[petsc-users] [petsc4py] Assembly fails
Alejandro Aragon - 3ME
A.M.Aragon at tudelft.nl
Thu Mar 26 06:07:09 CDT 2020
Hi Lisandro,
Yes, that is the case, I ended up installing following your instructions since it was the simplest way to do it. I was actually trying to install PETSc 3.11 and then to install petsc4py using pip and providing environmental variables for PETSC_DIR and PETSC_ARCH, but I couldn’t make it work. Later Lisandro pointed out I could not use Python 3.8 for this.
Best,
— Alejandro
On 26 Mar 2020, at 12:00, Lisandro Dalcin <dalcinl at gmail.com<mailto:dalcinl at gmail.com>> wrote:
On Wed, 25 Mar 2020 at 19:38, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
It looks like you have an inconsistent build, or a memory overwrite. Since you are in Python, I suspect the former. Can you build
PETSc from scratch and try this? Does it work in serial? Can you send a small code that reproduces this?
Well, I think Alejandro installed PETSc/petsc4py via pip as per my instructions. Can you confirm, Alejandro?
Lisandro Dalcin
Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/<https://urldefense.proofpoint.com/v2/url?u=http-3A__ecrc.kaust.edu.sa_&d=DwMFaQ&c=XYzUhXBD2cD-CornpT4QE19xOJBbRy-TBPLK0X9U2o8&r=U1Pry6bTDByPujjSnTcPY6KNXqrym6APfmtom-lIPFA&m=PWvcuQOFNDRTToOkEIL6eGXAKcbV_DG6KvK0ZhwMt24&s=VxgF-QiIr7bHGu42LRzRIPR5_WoGLSSDQdfhHp4qOSg&e=>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200326/c87c51f6/attachment-0001.html>
