[petsc-users] [petsc4py] Assembly fails
Alejandro Aragon - 3ME A.M.Aragon at tudelft.nl
Sat Mar 28 12:22:32 CDT 2020
Hi Lisandro,
Thanks for your reply. Waiting for PETSc 3.13 and the matching petsc4py 3.13 would work just fine for me. It would be nice, however, to know what’s causing the issue.
Best,
—Alejandro
On 27 Mar 2020, at 18:39, Lisandro Dalcin <dalcinl at gmail.com<mailto:dalcinl at gmail.com>> wrote:
On Fri, 27 Mar 2020 at 17:10, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Fri, Mar 27, 2020 at 3:31 AM Alejandro Aragon - 3ME <A.M.Aragon at tudelft.nl<mailto:A.M.Aragon at tudelft.nl>> wrote:
Dear Matthew,
Thanks for your email. I have attached the python code that reproduces the following error in my computer:
I think I see the problem. There were changes in DM in order to support fields which only occupy part of the domain.
Now you need to tell the DM about the fields before it builds a Section. I think in your code, you only need
  f = PetscContainer()
  f.setName("potential")
  dm.addField(field = f)
Except that petsc4py do not expose a Container class :-(
@Alejandro, PETSc 3.13 is about to be released. Once that is done, we have a small windows to make a few enhancements in petsc4py before releasing the matching petsc4py-3.13 that you can use to upgrade your code. Would that work for you?
Lisandro Dalcin
Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/<https://urldefense.proofpoint.com/v2/url?u=http-3A__ecrc.kaust.edu.sa_&d=DwMFaQ&c=XYzUhXBD2cD-CornpT4QE19xOJBbRy-TBPLK0X9U2o8&r=U1Pry6bTDByPujjSnTcPY6KNXqrym6APfmtom-lIPFA&m=HY1fXOtcfYiUbV-8yfY4iJFGJrKGJpALLyYLQbL63n0&s=U7jpaATgQWRTP15qiro-xfWS9FZ2fqFxRM_t-Zj6g5w&e=>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200328/fb0eed3c/attachment.html>
