[petsc-users] matsetvaluesblocked4_
Wed May 27 17:47:16 CDT 2020
On Wed, May 27, 2020 at 6:43 PM Mark Adams <mfadams at lbl.gov> wrote:
> Nvidias's NSight with 2D Q3 and bs=10. (attached).
> I am using LU in serial.
> I copied MatSetValues_SeqAIJ into a .cu file and made some minor
> adjustments.
> I am getting the indices from Matt's DMPlexMatGetClosureIndices and the
> matrix is from DMPlex. I also use GPU direct solvers sometimes and will
> want that in the future. All and all I figure AIJ is a safer bet, but maybe
> BAIJ is an option.
> Matt: Could I use BAIJ with Plex?
Plex does this automatically if you have blocks.
   Matt
> Thanks,
> Mark
> On Wed, May 27, 2020 at 6:14 PM Jed Brown <jed at jedbrown.org> wrote:
>> What did you profile to determine that expanding indices is significant?
>> matsetvaluesblocked4_ was made specially for PETSc-FUN3D with BAIJ
>> matrices.
>> I take it you can't use BAIJ because you use GAMG?
>> Mark Adams <mfadams at lbl.gov> writes:
>> > Is there a Mat AIJSeq method For MatSetValuesBlocked,
>> > like matsetvaluesblocked4_ that is not hardwired for bs=4?
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200527/a14028fa/attachment.html>
