[petsc-users] [petsc4py] Assembly fails
Lisandro Dalcin dalcinl at gmail.com
Fri Mar 27 12:39:53 CDT 2020
On Fri, 27 Mar 2020 at 17:10, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Mar 27, 2020 at 3:31 AM Alejandro Aragon - 3ME <
> A.M.Aragon at tudelft.nl> wrote:
>> Dear Matthew,
>> Thanks for your email. I have attached the python code that reproduces
>> the following error in my computer:
> I think I see the problem. There were changes in DM in order to support
> fields which only occupy part of the domain.
> Now you need to tell the DM about the fields before it builds a Section. I
> think in your code, you only need
>   f = PetscContainer()
>   f.setName("potential")
>   dm.addField(field = f)
Except that petsc4py do not expose a Container class :-(
@Alejandro, PETSc 3.13 is about to be released. Once that is done, we have
a small windows to make a few enhancements in petsc4py before releasing the
matching petsc4py-3.13 that you can use to upgrade your code. Would that
work for you?
Lisandro Dalcin
Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200327/df7dddb8/attachment.html>
