[petsc-users] Inquiry about the interpolation and restriction matrix for PCMG
    Matthew Knepley
    knepley at gmail.com
    Fri Mar 20 20:50:37 CDT 2020
On Fri, Mar 20, 2020 at 6:26 PM Xiaodong Liu <xliu29 at ncsu.edu> wrote:
> Hi, Petsc team,
> I am practising  PCMG using the following case (3DQ1)
> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex45.c.html
> I have several questions.
> *1)  About the interpolation and restriction matrix*
> For both Galerkin and non-Galerkin type, the interpolation matrix P  is
> based on the trilinear interpolation (*I found the source code*) and the
> restriction one R is 1/8*P^T?
> *Could you please tell me where  the source code to define the restriction
> matrix is? *
> *2) About the operator on the coarse level*
>  It is straightforward to calculate the operator on the coarse level  for
> Galerkin type by R*A*P. But how did you define the operator for
> non-Galerkin type?
non-Galerkin usually means rediscretization, where the user explicitly
supplies the coarser operations, using
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCMGSetOperators.html
      Matt
> Did you use DMRestrict ? Could you please tell me where is the source code
> to define
> (*link->restricthook)(fine,restrct,rscale,inject,coarse,link->ctx);
> in
> 2933: PetscErrorCode DMRestrict(DM fine,Mat restrct,Vec rscale,Mat
> inject,DM coarse)
> 2934: {
> 2935:   PetscErrorCode    ierr;
> 2936:   DMCoarsenHookLink link;
> 2939:   for (link=fine->coarsenhook; link; link=link->next) {
> 2940:     if (link->restricthook) {
> 2941:
> 2942:     }
> 2943:   }
> 2944:   return(0);
> 2945: }
> on
> https://www.mcs.anl.gov/petsc/petsc-current/src/dm/interface/dm.c.html#DMRestrict
> Thanks a lot !
> Take care!
> Xiaodong
> Xiaodong Liu, PhD
> X: Computational Physics Division
> Los Alamos National Laboratory
> P.O. Box 1663,
> Los Alamos, NM 87544
> 505-709-0534
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200320/27665b80/attachment.html>
