8351e-10)
row 2580: (2568, 3.83511e-10) (2576, 1.76402e-08) (2580, -4.66109e-06) (2581, 1.76402e-08) (2592, 3.83511e-10)
row 2581: (2569, 3.8351e-10) (2577, 1.60168e-08) (2580, 9.78536e-09) (2581, -4.65978e-06) (2582, 8.17008e-09) (2593, 3.8351e-10)
row 2582: (2570, 3.8351e-10) (2578, 1.60168e-08) (2581, 8.17008e-09) (2582, -4.65978e-06) (2583, 9.78536e-09) (2594, 3.8351e-10)
row 2583: (2571, 3.83511e-10) (2579, 1.76402e-08) (2582, 1.76402e-08) (2583, -4.66109e-06) (2595, 3.83511e-10)
row 2584: (843, 7.44534e-09) (2572, 3.83513e-10) (2584, -4.65739e-06) (2585, 1.60169e-08) (2588, 8.17014e-09) (2596, 3.8349e-10)
row 2585: (1552, 8.24582e-09) (2573, 3.83512e-10) (2584, 1.01703e-08) (2585, -4.65333e-06) (2586, 4.57946e-09) (2589, 4.57946e-09) (2597, 3.83489e-10)
row 2586: (1553, 8.24582e-09) (2574, 3.83512e-10) (2585, 4.57946e-09) (2586, -4.65333e-06) (2587, 1.01703e-08) (2590, 4.57946e-09) (2598, 3.83489e-10)
row 2587: (1554, 7.44534e-09) (2575, 3.83513e-10) (2586, 1.60169e-08) (2587, -4.65739e-06) (2591, 8.17014e-09) (2599, 3.8349e-10)
row 2588: (2576, 3.83513e-10) (2584, 8.17014e-09) (2588, -4.65973e-06) (2589, 1.60169e-08) (2592, 9.78543e-09) (2600, 3.8349e-10)
row 2589: (2577, 3.83512e-10) (2585, 4.57946e-09) (2588, 1.01703e-08) (2589, -4.65526e-06) (2590, 4.57946e-09) (2593, 1.01703e-08) (2601, 3.83489e-10)
row 2590: (2578, 3.83512e-10) (2586, 4.57946e-09) (2589, 4.57946e-09) (2590, -4.65526e-06) (2591, 1.01703e-08) (2594, 1.01703e-08) (2602, 3.83489e-10)
row 2591: (2579, 3.83513e-10) (2587, 8.17014e-09) (2590, 1.60169e-08) (2591, -4.65973e-06) (2595, 9.78543e-09) (2603, 3.8349e-10)
row 2592: (2580, 3.83514e-10) (2588, 1.76404e-08) (2592, -4.66104e-06) (2593, 1.76404e-08) (2604, 3.8349e-10)
row 2593: (2581, 3.83513e-10) (2589, 1.60169e-08) (2592, 9.78543e-09) (2593, -4.65973e-06) (2594, 8.17014e-09) (2605, 3.8349e-10)
row 2594: (2582, 3.83513e-10) (2590, 1.60169e-08) (2593, 8.17014e-09) (2594, -4.65973e-06) (2595, 9.78543e-09) (2606, 3.8349e-10)
row 2595: (2583, 3.83514e-10) (2591, 1.76404e-08) (2594, 1.76404e-08) (2595, -4.66104e-06) (2607, 3.8349e-10)
row 2596: (858, 7.4454e-09) (2584, 3.83446e-10) (2596, -4.65734e-06) (2597, 1.6017e-08) (2600, 8.1702e-09) (2608, 3.83446e-10)
row 2597: (1561, 8.24588e-09) (2585, 3.83445e-10) (2596, 1.01704e-08) (2597, -4.65328e-06) (2598, 4.57949e-09) (2601, 4.57949e-09) (2609, 3.83445e-10)
row 2598: (1562, 8.24588e-09) (2586, 3.83445e-10) (2597, 4.57949e-09) (2598, -4.65328e-06) (2599, 1.01704e-08) (2602, 4.57949e-09) (2610, 3.83445e-10)
row 2599: (1563, 7.4454e-09) (2587, 3.83446e-10) (2598, 1.6017e-08) (2599, -4.65734e-06) (2603, 8.1702e-09) (2611, 3.83446e-10)
row 2600: (2588, 3.83446e-10) (2596, 8.1702e-09) (2600, -4.65968e-06) (2601, 1.6017e-08) (2604, 9.78551e-09) (2612, 3.83446e-10)
row 2601: (2589, 3.83445e-10) (2597, 4.57949e-09) (2600, 1.01704e-08) (2601, -4.65521e-06) (2602, 4.57949e-09) (2605, 1.01704e-08) (2613, 3.83445e-10)
row 2602: (2590, 3.83445e-10) (2598, 4.57949e-09) (2601, 4.57949e-09) (2602, -4.65521e-06) (2603, 1.01704e-08) (2606, 1.01704e-08) (2614, 3.83445e-10)
row 2603: (2591, 3.83446e-10) (2599, 8.1702e-09) (2602, 1.6017e-08) (2603, -4.65968e-06) (2607, 9.78551e-09) (2615, 3.83446e-10)
row 2604: (2592, 3.83446e-10) (2600, 1.76405e-08) (2604, -4.66099e-06) (2605, 1.76405e-08) (2616, 3.83446e-10)
row 2605: (2593, 3.83446e-10) (2601, 1.6017e-08) (2604, 9.78551e-09) (2605, -4.65968e-06) (2606, 8.1702e-09) (2617, 3.83446e-10)
row 2606: (2594, 3.83446e-10) (2602, 1.6017e-08) (2605, 8.1702e-09) (2606, -4.65968e-06) (2607, 9.78551e-09) (2618, 3.83446e-10)
row 2607: (2595, 3.83446e-10) (2603, 1.76405e-08) (2606, 1.76405e-08) (2607, -4.66099e-06) (2619, 3.83446e-10)
row 2608: (873, 7.44545e-09) (2596, 3.83496e-10) (2608, -4.65729e-06) (2609, 1.60171e-08) (2612, 8.17026e-09) (2620, 3.83519e-10)
row 2609: (1570, 8.24594e-09) (2597, 3.83495e-10) (2608, 1.01705e-08) (2609, -4.65324e-06) (2610, 4.57952e-09) (2613, 4.57952e-09) (2621, 3.83518e-10)
row 2610: (1571, 8.24594e-09) (2598, 3.83495e-10) (2609, 4.57952e-09) (2610, -4.65324e-06) (2611, 1.01705e-08) (2614, 4.57952e-09) (2622, 3.83518e-10)
row 2611: (1572, 7.44545e-09) (2599, 3.83496e-10) (2610, 1.60171e-08) (2611, -4.65729e-06) (2615, 8.17026e-09) (2623, 3.83519e-10)
row 2612: (2600, 3.83496e-10) (2608, 8.17026e-09) (2612, -4.65963e-06) (2613, 1.60171e-08) (2616, 9.78558e-09) (2624, 3.83519e-10)
row 2613: (2601, 3.83495e-10) (2609, 4.57952e-09) (2612, 1.01705e-08) (2613, -4.65516e-06) (2614, 4.57952e-09) (2617, 1.01705e-08) (2625, 3.83518e-10)
row 2614: (2602, 3.83495e-10) (2610, 4.57952e-09) (2613, 4.57952e-09) (2614, -4.65516e-06) (2615, 1.01705e-08) (2618, 1.01705e-08) (2626, 3.83518e-10)
row 2615: (2603, 3.83496e-10) (2611, 8.17026e-09) (2614, 1.60171e-08) (2615, -4.65963e-06) (2619, 9.78558e-09) (2627, 3.83519e-10)
row 2616: (2604, 3.83496e-10) (2612, 1.76406e-08) (2616, -4.66094e-06) (2617, 1.76406e-08) (2628, 3.83519e-10)
row 2617: (2605, 3.83496e-10) (2613, 1.60171e-08) (2616, 9.78558e-09) (2617, -4.65963e-06) (2618, 8.17026e-09) (2629, 3.83519e-10)
row 2618: (2606, 3.83496e-10) (2614, 1.60171e-08) (2617, 8.17026e-09) (2618, -4.65963e-06) (2619, 9.78558e-09) (2630, 3.83519e-10)
row 2619: (2607, 3.83496e-10) (2615, 1.76406e-08) (2618, 1.76406e-08) (2619, -4.66094e-06) (2631, 3.83519e-10)
row 2620: (888, 7.44551e-09) (2608, 3.83522e-10) (2620, -4.65724e-06) (2621, 1.60172e-08) (2624, 8.17032e-09) (2632, 3.83522e-10)
row 2621: (1579, 8.246e-09) (2609, 3.83521e-10) (2620, 1.01705e-08) (2621, -4.65319e-06) (2622, 4.57956e-09) (2625, 4.57956e-09) (2633, 3.83521e-10)
row 2622: (1580, 8.246e-09) (2610, 3.83521e-10) (2621, 4.57956e-09) (2622, -4.65319e-06) (2623, 1.01705e-08) (2626, 4.57956e-09) (2634, 3.83521e-10)
row 2623: (1581, 7.44551e-09) (2611, 3.83522e-10) (2622, 1.60172e-08) (2623, -4.65724e-06) (2627, 8.17032e-09) (2635, 3.83522e-10)
row 2624: (2612, 3.83522e-10) (2620, 8.17032e-09) (2624, -4.65958e-06) (2625, 1.60172e-08) (2628, 9.78565e-09) (2636, 3.83522e-10)
row 2625: (2613, 3.83521e-10) (2621, 4.57956e-09) (2624, 1.01705e-08) (2625, -4.65511e-06) (2626, 4.57956e-09) (2629, 1.01705e-08) (2637, 3.83521e-10)
row 2626: (2614, 3.83521e-10) (2622, 4.57956e-09) (2625, 4.57956e-09) (2626, -4.65511e-06) (2627, 1.01705e-08) (2630, 1.01705e-08) (2638, 3.83521e-10)
row 2627: (2615, 3.83522e-10) (2623, 8.17032e-09) (2626, 1.60172e-08) (2627, -4.65958e-06) (2631, 9.78565e-09) (2639, 3.83522e-10)
row 2628: (2616, 3.83522e-10) (2624, 1.76408e-08) (2628, -4.66089e-06) (2629, 1.76408e-08) (2640, 3.83522e-10)
row 2629: (2617, 3.83522e-10) (2625, 1.60172e-08) (2628, 9.78565e-09) (2629, -4.65958e-06) (2630, 8.17032e-09) (2641, 3.83522e-10)
row 2630: (2618, 3.83522e-10) (2626, 1.60172e-08) (2629, 8.17032e-09) (2630, -4.65958e-06) (2631, 9.78565e-09) (2642, 3.83522e-10)
row 2631: (2619, 3.83522e-10) (2627, 1.76408e-08) (2630, 1.76408e-08) (2631, -4.66089e-06) (2643, 3.83522e-10)
row 2632: (903, 7.44556e-09) (2620, 3.83525e-10) (2632, -4.65734e-06) (2633, 1.60174e-08) (2636, 8.17038e-09) (2644, 5.23901e-10)
row 2633: (1588, 8.24606e-09) (2621, 3.83524e-10) (2632, 1.01706e-08) (2633, -4.65328e-06) (2634, 4.57959e-09) (2637, 4.57959e-09) (2645, 5.239e-10)
row 2634: (1589, 8.24606e-09) (2622, 3.83524e-10) (2633, 4.57959e-09) (2634, -4.65328e-06) (2635, 1.01706e-08) (2638, 4.57959e-09) (2646, 5.239e-10)
row 2635: (1590, 7.44556e-09) (2623, 3.83525e-10) (2634, 1.60174e-08) (2635, -4.65734e-06) (2639, 8.17038e-09) (2647, 5.23901e-10)
row 2636: (2624, 3.83525e-10) (2632, 8.17038e-09) (2636, -4.65968e-06) (2637, 1.60174e-08) (2640, 9.78572e-09) (2648, 5.23901e-10)
row 2637: (2625, 3.83524e-10) (2633, 4.57959e-09) (2636, 1.01706e-08) (2637, -4.6552e-06) (2638, 4.57959e-09) (2641, 1.01706e-08) (2649, 5.239e-10)
row 2638: (2626, 3.83524e-10) (2634, 4.57959e-09) (2637, 4.57959e-09) (2638, -4.6552e-06) (2639, 1.01706e-08) (2642, 1.01706e-08) (2650, 5.239e-10)
row 2639: (2627, 3.83525e-10) (2635, 8.17038e-09) (2638, 1.60174e-08) (2639, -4.65968e-06) (2643, 9.78572e-09) (2651, 5.23901e-10)
row 2640: (2628, 3.83525e-10) (2636, 1.76409e-08) (2640, -4.66098e-06) (2641, 1.76409e-08) (2652, 5.23901e-10)
row 2641: (2629, 3.83525e-10) (2637, 1.60174e-08) (2640, 9.78572e-09) (2641, -4.65968e-06) (2642, 8.17038e-09) (2653, 5.23901e-10)
row 2642: (2630, 3.83525e-10) (2638, 1.60174e-08) (2641, 8.17038e-09) (2642, -4.65968e-06) (2643, 9.78572e-09) (2654, 5.23901e-10)
row 2643: (2631, 3.83525e-10) (2639, 1.76409e-08) (2642, 1.76409e-08) (2643, -4.66098e-06) (2655, 5.23901e-10)
row 2644: (918, 7.4456e-09) (2632, 1.12907e-09) (2644, -4.65867e-06) (2645, 1.60174e-08) (2648, 8.17042e-09) (2656, 1.14303e-09)
row 2645: (1597, 8.2461e-09) (2633, 1.12907e-09) (2644, 1.01707e-08) (2645, -4.65461e-06) (2646, 4.57962e-09) (2649, 4.57962e-09) (2657, 1.14303e-09)
row 2646: (1598, 8.2461e-09) (2634, 1.12907e-09) (2645, 4.57962e-09) (2646, -4.65461e-06) (2647, 1.01707e-08) (2650, 4.57962e-09) (2658, 1.14303e-09)
row 2647: (1599, 7.4456e-09) (2635, 1.12907e-09) (2646, 1.60174e-08) (2647, -4.65867e-06) (2651, 8.17042e-09) (2659, 1.14303e-09)
row 2648: (2636, 1.12907e-09) (2644, 8.17042e-09) (2648, -4.66101e-06) (2649, 1.60174e-08) (2652, 9.78578e-09) (2660, 1.14303e-09)
row 2649: (2637, 1.12907e-09) (2645, 4.57962e-09) (2648, 1.01707e-08) (2649, -4.65653e-06) (2650, 4.57962e-09) (2653, 1.01707e-08) (2661, 1.14303e-09)
row 2650: (2638, 1.12907e-09) (2646, 4.57962e-09) (2649, 4.57962e-09) (2650, -4.65653e-06) (2651, 1.01707e-08) (2654, 1.01707e-08) (2662, 1.14303e-09)
row 2651: (2639, 1.12907e-09) (2647, 8.17042e-09) (2650, 1.60174e-08) (2651, -4.66101e-06) (2655, 9.78578e-09) (2663, 1.14303e-09)
row 2652: (2640, 1.12908e-09) (2648, 1.7641e-08) (2652, -4.66231e-06) (2653, 1.7641e-08) (2664, 1.14303e-09)
row 2653: (2641, 1.12907e-09) (2649, 1.60174e-08) (2652, 9.78578e-09) (2653, -4.66101e-06) (2654, 8.17042e-09) (2665, 1.14303e-09)
row 2654: (2642, 1.12907e-09) (2650, 1.60174e-08) (2653, 8.17042e-09) (2654, -4.66101e-06) (2655, 9.78578e-09) (2666, 1.14303e-09)
row 2655: (2643, 1.12908e-09) (2651, 1.7641e-08) (2654, 1.7641e-08) (2655, -4.66231e-06) (2667, 1.14303e-09)
row 2656: (933, 7.44564e-09) (2644, 5.39985e-10) (2656, -4.6573e-06) (2657, 1.60175e-08) (2660, 8.17047e-09) (2668, 3.9754e-10)
row 2657: (1606, 8.24615e-09) (2645, 5.39984e-10) (2656, 1.01707e-08) (2657, -4.65324e-06) (2658, 4.57964e-09) (2661, 4.57964e-09) (2669, 3.9754e-10)
row 2658: (1607, 8.24615e-09) (2646, 5.39984e-10) (2657, 4.57964e-09) (2658, -4.65324e-06) (2659, 1.01707e-08) (2662, 4.57964e-09) (2670, 3.9754e-10)
row 2659: (1608, 7.44564e-09) (2647, 5.39985e-10) (2658, 1.60175e-08) (2659, -4.6573e-06) (2663, 8.17047e-09) (2671, 3.9754e-10)
row 2660: (2648, 5.39985e-10) (2656, 8.17047e-09) (2660, -4.65964e-06) (2661, 1.60175e-08) (2664, 9.78583e-09) (2672, 3.9754e-10)
row 2661: (2649, 5.39984e-10) (2657, 4.57964e-09) (2660, 1.01707e-08) (2661, -4.65516e-06) (2662, 4.57964e-09) (2665, 1.01707e-08) (2673, 3.9754e-10)
row 2662: (2650, 5.39984e-10) (2658, 4.57964e-09) (2661, 4.57964e-09) (2662, -4.65516e-06) (2663, 1.01707e-08) (2666, 1.01707e-08) (2674, 3.9754e-10)
row 2663: (2651, 5.39985e-10) (2659, 8.17047e-09) (2662, 1.60175e-08) (2663, -4.65964e-06) (2667, 9.78583e-09) (2675, 3.9754e-10)
row 2664: (2652, 5.39986e-10) (2660, 1.76411e-08) (2664, -4.66094e-06) (2665, 1.76411e-08) (2676, 3.97541e-10)
row 2665: (2653, 5.39985e-10) (2661, 1.60175e-08) (2664, 9.78583e-09) (2665, -4.65964e-06) (2666, 8.17047e-09) (2677, 3.9754e-10)
row 2666: (2654, 5.39985e-10) (2662, 1.60175e-08) (2665, 8.17047e-09) (2666, -4.65964e-06) (2667, 9.78583e-09) (2678, 3.9754e-10)
row 2667: (2655, 5.39986e-10) (2663, 1.76411e-08) (2666, 1.76411e-08) (2667, -4.66094e-06) (2679, 3.97541e-10)
row 2668: (948, 7.44569e-09) (2656, 3.97543e-10) (2668, -4.65711e-06) (2669, 1.60177e-08) (2672, 8.17053e-09) (2680, 3.97543e-10)
row 2669: (1615, 8.24621e-09) (2657, 3.97542e-10) (2668, 1.01708e-08) (2669, -4.65305e-06) (2670, 4.57967e-09) (2673, 4.57967e-09) (2681, 3.97542e-10)
row 2670: (1616, 8.24621e-09) (2658, 3.97542e-10) (2669, 4.57967e-09) (2670, -4.65305e-06) (2671, 1.01708e-08) (2674, 4.57967e-09) (2682, 3.97542e-10)
row 2671: (1617, 7.44569e-09) (2659, 3.97543e-10) (2670, 1.60177e-08) (2671, -4.65711e-06) (2675, 8.17053e-09) (2683, 3.97543e-10)
row 2672: (2660, 3.97543e-10) (2668, 8.17053e-09) (2672, -4.65945e-06) (2673, 1.60177e-08) (2676, 9.7859e-09) (2684, 3.97543e-10)
row 2673: (2661, 3.97542e-10) (2669, 4.57967e-09) (2672, 1.01708e-08) (2673, -4.65497e-06) (2674, 4.57967e-09) (2677, 1.01708e-08) (2685, 3.97542e-10)
row 2674: (2662, 3.97542e-10) (2670, 4.57967e-09) (2673, 4.57967e-09) (2674, -4.65497e-06) (2675, 1.01708e-08) (2678, 1.01708e-08) (2686, 3.97542e-10)
row 2675: (2663, 3.97543e-10) (2671, 8.17053e-09) (2674, 1.60177e-08) (2675, -4.65945e-06) (2679, 9.7859e-09) (2687, 3.97543e-10)
row 2676: (2664, 3.97544e-10) (2672, 1.76412e-08) (2676, -4.66075e-06) (2677, 1.76412e-08) (2688, 3.97544e-10)
row 2677: (2665, 3.97543e-10) (2673, 1.60177e-08) (2676, 9.7859e-09) (2677, -4.65945e-06) (2678, 8.17053e-09) (2689, 3.97543e-10)
row 2678: (2666, 3.97543e-10) (2674, 1.60177e-08) (2677, 8.17053e-09) (2678, -4.65945e-06) (2679, 9.7859e-09) (2690, 3.97543e-10)
row 2679: (2667, 3.97544e-10) (2675, 1.76412e-08) (2678, 1.76412e-08) (2679, -4.66075e-06) (2691, 3.97544e-10)
row 2680: (963, 7.44575e-09) (2668, 3.97546e-10) (2680, -4.65706e-06) (2681, 1.60178e-08) (2684, 8.17059e-09) (2692, 3.97546e-10)
row 2681: (1624, 8.24627e-09) (2669, 3.97545e-10) (2680, 1.01709e-08) (2681, -4.653e-06) (2682, 4.57971e-09) (2685, 4.57971e-09) (2693, 3.97545e-10)
row 2682: (1625, 8.24627e-09) (2670, 3.97545e-10) (2681, 4.57971e-09) (2682, -4.653e-06) (2683, 1.01709e-08) (2686, 4.57971e-09) (2694, 3.97545e-10)
row 2683: (1626, 7.44575e-09) (2671, 3.97546e-10) (2682, 1.60178e-08) (2683, -4.65706e-06) (2687, 8.17059e-09) (2695, 3.97546e-10)
row 2684: (2672, 3.97546e-10) (2680, 8.17059e-09) (2684, -4.6594e-06) (2685, 1.60178e-08) (2688, 9.78597e-09) (2696, 3.97546e-10)
row 2685: (2673, 3.97545e-10) (2681, 4.57971e-09) (2684, 1.01709e-08) (2685, -4.65492e-06) (2686, 4.57971e-09) (2689, 1.01709e-08) (2697, 3.97545e-10)
row 2686: (2674, 3.97545e-10) (2682, 4.57971e-09) (2685, 4.57971e-09) (2686, -4.65492e-06) (2687, 1.01709e-08) (2690, 1.01709e-08) (2698, 3.97545e-10)
row 2687: (2675, 3.97546e-10) (2683, 8.17059e-09) (2686, 1.60178e-08) (2687, -4.6594e-06) (2691, 9.78597e-09) (2699, 3.97546e-10)
row 2688: (2676, 3.97546e-10) (2684, 1.76413e-08) (2688, -4.66071e-06) (2689, 1.76413e-08) (2700, 3.97546e-10)
row 2689: (2677, 3.97546e-10) (2685, 1.60178e-08) (2688, 9.78597e-09) (2689, -4.6594e-06) (2690, 8.17059e-09) (2701, 3.97546e-10)
row 2690: (2678, 3.97546e-10) (2686, 1.60178e-08) (2689, 8.17059e-09) (2690, -4.6594e-06) (2691, 9.78597e-09) (2702, 3.97546e-10)
row 2691: (2679, 3.97546e-10) (2687, 1.76413e-08) (2690, 1.76413e-08) (2691, -4.66071e-06) (2703, 3.97546e-10)
row 2692: (978, 7.4458e-09) (2680, 3.97549e-10) (2692, -4.65701e-06) (2693, 1.60179e-08) (2696, 8.17065e-09) (2704, 3.97549e-10)
row 2693: (1633, 8.24633e-09) (2681, 3.97548e-10) (2692, 1.0171e-08) (2693, -4.65295e-06) (2694, 4.57974e-09) (2697, 4.57974e-09) (2705, 3.97548e-10)
row 2694: (1634, 8.24633e-09) (2682, 3.97548e-10) (2693, 4.57974e-09) (2694, -4.65295e-06) (2695, 1.0171e-08) (2698, 4.57974e-09) (2706, 3.97548e-10)
row 2695: (1635, 7.4458e-09) (2683, 3.97549e-10) (2694, 1.60179e-08) (2695, -4.65701e-06) (2699, 8.17065e-09) (2707, 3.97549e-10)
row 2696: (2684, 3.97549e-10) (2692, 8.17065e-09) (2696, -4.65935e-06) (2697, 1.60179e-08) (2700, 9.78604e-09) (2708, 3.97549e-10)
row 2697: (2685, 3.97548e-10) (2693, 4.57974e-09) (2696, 1.0171e-08) (2697, -4.65488e-06) (2698, 4.57974e-09) (2701, 1.0171e-08) (2709, 3.97548e-10)
row 2698: (2686, 3.97548e-10) (2694, 4.57974e-09) (2697, 4.57974e-09) (2698, -4.65488e-06) (2699, 1.0171e-08) (2702, 1.0171e-08) (2710, 3.97548e-10)
row 2699: (2687, 3.97549e-10) (2695, 8.17065e-09) (2698, 1.60179e-08) (2699, -4.65935e-06) (2703, 9.78604e-09) (2711, 3.97549e-10)
row 2700: (2688, 3.97549e-10) (2696, 1.76415e-08) (2700, -4.66066e-06) (2701, 1.76415e-08) (2712, 3.97549e-10)
row 2701: (2689, 3.97549e-10) (2697, 1.60179e-08) (2700, 9.78604e-09) (2701, -4.65935e-06) (2702, 8.17065e-09) (2713, 3.97549e-10)
row 2702: (2690, 3.97549e-10) (2698, 1.60179e-08) (2701, 8.17065e-09) (2702, -4.65935e-06) (2703, 9.78604e-09) (2714, 3.97549e-10)
row 2703: (2691, 3.97549e-10) (2699, 1.76415e-08) (2702, 1.76415e-08) (2703, -4.66066e-06) (2715, 3.97549e-10)
row 2704: (993, 7.44586e-09) (2692, 3.97552e-10) (2704, -4.65696e-06) (2705, 1.6018e-08) (2708, 8.17071e-09) (2716, 3.97552e-10)
row 2705: (1642, 8.24639e-09) (2693, 3.97551e-10) (2704, 1.0171e-08) (2705, -4.6529e-06) (2706, 4.57977e-09) (2709, 4.57977e-09) (2717, 3.97551e-10)
row 2706: (1643, 8.24639e-09) (2694, 3.97551e-10) (2705, 4.57977e-09) (2706, -4.6529e-06) (2707, 1.0171e-08) (2710, 4.57977e-09) (2718, 3.97551e-10)
row 2707: (1644, 7.44586e-09) (2695, 3.97552e-10) (2706, 1.6018e-08) (2707, -4.65696e-06) (2711, 8.17071e-09) (2719, 3.97552e-10)
row 2708: (2696, 3.97552e-10) (2704, 8.17071e-09) (2708, -4.6593e-06) (2709, 1.6018e-08) (2712, 9.78611e-09) (2720, 3.97552e-10)
row 2709: (2697, 3.97551e-10) (2705, 4.57977e-09) (2708, 1.0171e-08) (2709, -4.65483e-06) (2710, 4.57977e-09) (2713, 1.0171e-08) (2721, 3.97551e-10)
row 2710: (2698, 3.97551e-10) (2706, 4.57977e-09) (2709, 4.57977e-09) (2710, -4.65483e-06) (2711, 1.0171e-08) (2714, 1.0171e-08) (2722, 3.97551e-10)
row 2711: (2699, 3.97552e-10) (2707, 8.17071e-09) (2710, 1.6018e-08) (2711, -4.6593e-06) (2715, 9.78611e-09) (2723, 3.97552e-10)
row 2712: (2700, 3.97552e-10) (2708, 1.76416e-08) (2712, -4.66061e-06) (2713, 1.76416e-08) (2724, 3.97552e-10)
row 2713: (2701, 3.97552e-10) (2709, 1.6018e-08) (2712, 9.78611e-09) (2713, -4.6593e-06) (2714, 8.17071e-09) (2725, 3.97552e-10)
row 2714: (2702, 3.97552e-10) (2710, 1.6018e-08) (2713, 8.17071e-09) (2714, -4.6593e-06) (2715, 9.78611e-09) (2726, 3.97552e-10)
row 2715: (2703, 3.97552e-10) (2711, 1.76416e-08) (2714, 1.76416e-08) (2715, -4.66061e-06) (2727, 3.97552e-10)
row 2716: (1008, 7.44591e-09) (2704, 3.97555e-10) (2716, -4.65706e-06) (2717, 1.60181e-08) (2720, 8.17076e-09) (2728, 5.39968e-10)
row 2717: (1651, 8.24645e-09) (2705, 3.97554e-10) (2716, 1.01711e-08) (2717, -4.653e-06) (2718, 4.57981e-09) (2721, 4.57981e-09) (2729, 5.39967e-10)
row 2718: (1652, 8.24645e-09) (2706, 3.97554e-10) (2717, 4.57981e-09) (2718, -4.653e-06) (2719, 1.01711e-08) (2722, 4.57981e-09) (2730, 5.39967e-10)
row 2719: (1653, 7.44591e-09) (2707, 3.97555e-10) (2718, 1.60181e-08) (2719, -4.65706e-06) (2723, 8.17076e-09) (2731, 5.39968e-10)
row 2720: (2708, 3.97555e-10) (2716, 8.17076e-09) (2720, -4.6594e-06) (2721, 1.60181e-08) (2724, 9.78618e-09) (2732, 5.39968e-10)
row 2721: (2709, 3.97554e-10) (2717, 4.57981e-09) (2720, 1.01711e-08) (2721, -4.65492e-06) (2722, 4.57981e-09) (2725, 1.01711e-08) (2733, 5.39967e-10)
row 2722: (2710, 3.97554e-10) (2718, 4.57981e-09) (2721, 4.57981e-09) (2722, -4.65492e-06) (2723, 1.01711e-08) (2726, 1.01711e-08) (2734, 5.39967e-10)
row 2723: (2711, 3.97555e-10) (2719, 8.17076e-09) (2722, 1.60181e-08) (2723, -4.6594e-06) (2727, 9.78618e-09) (2735, 5.39968e-10)
row 2724: (2712, 3.97555e-10) (2720, 1.76417e-08) (2724, -4.66071e-06) (2725, 1.76417e-08) (2736, 5.39968e-10)
row 2725: (2713, 3.97555e-10) (2721, 1.60181e-08) (2724, 9.78618e-09) (2725, -4.6594e-06) (2726, 8.17076e-09) (2737, 5.39968e-10)
row 2726: (2714, 3.97555e-10) (2722, 1.60181e-08) (2725, 8.17076e-09) (2726, -4.6594e-06) (2727, 9.78618e-09) (2738, 5.39968e-10)
row 2727: (2715, 3.97555e-10) (2723, 1.76417e-08) (2726, 1.76417e-08) (2727, -4.66071e-06) (2739, 5.39968e-10)
row 2728: (1023, 7.44595e-09) (2716, 1.14301e-09) (2728, -4.65837e-06) (2729, 1.60182e-08) (2732, 8.17081e-09) (2740, 1.14309e-09)
row 2729: (1660, 8.24649e-09) (2717, 1.14301e-09) (2728, 1.01712e-08) (2729, -4.65431e-06) (2730, 4.57983e-09) (2733, 4.57983e-09) (2741, 1.14308e-09)
row 2730: (1661, 8.24649e-09) (2718, 1.14301e-09) (2729, 4.57983e-09) (2730, -4.65431e-06) (2731, 1.01712e-08) (2734, 4.57983e-09) (2742, 1.14308e-09)
row 2731: (1662, 7.44595e-09) (2719, 1.14301e-09) (2730, 1.60182e-08) (2731, -4.65837e-06) (2735, 8.17081e-09) (2743, 1.14309e-09)
row 2732: (2720, 1.14301e-09) (2728, 8.17081e-09) (2732, -4.66071e-06) (2733, 1.60182e-08) (2736, 9.78624e-09) (2744, 1.14309e-09)
row 2733: (2721, 1.14301e-09) (2729, 4.57983e-09) (2732, 1.01712e-08) (2733, -4.65624e-06) (2734, 4.57983e-09) (2737, 1.01712e-08) (2745, 1.14308e-09)
row 2734: (2722, 1.14301e-09) (2730, 4.57983e-09) (2733, 4.57983e-09) (2734, -4.65624e-06) (2735, 1.01712e-08) (2738, 1.01712e-08) (2746, 1.14308e-09)
row 2735: (2723, 1.14301e-09) (2731, 8.17081e-09) (2734, 1.60182e-08) (2735, -4.66071e-06) (2739, 9.78624e-09) (2747, 1.14309e-09)
row 2736: (2724, 1.14301e-09) (2732, 1.76418e-08) (2736, -4.66202e-06) (2737, 1.76418e-08) (2748, 1.14309e-09)
row 2737: (2725, 1.14301e-09) (2733, 1.60182e-08) (2736, 9.78624e-09) (2737, -4.66071e-06) (2738, 8.17081e-09) (2749, 1.14309e-09)
row 2738: (2726, 1.14301e-09) (2734, 1.60182e-08) (2737, 8.17081e-09) (2738, -4.66071e-06) (2739, 9.78624e-09) (2750, 1.14309e-09)
row 2739: (2727, 1.14301e-09) (2735, 1.76418e-08) (2738, 1.76418e-08) (2739, -4.66202e-06) (2751, 1.14309e-09)
row 2740: (1038, 7.44599e-09) (2728, 5.40011e-10) (2740, -4.65699e-06) (2741, 1.60183e-08) (2744, 8.17085e-09) (2752, 3.97559e-10)
row 2741: (1669, 8.24654e-09) (2729, 5.40009e-10) (2740, 1.01712e-08) (2741, -4.65293e-06) (2742, 4.57986e-09) (2745, 4.57986e-09) (2753, 3.97558e-10)
row 2742: (1670, 8.24654e-09) (2730, 5.40009e-10) (2741, 4.57986e-09) (2742, -4.65293e-06) (2743, 1.01712e-08) (2746, 4.57986e-09) (2754, 3.97558e-10)
row 2743: (1671, 7.44599e-09) (2731, 5.40011e-10) (2742, 1.60183e-08) (2743, -4.65699e-06) (2747, 8.17085e-09) (2755, 3.97559e-10)
row 2744: (2732, 5.40011e-10) (2740, 8.17085e-09) (2744, -4.65933e-06) (2745, 1.60183e-08) (2748, 9.78629e-09) (2756, 3.97559e-10)
row 2745: (2733, 5.40009e-10) (2741, 4.57986e-09) (2744, 1.01712e-08) (2745, -4.65485e-06) (2746, 4.57986e-09) (2749, 1.01712e-08) (2757, 3.97558e-10)
row 2746: (2734, 5.40009e-10) (2742, 4.57986e-09) (2745, 4.57986e-09) (2746, -4.65485e-06) (2747, 1.01712e-08) (2750, 1.01712e-08) (2758, 3.97558e-10)
row 2747: (2735, 5.40011e-10) (2743, 8.17085e-09) (2746, 1.60183e-08) (2747, -4.65933e-06) (2751, 9.78629e-09) (2759, 3.97559e-10)
row 2748: (2736, 5.40011e-10) (2744, 1.76419e-08) (2748, -4.66064e-06) (2749, 1.76419e-08) (2760, 3.97559e-10)
row 2749: (2737, 5.40011e-10) (2745, 1.60183e-08) (2748, 9.78629e-09) (2749, -4.65933e-06) (2750, 8.17085e-09) (2761, 3.97559e-10)
row 2750: (2738, 5.40011e-10) (2746, 1.60183e-08) (2749, 8.17085e-09) (2750, -4.65933e-06) (2751, 9.78629e-09) (2762, 3.97559e-10)
row 2751: (2739, 5.40011e-10) (2747, 1.76419e-08) (2750, 1.76419e-08) (2751, -4.66064e-06) (2763, 3.97559e-10)
row 2752: (1053, 7.44604e-09) (2740, 3.97562e-10) (2752, -4.6568e-06) (2753, 1.60184e-08) (2756, 8.17091e-09) (2764, 3.97562e-10)
row 2753: (1678, 8.2466e-09) (2741, 3.97561e-10) (2752, 1.01713e-08) (2753, -4.65274e-06) (2754, 4.57989e-09) (2757, 4.57989e-09) (2765, 3.97561e-10)
row 2754: (1679, 8.2466e-09) (2742, 3.97561e-10) (2753, 4.57989e-09) (2754, -4.65274e-06) (2755, 1.01713e-08) (2758, 4.57989e-09) (2766, 3.97561e-10)
row 2755: (1680, 7.44604e-09) (2743, 3.97562e-10) (2754, 1.60184e-08) (2755, -4.6568e-06) (2759, 8.17091e-09) (2767, 3.97562e-10)
row 2756: (2744, 3.97562e-10) (2752, 8.17091e-09) (2756, -4.65914e-06) (2757, 1.60184e-08) (2760, 9.78636e-09) (2768, 3.97562e-10)
row 2757: (2745, 3.97561e-10) (2753, 4.57989e-09) (2756, 1.01713e-08) (2757, -4.65466e-06) (2758, 4.57989e-09) (2761, 1.01713e-08) (2769, 3.97561e-10)
row 2758: (2746, 3.97561e-10) (2754, 4.57989e-09) (2757, 4.57989e-09) (2758, -4.65466e-06) (2759, 1.01713e-08) (2762, 1.01713e-08) (2770, 3.97561e-10)
row 2759: (2747, 3.97562e-10) (2755, 8.17091e-09) (2758, 1.60184e-08) (2759, -4.65914e-06) (2763, 9.78636e-09) (2771, 3.97562e-10)
row 2760: (2748, 3.97562e-10) (2756, 1.7642e-08) (2760, -4.66044e-06) (2761, 1.7642e-08) (2772, 3.97562e-10)
row 2761: (2749, 3.97562e-10) (2757, 1.60184e-08) (2760, 9.78636e-09) (2761, -4.65914e-06) (2762, 8.17091e-09) (2773, 3.97562e-10)
row 2762: (2750, 3.97562e-10) (2758, 1.60184e-08) (2761, 8.17091e-09) (2762, -4.65914e-06) (2763, 9.78636e-09) (2774, 3.97562e-10)
row 2763: (2751, 3.97562e-10) (2759, 1.7642e-08) (2762, 1.7642e-08) (2763, -4.66044e-06) (2775, 3.97562e-10)
row 2764: (1068, 7.4461e-09) (2752, 3.97565e-10) (2764, -4.65675e-06) (2765, 1.60185e-08) (2768, 8.17097e-09) (2776, 3.97565e-10)
row 2765: (1687, 8.24666e-09) (2753, 3.97564e-10) (2764, 1.01714e-08) (2765, -4.65269e-06) (2766, 4.57992e-09) (2769, 4.57992e-09) (2777, 3.97564e-10)
row 2766: (1688, 8.24666e-09) (2754, 3.97564e-10) (2765, 4.57992e-09) (2766, -4.65269e-06) (2767, 1.01714e-08) (2770, 4.57992e-09) (2778, 3.97564e-10)
row 2767: (1689, 7.4461e-09) (2755, 3.97565e-10) (2766, 1.60185e-08) (2767, -4.65675e-06) (2771, 8.17097e-09) (2779, 3.97565e-10)
row 2768: (2756, 3.97565e-10) (2764, 8.17097e-09) (2768, -4.65909e-06) (2769, 1.60185e-08) (2772, 9.78643e-09) (2780, 3.97565e-10)
row 2769: (2757, 3.97564e-10) (2765, 4.57992e-09) (2768, 1.01714e-08) (2769, -4.65462e-06) (2770, 4.57992e-09) (2773, 1.01714e-08) (2781, 3.97564e-10)
row 2770: (2758, 3.97564e-10) (2766, 4.57992e-09) (2769, 4.57992e-09) (2770, -4.65462e-06) (2771, 1.01714e-08) (2774, 1.01714e-08) (2782, 3.97564e-10)
row 2771: (2759, 3.97565e-10) (2767, 8.17097e-09) (2770, 1.60185e-08) (2771, -4.65909e-06) (2775, 9.78643e-09) (2783, 3.97565e-10)
row 2772: (2760, 3.97565e-10) (2768, 1.76422e-08) (2772, -4.6604e-06) (2773, 1.76422e-08) (2784, 3.97565e-10)
row 2773: (2761, 3.97565e-10) (2769, 1.60185e-08) (2772, 9.78643e-09) (2773, -4.65909e-06) (2774, 8.17097e-09) (2785, 3.97565e-10)
row 2774: (2762, 3.97565e-10) (2770, 1.60185e-08) (2773, 8.17097e-09) (2774, -4.65909e-06) (2775, 9.78643e-09) (2786, 3.97565e-10)
row 2775: (2763, 3.97565e-10) (2771, 1.76422e-08) (2774, 1.76422e-08) (2775, -4.6604e-06) (2787, 3.97565e-10)
row 2776: (1083, 7.44615e-09) (2764, 3.97568e-10) (2776, -4.6567e-06) (2777, 1.60186e-08) (2780, 8.17103e-09) (2788, 3.97568e-10)
row 2777: (1696, 8.24672e-09) (2765, 3.97567e-10) (2776, 1.01714e-08) (2777, -4.65264e-06) (2778, 4.57996e-09) (2781, 4.57996e-09) (2789, 3.97567e-10)
row 2778: (1697, 8.24672e-09) (2766, 3.97567e-10) (2777, 4.57996e-09) (2778, -4.65264e-06) (2779, 1.01714e-08) (2782, 4.57996e-09) (2790, 3.97567e-10)
row 2779: (1698, 7.44615e-09) (2767, 3.97568e-10) (2778, 1.60186e-08) (2779, -4.6567e-06) (2783, 8.17103e-09) (2791, 3.97568e-10)
row 2780: (2768, 3.97568e-10) (2776, 8.17103e-09) (2780, -4.65904e-06) (2781, 1.60186e-08) (2784, 9.7865e-09) (2792, 3.97568e-10)
row 2781: (2769, 3.97567e-10) (2777, 4.57996e-09) (2780, 1.01714e-08) (2781, -4.65457e-06) (2782, 4.57996e-09) (2785, 1.01714e-08) (2793, 3.97567e-10)
row 2782: (2770, 3.97567e-10) (2778, 4.57996e-09) (2781, 4.57996e-09) (2782, -4.65457e-06) (2783, 1.01714e-08) (2786, 1.01714e-08) (2794, 3.97567e-10)
row 2783: (2771, 3.97568e-10) (2779, 8.17103e-09) (2782, 1.60186e-08) (2783, -4.65904e-06) (2787, 9.7865e-09) (2795, 3.97568e-10)
row 2784: (2772, 3.97568e-10) (2780, 1.76423e-08) (2784, -4.66035e-06) (2785, 1.76423e-08) (2796, 3.97568e-10)
row 2785: (2773, 3.97568e-10) (2781, 1.60186e-08) (2784, 9.7865e-09) (2785, -4.65904e-06) (2786, 8.17103e-09) (2797, 3.97568e-10)
row 2786: (2774, 3.97568e-10) (2782, 1.60186e-08) (2785, 8.17103e-09) (2786, -4.65904e-06) (2787, 9.7865e-09) (2798, 3.97568e-10)
row 2787: (2775, 3.97568e-10) (2783, 1.76423e-08) (2786, 1.76423e-08) (2787, -4.66035e-06) (2799, 3.97568e-10)
row 2788: (1098, 7.44621e-09) (2776, 3.97571e-10) (2788, -4.65665e-06) (2789, 1.60188e-08) (2792, 8.17109e-09) (2800, 3.97571e-10)
row 2789: (1705, 8.24678e-09) (2777, 3.9757e-10) (2788, 1.01715e-08) (2789, -4.6526e-06) (2790, 4.57999e-09) (2793, 4.57999e-09) (2801, 3.9757e-10)
row 2790: (1706, 8.24678e-09) (2778, 3.9757e-10) (2789, 4.57999e-09) (2790, -4.6526e-06) (2791, 1.01715e-08) (2794, 4.57999e-09) (2802, 3.9757e-10)
row 2791: (1707, 7.44621e-09) (2779, 3.97571e-10) (2790, 1.60188e-08) (2791, -4.65665e-06) (2795, 8.17109e-09) (2803, 3.97571e-10)
row 2792: (2780, 3.97571e-10) (2788, 8.17109e-09) (2792, -4.65899e-06) (2793, 1.60188e-08) (2796, 9.78657e-09) (2804, 3.97571e-10)
row 2793: (2781, 3.9757e-10) (2789, 4.57999e-09) (2792, 1.01715e-08) (2793, -4.65452e-06) (2794, 4.57999e-09) (2797, 1.01715e-08) (2805, 3.9757e-10)
row 2794: (2782, 3.9757e-10) (2790, 4.57999e-09) (2793, 4.57999e-09) (2794, -4.65452e-06) (2795, 1.01715e-08) (2798, 1.01715e-08) (2806, 3.9757e-10)
row 2795: (2783, 3.97571e-10) (2791, 8.17109e-09) (2794, 1.60188e-08) (2795, -4.65899e-06) (2799, 9.78657e-09) (2807, 3.97571e-10)
row 2796: (2784, 3.97571e-10) (2792, 1.76424e-08) (2796, -4.6603e-06) (2797, 1.76424e-08) (2808, 3.97571e-10)
row 2797: (2785, 3.97571e-10) (2793, 1.60188e-08) (2796, 9.78657e-09) (2797, -4.65899e-06) (2798, 8.17109e-09) (2809, 3.97571e-10)
row 2798: (2786, 3.97571e-10) (2794, 1.60188e-08) (2797, 8.17109e-09) (2798, -4.65899e-06) (2799, 9.78657e-09) (2810, 3.97571e-10)
row 2799: (2787, 3.97571e-10) (2795, 1.76424e-08) (2798, 1.76424e-08) (2799, -4.6603e-06) (2811, 3.97571e-10)
row 2800: (1113, 7.44626e-09) (2788, 3.97574e-10) (2800, -4.65675e-06) (2801, 1.60189e-08) (2804, 8.17115e-09) (2812, 5.39993e-10)
row 2801: (1714, 8.24684e-09) (2789, 3.97573e-10) (2800, 1.01716e-08) (2801, -4.65269e-06) (2802, 4.58002e-09) (2805, 4.58002e-09) (2813, 5.39992e-10)
row 2802: (1715, 8.24684e-09) (2790, 3.97573e-10) (2801, 4.58002e-09) (2802, -4.65269e-06) (2803, 1.01716e-08) (2806, 4.58002e-09) (2814, 5.39992e-10)
row 2803: (1716, 7.44626e-09) (2791, 3.97574e-10) (2802, 1.60189e-08) (2803, -4.65675e-06) (2807, 8.17115e-09) (2815, 5.39993e-10)
row 2804: (2792, 3.97574e-10) (2800, 8.17115e-09) (2804, -4.65909e-06) (2805, 1.60189e-08) (2808, 9.78664e-09) (2816, 5.39993e-10)
row 2805: (2793, 3.97573e-10) (2801, 4.58002e-09) (2804, 1.01716e-08) (2805, -4.65461e-06) (2806, 4.58002e-09) (2809, 1.01716e-08) (2817, 5.39992e-10)
row 2806: (2794, 3.97573e-10) (2802, 4.58002e-09) (2805, 4.58002e-09) (2806, -4.65461e-06) (2807, 1.01716e-08) (2810, 1.01716e-08) (2818, 5.39992e-10)
row 2807: (2795, 3.97574e-10) (2803, 8.17115e-09) (2806, 1.60189e-08) (2807, -4.65909e-06) (2811, 9.78664e-09) (2819, 5.39993e-10)
row 2808: (2796, 3.97574e-10) (2804, 1.76425e-08) (2808, -4.6604e-06) (2809, 1.76425e-08) (2820, 5.39994e-10)
row 2809: (2797, 3.97574e-10) (2805, 1.60189e-08) (2808, 9.78664e-09) (2809, -4.65909e-06) (2810, 8.17115e-09) (2821, 5.39993e-10)
row 2810: (2798, 3.97574e-10) (2806, 1.60189e-08) (2809, 8.17115e-09) (2810, -4.65909e-06) (2811, 9.78664e-09) (2822, 5.39993e-10)
row 2811: (2799, 3.97574e-10) (2807, 1.76425e-08) (2810, 1.76425e-08) (2811, -4.6604e-06) (2823, 5.39994e-10)
row 2812: (1128, 7.4463e-09) (2800, 1.14306e-09) (2812, -4.65806e-06) (2813, 1.6019e-08) (2816, 8.17119e-09) (2824, 1.14314e-09)
row 2813: (1723, 8.24688e-09) (2801, 1.14306e-09) (2812, 1.01716e-08) (2813, -4.654e-06) (2814, 4.58005e-09) (2817, 4.58005e-09) (2825, 1.14314e-09)
row 2814: (1724, 8.24688e-09) (2802, 1.14306e-09) (2813, 4.58005e-09) (2814, -4.654e-06) (2815, 1.01716e-08) (2818, 4.58005e-09) (2826, 1.14314e-09)
row 2815: (1725, 7.4463e-09) (2803, 1.14306e-09) (2814, 1.6019e-08) (2815, -4.65806e-06) (2819, 8.17119e-09) (2827, 1.14314e-09)
row 2816: (2804, 1.14306e-09) (2812, 8.17119e-09) (2816, -4.6604e-06) (2817, 1.6019e-08) (2820, 9.7867e-09) (2828, 1.14314e-09)
row 2817: (2805, 1.14306e-09) (2813, 4.58005e-09) (2816, 1.01716e-08) (2817, -4.65593e-06) (2818, 4.58005e-09) (2821, 1.01716e-08) (2829, 1.14314e-09)
row 2818: (2806, 1.14306e-09) (2814, 4.58005e-09) (2817, 4.58005e-09) (2818, -4.65593e-06) (2819, 1.01716e-08) (2822, 1.01716e-08) (2830, 1.14314e-09)
row 2819: (2807, 1.14306e-09) (2815, 8.17119e-09) (2818, 1.6019e-08) (2819, -4.6604e-06) (2823, 9.7867e-09) (2831, 1.14314e-09)
row 2820: (2808, 1.14306e-09) (2816, 1.76426e-08) (2820, -4.66171e-06) (2821, 1.76426e-08) (2832, 1.14314e-09)
row 2821: (2809, 1.14306e-09) (2817, 1.6019e-08) (2820, 9.7867e-09) (2821, -4.6604e-06) (2822, 8.17119e-09) (2833, 1.14314e-09)
row 2822: (2810, 1.14306e-09) (2818, 1.6019e-08) (2821, 8.17119e-09) (2822, -4.6604e-06) (2823, 9.7867e-09) (2834, 1.14314e-09)
row 2823: (2811, 1.14306e-09) (2819, 1.76426e-08) (2822, 1.76426e-08) (2823, -4.66171e-06) (2835, 1.14314e-09)
row 2824: (1143, 7.44634e-09) (2812, 5.40036e-10) (2824, -4.65668e-06) (2825, 1.6019e-08) (2828, 8.17124e-09) (2836, 3.97578e-10)
row 2825: (1732, 8.24692e-09) (2813, 5.40035e-10) (2824, 1.01717e-08) (2825, -4.65262e-06) (2826, 4.58007e-09) (2829, 4.58007e-09) (2837, 3.97577e-10)
row 2826: (1733, 8.24692e-09) (2814, 5.40035e-10) (2825, 4.58007e-09) (2826, -4.65262e-06) (2827, 1.01717e-08) (2830, 4.58007e-09) (2838, 3.97577e-10)
row 2827: (1734, 7.44634e-09) (2815, 5.40036e-10) (2826, 1.6019e-08) (2827, -4.65668e-06) (2831, 8.17124e-09) (2839, 3.97578e-10)
row 2828: (2816, 5.40036e-10) (2824, 8.17124e-09) (2828, -4.65902e-06) (2829, 1.6019e-08) (2832, 9.78675e-09) (2840, 3.97578e-10)
row 2829: (2817, 5.40035e-10) (2825, 4.58007e-09) (2828, 1.01717e-08) (2829, -4.65454e-06) (2830, 4.58007e-09) (2833, 1.01717e-08) (2841, 3.97577e-10)
row 2830: (2818, 5.40035e-10) (2826, 4.58007e-09) (2829, 4.58007e-09) (2830, -4.65454e-06) (2831, 1.01717e-08) (2834, 1.01717e-08) (2842, 3.97577e-10)
row 2831: (2819, 5.40036e-10) (2827, 8.17124e-09) (2830, 1.6019e-08) (2831, -4.65902e-06) (2835, 9.78675e-09) (2843, 3.97578e-10)
row 2832: (2820, 5.40036e-10) (2828, 1.76427e-08) (2832, -4.66033e-06) (2833, 1.76427e-08) (2844, 3.97578e-10)
row 2833: (2821, 5.40036e-10) (2829, 1.6019e-08) (2832, 9.78675e-09) (2833, -4.65902e-06) (2834, 8.17124e-09) (2845, 3.97578e-10)
row 2834: (2822, 5.40036e-10) (2830, 1.6019e-08) (2833, 8.17124e-09) (2834, -4.65902e-06) (2835, 9.78675e-09) (2846, 3.97578e-10)
row 2835: (2823, 5.40036e-10) (2831, 1.76427e-08) (2834, 1.76427e-08) (2835, -4.66033e-06) (2847, 3.97578e-10)
row 2836: (1158, 7.44639e-09) (2824, 3.97581e-10) (2836, -4.65649e-06) (2837, 1.60192e-08) (2840, 8.1713e-09) (2848, 3.97581e-10)
row 2837: (1741, 8.24698e-09) (2825, 3.9758e-10) (2836, 1.01718e-08) (2837, -4.65243e-06) (2838, 4.5801e-09) (2841, 4.5801e-09) (2849, 3.9758e-10)
row 2838: (1742, 8.24698e-09) (2826, 3.9758e-10) (2837, 4.5801e-09) (2838, -4.65243e-06) (2839, 1.01718e-08) (2842, 4.5801e-09) (2850, 3.9758e-10)
row 2839: (1743, 7.44639e-09) (2827, 3.97581e-10) (2838, 1.60192e-08) (2839, -4.65649e-06) (2843, 8.1713e-09) (2851, 3.97581e-10)
row 2840: (2828, 3.97581e-10) (2836, 8.1713e-09) (2840, -4.65883e-06) (2841, 1.60192e-08) (2844, 9.78682e-09) (2852, 3.97581e-10)
row 2841: (2829, 3.9758e-10) (2837, 4.5801e-09) (2840, 1.01718e-08) (2841, -4.65435e-06) (2842, 4.5801e-09) (2845, 1.01718e-08) (2853, 3.9758e-10)
row 2842: (2830, 3.9758e-10) (2838, 4.5801e-09) (2841, 4.5801e-09) (2842, -4.65435e-06) (2843, 1.01718e-08) (2846, 1.01718e-08) (2854, 3.9758e-10)
row 2843: (2831, 3.97581e-10) (2839, 8.1713e-09) (2842, 1.60192e-08) (2843, -4.65883e-06) (2847, 9.78682e-09) (2855, 3.97581e-10)
row 2844: (2832, 3.97581e-10) (2840, 1.76429e-08) (2844, -4.66014e-06) (2845, 1.76429e-08) (2856, 3.97581e-10)
row 2845: (2833, 3.97581e-10) (2841, 1.60192e-08) (2844, 9.78682e-09) (2845, -4.65883e-06) (2846, 8.1713e-09) (2857, 3.97581e-10)
row 2846: (2834, 3.97581e-10) (2842, 1.60192e-08) (2845, 8.1713e-09) (2846, -4.65883e-06) (2847, 9.78682e-09) (2858, 3.97581e-10)
row 2847: (2835, 3.97581e-10) (2843, 1.76429e-08) (2846, 1.76429e-08) (2847, -4.66014e-06) (2859, 3.97581e-10)
row 2848: (1173, 7.44645e-09) (2836, 3.97584e-10) (2848, -4.65644e-06) (2849, 1.60193e-08) (2852, 8.17135e-09) (2860, 3.97584e-10)
row 2849: (1750, 8.24704e-09) (2837, 3.97583e-10) (2848, 1.01718e-08) (2849, -4.65238e-06) (2850, 4.58014e-09) (2853, 4.58014e-09) (2861, 3.97583e-10)
row 2850: (1751, 8.24704e-09) (2838, 3.97583e-10) (2849, 4.58014e-09) (2850, -4.65238e-06) (2851, 1.01718e-08) (2854, 4.58014e-09) (2862, 3.97583e-10)
row 2851: (1752, 7.44645e-09) (2839, 3.97584e-10) (2850, 1.60193e-08) (2851, -4.65644e-06) (2855, 8.17135e-09) (2863, 3.97584e-10)
row 2852: (2840, 3.97584e-10) (2848, 8.17135e-09) (2852, -4.65878e-06) (2853, 1.60193e-08) (2856, 9.78689e-09) (2864, 3.97584e-10)
row 2853: (2841, 3.97583e-10) (2849, 4.58014e-09) (2852, 1.01718e-08) (2853, -4.65431e-06) (2854, 4.58014e-09) (2857, 1.01718e-08) (2865, 3.97583e-10)
row 2854: (2842, 3.97583e-10) (2850, 4.58014e-09) (2853, 4.58014e-09) (2854, -4.65431e-06) (2855, 1.01718e-08) (2858, 1.01718e-08) (2866, 3.97583e-10)
row 2855: (2843, 3.97584e-10) (2851, 8.17135e-09) (2854, 1.60193e-08) (2855, -4.65878e-06) (2859, 9.78689e-09) (2867, 3.97584e-10)
row 2856: (2844, 3.97584e-10) (2852, 1.7643e-08) (2856, -4.66009e-06) (2857, 1.7643e-08) (2868, 3.97584e-10)
row 2857: (2845, 3.97584e-10) (2853, 1.60193e-08) (2856, 9.78689e-09) (2857, -4.65878e-06) (2858, 8.17135e-09) (2869, 3.97584e-10)
row 2858: (2846, 3.97584e-10) (2854, 1.60193e-08) (2857, 8.17135e-09) (2858, -4.65878e-06) (2859, 9.78689e-09) (2870, 3.97584e-10)
row 2859: (2847, 3.97584e-10) (2855, 1.7643e-08) (2858, 1.7643e-08) (2859, -4.66009e-06) (2871, 3.97584e-10)
row 2860: (1188, 7.4465e-09) (2848, 3.97586e-10) (2860, -4.65639e-06) (2861, 1.60194e-08) (2864, 8.17141e-09) (2872, 3.97586e-10)
row 2861: (1759, 8.2471e-09) (2849, 3.97586e-10) (2860, 1.01719e-08) (2861, -4.65233e-06) (2862, 4.58017e-09) (2865, 4.58017e-09) (2873, 3.97586e-10)
row 2862: (1760, 8.2471e-09) (2850, 3.97586e-10) (2861, 4.58017e-09) (2862, -4.65233e-06) (2863, 1.01719e-08) (2866, 4.58017e-09) (2874, 3.97586e-10)
row 2863: (1761, 7.4465e-09) (2851, 3.97586e-10) (2862, 1.60194e-08) (2863, -4.65639e-06) (2867, 8.17141e-09) (2875, 3.97586e-10)
row 2864: (2852, 3.97586e-10) (2860, 8.17141e-09) (2864, -4.65873e-06) (2865, 1.60194e-08) (2868, 9.78696e-09) (2876, 3.97586e-10)
row 2865: (2853, 3.97586e-10) (2861, 4.58017e-09) (2864, 1.01719e-08) (2865, -4.65426e-06) (2866, 4.58017e-09) (2869, 1.01719e-08) (2877, 3.97586e-10)
row 2866: (2854, 3.97586e-10) (2862, 4.58017e-09) (2865, 4.58017e-09) (2866, -4.65426e-06) (2867, 1.01719e-08) (2870, 1.01719e-08) (2878, 3.97586e-10)
row 2867: (2855, 3.97586e-10) (2863, 8.17141e-09) (2866, 1.60194e-08) (2867, -4.65873e-06) (2871, 9.78696e-09) (2879, 3.97586e-10)
row 2868: (2856, 3.97587e-10) (2864, 1.76431e-08) (2868, -4.66004e-06) (2869, 1.76431e-08) (2880, 3.97587e-10)
row 2869: (2857, 3.97586e-10) (2865, 1.60194e-08) (2868, 9.78696e-09) (2869, -4.65873e-06) (2870, 8.17141e-09) (2881, 3.97586e-10)
row 2870: (2858, 3.97586e-10) (2866, 1.60194e-08) (2869, 8.17141e-09) (2870, -4.65873e-06) (2871, 9.78696e-09) (2882, 3.97586e-10)
row 2871: (2859, 3.97587e-10) (2867, 1.76431e-08) (2870, 1.76431e-08) (2871, -4.66004e-06) (2883, 3.97587e-10)
row 2872: (1203, 7.44656e-09) (2860, 3.97589e-10) (2872, -4.65634e-06) (2873, 1.60195e-08) (2876, 8.17147e-09) (2884, 3.97589e-10)
row 2873: (1768, 8.24716e-09) (2861, 3.97588e-10) (2872, 1.0172e-08) (2873, -4.65229e-06) (2874, 4.5802e-09) (2877, 4.5802e-09) (2885, 3.97588e-10)
row 2874: (1769, 8.24716e-09) (2862, 3.97588e-10) (2873, 4.5802e-09) (2874, -4.65229e-06) (2875, 1.0172e-08) (2878, 4.5802e-09) (2886, 3.97588e-10)
row 2875: (1770, 7.44656e-09) (2863, 3.97589e-10) (2874, 1.60195e-08) (2875, -4.65634e-06) (2879, 8.17147e-09) (2887, 3.97589e-10)
row 2876: (2864, 3.97589e-10) (2872, 8.17147e-09) (2876, -4.65868e-06) (2877, 1.60195e-08) (2880, 9.78703e-09) (2888, 3.97589e-10)
row 2877: (2865, 3.97588e-10) (2873, 4.5802e-09) (2876, 1.0172e-08) (2877, -4.65421e-06) (2878, 4.5802e-09) (2881, 1.0172e-08) (2889, 3.97588e-10)
row 2878: (2866, 3.97588e-10) (2874, 4.5802e-09) (2877, 4.5802e-09) (2878, -4.65421e-06) (2879, 1.0172e-08) (2882, 1.0172e-08) (2890, 3.97588e-10)
row 2879: (2867, 3.97589e-10) (2875, 8.17147e-09) (2878, 1.60195e-08) (2879, -4.65868e-06) (2883, 9.78703e-09) (2891, 3.97589e-10)
row 2880: (2868, 3.9759e-10) (2876, 1.76432e-08) (2880, -4.65999e-06) (2881, 1.76432e-08) (2892, 3.9759e-10)
row 2881: (2869, 3.97589e-10) (2877, 1.60195e-08) (2880, 9.78703e-09) (2881, -4.65868e-06) (2882, 8.17147e-09) (2893, 3.97589e-10)
row 2882: (2870, 3.97589e-10) (2878, 1.60195e-08) (2881, 8.17147e-09) (2882, -4.65868e-06) (2883, 9.78703e-09) (2894, 3.97589e-10)
row 2883: (2871, 3.9759e-10) (2879, 1.76432e-08) (2882, 1.76432e-08) (2883, -4.65999e-06) (2895, 3.9759e-10)
row 2884: (1218, 7.44661e-09) (2872, 3.97592e-10) (2884, -4.65644e-06) (2885, 1.60196e-08) (2888, 8.17153e-09) (2896, 5.40019e-10)
row 2885: (1777, 8.24722e-09) (2873, 3.97591e-10) (2884, 1.01721e-08) (2885, -4.65238e-06) (2886, 4.58024e-09) (2889, 4.58024e-09) (2897, 5.40018e-10)
row 2886: (1778, 8.24722e-09) (2874, 3.97591e-10) (2885, 4.58024e-09) (2886, -4.65238e-06) (2887, 1.01721e-08) (2890, 4.58024e-09) (2898, 5.40018e-10)
row 2887: (1779, 7.44661e-09) (2875, 3.97592e-10) (2886, 1.60196e-08) (2887, -4.65644e-06) (2891, 8.17153e-09) (2899, 5.40019e-10)
row 2888: (2876, 3.97592e-10) (2884, 8.17153e-09) (2888, -4.65878e-06) (2889, 1.60196e-08) (2892, 9.7871e-09) (2900, 5.40019e-10)
row 2889: (2877, 3.97591e-10) (2885, 4.58024e-09) (2888, 1.01721e-08) (2889, -4.65431e-06) (2890, 4.58024e-09) (2893, 1.01721e-08) (2901, 5.40018e-10)
row 2890: (2878, 3.97591e-10) (2886, 4.58024e-09) (2889, 4.58024e-09) (2890, -4.65431e-06) (2891, 1.01721e-08) (2894, 1.01721e-08) (2902, 5.40018e-10)
row 2891: (2879, 3.97592e-10) (2887, 8.17153e-09) (2890, 1.60196e-08) (2891, -4.65878e-06) (2895, 9.7871e-09) (2903, 5.40019e-10)
row 2892: (2880, 3.97592e-10) (2888, 1.76434e-08) (2892, -4.66009e-06) (2893, 1.76434e-08) (2904, 5.40019e-10)
row 2893: (2881, 3.97592e-10) (2889, 1.60196e-08) (2892, 9.7871e-09) (2893, -4.65878e-06) (2894, 8.17153e-09) (2905, 5.40019e-10)
row 2894: (2882, 3.97592e-10) (2890, 1.60196e-08) (2893, 8.17153e-09) (2894, -4.65878e-06) (2895, 9.7871e-09) (2906, 5.40019e-10)
row 2895: (2883, 3.97592e-10) (2891, 1.76434e-08) (2894, 1.76434e-08) (2895, -4.66009e-06) (2907, 5.40019e-10)
row 2896: (1233, 7.44665e-09) (2884, 1.14312e-09) (2896, -4.65775e-06) (2897, 1.60197e-08) (2900, 8.17158e-09) (2908, 1.14319e-09)
row 2897: (1786, 8.24727e-09) (2885, 1.14311e-09) (2896, 1.01721e-08) (2897, -4.65369e-06) (2898, 4.58026e-09) (2901, 4.58026e-09) (2909, 1.14319e-09)
row 2898: (1787, 8.24727e-09) (2886, 1.14311e-09) (2897, 4.58026e-09) (2898, -4.65369e-06) (2899, 1.01721e-08) (2902, 4.58026e-09) (2910, 1.14319e-09)
row 2899: (1788, 7.44665e-09) (2887, 1.14312e-09) (2898, 1.60197e-08) (2899, -4.65775e-06) (2903, 8.17158e-09) (2911, 1.14319e-09)
row 2900: (2888, 1.14312e-09) (2896, 8.17158e-09) (2900, -4.66009e-06) (2901, 1.60197e-08) (2904, 9.78716e-09) (2912, 1.14319e-09)
row 2901: (2889, 1.14311e-09) (2897, 4.58026e-09) (2900, 1.01721e-08) (2901, -4.65562e-06) (2902, 4.58026e-09) (2905, 1.01721e-08) (2913, 1.14319e-09)
row 2902: (2890, 1.14311e-09) (2898, 4.58026e-09) (2901, 4.58026e-09) (2902, -4.65562e-06) (2903, 1.01721e-08) (2906, 1.01721e-08) (2914, 1.14319e-09)
row 2903: (2891, 1.14312e-09) (2899, 8.17158e-09) (2902, 1.60197e-08) (2903, -4.66009e-06) (2907, 9.78716e-09) (2915, 1.14319e-09)
row 2904: (2892, 1.14312e-09) (2900, 1.76435e-08) (2904, -4.6614e-06) (2905, 1.76435e-08) (2916, 1.1432e-09)
row 2905: (2893, 1.14312e-09) (2901, 1.60197e-08) (2904, 9.78716e-09) (2905, -4.66009e-06) (2906, 8.17158e-09) (2917, 1.14319e-09)
row 2906: (2894, 1.14312e-09) (2902, 1.60197e-08) (2905, 8.17158e-09) (2906, -4.66009e-06) (2907, 9.78716e-09) (2918, 1.14319e-09)
row 2907: (2895, 1.14312e-09) (2903, 1.76435e-08) (2906, 1.76435e-08) (2907, -4.6614e-06) (2919, 1.1432e-09)
row 2908: (1248, 7.44669e-09) (2896, 5.40061e-10) (2908, -4.65637e-06) (2909, 1.60198e-08) (2912, 8.17162e-09) (2920, 3.97596e-10)
row 2909: (1795, 8.24731e-09) (2897, 5.4006e-10) (2908, 1.01722e-08) (2909, -4.65231e-06) (2910, 4.58029e-09) (2913, 4.58029e-09) (2921, 3.97596e-10)
row 2910: (1796, 8.24731e-09) (2898, 5.4006e-10) (2909, 4.58029e-09) (2910, -4.65231e-06) (2911, 1.01722e-08) (2914, 4.58029e-09) (2922, 3.97596e-10)
row 2911: (1797, 7.44669e-09) (2899, 5.40061e-10) (2910, 1.60198e-08) (2911, -4.65637e-06) (2915, 8.17162e-09) (2923, 3.97596e-10)
row 2912: (2900, 5.40061e-10) (2908, 8.17162e-09) (2912, -4.65871e-06) (2913, 1.60198e-08) (2916, 9.78721e-09) (2924, 3.97596e-10)
row 2913: (2901, 5.4006e-10) (2909, 4.58029e-09) (2912, 1.01722e-08) (2913, -4.65424e-06) (2914, 4.58029e-09) (2917, 1.01722e-08) (2925, 3.97596e-10)
row 2914: (2902, 5.4006e-10) (2910, 4.58029e-09) (2913, 4.58029e-09) (2914, -4.65424e-06) (2915, 1.01722e-08) (2918, 1.01722e-08) (2926, 3.97596e-10)
row 2915: (2903, 5.40061e-10) (2911, 8.17162e-09) (2914, 1.60198e-08) (2915, -4.65871e-06) (2919, 9.78721e-09) (2927, 3.97596e-10)
row 2916: (2904, 5.40062e-10) (2912, 1.76436e-08) (2916, -4.66002e-06) (2917, 1.76436e-08) (2928, 3.97597e-10)
row 2917: (2905, 5.40061e-10) (2913, 1.60198e-08) (2916, 9.78721e-09) (2917, -4.65871e-06) (2918, 8.17162e-09) (2929, 3.97596e-10)
row 2918: (2906, 5.40061e-10) (2914, 1.60198e-08) (2917, 8.17162e-09) (2918, -4.65871e-06) (2919, 9.78721e-09) (2930, 3.97596e-10)
row 2919: (2907, 5.40062e-10) (2915, 1.76436e-08) (2918, 1.76436e-08) (2919, -4.66002e-06) (2931, 3.97597e-10)
row 2920: (1263, 7.44675e-09) (2908, 3.97599e-10) (2920, -4.65618e-06) (2921, 1.60199e-08) (2924, 8.17168e-09) (2932, 3.97599e-10)
row 2921: (1804, 8.24737e-09) (2909, 3.97598e-10) (2920, 1.01722e-08) (2921, -4.65212e-06) (2922, 4.58032e-09) (2925, 4.58032e-09) (2933, 3.97598e-10)
row 2922: (1805, 8.24737e-09) (2910, 3.97598e-10) (2921, 4.58032e-09) (2922, -4.65212e-06) (2923, 1.01722e-08) (2926, 4.58032e-09) (2934, 3.97598e-10)
row 2923: (1806, 7.44675e-09) (2911, 3.97599e-10) (2922, 1.60199e-08) (2923, -4.65618e-06) (2927, 8.17168e-09) (2935, 3.97599e-10)
row 2924: (2912, 3.97599e-10) (2920, 8.17168e-09) (2924, -4.65852e-06) (2925, 1.60199e-08) (2928, 9.78728e-09) (2936, 3.97599e-10)
row 2925: (2913, 3.97598e-10) (2921, 4.58032e-09) (2924, 1.01722e-08) (2925, -4.65405e-06) (2926, 4.58032e-09) (2929, 1.01722e-08) (2937, 3.97598e-10)
row 2926: (2914, 3.97598e-10) (2922, 4.58032e-09) (2925, 4.58032e-09) (2926, -4.65405e-06) (2927, 1.01722e-08) (2930, 1.01722e-08) (2938, 3.97598e-10)
row 2927: (2915, 3.97599e-10) (2923, 8.17168e-09) (2926, 1.60199e-08) (2927, -4.65852e-06) (2931, 9.78728e-09) (2939, 3.97599e-10)
row 2928: (2916, 3.976e-10) (2924, 1.76437e-08) (2928, -4.65983e-06) (2929, 1.76437e-08) (2940, 3.976e-10)
row 2929: (2917, 3.97599e-10) (2925, 1.60199e-08) (2928, 9.78728e-09) (2929, -4.65852e-06) (2930, 8.17168e-09) (2941, 3.97599e-10)
row 2930: (2918, 3.97599e-10) (2926, 1.60199e-08) (2929, 8.17168e-09) (2930, -4.65852e-06) (2931, 9.78728e-09) (2942, 3.97599e-10)
row 2931: (2919, 3.976e-10) (2927, 1.76437e-08) (2930, 1.76437e-08) (2931, -4.65983e-06) (2943, 3.976e-10)
row 2932: (1278, 7.4468e-09) (2920, 3.97602e-10) (2932, -4.65613e-06) (2933, 1.602e-08) (2936, 8.17174e-09) (2944, 3.97602e-10)
row 2933: (1813, 8.24743e-09) (2921, 3.97601e-10) (2932, 1.01723e-08) (2933, -4.65207e-06) (2934, 4.58035e-09) (2937, 4.58035e-09) (2945, 3.97601e-10)
row 2934: (1814, 8.24743e-09) (2922, 3.97601e-10) (2933, 4.58035e-09) (2934, -4.65207e-06) (2935, 1.01723e-08) (2938, 4.58035e-09) (2946, 3.97601e-10)
row 2935: (1815, 7.4468e-09) (2923, 3.97602e-10) (2934, 1.602e-08) (2935, -4.65613e-06) (2939, 8.17174e-09) (2947, 3.97602e-10)
row 2936: (2924, 3.97602e-10) (2932, 8.17174e-09) (2936, -4.65847e-06) (2937, 1.602e-08) (2940, 9.78735e-09) (2948, 3.97602e-10)
row 2937: (2925, 3.97601e-10) (2933, 4.58035e-09) (2936, 1.01723e-08) (2937, -4.654e-06) (2938, 4.58035e-09) (2941, 1.01723e-08) (2949, 3.97601e-10)
row 2938: (2926, 3.97601e-10) (2934, 4.58035e-09) (2937, 4.58035e-09) (2938, -4.654e-06) (2939, 1.01723e-08) (2942, 1.01723e-08) (2950, 3.97601e-10)
row 2939: (2927, 3.97602e-10) (2935, 8.17174e-09) (2938, 1.602e-08) (2939, -4.65847e-06) (2943, 9.78735e-09) (2951, 3.97602e-10)
row 2940: (2928, 3.97603e-10) (2936, 1.76438e-08) (2940, -4.65978e-06) (2941, 1.76438e-08) (2952, 3.97603e-10)
row 2941: (2929, 3.97602e-10) (2937, 1.602e-08) (2940, 9.78735e-09) (2941, -4.65847e-06) (2942, 8.17174e-09) (2953, 3.97602e-10)
row 2942: (2930, 3.97602e-10) (2938, 1.602e-08) (2941, 8.17174e-09) (2942, -4.65847e-06) (2943, 9.78735e-09) (2954, 3.97602e-10)
row 2943: (2931, 3.97603e-10) (2939, 1.76438e-08) (2942, 1.76438e-08) (2943, -4.65978e-06) (2955, 3.97603e-10)
row 2944: (1293, 7.44685e-09) (2932, 3.97605e-10) (2944, -4.65608e-06) (2945, 1.60201e-08) (2948, 8.1718e-09) (2956, 3.97605e-10)
row 2945: (1822, 8.24749e-09) (2933, 3.97604e-10) (2944, 1.01724e-08) (2945, -4.65203e-06) (2946, 4.58039e-09) (2949, 4.58039e-09) (2957, 3.97604e-10)
row 2946: (1823, 8.24749e-09) (2934, 3.97604e-10) (2945, 4.58039e-09) (2946, -4.65203e-06) (2947, 1.01724e-08) (2950, 4.58039e-09) (2958, 3.97604e-10)
row 2947: (1824, 7.44685e-09) (2935, 3.97605e-10) (2946, 1.60201e-08) (2947, -4.65608e-06) (2951, 8.1718e-09) (2959, 3.97605e-10)
row 2948: (2936, 3.97605e-10) (2944, 8.1718e-09) (2948, -4.65842e-06) (2949, 1.60201e-08) (2952, 9.78742e-09) (2960, 3.97605e-10)
row 2949: (2937, 3.97604e-10) (2945, 4.58039e-09) (2948, 1.01724e-08) (2949, -4.65395e-06) (2950, 4.58039e-09) (2953, 1.01724e-08) (2961, 3.97604e-10)
row 2950: (2938, 3.97604e-10) (2946, 4.58039e-09) (2949, 4.58039e-09) (2950, -4.65395e-06) (2951, 1.01724e-08) (2954, 1.01724e-08) (2962, 3.97604e-10)
row 2951: (2939, 3.97605e-10) (2947, 8.1718e-09) (2950, 1.60201e-08) (2951, -4.65842e-06) (2955, 9.78742e-09) (2963, 3.97605e-10)
row 2952: (2940, 3.97605e-10) (2948, 1.76439e-08) (2952, -4.65973e-06) (2953, 1.76439e-08) (2964, 3.97605e-10)
row 2953: (2941, 3.97605e-10) (2949, 1.60201e-08) (2952, 9.78742e-09) (2953, -4.65842e-06) (2954, 8.1718e-09) (2965, 3.97605e-10)
row 2954: (2942, 3.97605e-10) (2950, 1.60201e-08) (2953, 8.1718e-09) (2954, -4.65842e-06) (2955, 9.78742e-09) (2966, 3.97605e-10)
row 2955: (2943, 3.97605e-10) (2951, 1.76439e-08) (2954, 1.76439e-08) (2955, -4.65973e-06) (2967, 3.97605e-10)
row 2956: (1308, 7.44691e-09) (2944, 3.97608e-10) (2956, -4.65604e-06) (2957, 1.60203e-08) (2960, 8.17186e-09) (2968, 3.97608e-10)
row 2957: (1831, 8.24755e-09) (2945, 3.97607e-10) (2956, 1.01725e-08) (2957, -4.65198e-06) (2958, 4.58042e-09) (2961, 4.58042e-09) (2969, 3.97607e-10)
row 2958: (1832, 8.24755e-09) (2946, 3.97607e-10) (2957, 4.58042e-09) (2958, -4.65198e-06) (2959, 1.01725e-08) (2962, 4.58042e-09) (2970, 3.97607e-10)
row 2959: (1833, 7.44691e-09) (2947, 3.97608e-10) (2958, 1.60203e-08) (2959, -4.65604e-06) (2963, 8.17186e-09) (2971, 3.97608e-10)
row 2960: (2948, 3.97608e-10) (2956, 8.17186e-09) (2960, -4.65838e-06) (2961, 1.60203e-08) (2964, 9.78749e-09) (2972, 3.97608e-10)
row 2961: (2949, 3.97607e-10) (2957, 4.58042e-09) (2960, 1.01725e-08) (2961, -4.6539e-06) (2962, 4.58042e-09) (2965, 1.01725e-08) (2973, 3.97607e-10)
row 2962: (2950, 3.97607e-10) (2958, 4.58042e-09) (2961, 4.58042e-09) (2962, -4.6539e-06) (2963, 1.01725e-08) (2966, 1.01725e-08) (2974, 3.97607e-10)
row 2963: (2951, 3.97608e-10) (2959, 8.17186e-09) (2962, 1.60203e-08) (2963, -4.65838e-06) (2967, 9.78749e-09) (2975, 3.97608e-10)
row 2964: (2952, 3.97608e-10) (2960, 1.76441e-08) (2964, -4.65969e-06) (2965, 1.76441e-08) (2976, 3.97608e-10)
row 2965: (2953, 3.97608e-10) (2961, 1.60203e-08) (2964, 9.78749e-09) (2965, -4.65838e-06) (2966, 8.17186e-09) (2977, 3.97608e-10)
row 2966: (2954, 3.97608e-10) (2962, 1.60203e-08) (2965, 8.17186e-09) (2966, -4.65838e-06) (2967, 9.78749e-09) (2978, 3.97608e-10)
row 2967: (2955, 3.97608e-10) (2963, 1.76441e-08) (2966, 1.76441e-08) (2967, -4.65969e-06) (2979, 3.97608e-10)
row 2968: (1323, 7.44696e-09) (2956, 3.97611e-10) (2968, -4.65613e-06) (2969, 1.60204e-08) (2972, 8.17192e-09) (2980, 5.40044e-10)
row 2969: (1840, 8.24761e-09) (2957, 3.9761e-10) (2968, 1.01725e-08) (2969, -4.65207e-06) (2970, 4.58045e-09) (2973, 4.58045e-09) (2981, 5.40043e-10)
row 2970: (1841, 8.24761e-09) (2958, 3.9761e-10) (2969, 4.58045e-09) (2970, -4.65207e-06) (2971, 1.01725e-08) (2974, 4.58045e-09) (2982, 5.40043e-10)
row 2971: (1842, 7.44696e-09) (2959, 3.97611e-10) (2970, 1.60204e-08) (2971, -4.65613e-06) (2975, 8.17192e-09) (2983, 5.40044e-10)
row 2972: (2960, 3.97611e-10) (2968, 8.17192e-09) (2972, -4.65847e-06) (2973, 1.60204e-08) (2976, 9.78757e-09) (2984, 5.40044e-10)
row 2973: (2961, 3.9761e-10) (2969, 4.58045e-09) (2972, 1.01725e-08) (2973, -4.654e-06) (2974, 4.58045e-09) (2977, 1.01725e-08) (2985, 5.40043e-10)
row 2974: (2962, 3.9761e-10) (2970, 4.58045e-09) (2973, 4.58045e-09) (2974, -4.654e-06) (2975, 1.01725e-08) (2978, 1.01725e-08) (2986, 5.40043e-10)
row 2975: (2963, 3.97611e-10) (2971, 8.17192e-09) (2974, 1.60204e-08) (2975, -4.65847e-06) (2979, 9.78757e-09) (2987, 5.40044e-10)
row 2976: (2964, 3.97611e-10) (2972, 1.76442e-08) (2976, -4.65978e-06) (2977, 1.76442e-08) (2988, 5.40045e-10)
row 2977: (2965, 3.97611e-10) (2973, 1.60204e-08) (2976, 9.78757e-09) (2977, -4.65847e-06) (2978, 8.17192e-09) (2989, 5.40044e-10)
row 2978: (2966, 3.97611e-10) (2974, 1.60204e-08) (2977, 8.17192e-09) (2978, -4.65847e-06) (2979, 9.78757e-09) (2990, 5.40044e-10)
row 2979: (2967, 3.97611e-10) (2975, 1.76442e-08) (2978, 1.76442e-08) (2979, -4.65978e-06) (2991, 5.40045e-10)
row 2980: (1338, 7.447e-09) (2968, 1.14317e-09) (2980, -4.65744e-06) (2981, 1.60205e-08) (2984, 8.17196e-09) (2992, 1.14325e-09)
row 2981: (1849, 8.24766e-09) (2969, 1.14317e-09) (2980, 1.01726e-08) (2981, -4.65339e-06) (2982, 4.58048e-09) (2985, 4.58048e-09) (2993, 1.14325e-09)
row 2982: (1850, 8.24766e-09) (2970, 1.14317e-09) (2981, 4.58048e-09) (2982, -4.65339e-06) (2983, 1.01726e-08) (2986, 4.58048e-09) (2994, 1.14325e-09)
row 2983: (1851, 7.447e-09) (2971, 1.14317e-09) (2982, 1.60205e-08) (2983, -4.65744e-06) (2987, 8.17196e-09) (2995, 1.14325e-09)
row 2984: (2972, 1.14317e-09) (2980, 8.17196e-09) (2984, -4.65978e-06) (2985, 1.60205e-08) (2988, 9.78762e-09) (2996, 1.14325e-09)
row 2985: (2973, 1.14317e-09) (2981, 4.58048e-09) (2984, 1.01726e-08) (2985, -4.65531e-06) (2986, 4.58048e-09) (2989, 1.01726e-08) (2997, 1.14325e-09)
row 2986: (2974, 1.14317e-09) (2982, 4.58048e-09) (2985, 4.58048e-09) (2986, -4.65531e-06) (2987, 1.01726e-08) (2990, 1.01726e-08) (2998, 1.14325e-09)
row 2987: (2975, 1.14317e-09) (2983, 8.17196e-09) (2986, 1.60205e-08) (2987, -4.65978e-06) (2991, 9.78762e-09) (2999, 1.14325e-09)
row 2988: (2976, 1.14317e-09) (2984, 1.76443e-08) (2988, -4.66109e-06) (2989, 1.76443e-08) (3000, 1.14325e-09)
row 2989: (2977, 1.14317e-09) (2985, 1.60205e-08) (2988, 9.78762e-09) (2989, -4.65978e-06) (2990, 8.17196e-09) (3001, 1.14325e-09)
row 2990: (2978, 1.14317e-09) (2986, 1.60205e-08) (2989, 8.17196e-09) (2990, -4.65978e-06) (2991, 9.78762e-09) (3002, 1.14325e-09)
row 2991: (2979, 1.14317e-09) (2987, 1.76443e-08) (2990, 1.76443e-08) (2991, -4.66109e-06) (3003, 1.14325e-09)
row 2992: (1353, 7.44704e-09) (2980, 5.40087e-10) (2992, -4.65606e-06) (2993, 1.60205e-08) (2996, 8.17201e-09) (3004, 3.97615e-10)
row 2993: (1858, 8.2477e-09) (2981, 5.40086e-10) (2992, 1.01726e-08) (2993, -4.652e-06) (2994, 4.5805e-09) (2997, 4.5805e-09) (3005, 3.97614e-10)
row 2994: (1859, 8.2477e-09) (2982, 5.40086e-10) (2993, 4.5805e-09) (2994, -4.652e-06) (2995, 1.01726e-08) (2998, 4.5805e-09) (3006, 3.97614e-10)
row 2995: (1860, 7.44704e-09) (2983, 5.40087e-10) (2994, 1.60205e-08) (2995, -4.65606e-06) (2999, 8.17201e-09) (3007, 3.97615e-10)
row 2996: (2984, 5.40087e-10) (2992, 8.17201e-09) (2996, -4.6584e-06) (2997, 1.60205e-08) (3000, 9.78767e-09) (3008, 3.97615e-10)
row 2997: (2985, 5.40086e-10) (2993, 4.5805e-09) (2996, 1.01726e-08) (2997, -4.65393e-06) (2998, 4.5805e-09) (3001, 1.01726e-08) (3009, 3.97614e-10)
row 2998: (2986, 5.40086e-10) (2994, 4.5805e-09) (2997, 4.5805e-09) (2998, -4.65393e-06) (2999, 1.01726e-08) (3002, 1.01726e-08) (3010, 3.97614e-10)
row 2999: (2987, 5.40087e-10) (2995, 8.17201e-09) (2998, 1.60205e-08) (2999, -4.6584e-06) (3003, 9.78767e-09) (3011, 3.97615e-10)
row 3000: (2988, 5.40087e-10) (2996, 1.76444e-08) (3000, -4.65971e-06) (3001, 1.76444e-08) (3012, 3.97615e-10)
row 3001: (2989, 5.40087e-10) (2997, 1.60205e-08) (3000, 9.78767e-09) (3001, -4.6584e-06) (3002, 8.17201e-09) (3013, 3.97615e-10)
row 3002: (2990, 5.40087e-10) (2998, 1.60205e-08) (3001, 8.17201e-09) (3002, -4.6584e-06) (3003, 9.78767e-09) (3014, 3.97615e-10)
row 3003: (2991, 5.40087e-10) (2999, 1.76444e-08) (3002, 1.76444e-08) (3003, -4.65971e-06) (3015, 3.97615e-10)
row 3004: (1368, 7.4471e-09) (2992, 3.97618e-10) (3004, -4.65587e-06) (3005, 1.60207e-08) (3008, 8.17207e-09) (3016, 3.97618e-10)
row 3005: (1867, 8.24776e-09) (2993, 3.97617e-10) (3004, 1.01727e-08) (3005, -4.65181e-06) (3006, 4.58054e-09) (3009, 4.58054e-09) (3017, 3.97617e-10)
row 3006: (1868, 8.24776e-09) (2994, 3.97617e-10) (3005, 4.58054e-09) (3006, -4.65181e-06) (3007, 1.01727e-08) (3010, 4.58054e-09) (3018, 3.97617e-10)
row 3007: (1869, 7.4471e-09) (2995, 3.97618e-10) (3006, 1.60207e-08) (3007, -4.65587e-06) (3011, 8.17207e-09) (3019, 3.97618e-10)
row 3008: (2996, 3.97618e-10) (3004, 8.17207e-09) (3008, -4.65821e-06) (3009, 1.60207e-08) (3012, 9.78774e-09) (3020, 3.97618e-10)
row 3009: (2997, 3.97617e-10) (3005, 4.58054e-09) (3008, 1.01727e-08) (3009, -4.65374e-06) (3010, 4.58054e-09) (3013, 1.01727e-08) (3021, 3.97617e-10)
row 3010: (2998, 3.97617e-10) (3006, 4.58054e-09) (3009, 4.58054e-09) (3010, -4.65374e-06) (3011, 1.01727e-08) (3014, 1.01727e-08) (3022, 3.97617e-10)
row 3011: (2999, 3.97618e-10) (3007, 8.17207e-09) (3010, 1.60207e-08) (3011, -4.65821e-06) (3015, 9.78774e-09) (3023, 3.97618e-10)
row 3012: (3000, 3.97618e-10) (3008, 1.76445e-08) (3012, -4.65952e-06) (3013, 1.76445e-08) (3024, 3.97618e-10)
row 3013: (3001, 3.97618e-10) (3009, 1.60207e-08) (3012, 9.78774e-09) (3013, -4.65821e-06) (3014, 8.17207e-09) (3025, 3.97618e-10)
row 3014: (3002, 3.97618e-10) (3010, 1.60207e-08) (3013, 8.17207e-09) (3014, -4.65821e-06) (3015, 9.78774e-09) (3026, 3.97618e-10)
row 3015: (3003, 3.97618e-10) (3011, 1.76445e-08) (3014, 1.76445e-08) (3015, -4.65952e-06) (3027, 3.97618e-10)
row 3016: (1383, 7.44715e-09) (3004, 3.97621e-10) (3016, -4.65582e-06) (3017, 1.60208e-08) (3020, 8.17212e-09) (3028, 3.97621e-10)
row 3017: (1876, 8.24782e-09) (3005, 3.9762e-10) (3016, 1.01728e-08) (3017, -4.65176e-06) (3018, 4.58057e-09) (3021, 4.58057e-09) (3029, 3.9762e-10)
row 3018: (1877, 8.24782e-09) (3006, 3.9762e-10) (3017, 4.58057e-09) (3018, -4.65176e-06) (3019, 1.01728e-08) (3022, 4.58057e-09) (3030, 3.9762e-10)
row 3019: (1878, 7.44715e-09) (3007, 3.97621e-10) (3018, 1.60208e-08) (3019, -4.65582e-06) (3023, 8.17212e-09) (3031, 3.97621e-10)
row 3020: (3008, 3.97621e-10) (3016, 8.17212e-09) (3020, -4.65816e-06) (3021, 1.60208e-08) (3024, 9.78781e-09) (3032, 3.97621e-10)
row 3021: (3009, 3.9762e-10) (3017, 4.58057e-09) (3020, 1.01728e-08) (3021, -4.65369e-06) (3022, 4.58057e-09) (3025, 1.01728e-08) (3033, 3.9762e-10)
row 3022: (3010, 3.9762e-10) (3018, 4.58057e-09) (3021, 4.58057e-09) (3022, -4.65369e-06) (3023, 1.01728e-08) (3026, 1.01728e-08) (3034, 3.9762e-10)
row 3023: (3011, 3.97621e-10) (3019, 8.17212e-09) (3022, 1.60208e-08) (3023, -4.65816e-06) (3027, 9.78781e-09) (3035, 3.97621e-10)
row 3024: (3012, 3.97621e-10) (3020, 1.76447e-08) (3024, -4.65947e-06) (3025, 1.76447e-08) (3036, 3.97621e-10)
row 3025: (3013, 3.97621e-10) (3021, 1.60208e-08) (3024, 9.78781e-09) (3025, -4.65816e-06) (3026, 8.17212e-09) (3037, 3.97621e-10)
row 3026: (3014, 3.97621e-10) (3022, 1.60208e-08) (3025, 8.17212e-09) (3026, -4.65816e-06) (3027, 9.78781e-09) (3038, 3.97621e-10)
row 3027: (3015, 3.97621e-10) (3023, 1.76447e-08) (3026, 1.76447e-08) (3027, -4.65947e-06) (3039, 3.97621e-10)
row 3028: (1398, 7.44721e-09) (3016, 3.97624e-10) (3028, -4.65578e-06) (3029, 1.60209e-08) (3032, 8.17218e-09) (3040, 3.97624e-10)
row 3029: (1885, 8.24788e-09) (3017, 3.97623e-10) (3028, 1.01729e-08) (3029, -4.65172e-06) (3030, 4.5806e-09) (3033, 4.5806e-09) (3041, 3.97623e-10)
row 3030: (1886, 8.24788e-09) (3018, 3.97623e-10) (3029, 4.5806e-09) (3030, -4.65172e-06) (3031, 1.01729e-08) (3034, 4.5806e-09) (3042, 3.97623e-10)
row 3031: (1887, 7.44721e-09) (3019, 3.97624e-10) (3030, 1.60209e-08) (3031, -4.65578e-06) (3035, 8.17218e-09) (3043, 3.97624e-10)
row 3032: (3020, 3.97624e-10) (3028, 8.17218e-09) (3032, -4.65812e-06) (3033, 1.60209e-08) (3036, 9.78788e-09) (3044, 3.97624e-10)
row 3033: (3021, 3.97623e-10) (3029, 4.5806e-09) (3032, 1.01729e-08) (3033, -4.65364e-06) (3034, 4.5806e-09) (3037, 1.01729e-08) (3045, 3.97623e-10)
row 3034: (3022, 3.97623e-10) (3030, 4.5806e-09) (3033, 4.5806e-09) (3034, -4.65364e-06) (3035, 1.01729e-08) (3038, 1.01729e-08) (3046, 3.97623e-10)
row 3035: (3023, 3.97624e-10) (3031, 8.17218e-09) (3034, 1.60209e-08) (3035, -4.65812e-06) (3039, 9.78788e-09) (3047, 3.97624e-10)
row 3036: (3024, 3.97624e-10) (3032, 1.76448e-08) (3036, -4.65942e-06) (3037, 1.76448e-08) (3048, 3.97624e-10)
row 3037: (3025, 3.97624e-10) (3033, 1.60209e-08) (3036, 9.78788e-09) (3037, -4.65812e-06) (3038, 8.17218e-09) (3049, 3.97624e-10)
row 3038: (3026, 3.97624e-10) (3034, 1.60209e-08) (3037, 8.17218e-09) (3038, -4.65812e-06) (3039, 9.78788e-09) (3050, 3.97624e-10)
row 3039: (3027, 3.97624e-10) (3035, 1.76448e-08) (3038, 1.76448e-08) (3039, -4.65942e-06) (3051, 3.97624e-10)
row 3040: (1413, 7.44726e-09) (3028, 3.97627e-10) (3040, -4.65573e-06) (3041, 1.6021e-08) (3044, 8.17224e-09) (3052, 3.97627e-10)
row 3041: (1894, 8.24794e-09) (3029, 3.97626e-10) (3040, 1.01729e-08) (3041, -4.65167e-06) (3042, 4.58064e-09) (3045, 4.58064e-09) (3053, 3.97626e-10)
row 3042: (1895, 8.24794e-09) (3030, 3.97626e-10) (3041, 4.58064e-09) (3042, -4.65167e-06) (3043, 1.01729e-08) (3046, 4.58064e-09) (3054, 3.97626e-10)
row 3043: (1896, 7.44726e-09) (3031, 3.97627e-10) (3042, 1.6021e-08) (3043, -4.65573e-06) (3047, 8.17224e-09) (3055, 3.97627e-10)
row 3044: (3032, 3.97627e-10) (3040, 8.17224e-09) (3044, -4.65807e-06) (3045, 1.6021e-08) (3048, 9.78796e-09) (3056, 3.97627e-10)
row 3045: (3033, 3.97626e-10) (3041, 4.58064e-09) (3044, 1.01729e-08) (3045, -4.65359e-06) (3046, 4.58064e-09) (3049, 1.01729e-08) (3057, 3.97626e-10)
row 3046: (3034, 3.97626e-10) (3042, 4.58064e-09) (3045, 4.58064e-09) (3046, -4.65359e-06) (3047, 1.01729e-08) (3050, 1.01729e-08) (3058, 3.97626e-10)
row 3047: (3035, 3.97627e-10) (3043, 8.17224e-09) (3046, 1.6021e-08) (3047, -4.65807e-06) (3051, 9.78796e-09) (3059, 3.97627e-10)
row 3048: (3036, 3.97627e-10) (3044, 1.76449e-08) (3048, -4.65938e-06) (3049, 1.76449e-08) (3060, 3.97627e-10)
row 3049: (3037, 3.97627e-10) (3045, 1.6021e-08) (3048, 9.78796e-09) (3049, -4.65807e-06) (3050, 8.17224e-09) (3061, 3.97627e-10)
row 3050: (3038, 3.97627e-10) (3046, 1.6021e-08) (3049, 8.17224e-09) (3050, -4.65807e-06) (3051, 9.78796e-09) (3062, 3.97627e-10)
row 3051: (3039, 3.97627e-10) (3047, 1.76449e-08) (3050, 1.76449e-08) (3051, -4.65938e-06) (3063, 3.97627e-10)
row 3052: (1428, 7.44731e-09) (3040, 3.9763e-10) (3052, -4.65582e-06) (3053, 1.60211e-08) (3056, 8.1723e-09) (3064, 5.4007e-10)
row 3053: (1903, 8.248e-09) (3041, 3.97629e-10) (3052, 1.0173e-08) (3053, -4.65176e-06) (3054, 4.58067e-09) (3057, 4.58067e-09) (3065, 5.40069e-10)
row 3054: (1904, 8.248e-09) (3042, 3.97629e-10) (3053, 4.58067e-09) (3054, -4.65176e-06) (3055, 1.0173e-08) (3058, 4.58067e-09) (3066, 5.40069e-10)
row 3055: (1905, 7.44731e-09) (3043, 3.9763e-10) (3054, 1.60211e-08) (3055, -4.65582e-06) (3059, 8.1723e-09) (3067, 5.4007e-10)
row 3056: (3044, 3.9763e-10) (3052, 8.1723e-09) (3056, -4.65816e-06) (3057, 1.60211e-08) (3060, 9.78803e-09) (3068, 5.4007e-10)
row 3057: (3045, 3.97629e-10) (3053, 4.58067e-09) (3056, 1.0173e-08) (3057, -4.65369e-06) (3058, 4.58067e-09) (3061, 1.0173e-08) (3069, 5.40069e-10)
row 3058: (3046, 3.97629e-10) (3054, 4.58067e-09) (3057, 4.58067e-09) (3058, -4.65369e-06) (3059, 1.0173e-08) (3062, 1.0173e-08) (3070, 5.40069e-10)
row 3059: (3047, 3.9763e-10) (3055, 8.1723e-09) (3058, 1.60211e-08) (3059, -4.65816e-06) (3063, 9.78803e-09) (3071, 5.4007e-10)
row 3060: (3048, 3.9763e-10) (3056, 1.7645e-08) (3060, -4.65947e-06) (3061, 1.7645e-08) (3072, 5.4007e-10)
row 3061: (3049, 3.9763e-10) (3057, 1.60211e-08) (3060, 9.78803e-09) (3061, -4.65816e-06) (3062, 8.1723e-09) (3073, 5.4007e-10)
row 3062: (3050, 3.9763e-10) (3058, 1.60211e-08) (3061, 8.1723e-09) (3062, -4.65816e-06) (3063, 9.78803e-09) (3074, 5.4007e-10)
row 3063: (3051, 3.9763e-10) (3059, 1.7645e-08) (3062, 1.7645e-08) (3063, -4.65947e-06) (3075, 5.4007e-10)
row 3064: (1443, 7.44735e-09) (3052, 1.14322e-09) (3064, -4.65715e-06) (3065, 1.60212e-08) (3068, 8.17235e-09) (3076, 1.15732e-09)
row 3065: (1912, 8.24805e-09) (3053, 1.14322e-09) (3064, 1.01731e-08) (3065, -4.65309e-06) (3066, 4.58069e-09) (3069, 4.58069e-09) (3077, 1.15731e-09)
row 3066: (1913, 8.24805e-09) (3054, 1.14322e-09) (3065, 4.58069e-09) (3066, -4.65309e-06) (3067, 1.01731e-08) (3070, 4.58069e-09) (3078, 1.15731e-09)
row 3067: (1914, 7.44735e-09) (3055, 1.14322e-09) (3066, 1.60212e-08) (3067, -4.65715e-06) (3071, 8.17235e-09) (3079, 1.15732e-09)
row 3068: (3056, 1.14322e-09) (3064, 8.17235e-09) (3068, -4.65949e-06) (3069, 1.60212e-08) (3072, 9.78808e-09) (3080, 1.15732e-09)
row 3069: (3057, 1.14322e-09) (3065, 4.58069e-09) (3068, 1.01731e-08) (3069, -4.65502e-06) (3070, 4.58069e-09) (3073, 1.01731e-08) (3081, 1.15731e-09)
row 3070: (3058, 1.14322e-09) (3066, 4.58069e-09) (3069, 4.58069e-09) (3070, -4.65502e-06) (3071, 1.01731e-08) (3074, 1.01731e-08) (3082, 1.15731e-09)
row 3071: (3059, 1.14322e-09) (3067, 8.17235e-09) (3070, 1.60212e-08) (3071, -4.65949e-06) (3075, 9.78808e-09) (3083, 1.15732e-09)
row 3072: (3060, 1.14323e-09) (3068, 1.76451e-08) (3072, -4.6608e-06) (3073, 1.76451e-08) (3084, 1.15732e-09)
row 3073: (3061, 1.14322e-09) (3069, 1.60212e-08) (3072, 9.78808e-09) (3073, -4.65949e-06) (3074, 8.17235e-09) (3085, 1.15732e-09)
row 3074: (3062, 1.14322e-09) (3070, 1.60212e-08) (3073, 8.17235e-09) (3074, -4.65949e-06) (3075, 9.78808e-09) (3086, 1.15732e-09)
row 3075: (3063, 1.14323e-09) (3071, 1.76451e-08) (3074, 1.76451e-08) (3075, -4.6608e-06) (3087, 1.15732e-09)
row 3076: (1458, 7.44739e-09) (3064, 5.56658e-10) (3076, -4.65578e-06) (3077, 1.60213e-08) (3080, 8.17239e-09) (3088, 4.12202e-10)
row 3077: (1921, 8.24809e-09) (3065, 5.56657e-10) (3076, 1.01731e-08) (3077, -4.65173e-06) (3078, 4.58072e-09) (3081, 4.58072e-09) (3089, 4.12201e-10)
row 3078: (1922, 8.24809e-09) (3066, 5.56657e-10) (3077, 4.58072e-09) (3078, -4.65173e-06) (3079, 1.01731e-08) (3082, 4.58072e-09) (3090, 4.12201e-10)
row 3079: (1923, 7.44739e-09) (3067, 5.56658e-10) (3078, 1.60213e-08) (3079, -4.65578e-06) (3083, 8.17239e-09) (3091, 4.12202e-10)
row 3080: (3068, 5.56658e-10) (3076, 8.17239e-09) (3080, -4.65812e-06) (3081, 1.60213e-08) (3084, 9.78813e-09) (3092, 4.12202e-10)
row 3081: (3069, 5.56657e-10) (3077, 4.58072e-09) (3080, 1.01731e-08) (3081, -4.65365e-06) (3082, 4.58072e-09) (3085, 1.01731e-08) (3093, 4.12201e-10)
row 3082: (3070, 5.56657e-10) (3078, 4.58072e-09) (3081, 4.58072e-09) (3082, -4.65365e-06) (3083, 1.01731e-08) (3086, 1.01731e-08) (3094, 4.12201e-10)
row 3083: (3071, 5.56658e-10) (3079, 8.17239e-09) (3082, 1.60213e-08) (3083, -4.65812e-06) (3087, 9.78813e-09) (3095, 4.12202e-10)
row 3084: (3072, 5.56659e-10) (3080, 1.76452e-08) (3084, -4.65943e-06) (3085, 1.76452e-08) (3096, 4.12202e-10)
row 3085: (3073, 5.56658e-10) (3081, 1.60213e-08) (3084, 9.78813e-09) (3085, -4.65812e-06) (3086, 8.17239e-09) (3097, 4.12202e-10)
row 3086: (3074, 5.56658e-10) (3082, 1.60213e-08) (3085, 8.17239e-09) (3086, -4.65812e-06) (3087, 9.78813e-09) (3098, 4.12202e-10)
row 3087: (3075, 5.56659e-10) (3083, 1.76452e-08) (3086, 1.76452e-08) (3087, -4.65943e-06) (3099, 4.12202e-10)
row 3088: (1473, 7.44745e-09) (3076, 4.12205e-10) (3088, -4.65559e-06) (3089, 1.60214e-08) (3092, 8.17245e-09) (3100, 4.12205e-10)
row 3089: (1930, 8.24815e-09) (3077, 4.12204e-10) (3088, 1.01732e-08) (3089, -4.65153e-06) (3090, 4.58075e-09) (3093, 4.58075e-09) (3101, 4.12204e-10)
row 3090: (1931, 8.24815e-09) (3078, 4.12204e-10) (3089, 4.58075e-09) (3090, -4.65153e-06) (3091, 1.01732e-08) (3094, 4.58075e-09) (3102, 4.12204e-10)
row 3091: (1932, 7.44745e-09) (3079, 4.12205e-10) (3090, 1.60214e-08) (3091, -4.65559e-06) (3095, 8.17245e-09) (3103, 4.12205e-10)
row 3092: (3080, 4.12205e-10) (3088, 8.17245e-09) (3092, -4.65793e-06) (3093, 1.60214e-08) (3096, 9.7882e-09) (3104, 4.12205e-10)
row 3093: (3081, 4.12204e-10) (3089, 4.58075e-09) (3092, 1.01732e-08) (3093, -4.65346e-06) (3094, 4.58075e-09) (3097, 1.01732e-08) (3105, 4.12204e-10)
row 3094: (3082, 4.12204e-10) (3090, 4.58075e-09) (3093, 4.58075e-09) (3094, -4.65346e-06) (3095, 1.01732e-08) (3098, 1.01732e-08) (3106, 4.12204e-10)
row 3095: (3083, 4.12205e-10) (3091, 8.17245e-09) (3094, 1.60214e-08) (3095, -4.65793e-06) (3099, 9.7882e-09) (3107, 4.12205e-10)
row 3096: (3084, 4.12205e-10) (3092, 1.76454e-08) (3096, -4.65924e-06) (3097, 1.76454e-08) (3108, 4.12205e-10)
row 3097: (3085, 4.12205e-10) (3093, 1.60214e-08) (3096, 9.7882e-09) (3097, -4.65793e-06) (3098, 8.17245e-09) (3109, 4.12205e-10)
row 3098: (3086, 4.12205e-10) (3094, 1.60214e-08) (3097, 8.17245e-09) (3098, -4.65793e-06) (3099, 9.7882e-09) (3110, 4.12205e-10)
row 3099: (3087, 4.12205e-10) (3095, 1.76454e-08) (3098, 1.76454e-08) (3099, -4.65924e-06) (3111, 4.12205e-10)
row 3100: (1488, 7.4475e-09) (3088, 4.12208e-10) (3100, -4.65555e-06) (3101, 1.60215e-08) (3104, 8.17251e-09) (3112, 4.12208e-10)
row 3101: (1939, 8.24821e-09) (3089, 4.12207e-10) (3100, 1.01733e-08) (3101, -4.65149e-06) (3102, 4.58078e-09) (3105, 4.58078e-09) (3113, 4.12207e-10)
row 3102: (1940, 8.24821e-09) (3090, 4.12207e-10) (3101, 4.58078e-09) (3102, -4.65149e-06) (3103, 1.01733e-08) (3106, 4.58078e-09) (3114, 4.12207e-10)
row 3103: (1941, 7.4475e-09) (3091, 4.12208e-10) (3102, 1.60215e-08) (3103, -4.65555e-06) (3107, 8.17251e-09) (3115, 4.12208e-10)
row 3104: (3092, 4.12208e-10) (3100, 8.17251e-09) (3104, -4.65789e-06) (3105, 1.60215e-08) (3108, 9.78827e-09) (3116, 4.12208e-10)
row 3105: (3093, 4.12207e-10) (3101, 4.58078e-09) (3104, 1.01733e-08) (3105, -4.65341e-06) (3106, 4.58078e-09) (3109, 1.01733e-08) (3117, 4.12207e-10)
row 3106: (3094, 4.12207e-10) (3102, 4.58078e-09) (3105, 4.58078e-09) (3106, -4.65341e-06) (3107, 1.01733e-08) (3110, 1.01733e-08) (3118, 4.12207e-10)
row 3107: (3095, 4.12208e-10) (3103, 8.17251e-09) (3106, 1.60215e-08) (3107, -4.65789e-06) (3111, 9.78827e-09) (3119, 4.12208e-10)
row 3108: (3096, 4.12208e-10) (3104, 1.76455e-08) (3108, -4.6592e-06) (3109, 1.76455e-08) (3120, 4.12208e-10)
row 3109: (3097, 4.12208e-10) (3105, 1.60215e-08) (3108, 9.78827e-09) (3109, -4.65789e-06) (3110, 8.17251e-09) (3121, 4.12208e-10)
row 3110: (3098, 4.12208e-10) (3106, 1.60215e-08) (3109, 8.17251e-09) (3110, -4.65789e-06) (3111, 9.78827e-09) (3122, 4.12208e-10)
row 3111: (3099, 4.12208e-10) (3107, 1.76455e-08) (3110, 1.76455e-08) (3111, -4.6592e-06) (3123, 4.12208e-10)
row 3112: (1503, 7.44755e-09) (3100, 4.12211e-10) (3112, -4.6555e-06) (3113, 1.60216e-08) (3116, 8.17257e-09) (3124, 4.12211e-10)
row 3113: (1948, 8.24827e-09) (3101, 4.1221e-10) (3112, 1.01733e-08) (3113, -4.65144e-06) (3114, 4.58082e-09) (3117, 4.58082e-09) (3125, 4.1221e-10)
row 3114: (1949, 8.24827e-09) (3102, 4.1221e-10) (3113, 4.58082e-09) (3114, -4.65144e-06) (3115, 1.01733e-08) (3118, 4.58082e-09) (3126, 4.1221e-10)
row 3115: (1950, 7.44755e-09) (3103, 4.12211e-10) (3114, 1.60216e-08) (3115, -4.6555e-06) (3119, 8.17257e-09) (3127, 4.12211e-10)
row 3116: (3104, 4.12211e-10) (3112, 8.17257e-09) (3116, -4.65784e-06) (3117, 1.60216e-08) (3120, 9.78834e-09) (3128, 4.12211e-10)
row 3117: (3105, 4.1221e-10) (3113, 4.58082e-09) (3116, 1.01733e-08) (3117, -4.65337e-06) (3118, 4.58082e-09) (3121, 1.01733e-08) (3129, 4.1221e-10)
row 3118: (3106, 4.1221e-10) (3114, 4.58082e-09) (3117, 4.58082e-09) (3118, -4.65337e-06) (3119, 1.01733e-08) (3122, 1.01733e-08) (3130, 4.1221e-10)
row 3119: (3107, 4.12211e-10) (3115, 8.17257e-09) (3118, 1.60216e-08) (3119, -4.65784e-06) (3123, 9.78834e-09) (3131, 4.12211e-10)
row 3120: (3108, 4.12211e-10) (3116, 1.76456e-08) (3120, -4.65915e-06) (3121, 1.76456e-08) (3132, 4.12211e-10)
row 3121: (3109, 4.12211e-10) (3117, 1.60216e-08) (3120, 9.78834e-09) (3121, -4.65784e-06) (3122, 8.17257e-09) (3133, 4.12211e-10)
row 3122: (3110, 4.12211e-10) (3118, 1.60216e-08) (3121, 8.17257e-09) (3122, -4.65784e-06) (3123, 9.78834e-09) (3134, 4.12211e-10)
row 3123: (3111, 4.12211e-10) (3119, 1.76456e-08) (3122, 1.76456e-08) (3123, -4.65915e-06) (3135, 4.12211e-10)
row 3124: (1518, 7.44761e-09) (3112, 4.12214e-10) (3124, -4.65545e-06) (3125, 1.60218e-08) (3128, 8.17263e-09)
row 3125: (1957, 8.24833e-09) (3113, 4.12213e-10) (3124, 1.01734e-08) (3125, -4.65139e-06) (3126, 4.58085e-09) (3129, 4.58085e-09)
row 3126: (1958, 8.24833e-09) (3114, 4.12213e-10) (3125, 4.58085e-09) (3126, -4.65139e-06) (3127, 1.01734e-08) (3130, 4.58085e-09)
row 3127: (1959, 7.44761e-09) (3115, 4.12214e-10) (3126, 1.60218e-08) (3127, -4.65545e-06) (3131, 8.17263e-09)
row 3128: (3116, 4.12214e-10) (3124, 8.17263e-09) (3128, -4.65779e-06) (3129, 1.60218e-08) (3132, 9.78841e-09)
row 3129: (3117, 4.12213e-10) (3125, 4.58085e-09) (3128, 1.01734e-08) (3129, -4.65332e-06) (3130, 4.58085e-09) (3133, 1.01734e-08)
row 3130: (3118, 4.12213e-10) (3126, 4.58085e-09) (3129, 4.58085e-09) (3130, -4.65332e-06) (3131, 1.01734e-08) (3134, 1.01734e-08)
row 3131: (3119, 4.12214e-10) (3127, 8.17263e-09) (3130, 1.60218e-08) (3131, -4.65779e-06) (3135, 9.78841e-09)
row 3132: (3120, 4.12214e-10) (3128, 1.76457e-08) (3132, -4.6591e-06) (3133, 1.76457e-08)
row 3133: (3121, 4.12214e-10) (3129, 1.60218e-08) (3132, 9.78841e-09) (3133, -4.65779e-06) (3134, 8.17263e-09)
row 3134: (3122, 4.12214e-10) (3130, 1.60218e-08) (3133, 8.17263e-09) (3134, -4.65779e-06) (3135, 9.78841e-09)
row 3135: (3123, 4.12214e-10) (3131, 1.76457e-08) (3134, 1.76457e-08) (3135, -4.6591e-06)
Vec Object: 5 MPI processes
type: mpi
Process [0]
-3.74028e-08
-7.94269e-08
-7.94269e-08
-3.74028e-08
-7.94269e-08
-8.20859e-08
-8.20859e-08
-7.94269e-08
-7.94269e-08
-8.20859e-08
-8.20859e-08
-7.94269e-08
-3.74067e-08
-7.94283e-08
-7.94283e-08
-3.74067e-08
-3.23508e-07
-3.64162e-07
-3.64162e-07
-3.23508e-07
-3.64162e-07
-3.61683e-07
-3.61683e-07
-3.64162e-07
-3.64162e-07
-3.61683e-07
-3.61683e-07
-3.64162e-07
-3.23508e-07
-3.64161e-07
-3.64161e-07
-3.23508e-07
-3.24837e-07
-3.65491e-07
-3.65491e-07
-3.24837e-07
-3.65491e-07
-3.63013e-07
-3.63013e-07
-3.65491e-07
-3.65491e-07
-3.63013e-07
-3.63013e-07
-3.65491e-07
-3.24837e-07
-3.65491e-07
-3.65491e-07
-3.24837e-07
-3.24906e-07
-3.65561e-07
-3.65561e-07
-3.24906e-07
-3.65561e-07
-3.63082e-07
-3.63082e-07
-3.65561e-07
-3.65561e-07
-3.63082e-07
-3.63082e-07
-3.65561e-07
-3.24907e-07
-3.65561e-07
-3.65561e-07
-3.24907e-07
-3.24976e-07
-3.65631e-07
-3.65631e-07
-3.24976e-07
-3.65631e-07
-3.63152e-07
-3.63152e-07
-3.65631e-07
-3.65631e-07
-3.63152e-07
-3.63152e-07
-3.65631e-07
-3.24976e-07
-3.65631e-07
-3.65631e-07
-3.24976e-07
-3.25045e-07
-3.65702e-07
-3.65702e-07
-3.25045e-07
-3.65702e-07
-3.63223e-07
-3.63223e-07
-3.65702e-07
-3.65702e-07
-3.63223e-07
-3.63223e-07
-3.65702e-07
-3.25046e-07
-3.65701e-07
-3.65701e-07
-3.25046e-07
-3.25115e-07
-3.65771e-07
-3.65771e-07
-3.25115e-07
-3.65771e-07
-3.63292e-07
-3.63292e-07
-3.65771e-07
-3.65771e-07
-3.63292e-07
-3.63292e-07
-3.65771e-07
-3.25115e-07
-3.65771e-07
-3.65771e-07
-3.25115e-07
-3.99007e-07
-4.39665e-07
-4.39665e-07
-3.99007e-07
-4.39665e-07
-4.37185e-07
-4.37185e-07
-4.39665e-07
-4.39665e-07
-4.37185e-07
-4.37185e-07
-4.39665e-07
-3.99008e-07
-4.39664e-07
-4.39664e-07
-3.99008e-07
-1.68882e-07
-2.0954e-07
-2.0954e-07
-1.68882e-07
-2.0954e-07
-2.07061e-07
-2.07061e-07
-2.0954e-07
-2.0954e-07
-2.07061e-07
-2.07061e-07
-2.0954e-07
-1.68882e-07
-2.09539e-07
-2.09539e-07
-1.68882e-07
-3.24045e-07
-3.64703e-07
-3.64703e-07
-3.24045e-07
-3.64703e-07
-3.62224e-07
-3.62224e-07
-3.64703e-07
-3.64703e-07
-3.62224e-07
-3.62224e-07
-3.64703e-07
-3.24045e-07
-3.64703e-07
-3.64703e-07
-3.24045e-07
-3.25354e-07
-3.66012e-07
-3.66012e-07
-3.25354e-07
-3.66012e-07
-3.63533e-07
-3.63533e-07
-3.66012e-07
-3.66012e-07
-3.63533e-07
-3.63533e-07
-3.66012e-07
-3.25354e-07
-3.66012e-07
-3.66012e-07
-3.25354e-07
-3.25422e-07
-3.66081e-07
-3.66081e-07
-3.25422e-07
-3.66081e-07
-3.63602e-07
-3.63602e-07
-3.66081e-07
-3.66081e-07
-3.63602e-07
-3.63602e-07
-3.66081e-07
-3.25422e-07
-3.66081e-07
-3.66081e-07
-3.25422e-07
-3.2549e-07
-3.6615e-07
-3.6615e-07
-3.2549e-07
-3.6615e-07
-3.63671e-07
-3.63671e-07
-3.6615e-07
-3.6615e-07
-3.63671e-07
-3.63671e-07
-3.6615e-07
-3.25491e-07
-3.66149e-07
-3.66149e-07
-3.25491e-07
-3.25559e-07
-3.66218e-07
-3.66218e-07
-3.25559e-07
-3.66218e-07
-3.63739e-07
-3.63739e-07
-3.66218e-07
-3.66218e-07
-3.63739e-07
-3.63739e-07
-3.66218e-07
-3.25559e-07
-3.66218e-07
-3.66218e-07
-3.25559e-07
-4.01693e-07
-4.42354e-07
-4.42354e-07
-4.01693e-07
-4.42354e-07
-4.39874e-07
-4.39874e-07
-4.42354e-07
-4.42354e-07
-4.39874e-07
-4.39874e-07
-4.42354e-07
-4.01694e-07
-4.42354e-07
-4.42354e-07
-4.01694e-07
-1.67285e-07
-2.07945e-07
-2.07945e-07
-1.67285e-07
-2.07945e-07
-2.05467e-07
-2.05467e-07
-2.07945e-07
-2.07945e-07
-2.05467e-07
-2.05467e-07
-2.07945e-07
-1.67285e-07
-2.07945e-07
-2.07945e-07
-1.67285e-07
-3.24487e-07
-3.65148e-07
-3.65148e-07
-3.24487e-07
-3.65148e-07
-3.62669e-07
-3.62669e-07
-3.65148e-07
-3.65148e-07
-3.62669e-07
-3.62669e-07
-3.65148e-07
-3.24488e-07
-3.65148e-07
-3.65148e-07
-3.24488e-07
-3.25796e-07
-3.66458e-07
-3.66458e-07
-3.25796e-07
-3.66458e-07
-3.63978e-07
-3.63978e-07
-3.66458e-07
-3.66458e-07
-3.63978e-07
-3.63978e-07
-3.66458e-07
-3.25796e-07
-3.66457e-07
-3.66457e-07
-3.25796e-07
-3.25864e-07
-3.66527e-07
-3.66527e-07
-3.25864e-07
-3.66527e-07
-3.64047e-07
-3.64047e-07
-3.66527e-07
-3.66527e-07
-3.64047e-07
-3.64047e-07
-3.66527e-07
-3.25865e-07
-3.66526e-07
-3.66526e-07
-3.25865e-07
-3.25933e-07
-3.66595e-07
-3.66595e-07
-3.25933e-07
-3.66595e-07
-3.64116e-07
-3.64116e-07
-3.66595e-07
-3.66595e-07
-3.64116e-07
-3.64116e-07
-3.66595e-07
-3.25933e-07
-3.66595e-07
-3.66595e-07
-3.25933e-07
-3.26001e-07
-3.66664e-07
-3.66664e-07
-3.26001e-07
-3.66664e-07
-3.64185e-07
-3.64185e-07
-3.66664e-07
-3.66664e-07
-3.64185e-07
-3.64185e-07
-3.66664e-07
-3.26002e-07
-3.66664e-07
-3.66664e-07
-3.26002e-07
-4.02138e-07
-4.42802e-07
-4.42802e-07
-4.02138e-07
-4.42802e-07
-4.40322e-07
-4.40322e-07
-4.42802e-07
-4.42802e-07
-4.40322e-07
-4.40322e-07
-4.42802e-07
-4.02139e-07
-4.42802e-07
-4.42802e-07
-4.02139e-07
-1.67723e-07
-2.08387e-07
-2.08387e-07
-1.67723e-07
-2.08387e-07
-2.05908e-07
-2.05908e-07
-2.08387e-07
-2.08387e-07
-2.05908e-07
-2.05908e-07
-2.08387e-07
-1.67723e-07
-2.08387e-07
-2.08387e-07
-1.67723e-07
-3.2493e-07
-3.65595e-07
-3.65595e-07
-3.2493e-07
-3.65595e-07
-3.63115e-07
-3.63115e-07
-3.65595e-07
-3.65595e-07
-3.63115e-07
-3.63115e-07
-3.65595e-07
-3.24931e-07
-3.65594e-07
-3.65594e-07
-3.24931e-07
-3.26239e-07
-3.66904e-07
-3.66904e-07
-3.26239e-07
-3.66904e-07
-3.64424e-07
-3.64424e-07
-3.66904e-07
-3.66904e-07
-3.64424e-07
-3.64424e-07
-3.66904e-07
-3.26239e-07
-3.66904e-07
-3.66904e-07
-3.26239e-07
-3.26308e-07
-3.66973e-07
-3.66973e-07
-3.26308e-07
-3.66973e-07
-3.64493e-07
-3.64493e-07
-3.66973e-07
-3.66973e-07
-3.64493e-07
-3.64493e-07
-3.66973e-07
-3.26308e-07
-3.66973e-07
-3.66973e-07
-3.26308e-07
-3.26376e-07
-3.67042e-07
-3.67042e-07
-3.26376e-07
-3.67042e-07
-3.64562e-07
-3.64562e-07
-3.67042e-07
-3.67042e-07
-3.64562e-07
-3.64562e-07
-3.67042e-07
-3.26376e-07
-3.67042e-07
-3.67042e-07
-3.26376e-07
-3.26445e-07
-3.67111e-07
-3.67111e-07
-3.26445e-07
-3.67111e-07
-3.64631e-07
-3.64631e-07
-3.67111e-07
-3.67111e-07
-3.64631e-07
-3.64631e-07
-3.67111e-07
-3.26445e-07
-3.67111e-07
-3.67111e-07
-3.26445e-07
-4.02584e-07
-4.4325e-07
-4.4325e-07
-4.02584e-07
-4.4325e-07
-4.40771e-07
-4.40771e-07
-4.4325e-07
-4.4325e-07
-4.40771e-07
-4.40771e-07
-4.4325e-07
-4.02584e-07
-4.4325e-07
-4.4325e-07
-4.02584e-07
-1.68161e-07
-2.08829e-07
-2.08829e-07
-1.68161e-07
-2.08829e-07
-2.06349e-07
-2.06349e-07
-2.08829e-07
-2.08829e-07
-2.06349e-07
-2.06349e-07
-2.08829e-07
-1.68162e-07
-2.08828e-07
-2.08828e-07
-1.68162e-07
-3.25374e-07
-3.66041e-07
-3.66041e-07
-3.25374e-07
-3.66041e-07
-3.63562e-07
-3.63562e-07
-3.66041e-07
-3.66041e-07
-3.63562e-07
-3.63562e-07
-3.66041e-07
-3.25374e-07
-3.66041e-07
-3.66041e-07
-3.25374e-07
-3.26683e-07
-3.6735e-07
-3.6735e-07
-3.26683e-07
-3.6735e-07
-3.64871e-07
-3.64871e-07
-3.6735e-07
-3.6735e-07
-3.64871e-07
-3.64871e-07
-3.6735e-07
-3.26683e-07
-3.6735e-07
-3.6735e-07
-3.26683e-07
-3.26751e-07
-3.6742e-07
-3.6742e-07
-3.26751e-07
-3.6742e-07
-3.6494e-07
-3.6494e-07
-3.6742e-07
-3.6742e-07
-3.6494e-07
-3.6494e-07
-3.6742e-07
-3.26752e-07
-3.67419e-07
-3.67419e-07
-3.26752e-07
-3.2682e-07
-3.67489e-07
-3.67489e-07
-3.2682e-07
-3.67489e-07
-3.65009e-07
-3.65009e-07
-3.67489e-07
-3.67489e-07
-3.65009e-07
-3.65009e-07
-3.67489e-07
-3.2682e-07
-3.67489e-07
-3.67489e-07
-3.2682e-07
-3.26888e-07
-3.67558e-07
-3.67558e-07
-3.26888e-07
-3.67558e-07
-3.65078e-07
-3.65078e-07
-3.67558e-07
-3.67558e-07
-3.65078e-07
-3.65078e-07
-3.67558e-07
-3.26889e-07
-3.67558e-07
-3.67558e-07
-3.26889e-07
-4.0303e-07
-4.437e-07
-4.437e-07
-4.0303e-07
-4.437e-07
-4.4122e-07
-4.4122e-07
-4.437e-07
-4.437e-07
-4.4122e-07
-4.4122e-07
-4.437e-07
-4.0303e-07
-4.437e-07
-4.437e-07
-4.0303e-07
-1.68601e-07
-2.09271e-07
-2.09271e-07
-1.68601e-07
-2.09271e-07
-2.06791e-07
-2.06791e-07
-2.09271e-07
-2.09271e-07
-2.06791e-07
-2.06791e-07
-2.09271e-07
-1.68601e-07
-2.09271e-07
-2.09271e-07
-1.68601e-07
-3.25818e-07
-3.66489e-07
-3.66489e-07
-3.25818e-07
-3.66489e-07
-3.64009e-07
-3.64009e-07
-3.66489e-07
-3.66489e-07
-3.64009e-07
-3.64009e-07
-3.66489e-07
-3.25818e-07
-3.66488e-07
-3.66488e-07
-3.25818e-07
-3.27127e-07
-3.67798e-07
-3.67798e-07
-3.27127e-07
-3.67798e-07
-3.65318e-07
-3.65318e-07
-3.67798e-07
-3.67798e-07
-3.65318e-07
-3.65318e-07
-3.67798e-07
-3.27127e-07
-3.67798e-07
-3.67798e-07
-3.27127e-07
-3.27195e-07
-3.67867e-07
-3.67867e-07
-3.27195e-07
-3.67867e-07
-3.65387e-07
-3.65387e-07
-3.67867e-07
-3.67867e-07
-3.65387e-07
-3.65387e-07
-3.67867e-07
-3.27196e-07
-3.67867e-07
-3.67867e-07
-3.27196e-07
-3.27264e-07
-3.67936e-07
-3.67936e-07
-3.27264e-07
-3.67936e-07
-3.65456e-07
-3.65456e-07
-3.67936e-07
-3.67936e-07
-3.65456e-07
-3.65456e-07
-3.67936e-07
-3.27264e-07
-3.67936e-07
-3.67936e-07
-3.27264e-07
-3.27333e-07
-3.68005e-07
-3.68005e-07
-3.27333e-07
-3.68005e-07
-3.65525e-07
-3.65525e-07
-3.68005e-07
-3.68005e-07
-3.65525e-07
-3.65525e-07
-3.68005e-07
-3.27333e-07
-3.68005e-07
-3.68005e-07
-3.27333e-07
-4.03476e-07
-4.4415e-07
-4.4415e-07
-4.03476e-07
-4.4415e-07
-4.41669e-07
-4.41669e-07
-4.4415e-07
-4.4415e-07
-4.41669e-07
-4.41669e-07
-4.4415e-07
-4.03477e-07
-4.44149e-07
-4.44149e-07
-4.03477e-07
-1.6907e-07
-2.09744e-07
-2.09744e-07
-1.6907e-07
-2.09744e-07
-2.07264e-07
-2.07264e-07
-2.09744e-07
-2.09744e-07
-2.07264e-07
-2.07264e-07
-2.09744e-07
-1.6907e-07
-2.09743e-07
-2.09743e-07
-1.6907e-07
-3.26282e-07
-3.66956e-07
-3.66956e-07
-3.26282e-07
-3.66956e-07
-3.64476e-07
-3.64476e-07
-3.66956e-07
-3.66956e-07
-3.64476e-07
-3.64476e-07
-3.66956e-07
-3.26283e-07
-3.66956e-07
-3.66956e-07
-3.26283e-07
-3.27569e-07
-3.68244e-07
-3.68244e-07
-3.27569e-07
-3.68244e-07
-3.65764e-07
-3.65764e-07
-3.68244e-07
-3.68244e-07
-3.65764e-07
-3.65764e-07
-3.68244e-07
-3.2757e-07
-3.68244e-07
-3.68244e-07
-3.2757e-07
-3.27637e-07
-3.68312e-07
-3.68312e-07
-3.27637e-07
-3.68312e-07
-3.65832e-07
-3.65832e-07
-3.68312e-07
-3.68312e-07
-3.65832e-07
-3.65832e-07
-3.68312e-07
-3.27637e-07
-3.68312e-07
-3.68312e-07
-3.27637e-07
-3.27705e-07
-3.6838e-07
-3.6838e-07
-3.27705e-07
-3.6838e-07
-3.659e-07
-3.659e-07
-3.6838e-07
-3.6838e-07
-3.659e-07
-3.659e-07
-3.6838e-07
-3.27705e-07
-3.6838e-07
-3.6838e-07
-3.27705e-07
-3.31778e-07
-3.72454e-07
-3.72454e-07
-3.31778e-07
-3.72454e-07
-3.69974e-07
-3.69974e-07
-3.72454e-07
-3.72454e-07
-3.69974e-07
-3.69974e-07
-3.72454e-07
-3.31778e-07
-3.72454e-07
-3.72454e-07
-3.31778e-07
Process [1]
-3.74028e-08
-7.94269e-08
-7.94269e-08
-7.94269e-08
-8.20859e-08
-8.20859e-08
-7.94283e-08
-7.94269e-08
-8.20859e-08
-8.20859e-08
-7.94283e-08
-3.74028e-08
-7.94269e-08
-7.94269e-08
-3.74067e-08
-3.23508e-07
-3.64162e-07
-3.64162e-07
-3.64162e-07
-3.61683e-07
-3.61683e-07
-3.64161e-07
-3.64162e-07
-3.61683e-07
-3.61683e-07
-3.64161e-07
-3.23508e-07
-3.64162e-07
-3.64162e-07
-3.23508e-07
-3.24837e-07
-3.65491e-07
-3.65491e-07
-3.65491e-07
-3.63013e-07
-3.63013e-07
-3.65491e-07
-3.65491e-07
-3.63013e-07
-3.63013e-07
-3.65491e-07
-3.24837e-07
-3.65491e-07
-3.65491e-07
-3.24837e-07
-3.24906e-07
-3.65561e-07
-3.65561e-07
-3.65561e-07
-3.63082e-07
-3.63082e-07
-3.65561e-07
-3.65561e-07
-3.63082e-07
-3.63082e-07
-3.65561e-07
-3.24906e-07
-3.65561e-07
-3.65561e-07
-3.24907e-07
-3.24976e-07
-3.65631e-07
-3.65631e-07
-3.65631e-07
-3.63152e-07
-3.63152e-07
-3.65631e-07
-3.65631e-07
-3.63152e-07
-3.63152e-07
-3.65631e-07
-3.24976e-07
-3.65631e-07
-3.65631e-07
-3.24976e-07
-3.25045e-07
-3.65702e-07
-3.65702e-07
-3.65702e-07
-3.63223e-07
-3.63223e-07
-3.65701e-07
-3.65702e-07
-3.63223e-07
-3.63223e-07
-3.65701e-07
-3.25045e-07
-3.65702e-07
-3.65702e-07
-3.25046e-07
-3.25115e-07
-3.65771e-07
-3.65771e-07
-3.65771e-07
-3.63292e-07
-3.63292e-07
-3.65771e-07
-3.65771e-07
-3.63292e-07
-3.63292e-07
-3.65771e-07
-3.25115e-07
-3.65771e-07
-3.65771e-07
-3.25115e-07
-3.99007e-07
-4.39665e-07
-4.39665e-07
-4.39665e-07
-4.37185e-07
-4.37185e-07
-4.39664e-07
-4.39665e-07
-4.37185e-07
-4.37185e-07
-4.39664e-07
-3.99007e-07
-4.39665e-07
-4.39665e-07
-3.99008e-07
-1.68882e-07
-2.0954e-07
-2.0954e-07
-2.0954e-07
-2.07061e-07
-2.07061e-07
-2.09539e-07
-2.0954e-07
-2.07061e-07
-2.07061e-07
-2.09539e-07
-1.68882e-07
-2.0954e-07
-2.0954e-07
-1.68882e-07
-3.24045e-07
-3.64703e-07
-3.64703e-07
-3.64703e-07
-3.62224e-07
-3.62224e-07
-3.64703e-07
-3.64703e-07
-3.62224e-07
-3.62224e-07
-3.64703e-07
-3.24045e-07
-3.64703e-07
-3.64703e-07
-3.24045e-07
-3.25354e-07
-3.66012e-07
-3.66012e-07
-3.66012e-07
-3.63533e-07
-3.63533e-07
-3.66012e-07
-3.66012e-07
-3.63533e-07
-3.63533e-07
-3.66012e-07
-3.25354e-07
-3.66012e-07
-3.66012e-07
-3.25354e-07
-3.25422e-07
-3.66081e-07
-3.66081e-07
-3.66081e-07
-3.63602e-07
-3.63602e-07
-3.66081e-07
-3.66081e-07
-3.63602e-07
-3.63602e-07
-3.66081e-07
-3.25422e-07
-3.66081e-07
-3.66081e-07
-3.25422e-07
-3.2549e-07
-3.6615e-07
-3.6615e-07
-3.6615e-07
-3.63671e-07
-3.63671e-07
-3.66149e-07
-3.6615e-07
-3.63671e-07
-3.63671e-07
-3.66149e-07
-3.2549e-07
-3.6615e-07
-3.6615e-07
-3.25491e-07
-3.25559e-07
-3.66218e-07
-3.66218e-07
-3.66218e-07
-3.63739e-07
-3.63739e-07
-3.66218e-07
-3.66218e-07
-3.63739e-07
-3.63739e-07
-3.66218e-07
-3.25559e-07
-3.66218e-07
-3.66218e-07
-3.25559e-07
-4.01693e-07
-4.42354e-07
-4.42354e-07
-4.42354e-07
-4.39874e-07
-4.39874e-07
-4.42354e-07
-4.42354e-07
-4.39874e-07
-4.39874e-07
-4.42354e-07
-4.01693e-07
-4.42354e-07
-4.42354e-07
-4.01694e-07
-1.67285e-07
-2.07945e-07
-2.07945e-07
-2.07945e-07
-2.05467e-07
-2.05467e-07
-2.07945e-07
-2.07945e-07
-2.05467e-07
-2.05467e-07
-2.07945e-07
-1.67285e-07
-2.07945e-07
-2.07945e-07
-1.67285e-07
-3.24487e-07
-3.65148e-07
-3.65148e-07
-3.65148e-07
-3.62669e-07
-3.62669e-07
-3.65148e-07
-3.65148e-07
-3.62669e-07
-3.62669e-07
-3.65148e-07
-3.24487e-07
-3.65148e-07
-3.65148e-07
-3.24488e-07
-3.25796e-07
-3.66458e-07
-3.66458e-07
-3.66458e-07
-3.63978e-07
-3.63978e-07
-3.66457e-07
-3.66458e-07
-3.63978e-07
-3.63978e-07
-3.66457e-07
-3.25796e-07
-3.66458e-07
-3.66458e-07
-3.25796e-07
-3.25864e-07
-3.66527e-07
-3.66527e-07
-3.66527e-07
-3.64047e-07
-3.64047e-07
-3.66526e-07
-3.66527e-07
-3.64047e-07
-3.64047e-07
-3.66526e-07
-3.25864e-07
-3.66527e-07
-3.66527e-07
-3.25865e-07
-3.25933e-07
-3.66595e-07
-3.66595e-07
-3.66595e-07
-3.64116e-07
-3.64116e-07
-3.66595e-07
-3.66595e-07
-3.64116e-07
-3.64116e-07
-3.66595e-07
-3.25933e-07
-3.66595e-07
-3.66595e-07
-3.25933e-07
-3.26001e-07
-3.66664e-07
-3.66664e-07
-3.66664e-07
-3.64185e-07
-3.64185e-07
-3.66664e-07
-3.66664e-07
-3.64185e-07
-3.64185e-07
-3.66664e-07
-3.26001e-07
-3.66664e-07
-3.66664e-07
-3.26002e-07
-4.02138e-07
-4.42802e-07
-4.42802e-07
-4.42802e-07
-4.40322e-07
-4.40322e-07
-4.42802e-07
-4.42802e-07
-4.40322e-07
-4.40322e-07
-4.42802e-07
-4.02138e-07
-4.42802e-07
-4.42802e-07
-4.02139e-07
-1.67723e-07
-2.08387e-07
-2.08387e-07
-2.08387e-07
-2.05908e-07
-2.05908e-07
-2.08387e-07
-2.08387e-07
-2.05908e-07
-2.05908e-07
-2.08387e-07
-1.67723e-07
-2.08387e-07
-2.08387e-07
-1.67723e-07
-3.2493e-07
-3.65595e-07
-3.65595e-07
-3.65595e-07
-3.63115e-07
-3.63115e-07
-3.65594e-07
-3.65595e-07
-3.63115e-07
-3.63115e-07
-3.65594e-07
-3.2493e-07
-3.65595e-07
-3.65595e-07
-3.24931e-07
-3.26239e-07
-3.66904e-07
-3.66904e-07
-3.66904e-07
-3.64424e-07
-3.64424e-07
-3.66904e-07
-3.66904e-07
-3.64424e-07
-3.64424e-07
-3.66904e-07
-3.26239e-07
-3.66904e-07
-3.66904e-07
-3.26239e-07
-3.26308e-07
-3.66973e-07
-3.66973e-07
-3.66973e-07
-3.64493e-07
-3.64493e-07
-3.66973e-07
-3.66973e-07
-3.64493e-07
-3.64493e-07
-3.66973e-07
-3.26308e-07
-3.66973e-07
-3.66973e-07
-3.26308e-07
-3.26376e-07
-3.67042e-07
-3.67042e-07
-3.67042e-07
-3.64562e-07
-3.64562e-07
-3.67042e-07
-3.67042e-07
-3.64562e-07
-3.64562e-07
-3.67042e-07
-3.26376e-07
-3.67042e-07
-3.67042e-07
-3.26376e-07
-3.26445e-07
-3.67111e-07
-3.67111e-07
-3.67111e-07
-3.64631e-07
-3.64631e-07
-3.67111e-07
-3.67111e-07
-3.64631e-07
-3.64631e-07
-3.67111e-07
-3.26445e-07
-3.67111e-07
-3.67111e-07
-3.26445e-07
-4.02584e-07
-4.4325e-07
-4.4325e-07
-4.4325e-07
-4.40771e-07
-4.40771e-07
-4.4325e-07
-4.4325e-07
-4.40771e-07
-4.40771e-07
-4.4325e-07
-4.02584e-07
-4.4325e-07
-4.4325e-07
-4.02584e-07
-1.68161e-07
-2.08829e-07
-2.08829e-07
-2.08829e-07
-2.06349e-07
-2.06349e-07
-2.08828e-07
-2.08829e-07
-2.06349e-07
-2.06349e-07
-2.08828e-07
-1.68161e-07
-2.08829e-07
-2.08829e-07
-1.68162e-07
-3.25374e-07
-3.66041e-07
-3.66041e-07
-3.66041e-07
-3.63562e-07
-3.63562e-07
-3.66041e-07
-3.66041e-07
-3.63562e-07
-3.63562e-07
-3.66041e-07
-3.25374e-07
-3.66041e-07
-3.66041e-07
-3.25374e-07
-3.26683e-07
-3.6735e-07
-3.6735e-07
-3.6735e-07
-3.64871e-07
-3.64871e-07
-3.6735e-07
-3.6735e-07
-3.64871e-07
-3.64871e-07
-3.6735e-07
-3.26683e-07
-3.6735e-07
-3.6735e-07
-3.26683e-07
-3.26751e-07
-3.6742e-07
-3.6742e-07
-3.6742e-07
-3.6494e-07
-3.6494e-07
-3.67419e-07
-3.6742e-07
-3.6494e-07
-3.6494e-07
-3.67419e-07
-3.26751e-07
-3.6742e-07
-3.6742e-07
-3.26752e-07
-3.2682e-07
-3.67489e-07
-3.67489e-07
-3.67489e-07
-3.65009e-07
-3.65009e-07
-3.67489e-07
-3.67489e-07
-3.65009e-07
-3.65009e-07
-3.67489e-07
-3.2682e-07
-3.67489e-07
-3.67489e-07
-3.2682e-07
-3.26888e-07
-3.67558e-07
-3.67558e-07
-3.67558e-07
-3.65078e-07
-3.65078e-07
-3.67558e-07
-3.67558e-07
-3.65078e-07
-3.65078e-07
-3.67558e-07
-3.26888e-07
-3.67558e-07
-3.67558e-07
-3.26889e-07
-4.0303e-07
-4.437e-07
-4.437e-07
-4.437e-07
-4.4122e-07
-4.4122e-07
-4.437e-07
-4.437e-07
-4.4122e-07
-4.4122e-07
-4.437e-07
-4.0303e-07
-4.437e-07
-4.437e-07
-4.0303e-07
-1.68601e-07
-2.09271e-07
-2.09271e-07
-2.09271e-07
-2.06791e-07
-2.06791e-07
-2.09271e-07
-2.09271e-07
-2.06791e-07
-2.06791e-07
-2.09271e-07
-1.68601e-07
-2.09271e-07
-2.09271e-07
-1.68601e-07
-3.25818e-07
-3.66489e-07
-3.66489e-07
-3.66489e-07
-3.64009e-07
-3.64009e-07
-3.66488e-07
-3.66489e-07
-3.64009e-07
-3.64009e-07
-3.66488e-07
-3.25818e-07
-3.66489e-07
-3.66489e-07
-3.25818e-07
-3.27127e-07
-3.67798e-07
-3.67798e-07
-3.67798e-07
-3.65318e-07
-3.65318e-07
-3.67798e-07
-3.67798e-07
-3.65318e-07
-3.65318e-07
-3.67798e-07
-3.27127e-07
-3.67798e-07
-3.67798e-07
-3.27127e-07
-3.27195e-07
-3.67867e-07
-3.67867e-07
-3.67867e-07
-3.65387e-07
-3.65387e-07
-3.67867e-07
-3.67867e-07
-3.65387e-07
-3.65387e-07
-3.67867e-07
-3.27195e-07
-3.67867e-07
-3.67867e-07
-3.27196e-07
-3.27264e-07
-3.67936e-07
-3.67936e-07
-3.67936e-07
-3.65456e-07
-3.65456e-07
-3.67936e-07
-3.67936e-07
-3.65456e-07
-3.65456e-07
-3.67936e-07
-3.27264e-07
-3.67936e-07
-3.67936e-07
-3.27264e-07
-3.27333e-07
-3.68005e-07
-3.68005e-07
-3.68005e-07
-3.65525e-07
-3.65525e-07
-3.68005e-07
-3.68005e-07
-3.65525e-07
-3.65525e-07
-3.68005e-07
-3.27333e-07
-3.68005e-07
-3.68005e-07
-3.27333e-07
-4.03476e-07
-4.4415e-07
-4.4415e-07
-4.4415e-07
-4.41669e-07
-4.41669e-07
-4.44149e-07
-4.4415e-07
-4.41669e-07
-4.41669e-07
-4.44149e-07
-4.03476e-07
-4.4415e-07
-4.4415e-07
-4.03477e-07
-1.6907e-07
-2.09744e-07
-2.09744e-07
-2.09744e-07
-2.07264e-07
-2.07264e-07
-2.09743e-07
-2.09744e-07
-2.07264e-07
-2.07264e-07
-2.09743e-07
-1.6907e-07
-2.09744e-07
-2.09744e-07
-1.6907e-07
-3.26282e-07
-3.66956e-07
-3.66956e-07
-3.66956e-07
-3.64476e-07
-3.64476e-07
-3.66956e-07
-3.66956e-07
-3.64476e-07
-3.64476e-07
-3.66956e-07
-3.26282e-07
-3.66956e-07
-3.66956e-07
-3.26283e-07
-3.27569e-07
-3.68244e-07
-3.68244e-07
-3.68244e-07
-3.65764e-07
-3.65764e-07
-3.68244e-07
-3.68244e-07
-3.65764e-07
-3.65764e-07
-3.68244e-07
-3.27569e-07
-3.68244e-07
-3.68244e-07
-3.2757e-07
-3.27637e-07
-3.68312e-07
-3.68312e-07
-3.68312e-07
-3.65832e-07
-3.65832e-07
-3.68312e-07
-3.68312e-07
-3.65832e-07
-3.65832e-07
-3.68312e-07
-3.27637e-07
-3.68312e-07
-3.68312e-07
-3.27637e-07
-3.27705e-07
-3.6838e-07
-3.6838e-07
-3.6838e-07
-3.659e-07
-3.659e-07
-3.6838e-07
-3.6838e-07
-3.659e-07
-3.659e-07
-3.6838e-07
-3.27705e-07
-3.6838e-07
-3.6838e-07
-3.27705e-07
-3.31778e-07
-3.72454e-07
-3.72454e-07
-3.72454e-07
-3.69974e-07
-3.69974e-07
-3.72454e-07
-3.72454e-07
-3.69974e-07
-3.69974e-07
-3.72454e-07
-3.31778e-07
-3.72454e-07
-3.72454e-07
-3.31778e-07
Process [2]
-8.20859e-08
-8.20859e-08
-7.94283e-08
-8.20859e-08
-8.20859e-08
-7.94283e-08
-7.94283e-08
-7.94283e-08
-3.74067e-08
-3.61683e-07
-3.61683e-07
-3.64161e-07
-3.61683e-07
-3.61683e-07
-3.64161e-07
-3.64161e-07
-3.64161e-07
-3.23508e-07
-3.63013e-07
-3.63013e-07
-3.65491e-07
-3.63013e-07
-3.63013e-07
-3.65491e-07
-3.65491e-07
-3.65491e-07
-3.24837e-07
-3.63082e-07
-3.63082e-07
-3.65561e-07
-3.63082e-07
-3.63082e-07
-3.65561e-07
-3.65561e-07
-3.65561e-07
-3.24907e-07
-3.63152e-07
-3.63152e-07
-3.65631e-07
-3.63152e-07
-3.63152e-07
-3.65631e-07
-3.65631e-07
-3.65631e-07
-3.24976e-07
-3.63223e-07
-3.63223e-07
-3.65701e-07
-3.63223e-07
-3.63223e-07
-3.65701e-07
-3.65701e-07
-3.65701e-07
-3.25046e-07
-3.63292e-07
-3.63292e-07
-3.65771e-07
-3.63292e-07
-3.63292e-07
-3.65771e-07
-3.65771e-07
-3.65771e-07
-3.25115e-07
-4.37185e-07
-4.37185e-07
-4.39664e-07
-4.37185e-07
-4.37185e-07
-4.39664e-07
-4.39664e-07
-4.39664e-07
-3.99008e-07
-2.07061e-07
-2.07061e-07
-2.09539e-07
-2.07061e-07
-2.07061e-07
-2.09539e-07
-2.09539e-07
-2.09539e-07
-1.68882e-07
-3.62224e-07
-3.62224e-07
-3.64703e-07
-3.62224e-07
-3.62224e-07
-3.64703e-07
-3.64703e-07
-3.64703e-07
-3.24045e-07
-3.63533e-07
-3.63533e-07
-3.66012e-07
-3.63533e-07
-3.63533e-07
-3.66012e-07
-3.66012e-07
-3.66012e-07
-3.25354e-07
-3.63602e-07
-3.63602e-07
-3.66081e-07
-3.63602e-07
-3.63602e-07
-3.66081e-07
-3.66081e-07
-3.66081e-07
-3.25422e-07
-3.63671e-07
-3.63671e-07
-3.66149e-07
-3.63671e-07
-3.63671e-07
-3.66149e-07
-3.66149e-07
-3.66149e-07
-3.25491e-07
-3.63739e-07
-3.63739e-07
-3.66218e-07
-3.63739e-07
-3.63739e-07
-3.66218e-07
-3.66218e-07
-3.66218e-07
-3.25559e-07
-4.39874e-07
-4.39874e-07
-4.42354e-07
-4.39874e-07
-4.39874e-07
-4.42354e-07
-4.42354e-07
-4.42354e-07
-4.01694e-07
-2.05467e-07
-2.05467e-07
-2.07945e-07
-2.05467e-07
-2.05467e-07
-2.07945e-07
-2.07945e-07
-2.07945e-07
-1.67285e-07
-3.62669e-07
-3.62669e-07
-3.65148e-07
-3.62669e-07
-3.62669e-07
-3.65148e-07
-3.65148e-07
-3.65148e-07
-3.24488e-07
-3.63978e-07
-3.63978e-07
-3.66457e-07
-3.63978e-07
-3.63978e-07
-3.66457e-07
-3.66457e-07
-3.66457e-07
-3.25796e-07
-3.64047e-07
-3.64047e-07
-3.66526e-07
-3.64047e-07
-3.64047e-07
-3.66526e-07
-3.66526e-07
-3.66526e-07
-3.25865e-07
-3.64116e-07
-3.64116e-07
-3.66595e-07
-3.64116e-07
-3.64116e-07
-3.66595e-07
-3.66595e-07
-3.66595e-07
-3.25933e-07
-3.64185e-07
-3.64185e-07
-3.66664e-07
-3.64185e-07
-3.64185e-07
-3.66664e-07
-3.66664e-07
-3.66664e-07
-3.26002e-07
-4.40322e-07
-4.40322e-07
-4.42802e-07
-4.40322e-07
-4.40322e-07
-4.42802e-07
-4.42802e-07
-4.42802e-07
-4.02139e-07
-2.05908e-07
-2.05908e-07
-2.08387e-07
-2.05908e-07
-2.05908e-07
-2.08387e-07
-2.08387e-07
-2.08387e-07
-1.67723e-07
-3.63115e-07
-3.63115e-07
-3.65594e-07
-3.63115e-07
-3.63115e-07
-3.65594e-07
-3.65594e-07
-3.65594e-07
-3.24931e-07
-3.64424e-07
-3.64424e-07
-3.66904e-07
-3.64424e-07
-3.64424e-07
-3.66904e-07
-3.66904e-07
-3.66904e-07
-3.26239e-07
-3.64493e-07
-3.64493e-07
-3.66973e-07
-3.64493e-07
-3.64493e-07
-3.66973e-07
-3.66973e-07
-3.66973e-07
-3.26308e-07
-3.64562e-07
-3.64562e-07
-3.67042e-07
-3.64562e-07
-3.64562e-07
-3.67042e-07
-3.67042e-07
-3.67042e-07
-3.26376e-07
-3.64631e-07
-3.64631e-07
-3.67111e-07
-3.64631e-07
-3.64631e-07
-3.67111e-07
-3.67111e-07
-3.67111e-07
-3.26445e-07
-4.40771e-07
-4.40771e-07
-4.4325e-07
-4.40771e-07
-4.40771e-07
-4.4325e-07
-4.4325e-07
-4.4325e-07
-4.02584e-07
-2.06349e-07
-2.06349e-07
-2.08828e-07
-2.06349e-07
-2.06349e-07
-2.08828e-07
-2.08828e-07
-2.08828e-07
-1.68162e-07
-3.63562e-07
-3.63562e-07
-3.66041e-07
-3.63562e-07
-3.63562e-07
-3.66041e-07
-3.66041e-07
-3.66041e-07
-3.25374e-07
-3.64871e-07
-3.64871e-07
-3.6735e-07
-3.64871e-07
-3.64871e-07
-3.6735e-07
-3.6735e-07
-3.6735e-07
-3.26683e-07
-3.6494e-07
-3.6494e-07
-3.67419e-07
-3.6494e-07
-3.6494e-07
-3.67419e-07
-3.67419e-07
-3.67419e-07
-3.26752e-07
-3.65009e-07
-3.65009e-07
-3.67489e-07
-3.65009e-07
-3.65009e-07
-3.67489e-07
-3.67489e-07
-3.67489e-07
-3.2682e-07
-3.65078e-07
-3.65078e-07
-3.67558e-07
-3.65078e-07
-3.65078e-07
-3.67558e-07
-3.67558e-07
-3.67558e-07
-3.26889e-07
-4.4122e-07
-4.4122e-07
-4.437e-07
-4.4122e-07
-4.4122e-07
-4.437e-07
-4.437e-07
-4.437e-07
-4.0303e-07
-2.06791e-07
-2.06791e-07
-2.09271e-07
-2.06791e-07
-2.06791e-07
-2.09271e-07
-2.09271e-07
-2.09271e-07
-1.68601e-07
-3.64009e-07
-3.64009e-07
-3.66488e-07
-3.64009e-07
-3.64009e-07
-3.66488e-07
-3.66488e-07
-3.66488e-07
-3.25818e-07
-3.65318e-07
-3.65318e-07
-3.67798e-07
-3.65318e-07
-3.65318e-07
-3.67798e-07
-3.67798e-07
-3.67798e-07
-3.27127e-07
-3.65387e-07
-3.65387e-07
-3.67867e-07
-3.65387e-07
-3.65387e-07
-3.67867e-07
-3.67867e-07
-3.67867e-07
-3.27196e-07
-3.65456e-07
-3.65456e-07
-3.67936e-07
-3.65456e-07
-3.65456e-07
-3.67936e-07
-3.67936e-07
-3.67936e-07
-3.27264e-07
-3.65525e-07
-3.65525e-07
-3.68005e-07
-3.65525e-07
-3.65525e-07
-3.68005e-07
-3.68005e-07
-3.68005e-07
-3.27333e-07
-4.41669e-07
-4.41669e-07
-4.44149e-07
-4.41669e-07
-4.41669e-07
-4.44149e-07
-4.44149e-07
-4.44149e-07
-4.03477e-07
-2.07264e-07
-2.07264e-07
-2.09743e-07
-2.07264e-07
-2.07264e-07
-2.09743e-07
-2.09743e-07
-2.09743e-07
-1.6907e-07
-3.64476e-07
-3.64476e-07
-3.66956e-07
-3.64476e-07
-3.64476e-07
-3.66956e-07
-3.66956e-07
-3.66956e-07
-3.26283e-07
-3.65764e-07
-3.65764e-07
-3.68244e-07
-3.65764e-07
-3.65764e-07
-3.68244e-07
-3.68244e-07
-3.68244e-07
-3.2757e-07
-3.65832e-07
-3.65832e-07
-3.68312e-07
-3.65832e-07
-3.65832e-07
-3.68312e-07
-3.68312e-07
-3.68312e-07
-3.27637e-07
-3.659e-07
-3.659e-07
-3.6838e-07
-3.659e-07
-3.659e-07
-3.6838e-07
-3.6838e-07
-3.6838e-07
-3.27705e-07
-3.69974e-07
-3.69974e-07
-3.72454e-07
-3.69974e-07
-3.69974e-07
-3.72454e-07
-3.72454e-07
-3.72454e-07
-3.31778e-07
Process [3]
-7.94269e-08
-7.94269e-08
-3.74028e-08
-8.20859e-08
-8.20859e-08
-7.94269e-08
-8.20859e-08
-8.20859e-08
-7.94269e-08
-7.94269e-08
-7.94269e-08
-3.74028e-08
-3.64162e-07
-3.64162e-07
-3.23508e-07
-3.61683e-07
-3.61683e-07
-3.64162e-07
-3.61683e-07
-3.61683e-07
-3.64162e-07
-3.64162e-07
-3.64162e-07
-3.23508e-07
-3.65491e-07
-3.65491e-07
-3.24837e-07
-3.63013e-07
-3.63013e-07
-3.65491e-07
-3.63013e-07
-3.63013e-07
-3.65491e-07
-3.65491e-07
-3.65491e-07
-3.24837e-07
-3.65561e-07
-3.65561e-07
-3.24906e-07
-3.63082e-07
-3.63082e-07
-3.65561e-07
-3.63082e-07
-3.63082e-07
-3.65561e-07
-3.65561e-07
-3.65561e-07
-3.24906e-07
-3.65631e-07
-3.65631e-07
-3.24976e-07
-3.63152e-07
-3.63152e-07
-3.65631e-07
-3.63152e-07
-3.63152e-07
-3.65631e-07
-3.65631e-07
-3.65631e-07
-3.24976e-07
-3.65702e-07
-3.65702e-07
-3.25045e-07
-3.63223e-07
-3.63223e-07
-3.65702e-07
-3.63223e-07
-3.63223e-07
-3.65702e-07
-3.65702e-07
-3.65702e-07
-3.25045e-07
-3.65771e-07
-3.65771e-07
-3.25115e-07
-3.63292e-07
-3.63292e-07
-3.65771e-07
-3.63292e-07
-3.63292e-07
-3.65771e-07
-3.65771e-07
-3.65771e-07
-3.25115e-07
-4.39665e-07
-4.39665e-07
-3.99007e-07
-4.37185e-07
-4.37185e-07
-4.39665e-07
-4.37185e-07
-4.37185e-07
-4.39665e-07
-4.39665e-07
-4.39665e-07
-3.99007e-07
-2.0954e-07
-2.0954e-07
-1.68882e-07
-2.07061e-07
-2.07061e-07
-2.0954e-07
-2.07061e-07
-2.07061e-07
-2.0954e-07
-2.0954e-07
-2.0954e-07
-1.68882e-07
-3.64703e-07
-3.64703e-07
-3.24045e-07
-3.62224e-07
-3.62224e-07
-3.64703e-07
-3.62224e-07
-3.62224e-07
-3.64703e-07
-3.64703e-07
-3.64703e-07
-3.24045e-07
-3.66012e-07
-3.66012e-07
-3.25354e-07
-3.63533e-07
-3.63533e-07
-3.66012e-07
-3.63533e-07
-3.63533e-07
-3.66012e-07
-3.66012e-07
-3.66012e-07
-3.25354e-07
-3.66081e-07
-3.66081e-07
-3.25422e-07
-3.63602e-07
-3.63602e-07
-3.66081e-07
-3.63602e-07
-3.63602e-07
-3.66081e-07
-3.66081e-07
-3.66081e-07
-3.25422e-07
-3.6615e-07
-3.6615e-07
-3.2549e-07
-3.63671e-07
-3.63671e-07
-3.6615e-07
-3.63671e-07
-3.63671e-07
-3.6615e-07
-3.6615e-07
-3.6615e-07
-3.2549e-07
-3.66218e-07
-3.66218e-07
-3.25559e-07
-3.63739e-07
-3.63739e-07
-3.66218e-07
-3.63739e-07
-3.63739e-07
-3.66218e-07
-3.66218e-07
-3.66218e-07
-3.25559e-07
-4.42354e-07
-4.42354e-07
-4.01693e-07
-4.39874e-07
-4.39874e-07
-4.42354e-07
-4.39874e-07
-4.39874e-07
-4.42354e-07
-4.42354e-07
-4.42354e-07
-4.01693e-07
-2.07945e-07
-2.07945e-07
-1.67285e-07
-2.05467e-07
-2.05467e-07
-2.07945e-07
-2.05467e-07
-2.05467e-07
-2.07945e-07
-2.07945e-07
-2.07945e-07
-1.67285e-07
-3.65148e-07
-3.65148e-07
-3.24487e-07
-3.62669e-07
-3.62669e-07
-3.65148e-07
-3.62669e-07
-3.62669e-07
-3.65148e-07
-3.65148e-07
-3.65148e-07
-3.24487e-07
-3.66458e-07
-3.66458e-07
-3.25796e-07
-3.63978e-07
-3.63978e-07
-3.66458e-07
-3.63978e-07
-3.63978e-07
-3.66458e-07
-3.66458e-07
-3.66458e-07
-3.25796e-07
-3.66527e-07
-3.66527e-07
-3.25864e-07
-3.64047e-07
-3.64047e-07
-3.66527e-07
-3.64047e-07
-3.64047e-07
-3.66527e-07
-3.66527e-07
-3.66527e-07
-3.25864e-07
-3.66595e-07
-3.66595e-07
-3.25933e-07
-3.64116e-07
-3.64116e-07
-3.66595e-07
-3.64116e-07
-3.64116e-07
-3.66595e-07
-3.66595e-07
-3.66595e-07
-3.25933e-07
-3.66664e-07
-3.66664e-07
-3.26001e-07
-3.64185e-07
-3.64185e-07
-3.66664e-07
-3.64185e-07
-3.64185e-07
-3.66664e-07
-3.66664e-07
-3.66664e-07
-3.26001e-07
-4.42802e-07
-4.42802e-07
-4.02138e-07
-4.40322e-07
-4.40322e-07
-4.42802e-07
-4.40322e-07
-4.40322e-07
-4.42802e-07
-4.42802e-07
-4.42802e-07
-4.02138e-07
-2.08387e-07
-2.08387e-07
-1.67723e-07
-2.05908e-07
-2.05908e-07
-2.08387e-07
-2.05908e-07
-2.05908e-07
-2.08387e-07
-2.08387e-07
-2.08387e-07
-1.67723e-07
-3.65595e-07
-3.65595e-07
-3.2493e-07
-3.63115e-07
-3.63115e-07
-3.65595e-07
-3.63115e-07
-3.63115e-07
-3.65595e-07
-3.65595e-07
-3.65595e-07
-3.2493e-07
-3.66904e-07
-3.66904e-07
-3.26239e-07
-3.64424e-07
-3.64424e-07
-3.66904e-07
-3.64424e-07
-3.64424e-07
-3.66904e-07
-3.66904e-07
-3.66904e-07
-3.26239e-07
-3.66973e-07
-3.66973e-07
-3.26308e-07
-3.64493e-07
-3.64493e-07
-3.66973e-07
-3.64493e-07
-3.64493e-07
-3.66973e-07
-3.66973e-07
-3.66973e-07
-3.26308e-07
-3.67042e-07
-3.67042e-07
-3.26376e-07
-3.64562e-07
-3.64562e-07
-3.67042e-07
-3.64562e-07
-3.64562e-07
-3.67042e-07
-3.67042e-07
-3.67042e-07
-3.26376e-07
-3.67111e-07
-3.67111e-07
-3.26445e-07
-3.64631e-07
-3.64631e-07
-3.67111e-07
-3.64631e-07
-3.64631e-07
-3.67111e-07
-3.67111e-07
-3.67111e-07
-3.26445e-07
-4.4325e-07
-4.4325e-07
-4.02584e-07
-4.40771e-07
-4.40771e-07
-4.4325e-07
-4.40771e-07
-4.40771e-07
-4.4325e-07
-4.4325e-07
-4.4325e-07
-4.02584e-07
-2.08829e-07
-2.08829e-07
-1.68161e-07
-2.06349e-07
-2.06349e-07
-2.08829e-07
-2.06349e-07
-2.06349e-07
-2.08829e-07
-2.08829e-07
-2.08829e-07
-1.68161e-07
-3.66041e-07
-3.66041e-07
-3.25374e-07
-3.63562e-07
-3.63562e-07
-3.66041e-07
-3.63562e-07
-3.63562e-07
-3.66041e-07
-3.66041e-07
-3.66041e-07
-3.25374e-07
-3.6735e-07
-3.6735e-07
-3.26683e-07
-3.64871e-07
-3.64871e-07
-3.6735e-07
-3.64871e-07
-3.64871e-07
-3.6735e-07
-3.6735e-07
-3.6735e-07
-3.26683e-07
-3.6742e-07
-3.6742e-07
-3.26751e-07
-3.6494e-07
-3.6494e-07
-3.6742e-07
-3.6494e-07
-3.6494e-07
-3.6742e-07
-3.6742e-07
-3.6742e-07
-3.26751e-07
-3.67489e-07
-3.67489e-07
-3.2682e-07
-3.65009e-07
-3.65009e-07
-3.67489e-07
-3.65009e-07
-3.65009e-07
-3.67489e-07
-3.67489e-07
-3.67489e-07
-3.2682e-07
-3.67558e-07
-3.67558e-07
-3.26888e-07
-3.65078e-07
-3.65078e-07
-3.67558e-07
-3.65078e-07
-3.65078e-07
-3.67558e-07
-3.67558e-07
-3.67558e-07
-3.26888e-07
-4.437e-07
-4.437e-07
-4.0303e-07
-4.4122e-07
-4.4122e-07
-4.437e-07
-4.4122e-07
-4.4122e-07
-4.437e-07
-4.437e-07
-4.437e-07
-4.0303e-07
-2.09271e-07
-2.09271e-07
-1.68601e-07
-2.06791e-07
-2.06791e-07
-2.09271e-07
-2.06791e-07
-2.06791e-07
-2.09271e-07
-2.09271e-07
-2.09271e-07
-1.68601e-07
-3.66489e-07
-3.66489e-07
-3.25818e-07
-3.64009e-07
-3.64009e-07
-3.66489e-07
-3.64009e-07
-3.64009e-07
-3.66489e-07
-3.66489e-07
-3.66489e-07
-3.25818e-07
-3.67798e-07
-3.67798e-07
-3.27127e-07
-3.65318e-07
-3.65318e-07
-3.67798e-07
-3.65318e-07
-3.65318e-07
-3.67798e-07
-3.67798e-07
-3.67798e-07
-3.27127e-07
-3.67867e-07
-3.67867e-07
-3.27195e-07
-3.65387e-07
-3.65387e-07
-3.67867e-07
-3.65387e-07
-3.65387e-07
-3.67867e-07
-3.67867e-07
-3.67867e-07
-3.27195e-07
-3.67936e-07
-3.67936e-07
-3.27264e-07
-3.65456e-07
-3.65456e-07
-3.67936e-07
-3.65456e-07
-3.65456e-07
-3.67936e-07
-3.67936e-07
-3.67936e-07
-3.27264e-07
-3.68005e-07
-3.68005e-07
-3.27333e-07
-3.65525e-07
-3.65525e-07
-3.68005e-07
-3.65525e-07
-3.65525e-07
-3.68005e-07
-3.68005e-07
-3.68005e-07
-3.27333e-07
-4.4415e-07
-4.4415e-07
-4.03476e-07
-4.41669e-07
-4.41669e-07
-4.4415e-07
-4.41669e-07
-4.41669e-07
-4.4415e-07
-4.4415e-07
-4.4415e-07
-4.03476e-07
-2.09744e-07
-2.09744e-07
-1.6907e-07
-2.07264e-07
-2.07264e-07
-2.09744e-07
-2.07264e-07
-2.07264e-07
-2.09744e-07
-2.09744e-07
-2.09744e-07
-1.6907e-07
-3.66956e-07
-3.66956e-07
-3.26282e-07
-3.64476e-07
-3.64476e-07
-3.66956e-07
-3.64476e-07
-3.64476e-07
-3.66956e-07
-3.66956e-07
-3.66956e-07
-3.26282e-07
-3.68244e-07
-3.68244e-07
-3.27569e-07
-3.65764e-07
-3.65764e-07
-3.68244e-07
-3.65764e-07
-3.65764e-07
-3.68244e-07
-3.68244e-07
-3.68244e-07
-3.27569e-07
-3.68312e-07
-3.68312e-07
-3.27637e-07
-3.65832e-07
-3.65832e-07
-3.68312e-07
-3.65832e-07
-3.65832e-07
-3.68312e-07
-3.68312e-07
-3.68312e-07
-3.27637e-07
-3.6838e-07
-3.6838e-07
-3.27705e-07
-3.659e-07
-3.659e-07
-3.6838e-07
-3.659e-07
-3.659e-07
-3.6838e-07
-3.6838e-07
-3.6838e-07
-3.27705e-07
-3.72454e-07
-3.72454e-07
-3.31778e-07
-3.69974e-07
-3.69974e-07
-3.72454e-07
-3.69974e-07
-3.69974e-07
-3.72454e-07
-3.72454e-07
-3.72454e-07
-3.31778e-07
Process [4]
-7.94269e-08
-8.20859e-08
-8.20859e-08
-7.94269e-08
-7.94269e-08
-8.20859e-08
-8.20859e-08
-7.94269e-08
-3.74028e-08
-7.94269e-08
-7.94269e-08
-3.74028e-08
-3.64162e-07
-3.61683e-07
-3.61683e-07
-3.64162e-07
-3.64162e-07
-3.61683e-07
-3.61683e-07
-3.64162e-07
-3.23508e-07
-3.64162e-07
-3.64162e-07
-3.23508e-07
-3.65491e-07
-3.63013e-07
-3.63013e-07
-3.65491e-07
-3.65491e-07
-3.63013e-07
-3.63013e-07
-3.65491e-07
-3.24837e-07
-3.65491e-07
-3.65491e-07
-3.24837e-07
-3.65561e-07
-3.63082e-07
-3.63082e-07
-3.65561e-07
-3.65561e-07
-3.63082e-07
-3.63082e-07
-3.65561e-07
-3.24906e-07
-3.65561e-07
-3.65561e-07
-3.24906e-07
-3.65631e-07
-3.63152e-07
-3.63152e-07
-3.65631e-07
-3.65631e-07
-3.63152e-07
-3.63152e-07
-3.65631e-07
-3.24976e-07
-3.65631e-07
-3.65631e-07
-3.24976e-07
-3.65702e-07
-3.63223e-07
-3.63223e-07
-3.65702e-07
-3.65702e-07
-3.63223e-07
-3.63223e-07
-3.65702e-07
-3.25045e-07
-3.65702e-07
-3.65702e-07
-3.25045e-07
-3.65771e-07
-3.63292e-07
-3.63292e-07
-3.65771e-07
-3.65771e-07
-3.63292e-07
-3.63292e-07
-3.65771e-07
-3.25115e-07
-3.65771e-07
-3.65771e-07
-3.25115e-07
-4.39665e-07
-4.37185e-07
-4.37185e-07
-4.39665e-07
-4.39665e-07
-4.37185e-07
-4.37185e-07
-4.39665e-07
-3.99007e-07
-4.39665e-07
-4.39665e-07
-3.99007e-07
-2.0954e-07
-2.07061e-07
-2.07061e-07
-2.0954e-07
-2.0954e-07
-2.07061e-07
-2.07061e-07
-2.0954e-07
-1.68882e-07
-2.0954e-07
-2.0954e-07
-1.68882e-07
-3.64703e-07
-3.62224e-07
-3.62224e-07
-3.64703e-07
-3.64703e-07
-3.62224e-07
-3.62224e-07
-3.64703e-07
-3.24045e-07
-3.64703e-07
-3.64703e-07
-3.24045e-07
-3.66012e-07
-3.63533e-07
-3.63533e-07
-3.66012e-07
-3.66012e-07
-3.63533e-07
-3.63533e-07
-3.66012e-07
-3.25354e-07
-3.66012e-07
-3.66012e-07
-3.25354e-07
-3.66081e-07
-3.63602e-07
-3.63602e-07
-3.66081e-07
-3.66081e-07
-3.63602e-07
-3.63602e-07
-3.66081e-07
-3.25422e-07
-3.66081e-07
-3.66081e-07
-3.25422e-07
-3.6615e-07
-3.63671e-07
-3.63671e-07
-3.6615e-07
-3.6615e-07
-3.63671e-07
-3.63671e-07
-3.6615e-07
-3.2549e-07
-3.6615e-07
-3.6615e-07
-3.2549e-07
-3.66218e-07
-3.63739e-07
-3.63739e-07
-3.66218e-07
-3.66218e-07
-3.63739e-07
-3.63739e-07
-3.66218e-07
-3.25559e-07
-3.66218e-07
-3.66218e-07
-3.25559e-07
-4.42354e-07
-4.39874e-07
-4.39874e-07
-4.42354e-07
-4.42354e-07
-4.39874e-07
-4.39874e-07
-4.42354e-07
-4.01693e-07
-4.42354e-07
-4.42354e-07
-4.01693e-07
-2.07945e-07
-2.05467e-07
-2.05467e-07
-2.07945e-07
-2.07945e-07
-2.05467e-07
-2.05467e-07
-2.07945e-07
-1.67285e-07
-2.07945e-07
-2.07945e-07
-1.67285e-07
-3.65148e-07
-3.62669e-07
-3.62669e-07
-3.65148e-07
-3.65148e-07
-3.62669e-07
-3.62669e-07
-3.65148e-07
-3.24487e-07
-3.65148e-07
-3.65148e-07
-3.24487e-07
-3.66458e-07
-3.63978e-07
-3.63978e-07
-3.66458e-07
-3.66458e-07
-3.63978e-07
-3.63978e-07
-3.66458e-07
-3.25796e-07
-3.66458e-07
-3.66458e-07
-3.25796e-07
-3.66527e-07
-3.64047e-07
-3.64047e-07
-3.66527e-07
-3.66527e-07
-3.64047e-07
-3.64047e-07
-3.66527e-07
-3.25864e-07
-3.66527e-07
-3.66527e-07
-3.25864e-07
-3.66595e-07
-3.64116e-07
-3.64116e-07
-3.66595e-07
-3.66595e-07
-3.64116e-07
-3.64116e-07
-3.66595e-07
-3.25933e-07
-3.66595e-07
-3.66595e-07
-3.25933e-07
-3.66664e-07
-3.64185e-07
-3.64185e-07
-3.66664e-07
-3.66664e-07
-3.64185e-07
-3.64185e-07
-3.66664e-07
-3.26001e-07
-3.66664e-07
-3.66664e-07
-3.26001e-07
-4.42802e-07
-4.40322e-07
-4.40322e-07
-4.42802e-07
-4.42802e-07
-4.40322e-07
-4.40322e-07
-4.42802e-07
-4.02138e-07
-4.42802e-07
-4.42802e-07
-4.02138e-07
-2.08387e-07
-2.05908e-07
-2.05908e-07
-2.08387e-07
-2.08387e-07
-2.05908e-07
-2.05908e-07
-2.08387e-07
-1.67723e-07
-2.08387e-07
-2.08387e-07
-1.67723e-07
-3.65595e-07
-3.63115e-07
-3.63115e-07
-3.65595e-07
-3.65595e-07
-3.63115e-07
-3.63115e-07
-3.65595e-07
-3.2493e-07
-3.65595e-07
-3.65595e-07
-3.2493e-07
-3.66904e-07
-3.64424e-07
-3.64424e-07
-3.66904e-07
-3.66904e-07
-3.64424e-07
-3.64424e-07
-3.66904e-07
-3.26239e-07
-3.66904e-07
-3.66904e-07
-3.26239e-07
-3.66973e-07
-3.64493e-07
-3.64493e-07
-3.66973e-07
-3.66973e-07
-3.64493e-07
-3.64493e-07
-3.66973e-07
-3.26308e-07
-3.66973e-07
-3.66973e-07
-3.26308e-07
-3.67042e-07
-3.64562e-07
-3.64562e-07
-3.67042e-07
-3.67042e-07
-3.64562e-07
-3.64562e-07
-3.67042e-07
-3.26376e-07
-3.67042e-07
-3.67042e-07
-3.26376e-07
-3.67111e-07
-3.64631e-07
-3.64631e-07
-3.67111e-07
-3.67111e-07
-3.64631e-07
-3.64631e-07
-3.67111e-07
-3.26445e-07
-3.67111e-07
-3.67111e-07
-3.26445e-07
-4.4325e-07
-4.40771e-07
-4.40771e-07
-4.4325e-07
-4.4325e-07
-4.40771e-07
-4.40771e-07
-4.4325e-07
-4.02584e-07
-4.4325e-07
-4.4325e-07
-4.02584e-07
-2.08829e-07
-2.06349e-07
-2.06349e-07
-2.08829e-07
-2.08829e-07
-2.06349e-07
-2.06349e-07
-2.08829e-07
-1.68161e-07
-2.08829e-07
-2.08829e-07
-1.68161e-07
-3.66041e-07
-3.63562e-07
-3.63562e-07
-3.66041e-07
-3.66041e-07
-3.63562e-07
-3.63562e-07
-3.66041e-07
-3.25374e-07
-3.66041e-07
-3.66041e-07
-3.25374e-07
-3.6735e-07
-3.64871e-07
-3.64871e-07
-3.6735e-07
-3.6735e-07
-3.64871e-07
-3.64871e-07
-3.6735e-07
-3.26683e-07
-3.6735e-07
-3.6735e-07
-3.26683e-07
-3.6742e-07
-3.6494e-07
-3.6494e-07
-3.6742e-07
-3.6742e-07
-3.6494e-07
-3.6494e-07
-3.6742e-07
-3.26751e-07
-3.6742e-07
-3.6742e-07
-3.26751e-07
-3.67489e-07
-3.65009e-07
-3.65009e-07
-3.67489e-07
-3.67489e-07
-3.65009e-07
-3.65009e-07
-3.67489e-07
-3.2682e-07
-3.67489e-07
-3.67489e-07
-3.2682e-07
-3.67558e-07
-3.65078e-07
-3.65078e-07
-3.67558e-07
-3.67558e-07
-3.65078e-07
-3.65078e-07
-3.67558e-07
-3.26888e-07
-3.67558e-07
-3.67558e-07
-3.26888e-07
-4.437e-07
-4.4122e-07
-4.4122e-07
-4.437e-07
-4.437e-07
-4.4122e-07
-4.4122e-07
-4.437e-07
-4.0303e-07
-4.437e-07
-4.437e-07
-4.0303e-07
-2.09271e-07
-2.06791e-07
-2.06791e-07
-2.09271e-07
-2.09271e-07
-2.06791e-07
-2.06791e-07
-2.09271e-07
-1.68601e-07
-2.09271e-07
-2.09271e-07
-1.68601e-07
-3.66489e-07
-3.64009e-07
-3.64009e-07
-3.66489e-07
-3.66489e-07
-3.64009e-07
-3.64009e-07
-3.66489e-07
-3.25818e-07
-3.66489e-07
-3.66489e-07
-3.25818e-07
-3.67798e-07
-3.65318e-07
-3.65318e-07
-3.67798e-07
-3.67798e-07
-3.65318e-07
-3.65318e-07
-3.67798e-07
-3.27127e-07
-3.67798e-07
-3.67798e-07
-3.27127e-07
-3.67867e-07
-3.65387e-07
-3.65387e-07
-3.67867e-07
-3.67867e-07
-3.65387e-07
-3.65387e-07
-3.67867e-07
-3.27195e-07
-3.67867e-07
-3.67867e-07
-3.27195e-07
-3.67936e-07
-3.65456e-07
-3.65456e-07
-3.67936e-07
-3.67936e-07
-3.65456e-07
-3.65456e-07
-3.67936e-07
-3.27264e-07
-3.67936e-07
-3.67936e-07
-3.27264e-07
-3.68005e-07
-3.65525e-07
-3.65525e-07
-3.68005e-07
-3.68005e-07
-3.65525e-07
-3.65525e-07
-3.68005e-07
-3.27333e-07
-3.68005e-07
-3.68005e-07
-3.27333e-07
-4.4415e-07
-4.41669e-07
-4.41669e-07
-4.4415e-07
-4.4415e-07
-4.41669e-07
-4.41669e-07
-4.4415e-07
-4.03476e-07
-4.4415e-07
-4.4415e-07
-4.03476e-07
-2.09744e-07
-2.07264e-07
-2.07264e-07
-2.09744e-07
-2.09744e-07
-2.07264e-07
-2.07264e-07
-2.09744e-07
-1.6907e-07
-2.09744e-07
-2.09744e-07
-1.6907e-07
-3.66956e-07
-3.64476e-07
-3.64476e-07
-3.66956e-07
-3.66956e-07
-3.64476e-07
-3.64476e-07
-3.66956e-07
-3.26282e-07
-3.66956e-07
-3.66956e-07
-3.26282e-07
-3.68244e-07
-3.65764e-07
-3.65764e-07
-3.68244e-07
-3.68244e-07
-3.65764e-07
-3.65764e-07
-3.68244e-07
-3.27569e-07
-3.68244e-07
-3.68244e-07
-3.27569e-07
-3.68312e-07
-3.65832e-07
-3.65832e-07
-3.68312e-07
-3.68312e-07
-3.65832e-07
-3.65832e-07
-3.68312e-07
-3.27637e-07
-3.68312e-07
-3.68312e-07
-3.27637e-07
-3.6838e-07
-3.659e-07
-3.659e-07
-3.6838e-07
-3.6838e-07
-3.659e-07
-3.659e-07
-3.6838e-07
-3.27705e-07
-3.6838e-07
-3.6838e-07
-3.27705e-07
-3.72454e-07
-3.69974e-07
-3.69974e-07
-3.72454e-07
-3.72454e-07
-3.69974e-07
-3.69974e-07
-3.72454e-07
-3.31778e-07
-3.72454e-07
-3.72454e-07
-3.31778e-07
