[petsc-users] make check vs make test
Adrian Croucher
a.croucher at auckland.ac.nz
Wed May 20 22:59:49 CDT 2020
hi
In the latest PETSc version (3.13), 'make test' seems to be doing a much
more comprehensive set of tests than it used to.
That is ok except that I have a CI pipeline which builds PETSc and my
code, and then runs my tests. It also does a 'make test' after building
PETSc and that is now making the CI time out.
At the end of the PETSc build process it says I should run 'make check'
to "check if the libraries are working". I can't seem to find any
documentation on what 'make check' actually does, but it looks like it
runs a much reduced set of tests. Currently I am running both 'make
check' and 'make test'.
For this use case should it be sufficient to run 'make check' and omit
'make test'?
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
