[petsc-users] Construct Matrix based on row and column values
Elias Karabelas karabelaselias at gmail.com
Mon Mar 23 07:31:26 CDT 2020
Dear Matt,
I've just found this answer from 2014
https://lists.mcs.anl.gov/pipermail/petsc-users/2014-August/022450.html
wondering if this would theoretically work.
And the thing with this FCT-Schemes is, that they're build on purely
algebraic considerations (like AMG) so I don't want to break it back
down to mesh information if possible at all.
Best regards
Elias
On 23/03/2020 13:02, Matthew Knepley wrote:
> On Mon, Mar 23, 2020 at 7:46 AM Elias Karabelas
> <karabelaselias at gmail.com <mailto:karabelaselias at gmail.com>> wrote:
>     Dear Users,
>     I want to implement a FCT (flux corrected transport) scheme with
>     PETSc.
>     To this end I have amongst other things create a Matrix whose entries
>     are given by
>     L_ij = -max(0, A_ij, A_ji) for i neq j
>     L_ii = Sum_{j=0,..n, j neq i} L_ij
>     where Mat A is an (non-symmetric) Input Matrix created beforehand.
>     I was wondering how to do this. My first search brought me to
>     https://www.mcs.anl.gov/petsc/petsc-current/src/mat/examples/tutorials/ex16.c.html
>     but this just goes over the rows of one matrix to set new values
>     and now
>     I would need to run over the rows and columns of the matrix. My
>     Idea was
>     to just create a transpose of A and do the same but then the
>     row-layout
>     will be different and I can't use the same for loop for A and AT and
>     thus also won't be able to calculate the max's above.
>     Any help would be appreciated
> I think it would likely be much easier to write your algorithm
> directly on the mesh, rather than using matrices, since the locality
> information is explicit with the mesh, but has to be reconstructed
> with the matrix.
> The problem here is that in parallel there would be no easy way to get
> the halo you need using a matrix. You
> really want the ghosted space for assembly, and that is provided by
> the DM objects. Does this make sense?
> Unless anybody in PETSc has a better idea.
>   Thanks,
>      Matt
>     Best regards
>     Elias
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200323/0881daa2/attachment.html>
