[petsc-users] Does Petsc provide the non-KSP iterative solver, e.g., SOR, for a linear system.
Xiaodong Liu
xliu29 at ncsu.edu
Wed Mar 18 12:40:14 CDT 2020
Thanks, Patrick. I will try your suggestion Richardson/SOR.
Xiaodong Liu, PhD
X: Computational Physics Division
Los Alamos National Laboratory
P.O. Box 1663,
Los Alamos, NM 87544
505-709-0534
On Wed, Mar 18, 2020 at 10:34 AM Patrick Sanan <patrick.sanan at gmail.com>
wrote:
> I may not be interpreting the question correctly, but you can use SOR as
> the only preconditioner, e.g.
> -ksp_type gmres -pc_type sor
> or you can use Richardson/SOR as your multigrid smoother, which might be
> what you're asking for
> -ksp_type gmres -pc_type mg -pc_mg_levels 3
> -mg_levels_ksp_type richardson -mg_levels_pc_type SOR
> Am Mi., 18. März 2020 um 18:19 Uhr schrieb Xiaodong Liu <xliu29 at ncsu.edu>:
>> Hi, Petsc team,
>> I am doing something using multigrid as a preconditioner for GMRES. From
>> the official case,
>> most use KSP (Chebyshev) and PC (SOR) for solving the preconditioning
>> system for every level of multigrid except the coarse one.
>> -mg_levels_ksp_type Chebyshev -mg_levels_pc_type SOR
>> I would like to use SOR for solving the preconditioning system
>> directly. I can not find that Petsc supports non-KSP iterative solver for a
>> linear system, right?
>> If I am wrong, please let me know.
>> Xiaodong Liu, PhD
>> P.O. Box 1663,
>> 505-709-0534
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200318/276b69e7/attachment.html>
