[petsc-users] Treatment of piecewise residual function in SNES
Yingjie Wu yjwu16 at gmail.com
Wed May 6 09:25:26 CDT 2020
I think my residual functions are piecewise but discontinuous functions.
Although the residual function is discontinuous, there is little difference
between the residuals in different segments at the piecewise point. This is
the first time I have encountered such a problem, as I described before, I
solve the two-phase problem of water, which involves the disappearance and
generation of phases, so the conservation equation is piecewised. I looked
at some of the papers about the piecewise residual function in Newton
method, which refers to the peiecewise smooth function, I do not really
understand the different treatment in Newton method between the two kinds
of functions.
Thank you very much for your reply, I know little about this field and hope
to get some suggestions.
Yingjie
Matthew Knepley <knepley at gmail.com> 于2020年5月6日周三 下午6:38写道:
> Do you mean a piecewise smooth function, with a discontinuous derivative,
> or a piecewise function which is itself discontinuous?
>   Thanks,
>      Matt
> On Tue, May 5, 2020 at 11:05 PM Yingjie Wu <yjwu16 at gmail.com> wrote:
>> Dear PETSc developers
>> Hi,
>> I have been using SNES to solve a nonlinear problem recently, but this
>> nonlinear problem is different from the ordinary problem, in which its
>> residual function is a piecewise function. I have the following questions
>> during calculation:
>>    1. As I am not very familiar with the jacobian matrix construction of
>>    this piecewise function, I used the - snes_fd. However, the result is not
>>    converged in process of calculation. I don't know if it's the piecewise
>>    function problem or other errors.
>>    2. For this piecewise function problem, it is actually determination
>>    of the residual function according to the current solution vector. Should I
>>    determine the piecewise function before each Newton step begins, or add
>>    judgment directly to the evaluation function to form the piecewise
>>    function? Now I'm adding judgment directly to the evaluation function to
>>    form a piecewise function.
>>    3. Are there some special treatment for piecewise residual functions
>>    in the SNES?
>> I'm dealing with a water two-phase flow problem, which is difficult to
>> describe in detail because the model is relatively complex. For the first
>> time I have encountered this problem and hope to get some advice or
>> information.
>> Thanks,
>> Yingjie
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200506/aab8b91f/attachment.html>
