[petsc-users] About the initial guess for KSP method.
Xiaodong Liu xliu29 at ncsu.edu
Tue Mar 17 10:19:08 CDT 2020
Thanks. It is very useful.
Xiaodong Liu, PhD
X: Computational Physics Division
Los Alamos National Laboratory
P.O. Box 1663,
Los Alamos, NM 87544
505-709-0534
On Tue, Mar 17, 2020 at 8:17 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 16, 2020 at 4:32 PM Xiaodong Liu <xliu29 at ncsu.edu> wrote:
>> Hi, all,
>> I am testing KSPSetInitialGuessNonzero using the case
>> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex50.c.html
>> This case is special. WIth zero initial guess, 1 iteration can deliver
>> the exact solution. But when I tried true for KSPSetInitialGuessNonzero, it
>> shows the same convergence history as false.
>> Does the code  change KSPSetInitialGuessNonzero to false automatically?
> For that flag to make any difference, you have to pass in a nonzero vector
> to KSPSolve(). This example does not do that.
> Were you doing that?
>   Thanks,
>      Matt
>> Take care.
>> Thanks,
>> Xiaodong Liu, PhD
>> P.O. Box 1663,
>> 505-709-0534
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200317/308b3fb6/attachment.html>
