[petsc-users] Treatment of piecewise residual function in SNES
    Matthew Knepley
    knepley at gmail.com
    Wed May  6 05:38:35 CDT 2020
Do you mean a piecewise smooth function, with a discontinuous derivative,
or a piecewise function which is itself discontinuous?
     Matt
On Tue, May 5, 2020 at 11:05 PM Yingjie Wu <yjwu16 at gmail.com> wrote:
> Dear PETSc developers
> Hi,
> I have been using SNES to solve a nonlinear problem recently, but this
> nonlinear problem is different from the ordinary problem, in which its
> residual function is a piecewise function. I have the following questions
> during calculation:
>    1. As I am not very familiar with the jacobian matrix construction of
>    this piecewise function, I used the - snes_fd. However, the result is not
>    converged in process of calculation. I don't know if it's the piecewise
>    function problem or other errors.
>    2. For this piecewise function problem, it is actually determination
>    of the residual function according to the current solution vector. Should I
>    determine the piecewise function before each Newton step begins, or add
>    judgment directly to the evaluation function to form the piecewise
>    function? Now I'm adding judgment directly to the evaluation function to
>    form a piecewise function.
>    3. Are there some special treatment for piecewise residual functions
>    in the SNES?
> I'm dealing with a water two-phase flow problem, which is difficult to
> describe in detail because the model is relatively complex. For the first
> time I have encountered this problem and hope to get some advice or
> information.
> Thanks,
> Yingjie
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200506/f2f4924f/attachment.html>
