[petsc-users] multiple definition of `main' with intel compilers
Alfredo Jaramillo
ajaramillopalma at gmail.com
Thu May 21 16:46:54 CDT 2020
hello Satish, no the tests seem to be ok altough some error related to mpd.
==============THE TESTS===================
Running check examples to verify correct installation
Using PETSC_DIR=/scratch/simulreserv/softwares/petsc-3.13.0 and
PETSC_ARCH=x64-O3-3.13-intel2016-64
Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
See http://www.mcs.anl.gov/petsc/documentation/faq.html
mpiexec_sdumont11: cannot connect to local mpd
(/tmp/mpd2.console_alfredo.jaramillo); possible causes:
1. no mpd is running on this host
2. an mpd is running but was started without a "console" (-n option)
Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
1,5c1,3
< lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
< 0 SNES Function norm 0.0406612
< 1 SNES Function norm 4.12227e-06
< 2 SNES Function norm 6.098e-11
< Number of SNES iterations = 2
/scratch/simulreserv/softwares/petsc-3.13.0/src/snes/tutorials
Possible problem with ex19 running with hypre, diffs above
1,9c1,3
< lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
< 0 SNES Function norm 0.239155
< 0 KSP Residual norm 0.239155
< 1 KSP Residual norm < 1.e-11
< 1 SNES Function norm 6.81968e-05
< 0 KSP Residual norm 6.81968e-05
< 2 SNES Function norm < 1.e-11
Possible problem with ex19 running with mumps, diffs above
Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI
process
Completed test examples
I entered in src/snes/tutorials/ and executed "make ex5f". The binary exf5
was created
On Thu, May 21, 2020 at 6:37 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Do you get this error when building PETSc examples [C and/or fortran] -
> when you build them with the corresponding petsc makefile?
> Can you send the log of the example compiles?
> Satish
> [the attachment got deleted - don't know by who..]
> DENIAL OF SERVICE ALERT
> A denial of service protection limit was exceeded. The file has been
> removed.
> Context: 'configure.log.7z'
> Reason: The data size limit was exceeded
> Limit: 10 MB
> Ticket Number : 0c9c-5ec6-f30f-0001
> For further information, contact your system administrator.
> Copyright 1999-2014 McAfee, Inc.
> All Rights Reserved.
> http://www.mcafee.com
> On Thu, 21 May 2020, Alfredo Jaramillo wrote:
> > dear PETSc team,
> > I have compiled PETSc with a 2016 version of the intel compilers. The
> > installation went well, but when I tried to compile my code the following
> > error appears in the final step of compilation (linking with ld)
> > ../build/linux_icc/obj_linux_icc_opt/main.o: In function `main':
> > main.c:(.text+0x0): multiple definition of `main'
> /opt/intel/parallel_studio_xe_2016_update2/compilers_and_libraries_2016.2.181/linux/compiler/lib/intel64/libifcore_pic.a(for_main.o):for_main.c:(.text+0x0):
> > first defined here
> > In function `main':
> > for_main.c:(.text+0x3e): undefined reference to `MAIN__'
> > I searched for this and I found that the option "-nofor_main" should be
> > added when compiling with ifort, but our code is written only in C an
> C++.
> > The FORTRAN compiler is used when PETSc compiles MUMPS. So I dont know if
> > this would work for this case.
> > The configure.log file and the log of the compilation giving the error
> are
> > attached to this message. These logs were obtained in a cluster, I'm
> > getting the same error on my personal computer with a 2020 version of the
> > Intel Parallel Studio.
> > thank you for any help on this
> > Alfredo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200521/4fd11962/attachment.html>
