[petsc-users] [petsc4py] Assembly fails
Lisandro Dalcin dalcinl at gmail.com
Thu Mar 26 06:00:28 CDT 2020
On Wed, 25 Mar 2020 at 19:38, Matthew Knepley <knepley at gmail.com> wrote:
> It looks like you have an inconsistent build, or a memory overwrite. Since
> you are in Python, I suspect the former. Can you build
> PETSc from scratch and try this? Does it work in serial? Can you send a
> small code that reproduces this?
Well, I think Alejandro installed PETSc/petsc4py via pip as per my
instructions. Can you confirm, Alejandro?
Lisandro Dalcin
Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200326/4a743a0d/attachment.html>
