[petsc-users] using real and complex together
Stefano Zampini
stefano.zampini at gmail.com
Tue May 26 15:34:11 CDT 2020
All the solvers/matrices/vectors works for PetscScalar types (i.e. in your case complex)
If you need to solve for the real part only, you can duplicate the matrix and call MatRealPart to zero out the imaginary part. But the solve will always run in the complex space
You should not be worried about doubling the memory for a matrix (i.e. real and imaginary part)
> On May 26, 2020, at 11:28 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
> complex version is needed since matrix sometimes is real and sometimes is complex. I want to solve real matrix without allocating memory for imaginary part((except eigen pairs).
> On Tuesday, May 26, 2020, Zhang, Hong <hzhang at mcs.anl.gov <mailto:hzhang at mcs.anl.gov>> wrote:
> You can build PETSc with complex version, and declare some variables as 'PETSC_REAL'.
> Hong
> From: petsc-users <petsc-users-bounces at mcs.anl.gov <mailto:petsc-users-bounces at mcs.anl.gov>> on behalf of Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>>
> Sent: Tuesday, May 26, 2020 1:00 PM
> To: PETSc <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Subject: [petsc-users] using real and complex together
> Dear PETSc dev team,
> Can I use both real and complex versions together?
> Thanks,
> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200526/0eb0f58c/attachment.html>
