[petsc-users] Inquiry about the interpolation and restriction matrix for PCMG
Mark Adams
mfadams at lbl.gov
Fri Mar 20 19:24:22 CDT 2020
On Fri, Mar 20, 2020 at 6:26 PM Xiaodong Liu <xliu29 at ncsu.edu> wrote:
> Hi, Petsc team,
> I am practising PCMG using the following case (3DQ1)
> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex45.c.html
> I have several questions.
> *1) About the interpolation and restriction matrix*
> For both Galerkin and non-Galerkin type, the interpolation matrix P is
> based on the trilinear interpolation (*I found the source code*) and the
> restriction one R is 1/8*P^T?
That sounds right if the course grid operator is not Galerkin. If it
Galerkin you do not need the 1/8 scaling.
> *Could you please tell me where the source code to define the restriction
> matrix is? *
> *2) About the operator on the coarse level*
> It is straightforward to calculate the operator on the coarse level for
> Galerkin type by R*A*P. But how did you define the operator for
> non-Galerkin type? Did you use DMRestrict ?
When I have these questions I just search for where restricthook is set. Or
run a debugger and step through the code. Maybe someone else knows this.
> Could you please tell me where is the source code to define
> (*link->restricthook)(fine,restrct,rscale,inject,coarse,link->ctx);
> in
> 2933: PetscErrorCode DMRestrict(DM fine,Mat restrct,Vec rscale,Mat
> inject,DM coarse)
> 2934: {
> 2935: PetscErrorCode ierr;
> 2936: DMCoarsenHookLink link;
> 2939: for (link=fine->coarsenhook; link; link=link->next) {
> 2940: if (link->restricthook) {
> 2941:
> 2942: }
> 2943: }
> 2944: return(0);
> 2945: }
> on
> https://www.mcs.anl.gov/petsc/petsc-current/src/dm/interface/dm.c.html#DMRestrict
> Thanks a lot !
> Take care!
> Xiaodong
> Xiaodong Liu, PhD
> X: Computational Physics Division
> Los Alamos National Laboratory
> P.O. Box 1663,
> Los Alamos, NM 87544
> 505-709-0534
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200320/1cd2ff5f/attachment-0001.html>
