[petsc-users] Rebuilding libmesh
Fande Kong
fdkong.jd at gmail.com
Wed Mar 18 19:06:36 CDT 2020
HI Lin,
Do you have a home-brew installed MPI?
configure:6076: mpif90 -v >&5
mpifort for MPICH version 3.3
Reading specs from
/home/lin/.linuxbrew/Cellar/gcc/5.5.0_7/bin/../lib/gcc/x86_64-unknown-linux-gnu/5.5.0/specs
MOOSE environment package should carry everything you need: compiler, mpi,
and petsc.
You could home-brew uninstall your mpi, and retry.
Fande,
On Wed, Mar 18, 2020 at 5:57 PM Jed Brown <jed at jedbrown.org> wrote:
> Alexander Lindsay <alexlindsay239 at gmail.com> writes:
> > Does anyone have a suggestion for this compilation error from
> petscconf.h?
> > Sorry this is with a somewhat old PETSc version:
> > configure:34535: checking whether we can compile a trivial PETSc program
> > configure:34564: mpicxx -c -std=gnu++11
> What do you get with `mpicxx --version`?
> This is usually a result of configuring PETSc with a different compiler
> version than you use to run.
> > -I/opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt/include
> > -I/opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt//include
> > -I/opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt/include conftest.cpp
> >&5
> > In file included from
> > /opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt/include/petscsys.h:14:0,
> > from
> > /opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt/include/petscbag.h:4,
> > from
> > /opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt/include/petsc.h:5,
> > from conftest.cpp:144:
> /opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt/include/petscconf.h:85:36:
> > error: expected '}' before '__attribute'
> > #define PETSC_DEPRECATED_ENUM(why) __attribute((deprecated))
> /opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt/include/petscksp.h:430:76:
> > note: in expansion of macro 'PETSC_DEPRECATED_ENUM'
> > #define KSP_DIVERGED_PCSETUP_FAILED_DEPRECATED
> > PETSC_DEPRECATED_ENUM("Use KSP_DIVERGED_PC_FAILED (since v3.11)")
> /opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt/include/petscksp.h:452:15:
> > note: in expansion of macro 'KSP_DIVERGED_PCSETUP_FAILED_DEPRECATED'
> > KSP_DIVERGED_PCSETUP_FAILED_DEPRECATED = -11,
> > On Wed, Mar 18, 2020 at 2:55 PM Lin <y7762516 at gmail.com> wrote:
> >> Hi, all,
> >> I met a problem with
> >> error: *** PETSc was not found, but --enable-petsc-required was
> specified.
> >> when I reinstalled MOOSE. However, I had been using MOOSE with no issues
> >> previously. Does someone know how to solve it? My system is Ubuntu
> 18.04.
> >> The error is listed as following:
> >> Found valid MPI installation...
> >> note: using /opt/moose/mpich-3.3/gcc-9.2.0/include/mpi.h
> >> checking mpi.h usability... yes
> >> checking mpi.h presence... yes
> >> checking for mpi.h... yes
> >> checking
> /opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt//include/petscversion.h
> >> usability... yes
> >> checking
> >> presence... yes
> >> checking for
> /opt/moose/petsc-3.11.4/mpich-3.3_gcc-9.2.0-opt//include/petscversion.h...
> >> yes
> >> <<< Found PETSc 3.11.4 installation in /opt/moose/petsc-3.11.4/mpich-3.3
> >> _gcc-9.2.0-opt ... >>>
> >> checking whether we can compile a trivial PETSc program... no
> >> checking for TAO support via PETSc... no
> >> configure: error: *** PETSc was not found, but --enable-petsc-required
> >> was specified.
> >> make: *** No targets specified and no makefile found. Stop.
> >> Besides, I attached my libMesh configure log file in the email.
> >> Regards,
> >> Lin
> >> You received this message because you are subscribed to the Google
> Groups
> >> "moose-users" group.
> >> To unsubscribe from this group and stop receiving emails from it, send
> an
> >> email to moose-users+unsubscribe at googlegroups.com.
> >> To view this discussion on the web visit
> https://groups.google.com/d/msgid/moose-users/db12322c-eae6-4ed4-b54f-3ab5e118f466%40googlegroups.com
> https://groups.google.com/d/msgid/moose-users/db12322c-eae6-4ed4-b54f-3ab5e118f466%40googlegroups.com?utm_medium=email&utm_source=footer
> Groups "moose-users" group.
> an email to moose-users+unsubscribe at googlegroups.com.
> https://groups.google.com/d/msgid/moose-users/CANFcJrE%2BURQoK0UiqBEsB9yZ2Qbbj24W_S_n8qYzxOBtD41Yzw%40mail.gmail.com
> You received this message because you are subscribed to the Google Groups
> To unsubscribe from this group and stop receiving emails from it, send an
> https://groups.google.com/d/msgid/moose-users/87r1xpw71l.fsf%40jedbrown.org
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200318/2521aa3f/attachment-0001.html>
