[petsc-users] Sanitize Options Passed "Through" Petsc
    Jed Brown
    jed at jedbrown.org
    Tue May 19 16:57:19 CDT 2020
Namespace the PETSc options or use something other than the command line
(e.g., PETSC_OPTIONS env variable or a file).  There is no way to know
in advance all the options that could be requested through the PETSc
options system.  If the other app has a well-defined list of allowed
options, you could whitelist those at program startup and leave
everything else for PETSc.
Jacob Faibussowitsch <jacob.fai at gmail.com> writes:
> Hello all,
> I use petsc/slepc as the driver for running another library code and would like to pass command line options through but this library takes the approach of erroring out when it encounters an unknown option (i.e. some option that petsc would use but it would not). My current way of dealing with the problem is to run my script with “-help” option to save the output in a separate ascii file, then next time the program is run remove any options found in the file from the options passed through.
> Clearly this isn’t exactly a bulletproof scheme, so I’m wondering if there is a smarter way to do it.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
